Setting tolerances for multigrid
Knut Erik Teigen knutert at stud.ntnu.no
Sun Jun 17 03:47:39 CDT 2007
Ok, I've attached two files, one with
./run -dmmg_galerkin -dmmg_nlevels 1 -ksp_type gmres -pc_type lu
-ksp_truemonitor -ksp_converged_reason > lev1
and one with
./run -dmmg_galerkin -dmmg_nlevels 2 -ksp_type gmres -pc_type lu
-mg_levels_1_ksp_type gmres -mg_levels_1_pc_type lu
-ksp_converged_reason -ksp_truemonitor > lev2
The relative residual is 1.e-12, and I am using
KSPSetInitialGuessNonzero.
I've also printed the solution, and if you diff the two files, you can
see that there is a large difference in the third step, e.g. 71.7852 vs.
70.9845. This shouldn't happen, even with a true residual of 1.e-5?
-Knut Erik-
On Sat, 2007-06-16 at 16:56 -0500, Barry Smith wrote:
> On Sat, 16 Jun 2007, Knut Erik Teigen wrote:
> > On Fri, 2007-06-15 at 14:30 -0500, Barry Smith wrote:
> > >   What happens if you run the two level with -ksp_rtol 1.e-12
> > The exact same thing happens. At the third time step, the solution with
> > two levels begin to deviate from the one with one level.
> > >   BTW: when you just change -dmmg_nlevels from 1 to 2 you are now
> > > solving a NEW problem that has twice as many points in each direction,
> > > this can also effect the time-stepping. You can use -dmmg_nlevels 2
> > > -pc_type lu to compare with the -dmmg_nlevels 2
> > I forgot to mention that I adjust the coarsest level according to the
> > number of levels, so that the finest level always contains the same
> > amount of points. I.e. with one level it is 65x129, with two 33x65 and
> > so on.
> > >   Always verify things with a direct solver before using multigrid
> > > or any other iterative linear solver. Multigrid is ONLY an optimization
> > > (faster, less memory), debug BEFORE turning on the optimizations.
> > Yes, I've already done this. With a direct solver, I get the same
> > solution as with one level. Since multigrid is only an optimization as
> > you mention, I don't understand why the solution should be different
> > when running with two or more levels as opposed to only one.
> > Here's the output when running with -pc_type lu. As you can see, with
> > two levels, suddenly more iterations are needed for the third step.
> > -dmmg_nlevels 1
> >  Start of time loop:
> >  L-s reinit converged after   10 steps with norm  1.716E-09
> >   0 KSP preconditioned resid norm 1.366287028032e+04 true resid norm 3.168341703825e+08 ||Ae||/||Ax|| 1.000000000000e+00
> >   1 KSP preconditioned resid norm 3.325862387561e+02 true resid norm 8.783238319618e-07 ||Ae||/||Ax|| 2.772187832207e-15
> >   2 KSP preconditioned resid norm 4.237324220037e-10 true resid norm 9.365968491320e-07 ||Ae||/||Ax|| 2.956110598807e-15
> > Linear solve converged due to CONVERGED_RTOL
>     0 KSP preconditioned resid norm 1.366743784848e+04 true resid norm 3.168385551957e+08 ||Ae||/||Ax|| 1.000000000000e+00
> >   1 KSP preconditioned resid norm 3.578541063222e+02 true resid norm 3.047639475331e-06 ||Ae||/||Ax|| 9.618903461571e-15
> >   2 KSP preconditioned resid norm 2.490853654289e-10 true resid norm 2.047397542219e-06 ||Ae||/||Ax|| 6.461958333808e-15
> >   0 KSP preconditioned resid norm 1.373641039770e+04 true resid norm 4.083933364397e+08 ||Ae||/||Ax|| 1.000000000000e+00
> >   1 KSP preconditioned resid norm 2.756300642422e+02 true resid norm 1.333942531534e-06 ||Ae||/||Ax|| 3.266318062786e-15
> >   2 KSP preconditioned resid norm 1.967864218276e-09 true resid norm 4.708778143639e-06 ||Ae||/||Ax|| 1.153000728339e-14
> > -dmmg_nlevels 2
> >  Start of time loop:
> >   1 KSP preconditioned resid norm 2.826990181167e+02 true resid norm 3.621921471554e+07 ||Ae||/||Ax|| 8.868708542429e-02
> >   2 KSP preconditioned resid norm 2.151728459050e+02 true resid norm 5.126312558070e+05 ||Ae||/||Ax|| 1.255239030774e-03
> >   3 KSP preconditioned resid norm 9.420491033127e+01 true resid norm 7.221320422298e+02 ||Ae||/||Ax|| 1.768226799500e-06
> > 118 KSP preconditioned resid norm 2.011348229632e-04 true resid norm 1.933530019765e-05 ||Ae||/||Ax|| 4.734479843920e-14
> > 119 KSP preconditioned resid norm 1.002113384828e-04 true resid norm 1.933774400466e-05 ||Ae||/||Ax|| 4.735078239337e-14
> > 120 KSP preconditioned resid norm 3.976002405523e-07 true resid norm 1.947236185243e-05 ||Ae||/||Ax|| 4.768041031762e-14
>   The true residuals both me, they are very big at "convergence" 1.e-5? Are you using KSPSetInitialGuessNonzero() and
> using the previous solution as initial guess?
>   Run with -ksp_type gmres -pc_type lu -ksp_monitor_true_residual. I bet the converged true residual is
> much better. Send the output.
>    Barry
> > >    Barry
> > > On Fri, 15 Jun 2007, Knut Erik Teigen wrote:
> > > > When running with those options I get this after the first timestep for
> > > > both one and two levels:
> > > > 159 KSP preconditioned resid norm 1.397494864058e-07 true resid norm
> > > > 4.996893774970e-02 ||Ae||/||Ax|| 1.577132216812e-10
> > > > However, after the second timestep they start to get different.
> > > > With two levels the norm is actually lower, but still, the computation
> > > > diverges after about 6 time steps. With one level the computation runs
> > > > smoothly. Here are the numbers:
> > > > -dmmg_nlevels 1
> > > >   0 KSP preconditioned resid norm 1.674785901465e+02
> > > > true resid norm 4.083933362528e+08 ||Ae||/||Ax|| 1.000000000000e+00
> > > >   1 KSP preconditioned resid norm 6.256839347623e+01
> > > > true resid norm 4.220478752135e+07 ||Ae||/||Ax|| 1.033434774147e-01
> > > > 159 KSP preconditioned resid norm 1.318896741223e-07
> > > > true resid norm 5.104451971417e-02 ||Ae||/||Ax|| 1.249886204866e-10
> > > > -dmmg_nlevels 2
> > > >   1 KSP preconditioned resid norm 6.252455641723e+01
> > > > true resid norm 5.561545924132e+07 ||Ae||/||Ax|| 1.361811134129e-01
> > > > 159 KSP preconditioned resid norm 1.305901659826e-07
> > > > true resid norm 4.297164043386e-02 ||Ae||/||Ax|| 1.052212086224e-10
> > > > -Knut Erik-
> > > > On Fri, 2007-06-15 at 10:10 -0500, Barry Smith wrote:
> > > > >   You need to make sure the linear solvers are converging properly
> > > > > before even worrying about time-stepping. Run with -ksp_monitor_true_residual
> > > > > (-ksp_truemonitor on older versions of PETSc) and -ksp_converged_reason
> > > > >    Barry
> > > > > > The computation runs just fine with -dmmg_nlevels 1.
> > > > > > I use a grid of 65x129, with three levels, so that the coarsest grid is
> > > > > > 17x33.
> > > > > > I've diffed the solutions, and they are equal for the first two time
> > > > > > steps, but then they start to differ somewhat. Here is an excerpt:
> > > > > > -dmmg_nlevels 1:
> > > > > > 65.0427492820557        65.0216231814457      64.9793945321386
> > > > > > -dmmg_nlevels 3:
> > > > > > 65.0920864319067        65.0711253401585      65.0292265582817
> > > > > > Using 2 or 4 levels produce the same result as 3 levels.
> > > > > > -Knut Erik-
> > > > > > On Fri, 2007-06-15 at 10:21 +0200, Matthew Knepley wrote:
> > > > > > > This does not sound right to me. I think something must be
> > > > > > > configured incorrectly. All MG does is accelerate the solution
> > > > > > > of the fine grid problem. I think something must be wrong with
> > > > > > > the specification here. It is easy to check. Run with -dmmg_nlevels 1
> > > > > > > which just solves on the fine grid.
> > > > > > >   Matt
> > > > > > > On 6/15/07, Knut Erik Teigen <knutert at stud.ntnu.no> wrote:
> > > > > > > > Thanks, Matthew. It seems like the tolerances weren't my problem,
> > > > > > > > though. Even with a tolerance of 1e-10, the computation diverges after
> > > > > > > > only a few time steps when using multigrid. With ordinary linear
> > > > > > > > solvers, I can use a tolerance of 1e-4 and still get a satisfactory
> > > > > > > > solution.
> > > > > > > > Could it be that the Galerkin approximation for the coarser levels is
> > > > > > > > too inaccurate for my problem?
> > > > > > > > -Knut Erik-
> > > > > > > > On Thu, 2007-06-14 at 11:32 -0500, Matthew Knepley wrote:
> > > > > > > > > On 6/14/07, Knut Erik Teigen <knutert at stud.ntnu.no> wrote:
> > > > > > > > > > Hello,
> > > > > > > > > > How do I set the tolerances for the KSP solvers when using the
> > > > > > > > > > DMMG routines without using command line arguments? It seems that
> > > > > > > > > > I can use the argument -ksp_rtol on the command line, but in the code I
> > > > > > > > > > can't use KSPSetTolerances since I don't have access to the KSP solver
> > > > > > > > > > context?
> > > > > > > > > You can use DMMGGetKSP() for the finest level, and dmmg[level]->ksp for
> > > > > > > > > any others.
> > > > > > > > > > Also, I see there is a reference to the function DMMGSetUseGalerkin
> > > > > > > > > > in the source code, but I can't find the documentation for it.
> > > > > > > > > > Does this function not exist yet? Again I would like to use
> > > > > > > > > > -dmmg_galerkin, but setting it in the code instead of on the command
> > > > > > > > > > line.
> > > > > > > > > I think you want this:
> > > > > > > > > http://www-unix.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/DA/DMMGSetUseGalerkinCoarse.html
> > > > > > > > >   Matt
> > > > > > > > > > Regards,
> > > > > > > > > > Knut Erik Teigen
  nlevels           1
 coarsest_x,coarsest_y:          65         129
 Using SSP-RK3()4 (SSP) scheme for system           1
 Using SSP-RK2()4 (SSP) scheme for system           2
 Using SSP-RK3()4 (SSP) scheme for system           3
 u                   : is f-variable number:    1
 v                   : is f-variable number:    2
 p                   : is f-variable number:    3
 fi                  : is f-variable number:    4
 Initial configuration: Rising bubble
 Using CFL-number=  0.3000
 Exact area, phase 1: 3.491E-05
 Numerical area, phase 1: 3.499E-05
 Using WENO boundary trick!
 Writing inputfile to file: out.inp
 c_conv= 0.00E+00 c_visc= 6.07E+02 c_grav= 1.78E+02 c_st= 1.58E+03
 Start of time loop:
  0 KSP preconditioned resid norm 3.168341703825e+08 true resid norm 3.168341703825e+08 ||Ae||/||Ax|| 1.000000000000e+00
  1 KSP preconditioned resid norm 7.830661072700e-07 true resid norm 7.337644742621e-07 ||Ae||/||Ax|| 2.315925941246e-15
Process [0]
66.5366
66.5153
66.473
66.4098
66.326
66.222
66.0984
65.9559
65.7952
65.6174
65.4234
65.2146
64.9923
64.7582
64.514
64.2616
64.0031
63.7408
63.4772
63.2148
62.9562
62.7043
62.4619
62.2317
62.0167
61.8195
61.6427
61.4887
61.3596
61.2572
61.1829
61.138
61.1229
61.138
61.1829
61.2572
61.3596
61.4887
61.6427
61.8195
62.0167
62.2317
62.4619
62.7043
62.9562
63.2148
63.4772
63.7408
64.0031
64.2616
64.514
64.7582
64.9923
65.2146
65.4234
65.6174
65.7952
65.9559
66.0984
66.222
66.326
66.4098
66.473
66.5153
66.5366
63.5162
63.4949
63.4524
63.3888
63.3046
63.2001
63.0758
62.9324
62.7708
62.5918
62.3966
62.1864
61.9625
61.7266
61.4804
61.2259
60.9651
60.7004
60.4341
60.169
59.9076
59.6528
59.4075
59.1745
58.9568
58.757
58.5778
58.4216
58.2906
58.1867
58.1114
58.0657
58.0504
58.0657
58.1114
58.1867
58.2906
58.4216
58.5778
58.757
58.9568
59.1745
59.4075
59.6528
59.9076
60.169
60.4341
60.7004
60.9651
61.2259
61.4804
61.7266
61.9625
62.1864
62.3966
62.5918
62.7708
62.9324
63.0758
63.2001
63.3046
63.3888
63.4524
63.4949
63.5162
60.5176
60.4961
60.4531
60.3889
60.3038
60.1982
60.0725
59.9276
59.764
59.5829
59.3851
59.172
58.9449
58.7054
58.4553
58.1965
57.9311
57.6614
57.39
57.1193
56.8523
56.5917
56.3406
56.1019
55.8785
55.6735
55.4894
55.3288
55.1941
55.0872
55.0097
54.9627
54.9469
54.9627
55.0097
55.0872
55.1941
55.3288
55.4894
55.6735
55.8785
56.1019
56.3406
56.5917
56.8523
57.1193
57.39
57.6614
57.9311
58.1965
58.4553
58.7054
58.9449
59.172
59.3851
59.5829
59.764
59.9276
60.0725
60.1982
60.3038
60.3889
60.4531
60.4961
60.5176
57.5408
57.5189
57.4754
57.4102
57.3238
57.2166
57.0889
56.9415
56.7752
56.5907
56.3892
56.1718
55.9399
55.6951
55.4391
55.1738
54.9015
54.6243
54.3449
54.066
53.7904
53.521
53.2611
53.0136
52.7818
52.5686
52.3771
52.2099
52.0694
51.9579
51.8769
51.8278
51.8114
51.8278
51.8769
51.9579
52.0694
52.2099
52.3771
52.5686
52.7818
53.0136
53.2611
53.521
53.7904
54.066
54.3449
54.6243
54.9015
55.1738
55.4391
55.6951
55.9399
56.1718
56.3892
56.5907
56.7752
56.9415
57.0889
57.2166
57.3238
57.4102
57.4754
57.5189
57.5408
54.5862
54.5639
54.5195
54.4531
54.3651
54.2556
54.1254
53.9748
53.8047
53.6159
53.4093
53.1863
52.948
52.6961
52.4323
52.1584
51.8767
51.5895
51.2995
51.0093
50.7221
50.4408
50.1689
49.9095
49.6661
49.4419
49.2401
49.0637
48.9154
48.7975
48.7118
48.6599
48.6425
48.6599
48.7118
48.7975
48.9154
49.0637
49.2401
49.4419
49.6661
49.9095
50.1689
50.4408
50.7221
51.0093
51.2995
51.5895
51.8767
52.1584
52.4323
52.6961
52.948
53.1863
53.4093
53.6159
53.8047
53.9748
54.1254
54.2556
54.3651
54.4531
54.5195
54.5639
54.5862
51.6541
51.6314
51.586
51.5181
51.428
51.3159
51.1824
51.0279
50.8532
50.659
50.4463
50.2162
49.97
49.7093
49.4356
49.1509
48.8575
48.5576
48.2541
47.9497
47.6477
47.3512
47.0638
46.7892
46.5308
46.2924
46.0774
45.8891
45.7305
45.6043
45.5125
45.4568
45.4382
45.4568
45.5125
45.6043
45.7305
45.8891
46.0774
46.2924
46.5308
46.7892
47.0638
47.3512
47.6477
47.9497
48.2541
48.5576
48.8575
49.1509
49.4356
49.7093
49.97
50.2162
50.4463
50.659
50.8532
51.0279
51.1824
51.3159
51.428
51.5181
51.586
51.6314
51.6541
48.7452
48.7219
48.6753
48.6057
48.5131
48.398
48.2607
48.1016
47.9215
47.721
47.501
47.2625
47.0069
46.7355
46.45
46.1524
45.8447
45.5295
45.2096
44.8878
44.5675
44.2524
43.946
43.6523
43.3753
43.1191
42.8875
42.6842
42.5128
42.3761
42.2766
42.2162
42.1959
42.2162
42.2766
42.3761
42.5128
42.6842
42.8875
43.1191
43.3753
43.6523
43.946
44.2524
44.5675
44.8878
45.2096
45.5295
45.8447
46.1524
46.45
46.7355
47.0069
47.2625
47.501
47.721
47.9215
48.1016
48.2607
48.398
48.5131
48.6057
48.6753
48.7219
48.7452
45.8599
45.836
45.7881
45.7165
45.6212
45.5026
45.361
45.1968
45.0104
44.8027
44.5743
44.3263
44.0597
43.776
43.4768
43.164
42.8396
42.5063
42.1668
41.8243
41.4823
41.1446
40.8152
40.4984
40.1988
39.9207
39.6688
39.4471
39.2597
39.1101
39.0011
38.9348
38.9125
38.9348
39.0011
39.1101
39.2597
39.4471
39.6688
39.9207
40.1988
40.4984
40.8152
41.1446
41.4823
41.8243
42.1668
42.5063
42.8396
43.164
43.4768
43.776
44.0597
44.3263
44.5743
44.8027
45.0104
45.1968
45.361
45.5026
45.6212
45.7165
45.7881
45.836
45.8599
42.999
42.9743
42.9251
42.8513
42.7531
42.6307
42.4843
42.3143
42.1212
41.9054
41.6677
41.4088
41.13
40.8323
40.5175
40.1872
39.8436
39.4893
39.1271
38.7604
38.3927
38.0283
37.6715
37.3272
37.0003
36.6959
36.4192
36.1752
35.9684
35.8029
35.6821
35.6086
35.5839
35.6086
35.6821
35.8029
35.9684
36.1752
36.4192
36.6959
37.0003
37.3272
37.6715
38.0283
38.3927
38.7604
39.1271
39.4893
39.8436
40.1872
40.5175
40.8323
41.13
41.4088
41.6677
41.9054
42.1212
42.3143
42.4843
42.6307
42.7531
42.8513
42.9251
42.9743
42.999
40.1631
40.1377
40.0869
40.0108
39.9095
39.783
39.6316
39.4554
39.2549
39.0304
38.7824
38.5117
38.2193
37.9062
37.5738
37.2239
36.8586
36.4804
36.0921
35.6973
35.2999
34.9042
34.5152
34.1382
33.7788
33.443
33.1366
32.8655
32.6351
32.4503
32.3152
32.2328
32.2051
32.2328
32.3152
32.4503
32.6351
32.8655
33.1366
33.443
33.7788
34.1382
34.5152
34.9042
35.2999
35.6973
36.0921
36.4804
36.8586
37.2239
37.5738
37.9062
38.2193
38.5117
38.7824
39.0304
39.2549
39.4554
39.6316
39.783
39.9095
40.0108
40.0869
40.1377
40.1631
37.353
37.3268
37.2745
37.196
37.0914
36.9607
36.8039
36.6213
36.4129
36.1791
35.9202
35.6368
35.3296
34.9995
34.6479
34.2763
33.8867
33.4815
33.0638
32.637
32.2053
31.7734
31.3468
30.9313
30.5335
30.1601
29.8181
29.5144
29.2554
29.0472
28.8946
28.8015
28.7702
28.8015
28.8946
29.0472
29.2554
29.5144
29.8181
30.1601
30.5335
30.9313
31.3468
31.7734
32.2053
32.637
33.0638
33.4815
33.8867
34.2763
34.6479
34.9995
35.3296
35.6368
35.9202
36.1791
36.4129
36.6213
36.8039
36.9607
37.0914
37.196
37.2745
37.3268
37.353
34.5694
34.5425
34.4886
34.4077
34.2998
34.1648
34.0026
33.8133
33.5968
33.3533
33.0829
32.786
32.4631
32.1148
31.7423
31.3469
30.9305
30.4955
30.0446
29.5816
29.1108
28.6373
28.167
27.7066
27.2634
26.8454
26.4608
26.1178
25.8243
25.5876
25.4137
25.3074
25.2717
25.3074
25.4137
25.5876
25.8243
26.1178
26.4608
26.8454
27.2634
27.7066
28.167
28.6373
29.1108
29.5816
30.0446
30.4955
30.9305
31.3469
31.7423
32.1148
32.4631
32.786
33.0829
33.3533
33.5968
33.8133
34.0026
34.1648
34.2998
34.4077
34.4886
34.5425
34.5694
31.8133
31.7856
31.7302
31.6469
31.5358
31.3965
31.2289
31.0329
30.8082
30.5548
30.2726
29.9617
29.6222
29.2547
28.8599
28.439
27.9934
27.5254
27.0378
26.5342
26.019
25.4979
24.9771
24.4643
23.9678
23.4969
23.0613
22.6709
22.3355
22.0641
21.8642
21.7417
21.7005
21.7417
21.8642
22.0641
22.3355
22.6709
23.0613
23.4969
23.9678
24.4643
24.9771
25.4979
26.019
26.5342
27.0378
27.5254
27.9934
28.439
28.8599
29.2547
29.6222
29.9617
30.2726
30.5548
30.8082
31.0329
31.2289
31.3965
31.5358
31.6469
31.7302
31.7856
31.8133
29.0852
29.0568
29
28.9145
28.8003
28.6569
28.4841
28.2815
28.0488
27.7856
27.4915
27.1663
26.8099
26.4224
26.0042
25.556
25.079
24.5753
24.0472
23.4984
22.9334
22.358
21.7792
21.2054
20.6462
20.1124
19.6157
19.1682
18.7819
18.4679
18.2359
18.0936
18.0456
18.0936
18.2359
18.4679
18.7819
19.1682
19.6157
20.1124
20.6462
21.2054
21.7792
22.358
22.9334
23.4984
24.0472
24.5753
25.079
25.556
26.0042
26.4224
26.8099
27.1663
27.4915
27.7856
28.0488
28.2815
28.4841
28.6569
28.8003
28.9145
29
29.0568
29.0852
26.386
26.3569
26.2988
26.2114
26.0943
25.9472
25.7695
25.5608
25.3204
25.0476
24.7419
24.4025
24.0291
23.6212
23.1788
22.7021
22.192
21.6498
21.0777
20.4791
19.8584
19.2216
18.5763
17.9317
17.2988
16.6903
16.1202
15.6034
15.1547
14.7883
14.5167
14.3496
14.2932
14.3496
14.5167
14.7883
15.1547
15.6034
16.1202
16.6903
17.2988
17.9317
18.5763
19.2216
19.8584
20.4791
21.0777
21.6498
22.192
22.7021
23.1788
23.6212
24.0291
24.4025
24.7419
25.0476
25.3204
25.5608
25.7695
25.9472
26.0943
26.2114
26.2988
26.3569
26.386
23.7162
23.6866
23.6274
23.5383
23.4188
23.2685
23.0865
22.8723
22.6248
22.3432
22.0264
21.6735
21.2833
20.8551
20.3882
19.8823
19.3375
18.7546
18.1352
17.4822
16.7998
16.0939
15.3726
14.646
13.9266
13.2292
12.5707
11.9694
11.4439
11.0126
10.6914
10.4932
10.4262
10.4932
10.6914
11.0126
11.4439
11.9694
12.5707
13.2292
13.9266
14.646
15.3726
16.0939
16.7998
17.4822
18.1352
18.7546
19.3375
19.8823
20.3882
20.8551
21.2833
21.6735
22.0264
22.3432
22.6248
22.8723
23.0865
23.2685
23.4188
23.5383
23.6274
23.6866
23.7162
21.0764
21.0465
20.9865
20.8961
20.7747
20.6218
20.4364
20.2175
19.964
19.6745
19.3477
18.9821
18.5762
18.1283
17.6373
17.102
16.5217
15.8963
15.2268
14.5151
13.7649
12.982
12.1743
11.353
10.532
9.72858
8.96314
8.25822
7.63765
7.1249
6.74121
6.5036
6.42312
6.5036
6.74121
7.1249
7.63765
8.25822
8.96314
9.72858
10.532
11.353
12.1743
12.982
13.7649
14.5151
15.2268
15.8963
16.5217
17.102
17.6373
18.1283
18.5762
18.9821
19.3477
19.6745
19.964
20.2175
20.4364
20.6218
20.7747
20.8961
20.9865
21.0465
21.0764
18.467
18.4368
18.3764
18.2853
18.1627
18.0081
17.8202
17.5978
17.3396
17.0437
16.7085
16.3318
15.9115
15.4454
14.9314
14.3674
13.7517
13.083
12.3612
11.5871
10.7634
9.89509
8.99
8.0596
7.11942
6.18947
5.29411
4.46142
3.72187
3.10617
2.64266
2.3544
2.25656
2.3544
2.64266
3.10617
3.72187
4.46142
5.29411
6.18947
7.11942
8.0596
8.99
9.89509
10.7634
11.5871
12.3612
13.083
13.7517
14.3674
14.9314
15.4454
15.9115
16.3318
16.7085
17.0437
17.3396
17.5978
17.8202
18.0081
18.1627
18.2853
18.3764
18.4368
18.467
15.8881
15.858
15.7975
15.7063
15.5834
15.4281
15.239
15.0147
14.7533
14.453
14.1113
13.7257
13.2933
12.8112
12.2763
11.6853
11.0353
10.3237
9.54868
8.70948
7.80723
6.84553
5.83138
4.77615
3.69651
2.61522
1.56142
0.570049
-0.3197
-1.06713
-1.63388
-1.98816
-2.10874
-1.98816
-1.63388
-1.06713
-0.3197
0.570049
1.56142
2.61522
3.69651
4.77615
5.83138
6.84553
7.80723
8.70948
9.54868
10.3237
11.0353
11.6853
12.2763
12.8112
13.2933
13.7257
14.1113
14.453
14.7533
15.0147
15.239
15.4281
15.5834
15.7063
15.7975
15.858
15.8881
13.3399
13.31
13.25
13.1593
13.0371
12.8824
12.6936
12.4691
12.2068
11.9042
11.5587
11.167
10.7257
10.2307
9.67803
9.06315
8.38155
7.6289
6.80131
5.89589
4.91141
3.84923
2.71449
1.51748
0.275259
-0.986929
-2.23468
-3.42453
-4.5058
-5.4239
-6.12621
-6.56806
-6.71896
-6.56806
-6.12621
-5.4239
-4.5058
-3.42453
-2.23468
-0.986929
0.275259
1.51748
2.71449
3.84923
4.91141
5.89589
6.80131
7.6289
8.38155
9.06315
9.67803
10.2307
10.7257
11.167
11.5587
11.9042
12.2068
12.4691
12.6936
12.8824
13.0371
13.1593
13.25
13.31
13.3399
10.8219
10.7926
10.7336
10.6443
10.524
10.3712
10.1845
9.96187
9.70101
9.39912
9.05298
8.65883
8.2124
7.70889
7.14295
6.50872
5.79995
5.01017
4.13298
3.16259
2.0945
0.926635
-0.339179
-1.69527
-3.12571
-4.60375
-6.08956
-7.52938
-8.85762
-9.99983
-10.8831
-11.4434
-11.6357
-11.4434
-10.8831
-9.99983
-8.85762
-7.52938
-6.08956
-4.60375
-3.12571
-1.69527
-0.339179
0.926635
2.0945
3.16259
4.13298
5.01017
5.79995
6.50872
7.14295
7.70889
8.2124
8.65883
9.05298
9.39912
9.70101
9.96187
10.1845
10.3712
10.524
10.6443
10.7336
10.7926
10.8219
8.33382
8.30528
8.24789
8.16101
8.04366
7.89451
7.71183
7.4935
7.23692
6.93898
6.59601
6.20372
5.75712
5.25046
4.67721
4.03
3.30063
2.4802
1.55932
0.528496
-0.621093
-1.89649
-3.30116
-4.83251
-6.47834
-8.21267
-9.99117
-11.7475
-13.3984
-14.8388
-15.9678
-16.6926
4.82094
-16.6926
-15.9678
-14.8388
-13.3984
-11.7475
-9.99117
-8.21267
-6.47834
-4.83251
-3.30116
-1.89649
-0.621093
0.528496
1.55932
2.4802
3.30063
4.03
4.67721
5.25046
5.75712
6.20372
6.59601
6.93898
7.23692
7.4935
7.71183
7.89451
8.04366
8.16101
8.24789
8.30528
8.33382
5.87468
5.84728
5.79215
5.70862
5.59566
5.45185
5.27539
5.06398
4.81483
4.52456
4.18914
3.80377
3.36282
2.85966
2.28659
1.63471
0.893778
0.0522543
-0.902705
-1.98498
-3.20892
-4.58831
-6.13451
-7.85347
-9.74109
-11.7767
-13.9153
-16.0729
4.81447
4.81375
4.81366
4.81375
4.81381
4.81375
4.81366
4.81375
4.81447
-16.0729
-13.9153
-11.7767
-9.74109
-7.85347
-6.13451
-4.58831
-3.20892
-1.98498
-0.902705
0.0522543
0.893778
1.63471
2.28659
2.85966
3.36282
3.80377
4.18914
4.52456
4.81483
5.06398
5.27539
5.45185
5.59566
5.70862
5.79215
5.84728
5.87468
3.44336
3.41744
3.36525
3.28611
3.17897
3.04238
2.87444
2.67279
2.43451
2.15601
1.83299
1.46028
1.03169
0.539857
-0.0239744
-0.670163
-1.41091
-2.26049
-3.23543
-4.35458
-5.63888
-7.11073
-8.79242
-10.7031
-12.8535
-15.2363
4.80709
4.80638
4.80685
4.80678
4.80675
4.80677
4.80678
4.80677
4.80675
4.80678
4.80685
4.80638
4.80709
-15.2363
-12.8535
-10.7031
-8.79242
-7.11073
-5.63888
-4.35458
-3.23543
-2.26049
-1.41091
-0.670163
-0.0239744
0.539857
1.03169
1.46028
1.83299
2.15601
2.43451
2.67279
2.87444
3.04238
3.17897
3.28611
3.36525
3.41744
3.44336
1.03838
1.01427
0.965723
0.892048
0.792198
0.664722
0.507728
0.318818
0.0950147
-0.167338
-0.472697
-0.82647
-1.23521
-1.70683
-2.2509
-2.879
-3.60507
-4.44592
-5.42171
-6.55645
-7.87837
-9.42004
-11.2177
-13.3094
-15.73
4.79998
4.79989
4.79971
4.79978
4.79979
4.79978
4.79978
4.79979
4.79978
4.79978
4.79979
4.79978
4.79971
4.79989
4.79998
-15.73
-13.3094
-11.2177
-9.42004
-7.87837
-6.55645
-5.42171
-4.44592
-3.60507
-2.879
-2.2509
-1.70683
-1.23521
-0.82647
-0.472697
-0.167338
0.0950147
0.318818
0.507728
0.664722
0.792198
0.892048
0.965723
1.01427
1.03838
-1.34212
-1.36407
-1.40829
-1.47543
-1.56652
-1.68295
-1.82657
-1.99972
-2.20533
-2.44701
-2.72921
-3.0574
-3.43824
-3.87993
-4.39251
-4.98834
-5.68267
-6.49432
-7.44657
-8.56822
-9.8947
-11.4694
-13.3444
-15.5817
4.79232
4.79269
4.79278
4.79277
4.79279
4.7928
4.7928
4.7928
4.7928
4.7928
4.7928
4.7928
4.79279
4.79277
4.79278
4.79269
4.79232
-15.5817
-13.3444
-11.4694
-9.8947
-8.56822
-7.44657
-6.49432
-5.68267
-4.98834
-4.39251
-3.87993
-3.43824
-3.0574
-2.72921
-2.44701
-2.20533
-1.99972
-1.82657
-1.68295
-1.56652
-1.47543
-1.40829
-1.36407
-1.34212
-3.70034
-3.7198
-3.75901
-3.8186
-3.8995
-4.00302
-4.13088
-4.2853
-4.46903
-4.68552
-4.93904
-5.23485
-5.57949
-5.98103
-6.44956
-6.99765
-7.64111
-8.39992
-9.29941
-10.372
-11.659
-13.2136
-15.1033
4.78504
4.78548
4.78569
4.78577
4.78579
4.78581
4.78582
4.78582
4.78582
4.78582
4.78582
4.78582
4.78582
4.78581
4.78579
4.78577
4.78569
4.78548
4.78504
-15.1033
-13.2136
-11.659
-10.372
-9.29941
-8.39992
-7.64111
-6.99765
-6.44956
-5.98103
-5.57949
-5.23485
-4.93904
-4.68552
-4.46903
-4.2853
-4.13088
-4.00302
-3.8995
-3.8186
-3.75901
-3.7198
-3.70034
-6.03879
-6.05546
-6.08905
-6.14012
-6.2095
-6.29836
-6.40823
-6.54111
-6.69947
-6.88644
-7.10591
-7.36272
-7.66293
-8.01412
-8.42581
-8.9101
-9.48242
-10.1626
-10.9765
-11.9579
-13.1515
-14.6174
-16.4372
4.77938
4.77887
4.77881
4.77882
4.77883
4.77884
4.77884
4.77884
4.77884
4.77884
4.77884
4.77884
4.77884
4.77884
4.77883
4.77882
4.77881
4.77887
4.77938
-16.4372
-14.6174
-13.1515
-11.9579
-10.9765
-10.1626
-9.48242
-8.9101
-8.42581
-8.01412
-7.66293
-7.36272
-7.10591
-6.88644
-6.69947
-6.54111
-6.40823
-6.29836
-6.2095
-6.14012
-6.08905
-6.05546
-6.03879
-8.36033
-8.37393
-8.40135
-8.44305
-8.49972
-8.57235
-8.66223
-8.77103
-8.90084
-9.05434
-9.23485
-9.44652
-9.69462
-9.98575
-10.3283
-10.7332
-11.2142
-11.7896
-12.4835
-13.3282
-14.3675
-15.662
4.7699
4.77151
4.7718
4.77186
4.77187
4.77187
4.77187
4.77186
4.77186
4.77186
4.77186
4.77186
4.77186
4.77186
4.77187
4.77187
4.77187
4.77186
4.7718
4.77151
4.7699
-15.662
-14.3675
-13.3282
-12.4835
-11.7896
-11.2142
-10.7332
-10.3283
-9.98575
-9.69462
-9.44652
-9.23485
-9.05434
-8.90084
-8.77103
-8.66223
-8.57235
-8.49972
-8.44305
-8.40135
-8.37393
-8.36033
-10.668
-10.6784
-10.6991
-10.7308
-10.7737
-10.8288
-10.897
-10.9796
-11.0782
-11.1948
-11.3321
-11.4933
-11.6826
-11.9051
-12.1676
-12.4788
-12.85
-13.2962
-13.8374
-14.501
-15.3244
-16.3603
4.76508
4.76497
4.76497
4.76496
4.76494
4.76492
4.7649
4.76489
4.76488
4.76487
4.76487
4.76487
4.76488
4.76489
4.7649
4.76492
4.76494
4.76496
4.76497
4.76497
4.76508
-16.3603
-15.3244
-14.501
-13.8374
-13.2962
-12.85
-12.4788
-12.1676
-11.9051
-11.6826
-11.4933
-11.3321
-11.1948
-11.0782
-10.9796
-10.897
-10.8288
-10.7737
-10.7308
-10.6991
-10.6784
-10.668
-12.9653
-12.9721
-12.986
-13.0069
-13.0355
-13.072
-13.1172
-13.1719
-13.2372
-13.3143
-13.4051
-13.5117
-13.6368
-13.7839
-13.9575
-14.1636
-14.4097
-14.7063
-15.0671
-15.5113
-16.0655
-16.7683
4.75872
4.75831
4.75814
4.75806
4.75801
4.75797
4.75794
4.75791
4.75789
4.75788
4.75788
4.75788
4.75789
4.75791
4.75794
4.75797
4.75801
4.75806
4.75814
4.75831
4.75872
-16.7683
-16.0655
-15.5113
-15.0671
-14.7063
-14.4097
-14.1636
-13.9575
-13.7839
-13.6368
-13.5117
-13.4051
-13.3143
-13.2372
-13.1719
-13.1172
-13.072
-13.0355
-13.0069
-12.986
-12.9721
-12.9653
-15.2556
-15.2589
-15.2655
-15.2755
-15.289
-15.3064
-15.3277
-15.3535
-15.384
-15.42
-15.4621
-15.5112
-15.5686
-15.6357
-15.7145
-15.8076
-15.9183
-16.0511
-16.2122
-16.4098
-16.6556
-16.9662
4.75166
4.75139
4.75124
4.75114
4.75106
4.751
4.75096
4.75093
4.7509
4.75089
4.75088
4.75089
4.7509
4.75093
4.75096
4.751
4.75106
4.75114
4.75124
4.75139
4.75166
-16.9662
-16.6556
-16.4098
-16.2122
-16.0511
-15.9183
-15.8076
-15.7145
-15.6357
-15.5686
-15.5112
-15.4621
-15.42
-15.384
-15.3535
-15.3277
-15.3064
-15.289
-15.2755
-15.2655
-15.2589
-15.2556
-17.5425
-17.5422
-17.5415
-17.5404
-17.5388
-17.5367
-17.5338
-17.5302
-17.5254
-17.5195
-17.5119
-17.5024
-17.4905
-17.4756
-17.457
-17.4337
-17.4043
-17.3673
-17.3201
-17.2595
-17.1801
-17.0731
4.74437
4.74436
4.74428
4.74419
4.7441
4.74403
4.74397
4.74393
4.7439
4.74388
4.74388
4.74388
4.7439
4.74393
4.74397
4.74403
4.7441
4.74419
4.74428
4.74436
4.74437
-17.0731
-17.1801
-17.2595
-17.3201
-17.3673
-17.4043
-17.4337
-17.457
-17.4756
-17.4905
-17.5024
-17.5119
-17.5195
-17.5254
-17.5302
-17.5338
-17.5367
-17.5388
-17.5404
-17.5415
-17.5422
-17.5425
-19.8299
-19.8259
-19.818
-19.8058
-19.7891
-19.7676
-19.7408
-19.7079
-19.6681
-19.6205
-19.5637
-19.496
-19.4155
-19.3194
-19.2043
-19.0658
-18.8982
-18.6937
-18.4418
-18.1282
-17.7325
-17.2253
4.73727
4.73741
4.73734
4.73723
4.73712
4.73704
4.73697
4.73692
4.73688
4.73687
4.73686
4.73687
4.73688
4.73692
4.73697
4.73704
4.73712
4.73723
4.73734
4.73741
4.73727
-17.2253
-17.7325
-18.1282
-18.4418
-18.6937
-18.8982
-19.0658
-19.2043
-19.3194
-19.4155
-19.496
-19.5637
-19.6205
-19.6681
-19.7079
-19.7408
-19.7676
-19.7891
-19.8058
-19.818
-19.8259
-19.8299
-22.1212
-22.1137
-22.0987
-22.0757
-22.0444
-22.0041
-21.9538
-21.8926
-21.8188
-21.7309
-21.6265
-21.5028
-21.3562
-21.1823
-20.9753
-20.7276
-20.4296
-20.0682
-19.6262
-19.0802
-18.3981
-17.5362
4.73084
4.73068
4.73045
4.73026
4.73013
4.73002
4.72995
4.72989
4.72986
4.72984
4.72983
4.72984
4.72986
4.72989
4.72995
4.73002
4.73013
4.73026
4.73045
4.73068
4.73084
-17.5362
-18.3981
-19.0802
-19.6262
-20.0682
-20.4296
-20.7276
-20.9753
-21.1823
-21.3562
-21.5028
-21.6265
-21.7309
-21.8188
-21.8926
-21.9538
-22.0041
-22.0444
-22.0757
-22.0987
-22.1137
-22.1212
-24.42
-24.4092
-24.3874
-24.3542
-24.3089
-24.2506
-24.1781
-24.0899
-23.984
-23.858
-23.7089
-23.5327
-23.3248
-23.079
-22.7875
-22.4406
-22.0252
-21.5246
-20.9163
-20.1704
-19.2461
-18.0878
4.72594
4.72403
4.72349
4.72325
4.7231
4.72299
4.7229
4.72285
4.72281
4.72279
4.72278
4.72279
4.72281
4.72285
4.7229
4.72299
4.7231
4.72325
4.72349
4.72403
4.72594
-18.0878
-19.2461
-20.1704
-20.9163
-21.5246
-22.0252
-22.4406
-22.7875
-23.079
-23.3248
-23.5327
-23.7089
-23.858
-23.984
-24.0899
-24.1781
-24.2506
-24.3089
-24.3542
-24.3874
-24.4092
-24.42
-26.7299
-26.7159
-26.6878
-26.6449
-26.5865
-26.5115
-26.4183
-26.3051
-26.1696
-26.0087
-25.8187
-25.595
-25.3318
-25.0219
-24.6562
-24.223
-23.7074
-23.0902
-22.3462
-21.4419
-20.3318
-18.9518
-17.2008
4.71599
4.71624
4.71616
4.71603
4.71592
4.71583
4.71578
4.71575
4.71573
4.71573
4.71573
4.71575
4.71578
4.71583
4.71592
4.71603
4.71616
4.71624
4.71599
-17.2008
-18.9518
-20.3318
-21.4419
-22.3462
-23.0902
-23.7074
-24.223
-24.6562
-25.0219
-25.3318
-25.595
-25.8187
-26.0087
-26.1696
-26.3051
-26.4183
-26.5115
-26.5865
-26.6449
-26.6878
-26.7159
-26.7299
-29.0539
-29.037
-29.0031
-28.9514
-28.881
-28.7908
-28.6788
-28.5431
-28.3809
-28.1888
-27.9627
-27.6973
-27.3863
-27.0216
-26.5934
-26.089
-25.4929
-24.7847
-23.9389
-22.9222
-21.6917
-20.1926
-18.3603
4.71017
4.70932
4.7091
4.70894
4.70881
4.70874
4.70869
4.70867
4.70866
4.70866
4.70866
4.70867
4.70869
4.70874
4.70881
4.70894
4.7091
4.70932
4.71017
-18.3603
-20.1926
-21.6917
-22.9222
-23.9389
-24.7847
-25.4929
-26.089
-26.5934
-27.0216
-27.3863
-27.6973
-27.9627
-28.1888
-28.3809
-28.5431
-28.6788
-28.7908
-28.881
-28.9514
-29.0031
-29.037
-29.0539
-31.395
-31.3755
-31.3364
-31.2768
-31.1958
-31.092
-30.9635
-30.808
-30.6226
-30.4036
-30.1466
-29.846
-29.4952
-29.0859
-28.6078
-28.0484
-27.392
-26.619
-25.7051
-24.6197
-23.3244
-21.7718
-19.9021
-17.6341
4.70174
4.702
4.7018
4.70166
4.70161
4.70158
4.70158
4.70159
4.70159
4.70159
4.70158
4.70158
4.70161
4.70166
4.7018
4.702
4.70174
-17.6341
-19.9021
-21.7718
-23.3244
-24.6197
-25.7051
-26.619
-27.392
-28.0484
-28.6078
-29.0859
-29.4952
-29.846
-30.1466
-30.4036
-30.6226
-30.808
-30.9635
-31.092
-31.1958
-31.2768
-31.3364
-31.3755
-31.395
-33.7558
-33.7341
-33.6904
-33.624
-33.5338
-33.4183
-33.2757
-33.1034
-32.8984
-32.657
-32.3746
-32.0457
-31.6635
-31.2199
-30.7048
-30.1063
-29.4095
-28.5965
-27.6455
-26.5302
-25.2186
-23.6729
-21.8483
-19.6931
-17.1542
4.69537
4.69461
4.69443
4.69444
4.69445
4.69448
4.69451
4.69452
4.69451
4.69448
4.69445
4.69444
4.69443
4.69461
4.69537
-17.1542
-19.6931
-21.8483
-23.6729
-25.2186
-26.5302
-27.6455
-28.5965
-29.4095
-30.1063
-30.7048
-31.2199
-31.6635
-32.0457
-32.3746
-32.657
-32.8984
-33.1034
-33.2757
-33.4183
-33.5338
-33.624
-33.6904
-33.7341
-33.7558
-36.1386
-36.115
-36.0675
-35.9953
-35.8974
-35.7723
-35.6179
-35.4319
-35.2112
-34.952
-34.6499
-34.2995
-33.8943
-33.4265
-32.8867
-32.2639
-31.545
-30.7141
-29.7529
-28.64
-27.3506
-25.8572
-24.1304
-22.1416
-19.8695
-17.313
4.68682
4.68701
4.68727
4.68731
4.68739
4.68745
4.68747
4.68745
4.68739
4.68731
4.68727
4.68701
4.68682
-17.313
-19.8695
-22.1416
-24.1304
-25.8572
-27.3506
-28.64
-29.7529
-30.7141
-31.545
-32.2639
-32.8867
-33.4265
-33.8943
-34.2995
-34.6499
-34.952
-35.2112
-35.4319
-35.6179
-35.7723
-35.8974
-35.9953
-36.0675
-36.115
-36.1386
-38.5454
-38.5202
-38.4696
-38.3928
-38.2887
-38.1558
-37.9923
-37.7957
-37.5629
-37.2906
-36.9743
-36.609
-36.1886
-35.706
-35.1529
-34.5193
-33.794
-32.964
-32.0145
-30.9289
-29.6897
-28.2785
-26.6787
-24.8779
-22.8737
-20.6819
-18.346
4.67951
4.68032
4.68013
4.68031
4.68043
4.68047
4.68043
4.68031
4.68013
4.68032
4.67951
-18.346
-20.6819
-22.8737
-24.8779
-26.6787
-28.2785
-29.6897
-30.9289
-32.0145
-32.964
-33.794
-34.5193
-35.1529
-35.706
-36.1886
-36.609
-36.9743
-37.2906
-37.5629
-37.7957
-37.9923
-38.1558
-38.2887
-38.3928
-38.4696
-38.5202
-38.5454
-40.9777
-40.9513
-40.8983
-40.818
-40.7092
-40.5706
-40.4003
-40.196
-39.955
-39.6738
-39.3485
-38.9745
-38.5462
-38.0573
-37.5006
-36.8678
-36.1495
-35.3354
-34.4141
-33.374
-32.2033
-30.8915
-29.4311
-27.8206
-26.0683
-24.1973
-22.2505
-20.2927
-18.4185
4.67255
4.67328
4.67351
4.67355
4.67351
4.67328
4.67255
-18.4185
-20.2927
-22.2505
-24.1973
-26.0683
-27.8206
-29.4311
-30.8915
-32.2033
-33.374
-34.4141
-35.3354
-36.1495
-36.8678
-37.5006
-38.0573
-38.5462
-38.9745
-39.3485
-39.6738
-39.955
-40.196
-40.4003
-40.5706
-40.7092
-40.818
-40.8983
-40.9513
-40.9777
-43.4367
-43.4095
-43.3549
-43.272
-43.16
-43.0175
-42.8428
-42.6338
-42.3878
-42.1018
-41.7723
-41.395
-40.9652
-40.4775
-39.9257
-39.3031
-38.6023
-37.8155
-36.9345
-35.9517
-34.8602
-33.6553
-32.3361
-30.9075
-29.3834
-27.7895
-26.1663
-24.5705
-23.0771
-21.7751
-20.7793
-20.1459
-19.9278
-20.1459
-20.7793
-21.7751
-23.0771
-24.5705
-26.1663
-27.7895
-29.3834
-30.9075
-32.3361
-33.6553
-34.8602
-35.9517
-36.9345
-37.8155
-38.6023
-39.3031
-39.9257
-40.4775
-40.9652
-41.395
-41.7723
-42.1018
-42.3878
-42.6338
-42.8428
-43.0175
-43.16
-43.272
-43.3549
-43.4095
-43.4367
-45.9234
-45.8957
-45.84
-45.7556
-45.6418
-45.4972
-45.3202
-45.109
-44.8612
-44.5741
-44.2445
-43.8689
-43.4431
-42.9627
-42.4227
-41.8179
-41.1425
-40.3911
-39.5584
-38.6398
-37.6322
-36.5352
-35.352
-34.0914
-32.7694
-31.4116
-30.0541
-28.7444
-27.5413
-26.511
-25.7229
-25.2266
-25.0568
-25.2266
-25.7229
-26.511
-27.5413
-28.7444
-30.0541
-31.4116
-32.7694
-34.0914
-35.352
-36.5352
-37.6322
-38.6398
-39.5584
-40.3911
-41.1425
-41.8179
-42.4227
-42.9627
-43.4431
-43.8689
-44.2445
-44.5741
-44.8612
-45.109
-45.3202
-45.4972
-45.6418
-45.7556
-45.84
-45.8957
-45.9234
-48.4382
-48.4103
-48.3541
-48.2692
-48.1548
-48.0097
-47.8324
-47.6214
-47.3745
-47.0894
-46.7635
-46.3936
-45.9765
-45.5084
-44.9856
-44.4041
-43.76
-43.0494
-42.2695
-41.4181
-40.4951
-39.5026
-38.4466
-37.3375
-36.1919
-35.0334
-33.8932
-32.8103
-31.8299
-31.0008
-30.3703
-29.9755
-29.841
-29.9755
-30.3703
-31.0008
-31.8299
-32.8103
-33.8932
-35.0334
-36.1919
-37.3375
-38.4466
-39.5026
-40.4951
-41.4181
-42.2695
-43.0494
-43.76
-44.4041
-44.9856
-45.5084
-45.9765
-46.3936
-46.7635
-47.0894
-47.3745
-47.6214
-47.8324
-48.0097
-48.1548
-48.2692
-48.3541
-48.4103
-48.4382
-50.9814
-50.9535
-50.8975
-50.8129
-50.699
-50.5547
-50.379
-50.1702
-49.9266
-49.6464
-49.3271
-48.9664
-48.5615
-48.1097
-47.6082
-47.0541
-46.4448
-45.7782
-45.0531
-44.2693
-43.4285
-42.5346
-41.595
-40.6207
-39.6275
-38.6366
-37.6742
-36.772
-35.9648
-35.289
-34.7784
-34.4602
-34.3521
-34.4602
-34.7784
-35.289
-35.9648
-36.772
-37.6742
-38.6366
-39.6275
-40.6207
-41.595
-42.5346
-43.4285
-44.2693
-45.0531
-45.7782
-46.4448
-47.0541
-47.6082
-48.1097
-48.5615
-48.9664
-49.3271
-49.6464
-49.9266
-50.1702
-50.379
-50.5547
-50.699
-50.8129
-50.8975
-50.9535
-50.9814
-53.5528
-53.5253
-53.4699
-53.3863
-53.2739
-53.1318
-52.959
-52.7543
-52.5161
-52.2429
-51.9328
-51.5839
-51.1942
-50.7616
-50.2842
-49.76
-49.1877
-48.5665
-47.8963
-47.1784
-46.4157
-45.6132
-44.7787
-43.9231
-43.0609
-42.2106
-41.3943
-40.6371
-39.9664
-39.4094
-38.9911
-38.7315
-38.6434
-38.7315
-38.9911
-39.4094
-39.9664
-40.6371
-41.3943
-42.2106
-43.0609
-43.9231
-44.7787
-45.6132
-46.4157
-47.1784
-47.8963
-48.5665
-49.1877
-49.76
-50.2842
-50.7616
-51.1942
-51.5839
-51.9328
-52.2429
-52.5161
-52.7543
-52.959
-53.1318
-53.2739
-53.3863
-53.4699
-53.5253
-53.5528
-56.1523
-56.1253
-56.0709
-55.989
-55.879
-55.7401
-55.5716
-55.3723
-55.1411
-54.8768
-54.5779
-54.2429
-53.8705
-53.4591
-53.0075
-52.5148
-51.9805
-51.4045
-50.788
-50.133
-49.4432
-48.7242
-47.9838
-47.2321
-46.4823
-45.7502
-45.0541
-44.4144
-43.8524
-43.3889
-43.0427
-42.8285
-42.756
-42.8285
-43.0427
-43.3889
-43.8524
-44.4144
-45.0541
-45.7502
-46.4823
-47.2321
-47.9838
-48.7242
-49.4432
-50.133
-50.788
-51.4045
-51.9805
-52.5148
-53.0075
-53.4591
-53.8705
-54.2429
-54.5779
-54.8768
-55.1411
-55.3723
-55.5716
-55.7401
-55.879
-55.989
-56.0709
-56.1253
-56.1523
-58.7793
-58.7529
-58.7
-58.6203
-58.5133
-58.3786
-58.2153
-58.0227
-57.7999
-57.5458
-57.2596
-56.94
-56.5862
-56.1973
-55.7727
-55.312
-54.8154
-54.2837
-53.7186
-53.1229
-52.5005
-51.8571
-51.2002
-50.5393
-49.8857
-49.2532
-48.6568
-48.1129
-47.6384
-47.2494
-46.9601
-46.7817
-46.7214
-46.7817
-46.9601
-47.2494
-47.6384
-48.1129
-48.6568
-49.2532
-49.8857
-50.5393
-51.2002
-51.8571
-52.5005
-53.1229
-53.7186
-54.2837
-54.8154
-55.312
-55.7727
-56.1973
-56.5862
-56.94
-57.2596
-57.5458
-57.7999
-58.0227
-58.2153
-58.3786
-58.5133
-58.6203
-58.7
-58.7529
-58.7793
-61.4331
-61.4075
-61.3563
-61.2792
-61.1759
-61.046
-60.8888
-60.7038
-60.4903
-60.2476
-59.975
-59.6719
-59.3377
-58.9719
-58.5745
-58.1456
-57.686
-57.1969
-56.6805
-56.1398
-55.579
-55.0037
-54.4208
-53.8389
-53.2679
-52.7194
-52.206
-51.741
-51.3376
-51.0086
-50.7648
-50.6149
-50.5643
-50.6149
-50.7648
-51.0086
-51.3376
-51.741
-52.206
-52.7194
-53.2679
-53.8389
-54.4208
-55.0037
-55.579
-56.1398
-56.6805
-57.1969
-57.686
-58.1456
-58.5745
-58.9719
-59.3377
-59.6719
-59.975
-60.2476
-60.4903
-60.7038
-60.8888
-61.046
-61.1759
-61.2792
-61.3563
-61.4075
-61.4331
-64.1128
-64.0882
-64.0389
-63.9648
-63.8656
-63.741
-63.5905
-63.4138
-63.2104
-62.9797
-62.7215
-62.4354
-62.1211
-61.7786
-61.4082
-61.0104
-60.5864
-60.1378
-59.667
-59.1771
-58.6724
-58.158
-57.6405
-57.1273
-56.6272
-56.15
-55.7061
-55.3063
-54.9614
-54.6811
-54.4742
-54.3473
-54.3045
-54.3473
-54.4742
-54.6811
-54.9614
-55.3063
-55.7061
-56.15
-56.6272
-57.1273
-57.6405
-58.158
-58.6724
-59.1771
-59.667
-60.1378
-60.5864
-61.0104
-61.4082
-61.7786
-62.1211
-62.4354
-62.7215
-62.9797
-63.2104
-63.4138
-63.5905
-63.741
-63.8656
-63.9648
-64.0389
-64.0882
-64.1128
-66.8175
-66.7939
-66.7468
-66.6759
-66.5811
-66.4622
-66.3189
-66.1509
-65.958
-65.7399
-65.4964
-65.2275
-64.9331
-64.6137
-64.2696
-63.9019
-63.5119
-63.1013
-62.6728
-62.2295
-61.7755
-61.3156
-60.8556
-60.4024
-59.9633
-59.5468
-59.1614
-58.8161
-58.5194
-58.2792
-58.1024
-57.9942
-57.9577
-57.9942
-58.1024
-58.2792
-58.5194
-58.8161
-59.1614
-59.5468
-59.9633
-60.4024
-60.8556
-61.3156
-61.7755
-62.2295
-62.6728
-63.1013
-63.5119
-63.9019
-64.2696
-64.6137
-64.9331
-65.2275
-65.4964
-65.7399
-65.958
-66.1509
-66.3189
-66.4622
-66.5811
-66.6759
-66.7468
-66.7939
-66.8175
-69.5461
-69.5236
-69.4787
-69.4113
-69.3211
-69.2082
-69.0724
-68.9134
-68.7313
-68.5258
-68.2972
-68.0454
-67.7707
-67.4737
-67.1551
-66.8161
-66.4581
-66.0831
-65.6937
-65.2929
-64.8845
-64.4732
-64.064
-63.663
-63.2766
-62.9119
-62.5761
-62.2764
-62.0199
-61.813
-61.661
-61.5681
-61.5369
-61.5681
-61.661
-61.813
-62.0199
-62.2764
-62.5761
-62.9119
-63.2766
-63.663
-64.064
-64.4732
-64.8845
-65.2929
-65.6937
-66.0831
-66.4581
-66.8161
-67.1551
-67.4737
-67.7707
-68.0454
-68.2972
-68.5258
-68.7313
-68.9134
-69.0724
-69.2082
-69.3211
-69.4113
-69.4787
-69.5236
-69.5461
-72.2974
-72.2761
-72.2336
-72.1696
-72.0843
-71.9775
-71.8493
-71.6995
-71.5282
-71.3354
-71.1214
-70.8864
-70.631
-70.3556
-70.0614
-69.7496
-69.4216
-69.0796
-68.726
-68.3638
-67.9966
-67.6285
-67.2642
-66.9088
-66.568
-66.2477
-65.954
-65.6929
-65.4702
-65.291
-65.1597
-65.0795
-65.0525
-65.0795
-65.1597
-65.291
-65.4702
-65.6929
-65.954
-66.2477
-66.568
-66.9088
-67.2642
-67.6285
-67.9966
-68.3638
-68.726
-69.0796
-69.4216
-69.7496
-70.0614
-70.3556
-70.631
-70.8864
-71.1214
-71.3354
-71.5282
-71.6995
-71.8493
-71.9775
-72.0843
-72.1696
-72.2336
-72.2761
-72.2974
-75.0704
-75.0503
-75.0101
-74.9497
-74.8693
-74.7687
-74.648
-74.5074
-74.3468
-74.1666
-73.9669
-73.7483
-73.5113
-73.2568
-72.9857
-72.6993
-72.3994
-72.0878
-71.7671
-71.4399
-71.1097
-70.7801
-70.4552
-70.1398
-69.8385
-69.5564
-69.2987
-69.0704
-68.8763
-68.7204
-68.6063
-68.5368
-68.5135
-68.5368
-68.6063
-68.7204
-68.8763
-69.0704
-69.2987
-69.5564
-69.8385
-70.1398
-70.4552
-70.7801
-71.1097
-71.4399
-71.7671
-72.0878
-72.3994
-72.6993
-72.9857
-73.2568
-73.5113
-73.7483
-73.9669
-74.1666
-74.3468
-74.5074
-74.648
-74.7687
-74.8693
-74.9497
-75.0101
-75.0503
-75.0704
-77.8638
-77.8449
-77.807
-77.7503
-77.6746
-77.5802
-77.4671
-77.3355
-77.1855
-77.0174
-76.8317
-76.6289
-76.4096
-76.1747
-75.9254
-75.6629
-75.389
-75.1054
-74.8146
-74.5192
-74.2221
-73.9267
-73.6368
-73.3563
-73.0894
-72.8404
-72.6137
-72.4134
-72.2434
-72.1073
-72.0078
-71.9473
-71.9269
-71.9473
-72.0078
-72.1073
-72.2434
-72.4134
-72.6137
-72.8404
-73.0894
-73.3563
-73.6368
-73.9267
-74.2221
-74.5192
-74.8146
-75.1054
-75.389
-75.6629
-75.9254
-76.1747
-76.4096
-76.6289
-76.8317
-77.0174
-77.1855
-77.3355
-77.4671
-77.5802
-77.6746
-77.7503
-77.807
-77.8449
-77.8638
-80.6764
-80.6587
-80.6232
-80.5699
-80.4991
-80.4108
-80.3051
-80.1822
-80.0424
-79.8862
-79.7139
-79.5261
-79.3236
-79.1074
-78.8785
-78.6382
-78.3882
-78.1304
-77.8669
-77.6001
-77.3327
-77.0679
-76.8088
-76.559
-76.3221
-76.1018
-75.9017
-75.7254
-75.5762
-75.4569
-75.3698
-75.3169
-75.2991
-75.3169
-75.3698
-75.4569
-75.5762
-75.7254
-75.9017
-76.1018
-76.3221
-76.559
-76.8088
-77.0679
-77.3327
-77.6001
-77.8669
-78.1304
-78.3882
-78.6382
-78.8785
-79.1074
-79.3236
-79.5261
-79.7139
-79.8862
-80.0424
-80.1822
-80.3051
-80.4108
-80.4991
-80.5699
-80.6232
-80.6587
-80.6764
-83.5071
-83.4905
-83.4573
-83.4075
-83.3414
-83.2589
-83.1604
-83.0461
-82.9162
-82.7713
-82.6117
-82.4383
-82.2517
-82.0529
-81.843
-81.6234
-81.3955
-81.1612
-80.9224
-80.6815
-80.4408
-80.2032
-79.9715
-79.7487
-79.538
-79.3426
-79.1657
-79.0101
-78.8786
-78.7737
-78.6972
-78.6507
-78.6351
-78.6507
-78.6972
-78.7737
-78.8786
-79.0101
-79.1657
-79.3426
-79.538
-79.7487
-79.9715
-80.2032
-80.4408
-80.6815
-80.9224
-81.1612
-81.3955
-81.6234
-81.843
-82.0529
-82.2517
-82.4383
-82.6117
-82.7713
-82.9162
-83.0461
-83.1604
-83.2589
-83.3414
-83.4075
-83.4573
-83.4905
-83.5071
-86.3546
-86.3391
-86.3082
-86.2618
-86.2002
-86.1235
-86.0319
-85.9257
-85.8053
-85.6711
-85.5237
-85.3638
-85.1921
-85.0097
-84.8175
-84.6169
-84.4093
-84.1965
-83.9802
-83.7626
-83.5459
-83.3325
-83.125
-82.926
-82.7384
-82.5648
-82.4079
-82.2702
-82.1541
-82.0615
-81.9942
-81.9532
-81.9395
-81.9532
-81.9942
-82.0615
-82.1541
-82.2702
-82.4079
-82.5648
-82.7384
-82.926
-83.125
-83.3325
-83.5459
-83.7626
-83.9802
-84.1965
-84.4093
-84.6169
-84.8175
-85.0097
-85.1921
-85.3638
-85.5237
-85.6711
-85.8053
-85.9257
-86.0319
-86.1235
-86.2002
-86.2618
-86.3082
-86.3391
-86.3546
-89.2179
-89.2035
-89.1747
-89.1316
-89.0743
-89.0031
-88.9181
-88.8197
-88.7083
-88.5844
-88.4485
-88.3013
-88.1436
-87.9763
-87.8005
-87.6174
-87.4285
-87.2353
-87.0394
-86.8428
-86.6476
-86.4558
-86.2698
-86.0919
-85.9245
-85.77
-85.6306
-85.5085
-85.4056
-85.3238
-85.2642
-85.2281
-85.216
-85.2281
-85.2642
-85.3238
-85.4056
-85.5085
-85.6306
-85.77
-85.9245
-86.0919
-86.2698
-86.4558
-86.6476
-86.8428
-87.0394
-87.2353
-87.4285
-87.6174
-87.8005
-87.9763
-88.1436
-88.3013
-88.4485
-88.5844
-88.7083
-88.8197
-88.9181
-89.0031
-89.0743
-89.1316
-89.1747
-89.2035
-89.2179
-92.0959
-92.0825
-92.0557
-92.0157
-91.9626
-91.8966
-91.818
-91.727
-91.6241
-91.5099
-91.3847
-91.2494
-91.1047
-90.9515
-90.7909
-90.624
-90.4521
-90.2767
-90.0993
-89.9217
-89.7457
-89.5733
-89.4064
-89.2471
-89.0976
-88.9597
-88.8357
-88.7272
-88.6359
-88.5633
-88.5106
-88.4786
-88.4679
-88.4786
-88.5106
-88.5633
-88.6359
-88.7272
-88.8357
-88.9597
-89.0976
-89.2471
-89.4064
-89.5733
-89.7457
-89.9217
-90.0993
-90.2767
-90.4521
-90.624
-90.7909
-90.9515
-91.1047
-91.2494
-91.3847
-91.5099
-91.6241
-91.727
-91.818
-91.8966
-91.9626
-92.0157
-92.0557
-92.0825
-92.0959
-94.9874
-94.975
-94.9502
-94.9132
-94.864
-94.803
-94.7303
-94.6464
-94.5516
-94.4463
-94.3313
-94.2071
-94.0745
-93.9343
-93.7877
-93.6356
-93.4793
-93.3201
-93.1595
-92.999
-92.8403
-92.6851
-92.5352
-92.3925
-92.2587
-92.1356
-92.025
-91.9283
-91.8472
-91.7827
-91.7359
-91.7075
-91.698
-91.7075
-91.7359
-91.7827
-91.8472
-91.9283
-92.025
-92.1356
-92.2587
-92.3925
-92.5352
-92.6851
-92.8403
-92.999
-93.1595
-93.3201
-93.4793
-93.6356
-93.7877
-93.9343
-94.0745
-94.2071
-94.3313
-94.4463
-94.5516
-94.6464
-94.7303
-94.803
-94.864
-94.9132
-94.9502
-94.975
-94.9874
-97.8915
-97.8801
-97.8572
-97.8229
-97.7775
-97.7212
-97.6542
-97.5768
-97.4895
-97.3928
-97.2871
-97.1732
-97.0519
-96.9238
-96.79
-96.6515
-96.5094
-96.3649
-96.2195
-96.0744
-95.9312
-95.7915
-95.6568
-95.5287
-95.4089
-95.2988
-95.2
-95.1138
-95.0415
-94.9841
-94.9425
-94.9172
-94.9088
-94.9172
-94.9425
-94.9841
-95.0415
-95.1138
-95.2
-95.2988
-95.4089
-95.5287
-95.6568
-95.7915
-95.9312
-96.0744
-96.2195
-96.3649
-96.5094
-96.6515
-96.79
-96.9238
-97.0519
-97.1732
-97.2871
-97.3928
-97.4895
-97.5768
-97.6542
-97.7212
-97.7775
-97.8229
-97.8572
-97.8801
-97.8915
-100.807
-100.797
-100.776
-100.744
-100.702
-100.65
-100.589
-100.517
-100.437
-100.348
-100.251
-100.147
-100.036
-99.9191
-99.7971
-99.671
-99.5418
-99.4108
-99.2791
-99.1479
-99.0187
-98.8928
-98.7717
-98.6566
-98.5492
-98.4506
-98.3623
-98.2853
-98.2207
-98.1695
-98.1324
-98.1099
-98.1024
-98.1099
-98.1324
-98.1695
-98.2207
-98.2853
-98.3623
-98.4506
-98.5492
-98.6566
-98.7717
-98.8928
-99.0187
-99.1479
-99.2791
-99.4108
-99.5418
-99.671
-99.7971
-99.9191
-100.036
-100.147
-100.251
-100.348
-100.437
-100.517
-100.589
-100.65
-100.702
-100.744
-100.776
-100.797
-100.807
-103.734
-103.724
-103.705
-103.676
-103.637
-103.589
-103.532
-103.467
-103.393
-103.312
-103.223
-103.128
-103.026
-102.919
-102.808
-102.694
-102.576
-102.457
-102.338
-102.219
-102.103
-101.989
-101.88
-101.777
-101.68
-101.592
-101.513
-101.444
-101.386
-101.341
-101.308
-101.287
-101.281
-101.287
-101.308
-101.341
-101.386
-101.444
-101.513
-101.592
-101.68
-101.777
-101.88
-101.989
-102.103
-102.219
-102.338
-102.457
-102.576
-102.694
-102.808
-102.919
-103.026
-103.128
-103.223
-103.312
-103.393
-103.467
-103.532
-103.589
-103.637
-103.676
-103.705
-103.724
-103.734
-106.67
-106.661
-106.643
-106.617
-106.581
-106.537
-106.485
-106.425
-106.358
-106.283
-106.202
-106.114
-106.022
-105.924
-105.823
-105.719
-105.612
-105.504
-105.396
-105.289
-105.184
-105.081
-104.983
-104.89
-104.803
-104.724
-104.653
-104.591
-104.54
-104.499
-104.469
-104.451
-104.445
-104.451
-104.469
-104.499
-104.54
-104.591
-104.653
-104.724
-104.803
-104.89
-104.983
-105.081
-105.184
-105.289
-105.396
-105.504
-105.612
-105.719
-105.823
-105.924
-106.022
-106.114
-106.202
-106.283
-106.358
-106.425
-106.485
-106.537
-106.581
-106.617
-106.643
-106.661
-106.67
-109.616
-109.608
-109.591
-109.567
-109.534
-109.494
-109.446
-109.391
-109.329
-109.261
-109.186
-109.107
-109.022
-108.933
-108.841
-108.746
-108.649
-108.552
-108.454
-108.357
-108.262
-108.169
-108.081
-107.997
-107.919
-107.848
-107.784
-107.729
-107.682
-107.646
-107.619
-107.603
-107.598
-107.603
-107.619
-107.646
-107.682
-107.729
-107.784
-107.848
-107.919
-107.997
-108.081
-108.169
-108.262
-108.357
-108.454
-108.552
-108.649
-108.746
-108.841
-108.933
-109.022
-109.107
-109.186
-109.261
-109.329
-109.391
-109.446
-109.494
-109.534
-109.567
-109.591
-109.608
-109.616
-112.57
-112.562
-112.547
-112.525
-112.495
-112.458
-112.414
-112.364
-112.307
-112.244
-112.177
-112.104
-112.027
-111.946
-111.862
-111.776
-111.688
-111.599
-111.51
-111.423
-111.336
-111.253
-111.173
-111.098
-111.028
-110.964
-110.906
-110.857
-110.815
-110.782
-110.759
-110.744
-110.739
-110.744
-110.759
-110.782
-110.815
-110.857
-110.906
-110.964
-111.028
-111.098
-111.173
-111.253
-111.336
-111.423
-111.51
-111.599
-111.688
-111.776
-111.862
-111.946
-112.027
-112.104
-112.177
-112.244
-112.307
-112.364
-112.414
-112.458
-112.495
-112.525
-112.547
-112.562
-112.57
-115.532
-115.525
-115.511
-115.49
-115.463
-115.429
-115.389
-115.343
-115.291
-115.234
-115.172
-115.105
-115.035
-114.961
-114.885
-114.807
-114.727
-114.646
-114.566
-114.487
-114.409
-114.333
-114.261
-114.193
-114.13
-114.073
-114.021
-113.977
-113.939
-113.91
-113.888
-113.875
-113.871
-113.875
-113.888
-113.91
-113.939
-113.977
-114.021
-114.073
-114.13
-114.193
-114.261
-114.333
-114.409
-114.487
-114.566
-114.646
-114.727
-114.807
-114.885
-114.961
-115.035
-115.105
-115.172
-115.234
-115.291
-115.343
-115.389
-115.429
-115.463
-115.49
-115.511
-115.525
-115.532
-118.5
-118.494
-118.481
-118.462
-118.437
-118.406
-118.37
-118.327
-118.28
-118.228
-118.171
-118.111
-118.047
-117.98
-117.91
-117.839
-117.767
-117.694
-117.621
-117.549
-117.479
-117.41
-117.345
-117.284
-117.227
-117.175
-117.129
-117.089
-117.055
-117.029
-117.01
-116.998
-116.994
-116.998
-117.01
-117.029
-117.055
-117.089
-117.129
-117.175
-117.227
-117.284
-117.345
-117.41
-117.479
-117.549
-117.621
-117.694
-117.767
-117.839
-117.91
-117.98
-118.047
-118.111
-118.171
-118.228
-118.28
-118.327
-118.37
-118.406
-118.437
-118.462
-118.481
-118.494
-118.5
-121.476
-121.47
-121.458
-121.441
-121.418
-121.39
-121.356
-121.317
-121.274
-121.227
-121.175
-121.12
-121.061
-121
-120.937
-120.873
-120.807
-120.741
-120.675
-120.61
-120.546
-120.484
-120.426
-120.37
-120.319
-120.272
-120.231
-120.194
-120.164
-120.14
-120.123
-120.113
-120.109
-120.113
-120.123
-120.14
-120.164
-120.194
-120.231
-120.272
-120.319
-120.37
-120.426
-120.484
-120.546
-120.61
-120.675
-120.741
-120.807
-120.873
-120.937
-121
-121.061
-121.12
-121.175
-121.227
-121.274
-121.317
-121.356
-121.39
-121.418
-121.441
-121.458
-121.47
-121.476
-124.457
-124.452
-124.441
-124.425
-124.404
-124.378
-124.347
-124.312
-124.273
-124.229
-124.182
-124.132
-124.079
-124.023
-123.966
-123.907
-123.848
-123.788
-123.728
-123.669
-123.611
-123.556
-123.503
-123.453
-123.406
-123.364
-123.326
-123.294
-123.267
-123.245
-123.23
-123.22
-123.217
-123.22
-123.23
-123.245
-123.267
-123.294
-123.326
-123.364
-123.406
-123.453
-123.503
-123.556
-123.611
-123.669
-123.728
-123.788
-123.848
-123.907
-123.966
-124.023
-124.079
-124.132
-124.182
-124.229
-124.273
-124.312
-124.347
-124.378
-124.404
-124.425
-124.441
-124.452
-124.457
-127.443
-127.439
-127.429
-127.414
-127.395
-127.372
-127.344
-127.311
-127.275
-127.236
-127.193
-127.147
-127.099
-127.048
-126.996
-126.943
-126.889
-126.834
-126.78
-126.727
-126.674
-126.624
-126.576
-126.531
-126.489
-126.451
-126.417
-126.388
-126.363
-126.344
-126.33
-126.322
-126.319
-126.322
-126.33
-126.344
-126.363
-126.388
-126.417
-126.451
-126.489
-126.531
-126.576
-126.624
-126.674
-126.727
-126.78
-126.834
-126.889
-126.943
-126.996
-127.048
-127.099
-127.147
-127.193
-127.236
-127.275
-127.311
-127.344
-127.372
-127.395
-127.414
-127.429
-127.439
-127.443
-130.435
-130.43
-130.422
-130.408
-130.391
-130.369
-130.344
-130.314
-130.282
-130.246
-130.207
-130.165
-130.121
-130.075
-130.028
-129.979
-129.93
-129.88
-129.831
-129.783
-129.736
-129.69
-129.647
-129.606
-129.568
-129.534
-129.504
-129.477
-129.455
-129.438
-129.425
-129.417
-129.415
-129.417
-129.425
-129.438
-129.455
-129.477
-129.504
-129.534
-129.568
-129.606
-129.647
-129.69
-129.736
-129.783
-129.831
-129.88
-129.93
-129.979
-130.028
-130.075
-130.121
-130.165
-130.207
-130.246
-130.282
-130.314
-130.344
-130.369
-130.391
-130.408
-130.422
-130.43
-130.435
-133.431
-133.427
-133.419
-133.407
-133.391
-133.371
-133.348
-133.321
-133.291
-133.258
-133.223
-133.185
-133.145
-133.103
-133.06
-133.016
-132.971
-132.927
-132.882
-132.838
-132.796
-132.754
-132.715
-132.678
-132.644
-132.613
-132.586
-132.562
-132.542
-132.526
-132.515
-132.508
-132.505
-132.508
-132.515
-132.526
-132.542
-132.562
-132.586
-132.613
-132.644
-132.678
-132.715
-132.754
-132.796
-132.838
-132.882
-132.927
-132.971
-133.016
-133.06
-133.103
-133.145
-133.185
-133.223
-133.258
-133.291
-133.321
-133.348
-133.371
-133.391
-133.407
-133.419
-133.427
-133.431
-136.431
-136.427
-136.42
-136.409
-136.395
-136.377
-136.355
-136.331
-136.304
-136.274
-136.241
-136.207
-136.171
-136.133
-136.093
-136.054
-136.013
-135.972
-135.932
-135.892
-135.854
-135.816
-135.781
-135.748
-135.717
-135.689
-135.664
-135.642
-135.624
-135.61
-135.6
-135.594
-135.592
-135.594
-135.6
-135.61
-135.624
-135.642
-135.664
-135.689
-135.717
-135.748
-135.781
-135.816
-135.854
-135.892
-135.932
-135.972
-136.013
-136.054
-136.093
-136.133
-136.171
-136.207
-136.241
-136.274
-136.304
-136.331
-136.355
-136.377
-136.395
-136.409
-136.42
-136.427
-136.431
-139.435
-139.432
-139.425
-139.415
-139.402
-139.385
-139.366
-139.344
-139.319
-139.292
-139.262
-139.231
-139.198
-139.163
-139.128
-139.092
-139.055
-139.018
-138.981
-138.945
-138.91
-138.877
-138.845
-138.814
-138.787
-138.761
-138.739
-138.719
-138.703
-138.69
-138.681
-138.675
-138.673
-138.675
-138.681
-138.69
-138.703
-138.719
-138.739
-138.761
-138.787
-138.814
-138.845
-138.877
-138.91
-138.945
-138.981
-139.018
-139.055
-139.092
-139.128
-139.163
-139.198
-139.231
-139.262
-139.292
-139.319
-139.344
-139.366
-139.385
-139.402
-139.415
-139.425
-139.432
-139.435
-142.443
-142.439
-142.433
-142.424
-142.412
-142.397
-142.38
-142.359
-142.337
-142.312
-142.285
-142.257
-142.227
-142.195
-142.163
-142.13
-142.097
-142.063
-142.03
-141.997
-141.966
-141.935
-141.906
-141.879
-141.854
-141.831
-141.81
-141.793
-141.778
-141.767
-141.758
-141.753
-141.751
-141.753
-141.758
-141.767
-141.778
-141.793
-141.81
-141.831
-141.854
-141.879
-141.906
-141.935
-141.966
-141.997
-142.03
-142.063
-142.097
-142.13
-142.163
-142.195
-142.227
-142.257
-142.285
-142.312
-142.337
-142.359
-142.38
-142.397
-142.412
-142.424
-142.433
-142.439
-142.443
-145.453
-145.45
-145.445
-145.436
-145.425
-145.412
-145.396
-145.377
-145.357
-145.334
-145.31
-145.284
-145.257
-145.228
-145.199
-145.169
-145.139
-145.108
-145.078
-145.049
-145.02
-144.992
-144.966
-144.941
-144.918
-144.898
-144.879
-144.863
-144.85
-144.84
-144.832
-144.828
-144.826
-144.828
-144.832
-144.84
-144.85
-144.863
-144.879
-144.898
-144.918
-144.941
-144.966
-144.992
-145.02
-145.049
-145.078
-145.108
-145.139
-145.169
-145.199
-145.228
-145.257
-145.284
-145.31
-145.334
-145.357
-145.377
-145.396
-145.412
-145.425
-145.436
-145.445
-145.45
-145.453
-148.466
-148.464
-148.459
-148.451
-148.441
-148.429
-148.414
-148.397
-148.379
-148.358
-148.336
-148.313
-148.288
-148.262
-148.235
-148.208
-148.181
-148.153
-148.126
-148.099
-148.073
-148.048
-148.024
-148.002
-147.981
-147.962
-147.946
-147.931
-147.919
-147.91
-147.903
-147.899
-147.898
-147.899
-147.903
-147.91
-147.919
-147.931
-147.946
-147.962
-147.981
-148.002
-148.024
-148.048
-148.073
-148.099
-148.126
-148.153
-148.181
-148.208
-148.235
-148.262
-148.288
-148.313
-148.336
-148.358
-148.379
-148.397
-148.414
-148.429
-148.441
-148.451
-148.459
-148.464
-148.466
-151.482
-151.48
-151.475
-151.469
-151.459
-151.448
-151.435
-151.42
-151.403
-151.384
-151.364
-151.342
-151.32
-151.296
-151.272
-151.248
-151.223
-151.198
-151.173
-151.149
-151.125
-151.102
-151.081
-151.061
-151.042
-151.025
-151.01
-150.997
-150.986
-150.977
-150.971
-150.968
-150.966
-150.968
-150.971
-150.977
-150.986
-150.997
-151.01
-151.025
-151.042
-151.061
-151.081
-151.102
-151.125
-151.149
-151.173
-151.198
-151.223
-151.248
-151.272
-151.296
-151.32
-151.342
-151.364
-151.384
-151.403
-151.42
-151.435
-151.448
-151.459
-151.469
-151.475
-151.48
-151.482
-154.501
-154.499
-154.494
-154.488
-154.48
-154.47
-154.457
-154.444
-154.428
-154.411
-154.393
-154.373
-154.353
-154.332
-154.31
-154.287
-154.265
-154.242
-154.22
-154.198
-154.176
-154.156
-154.136
-154.118
-154.101
-154.086
-154.072
-154.06
-154.05
-154.043
-154.037
-154.034
-154.033
-154.034
-154.037
-154.043
-154.05
-154.06
-154.072
-154.086
-154.101
-154.118
-154.136
-154.156
-154.176
-154.198
-154.22
-154.242
-154.265
-154.287
-154.31
-154.332
-154.353
-154.373
-154.393
-154.411
-154.428
-154.444
-154.457
-154.47
-154.48
-154.488
-154.494
-154.499
-154.501
-157.521
-157.519
-157.515
-157.51
-157.502
-157.493
-157.482
-157.469
-157.455
-157.44
-157.423
-157.405
-157.387
-157.368
-157.348
-157.327
-157.307
-157.286
-157.266
-157.246
-157.227
-157.208
-157.19
-157.174
-157.158
-157.144
-157.132
-157.121
-157.113
-157.106
-157.1
-157.097
-157.096
-157.097
-157.1
-157.106
-157.113
-157.121
-157.132
-157.144
-157.158
-157.174
-157.19
-157.208
-157.227
-157.246
-157.266
-157.286
-157.307
-157.327
-157.348
-157.368
-157.387
-157.405
-157.423
-157.44
-157.455
-157.469
-157.482
-157.493
-157.502
-157.51
-157.515
-157.519
-157.521
-160.544
-160.542
-160.538
-160.533
-160.526
-160.518
-160.508
-160.496
-160.484
-160.47
-160.455
-160.438
-160.422
-160.404
-160.386
-160.367
-160.349
-160.33
-160.312
-160.294
-160.276
-160.259
-160.243
-160.228
-160.214
-160.202
-160.191
-160.181
-160.173
-160.166
-160.162
-160.159
-160.158
-160.159
-160.162
-160.166
-160.173
-160.181
-160.191
-160.202
-160.214
-160.228
-160.243
-160.259
-160.276
-160.294
-160.312
-160.33
-160.349
-160.367
-160.386
-160.404
-160.422
-160.438
-160.455
-160.47
-160.484
-160.496
-160.508
-160.518
-160.526
-160.533
-160.538
-160.542
-160.544
-163.568
-163.566
-163.563
-163.558
-163.552
-163.544
-163.535
-163.525
-163.513
-163.501
-163.487
-163.472
-163.457
-163.441
-163.425
-163.408
-163.391
-163.374
-163.357
-163.341
-163.325
-163.31
-163.295
-163.282
-163.269
-163.258
-163.247
-163.239
-163.231
-163.226
-163.222
-163.219
-163.218
-163.219
-163.222
-163.226
-163.231
-163.239
-163.247
-163.258
-163.269
-163.282
-163.295
-163.31
-163.325
-163.341
-163.357
-163.374
-163.391
-163.408
-163.425
-163.441
-163.457
-163.472
-163.487
-163.501
-163.513
-163.525
-163.535
-163.544
-163.552
-163.558
-163.563
-163.566
-163.568
-166.594
-166.592
-166.589
-166.585
-166.579
-166.572
-166.564
-166.555
-166.544
-166.533
-166.52
-166.507
-166.493
-166.478
-166.463
-166.448
-166.433
-166.418
-166.402
-166.388
-166.373
-166.359
-166.346
-166.334
-166.322
-166.312
-166.303
-166.295
-166.288
-166.283
-166.279
-166.277
-166.276
-166.277
-166.279
-166.283
-166.288
-166.295
-166.303
-166.312
-166.322
-166.334
-166.346
-166.359
-166.373
-166.388
-166.402
-166.418
-166.433
-166.448
-166.463
-166.478
-166.493
-166.507
-166.52
-166.533
-166.544
-166.555
-166.564
-166.572
-166.579
-166.585
-166.589
-166.592
-166.594
-169.621
-169.62
-169.617
-169.613
-169.608
-169.602
-169.594
-169.586
-169.576
-169.565
-169.554
-169.542
-169.529
-169.516
-169.503
-169.489
-169.475
-169.461
-169.447
-169.434
-169.421
-169.408
-169.396
-169.385
-169.375
-169.365
-169.357
-169.35
-169.344
-169.339
-169.336
-169.334
-169.333
-169.334
-169.336
-169.339
-169.344
-169.35
-169.357
-169.365
-169.375
-169.385
-169.396
-169.408
-169.421
-169.434
-169.447
-169.461
-169.475
-169.489
-169.503
-169.516
-169.529
-169.542
-169.554
-169.565
-169.576
-169.586
-169.594
-169.602
-169.608
-169.613
-169.617
-169.62
-169.621
-172.65
-172.648
-172.646
-172.643
-172.638
-172.632
-172.625
-172.617
-172.609
-172.599
-172.589
-172.578
-172.566
-172.555
-172.542
-172.53
-172.517
-172.505
-172.492
-172.48
-172.468
-172.457
-172.446
-172.436
-172.426
-172.418
-172.41
-172.404
-172.398
-172.394
-172.391
-172.389
-172.389
-172.389
-172.391
-172.394
-172.398
-172.404
-172.41
-172.418
-172.426
-172.436
-172.446
-172.457
-172.468
-172.48
-172.492
-172.505
-172.517
-172.53
-172.542
-172.555
-172.566
-172.578
-172.589
-172.599
-172.609
-172.617
-172.625
-172.632
-172.638
-172.643
-172.646
-172.648
-172.65
-175.68
-175.678
-175.676
-175.673
-175.669
-175.664
-175.657
-175.65
-175.642
-175.634
-175.624
-175.614
-175.604
-175.593
-175.582
-175.571
-175.559
-175.548
-175.536
-175.525
-175.515
-175.504
-175.494
-175.485
-175.477
-175.469
-175.462
-175.456
-175.451
-175.448
-175.445
-175.443
-175.443
-175.443
-175.445
-175.448
-175.451
-175.456
-175.462
-175.469
-175.477
-175.485
-175.494
-175.504
-175.515
-175.525
-175.536
-175.548
-175.559
-175.571
-175.582
-175.593
-175.604
-175.614
-175.624
-175.634
-175.642
-175.65
-175.657
-175.664
-175.669
-175.673
-175.676
-175.678
-175.68
-178.71
-178.709
-178.708
-178.705
-178.701
-178.696
-178.69
-178.684
-178.677
-178.669
-178.66
-178.651
-178.642
-178.632
-178.622
-178.612
-178.601
-178.591
-178.581
-178.571
-178.561
-178.551
-178.542
-178.534
-178.526
-178.519
-178.513
-178.508
-178.504
-178.5
-178.498
-178.496
-178.495
-178.496
-178.498
-178.5
-178.504
-178.508
-178.513
-178.519
-178.526
-178.534
-178.542
-178.551
-178.561
-178.571
-178.581
-178.591
-178.601
-178.612
-178.622
-178.632
-178.642
-178.651
-178.66
-178.669
-178.677
-178.684
-178.69
-178.696
-178.701
-178.705
-178.708
-178.709
-178.71
-181.742
-181.742
-181.74
-181.737
-181.734
-181.729
-181.724
-181.718
-181.712
-181.705
-181.697
-181.689
-181.68
-181.671
-181.662
-181.653
-181.643
-181.634
-181.625
-181.615
-181.607
-181.598
-181.59
-181.582
-181.575
-181.569
-181.564
-181.559
-181.555
-181.552
-181.549
-181.548
-181.547
-181.548
-181.549
-181.552
-181.555
-181.559
-181.564
-181.569
-181.575
-181.582
-181.59
-181.598
-181.607
-181.615
-181.625
-181.634
-181.643
-181.653
-181.662
-181.671
-181.68
-181.689
-181.697
-181.705
-181.712
-181.718
-181.724
-181.729
-181.734
-181.737
-181.74
-181.742
-181.742
-184.775
-184.775
-184.773
-184.77
-184.767
-184.763
-184.759
-184.753
-184.747
-184.741
-184.734
-184.727
-184.719
-184.711
-184.702
-184.694
-184.685
-184.677
-184.668
-184.66
-184.652
-184.644
-184.637
-184.63
-184.624
-184.618
-184.613
-184.609
-184.605
-184.602
-184.6
-184.599
-184.598
-184.599
-184.6
-184.602
-184.605
-184.609
-184.613
-184.618
-184.624
-184.63
-184.637
-184.644
-184.652
-184.66
-184.668
-184.677
-184.685
-184.694
-184.702
-184.711
-184.719
-184.727
-184.734
-184.741
-184.747
-184.753
-184.759
-184.763
-184.767
-184.77
-184.773
-184.775
-184.775
-187.809
-187.808
-187.807
-187.805
-187.802
-187.798
-187.794
-187.789
-187.784
-187.778
-187.772
-187.765
-187.758
-187.75
-187.743
-187.735
-187.727
-187.72
-187.712
-187.704
-187.697
-187.69
-187.683
-187.677
-187.672
-187.666
-187.662
-187.658
-187.654
-187.652
-187.65
-187.649
-187.648
-187.649
-187.65
-187.652
-187.654
-187.658
-187.662
-187.666
-187.672
-187.677
-187.683
-187.69
-187.697
-187.704
-187.712
-187.72
-187.727
-187.735
-187.743
-187.75
-187.758
-187.765
-187.772
-187.778
-187.784
-187.789
-187.794
-187.798
-187.802
-187.805
-187.807
-187.808
-187.809
-190.844
-190.843
-190.842
-190.84
-190.837
-190.834
-190.83
-190.825
-190.821
-190.815
-190.809
-190.803
-190.797
-190.79
-190.783
-190.776
-190.769
-190.762
-190.755
-190.748
-190.742
-190.736
-190.73
-190.724
-190.719
-190.714
-190.71
-190.706
-190.703
-190.701
-190.699
-190.698
-190.698
-190.698
-190.699
-190.701
-190.703
-190.706
-190.71
-190.714
-190.719
-190.724
-190.73
-190.736
-190.742
-190.748
-190.755
-190.762
-190.769
-190.776
-190.783
-190.79
-190.797
-190.803
-190.809
-190.815
-190.821
-190.825
-190.83
-190.834
-190.837
-190.84
-190.842
-190.843
-190.844
-193.879
-193.878
-193.877
-193.875
-193.873
-193.87
-193.866
-193.862
-193.858
-193.853
-193.848
-193.842
-193.836
-193.83
-193.824
-193.818
-193.811
-193.805
-193.799
-193.792
-193.786
-193.781
-193.775
-193.77
-193.765
-193.761
-193.757
-193.754
-193.751
-193.749
-193.748
-193.747
-193.746
-193.747
-193.748
-193.749
-193.751
-193.754
-193.757
-193.761
-193.765
-193.77
-193.775
-193.781
-193.786
-193.792
-193.799
-193.805
-193.811
-193.818
-193.824
-193.83
-193.836
-193.842
-193.848
-193.853
-193.858
-193.862
-193.866
-193.87
-193.873
-193.875
-193.877
-193.878
-193.879
-196.914
-196.914
-196.913
-196.911
-196.909
-196.906
-196.903
-196.9
-196.895
-196.891
-196.886
-196.881
-196.876
-196.87
-196.865
-196.859
-196.853
-196.847
-196.842
-196.836
-196.831
-196.825
-196.821
-196.816
-196.812
-196.808
-196.804
-196.801
-196.799
-196.797
-196.796
-196.795
-196.794
-196.795
-196.796
-196.797
-196.799
-196.801
-196.804
-196.808
-196.812
-196.816
-196.821
-196.825
-196.831
-196.836
-196.842
-196.847
-196.853
-196.859
-196.865
-196.87
-196.876
-196.881
-196.886
-196.891
-196.895
-196.9
-196.903
-196.906
-196.909
-196.911
-196.913
-196.914
-196.914
-199.951
-199.95
-199.949
-199.948
-199.946
-199.943
-199.941
-199.937
-199.934
-199.93
-199.925
-199.921
-199.916
-199.911
-199.906
-199.9
-199.895
-199.89
-199.885
-199.88
-199.875
-199.87
-199.866
-199.861
-199.857
-199.854
-199.851
-199.848
-199.846
-199.844
-199.843
-199.842
-199.842
-199.842
-199.843
-199.844
-199.846
-199.848
-199.851
-199.854
-199.857
-199.861
-199.866
-199.87
-199.875
-199.88
-199.885
-199.89
-199.895
-199.9
-199.906
-199.911
-199.916
-199.921
-199.925
-199.93
-199.934
-199.937
-199.941
-199.943
-199.946
-199.948
-199.949
-199.95
-199.951
-202.988
-202.987
-202.986
-202.985
-202.983
-202.981
-202.978
-202.975
-202.972
-202.968
-202.964
-202.96
-202.956
-202.951
-202.947
-202.942
-202.937
-202.932
-202.928
-202.923
-202.919
-202.914
-202.91
-202.906
-202.903
-202.9
-202.897
-202.894
-202.892
-202.891
-202.89
-202.889
-202.889
-202.889
-202.89
-202.891
-202.892
-202.894
-202.897
-202.9
-202.903
-202.906
-202.91
-202.914
-202.919
-202.923
-202.928
-202.932
-202.937
-202.942
-202.947
-202.951
-202.956
-202.96
-202.964
-202.968
-202.972
-202.975
-202.978
-202.981
-202.983
-202.985
-202.986
-202.987
-202.988
-206.025
-206.025
-206.024
-206.022
-206.021
-206.019
-206.016
-206.014
-206.011
-206.007
-206.004
-206
-205.996
-205.992
-205.988
-205.983
-205.979
-205.975
-205.971
-205.966
-205.962
-205.958
-205.955
-205.951
-205.948
-205.945
-205.943
-205.94
-205.939
-205.937
-205.936
-205.935
-205.935
-205.935
-205.936
-205.937
-205.939
-205.94
-205.943
-205.945
-205.948
-205.951
-205.955
-205.958
-205.962
-205.966
-205.971
-205.975
-205.979
-205.983
-205.988
-205.992
-205.996
-206
-206.004
-206.007
-206.011
-206.014
-206.016
-206.019
-206.021
-206.022
-206.024
-206.025
-206.025
-209.063
-209.062
-209.062
-209.06
-209.059
-209.057
-209.055
-209.053
-209.05
-209.047
-209.044
-209.04
-209.037
-209.033
-209.029
-209.025
-209.021
-209.017
-209.013
-209.009
-209.006
-209.002
-208.999
-208.996
-208.993
-208.99
-208.988
-208.986
-208.984
-208.983
-208.982
-208.981
-208.981
-208.981
-208.982
-208.983
-208.984
-208.986
-208.988
-208.99
-208.993
-208.996
-208.999
-209.002
-209.006
-209.009
-209.013
-209.017
-209.021
-209.025
-209.029
-209.033
-209.037
-209.04
-209.044
-209.047
-209.05
-209.053
-209.055
-209.057
-209.059
-209.06
-209.062
-209.062
-209.063
-212.101
-212.1
-212.1
-212.099
-212.097
-212.096
-212.094
-212.092
-212.089
-212.086
-212.083
-212.08
-212.077
-212.074
-212.07
-212.067
-212.063
-212.059
-212.056
-212.052
-212.049
-212.046
-212.043
-212.04
-212.037
-212.035
-212.033
-212.031
-212.03
-212.028
-212.028
-212.027
-212.027
-212.027
-212.028
-212.028
-212.03
-212.031
-212.033
-212.035
-212.037
-212.04
-212.043
-212.046
-212.049
-212.052
-212.056
-212.059
-212.063
-212.067
-212.07
-212.074
-212.077
-212.08
-212.083
-212.086
-212.089
-212.092
-212.094
-212.096
-212.097
-212.099
-212.1
-212.1
-212.101
-215.139
-215.139
-215.138
-215.137
-215.136
-215.135
-215.133
-215.131
-215.129
-215.126
-215.124
-215.121
-215.118
-215.115
-215.111
-215.108
-215.105
-215.102
-215.099
-215.095
-215.092
-215.089
-215.087
-215.084
-215.082
-215.08
-215.078
-215.076
-215.075
-215.074
-215.073
-215.072
-215.072
-215.072
-215.073
-215.074
-215.075
-215.076
-215.078
-215.08
-215.082
-215.084
-215.087
-215.089
-215.092
-215.095
-215.099
-215.102
-215.105
-215.108
-215.111
-215.115
-215.118
-215.121
-215.124
-215.126
-215.129
-215.131
-215.133
-215.135
-215.136
-215.137
-215.138
-215.139
-215.139
-218.178
-218.178
-218.177
-218.176
-218.175
-218.174
-218.172
-218.17
-218.168
-218.166
-218.164
-218.161
-218.158
-218.156
-218.153
-218.15
-218.147
-218.144
-218.141
-218.138
-218.135
-218.133
-218.13
-218.128
-218.126
-218.124
-218.122
-218.121
-218.119
-218.118
-218.118
-218.117
-218.117
-218.117
-218.118
-218.118
-218.119
-218.121
-218.122
-218.124
-218.126
-218.128
-218.13
-218.133
-218.135
-218.138
-218.141
-218.144
-218.147
-218.15
-218.153
-218.156
-218.158
-218.161
-218.164
-218.166
-218.168
-218.17
-218.172
-218.174
-218.175
-218.176
-218.177
-218.178
-218.178
-221.217
-221.217
-221.216
-221.216
-221.215
-221.213
-221.212
-221.21
-221.208
-221.206
-221.204
-221.202
-221.199
-221.197
-221.194
-221.192
-221.189
-221.186
-221.184
-221.181
-221.178
-221.176
-221.174
-221.172
-221.17
-221.168
-221.166
-221.165
-221.164
-221.163
-221.162
-221.162
-221.162
-221.162
-221.162
-221.163
-221.164
-221.165
-221.166
-221.168
-221.17
-221.172
-221.174
-221.176
-221.178
-221.181
-221.184
-221.186
-221.189
-221.192
-221.194
-221.197
-221.199
-221.202
-221.204
-221.206
-221.208
-221.21
-221.212
-221.213
-221.215
-221.216
-221.216
-221.217
-221.217
-224.257
-224.256
-224.256
-224.255
-224.254
-224.253
-224.252
-224.25
-224.249
-224.247
-224.245
-224.243
-224.24
-224.238
-224.236
-224.233
-224.231
-224.228
-224.226
-224.224
-224.221
-224.219
-224.217
-224.215
-224.213
-224.212
-224.21
-224.209
-224.208
-224.207
-224.207
-224.206
-224.206
-224.206
-224.207
-224.207
-224.208
-224.209
-224.21
-224.212
-224.213
-224.215
-224.217
-224.219
-224.221
-224.224
-224.226
-224.228
-224.231
-224.233
-224.236
-224.238
-224.24
-224.243
-224.245
-224.247
-224.249
-224.25
-224.252
-224.253
-224.254
-224.255
-224.256
-224.256
-224.257
-227.296
-227.296
-227.295
-227.295
-227.294
-227.293
-227.292
-227.29
-227.289
-227.287
-227.285
-227.283
-227.281
-227.279
-227.277
-227.275
-227.273
-227.27
-227.268
-227.266
-227.264
-227.262
-227.26
-227.258
-227.257
-227.255
-227.254
-227.253
-227.252
-227.251
-227.251
-227.25
-227.25
-227.25
-227.251
-227.251
-227.252
-227.253
-227.254
-227.255
-227.257
-227.258
-227.26
-227.262
-227.264
-227.266
-227.268
-227.27
-227.273
-227.275
-227.277
-227.279
-227.281
-227.283
-227.285
-227.287
-227.289
-227.29
-227.292
-227.293
-227.294
-227.295
-227.295
-227.296
-227.296
-230.336
-230.336
-230.335
-230.335
-230.334
-230.333
-230.332
-230.331
-230.329
-230.328
-230.326
-230.324
-230.322
-230.321
-230.319
-230.317
-230.315
-230.313
-230.311
-230.309
-230.307
-230.305
-230.303
-230.302
-230.3
-230.299
-230.298
-230.297
-230.296
-230.295
-230.295
-230.294
-230.294
-230.294
-230.295
-230.295
-230.296
-230.297
-230.298
-230.299
-230.3
-230.302
-230.303
-230.305
-230.307
-230.309
-230.311
-230.313
-230.315
-230.317
-230.319
-230.321
-230.322
-230.324
-230.326
-230.328
-230.329
-230.331
-230.332
-230.333
-230.334
-230.335
-230.335
-230.336
-230.336
-233.376
-233.376
-233.375
-233.375
-233.374
-233.373
-233.372
-233.371
-233.37
-233.368
-233.367
-233.365
-233.364
-233.362
-233.36
-233.358
-233.356
-233.355
-233.353
-233.351
-233.349
-233.348
-233.346
-233.345
-233.343
-233.342
-233.341
-233.34
-233.339
-233.339
-233.338
-233.338
-233.338
-233.338
-233.338
-233.339
-233.339
-233.34
-233.341
-233.342
-233.343
-233.345
-233.346
-233.348
-233.349
-233.351
-233.353
-233.355
-233.356
-233.358
-233.36
-233.362
-233.364
-233.365
-233.367
-233.368
-233.37
-233.371
-233.372
-233.373
-233.374
-233.375
-233.375
-233.376
-233.376
-236.416
-236.416
-236.416
-236.415
-236.414
-236.414
-236.413
-236.412
-236.411
-236.409
-236.408
-236.406
-236.405
-236.403
-236.402
-236.4
-236.398
-236.397
-236.395
-236.393
-236.392
-236.39
-236.389
-236.388
-236.386
-236.385
-236.384
-236.383
-236.383
-236.382
-236.382
-236.382
-236.381
-236.382
-236.382
-236.382
-236.383
-236.383
-236.384
-236.385
-236.386
-236.388
-236.389
-236.39
-236.392
-236.393
-236.395
-236.397
-236.398
-236.4
-236.402
-236.403
-236.405
-236.406
-236.408
-236.409
-236.411
-236.412
-236.413
-236.414
-236.414
-236.415
-236.416
-236.416
-236.416
-239.456
-239.456
-239.456
-239.456
-239.455
-239.454
-239.453
-239.452
-239.451
-239.45
-239.449
-239.448
-239.446
-239.445
-239.443
-239.442
-239.44
-239.439
-239.437
-239.436
-239.434
-239.433
-239.432
-239.43
-239.429
-239.428
-239.427
-239.427
-239.426
-239.426
-239.425
-239.425
-239.425
-239.425
-239.425
-239.426
-239.426
-239.427
-239.427
-239.428
-239.429
-239.43
-239.432
-239.433
-239.434
-239.436
-239.437
-239.439
-239.44
-239.442
-239.443
-239.445
-239.446
-239.448
-239.449
-239.45
-239.451
-239.452
-239.453
-239.454
-239.455
-239.456
-239.456
-239.456
-239.456
-242.497
-242.497
-242.496
-242.496
-242.496
-242.495
-242.494
-242.493
-242.492
-242.491
-242.49
-242.489
-242.488
-242.486
-242.485
-242.484
-242.482
-242.481
-242.479
-242.478
-242.477
-242.476
-242.474
-242.473
-242.472
-242.471
-242.47
-242.47
-242.469
-242.469
-242.468
-242.468
-242.468
-242.468
-242.468
-242.469
-242.469
-242.47
-242.47
-242.471
-242.472
-242.473
-242.474
-242.476
-242.477
-242.478
-242.479
-242.481
-242.482
-242.484
-242.485
-242.486
-242.488
-242.489
-242.49
-242.491
-242.492
-242.493
-242.494
-242.495
-242.496
-242.496
-242.496
-242.497
-242.497
-245.537
-245.537
-245.537
-245.537
-245.536
-245.536
-245.535
-245.534
-245.533
-245.532
-245.531
-245.53
-245.529
-245.528
-245.527
-245.525
-245.524
-245.523
-245.522
-245.52
-245.519
-245.518
-245.517
-245.516
-245.515
-245.514
-245.513
-245.513
-245.512
-245.512
-245.511
-245.511
-245.511
-245.511
-245.511
-245.512
-245.512
-245.513
-245.513
-245.514
-245.515
-245.516
-245.517
-245.518
-245.519
-245.52
-245.522
-245.523
-245.524
-245.525
-245.527
-245.528
-245.529
-245.53
-245.531
-245.532
-245.533
-245.534
-245.535
-245.536
-245.536
-245.537
-245.537
-245.537
-245.537
-248.578
-248.578
-248.578
-248.578
-248.577
-248.577
-248.576
-248.575
-248.574
-248.574
-248.573
-248.572
-248.57
-248.569
-248.568
-248.567
-248.566
-248.565
-248.564
-248.563
-248.561
-248.56
-248.559
-248.558
-248.558
-248.557
-248.556
-248.556
-248.555
-248.555
-248.554
-248.554
-248.554
-248.554
-248.554
-248.555
-248.555
-248.556
-248.556
-248.557
-248.558
-248.558
-248.559
-248.56
-248.561
-248.563
-248.564
-248.565
-248.566
-248.567
-248.568
-248.569
-248.57
-248.572
-248.573
-248.574
-248.574
-248.575
-248.576
-248.577
-248.577
-248.578
-248.578
-248.578
-248.578
-251.619
-251.619
-251.619
-251.618
-251.618
-251.618
-251.617
-251.616
-251.616
-251.615
-251.614
-251.613
-251.612
-251.611
-251.61
-251.609
-251.608
-251.607
-251.606
-251.605
-251.604
-251.603
-251.602
-251.601
-251.6
-251.599
-251.599
-251.598
-251.598
-251.598
-251.597
-251.597
-251.597
-251.597
-251.597
-251.598
-251.598
-251.598
-251.599
-251.599
-251.6
-251.601
-251.602
-251.603
-251.604
-251.605
-251.606
-251.607
-251.608
-251.609
-251.61
-251.611
-251.612
-251.613
-251.614
-251.615
-251.616
-251.616
-251.617
-251.618
-251.618
-251.618
-251.619
-251.619
-251.619
-254.66
-254.66
-254.66
-254.659
-254.659
-254.659
-254.658
-254.658
-254.657
-254.656
-254.655
-254.654
-254.654
-254.653
-254.652
-254.651
-254.65
-254.649
-254.648
-254.647
-254.646
-254.645
-254.644
-254.643
-254.643
-254.642
-254.641
-254.641
-254.641
-254.64
-254.64
-254.64
-254.64
-254.64
-254.64
-254.64
-254.641
-254.641
-254.641
-254.642
-254.643
-254.643
-254.644
-254.645
-254.646
-254.647
-254.648
-254.649
-254.65
-254.651
-254.652
-254.653
-254.654
-254.654
-254.655
-254.656
-254.657
-254.658
-254.658
-254.659
-254.659
-254.659
-254.66
-254.66
-254.66
-257.701
-257.701
-257.701
-257.701
-257.7
-257.7
-257.699
-257.699
-257.698
-257.697
-257.697
-257.696
-257.695
-257.694
-257.693
-257.692
-257.692
-257.691
-257.69
-257.689
-257.688
-257.687
-257.687
-257.686
-257.685
-257.685
-257.684
-257.684
-257.683
-257.683
-257.683
-257.683
-257.682
-257.683
-257.683
-257.683
-257.683
-257.684
-257.684
-257.685
-257.685
-257.686
-257.687
-257.687
-257.688
-257.689
-257.69
-257.691
-257.692
-257.692
-257.693
-257.694
-257.695
-257.696
-257.697
-257.697
-257.698
-257.699
-257.699
-257.7
-257.7
-257.701
-257.701
-257.701
-257.701
-260.742
-260.742
-260.742
-260.742
-260.741
-260.741
-260.741
-260.74
-260.74
-260.739
-260.738
-260.737
-260.737
-260.736
-260.735
-260.734
-260.733
-260.733
-260.732
-260.731
-260.73
-260.729
-260.729
-260.728
-260.728
-260.727
-260.726
-260.726
-260.726
-260.725
-260.725
-260.725
-260.725
-260.725
-260.725
-260.725
-260.726
-260.726
-260.726
-260.727
-260.728
-260.728
-260.729
-260.729
-260.73
-260.731
-260.732
-260.733
-260.733
-260.734
-260.735
-260.736
-260.737
-260.737
-260.738
-260.739
-260.74
-260.74
-260.741
-260.741
-260.741
-260.742
-260.742
-260.742
-260.742
-263.783
-263.783
-263.783
-263.783
-263.783
-263.782
-263.782
-263.781
-263.781
-263.78
-263.78
-263.779
-263.778
-263.778
-263.777
-263.776
-263.775
-263.775
-263.774
-263.773
-263.772
-263.772
-263.771
-263.77
-263.77
-263.769
-263.769
-263.768
-263.768
-263.768
-263.768
-263.768
-263.768
-263.768
-263.768
-263.768
-263.768
-263.768
-263.769
-263.769
-263.77
-263.77
-263.771
-263.772
-263.772
-263.773
-263.774
-263.775
-263.775
-263.776
-263.777
-263.778
-263.778
-263.779
-263.78
-263.78
-263.781
-263.781
-263.782
-263.782
-263.783
-263.783
-263.783
-263.783
-263.783
-266.825
-266.825
-266.825
-266.824
-266.824
-266.824
-266.823
-266.823
-266.822
-266.822
-266.821
-266.821
-266.82
-266.819
-266.819
-266.818
-266.817
-266.816
-266.816
-266.815
-266.814
-266.814
-266.813
-266.813
-266.812
-266.812
-266.811
-266.811
-266.811
-266.81
-266.81
-266.81
-266.81
-266.81
-266.81
-266.81
-266.811
-266.811
-266.811
-266.812
-266.812
-266.813
-266.813
-266.814
-266.814
-266.815
-266.816
-266.816
-266.817
-266.818
-266.819
-266.819
-266.82
-266.821
-266.821
-266.822
-266.822
-266.823
-266.823
-266.824
-266.824
-266.824
-266.825
-266.825
-266.825
-269.866
-269.866
-269.866
-269.866
-269.866
-269.865
-269.865
-269.864
-269.864
-269.863
-269.863
-269.862
-269.862
-269.861
-269.86
-269.86
-269.859
-269.858
-269.858
-269.857
-269.856
-269.856
-269.855
-269.855
-269.854
-269.854
-269.853
-269.853
-269.853
-269.853
-269.852
-269.852
-269.852
-269.852
-269.852
-269.853
-269.853
-269.853
-269.853
-269.854
-269.854
-269.855
-269.855
-269.856
-269.856
-269.857
-269.858
-269.858
-269.859
-269.86
-269.86
-269.861
-269.862
-269.862
-269.863
-269.863
-269.864
-269.864
-269.865
-269.865
-269.866
-269.866
-269.866
-269.866
-269.866
-272.908
-272.908
-272.907
-272.907
-272.907
-272.907
-272.906
-272.906
-272.906
-272.905
-272.905
-272.904
-272.903
-272.903
-272.902
-272.902
-272.901
-272.9
-272.9
-272.899
-272.899
-272.898
-272.897
-272.897
-272.896
-272.896
-272.896
-272.895
-272.895
-272.895
-272.895
-272.895
-272.895
-272.895
-272.895
-272.895
-272.895
-272.895
-272.896
-272.896
-272.896
-272.897
-272.897
-272.898
-272.899
-272.899
-272.9
-272.9
-272.901
-272.902
-272.902
-272.903
-272.903
-272.904
-272.905
-272.905
-272.906
-272.906
-272.906
-272.907
-272.907
-272.907
-272.907
-272.908
-272.908
-275.949
-275.949
-275.949
-275.949
-275.949
-275.948
-275.948
-275.948
-275.947
-275.947
-275.946
-275.946
-275.945
-275.945
-275.944
-275.943
-275.943
-275.942
-275.942
-275.941
-275.941
-275.94
-275.939
-275.939
-275.939
-275.938
-275.938
-275.938
-275.937
-275.937
-275.937
-275.937
-275.937
-275.937
-275.937
-275.937
-275.937
-275.938
-275.938
-275.938
-275.939
-275.939
-275.939
-275.94
-275.941
-275.941
-275.942
-275.942
-275.943
-275.943
-275.944
-275.945
-275.945
-275.946
-275.946
-275.947
-275.947
-275.948
-275.948
-275.948
-275.949
-275.949
-275.949
-275.949
-275.949
-278.991
-278.991
-278.99
-278.99
-278.99
-278.99
-278.99
-278.989
-278.989
-278.988
-278.988
-278.987
-278.987
-278.986
-278.986
-278.985
-278.985
-278.984
-278.984
-278.983
-278.983
-278.982
-278.982
-278.981
-278.981
-278.98
-278.98
-278.98
-278.979
-278.979
-278.979
-278.979
-278.979
-278.979
-278.979
-278.979
-278.979
-278.98
-278.98
-278.98
-278.981
-278.981
-278.982
-278.982
-278.983
-278.983
-278.984
-278.984
-278.985
-278.985
-278.986
-278.986
-278.987
-278.987
-278.988
-278.988
-278.989
-278.989
-278.99
-278.99
-278.99
-278.99
-278.99
-278.991
-278.991
-282.032
-282.032
-282.032
-282.032
-282.032
-282.031
-282.031
-282.031
-282.03
-282.03
-282.03
-282.029
-282.029
-282.028
-282.028
-282.027
-282.027
-282.026
-282.025
-282.025
-282.024
-282.024
-282.024
-282.023
-282.023
-282.022
-282.022
-282.022
-282.022
-282.021
-282.021
-282.021
-282.021
-282.021
-282.021
-282.021
-282.022
-282.022
-282.022
-282.022
-282.023
-282.023
-282.024
-282.024
-282.024
-282.025
-282.025
-282.026
-282.027
-282.027
-282.028
-282.028
-282.029
-282.029
-282.03
-282.03
-282.03
-282.031
-282.031
-282.031
-282.032
-282.032
-282.032
-282.032
-282.032
-285.074
-285.074
-285.074
-285.074
-285.073
-285.073
-285.073
-285.073
-285.072
-285.072
-285.071
-285.071
-285.07
-285.07
-285.069
-285.069
-285.068
-285.068
-285.067
-285.067
-285.066
-285.066
-285.065
-285.065
-285.065
-285.064
-285.064
-285.064
-285.064
-285.063
-285.063
-285.063
-285.063
-285.063
-285.063
-285.063
-285.064
-285.064
-285.064
-285.064
-285.065
-285.065
-285.065
-285.066
-285.066
-285.067
-285.067
-285.068
-285.068
-285.069
-285.069
-285.07
-285.07
-285.071
-285.071
-285.072
-285.072
-285.073
-285.073
-285.073
-285.073
-285.074
-285.074
-285.074
-285.074
-288.116
-288.116
-288.115
-288.115
-288.115
-288.115
-288.115
-288.114
-288.114
-288.114
-288.113
-288.113
-288.112
-288.112
-288.111
-288.111
-288.11
-288.11
-288.109
-288.109
-288.108
-288.108
-288.107
-288.107
-288.107
-288.106
-288.106
-288.106
-288.106
-288.105
-288.105
-288.105
-288.105
-288.105
-288.105
-288.105
-288.106
-288.106
-288.106
-288.106
-288.107
-288.107
-288.107
-288.108
-288.108
-288.109
-288.109
-288.11
-288.11
-288.111
-288.111
-288.112
-288.112
-288.113
-288.113
-288.114
-288.114
-288.114
-288.115
-288.115
-288.115
-288.115
-288.115
-288.116
-288.116
-291.157
-291.157
-291.157
-291.157
-291.157
-291.157
-291.156
-291.156
-291.156
-291.155
-291.155
-291.155
-291.154
-291.154
-291.153
-291.153
-291.152
-291.152
-291.151
-291.151
-291.15
-291.15
-291.149
-291.149
-291.149
-291.148
-291.148
-291.148
-291.148
-291.147
-291.147
-291.147
-291.147
-291.147
-291.147
-291.147
-291.148
-291.148
-291.148
-291.148
-291.149
-291.149
-291.149
-291.15
-291.15
-291.151
-291.151
-291.152
-291.152
-291.153
-291.153
-291.154
-291.154
-291.155
-291.155
-291.155
-291.156
-291.156
-291.156
-291.157
-291.157
-291.157
-291.157
-291.157
-291.157
-294.199
-294.199
-294.199
-294.199
-294.199
-294.199
-294.198
-294.198
-294.198
-294.197
-294.197
-294.196
-294.196
-294.195
-294.195
-294.194
-294.194
-294.194
-294.193
-294.193
-294.192
-294.192
-294.191
-294.191
-294.19
-294.19
-294.19
-294.19
-294.189
-294.189
-294.189
-294.189
-294.189
-294.189
-294.189
-294.189
-294.189
-294.19
-294.19
-294.19
-294.19
-294.191
-294.191
-294.192
-294.192
-294.193
-294.193
-294.194
-294.194
-294.194
-294.195
-294.195
-294.196
-294.196
-294.197
-294.197
-294.198
-294.198
-294.198
-294.199
-294.199
-294.199
-294.199
-294.199
-294.199
  0 KSP preconditioned resid norm 3.005729294791e+04 true resid norm 3.005729294791e+04 ||Ae||/||Ax|| 9.486627323288e-05
  1 KSP preconditioned resid norm 5.352387062140e-07 true resid norm 8.438016085313e-07 ||Ae||/||Ax|| 2.663191062748e-15
Linear solve converged due to CONVERGED_RTOL
Process [0]
71.0932
71.0721
71.0298
70.9666
70.8829
70.779
70.6555
70.5131
70.3525
70.1748
69.9809
69.7722
69.5501
69.3161
69.072
68.8197
68.5614
68.2993
68.0357
67.7734
67.515
67.2632
67.0208
66.7908
66.5759
66.3787
66.202
66.048
65.919
65.8166
65.7424
65.6974
65.6823
65.6974
65.7424
65.8166
65.919
66.048
66.202
66.3787
66.5759
66.7908
67.0208
67.2632
67.515
67.7734
68.0357
68.2993
68.5614
68.8197
69.072
69.3161
69.5501
69.7722
69.9809
70.1748
70.3525
70.5131
70.6555
70.779
70.8829
70.9666
71.0298
71.0721
71.0932
68.0729
68.0516
68.0091
67.9456
67.8615
67.757
67.6328
67.4896
67.3281
67.1492
66.9541
66.744
66.5203
66.2845
66.0384
65.784
65.5234
65.2588
64.9927
64.7276
64.4664
64.2117
63.9665
63.7336
63.5159
63.3162
63.1371
62.981
62.85
62.7462
62.6709
62.6252
62.6099
62.6252
62.6709
62.7462
62.85
62.981
63.1371
63.3162
63.5159
63.7336
63.9665
64.2117
64.4664
64.7276
64.9927
65.2588
65.5234
65.784
66.0384
66.2845
66.5203
66.744
66.9541
67.1492
67.3281
67.4896
67.6328
67.757
67.8615
67.9456
68.0091
68.0516
68.0729
65.0742
65.0527
65.0098
64.9457
64.8606
64.7551
64.6295
64.4847
64.3213
64.1402
63.9426
63.7296
63.5026
63.2633
63.0133
62.7547
62.4894
62.2199
61.9485
61.678
61.4111
61.1506
60.8996
60.661
60.4378
60.2328
60.0488
59.8883
59.7536
59.6467
59.5692
59.5222
59.5065
59.5222
59.5692
59.6467
59.7536
59.8883
60.0488
60.2328
60.4378
60.661
60.8996
61.1506
61.4111
61.678
61.9485
62.2199
62.4894
62.7547
63.0133
63.2633
63.5026
63.7296
63.9426
64.1402
64.3213
64.4847
64.6295
64.7551
64.8606
64.9457
65.0098
65.0527
65.0742
62.0973
62.0755
62.032
61.9669
61.8806
61.7734
61.6459
61.4986
61.3323
61.148
60.9466
60.7293
60.4976
60.2529
59.9971
59.732
59.4598
59.1828
58.9035
58.6247
58.3492
58.08
57.8202
57.5728
57.3411
57.128
56.9366
56.7694
56.629
56.5175
56.4366
56.3875
56.3711
56.3875
56.4366
56.5175
56.629
56.7694
56.9366
57.128
57.3411
57.5728
57.8202
58.08
58.3492
58.6247
58.9035
59.1828
59.4598
59.732
59.9971
60.2529
60.4976
60.7293
60.9466
61.148
61.3323
61.4986
61.6459
61.7734
61.8806
61.9669
62.032
62.0755
62.0973
59.1426
59.1204
59.0761
59.0098
58.9218
58.8124
58.6822
58.5318
58.3618
58.1731
57.9667
57.7438
57.5057
57.2539
56.9902
56.7165
56.435
56.148
55.8581
55.5681
55.2809
54.9998
54.728
54.4687
54.2254
54.0013
53.7997
53.6233
53.4751
53.3572
53.2716
53.2196
53.2022
53.2196
53.2716
53.3572
53.4751
53.6233
53.7997
54.0013
54.2254
54.4687
54.728
54.9998
55.2809
55.5681
55.8581
56.148
56.435
56.7165
56.9902
57.2539
57.5057
57.7438
57.9667
58.1731
58.3618
58.5318
58.6822
58.8124
58.9218
59.0098
59.0761
59.1204
59.1426
56.2105
56.1878
56.1425
56.0746
55.9846
55.8726
55.7392
55.5849
55.4103
55.2162
55.0036
54.7737
54.5277
54.267
53.9935
53.709
53.4157
53.1161
52.8127
52.5085
52.2066
51.9103
51.6231
51.3485
51.0903
50.8519
50.637
50.4488
50.2903
50.1641
50.0724
50.0167
49.998
50.0167
50.0724
50.1641
50.2903
50.4488
50.637
50.8519
51.0903
51.3485
51.6231
51.9103
52.2066
52.5085
52.8127
53.1161
53.4157
53.709
53.9935
54.267
54.5277
54.7737
55.0036
55.2162
55.4103
55.5849
55.7392
55.8726
55.9846
56.0746
56.1425
56.1878
56.2105
53.3014
53.2782
53.2317
53.1621
53.0696
52.9546
52.8174
52.6585
52.4785
52.2781
52.0582
51.8199
51.5645
51.2932
51.0079
50.7105
50.403
50.088
49.7682
49.4466
49.1265
48.8115
48.5052
48.2117
47.9349
47.6787
47.4472
47.2441
47.0727
46.936
46.8366
46.7762
46.7559
46.7762
46.8366
46.936
47.0727
47.2441
47.4472
47.6787
47.9349
48.2117
48.5052
48.8115
49.1265
49.4466
49.7682
50.088
50.403
50.7105
51.0079
51.2932
51.5645
51.8199
52.0582
52.2781
52.4785
52.6585
52.8174
52.9546
53.0696
53.1621
53.2317
53.2782
53.3014
50.416
50.3921
50.3444
50.2728
50.1776
50.0591
49.9176
49.7535
49.5673
49.3597
49.1315
48.8836
48.6173
48.3337
48.0347
47.722
47.3979
47.0648
46.7255
46.3832
46.0413
45.7038
45.3745
45.0579
44.7584
44.4805
44.2286
44.0071
43.8198
43.6702
43.5612
43.4949
43.4726
43.4949
43.5612
43.6702
43.8198
44.0071
44.2286
44.4805
44.7584
45.0579
45.3745
45.7038
46.0413
46.3832
46.7255
47.0648
47.3979
47.722
48.0347
48.3337
48.6173
48.8836
49.1315
49.3597
49.5673
49.7535
49.9176
50.0591
50.1776
50.2728
50.3444
50.3921
50.416
47.555
47.5304
47.4812
47.4075
47.3094
47.1871
47.0408
46.871
46.678
46.4623
46.2248
45.9661
45.6874
45.39
45.0753
44.7453
44.4019
44.0478
43.6858
43.3193
42.9518
42.5876
42.231
41.8868
41.5601
41.2558
40.9793
40.7353
40.5286
40.3631
40.2424
40.1688
40.1442
40.1688
40.2424
40.3631
40.5286
40.7353
40.9793
41.2558
41.5601
41.8868
42.231
42.5876
42.9518
43.3193
43.6858
44.0478
44.4019
44.7453
45.0753
45.39
45.6874
45.9661
46.2248
46.4623
46.678
46.871
47.0408
47.1871
47.3094
47.4075
47.4812
47.5304
47.555
44.7189
44.6936
44.6429
44.5669
44.4656
44.3393
44.188
44.012
43.8116
43.5872
43.3394
43.069
42.7767
42.4638
42.1316
41.782
41.4169
41.0389
40.6509
40.2563
39.8591
39.4636
39.0748
38.698
38.3388
38.0031
37.6968
37.4258
37.1954
37.0107
36.8756
36.7932
36.7656
36.7932
36.8756
37.0107
37.1954
37.4258
37.6968
38.0031
38.3388
38.698
39.0748
39.4636
39.8591
40.2563
40.6509
41.0389
41.4169
41.782
42.1316
42.4638
42.7767
43.069
43.3394
43.5872
43.8116
44.012
44.188
44.3393
44.4656
44.5669
44.6429
44.6936
44.7189
41.9087
41.8826
41.8303
41.7519
41.6474
41.5168
41.3602
41.1777
40.9695
40.7359
40.4771
40.1939
39.8869
39.5571
39.2057
38.8343
38.4449
38.04
37.6225
37.196
36.7645
36.3329
35.9065
35.4913
35.0937
34.7204
34.3785
34.0749
33.816
33.6078
33.4552
33.3621
33.3308
33.3621
33.4552
33.6078
33.816
34.0749
34.3785
34.7204
35.0937
35.4913
35.9065
36.3329
36.7645
37.196
37.6225
38.04
38.4449
38.8343
39.2057
39.5571
39.8869
40.1939
40.4771
40.7359
40.9695
41.1777
41.3602
41.5168
41.6474
41.7519
41.8303
41.8826
41.9087
39.125
39.0981
39.0443
38.9635
38.8557
38.7208
38.5588
38.3696
38.1533
37.9099
37.6398
37.343
37.0203
36.6723
36.3
35.9049
35.4888
35.054
34.6034
34.1407
33.6702
33.1969
32.7269
32.2667
31.8238
31.406
31.0214
30.6785
30.385
30.1483
29.9745
29.8682
29.8324
29.8682
29.9745
30.1483
30.385
30.6785
31.0214
31.406
31.8238
32.2667
32.7269
33.1969
33.6702
34.1407
34.6034
35.054
35.4888
35.9049
36.3
36.6723
37.0203
37.343
37.6398
37.9099
38.1533
38.3696
38.5588
38.7208
38.8557
38.9635
39.0443
39.0981
39.125
36.3686
36.341
36.2857
36.2025
36.0915
35.9523
35.7849
35.589
35.3645
35.1113
34.8293
34.5186
34.1794
33.8121
33.4176
32.9969
32.5516
32.0839
31.5966
31.0933
30.5785
30.0577
29.5372
29.0246
28.5284
28.0576
27.6222
27.2319
26.8965
26.625
26.4251
26.3027
26.2614
26.3027
26.4251
26.625
26.8965
27.2319
27.6222
28.0576
28.5284
29.0246
29.5372
30.0577
30.5785
31.0933
31.5966
32.0839
32.5516
32.9969
33.4176
33.8121
34.1794
34.5186
34.8293
35.1113
35.3645
35.589
35.7849
35.9523
36.0915
36.2025
36.2857
36.341
36.3686
33.6403
33.612
33.5553
33.4699
33.3558
33.2125
33.0399
32.8375
32.6049
32.3419
32.048
31.723
31.3669
30.9797
30.5617
30.1138
29.6372
29.1338
28.6061
28.0576
27.493
26.918
26.3395
25.766
25.2071
24.6735
24.1769
23.7295
23.3431
23.0291
22.7971
22.6547
22.6067
22.6547
22.7971
23.0291
23.3431
23.7295
24.1769
24.6735
25.2071
25.766
26.3395
26.918
27.493
28.0576
28.6061
29.1338
29.6372
30.1138
30.5617
30.9797
31.3669
31.723
32.048
32.3419
32.6049
32.8375
33.0399
33.2125
33.3558
33.4699
33.5553
33.612
33.6403
30.9409
30.9119
30.8539
30.7666
30.6496
30.5026
30.3251
30.1166
29.8764
29.6038
29.2983
28.9592
28.586
28.1784
27.7363
27.2599
26.7501
26.2083
25.6366
25.0384
24.4181
23.7818
23.1368
22.4926
21.86
21.2518
20.6819
20.165
19.7163
19.3498
19.078
18.9108
18.8544
18.9108
19.078
19.3498
19.7163
20.165
20.6819
21.2518
21.86
22.4926
23.1368
23.7818
24.4181
25.0384
25.6366
26.2083
26.7501
27.2599
27.7363
28.1784
28.586
28.9592
29.2983
29.6038
29.8764
30.1166
30.3251
30.5026
30.6496
30.7666
30.8539
30.9119
30.9409
28.2709
28.2414
28.1823
28.0933
27.9739
27.8237
27.6419
27.4278
27.1806
26.8992
26.5826
26.2299
25.84
25.4122
24.9456
24.44
23.8956
23.313
22.6941
22.0415
21.3596
20.6543
19.9334
19.2072
18.4882
17.7912
17.1329
16.5315
16.0059
15.5743
15.2529
15.0545
14.9874
15.0545
15.2529
15.5743
16.0059
16.5315
17.1329
17.7912
18.4882
19.2072
19.9334
20.6543
21.3596
22.0415
22.6941
23.313
23.8956
24.44
24.9456
25.4122
25.84
26.2299
26.5826
26.8992
27.1806
27.4278
27.6419
27.8237
27.9739
28.0933
28.1823
28.2414
28.2709
25.6308
25.601
25.5411
25.4508
25.3296
25.1768
24.9915
24.7728
24.5195
24.2303
23.9037
23.5384
23.1327
22.6852
22.1945
21.6596
21.0797
20.4548
19.7857
19.0745
18.3249
17.5425
16.7354
15.9147
15.0942
14.2912
13.526
12.821
12.2001
11.6868
11.3027
11.0648
10.9842
11.0648
11.3027
11.6868
12.2001
12.821
13.526
14.2912
15.0942
15.9147
16.7354
17.5425
18.3249
19.0745
19.7857
20.4548
21.0797
21.6596
22.1945
22.6852
23.1327
23.5384
23.9037
24.2303
24.5195
24.7728
24.9915
25.1768
25.3296
25.4508
25.5411
25.601
25.6308
23.0212
22.9911
22.9308
22.8397
22.7173
22.5628
22.3751
22.1529
21.8949
21.5993
21.2642
20.8878
20.4678
20.0021
19.4885
18.9248
18.3095
17.6413
16.92
16.1465
15.3234
14.4557
13.5514
12.6217
11.6823
10.753
9.85794
9.0251
8.28488
7.66833
7.20406
6.9153
6.81728
6.9153
7.20406
7.66833
8.28488
9.0251
9.85794
10.753
11.6823
12.6217
13.5514
14.4557
15.3234
16.1465
16.92
17.6413
18.3095
18.9248
19.4885
20.0021
20.4678
20.8878
21.2642
21.5993
21.8949
22.1529
22.3751
22.5628
22.7173
22.8397
22.9308
22.9911
23.0212
20.442
20.412
20.3516
20.2605
20.1378
19.9826
19.7936
19.5695
19.3084
19.0082
18.6668
18.2815
17.8494
17.3677
16.8331
16.2425
15.593
14.8819
14.1074
13.2688
12.3672
11.4063
10.393
9.33877
8.26019
7.17991
6.12672
5.13513
4.2441
3.49514
2.92715
2.57212
2.45128
2.57212
2.92715
3.49514
4.2441
5.13513
6.12672
7.17991
8.26019
9.33877
10.393
11.4063
12.3672
13.2688
14.1074
14.8819
15.593
16.2425
16.8331
17.3677
17.8494
18.2815
18.6668
19.0082
19.3084
19.5695
19.7936
19.9826
20.1378
20.2605
20.3516
20.412
20.442
17.8935
17.8637
17.8038
17.7132
17.5912
17.4366
17.2479
17.0236
16.7615
16.4592
16.1139
15.7226
15.2815
14.7869
14.2346
13.6202
12.939
12.1869
11.3598
10.4551
9.47129
8.40996
7.27624
6.0805
4.83981
3.57931
2.33294
1.14303
0.0590359
-0.86183
-1.56602
-2.00892
-2.16018
-2.00892
-1.56602
-0.86183
0.0590359
1.14303
2.33294
3.57931
4.83981
6.0805
7.27624
8.40996
9.47129
10.4551
11.3598
12.1869
12.939
13.6202
14.2346
14.7869
15.2815
15.7226
16.1139
16.4592
16.7615
17.0236
17.2479
17.4366
17.5912
17.7132
17.8038
17.8637
17.8935
15.3753
15.346
15.2871
15.1979
15.0777
14.9251
14.7385
14.5161
14.2554
13.9538
13.6079
13.2141
12.768
12.2648
11.6993
11.0655
10.3572
9.56789
8.69127
7.72151
6.65415
5.48717
4.22247
2.86788
1.43954
-0.0356466
-1.5182
-2.95663
-4.29171
-5.43886
-6.32455
-6.88616
-7.07886
-6.88616
-6.32455
-5.43886
-4.29171
-2.95663
-1.5182
-0.0356466
1.43954
2.86788
4.22247
5.48717
6.65415
7.72151
8.69127
9.56789
10.3572
11.0655
11.6993
12.2648
12.768
13.2141
13.6079
13.9538
14.2554
14.5161
14.7385
14.9251
15.0777
15.1979
15.2871
15.346
15.3753
12.8868
12.8583
12.801
12.7143
12.597
12.448
12.2655
12.0474
11.791
11.4933
11.1506
10.7586
10.3123
9.80605
9.2332
8.58642
7.85752
7.03761
6.11729
5.08709
3.93819
2.6636
1.25997
-0.269846
-1.91317
-3.64313
-5.41414
-7.16128
-8.83331
-10.2814
-11.4123
-12.1382
9.37384
-12.1382
-11.4123
-10.2814
-8.83331
-7.16128
-5.41414
-3.64313
-1.91317
-0.269846
1.25997
2.6636
3.93819
5.08709
6.11729
7.03761
7.85752
8.58642
9.2332
9.80605
10.3123
10.7586
11.1506
11.4933
11.791
12.0474
12.2655
12.448
12.597
12.7143
12.801
12.8583
12.8868
10.4273
10.4
10.345
10.2615
10.1487
10.005
9.82873
9.61751
9.36857
9.07854
8.74338
8.35831
7.91768
7.41489
6.84222
6.19077
5.45032
4.60931
3.6549
2.5732
1.34986
-0.0289113
-1.57439
-3.2923
-5.17791
-7.20892
-9.33435
-11.4427
9.36703
9.3665
9.3665
9.36662
9.36669
9.36662
9.3665
9.3665
9.36703
-11.4427
-9.33435
-7.20892
-5.17791
-3.2923
-1.57439
-0.0289113
1.34986
2.5732
3.6549
4.60931
5.45032
6.19077
6.84222
7.41489
7.91768
8.35831
8.74338
9.07854
9.36857
9.61751
9.82873
10.005
10.1487
10.2615
10.345
10.4
10.4273
7.99565
7.9698
7.91769
7.83865
7.73163
7.59517
7.4274
7.22593
6.98785
6.70959
6.38683
6.01442
5.58615
5.09468
4.53125
3.8855
3.14524
2.29617
1.32177
0.203169
-1.08064
-2.55212
-4.23365
-6.14444
-8.29502
-10.6788
9.36027
9.35958
9.35974
9.35964
9.35962
9.35965
9.35967
9.35965
9.35962
9.35964
9.35974
9.35958
9.36027
-10.6788
-8.29502
-6.14444
-4.23365
-2.55212
-1.08064
0.203169
1.32177
2.29617
3.14524
3.8855
4.53125
5.09468
5.58615
6.01442
6.38683
6.70959
6.98785
7.22593
7.4274
7.59517
7.73163
7.83865
7.91769
7.9698
7.99565
5.59029
5.56625
5.51777
5.4442
5.34446
5.21712
5.06028
4.87155
4.64794
4.38582
4.08072
3.72723
3.31882
2.84756
2.30388
1.67623
0.950643
0.11032
-0.864911
-1.99909
-3.32055
-4.86202
-6.66009
-8.75307
-11.1753
9.35305
9.35297
9.35277
9.35274
9.3527
9.35268
9.35268
9.35269
9.35268
9.35268
9.3527
9.35274
9.35277
9.35297
9.35305
-11.1753
-8.75307
-6.66009
-4.86202
-3.32055
-1.99909
-0.864911
0.11032
0.950643
1.67623
2.30388
2.84756
3.31882
3.72723
4.08072
4.38582
4.64794
4.87155
5.06028
5.21712
5.34446
5.4442
5.51777
5.56625
5.59029
3.20939
3.1875
3.14336
3.0763
2.98533
2.86902
2.72555
2.55257
2.34716
2.1057
1.82374
1.49584
1.11531
0.673977
0.161794
-0.433595
-1.12743
-1.93853
-2.89018
-4.01117
-5.33702
-6.91132
-8.78705
-11.0274
9.34533
9.34572
9.34581
9.34578
9.34576
9.34574
9.34572
9.34572
9.34572
9.34572
9.34572
9.34574
9.34576
9.34578
9.34581
9.34572
9.34533
-11.0274
-8.78705
-6.91132
-5.33702
-4.01117
-2.89018
-1.93853
-1.12743
-0.433595
0.161794
0.673977
1.11531
1.49584
1.82374
2.1057
2.34716
2.55257
2.72555
2.86902
2.98533
3.0763
3.14336
3.1875
3.20939
0.850766
0.83136
0.792211
0.732709
0.651912
0.548511
0.420785
0.266531
0.082984
-0.133297
-0.386575
-0.682119
-1.02645
-1.42765
-1.89579
-2.44344
-3.08641
-3.84464
-4.74346
-5.8152
-7.10119
-8.65453
-10.5437
9.33799
9.33846
9.33868
9.33877
9.33878
9.33877
9.33876
9.33875
9.33875
9.33875
9.33875
9.33875
9.33876
9.33877
9.33878
9.33877
9.33868
9.33846
9.33799
-10.5437
-8.65453
-7.10119
-5.8152
-4.74346
-3.84464
-3.08641
-2.44344
-1.89579
-1.42765
-1.02645
-0.682119
-0.386575
-0.133297
0.082984
0.266531
0.420785
0.548511
0.651912
0.732709
0.792211
0.83136
0.850766
-1.48811
-1.50473
-1.53827
-1.58926
-1.65855
-1.74729
-1.85704
-1.98976
-2.14795
-2.33472
-2.55397
-2.81053
-3.11045
-3.46131
-3.87263
-4.3565
-4.92833
-5.60797
-6.42116
-7.40163
-8.59387
-10.0566
-11.8665
9.33233
9.33183
9.33178
9.33179
9.3318
9.3318
9.33179
9.33178
9.33177
9.33177
9.33177
9.33178
9.33179
9.3318
9.3318
9.33179
9.33178
9.33183
9.33233
-11.8665
-10.0566
-8.59387
-7.40163
-6.42116
-5.60797
-4.92833
-4.3565
-3.87263
-3.46131
-3.11045
-2.81053
-2.55397
-2.33472
-2.14795
-1.98976
-1.85704
-1.74729
-1.65855
-1.58926
-1.53827
-1.50473
-1.48811
-3.81009
-3.82365
-3.85102
-3.89265
-3.94924
-4.02177
-4.11153
-4.22019
-4.34985
-4.50317
-4.68346
-4.89491
-5.14273
-5.43356
-5.77579
-6.18022
-6.66077
-7.23567
-7.92898
-8.77302
-9.81183
-11.107
9.32283
9.32445
9.32475
9.32481
9.32483
9.32483
9.32482
9.32481
9.3248
9.3248
9.32479
9.3248
9.3248
9.32481
9.32482
9.32483
9.32483
9.32481
9.32475
9.32445
9.32283
-11.107
-9.81183
-8.77302
-7.92898
-7.23567
-6.66077
-6.18022
-5.77579
-5.43356
-5.14273
-4.89491
-4.68346
-4.50317
-4.34985
-4.22019
-4.11153
-4.02177
-3.94924
-3.89265
-3.85102
-3.82365
-3.81009
-6.11826
-6.12854
-6.14929
-6.18084
-6.22375
-6.27875
-6.34683
-6.42928
-6.52772
-6.64421
-6.78133
-6.94233
-7.13134
-7.3536
-7.6158
-7.92663
-8.29741
-8.7431
-9.28374
-9.94661
-10.7695
-11.8055
9.318
9.31789
9.3179
9.3179
9.31788
9.31787
9.31785
9.31784
9.31782
9.31782
9.31781
9.31782
9.31782
9.31784
9.31785
9.31787
9.31788
9.3179
9.3179
9.31789
9.318
-11.8055
-10.7695
-9.94661
-9.28374
-8.7431
-8.29741
-7.92663
-7.6158
-7.3536
-7.13134
-6.94233
-6.78133
-6.64421
-6.52772
-6.42928
-6.34683
-6.27875
-6.22375
-6.18084
-6.14929
-6.12854
-6.11826
-8.41597
-8.4228
-8.43657
-8.45752
-8.48598
-8.52244
-8.56755
-8.62214
-8.68728
-8.76431
-8.85493
-8.96132
-9.08619
-9.23306
-9.40643
-9.61217
-9.85798
-10.1541
-10.5144
-10.9577
-11.5106
-12.2104
9.31163
9.31122
9.31106
9.31099
9.31094
9.31091
9.31088
9.31086
9.31084
9.31083
9.31083
9.31083
9.31084
9.31086
9.31088
9.31091
9.31094
9.31099
9.31106
9.31122
9.31163
-12.2104
-11.5106
-10.9577
-10.5144
-10.1541
-9.85798
-9.61217
-9.40643
-9.23306
-9.08619
-8.96132
-8.85493
-8.76431
-8.68728
-8.62214
-8.56755
-8.52244
-8.48598
-8.45752
-8.43657
-8.4228
-8.41597
-10.7067
-10.71
-10.7166
-10.7266
-10.7401
-10.7573
-10.7786
-10.8043
-10.8347
-10.8706
-10.9125
-10.9615
-11.0187
-11.0856
-11.1642
-11.257
-11.3674
-11.5
-11.6606
-11.8577
-12.1026
-12.4118
9.30454
9.30429
9.30414
9.30405
9.30399
9.30394
9.3039
9.30387
9.30385
9.30384
9.30383
9.30384
9.30385
9.30387
9.3039
9.30394
9.30399
9.30405
9.30414
9.30429
9.30454
-12.4118
-12.1026
-11.8577
-11.6606
-11.5
-11.3674
-11.257
-11.1642
-11.0856
-11.0187
-10.9615
-10.9125
-10.8706
-10.8347
-10.8043
-10.7786
-10.7573
-10.7401
-10.7266
-10.7166
-10.71
-10.7067
-12.9942
-12.9938
-12.9931
-12.992
-12.9904
-12.9882
-12.9853
-12.9815
-12.9768
-12.9707
-12.963
-12.9534
-12.9413
-12.9263
-12.9075
-12.884
-12.8545
-12.8172
-12.77
-12.7092
-12.6295
-12.5215
9.29723
9.29724
9.29717
9.29709
9.29702
9.29696
9.29691
9.29687
9.29685
9.29684
9.29683
9.29684
9.29685
9.29687
9.29691
9.29696
9.29702
9.29709
9.29717
9.29724
9.29723
-12.5215
-12.6295
-12.7092
-12.77
-12.8172
-12.8545
-12.884
-12.9075
-12.9263
-12.9413
-12.9534
-12.963
-12.9707
-12.9768
-12.9815
-12.9853
-12.9882
-12.9904
-12.992
-12.9931
-12.9938
-12.9942
-15.282
-15.2781
-15.2701
-15.2579
-15.2413
-15.2197
-15.1928
-15.1599
-15.1201
-15.0724
-15.0155
-14.9477
-14.867
-14.7708
-14.6556
-14.517
-14.3493
-14.1448
-13.893
-13.5798
-13.185
-12.6784
9.29009
9.29026
9.29022
9.29012
9.29004
9.28996
9.28991
9.28987
9.28984
9.28983
9.28982
9.28983
9.28984
9.28987
9.28991
9.28996
9.29004
9.29012
9.29022
9.29026
9.29009
-12.6784
-13.185
-13.5798
-13.893
-14.1448
-14.3493
-14.517
-14.6556
-14.7708
-14.867
-14.9477
-15.0155
-15.0724
-15.1201
-15.1599
-15.1928
-15.2197
-15.2413
-15.2579
-15.2701
-15.2781
-15.282
-17.5738
-17.5664
-17.5513
-17.5284
-17.4971
-17.4567
-17.4065
-17.3452
-17.2714
-17.1834
-17.0789
-16.9552
-16.8086
-16.6346
-16.4274
-16.1797
-15.8816
-15.5202
-15.0785
-14.5333
-13.8537
-13
9.28363
9.28351
9.28331
9.28315
9.28304
9.28295
9.28289
9.28285
9.28282
9.28281
9.2828
9.28281
9.28282
9.28285
9.28289
9.28295
9.28304
9.28315
9.28331
9.28351
9.28363
-13
-13.8537
-14.5333
-15.0785
-15.5202
-15.8816
-16.1797
-16.4274
-16.6346
-16.8086
-16.9552
-17.0789
-17.1834
-17.2714
-17.3452
-17.4065
-17.4567
-17.4971
-17.5284
-17.5513
-17.5664
-17.5738
-19.8732
-19.8624
-19.8406
-19.8074
-19.7621
-19.7038
-19.6313
-19.5431
-19.4372
-19.3112
-19.162
-18.9859
-18.7779
-18.532
-18.2405
-17.8935
-17.478
-16.9773
-16.3691
-15.6232
-14.699
-13.5396
9.27862
9.27684
9.27635
9.27614
9.27601
9.27592
9.27585
9.27581
9.27579
9.27577
9.27577
9.27577
9.27579
9.27581
9.27585
9.27592
9.27601
9.27614
9.27635
9.27684
9.27862
-13.5396
-14.699
-15.6232
-16.3691
-16.9773
-17.478
-17.8935
-18.2405
-18.532
-18.7779
-18.9859
-19.162
-19.3112
-19.4372
-19.5431
-19.6313
-19.7038
-19.7621
-19.8074
-19.8406
-19.8624
-19.8732
-22.1835
-22.1696
-22.1415
-22.0987
-22.0403
-21.9653
-21.8721
-21.759
-21.6234
-21.4625
-21.2725
-21.0488
-20.7857
-20.4758
-20.11
-19.6767
-19.1611
-18.5437
-17.7993
-16.8944
-15.7829
-14.3994
-12.6413
9.26888
9.26911
9.26904
9.26894
9.26885
9.2688
9.26876
9.26874
9.26873
9.26873
9.26873
9.26874
9.26876
9.2688
9.26885
9.26894
9.26904
9.26911
9.26888
-12.6413
-14.3994
-15.7829
-16.8944
-17.7993
-18.5437
-19.1611
-19.6767
-20.11
-20.4758
-20.7857
-21.0488
-21.2725
-21.4625
-21.6234
-21.759
-21.8721
-21.9653
-22.0403
-22.0987
-22.1415
-22.1696
-22.1835
-24.5081
-24.4913
-24.4573
-24.4057
-24.3354
-24.2451
-24.1332
-23.9976
-23.8354
-23.6434
-23.4173
-23.1519
-22.8409
-22.4763
-22.048
-21.5437
-20.9474
-20.239
-19.3927
-18.3752
-17.1431
-15.6413
-13.806
9.26295
9.26218
9.26198
9.26184
9.26176
9.26172
9.2617
9.26169
9.26169
9.26169
9.26169
9.26169
9.2617
9.26172
9.26176
9.26184
9.26198
9.26218
9.26295
-13.806
-15.6413
-17.1431
-18.3752
-19.3927
-20.239
-20.9474
-21.5437
-22.048
-22.4763
-22.8409
-23.1519
-23.4173
-23.6434
-23.8354
-23.9976
-24.1332
-24.2451
-24.3354
-24.4057
-24.4573
-24.4913
-24.5081
-26.8497
-26.8303
-26.7912
-26.7317
-26.6507
-26.547
-26.4185
-26.2631
-26.0777
-25.8588
-25.6018
-25.3013
-24.9506
-24.5413
-24.0633
-23.504
-22.8475
-22.0744
-21.1601
-20.0739
-18.7773
-17.222
-15.3475
-13.0688
9.25465
9.25487
9.25469
9.25462
9.25462
9.25462
9.25463
9.25464
9.25464
9.25464
9.25463
9.25462
9.25462
9.25462
9.25469
9.25487
9.25465
-13.0688
-15.3475
-17.222
-18.7773
-20.0739
-21.1601
-22.0744
-22.8475
-23.504
-24.0633
-24.5413
-24.9506
-25.3013
-25.6018
-25.8588
-26.0777
-26.2631
-26.4185
-26.547
-26.6507
-26.7317
-26.7912
-26.8303
-26.8497
-29.211
-29.1894
-29.1457
-29.0794
-28.9892
-28.8738
-28.7313
-28.5591
-28.3542
-28.1129
-27.8306
-27.5018
-27.1198
-26.6762
-26.1613
-25.5629
-24.8661
-24.0532
-23.1021
-21.9864
-20.674
-19.127
-17.3001
-15.1415
-12.6017
9.24816
9.24742
9.24742
9.2475
9.24754
9.24757
9.24759
9.2476
9.24759
9.24757
9.24754
9.2475
9.24742
9.24742
9.24816
-12.6017
-15.1415
-17.3001
-19.127
-20.674
-21.9864
-23.1021
-24.0532
-24.8661
-25.5629
-26.1613
-26.6762
-27.1198
-27.5018
-27.8306
-28.1129
-28.3542
-28.5591
-28.7313
-28.8738
-28.9892
-29.0794
-29.1457
-29.1894
-29.211
-31.5944
-31.5708
-31.5234
-31.4513
-31.3534
-31.2283
-31.0741
-30.8882
-30.6676
-30.4085
-30.1066
-29.7564
-29.3513
-28.8837
-28.3441
-27.7216
-27.0028
-26.1722
-25.2112
-24.0984
-22.8092
-21.3161
-19.5898
-17.6018
-15.3302
-12.7637
9.23938
9.24013
9.24045
9.24046
9.24051
9.24056
9.24058
9.24056
9.24051
9.24046
9.24045
9.24013
9.23938
-12.7637
-15.3302
-17.6018
-19.5898
-21.3161
-22.8092
-24.0984
-25.2112
-26.1722
-27.0028
-27.7216
-28.3441
-28.8837
-29.3513
-29.7564
-30.1066
-30.4085
-30.6676
-30.8882
-31.0741
-31.2283
-31.3534
-31.4513
-31.5234
-31.5708
-31.5944
-34.0016
-33.9766
-33.926
-33.8493
-33.7452
-33.6125
-33.4491
-33.2525
-33.02
-32.7478
-32.4317
-32.0666
-31.6465
-31.1641
-30.6112
-29.978
-29.2531
-28.4236
-27.4746
-26.3897
-25.1515
-23.742
-22.1451
-20.35
-18.3585
-16.2
-13.9758
9.23329
9.2337
9.23333
9.23346
9.23356
9.23361
9.23356
9.23346
9.23333
9.2337
9.23329
-13.9758
-16.2
-18.3585
-20.35
-22.1451
-23.742
-25.1515
-26.3897
-27.4746
-28.4236
-29.2531
-29.978
-30.6112
-31.1641
-31.6465
-32.0666
-32.4317
-32.7478
-33.02
-33.2525
-33.4491
-33.6125
-33.7452
-33.8493
-33.926
-33.9766
-34.0016
-36.4344
-36.4082
-36.3552
-36.275
-36.1663
-36.0278
-35.8576
-35.6535
-35.4126
-35.1316
-34.8066
-34.4328
-34.0047
-33.5162
-32.9599
-32.3275
-31.6097
-30.7963
-29.8758
-28.8368
-27.6677
-26.3583
-24.9018
-23.2977
-21.5562
-19.7029
-17.7754
-15.7649
-13.8678
9.2257
9.22641
9.22663
9.22673
9.22663
9.22641
9.2257
-13.8678
-15.7649
-17.7754
-19.7029
-21.5562
-23.2977
-24.9018
-26.3583
-27.6677
-28.8368
-29.8758
-30.7963
-31.6097
-32.3275
-32.9599
-33.5162
-34.0047
-34.4328
-34.8066
-35.1316
-35.4126
-35.6535
-35.8576
-36.0278
-36.1663
-36.275
-36.3552
-36.4082
-36.4344
-38.894
-38.8669
-38.8122
-38.7295
-38.6176
-38.4752
-38.3007
-38.0918
-37.846
-37.5602
-37.2309
-36.854
-36.4245
-35.9371
-35.3858
-34.7637
-34.0636
-33.2775
-32.3976
-31.4161
-30.3263
-29.124
-27.8084
-26.3849
-24.8677
-23.2811
-21.66
-20.0468
-18.5407
-17.2346
-16.2389
-15.6153
-15.4425
-15.6153
-16.2389
-17.2346
-18.5407
-20.0468
-21.66
-23.2811
-24.8677
-26.3849
-27.8084
-29.124
-30.3263
-31.4161
-32.3976
-33.2775
-34.0636
-34.7637
-35.3858
-35.9371
-36.4245
-36.854
-37.2309
-37.5602
-37.846
-38.0918
-38.3007
-38.4752
-38.6176
-38.7295
-38.8122
-38.8669
-38.894
-41.3811
-41.3535
-41.2978
-41.2136
-41.0999
-40.9554
-40.7786
-40.5676
-40.32
-40.0331
-39.7038
-39.3284
-38.903
-38.4231
-37.8836
-37.2793
-36.6047
-35.8541
-35.0225
-34.1052
-33.0994
-32.0047
-30.8244
-29.5674
-28.2494
-26.8946
-25.5365
-24.2201
-23.0106
-21.9775
-21.1905
-20.7002
-20.5412
-20.7002
-21.1905
-21.9775
-23.0106
-24.2201
-25.5365
-26.8946
-28.2494
-29.5674
-30.8244
-32.0047
-33.0994
-34.1052
-35.0225
-35.8541
-36.6047
-37.2793
-37.8836
-38.4231
-38.903
-39.3284
-39.7038
-40.0331
-40.32
-40.5676
-40.7786
-40.9554
-41.0999
-41.2136
-41.2978
-41.3535
-41.3811
-43.8964
-43.8685
-43.8125
-43.7277
-43.6133
-43.4684
-43.2913
-43.0805
-42.8338
-42.549
-42.2233
-41.8538
-41.437
-40.9694
-40.4471
-39.8663
-39.2228
-38.5132
-37.7343
-36.8842
-35.9628
-34.9722
-33.9185
-32.8118
-31.6685
-30.5114
-29.3706
-28.2847
-27.3013
-26.4707
-25.8408
-25.4486
-25.3169
-25.4486
-25.8408
-26.4707
-27.3013
-28.2847
-29.3706
-30.5114
-31.6685
-32.8118
-33.9185
-34.9722
-35.9628
-36.8842
-37.7343
-38.5132
-39.2228
-39.8663
-40.4471
-40.9694
-41.437
-41.8538
-42.2233
-42.549
-42.8338
-43.0805
-43.2913
-43.4684
-43.6133
-43.7277
-43.8125
-43.8685
-43.8964
-46.44
-46.4122
-46.3563
-46.2718
-46.158
-46.0139
-45.8383
-45.6297
-45.3864
-45.1064
-44.7874
-44.427
-44.0226
-43.5713
-43.0703
-42.5168
-41.9082
-41.2425
-40.5184
-39.7357
-38.8963
-38.004
-37.0661
-36.0935
-35.1018
-34.1116
-33.1489
-32.2453
-31.4367
-30.7601
-30.2497
-29.9325
-29.8252
-29.9325
-30.2497
-30.7601
-31.4367
-32.2453
-33.1489
-34.1116
-35.1018
-36.0935
-37.0661
-38.004
-38.8963
-39.7357
-40.5184
-41.2425
-41.9082
-42.5168
-43.0703
-43.5713
-44.0226
-44.427
-44.7874
-45.1064
-45.3864
-45.6297
-45.8383
-46.0139
-46.158
-46.2718
-46.3563
-46.4122
-46.44
-49.0119
-48.9844
-48.9291
-48.8456
-48.7334
-48.5914
-48.4188
-48.2142
-47.9763
-47.7033
-47.3936
-47.0451
-46.6558
-46.2236
-45.7467
-45.2232
-44.6516
-44.0311
-43.3619
-42.645
-41.8834
-41.0822
-40.249
-39.3947
-38.5335
-37.6837
-36.8673
-36.1096
-35.4382
-34.8808
-34.4625
-34.2032
-34.1154
-34.2032
-34.4625
-34.8808
-35.4382
-36.1096
-36.8673
-37.6837
-38.5335
-39.3947
-40.249
-41.0822
-41.8834
-42.645
-43.3619
-44.0311
-44.6516
-45.2232
-45.7467
-46.2236
-46.6558
-47.0451
-47.3936
-47.7033
-47.9763
-48.2142
-48.4188
-48.5914
-48.7334
-48.8456
-48.9291
-48.9844
-49.0119
-51.6118
-51.5848
-51.5306
-51.4488
-51.3388
-51.2001
-51.0317
-50.8327
-50.6018
-50.3377
-50.0391
-49.7045
-49.3324
-48.9215
-48.4705
-47.9784
-47.4446
-46.8694
-46.2537
-45.5996
-44.9109
-44.1929
-43.4535
-42.7027
-41.9537
-41.222
-40.526
-39.8861
-39.3238
-38.8601
-38.5138
-38.2998
-38.2274
-38.2998
-38.5138
-38.8601
-39.3238
-39.8861
-40.526
-41.222
-41.9537
-42.7027
-43.4535
-44.1929
-44.9109
-45.5996
-46.2537
-46.8694
-47.4446
-47.9784
-48.4705
-48.9215
-49.3324
-49.7045
-50.0391
-50.3377
-50.6018
-50.8327
-51.0317
-51.2001
-51.3388
-51.4488
-51.5306
-51.5848
-51.6118
-54.2392
-54.2128
-54.16
-54.0804
-53.9736
-53.839
-53.6759
-53.4835
-53.2609
-53.0071
-52.7212
-52.402
-52.0486
-51.6601
-51.2359
-50.7758
-50.2798
-49.7488
-49.1845
-48.5895
-47.9679
-47.3254
-46.6693
-46.0091
-45.3562
-44.724
-44.1277
-43.5839
-43.1093
-42.7202
-42.4308
-42.2525
-42.1922
-42.2525
-42.4308
-42.7202
-43.1093
-43.5839
-44.1277
-44.724
-45.3562
-46.0091
-46.6693
-47.3254
-47.9679
-48.5895
-49.1845
-49.7488
-50.2798
-50.7758
-51.2359
-51.6601
-52.0486
-52.402
-52.7212
-53.0071
-53.2609
-53.4835
-53.6759
-53.839
-53.9736
-54.0804
-54.16
-54.2128
-54.2392
-56.8933
-56.8678
-56.8167
-56.7397
-56.6365
-56.5067
-56.3497
-56.1649
-55.9517
-55.7092
-55.437
-55.1342
-54.8003
-54.435
-54.038
-53.6096
-53.1506
-52.6621
-52.1463
-51.6063
-51.0463
-50.4717
-49.8894
-49.3081
-48.7376
-48.1895
-47.6763
-47.2113
-46.808
-46.4789
-46.2352
-46.0853
-46.0347
-46.0853
-46.2352
-46.4789
-46.808
-47.2113
-47.6763
-48.1895
-48.7376
-49.3081
-49.8894
-50.4717
-51.0463
-51.6063
-52.1463
-52.6621
-53.1506
-53.6096
-54.038
-54.435
-54.8003
-55.1342
-55.437
-55.7092
-55.9517
-56.1649
-56.3497
-56.5067
-56.6365
-56.7397
-56.8167
-56.8678
-56.8933
-59.5733
-59.5488
-59.4997
-59.4257
-59.3266
-59.2021
-59.0518
-58.8753
-58.6721
-58.4417
-58.1838
-57.898
-57.584
-57.2419
-56.8719
-56.4746
-56.0511
-55.6031
-55.1328
-54.6436
-54.1394
-53.6257
-53.1087
-52.596
-52.0963
-51.6195
-51.1758
-50.7761
-50.4312
-50.1511
-49.9442
-49.8172
-49.7744
-49.8172
-49.9442
-50.1511
-50.4312
-50.7761
-51.1758
-51.6195
-52.0963
-52.596
-53.1087
-53.6257
-54.1394
-54.6436
-55.1328
-55.6031
-56.0511
-56.4746
-56.8719
-57.2419
-57.584
-57.898
-58.1838
-58.4417
-58.6721
-58.8753
-59.0518
-59.2021
-59.3266
-59.4257
-59.4997
-59.5488
-59.5733
-62.2784
-62.2549
-62.2078
-62.137
-62.0424
-61.9236
-61.7805
-61.6127
-61.42
-61.2022
-60.9589
-60.6903
-60.3963
-60.0772
-59.7336
-59.3663
-58.9767
-58.5666
-58.1386
-57.6959
-57.2423
-56.7829
-56.3235
-55.8707
-55.432
-55.0157
-54.6306
-54.2854
-53.9888
-53.7487
-53.572
-53.4637
-53.4273
-53.4637
-53.572
-53.7487
-53.9888
-54.2854
-54.6306
-55.0157
-55.432
-55.8707
-56.3235
-56.7829
-57.2423
-57.6959
-58.1386
-58.5666
-58.9767
-59.3663
-59.7336
-60.0772
-60.3963
-60.6903
-60.9589
-61.2022
-61.42
-61.6127
-61.7805
-61.9236
-62.0424
-62.137
-62.2078
-62.2549
-62.2784
-65.0072
-64.9849
-64.9401
-64.8727
-64.7827
-64.6699
-64.5342
-64.3755
-64.1935
-63.9883
-63.7599
-63.5084
-63.2341
-62.9374
-62.6192
-62.2806
-61.923
-61.5484
-61.1594
-60.7591
-60.3512
-59.9403
-59.5316
-59.1309
-58.7449
-58.3804
-58.0448
-57.7453
-57.489
-57.2821
-57.1302
-57.0373
-57.0061
-57.0373
-57.1302
-57.2821
-57.489
-57.7453
-58.0448
-58.3804
-58.7449
-59.1309
-59.5316
-59.9403
-60.3512
-60.7591
-61.1594
-61.5484
-61.923
-62.2806
-62.6192
-62.9374
-63.2341
-63.5084
-63.7599
-63.9883
-64.1935
-64.3755
-64.5342
-64.6699
-64.7827
-64.8727
-64.9401
-64.9849
-65.0072
-67.7589
-67.7377
-67.6952
-67.6313
-67.5461
-67.4395
-67.3114
-67.1618
-66.9907
-66.7981
-66.5844
-66.3497
-66.0945
-65.8195
-65.5256
-65.2141
-64.8865
-64.5449
-64.1917
-63.83
-63.4632
-63.0954
-62.7315
-62.3764
-62.0359
-61.7158
-61.4223
-61.1614
-60.9388
-60.7597
-60.6285
-60.5483
-60.5214
-60.5483
-60.6285
-60.7597
-60.9388
-61.1614
-61.4223
-61.7158
-62.0359
-62.3764
-62.7315
-63.0954
-63.4632
-63.83
-64.1917
-64.5449
-64.8865
-65.2141
-65.5256
-65.8195
-66.0945
-66.3497
-66.5844
-66.7981
-66.9907
-67.1618
-67.3114
-67.4395
-67.5461
-67.6313
-67.6952
-67.7377
-67.7589
-70.5322
-70.5121
-70.472
-70.4117
-70.3314
-70.2309
-70.1104
-69.9699
-69.8095
-69.6295
-69.4301
-69.2117
-68.975
-68.7208
-68.45
-68.164
-67.8644
-67.5532
-67.2327
-66.906
-66.5761
-66.2468
-65.9223
-65.6071
-65.3061
-65.0242
-64.7668
-64.5386
-64.3445
-64.1888
-64.0748
-64.0053
-63.982
-64.0053
-64.0748
-64.1888
-64.3445
-64.5386
-64.7668
-65.0242
-65.3061
-65.6071
-65.9223
-66.2468
-66.5761
-66.906
-67.2327
-67.5532
-67.8644
-68.164
-68.45
-68.7208
-68.975
-69.2117
-69.4301
-69.6295
-69.8095
-69.9699
-70.1104
-70.2309
-70.3314
-70.4117
-70.472
-70.5121
-70.5322
-73.3258
-73.3069
-73.2691
-73.2125
-73.137
-73.0427
-72.9297
-72.7982
-72.6484
-72.4805
-72.295
-72.0924
-71.8734
-71.6388
-71.3898
-71.1276
-70.8539
-70.5707
-70.2802
-69.9851
-69.6883
-69.3933
-69.1037
-68.8234
-68.5567
-68.308
-68.0814
-67.8812
-67.7114
-67.5753
-67.476
-67.4154
-67.3951
-67.4154
-67.476
-67.5753
-67.7114
-67.8812
-68.0814
-68.308
-68.5567
-68.8234
-69.1037
-69.3933
-69.6883
-69.9851
-70.2802
-70.5707
-70.8539
-71.1276
-71.3898
-71.6388
-71.8734
-72.0924
-72.295
-72.4805
-72.6484
-72.7982
-72.9297
-73.0427
-73.137
-73.2125
-73.2691
-73.3069
-73.3258
-76.1387
-76.1209
-76.0855
-76.0324
-75.9617
-75.8734
-75.7679
-75.6451
-75.5056
-75.3495
-75.1774
-74.9898
-74.7876
-74.5716
-74.3429
-74.1029
-73.8532
-73.5957
-73.3324
-73.0659
-72.7989
-72.5343
-72.2755
-72.0259
-71.7892
-71.5691
-71.3692
-71.193
-71.0439
-70.9246
-70.8377
-70.7847
-70.767
-70.7847
-70.8377
-70.9246
-71.0439
-71.193
-71.3692
-71.5691
-71.7892
-72.0259
-72.2755
-72.5343
-72.7989
-73.0659
-73.3324
-73.5957
-73.8532
-74.1029
-74.3429
-74.5716
-74.7876
-74.9898
-75.1774
-75.3495
-75.5056
-75.6451
-75.7679
-75.8734
-75.9617
-76.0324
-76.0855
-76.1209
-76.1387
-78.9695
-78.953
-78.9198
-78.8702
-78.8041
-78.7218
-78.6234
-78.5092
-78.3795
-78.2347
-78.0754
-77.9021
-77.7157
-77.5172
-77.3075
-77.0881
-76.8605
-76.6265
-76.388
-76.1473
-75.9069
-75.6695
-75.438
-75.2154
-75.0049
-74.8097
-74.6329
-74.4774
-74.346
-74.2412
-74.1648
-74.1183
-74.1028
-74.1183
-74.1648
-74.2412
-74.346
-74.4774
-74.6329
-74.8097
-75.0049
-75.2154
-75.438
-75.6695
-75.9069
-76.1473
-76.388
-76.6265
-76.8605
-77.0881
-77.3075
-77.5172
-77.7157
-77.9021
-78.0754
-78.2347
-78.3795
-78.5092
-78.6234
-78.7218
-78.8041
-78.8702
-78.9198
-78.953
-78.9695
-81.8173
-81.8018
-81.7709
-81.7246
-81.6631
-81.5865
-81.495
-81.389
-81.2687
-81.1347
-80.9875
-80.8277
-80.6563
-80.474
-80.282
-80.0817
-79.8743
-79.6617
-79.4457
-79.2283
-79.0118
-78.7986
-78.5913
-78.3926
-78.2051
-78.0316
-77.8749
-77.7373
-77.6213
-77.5288
-77.4615
-77.4206
-77.4069
-77.4206
-77.4615
-77.5288
-77.6213
-77.7373
-77.8749
-78.0316
-78.2051
-78.3926
-78.5913
-78.7986
-79.0118
-79.2283
-79.4457
-79.6617
-79.8743
-80.0817
-80.282
-80.474
-80.6563
-80.8277
-80.9875
-81.1347
-81.2687
-81.389
-81.495
-81.5865
-81.6631
-81.7246
-81.7709
-81.8018
-81.8173
-84.6808
-84.6664
-84.6376
-84.5946
-84.5374
-84.4662
-84.3814
-84.2831
-84.1719
-84.0481
-83.9123
-83.7653
-83.6078
-83.4407
-83.2651
-83.0822
-82.8935
-82.7005
-82.5048
-82.3085
-82.1134
-81.9218
-81.736
-81.5583
-81.391
-81.2366
-81.0974
-80.9754
-80.8726
-80.7908
-80.7314
-80.6953
-80.6832
-80.6953
-80.7314
-80.7908
-80.8726
-80.9754
-81.0974
-81.2366
-81.391
-81.5583
-81.736
-81.9218
-82.1134
-82.3085
-82.5048
-82.7005
-82.8935
-83.0822
-83.2651
-83.4407
-83.6078
-83.7653
-83.9123
-84.0481
-84.1719
-84.2831
-84.3814
-84.4662
-84.5374
-84.5946
-84.6376
-84.6664
-84.6808
-87.5589
-87.5455
-87.5188
-87.4789
-87.4259
-87.3599
-87.2814
-87.1906
-87.0878
-86.9737
-86.8487
-86.7135
-86.569
-86.416
-86.2555
-86.0888
-85.9171
-85.7419
-85.5647
-85.3873
-85.2115
-85.0392
-84.8725
-84.7134
-84.5639
-84.4263
-84.3023
-84.1939
-84.1027
-84.0302
-83.9775
-83.9456
-83.9348
-83.9456
-83.9775
-84.0302
-84.1027
-84.1939
-84.3023
-84.4263
-84.5639
-84.7134
-84.8725
-85.0392
-85.2115
-85.3873
-85.5647
-85.7419
-85.9171
-86.0888
-86.2555
-86.416
-86.569
-86.7135
-86.8487
-86.9737
-87.0878
-87.1906
-87.2814
-87.3599
-87.4259
-87.4789
-87.5188
-87.5455
-87.5589
-90.4506
-90.4382
-90.4135
-90.3765
-90.3274
-90.2665
-90.1939
-90.1101
-90.0153
-89.9102
-89.7953
-89.6713
-89.5388
-89.3988
-89.2523
-89.1004
-88.9443
-88.7852
-88.6248
-88.4645
-88.3059
-88.1509
-88.0012
-87.8586
-87.7249
-87.602
-87.4914
-87.3949
-87.3138
-87.2494
-87.2026
-87.1743
-87.1648
-87.1743
-87.2026
-87.2494
-87.3138
-87.3949
-87.4914
-87.602
-87.7249
-87.8586
-88.0012
-88.1509
-88.3059
-88.4645
-88.6248
-88.7852
-88.9443
-89.1004
-89.2523
-89.3988
-89.5388
-89.6713
-89.7953
-89.9102
-90.0153
-90.1101
-90.1939
-90.2665
-90.3274
-90.3765
-90.4135
-90.4382
-90.4506
-93.3549
-93.3434
-93.3205
-93.2864
-93.2411
-93.1848
-93.1179
-93.0406
-92.9534
-92.8568
-92.7513
-92.6375
-92.5162
-92.3883
-92.2547
-92.1163
-91.9744
-91.8301
-91.6848
-91.5399
-91.3968
-91.2573
-91.1227
-90.9947
-90.875
-90.7651
-90.6664
-90.5803
-90.508
-90.4506
-90.409
-90.3838
-90.3754
-90.3838
-90.409
-90.4506
-90.508
-90.5803
-90.6664
-90.7651
-90.875
-90.9947
-91.1227
-91.2573
-91.3968
-91.5399
-91.6848
-91.8301
-91.9744
-92.1163
-92.2547
-92.3883
-92.5162
-92.6375
-92.7513
-92.8568
-92.9534
-93.0406
-93.1179
-93.1848
-93.2411
-93.2864
-93.3205
-93.3434
-93.3549
-96.2708
-96.2602
-96.2391
-96.2076
-96.1658
-96.1139
-96.0523
-95.9812
-95.9011
-95.8123
-95.7156
-95.6114
-95.5005
-95.3836
-95.2618
-95.1358
-95.0068
-94.8759
-94.7443
-94.6133
-94.4843
-94.3585
-94.2375
-94.1226
-94.0152
-93.9167
-93.8285
-93.7515
-93.6871
-93.6359
-93.5988
-93.5764
-93.5688
-93.5764
-93.5988
-93.6359
-93.6871
-93.7515
-93.8285
-93.9167
-94.0152
-94.1226
-94.2375
-94.3585
-94.4843
-94.6133
-94.7443
-94.8759
-95.0068
-95.1358
-95.2618
-95.3836
-95.5005
-95.6114
-95.7156
-95.8123
-95.9011
-95.9812
-96.0523
-96.1139
-96.1658
-96.2076
-96.2391
-96.2602
-96.2708
-99.1975
-99.1877
-99.1683
-99.1392
-99.1008
-99.053
-98.9963
-98.931
-98.8574
-98.776
-98.6874
-98.5921
-98.4907
-98.3841
-98.273
-98.1584
-98.0412
-97.9225
-97.8033
-97.6848
-97.5683
-97.4549
-97.346
-97.2427
-97.1463
-97.0581
-96.979
-96.9102
-96.8526
-96.8069
-96.7738
-96.7537
-96.747
-96.7537
-96.7738
-96.8069
-96.8526
-96.9102
-96.979
-97.0581
-97.1463
-97.2427
-97.346
-97.4549
-97.5683
-97.6848
-97.8033
-97.9225
-98.0412
-98.1584
-98.273
-98.3841
-98.4907
-98.5921
-98.6874
-98.776
-98.8574
-98.931
-98.9963
-99.053
-99.1008
-99.1392
-99.1683
-99.1877
-99.1975
-102.134
-102.125
-102.107
-102.08
-102.045
-102.001
-101.949
-101.889
-101.822
-101.747
-101.666
-101.579
-101.486
-101.389
-101.288
-101.184
-101.077
-100.969
-100.862
-100.754
-100.649
-100.547
-100.449
-100.356
-100.269
-100.19
-100.119
-100.058
-100.006
-99.9651
-99.9355
-99.9176
-99.9116
-99.9176
-99.9355
-99.9651
-100.006
-100.058
-100.119
-100.19
-100.269
-100.356
-100.449
-100.547
-100.649
-100.754
-100.862
-100.969
-101.077
-101.184
-101.288
-101.389
-101.486
-101.579
-101.666
-101.747
-101.822
-101.889
-101.949
-102.001
-102.045
-102.08
-102.107
-102.125
-102.134
-105.08
-105.072
-105.055
-105.031
-104.998
-104.958
-104.91
-104.855
-104.793
-104.725
-104.651
-104.571
-104.487
-104.398
-104.306
-104.211
-104.114
-104.017
-103.919
-103.822
-103.727
-103.635
-103.546
-103.463
-103.385
-103.314
-103.25
-103.195
-103.148
-103.112
-103.085
-103.069
-103.064
-103.069
-103.085
-103.112
-103.148
-103.195
-103.25
-103.314
-103.385
-103.463
-103.546
-103.635
-103.727
-103.822
-103.919
-104.017
-104.114
-104.211
-104.306
-104.398
-104.487
-104.571
-104.651
-104.725
-104.793
-104.855
-104.91
-104.958
-104.998
-105.031
-105.055
-105.072
-105.08
-108.034
-108.026
-108.011
-107.989
-107.959
-107.922
-107.878
-107.828
-107.771
-107.709
-107.641
-107.568
-107.491
-107.41
-107.327
-107.24
-107.153
-107.064
-106.975
-106.888
-106.802
-106.719
-106.639
-106.563
-106.493
-106.429
-106.372
-106.323
-106.281
-106.248
-106.225
-106.21
-106.205
-106.21
-106.225
-106.248
-106.281
-106.323
-106.372
-106.429
-106.493
-106.563
-106.639
-106.719
-106.802
-106.888
-106.975
-107.064
-107.153
-107.24
-107.327
-107.41
-107.491
-107.568
-107.641
-107.709
-107.771
-107.828
-107.878
-107.922
-107.959
-107.989
-108.011
-108.026
-108.034
-110.996
-110.989
-110.975
-110.954
-110.927
-110.893
-110.853
-110.807
-110.755
-110.698
-110.636
-110.57
-110.5
-110.426
-110.35
-110.271
-110.192
-110.111
-110.031
-109.952
-109.874
-109.799
-109.727
-109.659
-109.596
-109.538
-109.487
-109.442
-109.405
-109.376
-109.354
-109.341
-109.337
-109.341
-109.354
-109.376
-109.405
-109.442
-109.487
-109.538
-109.596
-109.659
-109.727
-109.799
-109.874
-109.952
-110.031
-110.111
-110.192
-110.271
-110.35
-110.426
-110.5
-110.57
-110.636
-110.698
-110.755
-110.807
-110.853
-110.893
-110.927
-110.954
-110.975
-110.989
-110.996
-113.964
-113.958
-113.945
-113.927
-113.902
-113.871
-113.834
-113.792
-113.744
-113.692
-113.636
-113.575
-113.511
-113.444
-113.375
-113.304
-113.232
-113.159
-113.086
-113.014
-112.944
-112.876
-112.811
-112.75
-112.693
-112.641
-112.595
-112.554
-112.521
-112.495
-112.475
-112.464
-112.46
-112.464
-112.475
-112.495
-112.521
-112.554
-112.595
-112.641
-112.693
-112.75
-112.811
-112.876
-112.944
-113.014
-113.086
-113.159
-113.232
-113.304
-113.375
-113.444
-113.511
-113.575
-113.636
-113.692
-113.744
-113.792
-113.834
-113.871
-113.902
-113.927
-113.945
-113.958
-113.964
-116.94
-116.934
-116.922
-116.905
-116.882
-116.854
-116.82
-116.782
-116.739
-116.691
-116.64
-116.584
-116.526
-116.465
-116.402
-116.337
-116.272
-116.206
-116.14
-116.075
-116.011
-115.95
-115.891
-115.836
-115.785
-115.738
-115.696
-115.66
-115.63
-115.606
-115.589
-115.578
-115.575
-115.578
-115.589
-115.606
-115.63
-115.66
-115.696
-115.738
-115.785
-115.836
-115.891
-115.95
-116.011
-116.075
-116.14
-116.206
-116.272
-116.337
-116.402
-116.465
-116.526
-116.584
-116.64
-116.691
-116.739
-116.782
-116.82
-116.854
-116.882
-116.905
-116.922
-116.934
-116.94
-119.921
-119.916
-119.905
-119.889
-119.868
-119.842
-119.812
-119.777
-119.737
-119.694
-119.647
-119.597
-119.544
-119.488
-119.431
-119.372
-119.312
-119.253
-119.193
-119.134
-119.076
-119.021
-118.968
-118.918
-118.872
-118.83
-118.792
-118.759
-118.732
-118.711
-118.695
-118.686
-118.683
-118.686
-118.695
-118.711
-118.732
-118.759
-118.792
-118.83
-118.872
-118.918
-118.968
-119.021
-119.076
-119.134
-119.193
-119.253
-119.312
-119.372
-119.431
-119.488
-119.544
-119.597
-119.647
-119.694
-119.737
-119.777
-119.812
-119.842
-119.868
-119.889
-119.905
-119.916
-119.921
-122.908
-122.903
-122.893
-122.879
-122.86
-122.836
-122.808
-122.776
-122.74
-122.7
-122.658
-122.612
-122.563
-122.513
-122.461
-122.408
-122.353
-122.299
-122.245
-122.192
-122.14
-122.089
-122.041
-121.996
-121.955
-121.917
-121.883
-121.853
-121.829
-121.81
-121.796
-121.787
-121.784
-121.787
-121.796
-121.81
-121.829
-121.853
-121.883
-121.917
-121.955
-121.996
-122.041
-122.089
-122.14
-122.192
-122.245
-122.299
-122.353
-122.408
-122.461
-122.513
-122.563
-122.612
-122.658
-122.7
-122.74
-122.776
-122.808
-122.836
-122.86
-122.879
-122.893
-122.903
-122.908
-125.899
-125.895
-125.886
-125.873
-125.855
-125.834
-125.808
-125.779
-125.746
-125.71
-125.671
-125.629
-125.586
-125.54
-125.492
-125.444
-125.395
-125.345
-125.296
-125.248
-125.201
-125.156
-125.112
-125.072
-125.034
-124.999
-124.969
-124.942
-124.92
-124.903
-124.89
-124.883
-124.88
-124.883
-124.89
-124.903
-124.92
-124.942
-124.969
-124.999
-125.034
-125.072
-125.112
-125.156
-125.201
-125.248
-125.296
-125.345
-125.395
-125.444
-125.492
-125.54
-125.586
-125.629
-125.671
-125.71
-125.746
-125.779
-125.808
-125.834
-125.855
-125.873
-125.886
-125.895
-125.899
-128.895
-128.891
-128.883
-128.871
-128.855
-128.836
-128.812
-128.786
-128.756
-128.723
-128.687
-128.65
-128.61
-128.568
-128.525
-128.481
-128.436
-128.392
-128.347
-128.303
-128.261
-128.22
-128.18
-128.144
-128.109
-128.078
-128.051
-128.027
-128.007
-127.991
-127.98
-127.973
-127.971
-127.973
-127.98
-127.991
-128.007
-128.027
-128.051
-128.078
-128.109
-128.144
-128.18
-128.22
-128.261
-128.303
-128.347
-128.392
-128.436
-128.481
-128.525
-128.568
-128.61
-128.65
-128.687
-128.723
-128.756
-128.786
-128.812
-128.836
-128.855
-128.871
-128.883
-128.891
-128.895
-131.896
-131.892
-131.885
-131.874
-131.859
-131.841
-131.82
-131.796
-131.768
-131.738
-131.706
-131.672
-131.635
-131.597
-131.558
-131.518
-131.478
-131.437
-131.397
-131.357
-131.319
-131.282
-131.246
-131.213
-131.182
-131.154
-131.129
-131.108
-131.09
-131.075
-131.065
-131.059
-131.057
-131.059
-131.065
-131.075
-131.09
-131.108
-131.129
-131.154
-131.182
-131.213
-131.246
-131.282
-131.319
-131.357
-131.397
-131.437
-131.478
-131.518
-131.558
-131.597
-131.635
-131.672
-131.706
-131.738
-131.768
-131.796
-131.82
-131.841
-131.859
-131.874
-131.885
-131.892
-131.896
-134.9
-134.896
-134.889
-134.879
-134.866
-134.85
-134.831
-134.808
-134.784
-134.756
-134.727
-134.696
-134.663
-134.628
-134.593
-134.556
-134.52
-134.483
-134.446
-134.41
-134.375
-134.342
-134.31
-134.28
-134.252
-134.226
-134.204
-134.184
-134.168
-134.155
-134.146
-134.141
-134.139
-134.141
-134.146
-134.155
-134.168
-134.184
-134.204
-134.226
-134.252
-134.28
-134.31
-134.342
-134.375
-134.41
-134.446
-134.483
-134.52
-134.556
-134.593
-134.628
-134.663
-134.696
-134.727
-134.756
-134.784
-134.808
-134.831
-134.85
-134.866
-134.879
-134.889
-134.896
-134.9
-137.907
-137.904
-137.898
-137.889
-137.877
-137.862
-137.844
-137.824
-137.801
-137.777
-137.75
-137.721
-137.691
-137.66
-137.628
-137.595
-137.562
-137.528
-137.495
-137.463
-137.431
-137.4
-137.371
-137.344
-137.319
-137.296
-137.276
-137.258
-137.243
-137.232
-137.223
-137.218
-137.217
-137.218
-137.223
-137.232
-137.243
-137.258
-137.276
-137.296
-137.319
-137.344
-137.371
-137.4
-137.431
-137.463
-137.495
-137.528
-137.562
-137.595
-137.628
-137.66
-137.691
-137.721
-137.75
-137.777
-137.801
-137.824
-137.844
-137.862
-137.877
-137.889
-137.898
-137.904
-137.907
-140.918
-140.915
-140.909
-140.901
-140.89
-140.876
-140.86
-140.842
-140.821
-140.799
-140.775
-140.749
-140.721
-140.693
-140.664
-140.634
-140.604
-140.573
-140.543
-140.514
-140.485
-140.457
-140.431
-140.406
-140.384
-140.363
-140.345
-140.329
-140.315
-140.305
-140.297
-140.293
-140.291
-140.293
-140.297
-140.305
-140.315
-140.329
-140.345
-140.363
-140.384
-140.406
-140.431
-140.457
-140.485
-140.514
-140.543
-140.573
-140.604
-140.634
-140.664
-140.693
-140.721
-140.749
-140.775
-140.799
-140.821
-140.842
-140.86
-140.876
-140.89
-140.901
-140.909
-140.915
-140.918
-143.931
-143.928
-143.923
-143.916
-143.906
-143.893
-143.879
-143.862
-143.843
-143.823
-143.801
-143.777
-143.752
-143.727
-143.7
-143.673
-143.646
-143.618
-143.591
-143.564
-143.538
-143.513
-143.489
-143.467
-143.446
-143.428
-143.411
-143.397
-143.385
-143.375
-143.368
-143.364
-143.363
-143.364
-143.368
-143.375
-143.385
-143.397
-143.411
-143.428
-143.446
-143.467
-143.489
-143.513
-143.538
-143.564
-143.591
-143.618
-143.646
-143.673
-143.7
-143.727
-143.752
-143.777
-143.801
-143.823
-143.843
-143.862
-143.879
-143.893
-143.906
-143.916
-143.923
-143.928
-143.931
-146.947
-146.945
-146.94
-146.933
-146.924
-146.913
-146.9
-146.884
-146.867
-146.849
-146.829
-146.807
-146.785
-146.761
-146.737
-146.712
-146.688
-146.663
-146.638
-146.614
-146.59
-146.567
-146.546
-146.526
-146.507
-146.49
-146.475
-146.462
-146.451
-146.443
-146.436
-146.433
-146.432
-146.433
-146.436
-146.443
-146.451
-146.462
-146.475
-146.49
-146.507
-146.526
-146.546
-146.567
-146.59
-146.614
-146.638
-146.663
-146.688
-146.712
-146.737
-146.761
-146.785
-146.807
-146.829
-146.849
-146.867
-146.884
-146.9
-146.913
-146.924
-146.933
-146.94
-146.945
-146.947
-149.965
-149.963
-149.959
-149.953
-149.944
-149.934
-149.922
-149.908
-149.893
-149.876
-149.858
-149.838
-149.818
-149.796
-149.775
-149.752
-149.73
-149.707
-149.685
-149.663
-149.641
-149.621
-149.601
-149.583
-149.566
-149.551
-149.537
-149.525
-149.515
-149.508
-149.502
-149.499
-149.498
-149.499
-149.502
-149.508
-149.515
-149.525
-149.537
-149.551
-149.566
-149.583
-149.601
-149.621
-149.641
-149.663
-149.685
-149.707
-149.73
-149.752
-149.775
-149.796
-149.818
-149.838
-149.858
-149.876
-149.893
-149.908
-149.922
-149.934
-149.944
-149.953
-149.959
-149.963
-149.965
-152.986
-152.984
-152.98
-152.974
-152.967
-152.958
-152.947
-152.934
-152.92
-152.905
-152.888
-152.87
-152.852
-152.832
-152.812
-152.792
-152.772
-152.751
-152.731
-152.711
-152.692
-152.673
-152.655
-152.639
-152.623
-152.61
-152.597
-152.587
-152.578
-152.571
-152.566
-152.563
-152.562
-152.563
-152.566
-152.571
-152.578
-152.587
-152.597
-152.61
-152.623
-152.639
-152.655
-152.673
-152.692
-152.711
-152.731
-152.751
-152.772
-152.792
-152.812
-152.832
-152.852
-152.87
-152.888
-152.905
-152.92
-152.934
-152.947
-152.958
-152.967
-152.974
-152.98
-152.984
-152.986
-156.008
-156.007
-156.003
-155.998
-155.991
-155.983
-155.973
-155.961
-155.948
-155.934
-155.919
-155.903
-155.886
-155.869
-155.851
-155.832
-155.814
-155.795
-155.777
-155.759
-155.741
-155.724
-155.708
-155.693
-155.679
-155.667
-155.656
-155.646
-155.638
-155.632
-155.627
-155.624
-155.623
-155.624
-155.627
-155.632
-155.638
-155.646
-155.656
-155.667
-155.679
-155.693
-155.708
-155.724
-155.741
-155.759
-155.777
-155.795
-155.814
-155.832
-155.851
-155.869
-155.886
-155.903
-155.919
-155.934
-155.948
-155.961
-155.973
-155.983
-155.991
-155.998
-156.003
-156.007
-156.008
-159.033
-159.031
-159.028
-159.023
-159.017
-159.009
-159
-158.99
-158.978
-158.965
-158.952
-158.937
-158.922
-158.906
-158.889
-158.873
-158.856
-158.839
-158.822
-158.806
-158.79
-158.775
-158.76
-158.747
-158.734
-158.723
-158.712
-158.704
-158.696
-158.691
-158.687
-158.684
-158.683
-158.684
-158.687
-158.691
-158.696
-158.704
-158.712
-158.723
-158.734
-158.747
-158.76
-158.775
-158.79
-158.806
-158.822
-158.839
-158.856
-158.873
-158.889
-158.906
-158.922
-158.937
-158.952
-158.965
-158.978
-158.99
-159
-159.009
-159.017
-159.023
-159.028
-159.031
-159.033
-162.058
-162.057
-162.054
-162.05
-162.044
-162.037
-162.029
-162.019
-162.009
-161.997
-161.985
-161.972
-161.958
-161.943
-161.928
-161.913
-161.898
-161.883
-161.867
-161.853
-161.838
-161.824
-161.811
-161.799
-161.787
-161.777
-161.768
-161.76
-161.753
-161.748
-161.745
-161.742
-161.742
-161.742
-161.745
-161.748
-161.753
-161.76
-161.768
-161.777
-161.787
-161.799
-161.811
-161.824
-161.838
-161.853
-161.867
-161.883
-161.898
-161.913
-161.928
-161.943
-161.958
-161.972
-161.985
-161.997
-162.009
-162.019
-162.029
-162.037
-162.044
-162.05
-162.054
-162.057
-162.058
-165.086
-165.084
-165.082
-165.078
-165.073
-165.066
-165.059
-165.05
-165.041
-165.03
-165.019
-165.007
-164.994
-164.981
-164.968
-164.954
-164.94
-164.926
-164.912
-164.899
-164.886
-164.873
-164.861
-164.85
-164.84
-164.83
-164.822
-164.815
-164.809
-164.804
-164.801
-164.799
-164.798
-164.799
-164.801
-164.804
-164.809
-164.815
-164.822
-164.83
-164.84
-164.85
-164.861
-164.873
-164.886
-164.899
-164.912
-164.926
-164.94
-164.954
-164.968
-164.981
-164.994
-165.007
-165.019
-165.03
-165.041
-165.05
-165.059
-165.066
-165.073
-165.078
-165.082
-165.084
-165.086
-168.114
-168.113
-168.111
-168.107
-168.103
-168.097
-168.09
-168.082
-168.074
-168.064
-168.054
-168.043
-168.031
-168.019
-168.007
-167.995
-167.982
-167.969
-167.957
-167.945
-167.933
-167.921
-167.911
-167.901
-167.891
-167.883
-167.875
-167.869
-167.863
-167.859
-167.856
-167.854
-167.854
-167.854
-167.856
-167.859
-167.863
-167.869
-167.875
-167.883
-167.891
-167.901
-167.911
-167.921
-167.933
-167.945
-167.957
-167.969
-167.982
-167.995
-168.007
-168.019
-168.031
-168.043
-168.054
-168.064
-168.074
-168.082
-168.09
-168.097
-168.103
-168.107
-168.111
-168.113
-168.114
-171.144
-171.143
-171.141
-171.138
-171.134
-171.128
-171.122
-171.115
-171.107
-171.098
-171.089
-171.079
-171.069
-171.058
-171.047
-171.035
-171.024
-171.013
-171.001
-170.99
-170.98
-170.969
-170.959
-170.95
-170.942
-170.934
-170.927
-170.921
-170.916
-170.913
-170.91
-170.908
-170.908
-170.908
-170.91
-170.913
-170.916
-170.921
-170.927
-170.934
-170.942
-170.95
-170.959
-170.969
-170.98
-170.99
-171.001
-171.013
-171.024
-171.035
-171.047
-171.058
-171.069
-171.079
-171.089
-171.098
-171.107
-171.115
-171.122
-171.128
-171.134
-171.138
-171.141
-171.143
-171.144
-174.175
-174.174
-174.172
-174.169
-174.165
-174.161
-174.155
-174.149
-174.142
-174.134
-174.125
-174.116
-174.107
-174.097
-174.087
-174.076
-174.066
-174.056
-174.045
-174.035
-174.026
-174.016
-174.007
-173.999
-173.991
-173.984
-173.978
-173.973
-173.969
-173.965
-173.963
-173.961
-173.961
-173.961
-173.963
-173.965
-173.969
-173.973
-173.978
-173.984
-173.991
-173.999
-174.007
-174.016
-174.026
-174.035
-174.045
-174.056
-174.066
-174.076
-174.087
-174.097
-174.107
-174.116
-174.125
-174.134
-174.142
-174.149
-174.155
-174.161
-174.165
-174.169
-174.172
-174.174
-174.175
-177.207
-177.206
-177.205
-177.202
-177.198
-177.194
-177.189
-177.183
-177.177
-177.169
-177.162
-177.154
-177.145
-177.136
-177.127
-177.118
-177.108
-177.099
-177.089
-177.08
-177.071
-177.063
-177.055
-177.047
-177.04
-177.034
-177.029
-177.024
-177.02
-177.017
-177.014
-177.013
-177.012
-177.013
-177.014
-177.017
-177.02
-177.024
-177.029
-177.034
-177.04
-177.047
-177.055
-177.063
-177.071
-177.08
-177.089
-177.099
-177.108
-177.118
-177.127
-177.136
-177.145
-177.154
-177.162
-177.169
-177.177
-177.183
-177.189
-177.194
-177.198
-177.202
-177.205
-177.206
-177.207
-180.24
-180.239
-180.238
-180.235
-180.232
-180.228
-180.224
-180.218
-180.212
-180.206
-180.199
-180.191
-180.184
-180.176
-180.167
-180.159
-180.15
-180.142
-180.133
-180.125
-180.117
-180.109
-180.102
-180.095
-180.089
-180.083
-180.078
-180.074
-180.07
-180.067
-180.065
-180.064
-180.063
-180.064
-180.065
-180.067
-180.07
-180.074
-180.078
-180.083
-180.089
-180.095
-180.102
-180.109
-180.117
-180.125
-180.133
-180.142
-180.15
-180.159
-180.167
-180.176
-180.184
-180.191
-180.199
-180.206
-180.212
-180.218
-180.224
-180.228
-180.232
-180.235
-180.238
-180.239
-180.24
-183.274
-183.273
-183.272
-183.269
-183.267
-183.263
-183.259
-183.254
-183.249
-183.243
-183.236
-183.23
-183.223
-183.215
-183.208
-183.2
-183.192
-183.184
-183.177
-183.169
-183.162
-183.155
-183.148
-183.142
-183.136
-183.131
-183.127
-183.123
-183.119
-183.117
-183.115
-183.114
-183.113
-183.114
-183.115
-183.117
-183.119
-183.123
-183.127
-183.131
-183.136
-183.142
-183.148
-183.155
-183.162
-183.169
-183.177
-183.184
-183.192
-183.2
-183.208
-183.215
-183.223
-183.23
-183.236
-183.243
-183.249
-183.254
-183.259
-183.263
-183.267
-183.269
-183.272
-183.273
-183.274
-186.308
-186.308
-186.306
-186.304
-186.302
-186.298
-186.295
-186.29
-186.285
-186.28
-186.274
-186.268
-186.262
-186.255
-186.248
-186.241
-186.234
-186.227
-186.22
-186.213
-186.207
-186.2
-186.194
-186.189
-186.184
-186.179
-186.175
-186.171
-186.168
-186.166
-186.164
-186.163
-186.163
-186.163
-186.164
-186.166
-186.168
-186.171
-186.175
-186.179
-186.184
-186.189
-186.194
-186.2
-186.207
-186.213
-186.22
-186.227
-186.234
-186.241
-186.248
-186.255
-186.262
-186.268
-186.274
-186.28
-186.285
-186.29
-186.295
-186.298
-186.302
-186.304
-186.306
-186.308
-186.308
-189.343
-189.343
-189.342
-189.34
-189.337
-189.335
-189.331
-189.327
-189.323
-189.318
-189.313
-189.307
-189.301
-189.295
-189.289
-189.283
-189.276
-189.27
-189.263
-189.257
-189.251
-189.246
-189.24
-189.235
-189.23
-189.226
-189.222
-189.219
-189.216
-189.214
-189.213
-189.212
-189.211
-189.212
-189.213
-189.214
-189.216
-189.219
-189.222
-189.226
-189.23
-189.235
-189.24
-189.246
-189.251
-189.257
-189.263
-189.27
-189.276
-189.283
-189.289
-189.295
-189.301
-189.307
-189.313
-189.318
-189.323
-189.327
-189.331
-189.335
-189.337
-189.34
-189.342
-189.343
-189.343
-192.379
-192.379
-192.378
-192.376
-192.374
-192.371
-192.368
-192.364
-192.36
-192.356
-192.351
-192.346
-192.341
-192.335
-192.33
-192.324
-192.318
-192.312
-192.307
-192.301
-192.296
-192.29
-192.285
-192.281
-192.277
-192.273
-192.269
-192.266
-192.264
-192.262
-192.261
-192.26
-192.259
-192.26
-192.261
-192.262
-192.264
-192.266
-192.269
-192.273
-192.277
-192.281
-192.285
-192.29
-192.296
-192.301
-192.307
-192.312
-192.318
-192.324
-192.33
-192.335
-192.341
-192.346
-192.351
-192.356
-192.36
-192.364
-192.368
-192.371
-192.374
-192.376
-192.378
-192.379
-192.379
-195.416
-195.415
-195.414
-195.413
-195.411
-195.408
-195.405
-195.402
-195.398
-195.394
-195.39
-195.386
-195.381
-195.376
-195.371
-195.365
-195.36
-195.355
-195.35
-195.345
-195.34
-195.335
-195.33
-195.326
-195.322
-195.319
-195.316
-195.313
-195.311
-195.309
-195.308
-195.307
-195.307
-195.307
-195.308
-195.309
-195.311
-195.313
-195.316
-195.319
-195.322
-195.326
-195.33
-195.335
-195.34
-195.345
-195.35
-195.355
-195.36
-195.365
-195.371
-195.376
-195.381
-195.386
-195.39
-195.394
-195.398
-195.402
-195.405
-195.408
-195.411
-195.413
-195.414
-195.415
-195.416
-198.452
-198.452
-198.451
-198.45
-198.448
-198.446
-198.443
-198.44
-198.437
-198.433
-198.429
-198.425
-198.421
-198.416
-198.412
-198.407
-198.402
-198.397
-198.393
-198.388
-198.384
-198.379
-198.375
-198.371
-198.368
-198.365
-198.362
-198.359
-198.357
-198.356
-198.355
-198.354
-198.354
-198.354
-198.355
-198.356
-198.357
-198.359
-198.362
-198.365
-198.368
-198.371
-198.375
-198.379
-198.384
-198.388
-198.393
-198.397
-198.402
-198.407
-198.412
-198.416
-198.421
-198.425
-198.429
-198.433
-198.437
-198.44
-198.443
-198.446
-198.448
-198.45
-198.451
-198.452
-198.452
-201.49
-201.489
-201.489
-201.487
-201.486
-201.484
-201.481
-201.479
-201.476
-201.472
-201.469
-201.465
-201.461
-201.457
-201.453
-201.448
-201.444
-201.44
-201.435
-201.431
-201.427
-201.423
-201.42
-201.416
-201.413
-201.41
-201.408
-201.405
-201.403
-201.402
-201.401
-201.4
-201.4
-201.4
-201.401
-201.402
-201.403
-201.405
-201.408
-201.41
-201.413
-201.416
-201.42
-201.423
-201.427
-201.431
-201.435
-201.44
-201.444
-201.448
-201.453
-201.457
-201.461
-201.465
-201.469
-201.472
-201.476
-201.479
-201.481
-201.484
-201.486
-201.487
-201.489
-201.489
-201.49
-204.528
-204.527
-204.526
-204.525
-204.524
-204.522
-204.52
-204.517
-204.515
-204.512
-204.508
-204.505
-204.501
-204.498
-204.494
-204.49
-204.486
-204.482
-204.478
-204.474
-204.471
-204.467
-204.464
-204.461
-204.458
-204.455
-204.453
-204.451
-204.449
-204.448
-204.447
-204.446
-204.446
-204.446
-204.447
-204.448
-204.449
-204.451
-204.453
-204.455
-204.458
-204.461
-204.464
-204.467
-204.471
-204.474
-204.478
-204.482
-204.486
-204.49
-204.494
-204.498
-204.501
-204.505
-204.508
-204.512
-204.515
-204.517
-204.52
-204.522
-204.524
-204.525
-204.526
-204.527
-204.528
-207.566
-207.565
-207.565
-207.564
-207.562
-207.561
-207.559
-207.556
-207.554
-207.551
-207.548
-207.545
-207.542
-207.539
-207.535
-207.532
-207.528
-207.524
-207.521
-207.517
-207.514
-207.511
-207.508
-207.505
-207.502
-207.5
-207.498
-207.496
-207.495
-207.493
-207.492
-207.492
-207.492
-207.492
-207.492
-207.493
-207.495
-207.496
-207.498
-207.5
-207.502
-207.505
-207.508
-207.511
-207.514
-207.517
-207.521
-207.524
-207.528
-207.532
-207.535
-207.539
-207.542
-207.545
-207.548
-207.551
-207.554
-207.556
-207.559
-207.561
-207.562
-207.564
-207.565
-207.565
-207.566
-210.604
-210.604
-210.603
-210.602
-210.601
-210.6
-210.598
-210.596
-210.594
-210.591
-210.588
-210.586
-210.583
-210.579
-210.576
-210.573
-210.57
-210.567
-210.563
-210.56
-210.557
-210.554
-210.552
-210.549
-210.547
-210.544
-210.543
-210.541
-210.54
-210.538
-210.538
-210.537
-210.537
-210.537
-210.538
-210.538
-210.54
-210.541
-210.543
-210.544
-210.547
-210.549
-210.552
-210.554
-210.557
-210.56
-210.563
-210.567
-210.57
-210.573
-210.576
-210.579
-210.583
-210.586
-210.588
-210.591
-210.594
-210.596
-210.598
-210.6
-210.601
-210.602
-210.603
-210.604
-210.604
-213.643
-213.643
-213.642
-213.641
-213.64
-213.639
-213.637
-213.635
-213.633
-213.631
-213.629
-213.626
-213.623
-213.621
-213.618
-213.615
-213.612
-213.609
-213.606
-213.603
-213.6
-213.598
-213.595
-213.593
-213.591
-213.589
-213.587
-213.585
-213.584
-213.583
-213.583
-213.582
-213.582
-213.582
-213.583
-213.583
-213.584
-213.585
-213.587
-213.589
-213.591
-213.593
-213.595
-213.598
-213.6
-213.603
-213.606
-213.609
-213.612
-213.615
-213.618
-213.621
-213.623
-213.626
-213.629
-213.631
-213.633
-213.635
-213.637
-213.639
-213.64
-213.641
-213.642
-213.643
-213.643
-216.682
-216.682
-216.681
-216.68
-216.679
-216.678
-216.677
-216.675
-216.673
-216.671
-216.669
-216.667
-216.664
-216.662
-216.659
-216.656
-216.654
-216.651
-216.648
-216.646
-216.643
-216.641
-216.639
-216.637
-216.635
-216.633
-216.631
-216.63
-216.629
-216.628
-216.627
-216.627
-216.627
-216.627
-216.627
-216.628
-216.629
-216.63
-216.631
-216.633
-216.635
-216.637
-216.639
-216.641
-216.643
-216.646
-216.648
-216.651
-216.654
-216.656
-216.659
-216.662
-216.664
-216.667
-216.669
-216.671
-216.673
-216.675
-216.677
-216.678
-216.679
-216.68
-216.681
-216.682
-216.682
-219.721
-219.721
-219.721
-219.72
-219.719
-219.718
-219.717
-219.715
-219.713
-219.712
-219.71
-219.707
-219.705
-219.703
-219.7
-219.698
-219.696
-219.693
-219.691
-219.688
-219.686
-219.684
-219.682
-219.68
-219.678
-219.677
-219.675
-219.674
-219.673
-219.672
-219.671
-219.671
-219.671
-219.671
-219.671
-219.672
-219.673
-219.674
-219.675
-219.677
-219.678
-219.68
-219.682
-219.684
-219.686
-219.688
-219.691
-219.693
-219.696
-219.698
-219.7
-219.703
-219.705
-219.707
-219.71
-219.712
-219.713
-219.715
-219.717
-219.718
-219.719
-219.72
-219.721
-219.721
-219.721
-222.761
-222.761
-222.76
-222.76
-222.759
-222.758
-222.757
-222.755
-222.754
-222.752
-222.75
-222.748
-222.746
-222.744
-222.742
-222.74
-222.738
-222.735
-222.733
-222.731
-222.729
-222.727
-222.725
-222.723
-222.722
-222.72
-222.719
-222.718
-222.717
-222.716
-222.716
-222.715
-222.715
-222.715
-222.716
-222.716
-222.717
-222.718
-222.719
-222.72
-222.722
-222.723
-222.725
-222.727
-222.729
-222.731
-222.733
-222.735
-222.738
-222.74
-222.742
-222.744
-222.746
-222.748
-222.75
-222.752
-222.754
-222.755
-222.757
-222.758
-222.759
-222.76
-222.76
-222.761
-222.761
-225.801
-225.801
-225.8
-225.8
-225.799
-225.798
-225.797
-225.796
-225.794
-225.793
-225.791
-225.789
-225.787
-225.785
-225.783
-225.781
-225.779
-225.777
-225.775
-225.774
-225.772
-225.77
-225.768
-225.767
-225.765
-225.764
-225.763
-225.761
-225.761
-225.76
-225.759
-225.759
-225.759
-225.759
-225.759
-225.76
-225.761
-225.761
-225.763
-225.764
-225.765
-225.767
-225.768
-225.77
-225.772
-225.774
-225.775
-225.777
-225.779
-225.781
-225.783
-225.785
-225.787
-225.789
-225.791
-225.793
-225.794
-225.796
-225.797
-225.798
-225.799
-225.8
-225.8
-225.801
-225.801
-228.841
-228.841
-228.84
-228.84
-228.839
-228.838
-228.837
-228.836
-228.835
-228.833
-228.832
-228.83
-228.829
-228.827
-228.825
-228.823
-228.821
-228.82
-228.818
-228.816
-228.814
-228.813
-228.811
-228.81
-228.808
-228.807
-228.806
-228.805
-228.804
-228.804
-228.803
-228.803
-228.803
-228.803
-228.803
-228.804
-228.804
-228.805
-228.806
-228.807
-228.808
-228.81
-228.811
-228.813
-228.814
-228.816
-228.818
-228.82
-228.821
-228.823
-228.825
-228.827
-228.829
-228.83
-228.832
-228.833
-228.835
-228.836
-228.837
-228.838
-228.839
-228.84
-228.84
-228.841
-228.841
-231.881
-231.881
-231.88
-231.88
-231.879
-231.879
-231.878
-231.877
-231.875
-231.874
-231.873
-231.871
-231.87
-231.868
-231.867
-231.865
-231.863
-231.862
-231.86
-231.858
-231.857
-231.855
-231.854
-231.853
-231.851
-231.85
-231.849
-231.848
-231.848
-231.847
-231.847
-231.846
-231.846
-231.846
-231.847
-231.847
-231.848
-231.848
-231.849
-231.85
-231.851
-231.853
-231.854
-231.855
-231.857
-231.858
-231.86
-231.862
-231.863
-231.865
-231.867
-231.868
-231.87
-231.871
-231.873
-231.874
-231.875
-231.877
-231.878
-231.879
-231.879
-231.88
-231.88
-231.881
-231.881
-234.921
-234.921
-234.921
-234.92
-234.92
-234.919
-234.918
-234.917
-234.916
-234.915
-234.914
-234.913
-234.911
-234.91
-234.908
-234.907
-234.905
-234.904
-234.902
-234.901
-234.899
-234.898
-234.897
-234.895
-234.894
-234.893
-234.892
-234.892
-234.891
-234.89
-234.89
-234.89
-234.89
-234.89
-234.89
-234.89
-234.891
-234.892
-234.892
-234.893
-234.894
-234.895
-234.897
-234.898
-234.899
-234.901
-234.902
-234.904
-234.905
-234.907
-234.908
-234.91
-234.911
-234.913
-234.914
-234.915
-234.916
-234.917
-234.918
-234.919
-234.92
-234.92
-234.921
-234.921
-234.921
-237.962
-237.962
-237.961
-237.961
-237.96
-237.96
-237.959
-237.958
-237.957
-237.956
-237.955
-237.954
-237.952
-237.951
-237.95
-237.948
-237.947
-237.946
-237.944
-237.943
-237.942
-237.94
-237.939
-237.938
-237.937
-237.936
-237.935
-237.935
-237.934
-237.934
-237.933
-237.933
-237.933
-237.933
-237.933
-237.934
-237.934
-237.935
-237.935
-237.936
-237.937
-237.938
-237.939
-237.94
-237.942
-237.943
-237.944
-237.946
-237.947
-237.948
-237.95
-237.951
-237.952
-237.954
-237.955
-237.956
-237.957
-237.958
-237.959
-237.96
-237.96
-237.961
-237.961
-237.962
-237.962
-241.002
-241.002
-241.002
-241.002
-241.001
-241.001
-241
-240.999
-240.998
-240.997
-240.996
-240.995
-240.994
-240.993
-240.991
-240.99
-240.989
-240.988
-240.986
-240.985
-240.984
-240.983
-240.982
-240.981
-240.98
-240.979
-240.978
-240.978
-240.977
-240.977
-240.976
-240.976
-240.976
-240.976
-240.976
-240.977
-240.977
-240.978
-240.978
-240.979
-240.98
-240.981
-240.982
-240.983
-240.984
-240.985
-240.986
-240.988
-240.989
-240.99
-240.991
-240.993
-240.994
-240.995
-240.996
-240.997
-240.998
-240.999
-241
-241.001
-241.001
-241.002
-241.002
-241.002
-241.002
-244.043
-244.043
-244.043
-244.042
-244.042
-244.041
-244.041
-244.04
-244.039
-244.038
-244.037
-244.036
-244.035
-244.034
-244.033
-244.032
-244.031
-244.03
-244.029
-244.027
-244.026
-244.025
-244.024
-244.023
-244.023
-244.022
-244.021
-244.02
-244.02
-244.02
-244.019
-244.019
-244.019
-244.019
-244.019
-244.02
-244.02
-244.02
-244.021
-244.022
-244.023
-244.023
-244.024
-244.025
-244.026
-244.027
-244.029
-244.03
-244.031
-244.032
-244.033
-244.034
-244.035
-244.036
-244.037
-244.038
-244.039
-244.04
-244.041
-244.041
-244.042
-244.042
-244.043
-244.043
-244.043
-247.084
-247.084
-247.084
-247.083
-247.083
-247.082
-247.082
-247.081
-247.08
-247.08
-247.079
-247.078
-247.077
-247.076
-247.075
-247.074
-247.073
-247.072
-247.071
-247.07
-247.069
-247.068
-247.067
-247.066
-247.065
-247.064
-247.064
-247.063
-247.063
-247.062
-247.062
-247.062
-247.062
-247.062
-247.062
-247.062
-247.063
-247.063
-247.064
-247.064
-247.065
-247.066
-247.067
-247.068
-247.069
-247.07
-247.071
-247.072
-247.073
-247.074
-247.075
-247.076
-247.077
-247.078
-247.079
-247.08
-247.08
-247.081
-247.082
-247.082
-247.083
-247.083
-247.084
-247.084
-247.084
-250.125
-250.125
-250.125
-250.124
-250.124
-250.124
-250.123
-250.122
-250.122
-250.121
-250.12
-250.119
-250.118
-250.117
-250.117
-250.116
-250.115
-250.114
-250.113
-250.112
-250.111
-250.11
-250.109
-250.108
-250.108
-250.107
-250.106
-250.106
-250.105
-250.105
-250.105
-250.105
-250.105
-250.105
-250.105
-250.105
-250.105
-250.106
-250.106
-250.107
-250.108
-250.108
-250.109
-250.11
-250.111
-250.112
-250.113
-250.114
-250.115
-250.116
-250.117
-250.117
-250.118
-250.119
-250.12
-250.121
-250.122
-250.122
-250.123
-250.124
-250.124
-250.124
-250.125
-250.125
-250.125
-253.166
-253.166
-253.166
-253.165
-253.165
-253.165
-253.164
-253.164
-253.163
-253.162
-253.162
-253.161
-253.16
-253.159
-253.158
-253.157
-253.156
-253.156
-253.155
-253.154
-253.153
-253.152
-253.151
-253.151
-253.15
-253.149
-253.149
-253.148
-253.148
-253.148
-253.148
-253.147
-253.147
-253.147
-253.148
-253.148
-253.148
-253.148
-253.149
-253.149
-253.15
-253.151
-253.151
-253.152
-253.153
-253.154
-253.155
-253.156
-253.156
-253.157
-253.158
-253.159
-253.16
-253.161
-253.162
-253.162
-253.163
-253.164
-253.164
-253.165
-253.165
-253.165
-253.166
-253.166
-253.166
-256.207
-256.207
-256.207
-256.207
-256.206
-256.206
-256.205
-256.205
-256.204
-256.204
-256.203
-256.202
-256.202
-256.201
-256.2
-256.199
-256.198
-256.198
-256.197
-256.196
-256.195
-256.194
-256.194
-256.193
-256.192
-256.192
-256.191
-256.191
-256.191
-256.19
-256.19
-256.19
-256.19
-256.19
-256.19
-256.19
-256.191
-256.191
-256.191
-256.192
-256.192
-256.193
-256.194
-256.194
-256.195
-256.196
-256.197
-256.198
-256.198
-256.199
-256.2
-256.201
-256.202
-256.202
-256.203
-256.204
-256.204
-256.205
-256.205
-256.206
-256.206
-256.207
-256.207
-256.207
-256.207
-259.248
-259.248
-259.248
-259.248
-259.248
-259.247
-259.247
-259.246
-259.246
-259.245
-259.245
-259.244
-259.243
-259.242
-259.242
-259.241
-259.24
-259.239
-259.239
-259.238
-259.237
-259.237
-259.236
-259.235
-259.235
-259.234
-259.234
-259.233
-259.233
-259.233
-259.233
-259.233
-259.232
-259.233
-259.233
-259.233
-259.233
-259.233
-259.234
-259.234
-259.235
-259.235
-259.236
-259.237
-259.237
-259.238
-259.239
-259.239
-259.24
-259.241
-259.242
-259.242
-259.243
-259.244
-259.245
-259.245
-259.246
-259.246
-259.247
-259.247
-259.248
-259.248
-259.248
-259.248
-259.248
-262.29
-262.29
-262.289
-262.289
-262.289
-262.289
-262.288
-262.288
-262.287
-262.287
-262.286
-262.286
-262.285
-262.284
-262.284
-262.283
-262.282
-262.281
-262.281
-262.28
-262.279
-262.279
-262.278
-262.278
-262.277
-262.277
-262.276
-262.276
-262.275
-262.275
-262.275
-262.275
-262.275
-262.275
-262.275
-262.275
-262.275
-262.276
-262.276
-262.277
-262.277
-262.278
-262.278
-262.279
-262.279
-262.28
-262.281
-262.281
-262.282
-262.283
-262.284
-262.284
-262.285
-262.286
-262.286
-262.287
-262.287
-262.288
-262.288
-262.289
-262.289
-262.289
-262.289
-262.29
-262.29
-265.331
-265.331
-265.331
-265.331
-265.33
-265.33
-265.33
-265.329
-265.329
-265.328
-265.328
-265.327
-265.327
-265.326
-265.325
-265.325
-265.324
-265.323
-265.323
-265.322
-265.321
-265.321
-265.32
-265.32
-265.319
-265.319
-265.318
-265.318
-265.318
-265.318
-265.317
-265.317
-265.317
-265.317
-265.317
-265.318
-265.318
-265.318
-265.318
-265.319
-265.319
-265.32
-265.32
-265.321
-265.321
-265.322
-265.323
-265.323
-265.324
-265.325
-265.325
-265.326
-265.327
-265.327
-265.328
-265.328
-265.329
-265.329
-265.33
-265.33
-265.33
-265.331
-265.331
-265.331
-265.331
-268.372
-268.372
-268.372
-268.372
-268.372
-268.372
-268.371
-268.371
-268.37
-268.37
-268.369
-268.369
-268.368
-268.368
-268.367
-268.366
-268.366
-268.365
-268.365
-268.364
-268.363
-268.363
-268.362
-268.362
-268.361
-268.361
-268.361
-268.36
-268.36
-268.36
-268.36
-268.36
-268.36
-268.36
-268.36
-268.36
-268.36
-268.36
-268.361
-268.361
-268.361
-268.362
-268.362
-268.363
-268.363
-268.364
-268.365
-268.365
-268.366
-268.366
-268.367
-268.368
-268.368
-268.369
-268.369
-268.37
-268.37
-268.371
-268.371
-268.372
-268.372
-268.372
-268.372
-268.372
-268.372
-271.414
-271.414
-271.414
-271.414
-271.413
-271.413
-271.413
-271.412
-271.412
-271.412
-271.411
-271.411
-271.41
-271.409
-271.409
-271.408
-271.408
-271.407
-271.407
-271.406
-271.405
-271.405
-271.404
-271.404
-271.403
-271.403
-271.403
-271.402
-271.402
-271.402
-271.402
-271.402
-271.402
-271.402
-271.402
-271.402
-271.402
-271.402
-271.403
-271.403
-271.403
-271.404
-271.404
-271.405
-271.405
-271.406
-271.407
-271.407
-271.408
-271.408
-271.409
-271.409
-271.41
-271.411
-271.411
-271.412
-271.412
-271.412
-271.413
-271.413
-271.413
-271.414
-271.414
-271.414
-271.414
-274.456
-274.455
-274.455
-274.455
-274.455
-274.455
-274.454
-274.454
-274.454
-274.453
-274.453
-274.452
-274.452
-274.451
-274.451
-274.45
-274.45
-274.449
-274.448
-274.448
-274.447
-274.447
-274.446
-274.446
-274.446
-274.445
-274.445
-274.445
-274.444
-274.444
-274.444
-274.444
-274.444
-274.444
-274.444
-274.444
-274.444
-274.445
-274.445
-274.445
-274.446
-274.446
-274.446
-274.447
-274.447
-274.448
-274.448
-274.449
-274.45
-274.45
-274.451
-274.451
-274.452
-274.452
-274.453
-274.453
-274.454
-274.454
-274.454
-274.455
-274.455
-274.455
-274.455
-274.455
-274.456
-277.497
-277.497
-277.497
-277.497
-277.497
-277.496
-277.496
-277.496
-277.495
-277.495
-277.495
-277.494
-277.494
-277.493
-277.493
-277.492
-277.491
-277.491
-277.49
-277.49
-277.489
-277.489
-277.488
-277.488
-277.488
-277.487
-277.487
-277.487
-277.486
-277.486
-277.486
-277.486
-277.486
-277.486
-277.486
-277.486
-277.486
-277.487
-277.487
-277.487
-277.488
-277.488
-277.488
-277.489
-277.489
-277.49
-277.49
-277.491
-277.491
-277.492
-277.493
-277.493
-277.494
-277.494
-277.495
-277.495
-277.495
-277.496
-277.496
-277.496
-277.497
-277.497
-277.497
-277.497
-277.497
-280.539
-280.539
-280.539
-280.538
-280.538
-280.538
-280.538
-280.537
-280.537
-280.537
-280.536
-280.536
-280.535
-280.535
-280.534
-280.534
-280.533
-280.533
-280.532
-280.532
-280.531
-280.531
-280.53
-280.53
-280.53
-280.529
-280.529
-280.529
-280.528
-280.528
-280.528
-280.528
-280.528
-280.528
-280.528
-280.528
-280.528
-280.529
-280.529
-280.529
-280.53
-280.53
-280.53
-280.531
-280.531
-280.532
-280.532
-280.533
-280.533
-280.534
-280.534
-280.535
-280.535
-280.536
-280.536
-280.537
-280.537
-280.537
-280.538
-280.538
-280.538
-280.538
-280.539
-280.539
-280.539
-283.58
-283.58
-283.58
-283.58
-283.58
-283.58
-283.58
-283.579
-283.579
-283.578
-283.578
-283.578
-283.577
-283.577
-283.576
-283.576
-283.575
-283.575
-283.574
-283.574
-283.573
-283.573
-283.572
-283.572
-283.572
-283.571
-283.571
-283.571
-283.57
-283.57
-283.57
-283.57
-283.57
-283.57
-283.57
-283.57
-283.57
-283.571
-283.571
-283.571
-283.572
-283.572
-283.572
-283.573
-283.573
-283.574
-283.574
-283.575
-283.575
-283.576
-283.576
-283.577
-283.577
-283.578
-283.578
-283.578
-283.579
-283.579
-283.58
-283.58
-283.58
-283.58
-283.58
-283.58
-283.58
-286.622
-286.622
-286.622
-286.622
-286.622
-286.622
-286.621
-286.621
-286.621
-286.62
-286.62
-286.619
-286.619
-286.618
-286.618
-286.618
-286.617
-286.617
-286.616
-286.616
-286.615
-286.615
-286.614
-286.614
-286.613
-286.613
-286.613
-286.613
-286.612
-286.612
-286.612
-286.612
-286.612
-286.612
-286.612
-286.612
-286.612
-286.613
-286.613
-286.613
-286.613
-286.614
-286.614
-286.615
-286.615
-286.616
-286.616
-286.617
-286.617
-286.618
-286.618
-286.618
-286.619
-286.619
-286.62
-286.62
-286.621
-286.621
-286.621
-286.622
-286.622
-286.622
-286.622
-286.622
-286.622
-289.664
-289.664
-289.664
-289.664
-289.664
-289.663
-289.663
-289.663
-289.662
-289.662
-289.662
-289.661
-289.661
-289.66
-289.66
-289.659
-289.659
-289.658
-289.658
-289.657
-289.657
-289.657
-289.656
-289.656
-289.655
-289.655
-289.655
-289.655
-289.654
-289.654
-289.654
-289.654
-289.654
-289.654
-289.654
-289.654
-289.654
-289.655
-289.655
-289.655
-289.655
-289.656
-289.656
-289.657
-289.657
-289.657
-289.658
-289.658
-289.659
-289.659
-289.66
-289.66
-289.661
-289.661
-289.662
-289.662
-289.662
-289.663
-289.663
-289.663
-289.664
-289.664
-289.664
-289.664
-289.664
  0 KSP preconditioned resid norm 2.315194375855e+08 true resid norm 2.315194375855e+08 ||Ae||/||Ax|| 5.669030734042e-01
  1 KSP preconditioned resid norm 2.416378524737e-07 true resid norm 7.075902174382e-07 ||Ae||/||Ax|| 1.732619399736e-15
Linear solve converged due to CONVERGED_RTOL
Process [0]
71.7852
71.7641
71.7219
71.6587
71.575
71.4712
71.3477
71.2053
71.0448
70.8671
70.6733
70.4646
70.2425
70.0086
69.7645
69.5123
69.2539
68.9918
68.7283
68.466
68.2076
67.9558
67.7135
67.4835
67.2685
67.0714
66.8947
66.7407
66.6117
66.5093
66.4351
66.3901
66.375
66.3901
66.4351
66.5093
66.6117
66.7407
66.8947
67.0714
67.2685
67.4835
67.7135
67.9558
68.2076
68.466
68.7283
68.9918
69.2539
69.5123
69.7645
70.0086
70.2425
70.4646
70.6733
70.8671
71.0448
71.2053
71.3477
71.4712
71.575
71.6587
71.7219
71.7641
71.7852
68.7648
68.7436
68.7011
68.6377
68.5536
68.4492
68.325
68.1818
68.0204
67.8415
67.6465
67.4364
67.2127
66.9769
66.7309
66.4765
66.2159
65.9514
65.6853
65.4203
65.159
64.9044
64.6592
64.4263
64.2086
64.0089
63.8298
63.6737
63.5428
63.4389
63.3636
63.318
63.3027
63.318
63.3636
63.4389
63.5428
63.6737
63.8298
64.0089
64.2086
64.4263
64.6592
64.9044
65.159
65.4203
65.6853
65.9514
66.2159
66.4765
66.7309
66.9769
67.2127
67.4364
67.6465
67.8415
68.0204
68.1818
68.325
68.4492
68.5536
68.6377
68.7011
68.7436
68.7648
65.7661
65.7446
65.7018
65.6377
65.5527
65.4472
65.3217
65.1769
65.0135
64.8325
64.6349
64.4219
64.195
63.9557
63.7058
63.4472
63.1819
62.9124
62.6411
62.3706
62.1037
61.8433
61.5923
61.3538
61.1305
60.9255
60.7415
60.5811
60.4464
60.3395
60.262
60.215
60.1993
60.215
60.262
60.3395
60.4464
60.5811
60.7415
60.9255
61.1305
61.3538
61.5923
61.8433
62.1037
62.3706
62.6411
62.9124
63.1819
63.4472
63.7058
63.9557
64.195
64.4219
64.6349
64.8325
65.0135
65.1769
65.3217
65.4472
65.5527
65.6377
65.7018
65.7446
65.7661
62.7891
62.7674
62.7239
62.6589
62.5726
62.4655
62.338
62.1908
62.0245
61.8402
61.6389
61.4217
61.19
60.9454
60.6895
60.4245
60.1523
59.8753
59.5961
59.3174
59.0419
58.7727
58.5129
58.2656
58.0339
57.8208
57.6294
57.4622
57.3219
57.2104
57.1294
57.0804
57.0639
57.0804
57.1294
57.2104
57.3219
57.4622
57.6294
57.8208
58.0339
58.2656
58.5129
58.7727
59.0419
59.3174
59.5961
59.8753
60.1523
60.4245
60.6895
60.9454
61.19
61.4217
61.6389
61.8402
62.0245
62.1908
62.338
62.4655
62.5726
62.6589
62.7239
62.7674
62.7891
59.8344
59.8123
59.768
59.7017
59.6137
59.5045
59.3743
59.2239
59.054
58.8653
58.659
58.4361
58.1981
57.9463
57.6827
57.409
57.1275
56.8405
56.5507
56.2607
55.9737
55.6926
55.4208
55.1616
54.9183
54.6942
54.4925
54.3162
54.168
54.0501
53.9645
53.9126
53.8952
53.9126
53.9645
54.0501
54.168
54.3162
54.4925
54.6942
54.9183
55.1616
55.4208
55.6926
55.9737
56.2607
56.5507
56.8405
57.1275
57.409
57.6827
57.9463
58.1981
58.4361
58.659
58.8653
59.054
59.2239
59.3743
59.5045
59.6137
59.7017
59.768
59.8123
59.8344
56.9022
56.8796
56.8343
56.7665
56.6765
56.5646
56.4312
56.2769
56.1024
55.9084
55.6959
55.466
55.22
54.9594
54.686
54.4015
54.1083
53.8087
53.5053
53.2012
52.8993
52.6031
52.3159
52.0414
51.7831
51.5448
51.3299
51.1417
50.9833
50.8571
50.7654
50.7097
50.691
50.7097
50.7654
50.8571
50.9833
51.1417
51.3299
51.5448
51.7831
52.0414
52.3159
52.6031
52.8993
53.2012
53.5053
53.8087
54.1083
54.4015
54.686
54.9594
55.22
55.466
55.6959
55.9084
56.1024
56.2769
56.4312
56.5646
56.6765
56.7665
56.8343
56.8796
56.9022
53.9931
53.9699
53.9235
53.854
53.7616
53.6466
53.5094
53.3505
53.1706
52.9702
52.7504
52.5122
52.2568
51.9856
51.7004
51.4029
51.0955
50.7806
50.4608
50.1393
49.8193
49.5043
49.1981
48.9046
48.6278
48.3717
48.1402
47.9371
47.7657
47.6291
47.5296
47.4692
47.449
47.4692
47.5296
47.6291
47.7657
47.9371
48.1402
48.3717
48.6278
48.9046
49.1981
49.5043
49.8193
50.1393
50.4608
50.7806
51.0955
51.4029
51.7004
51.9856
52.2568
52.5122
52.7504
52.9702
53.1706
53.3505
53.5094
53.6466
53.7616
53.854
53.9235
53.9699
53.9931
51.1077
51.0839
51.0361
50.9646
50.8695
50.7511
50.6096
50.4455
50.2594
50.0519
49.8237
49.5759
49.3096
49.0261
48.7271
48.4145
48.0904
47.7574
47.4182
47.0759
46.7341
46.3966
46.0674
45.7509
45.4514
45.1735
44.9217
44.7002
44.5129
44.3633
44.2543
44.188
44.1658
44.188
44.2543
44.3633
44.5129
44.7002
44.9217
45.1735
45.4514
45.7509
46.0674
46.3966
46.7341
47.0759
47.4182
47.7574
48.0904
48.4145
48.7271
49.0261
49.3096
49.5759
49.8237
50.0519
50.2594
50.4455
50.6096
50.7511
50.8695
50.9646
51.0361
51.0839
51.1077
48.2466
48.2221
48.1729
48.0992
48.0012
47.8789
47.7328
47.563
47.37
47.1544
46.9169
46.6583
46.3797
46.0824
45.7678
45.4377
45.0945
44.7404
44.3785
44.012
43.6447
43.2805
42.9239
42.5798
42.2531
41.9489
41.6724
41.4285
41.2217
41.0563
40.9355
40.862
40.8374
40.862
40.9355
41.0563
41.2217
41.4285
41.6724
41.9489
42.2531
42.5798
42.9239
43.2805
43.6447
44.012
44.3785
44.7404
45.0945
45.4377
45.7678
46.0824
46.3797
46.6583
46.9169
47.1544
47.37
47.563
47.7328
47.8789
48.0012
48.0992
48.1729
48.2221
48.2466
45.4105
45.3852
45.3346
45.2586
45.1574
45.0311
44.8799
44.7039
44.5036
44.2793
44.0316
43.7611
43.469
43.1561
42.824
42.4744
42.1094
41.7315
41.3436
40.9491
40.5519
40.1566
39.7678
39.3911
39.0319
38.6962
38.39
38.119
37.8887
37.7039
37.5688
37.4865
37.4588
37.4865
37.5688
37.7039
37.8887
38.119
38.39
38.6962
39.0319
39.3911
39.7678
40.1566
40.5519
40.9491
41.3436
41.7315
42.1094
42.4744
42.824
43.1561
43.469
43.7611
44.0316
44.2793
44.5036
44.7039
44.8799
45.0311
45.1574
45.2586
45.3346
45.3852
45.4105
42.6002
42.5742
42.522
42.4436
42.3392
42.2086
42.0521
41.8696
41.6615
41.4279
41.1692
40.8861
40.5791
40.2494
39.8981
39.5268
39.1375
38.7327
38.3153
37.8888
37.4574
37.0259
36.5996
36.1844
35.7869
35.4137
35.0718
34.7682
34.5093
34.3011
34.1485
34.0554
34.0241
34.0554
34.1485
34.3011
34.5093
34.7682
35.0718
35.4137
35.7869
36.1844
36.5996
37.0259
37.4574
37.8888
38.3153
38.7327
39.1375
39.5268
39.8981
40.2494
40.5791
40.8861
41.1692
41.4279
41.6615
41.8696
42.0521
42.2086
42.3392
42.4436
42.522
42.5742
42.6002
39.8165
39.7896
39.7359
39.6551
39.5474
39.4125
39.2506
39.0615
38.8452
38.6019
38.3318
38.0352
37.7125
37.3646
36.9924
36.5974
36.1813
35.7466
35.2962
34.8335
34.3631
33.89
33.42
32.9599
32.5171
32.0993
31.7148
31.3719
31.0785
30.8417
30.6679
30.5616
30.5258
30.5616
30.6679
30.8417
31.0785
31.3719
31.7148
32.0993
32.5171
32.9599
33.42
33.89
34.3631
34.8335
35.2962
35.7466
36.1813
36.5974
36.9924
37.3646
37.7125
38.0352
38.3318
38.6019
38.8452
39.0615
39.2506
39.4125
39.5474
39.6551
39.7359
39.7896
39.8165
37.06
37.0325
36.9772
36.8941
36.7831
36.644
36.4766
36.2808
36.0564
35.8033
35.5213
35.2107
34.8715
34.5044
34.1099
33.6893
33.2442
32.7766
32.2894
31.7862
31.2715
30.7508
30.2304
29.718
29.2218
28.7511
28.3157
27.9254
27.59
27.3185
27.1186
26.9961
26.9549
26.9961
27.1186
27.3185
27.59
27.9254
28.3157
28.7511
29.2218
29.718
30.2304
30.7508
31.2715
31.7862
32.2894
32.7766
33.2442
33.6893
34.1099
34.5044
34.8715
35.2107
35.5213
35.8033
36.0564
36.2808
36.4766
36.644
36.7831
36.8941
36.9772
37.0325
37.06
34.3317
34.3035
34.2468
34.1615
34.0474
33.9042
33.7316
33.5293
33.2968
33.0338
32.74
32.4151
32.059
31.6719
31.254
30.8063
30.3298
29.8264
29.2988
28.7505
28.1861
27.6111
27.0328
26.4594
25.9006
25.3671
24.8706
24.4231
24.0367
23.7227
23.4906
23.3482
23.3001
23.3482
23.4906
23.7227
24.0367
24.4231
24.8706
25.3671
25.9006
26.4594
27.0328
27.6111
28.1861
28.7505
29.2988
29.8264
30.3298
30.8063
31.254
31.6719
32.059
32.4151
32.74
33.0338
33.2968
33.5293
33.7316
33.9042
34.0474
34.1615
34.2468
34.3035
34.3317
31.6322
31.6033
31.5453
31.4581
31.3411
31.1942
31.0168
30.8083
30.5681
30.2957
29.9902
29.6512
29.2781
28.8706
28.4286
27.9523
27.4426
26.9009
26.3294
25.7313
25.1112
24.475
23.8302
23.1861
22.5537
21.9456
21.3757
20.8588
20.41
20.0434
19.7716
19.6043
19.5479
19.6043
19.7716
20.0434
20.41
20.8588
21.3757
21.9456
22.5537
23.1861
23.8302
24.475
25.1112
25.7313
26.3294
26.9009
27.4426
27.9523
28.4286
28.8706
29.2781
29.6512
29.9902
30.2957
30.5681
30.8083
31.0168
31.1942
31.3411
31.4581
31.5453
31.6033
31.6322
28.9622
28.9328
28.8737
28.7847
28.6654
28.5152
28.3335
28.1195
27.8723
27.591
27.2745
26.9219
26.5321
26.1043
25.6378
25.1324
24.588
24.0056
23.3868
22.7344
22.0527
21.3475
20.6269
19.9009
19.1821
18.4852
17.8269
17.2255
16.6998
16.268
15.9464
15.748
15.6809
15.748
15.9464
16.268
16.6998
17.2255
17.8269
18.4852
19.1821
19.9009
20.6269
21.3475
22.0527
22.7344
23.3868
24.0056
24.588
25.1324
25.6378
26.1043
26.5321
26.9219
27.2745
27.591
27.8723
28.1195
28.3335
28.5152
28.6654
28.7847
28.8737
28.9328
28.9622
26.3221
26.2923
26.2324
26.1422
26.021
25.8683
25.6831
25.4644
25.2112
24.922
24.5955
24.2303
23.8247
23.3773
22.8867
22.3519
21.7721
21.1473
20.4784
19.7674
19.018
18.2358
17.429
16.6085
15.7883
14.9855
14.2203
13.5153
12.8941
12.3807
11.9963
11.7582
11.6775
11.7582
11.9963
12.3807
12.8941
13.5153
14.2203
14.9855
15.7883
16.6085
17.429
18.2358
19.018
19.7674
20.4784
21.1473
21.7721
22.3519
22.8867
23.3773
23.8247
24.2303
24.5955
24.922
25.2112
25.4644
25.6831
25.8683
26.021
26.1422
26.2324
26.2923
26.3221
23.7123
23.6823
23.6221
23.5311
23.4087
23.2543
23.0666
22.8445
22.5865
22.2909
21.956
21.5796
21.1597
20.6941
20.1805
19.617
19.0018
18.3338
17.6127
16.8393
16.0165
15.1491
14.2451
13.3158
12.3767
11.4476
10.5527
9.71976
8.97919
8.36217
7.8975
7.60849
7.51038
7.60849
7.8975
8.36217
8.97919
9.71976
10.5527
11.4476
12.3767
13.3158
14.2451
15.1491
16.0165
16.8393
17.6127
18.3338
19.0018
19.617
20.1805
20.6941
21.1597
21.5796
21.956
22.2909
22.5865
22.8445
23.0666
23.2543
23.4087
23.5311
23.6221
23.6823
23.7123
21.1332
21.1032
21.0429
20.9517
20.8291
20.6739
20.4851
20.261
19.9999
19.6998
19.3585
18.9732
18.5412
18.0596
17.5251
16.9347
16.2852
15.5743
14.8
13.9616
13.0603
12.0996
11.0867
10.033
8.95488
7.87507
6.82216
5.83044
4.93875
4.18895
3.62032
3.26491
3.14394
3.26491
3.62032
4.18895
4.93875
5.83044
6.82216
7.87507
8.95488
10.033
11.0867
12.0996
13.0603
13.9616
14.8
15.5743
16.2852
16.9347
17.5251
18.0596
18.5412
18.9732
19.3585
19.6998
19.9999
20.261
20.4851
20.6739
20.8291
20.9517
21.0429
21.1032
21.1332
18.5846
18.5548
18.495
18.4044
18.2824
18.1279
17.9393
17.715
17.453
17.1507
16.8055
16.4142
15.9732
15.4787
14.9265
14.3121
13.6311
12.8791
12.0523
11.1477
10.1642
9.10324
7.96997
6.77481
5.53485
4.27517
3.02946
1.83951
0.754184
-0.168292
-0.873423
-1.3168
-1.46823
-1.3168
-0.873423
-0.168292
0.754184
1.83951
3.02946
4.27517
5.53485
6.77481
7.96997
9.10324
10.1642
11.1477
12.0523
12.8791
13.6311
14.3121
14.9265
15.4787
15.9732
16.4142
16.8055
17.1507
17.453
17.715
17.9393
18.1279
18.2824
18.4044
18.495
18.5548
18.5846
16.0663
16.0371
15.9782
15.8891
15.7689
15.6163
15.4298
15.2074
14.9468
14.6452
14.2994
13.9056
13.4596
12.9565
12.391
11.7573
11.0491
10.26
9.38355
8.41399
7.34688
6.18024
4.91602
3.56214
2.13484
0.661067
-0.819901
-2.2577
-3.59581
-4.7463
-5.63304
-6.19505
-6.38802
-6.19505
-5.63304
-4.7463
-3.59581
-2.2577
-0.819901
0.661067
2.13484
3.56214
4.91602
6.18024
7.34688
8.41399
9.38355
10.26
11.0491
11.7573
12.391
12.9565
13.4596
13.9056
14.2994
14.6452
14.9468
15.2074
15.4298
15.6163
15.7689
15.8891
15.9782
16.0371
16.0663
13.5778
13.5494
13.4921
13.4054
13.2882
13.1392
12.9568
12.7387
12.4823
12.1847
11.842
11.4501
11.0038
10.4976
9.92483
9.27814
8.54934
7.72955
6.80936
5.77932
4.63062
3.35632
1.95311
0.424027
-1.21802
-2.94576
-4.71315
-6.45619
-8.13639
-9.59221
-10.7228
-11.4485
-11.7002
-11.4485
-10.7228
-9.59221
-8.13639
-6.45619
-4.71315
-2.94576
-1.21802
0.424027
1.95311
3.35632
4.63062
5.77932
6.80936
7.72955
8.54934
9.27814
9.92483
10.4976
11.0038
11.4501
11.842
12.1847
12.4823
12.7387
12.9568
13.1392
13.2882
13.4054
13.4921
13.5494
13.5778
11.1183
11.091
11.036
10.9526
10.8398
10.6962
10.5199
10.3087
10.0598
9.7698
9.43468
9.04964
8.60906
8.10631
7.5337
6.88232
6.14195
5.30103
4.34673
3.26514
2.04191
0.663286
-0.881974
-2.5994
-4.48389
-6.51237
-8.63118
-10.7195
10.0536
10.0532
10.0533
10.0534
10.0535
10.0534
10.0533
10.0532
10.0536
-10.7195
-8.63118
-6.51237
-4.48389
-2.5994
-0.881974
0.663286
2.04191
3.26514
4.34673
5.30103
6.14195
6.88232
7.5337
8.10631
8.60906
9.04964
9.43468
9.7698
10.0598
10.3087
10.5199
10.6962
10.8398
10.9526
11.036
11.091
11.1183
8.68656
8.66074
8.60868
8.52967
8.42268
8.28625
8.1185
7.91706
7.679
7.40076
7.07802
6.70563
6.2774
5.78596
5.22257
4.57688
3.83667
2.98767
2.01334
0.894797
-0.388994
-1.86054
-3.54225
-5.4532
-7.60358
-9.9873
10.0472
10.0465
10.0465
10.0464
10.0464
10.0464
10.0465
10.0464
10.0464
10.0464
10.0465
10.0465
10.0472
-9.9873
-7.60358
-5.4532
-3.54225
-1.86054
-0.388994
0.894797
2.01334
2.98767
3.83667
4.57688
5.22257
5.78596
6.2774
6.70563
7.07802
7.40076
7.679
7.91706
8.1185
8.28625
8.42268
8.52967
8.60868
8.66074
8.68656
6.28117
6.25716
6.20872
6.13517
6.03546
5.90814
5.75131
5.5626
5.33901
5.07689
4.7718
4.41833
4.00993
3.53868
2.99503
2.3674
1.64186
0.801586
-0.173595
-1.30774
-2.62924
-4.17097
-5.96975
-8.06389
-10.4864
10.0399
10.0399
10.0396
10.0396
10.0395
10.0395
10.0395
10.0395
10.0395
10.0395
10.0395
10.0396
10.0396
10.0399
10.0399
-10.4864
-8.06389
-5.96975
-4.17097
-2.62924
-1.30774
-0.173595
0.801586
1.64186
2.3674
2.99503
3.53868
4.00993
4.41833
4.7718
5.07689
5.33901
5.5626
5.75131
5.90814
6.03546
6.13517
6.20872
6.25716
6.28117
3.90024
3.87839
3.83427
3.76724
3.67628
3.55999
3.41652
3.24355
3.03814
2.79667
2.51471
2.1868
1.80627
1.36493
0.852754
0.257375
-0.436438
-1.2475
-2.1991
-3.32004
-4.64586
-6.22038
-8.09734
-10.3412
10.0322
10.0326
10.0327
10.0326
10.0326
10.0325
10.0325
10.0325
10.0325
10.0325
10.0325
10.0325
10.0326
10.0326
10.0327
10.0326
10.0322
-10.3412
-8.09734
-6.22038
-4.64586
-3.32004
-2.1991
-1.2475
-0.436438
0.257375
0.852754
1.36493
1.80627
2.1868
2.51471
2.79667
3.03814
3.24355
3.41652
3.55999
3.67628
3.76724
3.83427
3.87839
3.90024
1.5416
1.52222
1.4831
1.42361
1.34282
1.23943
1.1117
0.957439
0.77388
0.557583
0.304285
0.00871717
-0.335639
-0.736868
-1.20503
-1.7527
-2.39567
-3.15388
-4.05266
-5.12427
-6.40995
-7.96269
-9.85243
10.0248
10.0253
10.0255
10.0256
10.0256
10.0256
10.0256
10.0256
10.0255
10.0255
10.0255
10.0256
10.0256
10.0256
10.0256
10.0256
10.0255
10.0253
10.0248
-9.85243
-7.96269
-6.40995
-5.12427
-4.05266
-3.15388
-2.39567
-1.7527
-1.20503
-0.736868
-0.335639
0.00871717
0.304285
0.557583
0.77388
0.957439
1.1117
1.23943
1.34282
1.42361
1.4831
1.52222
1.5416
-0.797291
-0.813886
-0.847405
-0.898387
-0.967671
-1.05642
-1.16618
-1.29892
-1.45713
-1.64393
-1.86322
-2.11982
-2.41979
-2.7707
-3.18207
-3.66599
-4.23786
-4.91752
-5.73072
-6.71111
-7.90287
-9.36282
-11.1572
10.0191
10.0186
10.0186
10.0186
10.0186
10.0186
10.0186
10.0186
10.0186
10.0186
10.0186
10.0186
10.0186
10.0186
10.0186
10.0186
10.0186
10.0186
10.0191
-11.1572
-9.36282
-7.90287
-6.71111
-5.73072
-4.91752
-4.23786
-3.66599
-3.18207
-2.7707
-2.41979
-2.11982
-1.86322
-1.64393
-1.45713
-1.29892
-1.16618
-1.05642
-0.967671
-0.898387
-0.847405
-0.813886
-0.797291
-3.11927
-3.13281
-3.16017
-3.2018
-3.2584
-3.33094
-3.42072
-3.5294
-3.6591
-3.81246
-3.99282
-4.20432
-4.45222
-4.74313
-5.08545
-5.48996
-5.9706
-6.54557
-7.23899
-8.08334
-9.12347
-10.4247
10.0096
10.0112
10.0115
10.0116
10.0116
10.0116
10.0116
10.0116
10.0116
10.0116
10.0116
10.0116
10.0116
10.0116
10.0116
10.0116
10.0116
10.0116
10.0115
10.0112
10.0096
-10.4247
-9.12347
-8.08334
-7.23899
-6.54557
-5.9706
-5.48996
-5.08545
-4.74313
-4.45222
-4.20432
-3.99282
-3.81246
-3.6591
-3.5294
-3.42072
-3.33094
-3.2584
-3.2018
-3.16017
-3.13281
-3.11927
-5.42743
-5.4377
-5.45845
-5.49001
-5.53293
-5.58795
-5.65606
-5.73855
-5.83704
-5.95359
-6.09078
-6.25187
-6.44098
-6.66334
-6.92568
-7.23664
-7.60755
-8.05334
-8.59402
-9.25676
-10.079
-11.1125
10.0048
10.0047
10.0047
10.0047
10.0047
10.0047
10.0046
10.0046
10.0046
10.0046
10.0046
10.0046
10.0046
10.0046
10.0046
10.0047
10.0047
10.0047
10.0047
10.0047
10.0048
-11.1125
-10.079
-9.25676
-8.59402
-8.05334
-7.60755
-7.23664
-6.92568
-6.66334
-6.44098
-6.25187
-6.09078
-5.95359
-5.83704
-5.73855
-5.65606
-5.58795
-5.53293
-5.49001
-5.45845
-5.4377
-5.42743
-7.72513
-7.73196
-7.74573
-7.76669
-7.79517
-7.83166
-7.87681
-7.93145
-7.99664
-8.07375
-8.16447
-8.27096
-8.39596
-8.54297
-8.71652
-8.92245
-9.16845
-9.46476
-9.82512
-10.2683
-10.82
-11.5166
9.99839
9.99799
9.99784
9.99777
9.99772
9.99769
9.99766
9.99764
9.99763
9.99762
9.99761
9.99762
9.99763
9.99764
9.99766
9.99769
9.99772
9.99777
9.99784
9.99799
9.99839
-11.5166
-10.82
-10.2683
-9.82512
-9.46476
-9.16845
-8.92245
-8.71652
-8.54297
-8.39596
-8.27096
-8.16447
-8.07375
-7.99664
-7.93145
-7.87681
-7.83166
-7.79517
-7.76669
-7.74573
-7.73196
-7.72513
-10.0159
-10.0191
-10.0257
-10.0357
-10.0493
-10.0666
-10.0879
-10.1136
-10.1442
-10.1801
-10.2221
-10.2712
-10.3286
-10.3957
-10.4745
-10.5676
-10.6783
-10.8112
-10.9722
-11.1695
-11.4144
-11.7237
9.99129
9.99104
9.99091
9.99082
9.99076
9.99072
9.99068
9.99065
9.99063
9.99062
9.99062
9.99062
9.99063
9.99065
9.99068
9.99072
9.99076
9.99082
9.99091
9.99104
9.99129
-11.7237
-11.4144
-11.1695
-10.9722
-10.8112
-10.6783
-10.5676
-10.4745
-10.3957
-10.3286
-10.2712
-10.2221
-10.1801
-10.1442
-10.1136
-10.0879
-10.0666
-10.0493
-10.0357
-10.0257
-10.0191
-10.0159
-12.3033
-12.303
-12.3023
-12.3011
-12.2996
-12.2974
-12.2946
-12.2909
-12.2862
-12.2802
-12.2727
-12.2632
-12.2513
-12.2365
-12.2179
-12.1947
-12.1657
-12.129
-12.0824
-12.0225
-11.9438
-11.8362
9.98396
9.98398
9.98392
9.98385
9.98379
9.98373
9.98369
9.98365
9.98363
9.98362
9.98361
9.98362
9.98363
9.98365
9.98369
9.98373
9.98379
9.98385
9.98392
9.98398
9.98396
-11.8362
-11.9438
-12.0225
-12.0824
-12.129
-12.1657
-12.1947
-12.2179
-12.2365
-12.2513
-12.2632
-12.2727
-12.2802
-12.2862
-12.2909
-12.2946
-12.2974
-12.2996
-12.3011
-12.3023
-12.303
-12.3033
-14.5911
-14.5872
-14.5792
-14.5671
-14.5504
-14.5289
-14.5021
-14.4692
-14.4295
-14.3819
-14.3251
-14.2575
-14.1771
-14.081
-13.9661
-13.8279
-13.6607
-13.4569
-13.2062
-12.8946
-12.5023
-11.9986
9.9768
9.97698
9.97696
9.97688
9.9768
9.97673
9.97668
9.97665
9.97662
9.97661
9.9766
9.97661
9.97662
9.97665
9.97668
9.97673
9.9768
9.97688
9.97696
9.97698
9.9768
-11.9986
-12.5023
-12.8946
-13.2062
-13.4569
-13.6607
-13.8279
-13.9661
-14.081
-14.1771
-14.2575
-14.3251
-14.3819
-14.4295
-14.4692
-14.5021
-14.5289
-14.5504
-14.5671
-14.5792
-14.5872
-14.5911
-16.8828
-16.8754
-16.8604
-16.8375
-16.8062
-16.7659
-16.7157
-16.6545
-16.5808
-16.493
-16.3886
-16.265
-16.1186
-15.9448
-15.738
-15.4906
-15.193
-14.8324
-14.3919
-13.8487
-13.1737
-12.3322
9.97029
9.97021
9.97004
9.9699
9.9698
9.96972
9.96967
9.96963
9.9696
9.96958
9.96958
9.96958
9.9696
9.96963
9.96967
9.96972
9.9698
9.9699
9.97004
9.97021
9.97029
-12.3322
-13.1737
-13.8487
-14.3919
-14.8324
-15.193
-15.4906
-15.738
-15.9448
-16.1186
-16.265
-16.3886
-16.493
-16.5808
-16.6545
-16.7157
-16.7659
-16.8062
-16.8375
-16.8604
-16.8754
-16.8828
-19.1822
-19.1714
-19.1497
-19.1165
-19.0712
-19.013
-18.9405
-18.8524
-18.7466
-18.6207
-18.4717
-18.2956
-18.0878
-17.8422
-17.551
-17.2043
-16.7893
-16.2892
-15.6817
-14.9368
-14.0132
-12.8507
9.96517
9.96354
9.96309
9.96289
9.96277
9.96269
9.96263
9.96259
9.96257
9.96255
9.96255
9.96255
9.96257
9.96259
9.96263
9.96269
9.96277
9.96289
9.96309
9.96354
9.96517
-12.8507
-14.0132
-14.9368
-15.6817
-16.2892
-16.7893
-17.2043
-17.551
-17.8422
-18.0878
-18.2956
-18.4717
-18.6207
-18.7466
-18.8524
-18.9405
-19.013
-19.0712
-19.1165
-19.1497
-19.1714
-19.1822
-21.4925
-21.4786
-21.4505
-21.4077
-21.3494
-21.2744
-21.1813
-21.0682
-20.9328
-20.772
-20.5821
-20.3585
-20.0955
-19.7858
-19.4203
-18.9873
-18.472
-17.855
-17.1111
-16.2066
-15.0953
-13.7118
-11.9587
9.95567
9.95588
9.95581
9.95571
9.95563
9.95558
9.95554
9.95552
9.95551
9.95551
9.95551
9.95552
9.95554
9.95558
9.95563
9.95571
9.95581
9.95588
9.95567
-11.9587
-13.7118
-15.0953
-16.2066
-17.1111
-17.855
-18.472
-18.9873
-19.4203
-19.7858
-20.0955
-20.3585
-20.5821
-20.772
-20.9328
-21.0682
-21.1813
-21.2744
-21.3494
-21.4077
-21.4505
-21.4786
-21.4925
-23.8169
-23.8002
-23.7663
-23.7147
-23.6444
-23.5542
-23.4424
-23.3068
-23.1447
-22.9528
-22.7268
-22.4615
-22.1507
-21.7862
-21.3581
-20.854
-20.2579
-19.5498
-18.7037
-17.6863
-16.454
-14.9515
-13.1147
9.94963
9.94894
9.94876
9.94863
9.94854
9.9485
9.94848
9.94847
9.94846
9.94846
9.94846
9.94847
9.94848
9.9485
9.94854
9.94863
9.94876
9.94894
9.94963
-13.1147
-14.9515
-16.454
-17.6863
-18.7037
-19.5498
-20.2579
-20.854
-21.3581
-21.7862
-22.1507
-22.4615
-22.7268
-22.9528
-23.1447
-23.3068
-23.4424
-23.5542
-23.6444
-23.7147
-23.7663
-23.8002
-23.8169
-26.1585
-26.1391
-26.1001
-26.0406
-25.9597
-25.856
-25.7276
-25.5723
-25.387
-25.1681
-24.9112
-24.6109
-24.2602
-23.8511
-23.3733
-22.814
-22.1577
-21.3847
-20.4704
-19.3841
-18.0871
-16.531
-14.6547
-12.3725
9.94147
9.94168
9.94149
9.94142
9.9414
9.9414
9.9414
9.94141
9.94141
9.94141
9.9414
9.9414
9.9414
9.94142
9.94149
9.94168
9.94147
-12.3725
-14.6547
-16.531
-18.0871
-19.3841
-20.4704
-21.3847
-22.1577
-22.814
-23.3733
-23.8511
-24.2602
-24.6109
-24.9112
-25.1681
-25.387
-25.5723
-25.7276
-25.856
-25.9597
-26.0406
-26.1001
-26.1391
-26.1585
-28.5197
-28.4982
-28.4546
-28.3882
-28.2982
-28.1828
-28.0403
-27.8681
-27.6633
-27.4221
-27.1399
-26.8112
-26.4293
-25.9858
-25.471
-24.8726
-24.176
-23.363
-22.4119
-21.296
-19.9834
-18.4358
-16.6083
-14.4497
-11.9142
9.93501
9.93425
9.93422
9.93429
9.93432
9.93434
9.93436
9.93437
9.93436
9.93434
9.93432
9.93429
9.93422
9.93425
9.93501
-11.9142
-14.4497
-16.6083
-18.4358
-19.9834
-21.296
-22.4119
-23.363
-24.176
-24.8726
-25.471
-25.9858
-26.4293
-26.8112
-27.1399
-27.4221
-27.6633
-27.8681
-28.0403
-28.1828
-28.2982
-28.3882
-28.4546
-28.4982
-28.5197
-30.903
-30.8795
-30.8321
-30.7601
-30.6623
-30.5372
-30.383
-30.1972
-29.9766
-29.7177
-29.4158
-29.0657
-28.6607
-28.1931
-27.6536
-27.0311
-26.3124
-25.4817
-24.5207
-23.4077
-22.1183
-20.6248
-18.8983
-16.9107
-14.6408
-12.0769
9.92626
9.92694
9.92723
9.92723
9.92728
9.92733
9.92735
9.92733
9.92728
9.92723
9.92723
9.92694
9.92626
-12.0769
-14.6408
-16.9107
-18.8983
-20.6248
-22.1183
-23.4077
-24.5207
-25.4817
-26.3124
-27.0311
-27.6536
-28.1931
-28.6607
-29.0657
-29.4158
-29.7177
-29.9766
-30.1972
-30.383
-30.5372
-30.6623
-30.7601
-30.8321
-30.8795
-30.903
-33.3102
-33.2852
-33.2347
-33.158
-33.054
-32.9213
-32.7579
-32.5615
-32.329
-32.0568
-31.7408
-31.3758
-30.9557
-30.4734
-29.9205
-29.2873
-28.5624
-27.7328
-26.7837
-25.6987
-24.4603
-23.0506
-21.4535
-19.6582
-17.6663
-15.5054
-13.2701
9.92004
9.92046
9.9201
9.92022
9.92032
9.92037
9.92032
9.92022
9.9201
9.92046
9.92004
-13.2701
-15.5054
-17.6663
-19.6582
-21.4535
-23.0506
-24.4603
-25.6987
-26.7837
-27.7328
-28.5624
-29.2873
-29.9205
-30.4734
-30.9557
-31.3758
-31.7408
-32.0568
-32.329
-32.5615
-32.7579
-32.9213
-33.054
-33.158
-33.2347
-33.2852
-33.3102
-35.743
-35.7167
-35.6639
-35.5836
-35.475
-35.3365
-35.1664
-34.9624
-34.7215
-34.4406
-34.1156
-33.7418
-33.3138
-32.8253
-32.269
-31.6366
-30.9188
-30.1053
-29.1848
-28.1456
-26.9763
-25.6667
-24.21
-22.6055
-20.8635
-19.0088
-17.0796
-15.0747
-13.1733
9.91246
9.91317
9.91339
9.91347
9.91339
9.91317
9.91246
-13.1733
-15.0747
-17.0796
-19.0088
-20.8635
-22.6055
-24.21
-25.6667
-26.9763
-28.1456
-29.1848
-30.1053
-30.9188
-31.6366
-32.269
-32.8253
-33.3138
-33.7418
-34.1156
-34.4406
-34.7215
-34.9624
-35.1664
-35.3365
-35.475
-35.5836
-35.6639
-35.7167
-35.743
-38.2024
-38.1754
-38.1208
-38.0381
-37.9262
-37.7839
-37.6094
-37.4006
-37.1548
-36.8691
-36.5398
-36.1629
-35.7334
-35.2461
-34.6948
-34.0727
-33.3725
-32.5864
-31.7063
-30.7247
-29.6348
-28.4323
-27.1164
-25.6927
-24.175
-22.588
-20.9668
-19.3553
-17.8498
-16.5481
-15.5484
-14.923
-14.7406
-14.923
-15.5484
-16.5481
-17.8498
-19.3553
-20.9668
-22.588
-24.175
-25.6927
-27.1164
-28.4323
-29.6348
-30.7247
-31.7063
-32.5864
-33.3725
-34.0727
-34.6948
-35.2461
-35.7334
-36.1629
-36.5398
-36.8691
-37.1548
-37.4006
-37.6094
-37.7839
-37.9262
-38.0381
-38.1208
-38.1754
-38.2024
-40.6895
-40.6619
-40.6063
-40.5221
-40.4084
-40.264
-40.0873
-39.8763
-39.6287
-39.3418
-39.0126
-38.6373
-38.2119
-37.7319
-37.1924
-36.5881
-35.9134
-35.1628
-34.3311
-33.4137
-32.4078
-31.3129
-30.1325
-28.8752
-27.557
-26.202
-24.8441
-23.5284
-22.3195
-21.2875
-20.4992
-20.0073
-19.846
-20.0073
-20.4992
-21.2875
-22.3195
-23.5284
-24.8441
-26.202
-27.557
-28.8752
-30.1325
-31.3129
-32.4078
-33.4137
-34.3311
-35.1628
-35.9134
-36.5881
-37.1924
-37.7319
-38.2119
-38.6373
-39.0126
-39.3418
-39.6287
-39.8763
-40.0873
-40.264
-40.4084
-40.5221
-40.6063
-40.6619
-40.6895
-43.2047
-43.1769
-43.1209
-43.0362
-42.9219
-42.7769
-42.5999
-42.3891
-42.1425
-41.8577
-41.532
-41.1625
-40.7457
-40.2781
-39.7559
-39.175
-38.5315
-37.8218
-37.0428
-36.1926
-35.2711
-34.2804
-33.2265
-32.1197
-30.9763
-29.8191
-28.6785
-27.5929
-26.6098
-25.7795
-25.149
-24.7561
-24.6237
-24.7561
-25.149
-25.7795
-26.6098
-27.5929
-28.6785
-29.8191
-30.9763
-32.1197
-33.2265
-34.2804
-35.2711
-36.1926
-37.0428
-37.8218
-38.5315
-39.175
-39.7559
-40.2781
-40.7457
-41.1625
-41.532
-41.8577
-42.1425
-42.3891
-42.5999
-42.7769
-42.9219
-43.0362
-43.1209
-43.1769
-43.2047
-45.7483
-45.7205
-45.6646
-45.5802
-45.4664
-45.3224
-45.1468
-44.9383
-44.695
-44.415
-44.096
-43.7357
-43.3312
-42.8799
-42.3789
-41.8254
-41.2168
-40.551
-39.8268
-39.0441
-38.2046
-37.3122
-36.3742
-35.4015
-34.4097
-33.4194
-32.4569
-31.5535
-30.745
-30.0684
-29.5578
-29.2402
-29.1327
-29.2402
-29.5578
-30.0684
-30.745
-31.5535
-32.4569
-33.4194
-34.4097
-35.4015
-36.3742
-37.3122
-38.2046
-39.0441
-39.8268
-40.551
-41.2168
-41.8254
-42.3789
-42.8799
-43.3312
-43.7357
-44.096
-44.415
-44.695
-44.9383
-45.1468
-45.3224
-45.4664
-45.5802
-45.6646
-45.7205
-45.7483
-48.3201
-48.2927
-48.2374
-48.154
-48.0418
-47.8999
-47.7273
-47.5227
-47.2848
-47.0119
-46.7021
-46.3536
-45.9643
-45.5322
-45.0552
-44.5317
-43.9601
-43.3396
-42.6702
-41.9533
-41.1917
-40.3904
-39.5571
-38.7027
-37.8415
-36.9917
-36.1753
-35.4176
-34.7463
-34.1889
-33.7705
-33.511
-33.4232
-33.511
-33.7705
-34.1889
-34.7463
-35.4176
-36.1753
-36.9917
-37.8415
-38.7027
-39.5571
-40.3904
-41.1917
-41.9533
-42.6702
-43.3396
-43.9601
-44.5317
-45.0552
-45.5322
-45.9643
-46.3536
-46.7021
-47.0119
-47.2848
-47.5227
-47.7273
-47.8999
-48.0418
-48.154
-48.2374
-48.2927
-48.3201
-50.92
-50.893
-50.8388
-50.7571
-50.6472
-50.5085
-50.3402
-50.1411
-49.9102
-49.6462
-49.3476
-49.013
-48.6409
-48.23
-47.7789
-47.2868
-46.7531
-46.1778
-45.562
-44.9079
-44.2191
-43.5011
-42.7615
-42.0108
-41.2617
-40.53
-39.834
-39.1941
-38.6318
-38.1681
-37.8218
-37.6077
-37.5352
-37.6077
-37.8218
-38.1681
-38.6318
-39.1941
-39.834
-40.53
-41.2617
-42.0108
-42.7615
-43.5011
-44.2191
-44.9079
-45.562
-46.1778
-46.7531
-47.2868
-47.7789
-48.23
-48.6409
-49.013
-49.3476
-49.6462
-49.9102
-50.1411
-50.3402
-50.5085
-50.6472
-50.7571
-50.8388
-50.893
-50.92
-53.5473
-53.521
-53.4683
-53.3887
-53.2819
-53.1473
-52.9842
-52.7918
-52.5693
-52.3155
-52.0296
-51.7104
-51.357
-50.9685
-50.5444
-50.0842
-49.5882
-49.0571
-48.4928
-47.8977
-47.2761
-46.6335
-45.9774
-45.3172
-44.6642
-44.032
-43.4357
-42.8919
-42.4173
-42.0282
-41.7388
-41.5604
-41.5001
-41.5604
-41.7388
-42.0282
-42.4173
-42.8919
-43.4357
-44.032
-44.6642
-45.3172
-45.9774
-46.6335
-47.2761
-47.8977
-48.4928
-49.0571
-49.5882
-50.0842
-50.5444
-50.9685
-51.357
-51.7104
-52.0296
-52.3155
-52.5693
-52.7918
-52.9842
-53.1473
-53.2819
-53.3887
-53.4683
-53.521
-53.5473
-56.2014
-56.176
-56.1249
-56.0479
-55.9448
-55.815
-55.658
-55.4732
-55.26
-55.0176
-54.7453
-54.4426
-54.1087
-53.7433
-53.3463
-52.918
-52.4589
-51.9704
-51.4546
-50.9145
-50.3545
-49.7798
-49.1975
-48.6161
-48.0456
-47.4975
-46.9843
-46.5193
-46.116
-45.7869
-45.5431
-45.3932
-45.3426
-45.3932
-45.5431
-45.7869
-46.116
-46.5193
-46.9843
-47.4975
-48.0456
-48.6161
-49.1975
-49.7798
-50.3545
-50.9145
-51.4546
-51.9704
-52.4589
-52.918
-53.3463
-53.7433
-54.1087
-54.4426
-54.7453
-55.0176
-55.26
-55.4732
-55.658
-55.815
-55.9448
-56.0479
-56.1249
-56.176
-56.2014
-58.8814
-58.8569
-58.8078
-58.7338
-58.6348
-58.5103
-58.36
-58.1835
-57.9804
-57.75
-57.4921
-57.2063
-56.8923
-56.5502
-56.1802
-55.7829
-55.3594
-54.9113
-54.4411
-53.9517
-53.4476
-52.9338
-52.4168
-51.904
-51.4044
-50.9275
-50.4838
-50.0842
-49.7392
-49.459
-49.2521
-49.1252
-49.0824
-49.1252
-49.2521
-49.459
-49.7392
-50.0842
-50.4838
-50.9275
-51.4044
-51.904
-52.4168
-52.9338
-53.4476
-53.9517
-54.4411
-54.9113
-55.3594
-55.7829
-56.1802
-56.5502
-56.8923
-57.2063
-57.4921
-57.75
-57.9804
-58.1835
-58.36
-58.5103
-58.6348
-58.7338
-58.8078
-58.8569
-58.8814
-61.5864
-61.5629
-61.5159
-61.4452
-61.3506
-61.2318
-61.0887
-60.921
-60.7283
-60.5104
-60.2672
-59.9986
-59.7046
-59.3855
-59.0418
-58.6745
-58.2849
-57.8749
-57.4468
-57.004
-56.5505
-56.0911
-55.6316
-55.1787
-54.74
-54.3238
-53.9386
-53.5934
-53.2968
-53.0567
-52.88
-52.7717
-52.7352
-52.7717
-52.88
-53.0567
-53.2968
-53.5934
-53.9386
-54.3238
-54.74
-55.1787
-55.6316
-56.0911
-56.5505
-57.004
-57.4468
-57.8749
-58.2849
-58.6745
-59.0418
-59.3855
-59.7046
-59.9986
-60.2672
-60.5104
-60.7283
-60.921
-61.0887
-61.2318
-61.3506
-61.4452
-61.5159
-61.5629
-61.5864
-64.3152
-64.2929
-64.2481
-64.1808
-64.0908
-63.9781
-63.8424
-63.6837
-63.5018
-63.2966
-63.0682
-62.8166
-62.5423
-62.2457
-61.9275
-61.5888
-61.2312
-60.8566
-60.4676
-60.0672
-59.6593
-59.2484
-58.8397
-58.439
-58.0529
-57.6885
-57.3528
-57.0533
-56.797
-56.5901
-56.4382
-56.3453
-56.314
-56.3453
-56.4382
-56.5901
-56.797
-57.0533
-57.3528
-57.6885
-58.0529
-58.439
-58.8397
-59.2484
-59.6593
-60.0672
-60.4676
-60.8566
-61.2312
-61.5888
-61.9275
-62.2457
-62.5423
-62.8166
-63.0682
-63.2966
-63.5018
-63.6837
-63.8424
-63.9781
-64.0908
-64.1808
-64.2481
-64.2929
-64.3152
-67.0669
-67.0457
-67.0032
-66.9394
-66.8542
-66.7476
-66.6195
-66.4699
-66.2988
-66.1063
-65.8926
-65.6579
-65.4027
-65.1277
-64.8338
-64.5223
-64.1947
-63.8531
-63.4999
-63.1381
-62.7713
-62.4035
-62.0395
-61.6845
-61.3439
-61.0239
-60.7303
-60.4694
-60.2468
-60.0677
-59.9364
-59.8563
-59.8294
-59.8563
-59.9364
-60.0677
-60.2468
-60.4694
-60.7303
-61.0239
-61.3439
-61.6845
-62.0395
-62.4035
-62.7713
-63.1381
-63.4999
-63.8531
-64.1947
-64.5223
-64.8338
-65.1277
-65.4027
-65.6579
-65.8926
-66.1063
-66.2988
-66.4699
-66.6195
-66.7476
-66.8542
-66.9394
-67.0032
-67.0457
-67.0669
-69.8401
-69.8201
-69.78
-69.7198
-69.6394
-69.539
-69.4185
-69.278
-69.1177
-68.9377
-68.7383
-68.5199
-68.2832
-68.0289
-67.7581
-67.4721
-67.1725
-66.8613
-66.5409
-66.2141
-65.8842
-65.5549
-65.2304
-64.9151
-64.6141
-64.3323
-64.0748
-63.8466
-63.6526
-63.4968
-63.3828
-63.3133
-63.2899
-63.3133
-63.3828
-63.4968
-63.6526
-63.8466
-64.0748
-64.3323
-64.6141
-64.9151
-65.2304
-65.5549
-65.8842
-66.2141
-66.5409
-66.8613
-67.1725
-67.4721
-67.7581
-68.0289
-68.2832
-68.5199
-68.7383
-68.9377
-69.1177
-69.278
-69.4185
-69.539
-69.6394
-69.7198
-69.78
-69.8201
-69.8401
-72.6337
-72.6149
-72.5771
-72.5205
-72.445
-72.3508
-72.2378
-72.1063
-71.9565
-71.7887
-71.6032
-71.4006
-71.1816
-70.947
-70.6979
-70.4358
-70.1621
-69.8789
-69.5884
-69.2932
-68.9964
-68.7014
-68.4117
-68.1315
-67.8648
-67.616
-67.3894
-67.1892
-67.0194
-66.8833
-66.7839
-66.7234
-66.7031
-66.7234
-66.7839
-66.8833
-67.0194
-67.1892
-67.3894
-67.616
-67.8648
-68.1315
-68.4117
-68.7014
-68.9964
-69.2932
-69.5884
-69.8789
-70.1621
-70.4358
-70.6979
-70.947
-71.1816
-71.4006
-71.6032
-71.7887
-71.9565
-72.1063
-72.2378
-72.3508
-72.445
-72.5205
-72.5771
-72.6149
-72.6337
-75.4466
-75.4289
-75.3935
-75.3404
-75.2697
-75.1815
-75.0759
-74.9532
-74.8136
-74.6576
-74.4855
-74.2979
-74.0957
-73.8797
-73.651
-73.4111
-73.1614
-72.9038
-72.6405
-72.374
-72.1069
-71.8424
-71.5836
-71.334
-71.0973
-70.8771
-70.6772
-70.501
-70.3519
-70.2326
-70.1457
-70.0927
-70.075
-70.0927
-70.1457
-70.2326
-70.3519
-70.501
-70.6772
-70.8771
-71.0973
-71.334
-71.5836
-71.8424
-72.1069
-72.374
-72.6405
-72.9038
-73.1614
-73.4111
-73.651
-73.8797
-74.0957
-74.2979
-74.4855
-74.6576
-74.8136
-74.9532
-75.0759
-75.1815
-75.2697
-75.3404
-75.3935
-75.4289
-75.4466
-78.2774
-78.2609
-78.2278
-78.1782
-78.1121
-78.0298
-77.9314
-77.8172
-77.6875
-77.5428
-77.3834
-77.2102
-77.0238
-76.8253
-76.6156
-76.3962
-76.1686
-75.9345
-75.696
-75.4553
-75.2149
-74.9775
-74.746
-74.5234
-74.3129
-74.1177
-73.9409
-73.7854
-73.6541
-73.5492
-73.4728
-73.4263
-73.4107
-73.4263
-73.4728
-73.5492
-73.6541
-73.7854
-73.9409
-74.1177
-74.3129
-74.5234
-74.746
-74.9775
-75.2149
-75.4553
-75.696
-75.9345
-76.1686
-76.3962
-76.6156
-76.8253
-77.0238
-77.2102
-77.3834
-77.5428
-77.6875
-77.8172
-77.9314
-78.0298
-78.1121
-78.1782
-78.2278
-78.2609
-78.2774
-81.1252
-81.1097
-81.0789
-81.0326
-80.9711
-80.8945
-80.803
-80.697
-80.5767
-80.4428
-80.2956
-80.1358
-79.9643
-79.7821
-79.5901
-79.3897
-79.1824
-78.9698
-78.7538
-78.5364
-78.3199
-78.1067
-77.8994
-77.7006
-77.5131
-77.3397
-77.1829
-77.0453
-76.9293
-76.8368
-76.7695
-76.7286
-76.7149
-76.7286
-76.7695
-76.8368
-76.9293
-77.0453
-77.1829
-77.3397
-77.5131
-77.7006
-77.8994
-78.1067
-78.3199
-78.5364
-78.7538
-78.9698
-79.1824
-79.3897
-79.5901
-79.7821
-79.9643
-80.1358
-80.2956
-80.4428
-80.5767
-80.697
-80.803
-80.8945
-80.9711
-81.0326
-81.0789
-81.1097
-81.1252
-83.9886
-83.9743
-83.9455
-83.9025
-83.8454
-83.7742
-83.6894
-83.5912
-83.4799
-83.3561
-83.2204
-83.0734
-82.9158
-82.7487
-82.5732
-82.3903
-82.2016
-82.0085
-81.8129
-81.6165
-81.4215
-81.2299
-81.044
-80.8663
-80.6991
-80.5447
-80.4054
-80.2834
-80.1806
-80.0988
-80.0394
-80.0033
-79.9912
-80.0033
-80.0394
-80.0988
-80.1806
-80.2834
-80.4054
-80.5447
-80.6991
-80.8663
-81.044
-81.2299
-81.4215
-81.6165
-81.8129
-82.0085
-82.2016
-82.3903
-82.5732
-82.7487
-82.9158
-83.0734
-83.2204
-83.3561
-83.4799
-83.5912
-83.6894
-83.7742
-83.8454
-83.9025
-83.9455
-83.9743
-83.9886
-86.8667
-86.8534
-86.8267
-86.7868
-86.7338
-86.6679
-86.5894
-86.4986
-86.3958
-86.2817
-86.1567
-86.0216
-85.877
-85.724
-85.5636
-85.3969
-85.2252
-85.0499
-84.8727
-84.6953
-84.5195
-84.3472
-84.1805
-84.0214
-83.872
-83.7343
-83.6103
-83.5019
-83.4107
-83.3382
-83.2855
-83.2535
-83.2428
-83.2535
-83.2855
-83.3382
-83.4107
-83.5019
-83.6103
-83.7343
-83.872
-84.0214
-84.1805
-84.3472
-84.5195
-84.6953
-84.8727
-85.0499
-85.2252
-85.3969
-85.5636
-85.724
-85.877
-86.0216
-86.1567
-86.2817
-86.3958
-86.4986
-86.5894
-86.6679
-86.7338
-86.7868
-86.8267
-86.8534
-86.8667
-89.7584
-89.7461
-89.7214
-89.6844
-89.6354
-89.5744
-89.5019
-89.418
-89.3233
-89.2182
-89.1033
-88.9793
-88.8468
-88.7069
-88.5604
-88.4084
-88.2523
-88.0933
-87.9328
-87.7725
-87.614
-87.4589
-87.3092
-87.1666
-87.0329
-86.91
-86.7994
-86.7029
-86.6218
-86.5574
-86.5106
-86.4823
-86.4728
-86.4823
-86.5106
-86.5574
-86.6218
-86.7029
-86.7994
-86.91
-87.0329
-87.1666
-87.3092
-87.4589
-87.614
-87.7725
-87.9328
-88.0933
-88.2523
-88.4084
-88.5604
-88.7069
-88.8468
-88.9793
-89.1033
-89.2182
-89.3233
-89.418
-89.5019
-89.5744
-89.6354
-89.6844
-89.7214
-89.7461
-89.7584
-92.6627
-92.6513
-92.6284
-92.5943
-92.549
-92.4927
-92.4258
-92.3486
-92.2614
-92.1648
-92.0593
-91.9455
-91.8243
-91.6963
-91.5627
-91.4243
-91.2824
-91.1381
-90.9928
-90.8479
-90.7049
-90.5653
-90.4307
-90.3028
-90.183
-90.0731
-89.9744
-89.8883
-89.816
-89.7586
-89.717
-89.6918
-89.6834
-89.6918
-89.717
-89.7586
-89.816
-89.8883
-89.9744
-90.0731
-90.183
-90.3028
-90.4307
-90.5653
-90.7049
-90.8479
-90.9928
-91.1381
-91.2824
-91.4243
-91.5627
-91.6963
-91.8243
-91.9455
-92.0593
-92.1648
-92.2614
-92.3486
-92.4258
-92.4927
-92.549
-92.5943
-92.6284
-92.6513
-92.6627
-95.5786
-95.5681
-95.547
-95.5155
-95.4737
-95.4219
-95.3602
-95.2892
-95.209
-95.1203
-95.0235
-94.9194
-94.8085
-94.6917
-94.5698
-94.4438
-94.3148
-94.1839
-94.0523
-93.9213
-93.7923
-93.6665
-93.5455
-93.4306
-93.3232
-93.2247
-93.1365
-93.0595
-92.9951
-92.9439
-92.9068
-92.8844
-92.8768
-92.8844
-92.9068
-92.9439
-92.9951
-93.0595
-93.1365
-93.2247
-93.3232
-93.4306
-93.5455
-93.6665
-93.7923
-93.9213
-94.0523
-94.1839
-94.3148
-94.4438
-94.5698
-94.6917
-94.8085
-94.9194
-95.0235
-95.1203
-95.209
-95.2892
-95.3602
-95.4219
-95.4737
-95.5155
-95.547
-95.5681
-95.5786
-98.5053
-98.4956
-98.4762
-98.4471
-98.4087
-98.361
-98.3043
-98.239
-98.1654
-98.084
-97.9954
-97.9
-97.7987
-97.6921
-97.581
-97.4664
-97.3492
-97.2305
-97.1113
-96.9928
-96.8763
-96.7629
-96.654
-96.5507
-96.4543
-96.3661
-96.287
-96.2182
-96.1606
-96.1149
-96.0818
-96.0617
-96.055
-96.0617
-96.0818
-96.1149
-96.1606
-96.2182
-96.287
-96.3661
-96.4543
-96.5507
-96.654
-96.7629
-96.8763
-96.9928
-97.1113
-97.2305
-97.3492
-97.4664
-97.581
-97.6921
-97.7987
-97.9
-97.9954
-98.084
-98.1654
-98.239
-98.3043
-98.361
-98.4087
-98.4471
-98.4762
-98.4956
-98.5053
-101.442
-101.433
-101.415
-101.388
-101.353
-101.309
-101.257
-101.197
-101.13
-101.055
-100.974
-100.887
-100.794
-100.697
-100.596
-100.492
-100.385
-100.277
-100.17
-100.062
-99.9571
-99.8549
-99.7568
-99.6639
-99.5773
-99.498
-99.4272
-99.3655
-99.3139
-99.2731
-99.2435
-99.2255
-99.2195
-99.2255
-99.2435
-99.2731
-99.3139
-99.3655
-99.4272
-99.498
-99.5773
-99.6639
-99.7568
-99.8549
-99.9571
-100.062
-100.17
-100.277
-100.385
-100.492
-100.596
-100.697
-100.794
-100.887
-100.974
-101.055
-101.13
-101.197
-101.257
-101.309
-101.353
-101.388
-101.415
-101.433
-101.442
-104.388
-104.379
-104.363
-104.338
-104.306
-104.266
-104.218
-104.163
-104.101
-104.033
-103.959
-103.879
-103.795
-103.706
-103.614
-103.519
-103.422
-103.325
-103.227
-103.13
-103.035
-102.943
-102.854
-102.771
-102.693
-102.622
-102.558
-102.503
-102.456
-102.42
-102.393
-102.377
-102.372
-102.377
-102.393
-102.42
-102.456
-102.503
-102.558
-102.622
-102.693
-102.771
-102.854
-102.943
-103.035
-103.13
-103.227
-103.325
-103.422
-103.519
-103.614
-103.706
-103.795
-103.879
-103.959
-104.033
-104.101
-104.163
-104.218
-104.266
-104.306
-104.338
-104.363
-104.379
-104.388
-107.342
-107.334
-107.319
-107.297
-107.267
-107.23
-107.186
-107.136
-107.079
-107.017
-106.949
-106.876
-106.799
-106.718
-106.635
-106.548
-106.461
-106.372
-106.283
-106.196
-106.11
-106.027
-105.947
-105.871
-105.801
-105.737
-105.68
-105.631
-105.589
-105.556
-105.533
-105.518
-105.513
-105.518
-105.533
-105.556
-105.589
-105.631
-105.68
-105.737
-105.801
-105.871
-105.947
-106.027
-106.11
-106.196
-106.283
-106.372
-106.461
-106.548
-106.635
-106.718
-106.799
-106.876
-106.949
-107.017
-107.079
-107.136
-107.186
-107.23
-107.267
-107.297
-107.319
-107.334
-107.342
-110.303
-110.297
-110.283
-110.262
-110.235
-110.201
-110.161
-110.115
-110.063
-110.006
-109.944
-109.878
-109.808
-109.734
-109.658
-109.579
-109.5
-109.419
-109.339
-109.26
-109.182
-109.107
-109.035
-108.967
-108.904
-108.846
-108.795
-108.75
-108.713
-108.684
-108.662
-108.649
-108.645
-108.649
-108.662
-108.684
-108.713
-108.75
-108.795
-108.846
-108.904
-108.967
-109.035
-109.107
-109.182
-109.26
-109.339
-109.419
-109.5
-109.579
-109.658
-109.734
-109.808
-109.878
-109.944
-110.006
-110.063
-110.115
-110.161
-110.201
-110.235
-110.262
-110.283
-110.297
-110.303
-113.272
-113.266
-113.253
-113.234
-113.209
-113.178
-113.142
-113.1
-113.052
-113
-112.944
-112.883
-112.819
-112.752
-112.683
-112.612
-112.539
-112.467
-112.394
-112.322
-112.252
-112.184
-112.119
-112.058
-112.001
-111.949
-111.903
-111.862
-111.829
-111.802
-111.783
-111.772
-111.768
-111.772
-111.783
-111.802
-111.829
-111.862
-111.903
-111.949
-112.001
-112.058
-112.119
-112.184
-112.252
-112.322
-112.394
-112.467
-112.539
-112.612
-112.683
-112.752
-112.819
-112.883
-112.944
-113
-113.052
-113.1
-113.142
-113.178
-113.209
-113.234
-113.253
-113.266
-113.272
-116.248
-116.242
-116.23
-116.213
-116.19
-116.162
-116.128
-116.09
-116.047
-115.999
-115.947
-115.892
-115.834
-115.773
-115.71
-115.645
-115.58
-115.514
-115.448
-115.383
-115.319
-115.258
-115.199
-115.144
-115.092
-115.046
-115.004
-114.968
-114.938
-114.914
-114.897
-114.886
-114.883
-114.886
-114.897
-114.914
-114.938
-114.968
-115.004
-115.046
-115.092
-115.144
-115.199
-115.258
-115.319
-115.383
-115.448
-115.514
-115.58
-115.645
-115.71
-115.773
-115.834
-115.892
-115.947
-115.999
-116.047
-116.09
-116.128
-116.162
-116.19
-116.213
-116.23
-116.242
-116.248
-119.229
-119.224
-119.213
-119.197
-119.176
-119.15
-119.12
-119.085
-119.045
-119.002
-118.955
-118.905
-118.852
-118.796
-118.739
-118.68
-118.62
-118.56
-118.501
-118.442
-118.384
-118.329
-118.276
-118.226
-118.18
-118.137
-118.1
-118.067
-118.04
-118.019
-118.003
-117.994
-117.991
-117.994
-118.003
-118.019
-118.04
-118.067
-118.1
-118.137
-118.18
-118.226
-118.276
-118.329
-118.384
-118.442
-118.501
-118.56
-118.62
-118.68
-118.739
-118.796
-118.852
-118.905
-118.955
-119.002
-119.045
-119.085
-119.12
-119.15
-119.176
-119.197
-119.213
-119.224
-119.229
-122.216
-122.211
-122.201
-122.187
-122.167
-122.144
-122.116
-122.084
-122.048
-122.008
-121.965
-121.92
-121.871
-121.821
-121.769
-121.716
-121.661
-121.607
-121.553
-121.5
-121.448
-121.397
-121.349
-121.304
-121.263
-121.225
-121.191
-121.161
-121.137
-121.118
-121.104
-121.095
-121.092
-121.095
-121.104
-121.118
-121.137
-121.161
-121.191
-121.225
-121.263
-121.304
-121.349
-121.397
-121.448
-121.5
-121.553
-121.607
-121.661
-121.716
-121.769
-121.821
-121.871
-121.92
-121.965
-122.008
-122.048
-122.084
-122.116
-122.144
-122.167
-122.187
-122.201
-122.211
-122.216
-125.207
-125.203
-125.194
-125.181
-125.163
-125.142
-125.116
-125.087
-125.054
-125.018
-124.979
-124.937
-124.893
-124.848
-124.8
-124.752
-124.703
-124.653
-124.604
-124.556
-124.509
-124.464
-124.42
-124.379
-124.342
-124.307
-124.277
-124.25
-124.228
-124.211
-124.198
-124.191
-124.188
-124.191
-124.198
-124.211
-124.228
-124.25
-124.277
-124.307
-124.342
-124.379
-124.42
-124.464
-124.509
-124.556
-124.604
-124.653
-124.703
-124.752
-124.8
-124.848
-124.893
-124.937
-124.979
-125.018
-125.054
-125.087
-125.116
-125.142
-125.163
-125.181
-125.194
-125.203
-125.207
-128.203
-128.199
-128.191
-128.179
-128.163
-128.143
-128.12
-128.094
-128.064
-128.031
-127.995
-127.957
-127.917
-127.876
-127.833
-127.789
-127.744
-127.7
-127.655
-127.611
-127.569
-127.527
-127.488
-127.452
-127.417
-127.386
-127.359
-127.335
-127.315
-127.299
-127.288
-127.281
-127.279
-127.281
-127.288
-127.299
-127.315
-127.335
-127.359
-127.386
-127.417
-127.452
-127.488
-127.527
-127.569
-127.611
-127.655
-127.7
-127.744
-127.789
-127.833
-127.876
-127.917
-127.957
-127.995
-128.031
-128.064
-128.094
-128.12
-128.143
-128.163
-128.179
-128.191
-128.199
-128.203
-131.203
-131.2
-131.192
-131.181
-131.167
-131.149
-131.128
-131.103
-131.076
-131.046
-131.014
-130.98
-130.943
-130.905
-130.866
-130.826
-130.786
-130.745
-130.705
-130.665
-130.627
-130.59
-130.554
-130.521
-130.49
-130.462
-130.437
-130.416
-130.398
-130.383
-130.373
-130.367
-130.365
-130.367
-130.373
-130.383
-130.398
-130.416
-130.437
-130.462
-130.49
-130.521
-130.554
-130.59
-130.627
-130.665
-130.705
-130.745
-130.786
-130.826
-130.866
-130.905
-130.943
-130.98
-131.014
-131.046
-131.076
-131.103
-131.128
-131.149
-131.167
-131.181
-131.192
-131.2
-131.203
-134.207
-134.204
-134.197
-134.187
-134.174
-134.158
-134.138
-134.116
-134.092
-134.064
-134.035
-134.004
-133.971
-133.936
-133.901
-133.864
-133.828
-133.791
-133.754
-133.718
-133.683
-133.65
-133.618
-133.588
-133.56
-133.534
-133.512
-133.492
-133.476
-133.463
-133.454
-133.449
-133.447
-133.449
-133.454
-133.463
-133.476
-133.492
-133.512
-133.534
-133.56
-133.588
-133.618
-133.65
-133.683
-133.718
-133.754
-133.791
-133.828
-133.864
-133.901
-133.936
-133.971
-134.004
-134.035
-134.064
-134.092
-134.116
-134.138
-134.158
-134.174
-134.187
-134.197
-134.204
-134.207
-137.215
-137.212
-137.206
-137.197
-137.185
-137.17
-137.152
-137.132
-137.109
-137.085
-137.058
-137.029
-136.999
-136.968
-136.936
-136.903
-136.87
-136.836
-136.803
-136.77
-136.739
-136.708
-136.679
-136.652
-136.627
-136.604
-136.584
-136.566
-136.551
-136.54
-136.531
-136.526
-136.525
-136.526
-136.531
-136.54
-136.551
-136.566
-136.584
-136.604
-136.627
-136.652
-136.679
-136.708
-136.739
-136.77
-136.803
-136.836
-136.87
-136.903
-136.936
-136.968
-136.999
-137.029
-137.058
-137.085
-137.109
-137.132
-137.152
-137.17
-137.185
-137.197
-137.206
-137.212
-137.215
-140.225
-140.223
-140.217
-140.209
-140.198
-140.184
-140.168
-140.15
-140.129
-140.107
-140.082
-140.057
-140.029
-140.001
-139.972
-139.942
-139.911
-139.881
-139.851
-139.822
-139.793
-139.765
-139.739
-139.714
-139.692
-139.671
-139.652
-139.637
-139.623
-139.613
-139.605
-139.601
-139.599
-139.601
-139.605
-139.613
-139.623
-139.637
-139.652
-139.671
-139.692
-139.714
-139.739
-139.765
-139.793
-139.822
-139.851
-139.881
-139.911
-139.942
-139.972
-140.001
-140.029
-140.057
-140.082
-140.107
-140.129
-140.15
-140.168
-140.184
-140.198
-140.209
-140.217
-140.223
-140.225
-143.239
-143.236
-143.231
-143.224
-143.214
-143.201
-143.187
-143.17
-143.151
-143.131
-143.109
-143.085
-143.06
-143.035
-143.008
-142.981
-142.953
-142.926
-142.899
-142.872
-142.846
-142.821
-142.797
-142.775
-142.754
-142.736
-142.719
-142.705
-142.693
-142.683
-142.676
-142.672
-142.671
-142.672
-142.676
-142.683
-142.693
-142.705
-142.719
-142.736
-142.754
-142.775
-142.797
-142.821
-142.846
-142.872
-142.899
-142.926
-142.953
-142.981
-143.008
-143.035
-143.06
-143.085
-143.109
-143.131
-143.151
-143.17
-143.187
-143.201
-143.214
-143.224
-143.231
-143.236
-143.239
-146.255
-146.253
-146.248
-146.241
-146.232
-146.221
-146.207
-146.192
-146.175
-146.157
-146.137
-146.115
-146.093
-146.069
-146.045
-146.02
-145.995
-145.971
-145.946
-145.922
-145.898
-145.875
-145.854
-145.834
-145.815
-145.798
-145.783
-145.77
-145.759
-145.751
-145.744
-145.741
-145.739
-145.741
-145.744
-145.751
-145.759
-145.77
-145.783
-145.798
-145.815
-145.834
-145.854
-145.875
-145.898
-145.922
-145.946
-145.971
-145.995
-146.02
-146.045
-146.069
-146.093
-146.115
-146.137
-146.157
-146.175
-146.192
-146.207
-146.221
-146.232
-146.241
-146.248
-146.253
-146.255
-149.273
-149.271
-149.267
-149.261
-149.252
-149.242
-149.23
-149.216
-149.201
-149.184
-149.166
-149.146
-149.126
-149.104
-149.082
-149.06
-149.038
-149.015
-148.993
-148.971
-148.949
-148.929
-148.909
-148.891
-148.874
-148.859
-148.845
-148.833
-148.823
-148.816
-148.81
-148.807
-148.806
-148.807
-148.81
-148.816
-148.823
-148.833
-148.845
-148.859
-148.874
-148.891
-148.909
-148.929
-148.949
-148.971
-148.993
-149.015
-149.038
-149.06
-149.082
-149.104
-149.126
-149.146
-149.166
-149.184
-149.201
-149.216
-149.23
-149.242
-149.252
-149.261
-149.267
-149.271
-149.273
-152.294
-152.292
-152.288
-152.282
-152.275
-152.265
-152.254
-152.242
-152.228
-152.212
-152.196
-152.178
-152.16
-152.14
-152.12
-152.1
-152.08
-152.059
-152.039
-152.019
-151.999
-151.981
-151.963
-151.947
-151.931
-151.917
-151.905
-151.894
-151.886
-151.879
-151.874
-151.871
-151.87
-151.871
-151.874
-151.879
-151.886
-151.894
-151.905
-151.917
-151.931
-151.947
-151.963
-151.981
-151.999
-152.019
-152.039
-152.059
-152.08
-152.1
-152.12
-152.14
-152.16
-152.178
-152.196
-152.212
-152.228
-152.242
-152.254
-152.265
-152.275
-152.282
-152.288
-152.292
-152.294
-155.316
-155.314
-155.311
-155.306
-155.299
-155.29
-155.28
-155.269
-155.256
-155.242
-155.227
-155.211
-155.194
-155.177
-155.159
-155.14
-155.122
-155.103
-155.085
-155.067
-155.049
-155.032
-155.016
-155.001
-154.987
-154.975
-154.964
-154.954
-154.946
-154.94
-154.935
-154.932
-154.931
-154.932
-154.935
-154.94
-154.946
-154.954
-154.964
-154.975
-154.987
-155.001
-155.016
-155.032
-155.049
-155.067
-155.085
-155.103
-155.122
-155.14
-155.159
-155.177
-155.194
-155.211
-155.227
-155.242
-155.256
-155.269
-155.28
-155.29
-155.299
-155.306
-155.311
-155.314
-155.316
-158.34
-158.339
-158.336
-158.331
-158.325
-158.317
-158.308
-158.298
-158.286
-158.273
-158.26
-158.245
-158.23
-158.214
-158.197
-158.181
-158.164
-158.147
-158.13
-158.114
-158.098
-158.083
-158.068
-158.054
-158.042
-158.031
-158.02
-158.012
-158.004
-157.999
-157.995
-157.992
-157.991
-157.992
-157.995
-157.999
-158.004
-158.012
-158.02
-158.031
-158.042
-158.054
-158.068
-158.083
-158.098
-158.114
-158.13
-158.147
-158.164
-158.181
-158.197
-158.214
-158.23
-158.245
-158.26
-158.273
-158.286
-158.298
-158.308
-158.317
-158.325
-158.331
-158.336
-158.339
-158.34
-161.366
-161.365
-161.362
-161.358
-161.352
-161.345
-161.337
-161.327
-161.317
-161.305
-161.293
-161.28
-161.266
-161.251
-161.236
-161.221
-161.206
-161.191
-161.175
-161.161
-161.146
-161.132
-161.119
-161.107
-161.095
-161.085
-161.076
-161.068
-161.061
-161.056
-161.052
-161.05
-161.049
-161.05
-161.052
-161.056
-161.061
-161.068
-161.076
-161.085
-161.095
-161.107
-161.119
-161.132
-161.146
-161.161
-161.175
-161.191
-161.206
-161.221
-161.236
-161.251
-161.266
-161.28
-161.293
-161.305
-161.317
-161.327
-161.337
-161.345
-161.352
-161.358
-161.362
-161.365
-161.366
-164.394
-164.392
-164.39
-164.386
-164.381
-164.374
-164.367
-164.358
-164.349
-164.338
-164.327
-164.315
-164.302
-164.289
-164.276
-164.262
-164.248
-164.234
-164.22
-164.207
-164.194
-164.181
-164.169
-164.158
-164.148
-164.138
-164.13
-164.123
-164.117
-164.112
-164.109
-164.107
-164.106
-164.107
-164.109
-164.112
-164.117
-164.123
-164.13
-164.138
-164.148
-164.158
-164.169
-164.181
-164.194
-164.207
-164.22
-164.234
-164.248
-164.262
-164.276
-164.289
-164.302
-164.315
-164.327
-164.338
-164.349
-164.358
-164.367
-164.374
-164.381
-164.386
-164.39
-164.392
-164.394
-167.422
-167.421
-167.419
-167.415
-167.41
-167.405
-167.398
-167.39
-167.381
-167.372
-167.362
-167.351
-167.339
-167.327
-167.315
-167.303
-167.29
-167.277
-167.265
-167.253
-167.241
-167.229
-167.219
-167.208
-167.199
-167.191
-167.183
-167.177
-167.171
-167.167
-167.164
-167.162
-167.161
-167.162
-167.164
-167.167
-167.171
-167.177
-167.183
-167.191
-167.199
-167.208
-167.219
-167.229
-167.241
-167.253
-167.265
-167.277
-167.29
-167.303
-167.315
-167.327
-167.339
-167.351
-167.362
-167.372
-167.381
-167.39
-167.398
-167.405
-167.41
-167.415
-167.419
-167.421
-167.422
-170.452
-170.451
-170.449
-170.446
-170.441
-170.436
-170.43
-170.423
-170.415
-170.406
-170.397
-170.387
-170.377
-170.366
-170.355
-170.343
-170.332
-170.321
-170.309
-170.298
-170.287
-170.277
-170.267
-170.258
-170.25
-170.242
-170.235
-170.229
-170.224
-170.221
-170.218
-170.216
-170.216
-170.216
-170.218
-170.221
-170.224
-170.229
-170.235
-170.242
-170.25
-170.258
-170.267
-170.277
-170.287
-170.298
-170.309
-170.321
-170.332
-170.343
-170.355
-170.366
-170.377
-170.387
-170.397
-170.406
-170.415
-170.423
-170.43
-170.436
-170.441
-170.446
-170.449
-170.451
-170.452
-173.483
-173.482
-173.48
-173.477
-173.473
-173.469
-173.463
-173.457
-173.449
-173.442
-173.433
-173.424
-173.415
-173.405
-173.395
-173.384
-173.374
-173.364
-173.353
-173.343
-173.334
-173.324
-173.315
-173.307
-173.299
-173.292
-173.286
-173.281
-173.276
-173.273
-173.27
-173.269
-173.268
-173.269
-173.27
-173.273
-173.276
-173.281
-173.286
-173.292
-173.299
-173.307
-173.315
-173.324
-173.334
-173.343
-173.353
-173.364
-173.374
-173.384
-173.395
-173.405
-173.415
-173.424
-173.433
-173.442
-173.449
-173.457
-173.463
-173.469
-173.473
-173.477
-173.48
-173.482
-173.483
-176.515
-176.514
-176.512
-176.51
-176.506
-176.502
-176.497
-176.491
-176.484
-176.477
-176.47
-176.461
-176.453
-176.444
-176.435
-176.425
-176.416
-176.407
-176.397
-176.388
-176.379
-176.371
-176.363
-176.355
-176.348
-176.342
-176.336
-176.332
-176.328
-176.324
-176.322
-176.321
-176.32
-176.321
-176.322
-176.324
-176.328
-176.332
-176.336
-176.342
-176.348
-176.355
-176.363
-176.371
-176.379
-176.388
-176.397
-176.407
-176.416
-176.425
-176.435
-176.444
-176.453
-176.461
-176.47
-176.477
-176.484
-176.491
-176.497
-176.502
-176.506
-176.51
-176.512
-176.514
-176.515
-179.548
-179.547
-179.546
-179.543
-179.54
-179.536
-179.531
-179.526
-179.52
-179.514
-179.507
-179.499
-179.492
-179.483
-179.475
-179.467
-179.458
-179.45
-179.441
-179.433
-179.425
-179.417
-179.41
-179.403
-179.397
-179.391
-179.386
-179.382
-179.378
-179.375
-179.373
-179.372
-179.371
-179.372
-179.373
-179.375
-179.378
-179.382
-179.386
-179.391
-179.397
-179.403
-179.41
-179.417
-179.425
-179.433
-179.441
-179.45
-179.458
-179.467
-179.475
-179.483
-179.492
-179.499
-179.507
-179.514
-179.52
-179.526
-179.531
-179.536
-179.54
-179.543
-179.546
-179.547
-179.548
-182.582
-182.581
-182.58
-182.577
-182.574
-182.571
-182.567
-182.562
-182.556
-182.551
-182.544
-182.538
-182.53
-182.523
-182.516
-182.508
-182.5
-182.492
-182.485
-182.477
-182.47
-182.463
-182.456
-182.45
-182.444
-182.439
-182.435
-182.431
-182.427
-182.425
-182.423
-182.422
-182.421
-182.422
-182.423
-182.425
-182.427
-182.431
-182.435
-182.439
-182.444
-182.45
-182.456
-182.463
-182.47
-182.477
-182.485
-182.492
-182.5
-182.508
-182.516
-182.523
-182.53
-182.538
-182.544
-182.551
-182.556
-182.562
-182.567
-182.571
-182.574
-182.577
-182.58
-182.581
-182.582
-185.616
-185.616
-185.614
-185.612
-185.61
-185.606
-185.603
-185.598
-185.593
-185.588
-185.582
-185.576
-185.57
-185.563
-185.556
-185.549
-185.542
-185.535
-185.528
-185.521
-185.515
-185.508
-185.502
-185.497
-185.492
-185.487
-185.483
-185.479
-185.476
-185.474
-185.472
-185.471
-185.471
-185.471
-185.472
-185.474
-185.476
-185.479
-185.483
-185.487
-185.492
-185.497
-185.502
-185.508
-185.515
-185.521
-185.528
-185.535
-185.542
-185.549
-185.556
-185.563
-185.57
-185.576
-185.582
-185.588
-185.593
-185.598
-185.603
-185.606
-185.61
-185.612
-185.614
-185.616
-185.616
-188.651
-188.651
-188.65
-188.648
-188.645
-188.642
-188.639
-188.635
-188.631
-188.626
-188.62
-188.615
-188.609
-188.603
-188.597
-188.59
-188.584
-188.578
-188.571
-188.565
-188.559
-188.553
-188.548
-188.543
-188.538
-188.534
-188.53
-188.527
-188.524
-188.522
-188.521
-188.52
-188.519
-188.52
-188.521
-188.522
-188.524
-188.527
-188.53
-188.534
-188.538
-188.543
-188.548
-188.553
-188.559
-188.565
-188.571
-188.578
-188.584
-188.59
-188.597
-188.603
-188.609
-188.615
-188.62
-188.626
-188.631
-188.635
-188.639
-188.642
-188.645
-188.648
-188.65
-188.651
-188.651
-191.687
-191.687
-191.686
-191.684
-191.682
-191.679
-191.676
-191.672
-191.668
-191.664
-191.659
-191.654
-191.649
-191.643
-191.638
-191.632
-191.626
-191.62
-191.615
-191.609
-191.604
-191.598
-191.593
-191.589
-191.584
-191.581
-191.577
-191.574
-191.572
-191.57
-191.568
-191.568
-191.567
-191.568
-191.568
-191.57
-191.572
-191.574
-191.577
-191.581
-191.584
-191.589
-191.593
-191.598
-191.604
-191.609
-191.615
-191.62
-191.626
-191.632
-191.638
-191.643
-191.649
-191.654
-191.659
-191.664
-191.668
-191.672
-191.676
-191.679
-191.682
-191.684
-191.686
-191.687
-191.687
-194.724
-194.723
-194.722
-194.721
-194.719
-194.716
-194.713
-194.71
-194.706
-194.702
-194.698
-194.693
-194.689
-194.684
-194.679
-194.673
-194.668
-194.663
-194.658
-194.653
-194.648
-194.643
-194.638
-194.634
-194.63
-194.627
-194.624
-194.621
-194.619
-194.617
-194.616
-194.615
-194.615
-194.615
-194.616
-194.617
-194.619
-194.621
-194.624
-194.627
-194.63
-194.634
-194.638
-194.643
-194.648
-194.653
-194.658
-194.663
-194.668
-194.673
-194.679
-194.684
-194.689
-194.693
-194.698
-194.702
-194.706
-194.71
-194.713
-194.716
-194.719
-194.721
-194.722
-194.723
-194.724
-197.76
-197.76
-197.759
-197.758
-197.756
-197.754
-197.751
-197.748
-197.745
-197.741
-197.737
-197.733
-197.729
-197.724
-197.72
-197.715
-197.71
-197.705
-197.701
-197.696
-197.691
-197.687
-197.683
-197.679
-197.676
-197.673
-197.67
-197.667
-197.665
-197.664
-197.663
-197.662
-197.662
-197.662
-197.663
-197.664
-197.665
-197.667
-197.67
-197.673
-197.676
-197.679
-197.683
-197.687
-197.691
-197.696
-197.701
-197.705
-197.71
-197.715
-197.72
-197.724
-197.729
-197.733
-197.737
-197.741
-197.745
-197.748
-197.751
-197.754
-197.756
-197.758
-197.759
-197.76
-197.76
-200.798
-200.797
-200.796
-200.795
-200.794
-200.792
-200.789
-200.787
-200.784
-200.78
-200.777
-200.773
-200.769
-200.765
-200.761
-200.756
-200.752
-200.748
-200.743
-200.739
-200.735
-200.731
-200.728
-200.724
-200.721
-200.718
-200.715
-200.713
-200.711
-200.71
-200.709
-200.708
-200.708
-200.708
-200.709
-200.71
-200.711
-200.713
-200.715
-200.718
-200.721
-200.724
-200.728
-200.731
-200.735
-200.739
-200.743
-200.748
-200.752
-200.756
-200.761
-200.765
-200.769
-200.773
-200.777
-200.78
-200.784
-200.787
-200.789
-200.792
-200.794
-200.795
-200.796
-200.797
-200.798
-203.835
-203.835
-203.834
-203.833
-203.832
-203.83
-203.828
-203.825
-203.823
-203.82
-203.816
-203.813
-203.809
-203.806
-203.802
-203.798
-203.794
-203.79
-203.786
-203.782
-203.779
-203.775
-203.772
-203.769
-203.766
-203.763
-203.761
-203.759
-203.757
-203.756
-203.755
-203.754
-203.754
-203.754
-203.755
-203.756
-203.757
-203.759
-203.761
-203.763
-203.766
-203.769
-203.772
-203.775
-203.779
-203.782
-203.786
-203.79
-203.794
-203.798
-203.802
-203.806
-203.809
-203.813
-203.816
-203.82
-203.823
-203.825
-203.828
-203.83
-203.832
-203.833
-203.834
-203.835
-203.835
-206.874
-206.873
-206.873
-206.872
-206.87
-206.869
-206.867
-206.864
-206.862
-206.859
-206.856
-206.853
-206.85
-206.846
-206.843
-206.839
-206.836
-206.832
-206.829
-206.825
-206.822
-206.819
-206.816
-206.813
-206.81
-206.808
-206.806
-206.804
-206.802
-206.801
-206.8
-206.8
-206.8
-206.8
-206.8
-206.801
-206.802
-206.804
-206.806
-206.808
-206.81
-206.813
-206.816
-206.819
-206.822
-206.825
-206.829
-206.832
-206.836
-206.839
-206.843
-206.846
-206.85
-206.853
-206.856
-206.859
-206.862
-206.864
-206.867
-206.869
-206.87
-206.872
-206.873
-206.873
-206.874
-209.912
-209.912
-209.911
-209.91
-209.909
-209.907
-209.906
-209.904
-209.901
-209.899
-209.896
-209.893
-209.89
-209.887
-209.884
-209.881
-209.878
-209.875
-209.871
-209.868
-209.865
-209.862
-209.859
-209.857
-209.855
-209.852
-209.85
-209.849
-209.847
-209.846
-209.846
-209.845
-209.845
-209.845
-209.846
-209.846
-209.847
-209.849
-209.85
-209.852
-209.855
-209.857
-209.859
-209.862
-209.865
-209.868
-209.871
-209.875
-209.878
-209.881
-209.884
-209.887
-209.89
-209.893
-209.896
-209.899
-209.901
-209.904
-209.906
-209.907
-209.909
-209.91
-209.911
-209.912
-209.912
-212.951
-212.951
-212.95
-212.949
-212.948
-212.947
-212.945
-212.943
-212.941
-212.939
-212.937
-212.934
-212.931
-212.928
-212.926
-212.923
-212.92
-212.917
-212.914
-212.911
-212.908
-212.906
-212.903
-212.901
-212.899
-212.897
-212.895
-212.893
-212.892
-212.891
-212.89
-212.89
-212.89
-212.89
-212.89
-212.891
-212.892
-212.893
-212.895
-212.897
-212.899
-212.901
-212.903
-212.906
-212.908
-212.911
-212.914
-212.917
-212.92
-212.923
-212.926
-212.928
-212.931
-212.934
-212.937
-212.939
-212.941
-212.943
-212.945
-212.947
-212.948
-212.949
-212.95
-212.951
-212.951
-215.99
-215.99
-215.989
-215.988
-215.987
-215.986
-215.985
-215.983
-215.981
-215.979
-215.977
-215.975
-215.972
-215.97
-215.967
-215.964
-215.962
-215.959
-215.956
-215.954
-215.951
-215.949
-215.947
-215.944
-215.942
-215.941
-215.939
-215.938
-215.937
-215.936
-215.935
-215.935
-215.935
-215.935
-215.935
-215.936
-215.937
-215.938
-215.939
-215.941
-215.942
-215.944
-215.947
-215.949
-215.951
-215.954
-215.956
-215.959
-215.962
-215.964
-215.967
-215.97
-215.972
-215.975
-215.977
-215.979
-215.981
-215.983
-215.985
-215.986
-215.987
-215.988
-215.989
-215.99
-215.99
-219.029
-219.029
-219.029
-219.028
-219.027
-219.026
-219.024
-219.023
-219.021
-219.019
-219.017
-219.015
-219.013
-219.011
-219.008
-219.006
-219.004
-219.001
-218.999
-218.996
-218.994
-218.992
-218.99
-218.988
-218.986
-218.984
-218.983
-218.982
-218.981
-218.98
-218.979
-218.979
-218.979
-218.979
-218.979
-218.98
-218.981
-218.982
-218.983
-218.984
-218.986
-218.988
-218.99
-218.992
-218.994
-218.996
-218.999
-219.001
-219.004
-219.006
-219.008
-219.011
-219.013
-219.015
-219.017
-219.019
-219.021
-219.023
-219.024
-219.026
-219.027
-219.028
-219.029
-219.029
-219.029
-222.069
-222.069
-222.068
-222.068
-222.067
-222.066
-222.065
-222.063
-222.062
-222.06
-222.058
-222.056
-222.054
-222.052
-222.05
-222.048
-222.045
-222.043
-222.041
-222.039
-222.037
-222.035
-222.033
-222.031
-222.03
-222.028
-222.027
-222.026
-222.025
-222.024
-222.024
-222.023
-222.023
-222.023
-222.024
-222.024
-222.025
-222.026
-222.027
-222.028
-222.03
-222.031
-222.033
-222.035
-222.037
-222.039
-222.041
-222.043
-222.045
-222.048
-222.05
-222.052
-222.054
-222.056
-222.058
-222.06
-222.062
-222.063
-222.065
-222.066
-222.067
-222.068
-222.068
-222.069
-222.069
-225.109
-225.108
-225.108
-225.107
-225.107
-225.106
-225.105
-225.103
-225.102
-225.101
-225.099
-225.097
-225.095
-225.093
-225.091
-225.089
-225.087
-225.085
-225.083
-225.081
-225.08
-225.078
-225.076
-225.074
-225.073
-225.072
-225.07
-225.069
-225.069
-225.068
-225.067
-225.067
-225.067
-225.067
-225.067
-225.068
-225.069
-225.069
-225.07
-225.072
-225.073
-225.074
-225.076
-225.078
-225.08
-225.081
-225.083
-225.085
-225.087
-225.089
-225.091
-225.093
-225.095
-225.097
-225.099
-225.101
-225.102
-225.103
-225.105
-225.106
-225.107
-225.107
-225.108
-225.108
-225.109
-228.149
-228.148
-228.148
-228.148
-228.147
-228.146
-228.145
-228.144
-228.143
-228.141
-228.14
-228.138
-228.136
-228.135
-228.133
-228.131
-228.129
-228.127
-228.126
-228.124
-228.122
-228.121
-228.119
-228.117
-228.116
-228.115
-228.114
-228.113
-228.112
-228.112
-228.111
-228.111
-228.111
-228.111
-228.111
-228.112
-228.112
-228.113
-228.114
-228.115
-228.116
-228.117
-228.119
-228.121
-228.122
-228.124
-228.126
-228.127
-228.129
-228.131
-228.133
-228.135
-228.136
-228.138
-228.14
-228.141
-228.143
-228.144
-228.145
-228.146
-228.147
-228.148
-228.148
-228.148
-228.149
-231.189
-231.189
-231.188
-231.188
-231.187
-231.186
-231.186
-231.184
-231.183
-231.182
-231.181
-231.179
-231.178
-231.176
-231.174
-231.173
-231.171
-231.17
-231.168
-231.166
-231.165
-231.163
-231.162
-231.16
-231.159
-231.158
-231.157
-231.156
-231.156
-231.155
-231.155
-231.154
-231.154
-231.154
-231.155
-231.155
-231.156
-231.156
-231.157
-231.158
-231.159
-231.16
-231.162
-231.163
-231.165
-231.166
-231.168
-231.17
-231.171
-231.173
-231.174
-231.176
-231.178
-231.179
-231.181
-231.182
-231.183
-231.184
-231.186
-231.186
-231.187
-231.188
-231.188
-231.189
-231.189
-234.229
-234.229
-234.229
-234.228
-234.228
-234.227
-234.226
-234.225
-234.224
-234.223
-234.222
-234.22
-234.219
-234.218
-234.216
-234.215
-234.213
-234.212
-234.21
-234.209
-234.207
-234.206
-234.204
-234.203
-234.202
-234.201
-234.2
-234.199
-234.199
-234.198
-234.198
-234.198
-234.198
-234.198
-234.198
-234.198
-234.199
-234.199
-234.2
-234.201
-234.202
-234.203
-234.204
-234.206
-234.207
-234.209
-234.21
-234.212
-234.213
-234.215
-234.216
-234.218
-234.219
-234.22
-234.222
-234.223
-234.224
-234.225
-234.226
-234.227
-234.228
-234.228
-234.229
-234.229
-234.229
-237.27
-237.269
-237.269
-237.269
-237.268
-237.268
-237.267
-237.266
-237.265
-237.264
-237.263
-237.262
-237.26
-237.259
-237.258
-237.256
-237.255
-237.254
-237.252
-237.251
-237.25
-237.248
-237.247
-237.246
-237.245
-237.244
-237.243
-237.243
-237.242
-237.242
-237.241
-237.241
-237.241
-237.241
-237.241
-237.242
-237.242
-237.243
-237.243
-237.244
-237.245
-237.246
-237.247
-237.248
-237.25
-237.251
-237.252
-237.254
-237.255
-237.256
-237.258
-237.259
-237.26
-237.262
-237.263
-237.264
-237.265
-237.266
-237.267
-237.268
-237.268
-237.269
-237.269
-237.269
-237.27
-240.31
-240.31
-240.31
-240.31
-240.309
-240.308
-240.308
-240.307
-240.306
-240.305
-240.304
-240.303
-240.302
-240.301
-240.299
-240.298
-240.297
-240.296
-240.294
-240.293
-240.292
-240.291
-240.29
-240.289
-240.288
-240.287
-240.286
-240.286
-240.285
-240.285
-240.284
-240.284
-240.284
-240.284
-240.284
-240.285
-240.285
-240.286
-240.286
-240.287
-240.288
-240.289
-240.29
-240.291
-240.292
-240.293
-240.294
-240.296
-240.297
-240.298
-240.299
-240.301
-240.302
-240.303
-240.304
-240.305
-240.306
-240.307
-240.308
-240.308
-240.309
-240.31
-240.31
-240.31
-240.31
-243.351
-243.351
-243.351
-243.35
-243.35
-243.349
-243.349
-243.348
-243.347
-243.346
-243.345
-243.344
-243.343
-243.342
-243.341
-243.34
-243.339
-243.338
-243.336
-243.335
-243.334
-243.333
-243.332
-243.331
-243.33
-243.33
-243.329
-243.328
-243.328
-243.328
-243.327
-243.327
-243.327
-243.327
-243.327
-243.328
-243.328
-243.328
-243.329
-243.33
-243.33
-243.331
-243.332
-243.333
-243.334
-243.335
-243.336
-243.338
-243.339
-243.34
-243.341
-243.342
-243.343
-243.344
-243.345
-243.346
-243.347
-243.348
-243.349
-243.349
-243.35
-243.35
-243.351
-243.351
-243.351
-246.392
-246.392
-246.392
-246.391
-246.391
-246.39
-246.39
-246.389
-246.388
-246.388
-246.387
-246.386
-246.385
-246.384
-246.383
-246.382
-246.381
-246.38
-246.379
-246.377
-246.376
-246.376
-246.375
-246.374
-246.373
-246.372
-246.372
-246.371
-246.371
-246.37
-246.37
-246.37
-246.37
-246.37
-246.37
-246.37
-246.371
-246.371
-246.372
-246.372
-246.373
-246.374
-246.375
-246.376
-246.376
-246.377
-246.379
-246.38
-246.381
-246.382
-246.383
-246.384
-246.385
-246.386
-246.387
-246.388
-246.388
-246.389
-246.39
-246.39
-246.391
-246.391
-246.392
-246.392
-246.392
-249.433
-249.433
-249.433
-249.432
-249.432
-249.431
-249.431
-249.43
-249.43
-249.429
-249.428
-249.427
-249.426
-249.425
-249.424
-249.423
-249.422
-249.422
-249.421
-249.42
-249.419
-249.418
-249.417
-249.416
-249.416
-249.415
-249.414
-249.414
-249.413
-249.413
-249.413
-249.413
-249.413
-249.413
-249.413
-249.413
-249.413
-249.414
-249.414
-249.415
-249.416
-249.416
-249.417
-249.418
-249.419
-249.42
-249.421
-249.422
-249.422
-249.423
-249.424
-249.425
-249.426
-249.427
-249.428
-249.429
-249.43
-249.43
-249.431
-249.431
-249.432
-249.432
-249.433
-249.433
-249.433
-252.474
-252.474
-252.474
-252.473
-252.473
-252.473
-252.472
-252.472
-252.471
-252.47
-252.469
-252.469
-252.468
-252.467
-252.466
-252.465
-252.464
-252.463
-252.463
-252.462
-252.461
-252.46
-252.459
-252.459
-252.458
-252.457
-252.457
-252.456
-252.456
-252.456
-252.455
-252.455
-252.455
-252.455
-252.455
-252.456
-252.456
-252.456
-252.457
-252.457
-252.458
-252.459
-252.459
-252.46
-252.461
-252.462
-252.463
-252.463
-252.464
-252.465
-252.466
-252.467
-252.468
-252.469
-252.469
-252.47
-252.471
-252.472
-252.472
-252.473
-252.473
-252.473
-252.474
-252.474
-252.474
-255.515
-255.515
-255.515
-255.515
-255.514
-255.514
-255.513
-255.513
-255.512
-255.512
-255.511
-255.51
-255.509
-255.509
-255.508
-255.507
-255.506
-255.505
-255.505
-255.504
-255.503
-255.502
-255.502
-255.501
-255.5
-255.5
-255.499
-255.499
-255.499
-255.498
-255.498
-255.498
-255.498
-255.498
-255.498
-255.498
-255.499
-255.499
-255.499
-255.5
-255.5
-255.501
-255.502
-255.502
-255.503
-255.504
-255.505
-255.505
-255.506
-255.507
-255.508
-255.509
-255.509
-255.51
-255.511
-255.512
-255.512
-255.513
-255.513
-255.514
-255.514
-255.515
-255.515
-255.515
-255.515
-258.556
-258.556
-258.556
-258.556
-258.556
-258.555
-258.555
-258.554
-258.554
-258.553
-258.553
-258.552
-258.551
-258.55
-258.55
-258.549
-258.548
-258.547
-258.547
-258.546
-258.545
-258.544
-258.544
-258.543
-258.543
-258.542
-258.542
-258.541
-258.541
-258.541
-258.541
-258.54
-258.54
-258.54
-258.541
-258.541
-258.541
-258.541
-258.542
-258.542
-258.543
-258.543
-258.544
-258.544
-258.545
-258.546
-258.547
-258.547
-258.548
-258.549
-258.55
-258.55
-258.551
-258.552
-258.553
-258.553
-258.554
-258.554
-258.555
-258.555
-258.556
-258.556
-258.556
-258.556
-258.556
-261.598
-261.597
-261.597
-261.597
-261.597
-261.597
-261.596
-261.596
-261.595
-261.595
-261.594
-261.593
-261.593
-261.592
-261.591
-261.591
-261.59
-261.589
-261.589
-261.588
-261.587
-261.587
-261.586
-261.585
-261.585
-261.584
-261.584
-261.584
-261.583
-261.583
-261.583
-261.583
-261.583
-261.583
-261.583
-261.583
-261.583
-261.584
-261.584
-261.584
-261.585
-261.585
-261.586
-261.587
-261.587
-261.588
-261.589
-261.589
-261.59
-261.591
-261.591
-261.592
-261.593
-261.593
-261.594
-261.595
-261.595
-261.596
-261.596
-261.597
-261.597
-261.597
-261.597
-261.597
-261.598
-264.639
-264.639
-264.639
-264.639
-264.638
-264.638
-264.638
-264.637
-264.637
-264.636
-264.636
-264.635
-264.634
-264.634
-264.633
-264.633
-264.632
-264.631
-264.631
-264.63
-264.629
-264.629
-264.628
-264.628
-264.627
-264.627
-264.626
-264.626
-264.626
-264.625
-264.625
-264.625
-264.625
-264.625
-264.625
-264.625
-264.626
-264.626
-264.626
-264.627
-264.627
-264.628
-264.628
-264.629
-264.629
-264.63
-264.631
-264.631
-264.632
-264.633
-264.633
-264.634
-264.634
-264.635
-264.636
-264.636
-264.637
-264.637
-264.638
-264.638
-264.638
-264.639
-264.639
-264.639
-264.639
-267.68
-267.68
-267.68
-267.68
-267.68
-267.679
-267.679
-267.679
-267.678
-267.678
-267.677
-267.677
-267.676
-267.676
-267.675
-267.674
-267.674
-267.673
-267.673
-267.672
-267.671
-267.671
-267.67
-267.67
-267.669
-267.669
-267.668
-267.668
-267.668
-267.668
-267.668
-267.667
-267.667
-267.667
-267.668
-267.668
-267.668
-267.668
-267.668
-267.669
-267.669
-267.67
-267.67
-267.671
-267.671
-267.672
-267.673
-267.673
-267.674
-267.674
-267.675
-267.676
-267.676
-267.677
-267.677
-267.678
-267.678
-267.679
-267.679
-267.679
-267.68
-267.68
-267.68
-267.68
-267.68
-270.722
-270.722
-270.722
-270.722
-270.721
-270.721
-270.721
-270.72
-270.72
-270.719
-270.719
-270.718
-270.718
-270.717
-270.717
-270.716
-270.716
-270.715
-270.714
-270.714
-270.713
-270.713
-270.712
-270.712
-270.711
-270.711
-270.711
-270.71
-270.71
-270.71
-270.71
-270.71
-270.71
-270.71
-270.71
-270.71
-270.71
-270.71
-270.711
-270.711
-270.711
-270.712
-270.712
-270.713
-270.713
-270.714
-270.714
-270.715
-270.716
-270.716
-270.717
-270.717
-270.718
-270.718
-270.719
-270.719
-270.72
-270.72
-270.721
-270.721
-270.721
-270.722
-270.722
-270.722
-270.722
-273.763
-273.763
-273.763
-273.763
-273.763
-273.763
-273.762
-273.762
-273.762
-273.761
-273.761
-273.76
-273.76
-273.759
-273.759
-273.758
-273.757
-273.757
-273.756
-273.756
-273.755
-273.755
-273.754
-273.754
-273.753
-273.753
-273.753
-273.752
-273.752
-273.752
-273.752
-273.752
-273.752
-273.752
-273.752
-273.752
-273.752
-273.752
-273.753
-273.753
-273.753
-273.754
-273.754
-273.755
-273.755
-273.756
-273.756
-273.757
-273.757
-273.758
-273.759
-273.759
-273.76
-273.76
-273.761
-273.761
-273.762
-273.762
-273.762
-273.763
-273.763
-273.763
-273.763
-273.763
-273.763
-276.805
-276.805
-276.805
-276.805
-276.805
-276.804
-276.804
-276.804
-276.803
-276.803
-276.802
-276.802
-276.801
-276.801
-276.8
-276.8
-276.799
-276.799
-276.798
-276.798
-276.797
-276.797
-276.796
-276.796
-276.796
-276.795
-276.795
-276.795
-276.794
-276.794
-276.794
-276.794
-276.794
-276.794
-276.794
-276.794
-276.794
-276.795
-276.795
-276.795
-276.796
-276.796
-276.796
-276.797
-276.797
-276.798
-276.798
-276.799
-276.799
-276.8
-276.8
-276.801
-276.801
-276.802
-276.802
-276.803
-276.803
-276.804
-276.804
-276.804
-276.805
-276.805
-276.805
-276.805
-276.805
-279.847
-279.847
-279.847
-279.846
-279.846
-279.846
-279.846
-279.845
-279.845
-279.845
-279.844
-279.844
-279.843
-279.843
-279.842
-279.842
-279.841
-279.841
-279.84
-279.84
-279.839
-279.839
-279.838
-279.838
-279.838
-279.837
-279.837
-279.837
-279.836
-279.836
-279.836
-279.836
-279.836
-279.836
-279.836
-279.836
-279.836
-279.837
-279.837
-279.837
-279.838
-279.838
-279.838
-279.839
-279.839
-279.84
-279.84
-279.841
-279.841
-279.842
-279.842
-279.843
-279.843
-279.844
-279.844
-279.845
-279.845
-279.845
-279.846
-279.846
-279.846
-279.846
-279.847
-279.847
-279.847
-282.888
-282.888
-282.888
-282.888
-282.888
-282.888
-282.887
-282.887
-282.887
-282.886
-282.886
-282.886
-282.885
-282.885
-282.884
-282.884
-282.883
-282.883
-282.882
-282.882
-282.881
-282.881
-282.88
-282.88
-282.879
-282.879
-282.879
-282.879
-282.878
-282.878
-282.878
-282.878
-282.878
-282.878
-282.878
-282.878
-282.878
-282.879
-282.879
-282.879
-282.879
-282.88
-282.88
-282.881
-282.881
-282.882
-282.882
-282.883
-282.883
-282.884
-282.884
-282.885
-282.885
-282.886
-282.886
-282.886
-282.887
-282.887
-282.887
-282.888
-282.888
-282.888
-282.888
-282.888
-282.888
-285.93
-285.93
-285.93
-285.93
-285.93
-285.929
-285.929
-285.929
-285.929
-285.928
-285.928
-285.927
-285.927
-285.926
-285.926
-285.925
-285.925
-285.924
-285.924
-285.923
-285.923
-285.923
-285.922
-285.922
-285.921
-285.921
-285.921
-285.921
-285.92
-285.92
-285.92
-285.92
-285.92
-285.92
-285.92
-285.92
-285.92
-285.921
-285.921
-285.921
-285.921
-285.922
-285.922
-285.923
-285.923
-285.923
-285.924
-285.924
-285.925
-285.925
-285.926
-285.926
-285.927
-285.927
-285.928
-285.928
-285.929
-285.929
-285.929
-285.929
-285.93
-285.93
-285.93
-285.93
-285.93
-288.972
-288.972
-288.972
-288.972
-288.972
-288.971
-288.971
-288.971
-288.97
-288.97
-288.97
-288.969
-288.969
-288.968
-288.968
-288.967
-288.967
-288.966
-288.966
-288.965
-288.965
-288.964
-288.964
-288.964
-288.963
-288.963
-288.963
-288.962
-288.962
-288.962
-288.962
-288.962
-288.962
-288.962
-288.962
-288.962
-288.962
-288.962
-288.963
-288.963
-288.963
-288.964
-288.964
-288.964
-288.965
-288.965
-288.966
-288.966
-288.967
-288.967
-288.968
-288.968
-288.969
-288.969
-288.97
-288.97
-288.97
-288.971
-288.971
-288.971
-288.972
-288.972
-288.972
-288.972
-288.972
  0 KSP preconditioned resid norm 2.430791297299e+04 true resid norm 2.430791297299e+04 ||Ae||/||Ax|| 5.951731000641e-05
  1 KSP preconditioned resid norm 5.856729238698e-07 true resid norm 9.372585274370e-07 ||Ae||/||Ax|| 2.294853794960e-15
Linear solve converged due to CONVERGED_RTOL
Process [0]
77.1459
77.1248
77.0825
77.0193
76.9355
76.8316
76.7081
76.5656
76.405
76.2272
76.0333
75.8246
75.6024
75.3683
75.1241
74.8718
74.6134
74.3512
74.0876
73.8252
73.5667
73.3148
73.0724
72.8424
72.6274
72.4302
72.2535
72.0995
71.9703
71.8679
71.7937
71.7487
71.7337
71.7487
71.7937
71.8679
71.9703
72.0995
72.2535
72.4302
72.6274
72.8424
73.0724
73.3148
73.5667
73.8252
74.0876
74.3512
74.6134
74.8718
75.1241
75.3683
75.6024
75.8246
76.0333
76.2272
76.405
76.5656
76.7081
76.8316
76.9355
77.0193
77.0825
77.1248
77.1459
74.1256
74.1043
74.0618
73.9983
73.9141
73.8096
73.6854
73.5421
73.3806
73.2017
73.0065
72.7963
72.5725
72.3367
72.0906
71.8361
71.5754
71.3107
71.0445
70.7794
70.5181
70.2634
70.0181
69.7852
69.5674
69.3677
69.1885
69.0324
68.9014
68.7975
68.7222
68.6766
68.6613
68.6766
68.7222
68.7975
68.9014
69.0324
69.1885
69.3677
69.5674
69.7852
70.0181
70.2634
70.5181
70.7794
71.0445
71.3107
71.5754
71.8361
72.0906
72.3367
72.5725
72.7963
73.0065
73.2017
73.3806
73.5421
73.6854
73.8096
73.9141
73.9983
74.0618
74.1043
74.1256
71.1269
71.1054
71.0625
70.9983
70.9133
70.8077
70.6821
70.5372
70.3738
70.1926
69.995
69.7819
69.5549
69.3155
69.0655
68.8067
68.5414
68.2718
68.0004
67.7298
67.4628
67.2023
66.9512
66.7126
66.4893
66.2842
66.1002
65.9397
65.805
65.6981
65.6205
65.5735
65.5578
65.5735
65.6205
65.6981
65.805
65.9397
66.1002
66.2842
66.4893
66.7126
66.9512
67.2023
67.4628
67.7298
68.0004
68.2718
68.5414
68.8067
69.0655
69.3155
69.5549
69.7819
69.995
70.1926
70.3738
70.5372
70.6821
70.8077
70.9133
70.9983
71.0625
71.1054
71.1269
68.15
68.1282
68.0847
68.0196
67.9333
67.8261
67.6985
67.5512
67.3849
67.2005
66.999
66.7817
66.5499
66.3051
66.0492
65.7841
65.5118
65.2347
64.9554
64.6765
64.4009
64.1317
63.8718
63.6244
63.3926
63.1795
62.988
62.8208
62.6804
62.5688
62.4879
62.4388
62.4224
62.4388
62.4879
62.5688
62.6804
62.8208
62.988
63.1795
63.3926
63.6244
63.8718
64.1317
64.4009
64.6765
64.9554
65.2347
65.5118
65.7841
66.0492
66.3051
66.5499
66.7817
66.999
67.2005
67.3849
67.5512
67.6985
67.8261
67.9333
68.0196
68.0847
68.1282
68.15
65.1953
65.1731
65.1288
65.0625
64.9745
64.8651
64.7349
64.5844
64.4143
64.2256
64.0191
63.7962
63.558
63.3061
63.0424
62.7686
62.487
62.1999
61.9099
61.6198
61.3327
61.0515
60.7796
60.5203
60.2769
60.0528
59.851
59.6747
59.5264
59.4085
59.3229
59.2709
59.2535
59.2709
59.3229
59.4085
59.5264
59.6747
59.851
60.0528
60.2769
60.5203
60.7796
61.0515
61.3327
61.6198
61.9099
62.1999
62.487
62.7686
63.0424
63.3061
63.558
63.7962
64.0191
64.2256
64.4143
64.5844
64.7349
64.8651
64.9745
65.0625
65.1288
65.1731
65.1953
62.2633
62.2406
62.1952
62.1274
62.0373
61.9253
61.7919
61.6375
61.4628
61.2687
61.0561
60.8261
60.58
60.3193
60.0457
59.7611
59.4677
59.168
58.8646
58.5603
58.2583
57.9619
57.6746
57.4
57.1417
56.9033
56.6884
56.5001
56.3416
56.2154
56.1236
56.0679
56.0493
56.0679
56.1236
56.2154
56.3416
56.5001
56.6884
56.9033
57.1417
57.4
57.6746
57.9619
58.2583
58.5603
58.8646
59.168
59.4677
59.7611
60.0457
60.3193
60.58
60.8261
61.0561
61.2687
61.4628
61.6375
61.7919
61.9253
62.0373
62.1274
62.1952
62.2406
62.2633
59.3543
59.331
59.2845
59.2149
59.1224
59.0073
58.8701
58.7111
58.531
58.3306
58.1107
57.8723
57.6168
57.3455
57.0601
56.7625
56.455
56.1399
55.82
55.4984
55.1782
54.8631
54.5568
54.2632
53.9863
53.7301
53.4985
53.2953
53.1239
52.9873
52.8878
52.8274
52.8071
52.8274
52.8878
52.9873
53.1239
53.2953
53.4985
53.7301
53.9863
54.2632
54.5568
54.8631
55.1782
55.4984
55.82
56.1399
56.455
56.7625
57.0601
57.3455
57.6168
57.8723
58.1107
58.3306
58.531
58.7111
58.8701
59.0073
59.1224
59.2149
59.2845
59.331
59.3543
56.4689
56.445
56.3972
56.3256
56.2305
56.1119
55.9704
55.8062
55.62
55.4123
55.184
54.9361
54.6696
54.386
54.0869
53.7741
53.4499
53.1167
52.7773
52.4349
52.093
51.7554
51.426
51.1094
50.8098
50.5318
50.2799
50.0583
49.871
49.7214
49.6123
49.546
49.5238
49.546
49.6123
49.7214
49.871
50.0583
50.2799
50.5318
50.8098
51.1094
51.426
51.7554
52.093
52.4349
52.7773
53.1167
53.4499
53.7741
54.0869
54.386
54.6696
54.9361
55.184
55.4123
55.62
55.8062
55.9704
56.1119
56.2305
56.3256
56.3972
56.445
56.4689
53.6079
53.5833
53.5341
53.4603
53.3622
53.2399
53.0936
52.9237
52.7306
52.5149
52.2773
52.0186
51.7398
51.4423
51.1275
50.7974
50.4539
50.0997
49.7377
49.371
49.0035
48.6391
48.2825
47.9382
47.6114
47.3071
47.0305
46.7865
46.5797
46.4143
46.2935
46.22
46.1953
46.22
46.2935
46.4143
46.5797
46.7865
47.0305
47.3071
47.6114
47.9382
48.2825
48.6391
49.0035
49.371
49.7377
50.0997
50.4539
50.7974
51.1275
51.4423
51.7398
52.0186
52.2773
52.5149
52.7306
52.9237
53.0936
53.2399
53.3622
53.4603
53.5341
53.5833
53.6079
50.7719
50.7466
50.6959
50.6198
50.5185
50.3921
50.2408
50.0647
49.8643
49.6398
49.392
49.1214
48.8291
48.5161
48.1838
47.8341
47.4689
47.0908
46.7027
46.308
45.9107
45.5151
45.1263
44.7493
44.3901
44.0543
43.748
43.4769
43.2465
43.0617
42.9266
42.8443
42.8166
42.8443
42.9266
43.0617
43.2465
43.4769
43.748
44.0543
44.3901
44.7493
45.1263
45.5151
45.9107
46.308
46.7027
47.0908
47.4689
47.8341
48.1838
48.5161
48.8291
49.1214
49.392
49.6398
49.8643
50.0647
50.2408
50.3921
50.5185
50.6198
50.6959
50.7466
50.7719
47.9617
47.9356
47.8834
47.8049
47.7004
47.5698
47.4131
47.2306
47.0223
46.7885
46.5298
46.2464
45.9393
45.6094
45.2579
44.8864
44.497
44.0919
43.6743
43.2477
42.8161
42.3844
41.9579
41.5426
41.1449
40.7716
40.4296
40.1259
39.867
39.6588
39.5062
39.4131
39.3818
39.4131
39.5062
39.6588
39.867
40.1259
40.4296
40.7716
41.1449
41.5426
41.9579
42.3844
42.8161
43.2477
43.6743
44.0919
44.497
44.8864
45.2579
45.6094
45.9393
46.2464
46.5298
46.7885
47.0223
47.2306
47.4131
47.5698
47.7004
47.8049
47.8834
47.9356
47.9617
45.1781
45.1512
45.0974
45.0166
44.9087
44.7738
44.6117
44.4225
44.2061
43.9627
43.6924
43.3956
43.0728
42.7247
42.3523
41.9571
41.5408
41.1059
40.6552
40.1923
39.7217
39.2483
38.7782
38.3179
37.8749
37.457
37.0724
36.7295
36.436
36.1993
36.0254
35.9191
35.8834
35.9191
36.0254
36.1993
36.436
36.7295
37.0724
37.457
37.8749
38.3179
38.7782
39.2483
39.7217
40.1923
40.6552
41.1059
41.5408
41.9571
42.3523
42.7247
43.0728
43.3956
43.6924
43.9627
44.2061
44.4225
44.6117
44.7738
44.9087
45.0166
45.0974
45.1512
45.1781
42.4218
42.3942
42.3389
42.2557
42.1446
42.0054
41.8379
41.642
41.4174
41.1641
40.882
40.5712
40.2319
39.8645
39.4699
39.0491
38.6037
38.1358
37.6484
37.1449
36.63
36.109
35.5884
35.0758
34.5794
34.1086
33.673
33.2827
32.9474
32.6759
32.476
32.3536
32.3123
32.3536
32.476
32.6759
32.9474
33.2827
33.673
34.1086
34.5794
35.0758
35.5884
36.109
36.63
37.1449
37.6484
38.1358
38.6037
39.0491
39.4699
39.8645
40.2319
40.5712
40.882
41.1641
41.4174
41.642
41.8379
42.0054
42.1446
42.2557
42.3389
42.3942
42.4218
39.6937
39.6653
39.6086
39.5232
39.409
39.2657
39.093
38.8905
38.6579
38.3948
38.1008
37.7757
37.4195
37.0321
36.6141
36.166
35.6893
35.1857
34.6578
34.1092
33.5445
32.9693
32.3907
31.817
31.258
30.7243
30.2277
29.7802
29.3939
29.0799
28.8479
28.7055
28.6575
28.7055
28.8479
29.0799
29.3939
29.7802
30.2277
30.7243
31.258
31.817
32.3907
32.9693
33.5445
34.1092
34.6578
35.1857
35.6893
36.166
36.6141
37.0321
37.4195
37.7757
38.1008
38.3948
38.6579
38.8905
39.093
39.2657
39.409
39.5232
39.6086
39.6653
39.6937
36.9943
36.9654
36.9073
36.8199
36.7029
36.5559
36.3784
36.1697
35.9294
35.6568
35.3511
35.0119
34.6386
34.2309
33.7886
33.3122
32.8022
32.2602
31.6883
31.0899
30.4695
29.833
29.1879
28.5435
27.9108
27.3024
26.7325
26.2156
25.7669
25.4005
25.1288
24.9616
24.9052
24.9616
25.1288
25.4005
25.7669
26.2156
26.7325
27.3024
27.9108
28.5435
29.1879
29.833
30.4695
31.0899
31.6883
32.2602
32.8022
33.3122
33.7886
34.2309
34.6386
35.0119
35.3511
35.6568
35.9294
36.1697
36.3784
36.5559
36.7029
36.8199
36.9073
36.9654
36.9943
34.3244
34.295
34.2358
34.1468
34.0274
33.8771
33.6952
33.4811
33.2337
32.9522
32.6356
32.2828
31.8928
31.4647
30.998
30.4923
29.9477
29.3649
28.7458
28.093
27.4109
26.7054
25.9843
25.258
24.5388
23.8416
23.1832
22.5819
22.0564
21.6249
21.3036
21.1053
21.0382
21.1053
21.3036
21.6249
22.0564
22.5819
23.1832
23.8416
24.5388
25.258
25.9843
26.7054
27.4109
28.093
28.7458
29.3649
29.9477
30.4923
30.998
31.4647
31.8928
32.2828
32.6356
32.9522
33.2337
33.4811
33.6952
33.8771
34.0274
34.1468
34.2358
34.295
34.3244
31.6845
31.6547
31.5948
31.5044
31.3832
31.2303
31.045
30.8262
30.5728
30.2834
29.9568
29.5913
29.1855
28.7379
28.247
27.7119
27.1318
26.5067
25.8374
25.126
24.3761
23.5935
22.7862
21.9652
21.1445
20.3414
19.5761
18.8711
18.2504
17.7374
17.3534
17.1156
17.0351
17.1156
17.3534
17.7374
18.2504
18.8711
19.5761
20.3414
21.1445
21.9652
22.7862
23.5935
24.3761
25.126
25.8374
26.5067
27.1318
27.7119
28.247
28.7379
29.1855
29.5913
29.9568
30.2834
30.5728
30.8262
31.045
31.2303
31.3832
31.5044
31.5948
31.6547
31.6845
29.075
29.0449
28.9846
28.8935
28.7711
28.6165
28.4287
28.2064
27.9483
27.6525
27.3174
26.9408
26.5207
26.0548
25.541
24.9772
24.3617
23.6933
22.9717
22.198
21.3746
20.5067
19.602
18.6721
17.7324
16.8028
15.9076
15.0749
14.335
13.7188
13.2548
12.9663
12.8683
12.9663
13.2548
13.7188
14.335
15.0749
15.9076
16.8028
17.7324
18.6721
19.602
20.5067
21.3746
22.198
22.9717
23.6933
24.3617
24.9772
25.541
26.0548
26.5207
26.9408
27.3174
27.6525
27.9483
28.2064
28.4287
28.6165
28.7711
28.8935
28.9846
29.0449
29.075
26.496
26.466
26.4056
26.3144
26.1916
26.0363
25.8473
25.6231
25.3619
25.0617
24.7201
24.3346
23.9024
23.4205
22.8857
22.295
21.6452
20.9339
20.1591
19.3203
18.4184
17.4572
16.4435
15.3889
14.3099
13.2292
12.1758
11.1843
10.2939
9.54553
8.97807
8.62338
8.50265
8.62338
8.97807
9.54553
10.2939
11.1843
12.1758
13.2292
14.3099
15.3889
16.4435
17.4572
18.4184
19.3203
20.1591
20.9339
21.6452
22.295
22.8857
23.4205
23.9024
24.3346
24.7201
25.0617
25.3619
25.6231
25.8473
26.0363
26.1916
26.3144
26.4056
26.466
26.496
23.9476
23.9178
23.8579
23.7673
23.6452
23.4905
23.3018
23.0774
22.8152
22.5128
22.1674
21.7758
21.3346
20.8399
20.2874
19.6727
18.9913
18.2389
17.4116
16.5066
15.5225
14.4608
13.3267
12.1305
10.8892
9.62801
8.38109
7.19123
6.10844
5.18858
4.48524
4.04286
3.89176
4.04286
4.48524
5.18858
6.10844
7.19123
8.38109
9.62801
10.8892
12.1305
13.3267
14.4608
15.5225
16.5066
17.4116
18.2389
18.9913
19.6727
20.2874
20.8399
21.3346
21.7758
22.1674
22.5128
22.8152
23.0774
23.3018
23.4905
23.6452
23.7673
23.8579
23.9178
23.9476
21.4296
21.4003
21.3413
21.2522
21.1319
20.9792
20.7926
20.57
20.3093
20.0075
19.6615
19.2675
18.8212
18.3179
17.7521
17.1181
16.4095
15.62
14.7431
13.7731
12.7054
11.538
10.2729
8.91775
7.48861
6.0123
4.5284
3.08938
1.75751
0.611761
-0.27264
-0.833476
-1.02605
-0.833476
-0.27264
0.611761
1.75751
3.08938
4.5284
6.0123
7.48861
8.91775
10.2729
11.538
12.7054
13.7731
14.7431
15.62
16.4095
17.1181
17.7521
18.3179
18.8212
19.2675
19.6615
20.0075
20.3093
20.57
20.7926
20.9792
21.1319
21.2522
21.3413
21.4003
21.4296
18.9413
18.9128
18.8555
18.7687
18.6514
18.5023
18.3197
18.1015
17.845
17.5472
17.2044
16.8122
16.3657
15.8592
15.2862
14.6392
13.91
13.0898
12.1692
11.1387
9.98952
8.71459
7.31054
5.78017
4.13594
2.40429
0.63013
-1.1213
-2.78245
-4.23049
-5.35926
-6.08401
-6.33523
-6.08401
-5.35926
-4.23049
-2.78245
-1.1213
0.63013
2.40429
4.13594
5.78017
7.31054
8.71459
9.98952
11.1387
12.1692
13.0898
13.91
14.6392
15.2862
15.8592
16.3657
16.8122
17.2044
17.5472
17.845
18.1015
18.3197
18.5023
18.6514
18.7687
18.8555
18.9128
18.9413
16.482
16.4547
16.3996
16.3162
16.2033
16.0595
15.8831
15.6718
15.4228
15.1326
14.7973
14.4121
13.9712
13.4682
12.8954
12.2437
11.5029
10.6617
9.70696
8.62496
7.40131
6.02224
4.47646
2.75822
0.872031
-1.16056
-3.29124
-5.42417
15.4199
15.4193
15.4193
15.4194
15.4194
15.4194
15.4193
15.4193
15.4199
-5.42417
-3.29124
-1.16056
0.872031
2.75822
4.47646
6.02224
7.40131
8.62496
9.70696
10.6617
11.5029
12.2437
12.8954
13.4682
13.9712
14.4121
14.7973
15.1326
15.4228
15.6718
15.8831
16.0595
16.2033
16.3162
16.3996
16.4547
16.482
14.0506
14.0247
13.9726
13.8935
13.7864
13.6499
13.482
13.2805
13.0423
12.7639
12.4409
12.0684
11.6399
11.1482
10.5846
9.93855
9.19801
8.34865
7.37394
6.25503
4.97093
3.4992
1.81753
-0.0931702
-2.24321
-4.62581
15.4129
15.4122
15.4125
15.4124
15.4124
15.4124
15.4124
15.4124
15.4124
15.4124
15.4125
15.4122
15.4129
-4.62581
-2.24321
-0.0931702
1.81753
3.4992
4.97093
6.25503
7.37394
8.34865
9.19801
9.93855
10.5846
11.1482
11.6399
12.0684
12.4409
12.7639
13.0423
13.2805
13.482
13.6499
13.7864
13.8935
13.9726
14.0247
14.0506
11.6455
11.6214
11.5729
11.4993
11.3995
11.2721
11.1151
10.9263
10.7026
10.4403
10.1351
9.78139
9.37278
8.9013
8.35738
7.72945
7.00358
6.16294
5.18738
4.05286
2.73108
1.18935
-0.608833
-2.70151
-5.12231
15.4057
15.4056
15.4054
15.4054
15.4054
15.4054
15.4054
15.4054
15.4054
15.4054
15.4054
15.4054
15.4054
15.4056
15.4057
-5.12231
-2.70151
-0.608833
1.18935
2.73108
4.05286
5.18738
6.16294
7.00358
7.72945
8.35738
8.9013
9.37278
9.78139
10.1351
10.4403
10.7026
10.9263
11.1151
11.2721
11.3995
11.4993
11.5729
11.6214
11.6455
9.26481
9.2429
9.19873
9.13163
9.0406
8.92422
8.78066
8.60757
8.40204
8.16044
7.87832
7.55023
7.1695
6.72794
6.2155
5.61984
4.92569
4.11426
3.16224
2.04086
0.714614
-0.860049
-2.73613
-4.97663
15.398
15.3984
15.3985
15.3984
15.3984
15.3984
15.3984
15.3984
15.3984
15.3984
15.3984
15.3984
15.3984
15.3984
15.3985
15.3984
15.398
-4.97663
-2.73613
-0.860049
0.714614
2.04086
3.16224
4.11426
4.92569
5.61984
6.2155
6.72794
7.1695
7.55023
7.87832
8.16044
8.40204
8.60757
8.78066
8.92422
9.0406
9.13163
9.19873
9.2429
9.26481
6.90644
6.88702
6.84784
6.7883
6.70745
6.60397
6.47616
6.3218
6.13813
5.9217
5.66826
5.37253
5.028
4.62656
4.15816
3.61022
2.96693
2.20834
1.3091
0.236901
-1.04958
-2.60335
-4.49337
15.3907
15.3911
15.3913
15.3914
15.3915
15.3915
15.3915
15.3915
15.3915
15.3915
15.3915
15.3915
15.3915
15.3915
15.3915
15.3914
15.3913
15.3911
15.3907
-4.49337
-2.60335
-1.04958
0.236901
1.3091
2.20834
2.96693
3.61022
4.15816
4.62656
5.028
5.37253
5.66826
5.9217
6.13813
6.3218
6.47616
6.60397
6.70745
6.7883
6.84784
6.88702
6.90644
4.56784
4.5512
4.51764
4.46661
4.39727
4.30845
4.19861
4.06579
3.90748
3.72056
3.50115
3.24441
2.94427
2.59318
2.1816
1.69743
1.12527
0.445244
-0.368405
-1.34944
-2.54233
-4.00519
-5.80938
15.385
15.3845
15.3845
15.3845
15.3845
15.3845
15.3845
15.3845
15.3845
15.3845
15.3845
15.3845
15.3845
15.3845
15.3845
15.3845
15.3845
15.3845
15.385
-5.80938
-4.00519
-2.54233
-1.34944
-0.368405
0.445244
1.12527
1.69743
2.1816
2.59318
2.94427
3.24441
3.50115
3.72056
3.90748
4.06579
4.19861
4.30845
4.39727
4.46661
4.51764
4.5512
4.56784
2.24615
2.23258
2.20518
2.16351
2.10687
2.03427
1.94442
1.83566
1.70588
1.55242
1.37197
1.16034
0.912304
0.621242
0.27874
-0.125983
-0.60687
-1.18214
-1.87592
-2.72064
-3.76093
-5.06104
15.3756
15.3771
15.3774
15.3775
15.3775
15.3775
15.3775
15.3775
15.3775
15.3775
15.3775
15.3775
15.3775
15.3775
15.3775
15.3775
15.3775
15.3775
15.3774
15.3771
15.3756
-5.06104
-3.76093
-2.72064
-1.87592
-1.18214
-0.60687
-0.125983
0.27874
0.621242
0.912304
1.16034
1.37197
1.55242
1.70588
1.83566
1.94442
2.03427
2.10687
2.16351
2.20518
2.23258
2.24615
-0.0617149
-0.0720069
-0.0927791
-0.124377
-0.167335
-0.222401
-0.290568
-0.373116
-0.471674
-0.588296
-0.72557
-0.886755
-1.07597
-1.29846
-1.56093
-1.87205
-2.24315
-2.68918
-3.23015
-3.89322
-4.71568
-5.74865
15.3707
15.3706
15.3706
15.3706
15.3706
15.3706
15.3705
15.3705
15.3705
15.3705
15.3705
15.3705
15.3705
15.3705
15.3705
15.3706
15.3706
15.3706
15.3706
15.3706
15.3707
-5.74865
-4.71568
-3.89322
-3.23015
-2.68918
-2.24315
-1.87205
-1.56093
-1.29846
-1.07597
-0.886755
-0.72557
-0.588296
-0.471674
-0.373116
-0.290568
-0.222401
-0.167335
-0.124377
-0.0927791
-0.0720069
-0.0617149
-2.35911
-2.36595
-2.37975
-2.40073
-2.42924
-2.46576
-2.51095
-2.56563
-2.63088
-2.70804
-2.79882
-2.90538
-3.03046
-3.17756
-3.35119
-3.55722
-3.80334
-4.09981
-4.46039
-4.90395
-5.45665
-6.15579
15.3643
15.3639
15.3638
15.3637
15.3636
15.3636
15.3636
15.3635
15.3635
15.3635
15.3635
15.3635
15.3635
15.3635
15.3636
15.3636
15.3636
15.3637
15.3638
15.3639
15.3643
-6.15579
-5.45665
-4.90395
-4.46039
-4.09981
-3.80334
-3.55722
-3.35119
-3.17756
-3.03046
-2.90538
-2.79882
-2.70804
-2.63088
-2.56563
-2.51095
-2.46576
-2.42924
-2.40073
-2.37975
-2.36595
-2.35911
-4.64955
-4.65283
-4.65942
-4.66943
-4.683
-4.70033
-4.72169
-4.74743
-4.77799
-4.81396
-4.85605
-4.9052
-4.96258
-5.02971
-5.10855
-5.20166
-5.31242
-5.44531
-5.60638
-5.80386
-6.0492
-6.3592
15.3572
15.357
15.3568
15.3567
15.3567
15.3566
15.3566
15.3566
15.3565
15.3565
15.3565
15.3565
15.3565
15.3566
15.3566
15.3566
15.3567
15.3567
15.3568
15.357
15.3572
-6.3592
-6.0492
-5.80386
-5.60638
-5.44531
-5.31242
-5.20166
-5.10855
-5.02971
-4.96258
-4.9052
-4.85605
-4.81396
-4.77799
-4.74743
-4.72169
-4.70033
-4.683
-4.66943
-4.65942
-4.65283
-4.64955
-6.93667
-6.93633
-6.93563
-6.93452
-6.93294
-6.9308
-6.92798
-6.92431
-6.91962
-6.91365
-6.90612
-6.89666
-6.8848
-6.86997
-6.85141
-6.82818
-6.79901
-6.7622
-6.71539
-6.65517
-6.57618
-6.46898
15.3499
15.3499
15.3499
15.3498
15.3497
15.3496
15.3496
15.3496
15.3495
15.3495
15.3495
15.3495
15.3495
15.3496
15.3496
15.3496
15.3497
15.3498
15.3499
15.3499
15.3499
-6.46898
-6.57618
-6.65517
-6.71539
-6.7622
-6.79901
-6.82818
-6.85141
-6.86997
-6.8848
-6.89666
-6.90612
-6.91365
-6.91962
-6.92431
-6.92798
-6.9308
-6.93294
-6.93452
-6.93563
-6.93633
-6.93667
-9.22412
-9.2202
-9.21224
-9.20009
-9.18346
-9.16197
-9.13512
-9.10225
-9.06253
-9.01494
-8.95816
-8.89055
-8.81005
-8.714
-8.59903
-8.46075
-8.29337
-8.08925
-7.83804
-7.52554
-7.13178
-6.62679
15.3428
15.343
15.3429
15.3428
15.3427
15.3426
15.3426
15.3425
15.3425
15.3425
15.3425
15.3425
15.3425
15.3425
15.3426
15.3426
15.3427
15.3428
15.3429
15.343
15.3428
-6.62679
-7.13178
-7.52554
-7.83804
-8.08925
-8.29337
-8.46075
-8.59903
-8.714
-8.81005
-8.89055
-8.95816
-9.01494
-9.06253
-9.10225
-9.13512
-9.16197
-9.18346
-9.20009
-9.21224
-9.2202
-9.22412
-11.5156
-11.5082
-11.4931
-11.4702
-11.4389
-11.3986
-11.3484
-11.2871
-11.2135
-11.1256
-11.0212
-10.8975
-10.7511
-10.5773
-10.3703
-10.1228
-9.82506
-9.46413
-9.02293
-8.47844
-7.80011
-6.94949
15.3363
15.3362
15.336
15.3358
15.3357
15.3356
15.3356
15.3355
15.3355
15.3355
15.3355
15.3355
15.3355
15.3355
15.3356
15.3356
15.3357
15.3358
15.336
15.3362
15.3363
-6.94949
-7.80011
-8.47844
-9.02293
-9.46413
-9.82506
-10.1228
-10.3703
-10.5773
-10.7511
-10.8975
-11.0212
-11.1256
-11.2135
-11.2871
-11.3484
-11.3986
-11.4389
-11.4702
-11.4931
-11.5082
-11.5156
-13.8146
-13.8038
-13.782
-13.7488
-13.7035
-13.6453
-13.5728
-13.4846
-13.3788
-13.2529
-13.1038
-12.9277
-12.7199
-12.4741
-12.1828
-11.836
-11.4209
-10.9205
-10.3127
-9.5673
-8.64299
-7.48092
15.3313
15.3296
15.3291
15.3288
15.3287
15.3286
15.3285
15.3285
15.3284
15.3284
15.3284
15.3284
15.3284
15.3285
15.3285
15.3286
15.3287
15.3288
15.3291
15.3296
15.3313
-7.48092
-8.64299
-9.5673
-10.3127
-10.9205
-11.4209
-11.836
-12.1828
-12.4741
-12.7199
-12.9277
-13.1038
-13.2529
-13.3788
-13.4846
-13.5728
-13.6453
-13.7035
-13.7488
-13.782
-13.8038
-13.8146
-16.1246
-16.1107
-16.0825
-16.0397
-15.9813
-15.9063
-15.8132
-15.7001
-15.5646
-15.4037
-15.2138
-14.9902
-14.7271
-14.4173
-14.0517
-13.6186
-13.1032
-12.4862
-11.7422
-10.8378
-9.72734
-8.3463
-6.59836
15.3216
15.3218
15.3217
15.3216
15.3215
15.3215
15.3214
15.3214
15.3214
15.3214
15.3214
15.3214
15.3214
15.3215
15.3215
15.3216
15.3217
15.3218
15.3216
-6.59836
-8.3463
-9.72734
-10.8378
-11.7422
-12.4862
-13.1032
-13.6186
-14.0517
-14.4173
-14.7271
-14.9902
-15.2138
-15.4037
-15.5646
-15.7001
-15.8132
-15.9063
-15.9813
-16.0397
-16.0825
-16.1107
-16.1246
-18.4487
-18.4319
-18.398
-18.3463
-18.276
-18.1858
-18.0739
-17.9383
-17.7761
-17.5841
-17.358
-17.0927
-16.7818
-16.4172
-15.9891
-15.4848
-14.8887
-14.1806
-13.3347
-12.3177
-11.0865
-9.5859
-7.75108
15.3157
15.3149
15.3147
15.3146
15.3144
15.3144
15.3143
15.3143
15.3143
15.3143
15.3143
15.3143
15.3143
15.3144
15.3144
15.3146
15.3147
15.3149
15.3157
-7.75108
-9.5859
-11.0865
-12.3177
-13.3347
-14.1806
-14.8887
-15.4848
-15.9891
-16.4172
-16.7818
-17.0927
-17.358
-17.5841
-17.7761
-17.9383
-18.0739
-18.1858
-18.276
-18.3463
-18.398
-18.4319
-18.4487
-20.79
-20.7706
-20.7315
-20.6719
-20.591
-20.4872
-20.3588
-20.2034
-20.018
-19.7991
-19.5421
-19.2416
-18.8909
-18.4817
-18.0037
-17.4444
-16.788
-16.015
-15.101
-14.0151
-12.7191
-11.165
-9.2924
-7.01895
15.3074
15.3076
15.3074
15.3073
15.3073
15.3072
15.3072
15.3072
15.3072
15.3072
15.3072
15.3072
15.3073
15.3073
15.3074
15.3076
15.3074
-7.01895
-9.2924
-11.165
-12.7191
-14.0151
-15.101
-16.015
-16.788
-17.4444
-18.0037
-18.4817
-18.8909
-19.2416
-19.5421
-19.7991
-20.018
-20.2034
-20.3588
-20.4872
-20.591
-20.6719
-20.7315
-20.7706
-20.79
-23.1509
-23.1293
-23.0856
-23.0193
-22.9291
-22.8137
-22.6711
-22.4989
-22.294
-22.0527
-21.7704
-21.4415
-21.0594
-20.6159
-20.1009
-19.5025
-18.8057
-17.9927
-17.0416
-15.926
-14.6139
-13.0674
-11.2416
-9.08504
-6.54771
15.301
15.3002
15.3001
15.3001
15.3001
15.3002
15.3002
15.3002
15.3002
15.3002
15.3001
15.3001
15.3001
15.3002
15.301
-6.54771
-9.08504
-11.2416
-13.0674
-14.6139
-15.926
-17.0416
-17.9927
-18.8057
-19.5025
-20.1009
-20.6159
-21.0594
-21.4415
-21.7704
-22.0527
-22.294
-22.4989
-22.6711
-22.8137
-22.9291
-23.0193
-23.0856
-23.1293
-23.1509
-25.5339
-25.5103
-25.4629
-25.3908
-25.2929
-25.1678
-25.0135
-24.8276
-24.6069
-24.3478
-24.0459
-23.6956
-23.2904
-22.8227
-22.283
-21.6603
-20.9414
-20.1106
-19.1495
-18.0364
-16.7469
-15.2534
-13.5266
-11.5382
-9.2671
-6.70836
15.2924
15.2927
15.293
15.293
15.2931
15.2931
15.2932
15.2931
15.2931
15.293
15.293
15.2927
15.2924
-6.70836
-9.2671
-11.5382
-13.5266
-15.2534
-16.7469
-18.0364
-19.1495
-20.1106
-20.9414
-21.6603
-22.283
-22.8227
-23.2904
-23.6956
-24.0459
-24.3478
-24.6069
-24.8276
-25.0135
-25.1678
-25.2929
-25.3908
-25.4629
-25.5103
-25.5339
-27.9408
-27.9157
-27.8651
-27.7884
-27.6843
-27.5516
-27.3881
-27.1915
-26.9589
-26.6866
-26.3705
-26.0052
-25.585
-25.1025
-24.5494
-23.916
-23.1908
-22.3609
-21.4115
-20.3261
-19.0871
-17.6763
-16.0774
-14.2785
-12.2786
-10.0976
-7.79614
15.2854
15.2861
15.2858
15.286
15.2861
15.2862
15.2861
15.286
15.2858
15.2861
15.2854
-7.79614
-10.0976
-12.2786
-14.2785
-16.0774
-17.6763
-19.0871
-20.3261
-21.4115
-22.3609
-23.1908
-23.916
-24.5494
-25.1025
-25.585
-26.0052
-26.3705
-26.6866
-26.9589
-27.1915
-27.3881
-27.5516
-27.6843
-27.7884
-27.8651
-27.9157
-27.9408
-30.3732
-30.347
-30.294
-30.2137
-30.105
-29.9665
-29.7962
-29.592
-29.3511
-29.07
-28.7448
-28.3709
-27.9427
-27.454
-26.8974
-26.2647
-25.5466
-24.7326
-23.8116
-22.7718
-21.6015
-20.2904
-18.8313
-17.2229
-15.4741
-13.6087
-11.6679
-9.69355
-7.80795
15.2782
15.279
15.2792
15.2792
15.2792
15.279
15.2782
-7.80795
-9.69355
-11.6679
-13.6087
-15.4741
-17.2229
-18.8313
-20.2904
-21.6015
-22.7718
-23.8116
-24.7326
-25.5466
-26.2647
-26.8974
-27.454
-27.9427
-28.3709
-28.7448
-29.07
-29.3511
-29.592
-29.7962
-29.9665
-30.105
-30.2137
-30.294
-30.347
-30.3732
-32.8324
-32.8053
-32.7507
-32.6679
-32.5559
-32.4135
-32.2389
-32.0299
-31.784
-31.4982
-31.1687
-30.7916
-30.3619
-29.8743
-29.3227
-28.7003
-27.9997
-27.2131
-26.3324
-25.35
-24.259
-23.0549
-21.7368
-20.3099
-18.788
-17.1965
-15.5739
-13.9727
-12.4752
-11.1754
-10.1759
-9.54592
-9.3407
-9.54592
-10.1759
-11.1754
-12.4752
-13.9727
-15.5739
-17.1965
-18.788
-20.3099
-21.7368
-23.0549
-24.259
-25.35
-26.3324
-27.2131
-27.9997
-28.7003
-29.3227
-29.8743
-30.3619
-30.7916
-31.1687
-31.4982
-31.784
-32.0299
-32.2389
-32.4135
-32.5559
-32.6679
-32.7507
-32.8053
-32.8324
-35.3192
-35.2916
-35.2359
-35.1516
-35.0379
-34.8933
-34.7164
-34.5053
-34.2576
-33.9706
-33.6411
-33.2656
-32.84
-32.3597
-31.8199
-31.2152
-30.5401
-29.789
-28.9566
-28.0384
-27.0314
-25.9351
-24.7528
-23.4934
-22.1727
-20.8159
-19.4582
-18.1465
-16.9416
-15.9112
-15.1226
-14.6279
-14.4612
-14.6279
-15.1226
-15.9112
-16.9416
-18.1465
-19.4582
-20.8159
-22.1727
-23.4934
-24.7528
-25.9351
-27.0314
-28.0384
-28.9566
-29.789
-30.5401
-31.2152
-31.8199
-32.3597
-32.84
-33.2656
-33.6411
-33.9706
-34.2576
-34.5053
-34.7164
-34.8933
-35.0379
-35.1516
-35.2359
-35.2916
-35.3192
-37.8342
-37.8063
-37.7502
-37.6654
-37.551
-37.4059
-37.2288
-37.0178
-36.7711
-36.4861
-36.1603
-35.7905
-35.3735
-34.9056
-34.383
-33.8017
-33.1578
-32.4475
-31.6679
-30.8169
-29.8944
-28.9026
-27.8473
-26.739
-25.5942
-24.4361
-23.2958
-22.212
-21.2308
-20.4015
-19.7709
-19.3768
-19.243
-19.3768
-19.7709
-20.4015
-21.2308
-22.212
-23.2958
-24.4361
-25.5942
-26.739
-27.8473
-28.9026
-29.8944
-30.8169
-31.6679
-32.4475
-33.1578
-33.8017
-34.383
-34.9056
-35.3735
-35.7905
-36.1603
-36.4861
-36.7711
-37.0178
-37.2288
-37.4059
-37.551
-37.6654
-37.7502
-37.8063
-37.8342
-40.3774
-40.3496
-40.2937
-40.2092
-40.0953
-39.9511
-39.7755
-39.5668
-39.3233
-39.0431
-38.724
-38.3634
-37.9587
-37.5071
-37.0057
-36.4518
-35.8427
-35.1765
-34.4517
-33.6682
-32.8278
-31.9345
-30.9955
-30.0217
-29.029
-28.0383
-27.0759
-26.1733
-25.3658
-24.6898
-24.1792
-23.8612
-23.7533
-23.8612
-24.1792
-24.6898
-25.3658
-26.1733
-27.0759
-28.0383
-29.029
-30.0217
-30.9955
-31.9345
-32.8278
-33.6682
-34.4517
-35.1765
-35.8427
-36.4518
-37.0057
-37.5071
-37.9587
-38.3634
-38.724
-39.0431
-39.3233
-39.5668
-39.7755
-39.9511
-40.0953
-40.2092
-40.2937
-40.3496
-40.3774
-42.949
-42.9215
-42.8662
-42.7827
-42.6704
-42.5284
-42.3556
-42.151
-41.9129
-41.6398
-41.3298
-40.9811
-40.5915
-40.1591
-39.6818
-39.1579
-38.5858
-37.9648
-37.2949
-36.5774
-35.815
-35.0129
-34.1789
-33.3237
-32.4619
-31.6118
-30.7954
-30.0381
-29.3672
-28.8101
-28.3918
-28.1323
-28.0443
-28.1323
-28.3918
-28.8101
-29.3672
-30.0381
-30.7954
-31.6118
-32.4619
-33.3237
-34.1789
-35.0129
-35.815
-36.5774
-37.2949
-37.9648
-38.5858
-39.1579
-39.6818
-40.1591
-40.5915
-40.9811
-41.3298
-41.6398
-41.9129
-42.151
-42.3556
-42.5284
-42.6704
-42.7827
-42.8662
-42.9215
-42.949
-45.5487
-45.5216
-45.4674
-45.3855
-45.2756
-45.1368
-44.9683
-44.7691
-44.538
-44.2738
-43.975
-43.6402
-43.2679
-42.8567
-42.4053
-41.9128
-41.3786
-40.8029
-40.1866
-39.5319
-38.8425
-38.1239
-37.3837
-36.6324
-35.8829
-35.1509
-34.4549
-33.8152
-33.2531
-32.7895
-32.4433
-32.2291
-32.1567
-32.2291
-32.4433
-32.7895
-33.2531
-33.8152
-34.4549
-35.1509
-35.8829
-36.6324
-37.3837
-38.1239
-38.8425
-39.5319
-40.1866
-40.8029
-41.3786
-41.9128
-42.4053
-42.8567
-43.2679
-43.6402
-43.975
-44.2738
-44.538
-44.7691
-44.9683
-45.1368
-45.2756
-45.3855
-45.4674
-45.5216
-45.5487
-48.1757
-48.1494
-48.0966
-48.0169
-47.91
-47.7753
-47.6121
-47.4196
-47.1969
-46.943
-46.6568
-46.3374
-45.9837
-45.595
-45.1705
-44.71
-44.2136
-43.6822
-43.1173
-42.5218
-41.8997
-41.2566
-40.6
-39.9393
-39.286
-38.6535
-38.0572
-37.5134
-37.0389
-36.6498
-36.3605
-36.1821
-36.1219
-36.1821
-36.3605
-36.6498
-37.0389
-37.5134
-38.0572
-38.6535
-39.286
-39.9393
-40.6
-41.2566
-41.8997
-42.5218
-43.1173
-43.6822
-44.2136
-44.71
-45.1705
-45.595
-45.9837
-46.3374
-46.6568
-46.943
-47.1969
-47.4196
-47.6121
-47.7753
-47.91
-48.0169
-48.0966
-48.1494
-48.1757
-50.8296
-50.8041
-50.753
-50.676
-50.5727
-50.4428
-50.2857
-50.1008
-49.8874
-49.6448
-49.3724
-49.0694
-48.7353
-48.3696
-47.9724
-47.5437
-47.0842
-46.5954
-46.0792
-45.5387
-44.9782
-44.4031
-43.8204
-43.2387
-42.6679
-42.1195
-41.6062
-41.1412
-40.7379
-40.4088
-40.1651
-40.0152
-39.9646
-40.0152
-40.1651
-40.4088
-40.7379
-41.1412
-41.6062
-42.1195
-42.6679
-43.2387
-43.8204
-44.4031
-44.9782
-45.5387
-46.0792
-46.5954
-47.0842
-47.5437
-47.9724
-48.3696
-48.7353
-49.0694
-49.3724
-49.6448
-49.8874
-50.1008
-50.2857
-50.4428
-50.5727
-50.676
-50.753
-50.8041
-50.8296
-53.5094
-53.4849
-53.4357
-53.3617
-53.2625
-53.1379
-52.9875
-52.8109
-52.6076
-52.3771
-52.119
-51.8329
-51.5188
-51.1764
-50.8061
-50.4086
-49.9847
-49.5363
-49.0657
-48.576
-48.0715
-47.5573
-47.0399
-46.5269
-46.027
-45.5499
-45.1061
-44.7064
-44.3615
-44.0812
-43.8743
-43.7474
-43.7046
-43.7474
-43.8743
-44.0812
-44.3615
-44.7064
-45.1061
-45.5499
-46.027
-46.5269
-47.0399
-47.5573
-48.0715
-48.576
-49.0657
-49.5363
-49.9847
-50.4086
-50.8061
-51.1764
-51.5188
-51.8329
-52.119
-52.3771
-52.6076
-52.8109
-52.9875
-53.1379
-53.2625
-53.3617
-53.4357
-53.4849
-53.5094
-56.2142
-56.1907
-56.1436
-56.0728
-55.9781
-55.8593
-55.716
-55.5481
-55.3553
-55.1373
-54.8939
-54.6251
-54.3309
-54.0115
-53.6676
-53.3001
-52.9102
-52.4998
-52.0715
-51.6284
-51.1745
-50.7148
-50.255
-49.8019
-49.363
-48.9465
-48.5612
-48.216
-47.9193
-47.6792
-47.5024
-47.3941
-47.3577
-47.3941
-47.5024
-47.6792
-47.9193
-48.216
-48.5612
-48.9465
-49.363
-49.8019
-50.255
-50.7148
-51.1745
-51.6284
-52.0715
-52.4998
-52.9102
-53.3001
-53.6676
-54.0115
-54.3309
-54.6251
-54.8939
-55.1373
-55.3553
-55.5481
-55.716
-55.8593
-55.9781
-56.0728
-56.1436
-56.1907
-56.2142
-58.9429
-58.9205
-58.8757
-58.8083
-58.7182
-58.6054
-58.4696
-58.3107
-58.1286
-57.9233
-57.6947
-57.443
-57.1685
-56.8716
-56.5532
-56.2143
-55.8564
-55.4816
-55.0923
-54.6916
-54.2835
-53.8723
-53.4633
-53.0624
-52.6761
-52.3115
-51.9757
-51.6761
-51.4197
-51.2128
-51.0609
-50.968
-50.9367
-50.968
-51.0609
-51.2128
-51.4197
-51.6761
-51.9757
-52.3115
-52.6761
-53.0624
-53.4633
-53.8723
-54.2835
-54.6916
-55.0923
-55.4816
-55.8564
-56.2143
-56.5532
-56.8716
-57.1685
-57.443
-57.6947
-57.9233
-58.1286
-58.3107
-58.4696
-58.6054
-58.7182
-58.8083
-58.8757
-58.9205
-58.9429
-61.6944
-61.6731
-61.6306
-61.5667
-61.4815
-61.3748
-61.2466
-61.0968
-60.9256
-60.7329
-60.519
-60.2842
-60.0288
-59.7536
-59.4595
-59.1478
-58.8199
-58.4781
-58.1246
-57.7626
-57.3955
-57.0275
-56.6633
-56.308
-55.9673
-55.6471
-55.3535
-55.0925
-54.8698
-54.6907
-54.5594
-54.4792
-54.4522
-54.4792
-54.5594
-54.6907
-54.8698
-55.0925
-55.3535
-55.6471
-55.9673
-56.308
-56.6633
-57.0275
-57.3955
-57.7626
-58.1246
-58.4781
-58.8199
-59.1478
-59.4595
-59.7536
-60.0288
-60.2842
-60.519
-60.7329
-60.9256
-61.0968
-61.2466
-61.3748
-61.4815
-61.5667
-61.6306
-61.6731
-61.6944
-64.4674
-64.4474
-64.4072
-64.3469
-64.2665
-64.166
-64.0454
-63.9048
-63.7443
-63.5641
-63.3646
-63.1461
-62.9092
-62.6548
-62.3838
-62.0976
-61.7977
-61.4863
-61.1657
-60.8386
-60.5085
-60.179
-59.8543
-59.5389
-59.2377
-58.9557
-58.6981
-58.4699
-58.2758
-58.1199
-58.0059
-57.9364
-57.913
-57.9364
-58.0059
-58.1199
-58.2758
-58.4699
-58.6981
-58.9557
-59.2377
-59.5389
-59.8543
-60.179
-60.5085
-60.8386
-61.1657
-61.4863
-61.7977
-62.0976
-62.3838
-62.6548
-62.9092
-63.1461
-63.3646
-63.5641
-63.7443
-63.9048
-64.0454
-64.166
-64.2665
-64.3469
-64.4072
-64.4474
-64.4674
-67.2609
-67.242
-67.2042
-67.1475
-67.0719
-66.9776
-66.8645
-66.733
-66.583
-66.415
-66.2294
-66.0267
-65.8075
-65.5727
-65.3235
-65.0612
-64.7873
-64.5039
-64.2132
-63.9178
-63.6209
-63.3256
-63.0358
-62.7554
-62.4885
-62.2396
-62.0129
-61.8127
-61.6428
-61.5067
-61.4073
-61.3467
-61.3264
-61.3467
-61.4073
-61.5067
-61.6428
-61.8127
-62.0129
-62.2396
-62.4885
-62.7554
-63.0358
-63.3256
-63.6209
-63.9178
-64.2132
-64.5039
-64.7873
-65.0612
-65.3235
-65.5727
-65.8075
-66.0267
-66.2294
-66.415
-66.583
-66.733
-66.8645
-66.9776
-67.0719
-67.1475
-67.2042
-67.242
-67.2609
-70.0736
-70.0559
-70.0204
-69.9673
-69.8965
-69.8082
-69.7025
-69.5797
-69.4401
-69.2839
-69.1116
-68.924
-68.7216
-68.5054
-68.2766
-68.0364
-67.7866
-67.5288
-67.2654
-66.9987
-66.7315
-66.4667
-66.2077
-65.958
-65.7212
-65.5009
-65.3009
-65.1247
-64.9755
-64.8562
-64.7691
-64.7162
-64.6984
-64.7162
-64.7691
-64.8562
-64.9755
-65.1247
-65.3009
-65.5009
-65.7212
-65.958
-66.2077
-66.4667
-66.7315
-66.9987
-67.2654
-67.5288
-67.7866
-68.0364
-68.2766
-68.5054
-68.7216
-68.924
-69.1116
-69.2839
-69.4401
-69.5797
-69.7025
-69.8082
-69.8965
-69.9673
-70.0204
-70.0559
-70.0736
-72.9043
-72.8878
-72.8546
-72.8049
-72.7388
-72.6564
-72.558
-72.4437
-72.3139
-72.169
-72.0095
-71.8362
-71.6497
-71.4509
-71.2411
-71.0216
-70.7938
-70.5596
-70.3209
-70.0801
-69.8395
-69.602
-69.3703
-69.1476
-68.937
-68.7417
-68.5648
-68.4092
-68.2778
-68.1729
-68.0964
-68.05
-68.0344
-68.05
-68.0964
-68.1729
-68.2778
-68.4092
-68.5648
-68.7417
-68.937
-69.1476
-69.3703
-69.602
-69.8395
-70.0801
-70.3209
-70.5596
-70.7938
-71.0216
-71.2411
-71.4509
-71.6497
-71.8362
-72.0095
-72.169
-72.3139
-72.4437
-72.558
-72.6564
-72.7388
-72.8049
-72.8546
-72.8878
-72.9043
-75.7519
-75.7365
-75.7055
-75.6592
-75.5977
-75.521
-75.4294
-75.3233
-75.203
-75.0689
-74.9216
-74.7617
-74.5901
-74.4077
-74.2156
-74.0151
-73.8076
-73.5949
-73.3787
-73.1612
-72.9445
-72.7312
-72.5238
-72.3249
-72.1373
-71.9637
-71.8069
-71.6693
-71.5532
-71.4606
-71.3933
-71.3524
-71.3387
-71.3524
-71.3933
-71.4606
-71.5532
-71.6693
-71.8069
-71.9637
-72.1373
-72.3249
-72.5238
-72.7312
-72.9445
-73.1612
-73.3787
-73.5949
-73.8076
-74.0151
-74.2156
-74.4077
-74.5901
-74.7617
-74.9216
-75.0689
-75.203
-75.3233
-75.4294
-75.521
-75.5977
-75.6592
-75.7055
-75.7365
-75.7519
-78.6153
-78.6009
-78.5721
-78.5291
-78.4718
-78.4006
-78.3157
-78.2174
-78.1061
-77.9822
-77.8464
-77.6992
-77.5416
-77.3744
-77.1986
-77.0157
-76.8268
-76.6336
-76.4379
-76.2414
-76.0462
-75.8545
-75.6685
-75.4907
-75.3233
-75.1689
-75.0295
-74.9074
-74.8046
-74.7228
-74.6633
-74.6272
-74.6151
-74.6272
-74.6633
-74.7228
-74.8046
-74.9074
-75.0295
-75.1689
-75.3233
-75.4907
-75.6685
-75.8545
-76.0462
-76.2414
-76.4379
-76.6336
-76.8268
-77.0157
-77.1986
-77.3744
-77.5416
-77.6992
-77.8464
-77.9822
-78.1061
-78.2174
-78.3157
-78.4006
-78.4718
-78.5291
-78.5721
-78.6009
-78.6153
-81.4933
-81.4799
-81.4532
-81.4133
-81.3602
-81.2942
-81.2156
-81.1247
-81.0219
-80.9077
-80.7826
-80.6474
-80.5027
-80.3496
-80.189
-80.0222
-79.8504
-79.675
-79.4977
-79.3202
-79.1443
-78.9719
-78.8051
-78.6458
-78.4963
-78.3586
-78.2345
-78.1261
-78.0348
-77.9623
-77.9096
-77.8776
-77.8669
-77.8776
-77.9096
-77.9623
-78.0348
-78.1261
-78.2345
-78.3586
-78.4963
-78.6458
-78.8051
-78.9719
-79.1443
-79.3202
-79.4977
-79.675
-79.8504
-80.0222
-80.189
-80.3496
-80.5027
-80.6474
-80.7826
-80.9077
-81.0219
-81.1247
-81.2156
-81.2942
-81.3602
-81.4133
-81.4532
-81.4799
-81.4933
-84.3849
-84.3725
-84.3478
-84.3108
-84.2617
-84.2007
-84.128
-84.0441
-83.9494
-83.8442
-83.7292
-83.605
-83.4725
-83.3324
-83.1858
-83.0338
-82.8775
-82.7184
-82.5579
-82.3974
-82.2388
-82.0837
-81.9338
-81.7912
-81.6574
-81.5344
-81.4238
-81.3272
-81.2461
-81.1816
-81.1348
-81.1064
-81.0969
-81.1064
-81.1348
-81.1816
-81.2461
-81.3272
-81.4238
-81.5344
-81.6574
-81.7912
-81.9338
-82.0837
-82.2388
-82.3974
-82.5579
-82.7184
-82.8775
-83.0338
-83.1858
-83.3324
-83.4725
-83.605
-83.7292
-83.8442
-83.9494
-84.0441
-84.128
-84.2007
-84.2617
-84.3108
-84.3478
-84.3725
-84.3849
-87.2891
-87.2776
-87.2548
-87.2206
-87.1752
-87.1189
-87.0519
-86.9746
-86.8874
-86.7907
-86.6851
-86.5712
-86.4499
-86.3219
-86.1881
-86.0497
-85.9076
-85.7632
-85.6178
-85.4728
-85.3297
-85.1901
-85.0554
-84.9274
-84.8076
-84.6976
-84.5988
-84.5126
-84.4403
-84.383
-84.3413
-84.3161
-84.3076
-84.3161
-84.3413
-84.383
-84.4403
-84.5126
-84.5988
-84.6976
-84.8076
-84.9274
-85.0554
-85.1901
-85.3297
-85.4728
-85.6178
-85.7632
-85.9076
-86.0497
-86.1881
-86.3219
-86.4499
-86.5712
-86.6851
-86.7907
-86.8874
-86.9746
-87.0519
-87.1189
-87.1752
-87.2206
-87.2548
-87.2776
-87.2891
-90.2049
-90.1944
-90.1732
-90.1417
-90.0999
-90.048
-89.9863
-89.9151
-89.8349
-89.7461
-89.6493
-89.5451
-89.4341
-89.3172
-89.1952
-89.0692
-88.9401
-88.8091
-88.6774
-88.5463
-88.4172
-88.2913
-88.1702
-88.0553
-87.9478
-87.8493
-87.761
-87.684
-87.6195
-87.5683
-87.5312
-87.5087
-87.5012
-87.5087
-87.5312
-87.5683
-87.6195
-87.684
-87.761
-87.8493
-87.9478
-88.0553
-88.1702
-88.2913
-88.4172
-88.5463
-88.6774
-88.8091
-88.9401
-89.0692
-89.1952
-89.3172
-89.4341
-89.5451
-89.6493
-89.7461
-89.8349
-89.9151
-89.9863
-90.048
-90.0999
-90.1417
-90.1732
-90.1944
-90.2049
-93.1315
-93.1218
-93.1023
-93.0733
-93.0348
-92.987
-92.9303
-92.8649
-92.7913
-92.7098
-92.6211
-92.5257
-92.4243
-92.3176
-92.2065
-92.0918
-91.9745
-91.8557
-91.7364
-91.6179
-91.5013
-91.3878
-91.2788
-91.1755
-91.079
-90.9907
-90.9116
-90.8427
-90.7851
-90.7394
-90.7062
-90.6862
-90.6795
-90.6862
-90.7062
-90.7394
-90.7851
-90.8427
-90.9116
-90.9907
-91.079
-91.1755
-91.2788
-91.3878
-91.5013
-91.6179
-91.7364
-91.8557
-91.9745
-92.0918
-92.2065
-92.3176
-92.4243
-92.5257
-92.6211
-92.7098
-92.7913
-92.8649
-92.9303
-92.987
-93.0348
-93.0733
-93.1023
-93.1218
-93.1315
-96.0681
-96.0591
-96.0412
-96.0144
-95.979
-95.9351
-95.883
-95.823
-95.7555
-95.6809
-95.5997
-95.5125
-95.4198
-95.3225
-95.2213
-95.117
-95.0105
-94.9027
-94.7947
-94.6874
-94.5821
-94.4798
-94.3816
-94.2887
-94.202
-94.1227
-94.0518
-93.9901
-93.9385
-93.8976
-93.868
-93.8501
-93.8441
-93.8501
-93.868
-93.8976
-93.9385
-93.9901
-94.0518
-94.1227
-94.202
-94.2887
-94.3816
-94.4798
-94.5821
-94.6874
-94.7947
-94.9027
-95.0105
-95.117
-95.2213
-95.3225
-95.4198
-95.5125
-95.5997
-95.6809
-95.7555
-95.823
-95.883
-95.9351
-95.979
-96.0144
-96.0412
-96.0591
-96.0681
-99.0137
-99.0055
-98.989
-98.9644
-98.9319
-98.8916
-98.8438
-98.7888
-98.7269
-98.6586
-98.5844
-98.5047
-98.4202
-98.3315
-98.2393
-98.1444
-98.0477
-97.9499
-97.8521
-97.7551
-97.6599
-97.5676
-97.4791
-97.3954
-97.3175
-97.2463
-97.1826
-97.1273
-97.0811
-97.0444
-97.0179
-97.0019
-96.9965
-97.0019
-97.0179
-97.0444
-97.0811
-97.1273
-97.1826
-97.2463
-97.3175
-97.3954
-97.4791
-97.5676
-97.6599
-97.7551
-97.8521
-97.9499
-98.0477
-98.1444
-98.2393
-98.3315
-98.4202
-98.5047
-98.5844
-98.6586
-98.7269
-98.7888
-98.8438
-98.8916
-98.9319
-98.9644
-98.989
-99.0055
-99.0137
-101.968
-101.96
-101.945
-101.923
-101.893
-101.856
-101.812
-101.762
-101.705
-101.642
-101.575
-101.502
-101.425
-101.344
-101.26
-101.174
-101.086
-100.997
-100.909
-100.821
-100.735
-100.652
-100.572
-100.496
-100.426
-100.362
-100.305
-100.255
-100.214
-100.181
-100.157
-100.143
-100.138
-100.143
-100.157
-100.181
-100.214
-100.255
-100.305
-100.362
-100.426
-100.496
-100.572
-100.652
-100.735
-100.821
-100.909
-100.997
-101.086
-101.174
-101.26
-101.344
-101.425
-101.502
-101.575
-101.642
-101.705
-101.762
-101.812
-101.856
-101.893
-101.923
-101.945
-101.96
-101.968
-104.929
-104.923
-104.909
-104.888
-104.861
-104.827
-104.787
-104.741
-104.689
-104.632
-104.57
-104.503
-104.433
-104.359
-104.283
-104.205
-104.125
-104.045
-103.964
-103.885
-103.807
-103.732
-103.66
-103.592
-103.529
-103.471
-103.42
-103.375
-103.338
-103.308
-103.287
-103.274
-103.27
-103.274
-103.287
-103.308
-103.338
-103.375
-103.42
-103.471
-103.529
-103.592
-103.66
-103.732
-103.807
-103.885
-103.964
-104.045
-104.125
-104.205
-104.283
-104.359
-104.433
-104.503
-104.57
-104.632
-104.689
-104.741
-104.787
-104.827
-104.861
-104.888
-104.909
-104.923
-104.929
-107.898
-107.892
-107.879
-107.86
-107.835
-107.804
-107.768
-107.725
-107.678
-107.626
-107.569
-107.509
-107.445
-107.378
-107.308
-107.237
-107.165
-107.092
-107.019
-106.947
-106.877
-106.809
-106.744
-106.683
-106.626
-106.574
-106.527
-106.487
-106.454
-106.427
-106.408
-106.397
-106.393
-106.397
-106.408
-106.427
-106.454
-106.487
-106.527
-106.574
-106.626
-106.683
-106.744
-106.809
-106.877
-106.947
-107.019
-107.092
-107.165
-107.237
-107.308
-107.378
-107.445
-107.509
-107.569
-107.626
-107.678
-107.725
-107.768
-107.804
-107.835
-107.86
-107.879
-107.892
-107.898
-110.874
-110.868
-110.856
-110.839
-110.816
-110.788
-110.754
-110.715
-110.672
-110.625
-110.573
-110.518
-110.46
-110.399
-110.335
-110.271
-110.205
-110.139
-110.073
-110.008
-109.944
-109.883
-109.824
-109.769
-109.717
-109.671
-109.629
-109.593
-109.563
-109.539
-109.522
-109.511
-109.508
-109.511
-109.522
-109.539
-109.563
-109.593
-109.629
-109.671
-109.717
-109.769
-109.824
-109.883
-109.944
-110.008
-110.073
-110.139
-110.205
-110.271
-110.335
-110.399
-110.46
-110.518
-110.573
-110.625
-110.672
-110.715
-110.754
-110.788
-110.816
-110.839
-110.856
-110.868
-110.874
-113.855
-113.849
-113.839
-113.823
-113.802
-113.776
-113.745
-113.71
-113.671
-113.627
-113.58
-113.53
-113.477
-113.422
-113.364
-113.305
-113.246
-113.186
-113.126
-113.067
-113.01
-112.954
-112.901
-112.851
-112.805
-112.762
-112.725
-112.692
-112.665
-112.644
-112.628
-112.619
-112.616
-112.619
-112.628
-112.644
-112.665
-112.692
-112.725
-112.762
-112.805
-112.851
-112.901
-112.954
-113.01
-113.067
-113.126
-113.186
-113.246
-113.305
-113.364
-113.422
-113.477
-113.53
-113.58
-113.627
-113.671
-113.71
-113.745
-113.776
-113.802
-113.823
-113.839
-113.849
-113.855
-116.841
-116.836
-116.827
-116.812
-116.793
-116.769
-116.742
-116.709
-116.673
-116.634
-116.591
-116.545
-116.497
-116.446
-116.394
-116.341
-116.287
-116.232
-116.178
-116.125
-116.073
-116.022
-115.975
-115.929
-115.888
-115.85
-115.816
-115.786
-115.762
-115.743
-115.729
-115.72
-115.717
-115.72
-115.729
-115.743
-115.762
-115.786
-115.816
-115.85
-115.888
-115.929
-115.975
-116.022
-116.073
-116.125
-116.178
-116.232
-116.287
-116.341
-116.394
-116.446
-116.497
-116.545
-116.591
-116.634
-116.673
-116.709
-116.742
-116.769
-116.793
-116.812
-116.827
-116.836
-116.841
-119.833
-119.828
-119.82
-119.806
-119.789
-119.767
-119.742
-119.712
-119.68
-119.644
-119.605
-119.563
-119.519
-119.473
-119.426
-119.377
-119.328
-119.279
-119.23
-119.181
-119.134
-119.089
-119.045
-119.005
-118.967
-118.932
-118.902
-118.875
-118.853
-118.836
-118.823
-118.816
-118.813
-118.816
-118.823
-118.836
-118.853
-118.875
-118.902
-118.932
-118.967
-119.005
-119.045
-119.089
-119.134
-119.181
-119.23
-119.279
-119.328
-119.377
-119.426
-119.473
-119.519
-119.563
-119.605
-119.644
-119.68
-119.712
-119.742
-119.767
-119.789
-119.806
-119.82
-119.828
-119.833
-122.829
-122.825
-122.817
-122.805
-122.789
-122.769
-122.746
-122.719
-122.689
-122.656
-122.621
-122.583
-122.543
-122.501
-122.458
-122.414
-122.37
-122.325
-122.28
-122.237
-122.194
-122.153
-122.113
-122.077
-122.043
-122.012
-121.984
-121.96
-121.94
-121.924
-121.913
-121.906
-121.904
-121.906
-121.913
-121.924
-121.94
-121.96
-121.984
-122.012
-122.043
-122.077
-122.113
-122.153
-122.194
-122.237
-122.28
-122.325
-122.37
-122.414
-122.458
-122.501
-122.543
-122.583
-122.621
-122.656
-122.689
-122.719
-122.746
-122.769
-122.789
-122.805
-122.817
-122.825
-122.829
-125.829
-125.825
-125.818
-125.807
-125.793
-125.775
-125.753
-125.729
-125.702
-125.672
-125.64
-125.605
-125.569
-125.531
-125.492
-125.452
-125.411
-125.371
-125.33
-125.291
-125.252
-125.215
-125.179
-125.146
-125.115
-125.087
-125.062
-125.041
-125.023
-125.008
-124.998
-124.992
-124.99
-124.992
-124.998
-125.008
-125.023
-125.041
-125.062
-125.087
-125.115
-125.146
-125.179
-125.215
-125.252
-125.291
-125.33
-125.371
-125.411
-125.452
-125.492
-125.531
-125.569
-125.605
-125.64
-125.672
-125.702
-125.729
-125.753
-125.775
-125.793
-125.807
-125.818
-125.825
-125.829
-128.833
-128.83
-128.823
-128.813
-128.8
-128.783
-128.764
-128.742
-128.717
-128.69
-128.66
-128.629
-128.596
-128.562
-128.526
-128.49
-128.453
-128.416
-128.38
-128.344
-128.309
-128.275
-128.243
-128.213
-128.185
-128.159
-128.137
-128.118
-128.101
-128.088
-128.079
-128.074
-128.072
-128.074
-128.079
-128.088
-128.101
-128.118
-128.137
-128.159
-128.185
-128.213
-128.243
-128.275
-128.309
-128.344
-128.38
-128.416
-128.453
-128.49
-128.526
-128.562
-128.596
-128.629
-128.66
-128.69
-128.717
-128.742
-128.764
-128.783
-128.8
-128.813
-128.823
-128.83
-128.833
-131.841
-131.837
-131.831
-131.822
-131.81
-131.795
-131.778
-131.757
-131.735
-131.71
-131.683
-131.655
-131.625
-131.593
-131.561
-131.528
-131.495
-131.461
-131.428
-131.396
-131.364
-131.333
-131.304
-131.277
-131.252
-131.229
-131.209
-131.191
-131.176
-131.165
-131.157
-131.151
-131.15
-131.151
-131.157
-131.165
-131.176
-131.191
-131.209
-131.229
-131.252
-131.277
-131.304
-131.333
-131.364
-131.396
-131.428
-131.461
-131.495
-131.528
-131.561
-131.593
-131.625
-131.655
-131.683
-131.71
-131.735
-131.757
-131.778
-131.795
-131.81
-131.822
-131.831
-131.837
-131.841
-134.851
-134.848
-134.843
-134.834
-134.823
-134.81
-134.794
-134.775
-134.755
-134.732
-134.708
-134.682
-134.655
-134.626
-134.597
-134.567
-134.537
-134.507
-134.476
-134.447
-134.418
-134.391
-134.364
-134.34
-134.317
-134.296
-134.278
-134.262
-134.248
-134.238
-134.23
-134.226
-134.224
-134.226
-134.23
-134.238
-134.248
-134.262
-134.278
-134.296
-134.317
-134.34
-134.364
-134.391
-134.418
-134.447
-134.476
-134.507
-134.537
-134.567
-134.597
-134.626
-134.655
-134.682
-134.708
-134.732
-134.755
-134.775
-134.794
-134.81
-134.823
-134.834
-134.843
-134.848
-134.851
-137.864
-137.862
-137.857
-137.849
-137.839
-137.827
-137.812
-137.796
-137.777
-137.756
-137.734
-137.711
-137.686
-137.66
-137.633
-137.606
-137.579
-137.551
-137.524
-137.497
-137.471
-137.446
-137.422
-137.4
-137.379
-137.361
-137.344
-137.33
-137.318
-137.308
-137.301
-137.297
-137.296
-137.297
-137.301
-137.308
-137.318
-137.33
-137.344
-137.361
-137.379
-137.4
-137.422
-137.446
-137.471
-137.497
-137.524
-137.551
-137.579
-137.606
-137.633
-137.66
-137.686
-137.711
-137.734
-137.756
-137.777
-137.796
-137.812
-137.827
-137.839
-137.849
-137.857
-137.862
-137.864
-140.88
-140.878
-140.873
-140.867
-140.857
-140.846
-140.833
-140.818
-140.801
-140.782
-140.762
-140.741
-140.718
-140.695
-140.67
-140.646
-140.621
-140.596
-140.571
-140.547
-140.523
-140.501
-140.479
-140.459
-140.44
-140.423
-140.408
-140.395
-140.384
-140.376
-140.37
-140.366
-140.365
-140.366
-140.37
-140.376
-140.384
-140.395
-140.408
-140.423
-140.44
-140.459
-140.479
-140.501
-140.523
-140.547
-140.571
-140.596
-140.621
-140.646
-140.67
-140.695
-140.718
-140.741
-140.762
-140.782
-140.801
-140.818
-140.833
-140.846
-140.857
-140.867
-140.873
-140.878
-140.88
-143.899
-143.897
-143.892
-143.886
-143.878
-143.868
-143.856
-143.842
-143.826
-143.809
-143.791
-143.772
-143.751
-143.73
-143.708
-143.685
-143.663
-143.64
-143.618
-143.596
-143.574
-143.554
-143.534
-143.516
-143.499
-143.484
-143.47
-143.458
-143.449
-143.441
-143.435
-143.432
-143.431
-143.432
-143.435
-143.441
-143.449
-143.458
-143.47
-143.484
-143.499
-143.516
-143.534
-143.554
-143.574
-143.596
-143.618
-143.64
-143.663
-143.685
-143.708
-143.73
-143.751
-143.772
-143.791
-143.809
-143.826
-143.842
-143.856
-143.868
-143.878
-143.886
-143.892
-143.897
-143.899
-146.919
-146.917
-146.913
-146.908
-146.9
-146.891
-146.88
-146.867
-146.853
-146.838
-146.821
-146.804
-146.785
-146.766
-146.746
-146.725
-146.705
-146.684
-146.664
-146.644
-146.625
-146.606
-146.588
-146.572
-146.557
-146.543
-146.53
-146.52
-146.511
-146.504
-146.499
-146.496
-146.495
-146.496
-146.499
-146.504
-146.511
-146.52
-146.53
-146.543
-146.557
-146.572
-146.588
-146.606
-146.625
-146.644
-146.664
-146.684
-146.705
-146.725
-146.746
-146.766
-146.785
-146.804
-146.821
-146.838
-146.853
-146.867
-146.88
-146.891
-146.9
-146.908
-146.913
-146.917
-146.919
-149.942
-149.94
-149.936
-149.931
-149.924
-149.916
-149.906
-149.895
-149.882
-149.868
-149.853
-149.837
-149.82
-149.802
-149.784
-149.766
-149.747
-149.728
-149.71
-149.692
-149.674
-149.657
-149.641
-149.626
-149.613
-149.6
-149.589
-149.579
-149.571
-149.565
-149.56
-149.557
-149.557
-149.557
-149.56
-149.565
-149.571
-149.579
-149.589
-149.6
-149.613
-149.626
-149.641
-149.657
-149.674
-149.692
-149.71
-149.728
-149.747
-149.766
-149.784
-149.802
-149.82
-149.837
-149.853
-149.868
-149.882
-149.895
-149.906
-149.916
-149.924
-149.931
-149.936
-149.94
-149.942
-152.966
-152.964
-152.961
-152.956
-152.95
-152.943
-152.933
-152.923
-152.911
-152.899
-152.885
-152.87
-152.855
-152.839
-152.823
-152.806
-152.789
-152.772
-152.755
-152.739
-152.723
-152.708
-152.693
-152.68
-152.667
-152.656
-152.646
-152.637
-152.63
-152.624
-152.62
-152.617
-152.616
-152.617
-152.62
-152.624
-152.63
-152.637
-152.646
-152.656
-152.667
-152.68
-152.693
-152.708
-152.723
-152.739
-152.755
-152.772
-152.789
-152.806
-152.823
-152.839
-152.855
-152.87
-152.885
-152.899
-152.911
-152.923
-152.933
-152.943
-152.95
-152.956
-152.961
-152.964
-152.966
-155.992
-155.99
-155.987
-155.983
-155.977
-155.97
-155.962
-155.953
-155.942
-155.931
-155.918
-155.905
-155.891
-155.877
-155.862
-155.846
-155.831
-155.816
-155.801
-155.786
-155.771
-155.758
-155.744
-155.732
-155.721
-155.71
-155.701
-155.693
-155.687
-155.681
-155.678
-155.675
-155.675
-155.675
-155.678
-155.681
-155.687
-155.693
-155.701
-155.71
-155.721
-155.732
-155.744
-155.758
-155.771
-155.786
-155.801
-155.816
-155.831
-155.846
-155.862
-155.877
-155.891
-155.905
-155.918
-155.931
-155.942
-155.953
-155.962
-155.97
-155.977
-155.983
-155.987
-155.99
-155.992
-159.019
-159.018
-159.015
-159.011
-159.006
-159
-158.992
-158.984
-158.974
-158.964
-158.952
-158.94
-158.928
-158.914
-158.901
-158.887
-158.873
-158.859
-158.846
-158.832
-158.819
-158.806
-158.795
-158.783
-158.773
-158.764
-158.755
-158.748
-158.742
-158.738
-158.734
-158.732
-158.731
-158.732
-158.734
-158.738
-158.742
-158.748
-158.755
-158.764
-158.773
-158.783
-158.795
-158.806
-158.819
-158.832
-158.846
-158.859
-158.873
-158.887
-158.901
-158.914
-158.928
-158.94
-158.952
-158.964
-158.974
-158.984
-158.992
-159
-159.006
-159.011
-159.015
-159.018
-159.019
-162.048
-162.047
-162.044
-162.041
-162.036
-162.03
-162.023
-162.016
-162.007
-161.997
-161.987
-161.976
-161.965
-161.953
-161.94
-161.928
-161.915
-161.903
-161.89
-161.878
-161.866
-161.855
-161.844
-161.834
-161.824
-161.816
-161.808
-161.802
-161.797
-161.792
-161.789
-161.787
-161.787
-161.787
-161.789
-161.792
-161.797
-161.802
-161.808
-161.816
-161.824
-161.834
-161.844
-161.855
-161.866
-161.878
-161.89
-161.903
-161.915
-161.928
-161.94
-161.953
-161.965
-161.976
-161.987
-161.997
-162.007
-162.016
-162.023
-162.03
-162.036
-162.041
-162.044
-162.047
-162.048
-165.078
-165.077
-165.074
-165.071
-165.067
-165.062
-165.055
-165.048
-165.04
-165.032
-165.022
-165.013
-165.002
-164.991
-164.98
-164.969
-164.957
-164.946
-164.935
-164.924
-164.913
-164.902
-164.893
-164.883
-164.875
-164.867
-164.86
-164.855
-164.85
-164.846
-164.843
-164.841
-164.841
-164.841
-164.843
-164.846
-164.85
-164.855
-164.86
-164.867
-164.875
-164.883
-164.893
-164.902
-164.913
-164.924
-164.935
-164.946
-164.957
-164.969
-164.98
-164.991
-165.002
-165.013
-165.022
-165.032
-165.04
-165.048
-165.055
-165.062
-165.067
-165.071
-165.074
-165.077
-165.078
-168.109
-168.108
-168.106
-168.103
-168.099
-168.094
-168.088
-168.082
-168.075
-168.067
-168.058
-168.049
-168.04
-168.03
-168.02
-168.01
-167.999
-167.989
-167.979
-167.969
-167.959
-167.95
-167.941
-167.932
-167.925
-167.918
-167.912
-167.906
-167.902
-167.898
-167.896
-167.894
-167.894
-167.894
-167.896
-167.898
-167.902
-167.906
-167.912
-167.918
-167.925
-167.932
-167.941
-167.95
-167.959
-167.969
-167.979
-167.989
-167.999
-168.01
-168.02
-168.03
-168.04
-168.049
-168.058
-168.067
-168.075
-168.082
-168.088
-168.094
-168.099
-168.103
-168.106
-168.108
-168.109
-171.141
-171.14
-171.138
-171.135
-171.132
-171.127
-171.122
-171.116
-171.11
-171.103
-171.095
-171.087
-171.078
-171.069
-171.06
-171.051
-171.041
-171.032
-171.023
-171.014
-171.005
-170.996
-170.988
-170.981
-170.974
-170.967
-170.962
-170.957
-170.953
-170.95
-170.947
-170.946
-170.946
-170.946
-170.947
-170.95
-170.953
-170.957
-170.962
-170.967
-170.974
-170.981
-170.988
-170.996
-171.005
-171.014
-171.023
-171.032
-171.041
-171.051
-171.06
-171.069
-171.078
-171.087
-171.095
-171.103
-171.11
-171.116
-171.122
-171.127
-171.132
-171.135
-171.138
-171.14
-171.141
-174.173
-174.173
-174.171
-174.169
-174.165
-174.161
-174.157
-174.152
-174.146
-174.139
-174.132
-174.125
-174.117
-174.109
-174.1
-174.092
-174.083
-174.075
-174.066
-174.058
-174.05
-174.042
-174.035
-174.028
-174.022
-174.016
-174.011
-174.007
-174.003
-174
-173.998
-173.997
-173.997
-173.997
-173.998
-174
-174.003
-174.007
-174.011
-174.016
-174.022
-174.028
-174.035
-174.042
-174.05
-174.058
-174.066
-174.075
-174.083
-174.092
-174.1
-174.109
-174.117
-174.125
-174.132
-174.139
-174.146
-174.152
-174.157
-174.161
-174.165
-174.169
-174.171
-174.173
-174.173
-177.207
-177.206
-177.205
-177.203
-177.2
-177.196
-177.192
-177.187
-177.182
-177.176
-177.17
-177.163
-177.156
-177.148
-177.141
-177.133
-177.125
-177.118
-177.11
-177.103
-177.095
-177.088
-177.082
-177.075
-177.07
-177.065
-177.06
-177.056
-177.053
-177.05
-177.048
-177.047
-177.047
-177.047
-177.048
-177.05
-177.053
-177.056
-177.06
-177.065
-177.07
-177.075
-177.082
-177.088
-177.095
-177.103
-177.11
-177.118
-177.125
-177.133
-177.141
-177.148
-177.156
-177.163
-177.17
-177.176
-177.182
-177.187
-177.192
-177.196
-177.2
-177.203
-177.205
-177.206
-177.207
-180.242
-180.241
-180.24
-180.238
-180.235
-180.232
-180.228
-180.224
-180.219
-180.213
-180.208
-180.201
-180.195
-180.188
-180.181
-180.174
-180.167
-180.16
-180.153
-180.147
-180.14
-180.134
-180.128
-180.122
-180.117
-180.112
-180.108
-180.104
-180.101
-180.099
-180.097
-180.096
-180.096
-180.096
-180.097
-180.099
-180.101
-180.104
-180.108
-180.112
-180.117
-180.122
-180.128
-180.134
-180.14
-180.147
-180.153
-180.16
-180.167
-180.174
-180.181
-180.188
-180.195
-180.201
-180.208
-180.213
-180.219
-180.224
-180.228
-180.232
-180.235
-180.238
-180.24
-180.241
-180.242
-183.277
-183.276
-183.275
-183.273
-183.271
-183.268
-183.264
-183.26
-183.256
-183.251
-183.246
-183.24
-183.234
-183.228
-183.222
-183.216
-183.209
-183.203
-183.197
-183.191
-183.185
-183.179
-183.173
-183.168
-183.164
-183.159
-183.156
-183.152
-183.15
-183.147
-183.146
-183.145
-183.145
-183.145
-183.146
-183.147
-183.15
-183.152
-183.156
-183.159
-183.164
-183.168
-183.173
-183.179
-183.185
-183.191
-183.197
-183.203
-183.209
-183.216
-183.222
-183.228
-183.234
-183.24
-183.246
-183.251
-183.256
-183.26
-183.264
-183.268
-183.271
-183.273
-183.275
-183.276
-183.277
-186.313
-186.312
-186.311
-186.309
-186.307
-186.304
-186.301
-186.298
-186.294
-186.289
-186.284
-186.279
-186.274
-186.269
-186.263
-186.257
-186.251
-186.246
-186.24
-186.234
-186.229
-186.224
-186.219
-186.214
-186.21
-186.206
-186.203
-186.2
-186.197
-186.195
-186.194
-186.193
-186.193
-186.193
-186.194
-186.195
-186.197
-186.2
-186.203
-186.206
-186.21
-186.214
-186.219
-186.224
-186.229
-186.234
-186.24
-186.246
-186.251
-186.257
-186.263
-186.269
-186.274
-186.279
-186.284
-186.289
-186.294
-186.298
-186.301
-186.304
-186.307
-186.309
-186.311
-186.312
-186.313
-189.349
-189.348
-189.347
-189.346
-189.344
-189.342
-189.339
-189.335
-189.332
-189.328
-189.323
-189.319
-189.314
-189.309
-189.304
-189.299
-189.293
-189.288
-189.283
-189.278
-189.273
-189.268
-189.264
-189.26
-189.256
-189.252
-189.249
-189.246
-189.244
-189.242
-189.241
-189.24
-189.24
-189.24
-189.241
-189.242
-189.244
-189.246
-189.249
-189.252
-189.256
-189.26
-189.264
-189.268
-189.273
-189.278
-189.283
-189.288
-189.293
-189.299
-189.304
-189.309
-189.314
-189.319
-189.323
-189.328
-189.332
-189.335
-189.339
-189.342
-189.344
-189.346
-189.347
-189.348
-189.349
-192.386
-192.385
-192.384
-192.383
-192.381
-192.379
-192.376
-192.373
-192.37
-192.367
-192.363
-192.358
-192.354
-192.35
-192.345
-192.34
-192.335
-192.331
-192.326
-192.321
-192.317
-192.312
-192.308
-192.305
-192.301
-192.298
-192.295
-192.293
-192.291
-192.289
-192.288
-192.287
-192.287
-192.287
-192.288
-192.289
-192.291
-192.293
-192.295
-192.298
-192.301
-192.305
-192.308
-192.312
-192.317
-192.321
-192.326
-192.331
-192.335
-192.34
-192.345
-192.35
-192.354
-192.358
-192.363
-192.367
-192.37
-192.373
-192.376
-192.379
-192.381
-192.383
-192.384
-192.385
-192.386
-195.423
-195.423
-195.422
-195.421
-195.419
-195.417
-195.415
-195.412
-195.409
-195.406
-195.402
-195.398
-195.394
-195.39
-195.386
-195.382
-195.377
-195.373
-195.369
-195.365
-195.36
-195.357
-195.353
-195.349
-195.346
-195.343
-195.341
-195.339
-195.337
-195.335
-195.334
-195.334
-195.333
-195.334
-195.334
-195.335
-195.337
-195.339
-195.341
-195.343
-195.346
-195.349
-195.353
-195.357
-195.36
-195.365
-195.369
-195.373
-195.377
-195.382
-195.386
-195.39
-195.394
-195.398
-195.402
-195.406
-195.409
-195.412
-195.415
-195.417
-195.419
-195.421
-195.422
-195.423
-195.423
-198.461
-198.46
-198.46
-198.459
-198.457
-198.455
-198.453
-198.451
-198.448
-198.445
-198.442
-198.438
-198.435
-198.431
-198.427
-198.423
-198.419
-198.415
-198.411
-198.408
-198.404
-198.4
-198.397
-198.394
-198.391
-198.388
-198.386
-198.384
-198.382
-198.381
-198.38
-198.38
-198.379
-198.38
-198.38
-198.381
-198.382
-198.384
-198.386
-198.388
-198.391
-198.394
-198.397
-198.4
-198.404
-198.408
-198.411
-198.415
-198.419
-198.423
-198.427
-198.431
-198.435
-198.438
-198.442
-198.445
-198.448
-198.451
-198.453
-198.455
-198.457
-198.459
-198.46
-198.46
-198.461
-201.499
-201.499
-201.498
-201.497
-201.496
-201.494
-201.492
-201.49
-201.487
-201.485
-201.482
-201.478
-201.475
-201.472
-201.468
-201.465
-201.461
-201.458
-201.454
-201.451
-201.447
-201.444
-201.441
-201.438
-201.436
-201.433
-201.431
-201.429
-201.428
-201.427
-201.426
-201.425
-201.425
-201.425
-201.426
-201.427
-201.428
-201.429
-201.431
-201.433
-201.436
-201.438
-201.441
-201.444
-201.447
-201.451
-201.454
-201.458
-201.461
-201.465
-201.468
-201.472
-201.475
-201.478
-201.482
-201.485
-201.487
-201.49
-201.492
-201.494
-201.496
-201.497
-201.498
-201.499
-201.499
-204.537
-204.537
-204.537
-204.536
-204.534
-204.533
-204.531
-204.529
-204.527
-204.524
-204.522
-204.519
-204.516
-204.513
-204.51
-204.506
-204.503
-204.5
-204.497
-204.494
-204.491
-204.488
-204.485
-204.482
-204.48
-204.478
-204.476
-204.474
-204.473
-204.472
-204.471
-204.47
-204.47
-204.47
-204.471
-204.472
-204.473
-204.474
-204.476
-204.478
-204.48
-204.482
-204.485
-204.488
-204.491
-204.494
-204.497
-204.5
-204.503
-204.506
-204.51
-204.513
-204.516
-204.519
-204.522
-204.524
-204.527
-204.529
-204.531
-204.533
-204.534
-204.536
-204.537
-204.537
-204.537
-207.576
-207.576
-207.575
-207.575
-207.573
-207.572
-207.57
-207.569
-207.567
-207.564
-207.562
-207.559
-207.557
-207.554
-207.551
-207.548
-207.545
-207.542
-207.539
-207.536
-207.534
-207.531
-207.528
-207.526
-207.524
-207.522
-207.52
-207.519
-207.517
-207.517
-207.516
-207.515
-207.515
-207.515
-207.516
-207.517
-207.517
-207.519
-207.52
-207.522
-207.524
-207.526
-207.528
-207.531
-207.534
-207.536
-207.539
-207.542
-207.545
-207.548
-207.551
-207.554
-207.557
-207.559
-207.562
-207.564
-207.567
-207.569
-207.57
-207.572
-207.573
-207.575
-207.575
-207.576
-207.576
-210.615
-210.615
-210.615
-210.614
-210.613
-210.612
-210.61
-210.608
-210.607
-210.604
-210.602
-210.6
-210.597
-210.595
-210.592
-210.59
-210.587
-210.584
-210.582
-210.579
-210.577
-210.574
-210.572
-210.57
-210.568
-210.566
-210.564
-210.563
-210.562
-210.561
-210.56
-210.56
-210.56
-210.56
-210.56
-210.561
-210.562
-210.563
-210.564
-210.566
-210.568
-210.57
-210.572
-210.574
-210.577
-210.579
-210.582
-210.584
-210.587
-210.59
-210.592
-210.595
-210.597
-210.6
-210.602
-210.604
-210.607
-210.608
-210.61
-210.612
-210.613
-210.614
-210.615
-210.615
-210.615
-213.655
-213.654
-213.654
-213.653
-213.652
-213.651
-213.65
-213.648
-213.647
-213.645
-213.643
-213.641
-213.638
-213.636
-213.634
-213.631
-213.629
-213.626
-213.624
-213.622
-213.619
-213.617
-213.615
-213.613
-213.611
-213.61
-213.608
-213.607
-213.606
-213.605
-213.605
-213.604
-213.604
-213.604
-213.605
-213.605
-213.606
-213.607
-213.608
-213.61
-213.611
-213.613
-213.615
-213.617
-213.619
-213.622
-213.624
-213.626
-213.629
-213.631
-213.634
-213.636
-213.638
-213.641
-213.643
-213.645
-213.647
-213.648
-213.65
-213.651
-213.652
-213.653
-213.654
-213.654
-213.655
-216.694
-216.694
-216.694
-216.693
-216.692
-216.691
-216.69
-216.689
-216.687
-216.685
-216.683
-216.682
-216.679
-216.677
-216.675
-216.673
-216.671
-216.669
-216.666
-216.664
-216.662
-216.66
-216.658
-216.657
-216.655
-216.653
-216.652
-216.651
-216.65
-216.649
-216.649
-216.649
-216.648
-216.649
-216.649
-216.649
-216.65
-216.651
-216.652
-216.653
-216.655
-216.657
-216.658
-216.66
-216.662
-216.664
-216.666
-216.669
-216.671
-216.673
-216.675
-216.677
-216.679
-216.682
-216.683
-216.685
-216.687
-216.689
-216.69
-216.691
-216.692
-216.693
-216.694
-216.694
-216.694
-219.734
-219.734
-219.733
-219.733
-219.732
-219.731
-219.73
-219.729
-219.727
-219.726
-219.724
-219.722
-219.721
-219.719
-219.717
-219.715
-219.713
-219.711
-219.709
-219.707
-219.705
-219.703
-219.701
-219.7
-219.698
-219.697
-219.696
-219.695
-219.694
-219.693
-219.693
-219.692
-219.692
-219.692
-219.693
-219.693
-219.694
-219.695
-219.696
-219.697
-219.698
-219.7
-219.701
-219.703
-219.705
-219.707
-219.709
-219.711
-219.713
-219.715
-219.717
-219.719
-219.721
-219.722
-219.724
-219.726
-219.727
-219.729
-219.73
-219.731
-219.732
-219.733
-219.733
-219.734
-219.734
-222.774
-222.774
-222.773
-222.773
-222.772
-222.771
-222.77
-222.769
-222.768
-222.767
-222.765
-222.763
-222.762
-222.76
-222.758
-222.756
-222.755
-222.753
-222.751
-222.749
-222.748
-222.746
-222.744
-222.743
-222.742
-222.74
-222.739
-222.738
-222.737
-222.737
-222.736
-222.736
-222.736
-222.736
-222.736
-222.737
-222.737
-222.738
-222.739
-222.74
-222.742
-222.743
-222.744
-222.746
-222.748
-222.749
-222.751
-222.753
-222.755
-222.756
-222.758
-222.76
-222.762
-222.763
-222.765
-222.767
-222.768
-222.769
-222.77
-222.771
-222.772
-222.773
-222.773
-222.774
-222.774
-225.814
-225.814
-225.814
-225.813
-225.813
-225.812
-225.811
-225.81
-225.809
-225.807
-225.806
-225.805
-225.803
-225.801
-225.8
-225.798
-225.797
-225.795
-225.793
-225.792
-225.79
-225.789
-225.787
-225.786
-225.785
-225.783
-225.782
-225.782
-225.781
-225.78
-225.78
-225.78
-225.78
-225.78
-225.78
-225.78
-225.781
-225.782
-225.782
-225.783
-225.785
-225.786
-225.787
-225.789
-225.79
-225.792
-225.793
-225.795
-225.797
-225.798
-225.8
-225.801
-225.803
-225.805
-225.806
-225.807
-225.809
-225.81
-225.811
-225.812
-225.813
-225.813
-225.814
-225.814
-225.814
-228.855
-228.854
-228.854
-228.854
-228.853
-228.852
-228.852
-228.851
-228.85
-228.848
-228.847
-228.846
-228.844
-228.843
-228.841
-228.84
-228.838
-228.837
-228.835
-228.834
-228.833
-228.831
-228.83
-228.829
-228.828
-228.827
-228.826
-228.825
-228.824
-228.824
-228.823
-228.823
-228.823
-228.823
-228.823
-228.824
-228.824
-228.825
-228.826
-228.827
-228.828
-228.829
-228.83
-228.831
-228.833
-228.834
-228.835
-228.837
-228.838
-228.84
-228.841
-228.843
-228.844
-228.846
-228.847
-228.848
-228.85
-228.851
-228.852
-228.852
-228.853
-228.854
-228.854
-228.854
-228.855
-231.895
-231.895
-231.895
-231.894
-231.894
-231.893
-231.892
-231.891
-231.89
-231.889
-231.888
-231.887
-231.886
-231.884
-231.883
-231.882
-231.88
-231.879
-231.878
-231.876
-231.875
-231.874
-231.872
-231.871
-231.87
-231.869
-231.869
-231.868
-231.867
-231.867
-231.867
-231.866
-231.866
-231.866
-231.867
-231.867
-231.867
-231.868
-231.869
-231.869
-231.87
-231.871
-231.872
-231.874
-231.875
-231.876
-231.878
-231.879
-231.88
-231.882
-231.883
-231.884
-231.886
-231.887
-231.888
-231.889
-231.89
-231.891
-231.892
-231.893
-231.894
-231.894
-231.895
-231.895
-231.895
-234.936
-234.936
-234.935
-234.935
-234.934
-234.934
-234.933
-234.932
-234.931
-234.93
-234.929
-234.928
-234.927
-234.926
-234.925
-234.923
-234.922
-234.921
-234.92
-234.918
-234.917
-234.916
-234.915
-234.914
-234.913
-234.912
-234.912
-234.911
-234.91
-234.91
-234.91
-234.909
-234.909
-234.909
-234.91
-234.91
-234.91
-234.911
-234.912
-234.912
-234.913
-234.914
-234.915
-234.916
-234.917
-234.918
-234.92
-234.921
-234.922
-234.923
-234.925
-234.926
-234.927
-234.928
-234.929
-234.93
-234.931
-234.932
-234.933
-234.934
-234.934
-234.935
-234.935
-234.936
-234.936
-237.976
-237.976
-237.976
-237.976
-237.975
-237.975
-237.974
-237.973
-237.973
-237.972
-237.971
-237.97
-237.969
-237.968
-237.966
-237.965
-237.964
-237.963
-237.962
-237.961
-237.96
-237.959
-237.958
-237.957
-237.956
-237.955
-237.954
-237.954
-237.953
-237.953
-237.953
-237.952
-237.952
-237.952
-237.953
-237.953
-237.953
-237.954
-237.954
-237.955
-237.956
-237.957
-237.958
-237.959
-237.96
-237.961
-237.962
-237.963
-237.964
-237.965
-237.966
-237.968
-237.969
-237.97
-237.971
-237.972
-237.973
-237.973
-237.974
-237.975
-237.975
-237.976
-237.976
-237.976
-237.976
-241.017
-241.017
-241.017
-241.017
-241.016
-241.016
-241.015
-241.014
-241.014
-241.013
-241.012
-241.011
-241.01
-241.009
-241.008
-241.007
-241.006
-241.005
-241.004
-241.003
-241.002
-241.001
-241
-240.999
-240.998
-240.998
-240.997
-240.996
-240.996
-240.996
-240.995
-240.995
-240.995
-240.995
-240.995
-240.996
-240.996
-240.996
-240.997
-240.998
-240.998
-240.999
-241
-241.001
-241.002
-241.003
-241.004
-241.005
-241.006
-241.007
-241.008
-241.009
-241.01
-241.011
-241.012
-241.013
-241.014
-241.014
-241.015
-241.016
-241.016
-241.017
-241.017
-241.017
-241.017
-244.058
-244.058
-244.058
-244.058
-244.057
-244.057
-244.056
-244.056
-244.055
-244.054
-244.053
-244.053
-244.052
-244.051
-244.05
-244.049
-244.048
-244.047
-244.046
-244.045
-244.044
-244.043
-244.042
-244.042
-244.041
-244.04
-244.04
-244.039
-244.039
-244.038
-244.038
-244.038
-244.038
-244.038
-244.038
-244.038
-244.039
-244.039
-244.04
-244.04
-244.041
-244.042
-244.042
-244.043
-244.044
-244.045
-244.046
-244.047
-244.048
-244.049
-244.05
-244.051
-244.052
-244.053
-244.053
-244.054
-244.055
-244.056
-244.056
-244.057
-244.057
-244.058
-244.058
-244.058
-244.058
-247.099
-247.099
-247.099
-247.099
-247.098
-247.098
-247.097
-247.097
-247.096
-247.096
-247.095
-247.094
-247.093
-247.092
-247.092
-247.091
-247.09
-247.089
-247.088
-247.087
-247.086
-247.085
-247.085
-247.084
-247.083
-247.083
-247.082
-247.082
-247.081
-247.081
-247.081
-247.081
-247.081
-247.081
-247.081
-247.081
-247.081
-247.082
-247.082
-247.083
-247.083
-247.084
-247.085
-247.085
-247.086
-247.087
-247.088
-247.089
-247.09
-247.091
-247.092
-247.092
-247.093
-247.094
-247.095
-247.096
-247.096
-247.097
-247.097
-247.098
-247.098
-247.099
-247.099
-247.099
-247.099
-250.14
-250.14
-250.14
-250.14
-250.14
-250.139
-250.139
-250.138
-250.138
-250.137
-250.136
-250.136
-250.135
-250.134
-250.133
-250.132
-250.132
-250.131
-250.13
-250.129
-250.128
-250.128
-250.127
-250.126
-250.126
-250.125
-250.125
-250.124
-250.124
-250.124
-250.123
-250.123
-250.123
-250.123
-250.123
-250.124
-250.124
-250.124
-250.125
-250.125
-250.126
-250.126
-250.127
-250.128
-250.128
-250.129
-250.13
-250.131
-250.132
-250.132
-250.133
-250.134
-250.135
-250.136
-250.136
-250.137
-250.138
-250.138
-250.139
-250.139
-250.14
-250.14
-250.14
-250.14
-250.14
-253.182
-253.182
-253.181
-253.181
-253.181
-253.181
-253.18
-253.18
-253.179
-253.179
-253.178
-253.177
-253.177
-253.176
-253.175
-253.174
-253.173
-253.173
-253.172
-253.171
-253.171
-253.17
-253.169
-253.169
-253.168
-253.167
-253.167
-253.167
-253.166
-253.166
-253.166
-253.166
-253.166
-253.166
-253.166
-253.166
-253.166
-253.167
-253.167
-253.167
-253.168
-253.169
-253.169
-253.17
-253.171
-253.171
-253.172
-253.173
-253.173
-253.174
-253.175
-253.176
-253.177
-253.177
-253.178
-253.179
-253.179
-253.18
-253.18
-253.181
-253.181
-253.181
-253.181
-253.182
-253.182
-256.223
-256.223
-256.223
-256.223
-256.222
-256.222
-256.222
-256.221
-256.221
-256.22
-256.219
-256.219
-256.218
-256.217
-256.217
-256.216
-256.215
-256.215
-256.214
-256.213
-256.213
-256.212
-256.211
-256.211
-256.21
-256.21
-256.209
-256.209
-256.209
-256.208
-256.208
-256.208
-256.208
-256.208
-256.208
-256.208
-256.209
-256.209
-256.209
-256.21
-256.21
-256.211
-256.211
-256.212
-256.213
-256.213
-256.214
-256.215
-256.215
-256.216
-256.217
-256.217
-256.218
-256.219
-256.219
-256.22
-256.221
-256.221
-256.222
-256.222
-256.222
-256.223
-256.223
-256.223
-256.223
-259.264
-259.264
-259.264
-259.264
-259.264
-259.263
-259.263
-259.263
-259.262
-259.262
-259.261
-259.26
-259.26
-259.259
-259.259
-259.258
-259.257
-259.257
-259.256
-259.255
-259.255
-259.254
-259.253
-259.253
-259.252
-259.252
-259.252
-259.251
-259.251
-259.251
-259.251
-259.251
-259.251
-259.251
-259.251
-259.251
-259.251
-259.251
-259.252
-259.252
-259.252
-259.253
-259.253
-259.254
-259.255
-259.255
-259.256
-259.257
-259.257
-259.258
-259.259
-259.259
-259.26
-259.26
-259.261
-259.262
-259.262
-259.263
-259.263
-259.263
-259.264
-259.264
-259.264
-259.264
-259.264
-262.306
-262.306
-262.306
-262.305
-262.305
-262.305
-262.305
-262.304
-262.304
-262.303
-262.303
-262.302
-262.302
-262.301
-262.3
-262.3
-262.299
-262.298
-262.298
-262.297
-262.297
-262.296
-262.296
-262.295
-262.295
-262.294
-262.294
-262.294
-262.293
-262.293
-262.293
-262.293
-262.293
-262.293
-262.293
-262.293
-262.293
-262.294
-262.294
-262.294
-262.295
-262.295
-262.296
-262.296
-262.297
-262.297
-262.298
-262.298
-262.299
-262.3
-262.3
-262.301
-262.302
-262.302
-262.303
-262.303
-262.304
-262.304
-262.305
-262.305
-262.305
-262.305
-262.306
-262.306
-262.306
-265.347
-265.347
-265.347
-265.347
-265.347
-265.346
-265.346
-265.346
-265.345
-265.345
-265.344
-265.344
-265.343
-265.343
-265.342
-265.342
-265.341
-265.34
-265.34
-265.339
-265.339
-265.338
-265.338
-265.337
-265.337
-265.336
-265.336
-265.336
-265.335
-265.335
-265.335
-265.335
-265.335
-265.335
-265.335
-265.335
-265.335
-265.336
-265.336
-265.336
-265.337
-265.337
-265.338
-265.338
-265.339
-265.339
-265.34
-265.34
-265.341
-265.342
-265.342
-265.343
-265.343
-265.344
-265.344
-265.345
-265.345
-265.346
-265.346
-265.346
-265.347
-265.347
-265.347
-265.347
-265.347
-268.389
-268.389
-268.389
-268.388
-268.388
-268.388
-268.388
-268.387
-268.387
-268.387
-268.386
-268.386
-268.385
-268.385
-268.384
-268.383
-268.383
-268.382
-268.382
-268.381
-268.381
-268.38
-268.38
-268.379
-268.379
-268.378
-268.378
-268.378
-268.378
-268.377
-268.377
-268.377
-268.377
-268.377
-268.377
-268.377
-268.378
-268.378
-268.378
-268.378
-268.379
-268.379
-268.38
-268.38
-268.381
-268.381
-268.382
-268.382
-268.383
-268.383
-268.384
-268.385
-268.385
-268.386
-268.386
-268.387
-268.387
-268.387
-268.388
-268.388
-268.388
-268.388
-268.389
-268.389
-268.389
-271.43
-271.43
-271.43
-271.43
-271.43
-271.43
-271.429
-271.429
-271.429
-271.428
-271.428
-271.427
-271.427
-271.426
-271.426
-271.425
-271.425
-271.424
-271.424
-271.423
-271.423
-271.422
-271.422
-271.421
-271.421
-271.421
-271.42
-271.42
-271.42
-271.42
-271.419
-271.419
-271.419
-271.419
-271.419
-271.42
-271.42
-271.42
-271.42
-271.421
-271.421
-271.421
-271.422
-271.422
-271.423
-271.423
-271.424
-271.424
-271.425
-271.425
-271.426
-271.426
-271.427
-271.427
-271.428
-271.428
-271.429
-271.429
-271.429
-271.43
-271.43
-271.43
-271.43
-271.43
-271.43
-274.472
-274.472
-274.472
-274.472
-274.472
-274.471
-274.471
-274.471
-274.47
-274.47
-274.47
-274.469
-274.469
-274.468
-274.468
-274.467
-274.467
-274.466
-274.466
-274.465
-274.465
-274.464
-274.464
-274.463
-274.463
-274.463
-274.462
-274.462
-274.462
-274.462
-274.461
-274.461
-274.461
-274.461
-274.461
-274.462
-274.462
-274.462
-274.462
-274.463
-274.463
-274.463
-274.464
-274.464
-274.465
-274.465
-274.466
-274.466
-274.467
-274.467
-274.468
-274.468
-274.469
-274.469
-274.47
-274.47
-274.47
-274.471
-274.471
-274.471
-274.472
-274.472
-274.472
-274.472
-274.472
-277.514
-277.514
-277.514
-277.513
-277.513
-277.513
-277.513
-277.512
-277.512
-277.512
-277.511
-277.511
-277.51
-277.51
-277.509
-277.509
-277.508
-277.508
-277.507
-277.507
-277.506
-277.506
-277.506
-277.505
-277.505
-277.504
-277.504
-277.504
-277.504
-277.504
-277.503
-277.503
-277.503
-277.503
-277.503
-277.504
-277.504
-277.504
-277.504
-277.504
-277.505
-277.505
-277.506
-277.506
-277.506
-277.507
-277.507
-277.508
-277.508
-277.509
-277.509
-277.51
-277.51
-277.511
-277.511
-277.512
-277.512
-277.512
-277.513
-277.513
-277.513
-277.513
-277.514
-277.514
-277.514
-280.556
-280.555
-280.555
-280.555
-280.555
-280.555
-280.555
-280.554
-280.554
-280.554
-280.553
-280.553
-280.552
-280.552
-280.551
-280.551
-280.55
-280.55
-280.549
-280.549
-280.548
-280.548
-280.548
-280.547
-280.547
-280.546
-280.546
-280.546
-280.546
-280.546
-280.545
-280.545
-280.545
-280.545
-280.545
-280.546
-280.546
-280.546
-280.546
-280.546
-280.547
-280.547
-280.548
-280.548
-280.548
-280.549
-280.549
-280.55
-280.55
-280.551
-280.551
-280.552
-280.552
-280.553
-280.553
-280.554
-280.554
-280.554
-280.555
-280.555
-280.555
-280.555
-280.555
-280.555
-280.556
-283.597
-283.597
-283.597
-283.597
-283.597
-283.597
-283.596
-283.596
-283.596
-283.595
-283.595
-283.595
-283.594
-283.594
-283.593
-283.593
-283.592
-283.592
-283.591
-283.591
-283.59
-283.59
-283.589
-283.589
-283.589
-283.588
-283.588
-283.588
-283.588
-283.587
-283.587
-283.587
-283.587
-283.587
-283.587
-283.587
-283.588
-283.588
-283.588
-283.588
-283.589
-283.589
-283.589
-283.59
-283.59
-283.591
-283.591
-283.592
-283.592
-283.593
-283.593
-283.594
-283.594
-283.595
-283.595
-283.595
-283.596
-283.596
-283.596
-283.597
-283.597
-283.597
-283.597
-283.597
-283.597
 Time step         1  t=1.56074E-04  dt=1.561E-04  cfl=3.00E-01 cfl_v=9.48E-02
 c_conv= 9.82E+00 c_visc= 6.07E+02 c_grav= 1.78E+02 c_st= 5.03E+02
 nlevels           2
 coarsest_x,coarsest_y:          33          65
 Using SSP-RK3()4 (SSP) scheme for system           1
 Using SSP-RK2()4 (SSP) scheme for system           2
 Using SSP-RK3()4 (SSP) scheme for system           3
 u                   : is f-variable number:    1
 v                   : is f-variable number:    2
 p                   : is f-variable number:    3
 fi                  : is f-variable number:    4
 Initial configuration: Rising bubble
 Using CFL-number=  0.3000
 Exact area, phase 1: 3.491E-05
 Numerical area, phase 1: 3.499E-05
 Using WENO boundary trick!
 Writing inputfile to file: out.inp
 c_conv= 0.00E+00 c_visc= 6.07E+02 c_grav= 1.78E+02 c_st= 1.58E+03
 Start of time loop:
 L-s reinit converged after   10 steps with norm  1.716E-09
  0 KSP preconditioned resid norm 3.168341703825e+08 true resid norm 3.168341703825e+08 ||Ae||/||Ax|| 1.000000000000e+00
  1 KSP preconditioned resid norm 7.830661072700e-07 true resid norm 7.337644742621e-07 ||Ae||/||Ax|| 2.315925941246e-15
Linear solve converged due to CONVERGED_RTOL
Process [0]
66.5366
66.5153
66.473
66.4098
66.326
66.222
66.0984
65.9559
65.7952
65.6174
65.4234
65.2146
64.9923
64.7582
64.514
64.2616
64.0031
63.7408
63.4772
63.2148
62.9562
62.7043
62.4619
62.2317
62.0167
61.8195
61.6427
61.4887
61.3596
61.2572
61.1829
61.138
61.1229
61.138
61.1829
61.2572
61.3596
61.4887
61.6427
61.8195
62.0167
62.2317
62.4619
62.7043
62.9562
63.2148
63.4772
63.7408
64.0031
64.2616
64.514
64.7582
64.9923
65.2146
65.4234
65.6174
65.7952
65.9559
66.0984
66.222
66.326
66.4098
66.473
66.5153
66.5366
63.5162
63.4949
63.4524
63.3888
63.3046
63.2001
63.0758
62.9324
62.7708
62.5918
62.3966
62.1864
61.9625
61.7266
61.4804
61.2259
60.9651
60.7004
60.4341
60.169
59.9076
59.6528
59.4075
59.1745
58.9568
58.757
58.5778
58.4216
58.2906
58.1867
58.1114
58.0657
58.0504
58.0657
58.1114
58.1867
58.2906
58.4216
58.5778
58.757
58.9568
59.1745
59.4075
59.6528
59.9076
60.169
60.4341
60.7004
60.9651
61.2259
61.4804
61.7266
61.9625
62.1864
62.3966
62.5918
62.7708
62.9324
63.0758
63.2001
63.3046
63.3888
63.4524
63.4949
63.5162
60.5176
60.4961
60.4531
60.3889
60.3038
60.1982
60.0725
59.9276
59.764
59.5829
59.3851
59.172
58.9449
58.7054
58.4553
58.1965
57.9311
57.6614
57.39
57.1193
56.8523
56.5917
56.3406
56.1019
55.8785
55.6735
55.4894
55.3288
55.1941
55.0872
55.0097
54.9627
54.9469
54.9627
55.0097
55.0872
55.1941
55.3288
55.4894
55.6735
55.8785
56.1019
56.3406
56.5917
56.8523
57.1193
57.39
57.6614
57.9311
58.1965
58.4553
58.7054
58.9449
59.172
59.3851
59.5829
59.764
59.9276
60.0725
60.1982
60.3038
60.3889
60.4531
60.4961
60.5176
57.5408
57.5189
57.4754
57.4102
57.3238
57.2166
57.0889
56.9415
56.7752
56.5907
56.3892
56.1718
55.9399
55.6951
55.4391
55.1738
54.9015
54.6243
54.3449
54.066
53.7904
53.521
53.2611
53.0136
52.7818
52.5686
52.3771
52.2099
52.0694
51.9579
51.8769
51.8278
51.8114
51.8278
51.8769
51.9579
52.0694
52.2099
52.3771
52.5686
52.7818
53.0136
53.2611
53.521
53.7904
54.066
54.3449
54.6243
54.9015
55.1738
55.4391
55.6951
55.9399
56.1718
56.3892
56.5907
56.7752
56.9415
57.0889
57.2166
57.3238
57.4102
57.4754
57.5189
57.5408
54.5862
54.5639
54.5195
54.4531
54.3651
54.2556
54.1254
53.9748
53.8047
53.6159
53.4093
53.1863
52.948
52.6961
52.4323
52.1584
51.8767
51.5895
51.2995
51.0093
50.7221
50.4408
50.1689
49.9095
49.6661
49.4419
49.2401
49.0637
48.9154
48.7975
48.7118
48.6599
48.6425
48.6599
48.7118
48.7975
48.9154
49.0637
49.2401
49.4419
49.6661
49.9095
50.1689
50.4408
50.7221
51.0093
51.2995
51.5895
51.8767
52.1584
52.4323
52.6961
52.948
53.1863
53.4093
53.6159
53.8047
53.9748
54.1254
54.2556
54.3651
54.4531
54.5195
54.5639
54.5862
51.6541
51.6314
51.586
51.5181
51.428
51.3159
51.1824
51.0279
50.8532
50.659
50.4463
50.2162
49.97
49.7093
49.4356
49.1509
48.8575
48.5576
48.2541
47.9497
47.6477
47.3512
47.0638
46.7892
46.5308
46.2924
46.0774
45.8891
45.7305
45.6043
45.5125
45.4568
45.4382
45.4568
45.5125
45.6043
45.7305
45.8891
46.0774
46.2924
46.5308
46.7892
47.0638
47.3512
47.6477
47.9497
48.2541
48.5576
48.8575
49.1509
49.4356
49.7093
49.97
50.2162
50.4463
50.659
50.8532
51.0279
51.1824
51.3159
51.428
51.5181
51.586
51.6314
51.6541
48.7452
48.7219
48.6753
48.6057
48.5131
48.398
48.2607
48.1016
47.9215
47.721
47.501
47.2625
47.0069
46.7355
46.45
46.1524
45.8447
45.5295
45.2096
44.8878
44.5675
44.2524
43.946
43.6523
43.3753
43.1191
42.8875
42.6842
42.5128
42.3761
42.2766
42.2162
42.1959
42.2162
42.2766
42.3761
42.5128
42.6842
42.8875
43.1191
43.3753
43.6523
43.946
44.2524
44.5675
44.8878
45.2096
45.5295
45.8447
46.1524
46.45
46.7355
47.0069
47.2625
47.501
47.721
47.9215
48.1016
48.2607
48.398
48.5131
48.6057
48.6753
48.7219
48.7452
45.8599
45.836
45.7881
45.7165
45.6212
45.5026
45.361
45.1968
45.0104
44.8027
44.5743
44.3263
44.0597
43.776
43.4768
43.164
42.8396
42.5063
42.1668
41.8243
41.4823
41.1446
40.8152
40.4984
40.1988
39.9207
39.6688
39.4471
39.2597
39.1101
39.0011
38.9348
38.9125
38.9348
39.0011
39.1101
39.2597
39.4471
39.6688
39.9207
40.1988
40.4984
40.8152
41.1446
41.4823
41.8243
42.1668
42.5063
42.8396
43.164
43.4768
43.776
44.0597
44.3263
44.5743
44.8027
45.0104
45.1968
45.361
45.5026
45.6212
45.7165
45.7881
45.836
45.8599
42.999
42.9743
42.9251
42.8513
42.7531
42.6307
42.4843
42.3143
42.1212
41.9054
41.6677
41.4088
41.13
40.8323
40.5175
40.1872
39.8436
39.4893
39.1271
38.7604
38.3927
38.0283
37.6715
37.3272
37.0003
36.6959
36.4192
36.1752
35.9684
35.8029
35.6821
35.6086
35.5839
35.6086
35.6821
35.8029
35.9684
36.1752
36.4192
36.6959
37.0003
37.3272
37.6715
38.0283
38.3927
38.7604
39.1271
39.4893
39.8436
40.1872
40.5175
40.8323
41.13
41.4088
41.6677
41.9054
42.1212
42.3143
42.4843
42.6307
42.7531
42.8513
42.9251
42.9743
42.999
40.1631
40.1377
40.0869
40.0108
39.9095
39.783
39.6316
39.4554
39.2549
39.0304
38.7824
38.5117
38.2193
37.9062
37.5738
37.2239
36.8586
36.4804
36.0921
35.6973
35.2999
34.9042
34.5152
34.1382
33.7788
33.443
33.1366
32.8655
32.6351
32.4503
32.3152
32.2328
32.2051
32.2328
32.3152
32.4503
32.6351
32.8655
33.1366
33.443
33.7788
34.1382
34.5152
34.9042
35.2999
35.6973
36.0921
36.4804
36.8586
37.2239
37.5738
37.9062
38.2193
38.5117
38.7824
39.0304
39.2549
39.4554
39.6316
39.783
39.9095
40.0108
40.0869
40.1377
40.1631
37.353
37.3268
37.2745
37.196
37.0914
36.9607
36.8039
36.6213
36.4129
36.1791
35.9202
35.6368
35.3296
34.9995
34.6479
34.2763
33.8867
33.4815
33.0638
32.637
32.2053
31.7734
31.3468
30.9313
30.5335
30.1601
29.8181
29.5144
29.2554
29.0472
28.8946
28.8015
28.7702
28.8015
28.8946
29.0472
29.2554
29.5144
29.8181
30.1601
30.5335
30.9313
31.3468
31.7734
32.2053
32.637
33.0638
33.4815
33.8867
34.2763
34.6479
34.9995
35.3296
35.6368
35.9202
36.1791
36.4129
36.6213
36.8039
36.9607
37.0914
37.196
37.2745
37.3268
37.353
34.5694
34.5425
34.4886
34.4077
34.2998
34.1648
34.0026
33.8133
33.5968
33.3533
33.0829
32.786
32.4631
32.1148
31.7423
31.3469
30.9305
30.4955
30.0446
29.5816
29.1108
28.6373
28.167
27.7066
27.2634
26.8454
26.4608
26.1178
25.8243
25.5876
25.4137
25.3074
25.2717
25.3074
25.4137
25.5876
25.8243
26.1178
26.4608
26.8454
27.2634
27.7066
28.167
28.6373
29.1108
29.5816
30.0446
30.4955
30.9305
31.3469
31.7423
32.1148
32.4631
32.786
33.0829
33.3533
33.5968
33.8133
34.0026
34.1648
34.2998
34.4077
34.4886
34.5425
34.5694
31.8133
31.7856
31.7302
31.6469
31.5358
31.3965
31.2289
31.0329
30.8082
30.5548
30.2726
29.9617
29.6222
29.2547
28.8599
28.439
27.9934
27.5254
27.0378
26.5342
26.019
25.4979
24.9771
24.4643
23.9678
23.4969
23.0613
22.6709
22.3355
22.0641
21.8642
21.7417
21.7005
21.7417
21.8642
22.0641
22.3355
22.6709
23.0613
23.4969
23.9678
24.4643
24.9771
25.4979
26.019
26.5342
27.0378
27.5254
27.9934
28.439
28.8599
29.2547
29.6222
29.9617
30.2726
30.5548
30.8082
31.0329
31.2289
31.3965
31.5358
31.6469
31.7302
31.7856
31.8133
29.0852
29.0568
29
28.9145
28.8003
28.6569
28.4841
28.2815
28.0488
27.7856
27.4915
27.1663
26.8099
26.4224
26.0042
25.556
25.079
24.5753
24.0472
23.4984
22.9334
22.358
21.7792
21.2054
20.6462
20.1124
19.6157
19.1682
18.7819
18.4679
18.2359
18.0936
18.0456
18.0936
18.2359
18.4679
18.7819
19.1682
19.6157
20.1124
20.6462
21.2054
21.7792
22.358
22.9334
23.4984
24.0472
24.5753
25.079
25.556
26.0042
26.4224
26.8099
27.1663
27.4915
27.7856
28.0488
28.2815
28.4841
28.6569
28.8003
28.9145
29
29.0568
29.0852
26.386
26.3569
26.2988
26.2114
26.0943
25.9472
25.7695
25.5608
25.3204
25.0476
24.7419
24.4025
24.0291
23.6212
23.1788
22.7021
22.192
21.6498
21.0777
20.4791
19.8584
19.2216
18.5763
17.9317
17.2988
16.6903
16.1202
15.6034
15.1547
14.7883
14.5167
14.3496
14.2932
14.3496
14.5167
14.7883
15.1547
15.6034
16.1202
16.6903
17.2988
17.9317
18.5763
19.2216
19.8584
20.4791
21.0777
21.6498
22.192
22.7021
23.1788
23.6212
24.0291
24.4025
24.7419
25.0476
25.3204
25.5608
25.7695
25.9472
26.0943
26.2114
26.2988
26.3569
26.386
23.7162
23.6866
23.6274
23.5383
23.4188
23.2685
23.0865
22.8723
22.6248
22.3432
22.0264
21.6735
21.2833
20.8551
20.3882
19.8823
19.3375
18.7546
18.1352
17.4822
16.7998
16.0939
15.3726
14.646
13.9266
13.2292
12.5707
11.9694
11.4439
11.0126
10.6914
10.4932
10.4262
10.4932
10.6914
11.0126
11.4439
11.9694
12.5707
13.2292
13.9266
14.646
15.3726
16.0939
16.7998
17.4822
18.1352
18.7546
19.3375
19.8823
20.3882
20.8551
21.2833
21.6735
22.0264
22.3432
22.6248
22.8723
23.0865
23.2685
23.4188
23.5383
23.6274
23.6866
23.7162
21.0764
21.0465
20.9865
20.8961
20.7747
20.6218
20.4364
20.2175
19.964
19.6745
19.3477
18.9821
18.5762
18.1283
17.6373
17.102
16.5217
15.8963
15.2268
14.5151
13.7649
12.982
12.1743
11.353
10.532
9.72858
8.96314
8.25822
7.63765
7.1249
6.74121
6.5036
6.42312
6.5036
6.74121
7.1249
7.63765
8.25822
8.96314
9.72858
10.532
11.353
12.1743
12.982
13.7649
14.5151
15.2268
15.8963
16.5217
17.102
17.6373
18.1283
18.5762
18.9821
19.3477
19.6745
19.964
20.2175
20.4364
20.6218
20.7747
20.8961
20.9865
21.0465
21.0764
18.467
18.4368
18.3764
18.2853
18.1627
18.0081
17.8202
17.5978
17.3396
17.0437
16.7085
16.3318
15.9115
15.4454
14.9314
14.3674
13.7517
13.083
12.3612
11.5871
10.7634
9.89509
8.99
8.0596
7.11942
6.18947
5.29411
4.46142
3.72187
3.10617
2.64266
2.3544
2.25656
2.3544
2.64266
3.10617
3.72187
4.46142
5.29411
6.18947
7.11942
8.0596
8.99
9.89509
10.7634
11.5871
12.3612
13.083
13.7517
14.3674
14.9314
15.4454
15.9115
16.3318
16.7085
17.0437
17.3396
17.5978
17.8202
18.0081
18.1627
18.2853
18.3764
18.4368
18.467
15.8881
15.858
15.7975
15.7063
15.5834
15.4281
15.239
15.0147
14.7533
14.453
14.1113
13.7257
13.2933
12.8112
12.2763
11.6853
11.0353
10.3237
9.54868
8.70948
7.80723
6.84553
5.83138
4.77615
3.69651
2.61522
1.56142
0.570049
-0.3197
-1.06713
-1.63388
-1.98816
-2.10874
-1.98816
-1.63388
-1.06713
-0.3197
0.570049
1.56142
2.61522
3.69651
4.77615
5.83138
6.84553
7.80723
8.70948
9.54868
10.3237
11.0353
11.6853
12.2763
12.8112
13.2933
13.7257
14.1113
14.453
14.7533
15.0147
15.239
15.4281
15.5834
15.7063
15.7975
15.858
15.8881
13.3399
13.31
13.25
13.1593
13.0371
12.8824
12.6936
12.4691
12.2068
11.9042
11.5587
11.167
10.7257
10.2307
9.67803
9.06315
8.38155
7.6289
6.80131
5.89589
4.91141
3.84923
2.71449
1.51748
0.275259
-0.986929
-2.23468
-3.42453
-4.5058
-5.4239
-6.12621
-6.56806
-6.71896
-6.56806
-6.12621
-5.4239
-4.5058
-3.42453
-2.23468
-0.986929
0.275259
1.51748
2.71449
3.84923
4.91141
5.89589
6.80131
7.6289
8.38155
9.06315
9.67803
10.2307
10.7257
11.167
11.5587
11.9042
12.2068
12.4691
12.6936
12.8824
13.0371
13.1593
13.25
13.31
13.3399
10.8219
10.7926
10.7336
10.6443
10.524
10.3712
10.1845
9.96187
9.70101
9.39912
9.05298
8.65883
8.2124
7.70889
7.14295
6.50872
5.79995
5.01017
4.13298
3.16259
2.0945
0.926635
-0.339179
-1.69527
-3.12571
-4.60375
-6.08956
-7.52938
-8.85762
-9.99983
-10.8831
-11.4434
-11.6357
-11.4434
-10.8831
-9.99983
-8.85762
-7.52938
-6.08956
-4.60375
-3.12571
-1.69527
-0.339179
0.926635
2.0945
3.16259
4.13298
5.01017
5.79995
6.50872
7.14295
7.70889
8.2124
8.65883
9.05298
9.39912
9.70101
9.96187
10.1845
10.3712
10.524
10.6443
10.7336
10.7926
10.8219
8.33382
8.30528
8.24789
8.16101
8.04366
7.89451
7.71183
7.4935
7.23692
6.93898
6.59601
6.20372
5.75712
5.25046
4.67721
4.03
3.30063
2.4802
1.55932
0.528496
-0.621093
-1.89649
-3.30116
-4.83251
-6.47834
-8.21267
-9.99117
-11.7475
-13.3984
-14.8388
-15.9678
-16.6926
4.82094
-16.6926
-15.9678
-14.8388
-13.3984
-11.7475
-9.99117
-8.21267
-6.47834
-4.83251
-3.30116
-1.89649
-0.621093
0.528496
1.55932
2.4802
3.30063
4.03
4.67721
5.25046
5.75712
6.20372
6.59601
6.93898
7.23692
7.4935
7.71183
7.89451
8.04366
8.16101
8.24789
8.30528
8.33382
5.87468
5.84728
5.79215
5.70862
5.59566
5.45185
5.27539
5.06398
4.81483
4.52456
4.18914
3.80377
3.36282
2.85966
2.28659
1.63471
0.893778
0.0522543
-0.902705
-1.98498
-3.20892
-4.58831
-6.13451
-7.85347
-9.74109
-11.7767
-13.9153
-16.0729
4.81447
4.81375
4.81366
4.81375
4.81381
4.81375
4.81366
4.81375
4.81447
-16.0729
-13.9153
-11.7767
-9.74109
-7.85347
-6.13451
-4.58831
-3.20892
-1.98498
-0.902705
0.0522543
0.893778
1.63471
2.28659
2.85966
3.36282
3.80377
4.18914
4.52456
4.81483
5.06398
5.27539
5.45185
5.59566
5.70862
5.79215
5.84728
5.87468
3.44336
3.41744
3.36525
3.28611
3.17897
3.04238
2.87444
2.67279
2.43451
2.15601
1.83299
1.46028
1.03169
0.539857
-0.0239744
-0.670163
-1.41091
-2.26049
-3.23543
-4.35458
-5.63888
-7.11073
-8.79242
-10.7031
-12.8535
-15.2363
4.80709
4.80638
4.80685
4.80678
4.80675
4.80677
4.80678
4.80677
4.80675
4.80678
4.80685
4.80638
4.80709
-15.2363
-12.8535
-10.7031
-8.79242
-7.11073
-5.63888
-4.35458
-3.23543
-2.26049
-1.41091
-0.670163
-0.0239744
0.539857
1.03169
1.46028
1.83299
2.15601
2.43451
2.67279
2.87444
3.04238
3.17897
3.28611
3.36525
3.41744
3.44336
1.03838
1.01427
0.965723
0.892048
0.792198
0.664722
0.507728
0.318818
0.0950147
-0.167338
-0.472697
-0.82647
-1.23521
-1.70683
-2.2509
-2.879
-3.60507
-4.44592
-5.42171
-6.55645
-7.87837
-9.42004
-11.2177
-13.3094
-15.73
4.79998
4.79989
4.79971
4.79978
4.79979
4.79978
4.79978
4.79979
4.79978
4.79978
4.79979
4.79978
4.79971
4.79989
4.79998
-15.73
-13.3094
-11.2177
-9.42004
-7.87837
-6.55645
-5.42171
-4.44592
-3.60507
-2.879
-2.2509
-1.70683
-1.23521
-0.82647
-0.472697
-0.167338
0.0950147
0.318818
0.507728
0.664722
0.792198
0.892048
0.965723
1.01427
1.03838
-1.34212
-1.36407
-1.40829
-1.47543
-1.56652
-1.68295
-1.82657
-1.99972
-2.20533
-2.44701
-2.72921
-3.0574
-3.43824
-3.87993
-4.39251
-4.98834
-5.68267
-6.49432
-7.44657
-8.56822
-9.8947
-11.4694
-13.3444
-15.5817
4.79232
4.79269
4.79278
4.79277
4.79279
4.7928
4.7928
4.7928
4.7928
4.7928
4.7928
4.7928
4.79279
4.79277
4.79278
4.79269
4.79232
-15.5817
-13.3444
-11.4694
-9.8947
-8.56822
-7.44657
-6.49432
-5.68267
-4.98834
-4.39251
-3.87993
-3.43824
-3.0574
-2.72921
-2.44701
-2.20533
-1.99972
-1.82657
-1.68295
-1.56652
-1.47543
-1.40829
-1.36407
-1.34212
-3.70034
-3.7198
-3.75901
-3.8186
-3.8995
-4.00302
-4.13088
-4.2853
-4.46903
-4.68552
-4.93904
-5.23485
-5.57949
-5.98103
-6.44956
-6.99765
-7.64111
-8.39992
-9.29941
-10.372
-11.659
-13.2136
-15.1033
4.78504
4.78548
4.78569
4.78577
4.78579
4.78581
4.78582
4.78582
4.78582
4.78582
4.78582
4.78582
4.78582
4.78581
4.78579
4.78577
4.78569
4.78548
4.78504
-15.1033
-13.2136
-11.659
-10.372
-9.29941
-8.39992
-7.64111
-6.99765
-6.44956
-5.98103
-5.57949
-5.23485
-4.93904
-4.68552
-4.46903
-4.2853
-4.13088
-4.00302
-3.8995
-3.8186
-3.75901
-3.7198
-3.70034
-6.03879
-6.05546
-6.08905
-6.14012
-6.2095
-6.29836
-6.40823
-6.54111
-6.69947
-6.88644
-7.10591
-7.36272
-7.66293
-8.01412
-8.42581
-8.9101
-9.48242
-10.1626
-10.9765
-11.9579
-13.1515
-14.6174
-16.4372
4.77938
4.77887
4.77881
4.77882
4.77883
4.77884
4.77884
4.77884
4.77884
4.77884
4.77884
4.77884
4.77884
4.77884
4.77883
4.77882
4.77881
4.77887
4.77938
-16.4372
-14.6174
-13.1515
-11.9579
-10.9765
-10.1626
-9.48242
-8.9101
-8.42581
-8.01412
-7.66293
-7.36272
-7.10591
-6.88644
-6.69947
-6.54111
-6.40823
-6.29836
-6.2095
-6.14012
-6.08905
-6.05546
-6.03879
-8.36033
-8.37393
-8.40135
-8.44305
-8.49972
-8.57235
-8.66223
-8.77103
-8.90084
-9.05434
-9.23485
-9.44652
-9.69462
-9.98575
-10.3283
-10.7332
-11.2142
-11.7896
-12.4835
-13.3282
-14.3675
-15.662
4.7699
4.77151
4.7718
4.77186
4.77187
4.77187
4.77187
4.77186
4.77186
4.77186
4.77186
4.77186
4.77186
4.77186
4.77187
4.77187
4.77187
4.77186
4.7718
4.77151
4.7699
-15.662
-14.3675
-13.3282
-12.4835
-11.7896
-11.2142
-10.7332
-10.3283
-9.98575
-9.69462
-9.44652
-9.23485
-9.05434
-8.90084
-8.77103
-8.66223
-8.57235
-8.49972
-8.44305
-8.40135
-8.37393
-8.36033
-10.668
-10.6784
-10.6991
-10.7308
-10.7737
-10.8288
-10.897
-10.9796
-11.0782
-11.1948
-11.3321
-11.4933
-11.6826
-11.9051
-12.1676
-12.4788
-12.85
-13.2962
-13.8374
-14.501
-15.3244
-16.3603
4.76508
4.76497
4.76497
4.76496
4.76494
4.76492
4.7649
4.76489
4.76488
4.76487
4.76487
4.76487
4.76488
4.76489
4.7649
4.76492
4.76494
4.76496
4.76497
4.76497
4.76508
-16.3603
-15.3244
-14.501
-13.8374
-13.2962
-12.85
-12.4788
-12.1676
-11.9051
-11.6826
-11.4933
-11.3321
-11.1948
-11.0782
-10.9796
-10.897
-10.8288
-10.7737
-10.7308
-10.6991
-10.6784
-10.668
-12.9653
-12.9721
-12.986
-13.0069
-13.0355
-13.072
-13.1172
-13.1719
-13.2372
-13.3143
-13.4051
-13.5117
-13.6368
-13.7839
-13.9575
-14.1636
-14.4097
-14.7063
-15.0671
-15.5113
-16.0655
-16.7683
4.75872
4.75831
4.75814
4.75806
4.75801
4.75797
4.75794
4.75791
4.75789
4.75788
4.75788
4.75788
4.75789
4.75791
4.75794
4.75797
4.75801
4.75806
4.75814
4.75831
4.75872
-16.7683
-16.0655
-15.5113
-15.0671
-14.7063
-14.4097
-14.1636
-13.9575
-13.7839
-13.6368
-13.5117
-13.4051
-13.3143
-13.2372
-13.1719
-13.1172
-13.072
-13.0355
-13.0069
-12.986
-12.9721
-12.9653
-15.2556
-15.2589
-15.2655
-15.2755
-15.289
-15.3064
-15.3277
-15.3535
-15.384
-15.42
-15.4621
-15.5112
-15.5686
-15.6357
-15.7145
-15.8076
-15.9183
-16.0511
-16.2122
-16.4098
-16.6556
-16.9662
4.75166
4.75139
4.75124
4.75114
4.75106
4.751
4.75096
4.75093
4.7509
4.75089
4.75088
4.75089
4.7509
4.75093
4.75096
4.751
4.75106
4.75114
4.75124
4.75139
4.75166
-16.9662
-16.6556
-16.4098
-16.2122
-16.0511
-15.9183
-15.8076
-15.7145
-15.6357
-15.5686
-15.5112
-15.4621
-15.42
-15.384
-15.3535
-15.3277
-15.3064
-15.289
-15.2755
-15.2655
-15.2589
-15.2556
-17.5425
-17.5422
-17.5415
-17.5404
-17.5388
-17.5367
-17.5338
-17.5302
-17.5254
-17.5195
-17.5119
-17.5024
-17.4905
-17.4756
-17.457
-17.4337
-17.4043
-17.3673
-17.3201
-17.2595
-17.1801
-17.0731
4.74437
4.74436
4.74428
4.74419
4.7441
4.74403
4.74397
4.74393
4.7439
4.74388
4.74388
4.74388
4.7439
4.74393
4.74397
4.74403
4.7441
4.74419
4.74428
4.74436
4.74437
-17.0731
-17.1801
-17.2595
-17.3201
-17.3673
-17.4043
-17.4337
-17.457
-17.4756
-17.4905
-17.5024
-17.5119
-17.5195
-17.5254
-17.5302
-17.5338
-17.5367
-17.5388
-17.5404
-17.5415
-17.5422
-17.5425
-19.8299
-19.8259
-19.818
-19.8058
-19.7891
-19.7676
-19.7408
-19.7079
-19.6681
-19.6205
-19.5637
-19.496
-19.4155
-19.3194
-19.2043
-19.0658
-18.8982
-18.6937
-18.4418
-18.1282
-17.7325
-17.2253
4.73727
4.73741
4.73734
4.73723
4.73712
4.73704
4.73697
4.73692
4.73688
4.73687
4.73686
4.73687
4.73688
4.73692
4.73697
4.73704
4.73712
4.73723
4.73734
4.73741
4.73727
-17.2253
-17.7325
-18.1282
-18.4418
-18.6937
-18.8982
-19.0658
-19.2043
-19.3194
-19.4155
-19.496
-19.5637
-19.6205
-19.6681
-19.7079
-19.7408
-19.7676
-19.7891
-19.8058
-19.818
-19.8259
-19.8299
-22.1212
-22.1137
-22.0987
-22.0757
-22.0444
-22.0041
-21.9538
-21.8926
-21.8188
-21.7309
-21.6265
-21.5028
-21.3562
-21.1823
-20.9753
-20.7276
-20.4296
-20.0682
-19.6262
-19.0802
-18.3981
-17.5362
4.73084
4.73068
4.73045
4.73026
4.73013
4.73002
4.72995
4.72989
4.72986
4.72984
4.72983
4.72984
4.72986
4.72989
4.72995
4.73002
4.73013
4.73026
4.73045
4.73068
4.73084
-17.5362
-18.3981
-19.0802
-19.6262
-20.0682
-20.4296
-20.7276
-20.9753
-21.1823
-21.3562
-21.5028
-21.6265
-21.7309
-21.8188
-21.8926
-21.9538
-22.0041
-22.0444
-22.0757
-22.0987
-22.1137
-22.1212
-24.42
-24.4092
-24.3874
-24.3542
-24.3089
-24.2506
-24.1781
-24.0899
-23.984
-23.858
-23.7089
-23.5327
-23.3248
-23.079
-22.7875
-22.4406
-22.0252
-21.5246
-20.9163
-20.1704
-19.2461
-18.0878
4.72594
4.72403
4.72349
4.72325
4.7231
4.72299
4.7229
4.72285
4.72281
4.72279
4.72278
4.72279
4.72281
4.72285
4.7229
4.72299
4.7231
4.72325
4.72349
4.72403
4.72594
-18.0878
-19.2461
-20.1704
-20.9163
-21.5246
-22.0252
-22.4406
-22.7875
-23.079
-23.3248
-23.5327
-23.7089
-23.858
-23.984
-24.0899
-24.1781
-24.2506
-24.3089
-24.3542
-24.3874
-24.4092
-24.42
-26.7299
-26.7159
-26.6878
-26.6449
-26.5865
-26.5115
-26.4183
-26.3051
-26.1696
-26.0087
-25.8187
-25.595
-25.3318
-25.0219
-24.6562
-24.223
-23.7074
-23.0902
-22.3462
-21.4419
-20.3318
-18.9518
-17.2008
4.71599
4.71624
4.71616
4.71603
4.71592
4.71583
4.71578
4.71575
4.71573
4.71573
4.71573
4.71575
4.71578
4.71583
4.71592
4.71603
4.71616
4.71624
4.71599
-17.2008
-18.9518
-20.3318
-21.4419
-22.3462
-23.0902
-23.7074
-24.223
-24.6562
-25.0219
-25.3318
-25.595
-25.8187
-26.0087
-26.1696
-26.3051
-26.4183
-26.5115
-26.5865
-26.6449
-26.6878
-26.7159
-26.7299
-29.0539
-29.037
-29.0031
-28.9514
-28.881
-28.7908
-28.6788
-28.5431
-28.3809
-28.1888
-27.9627
-27.6973
-27.3863
-27.0216
-26.5934
-26.089
-25.4929
-24.7847
-23.9389
-22.9222
-21.6917
-20.1926
-18.3603
4.71017
4.70932
4.7091
4.70894
4.70881
4.70874
4.70869
4.70867
4.70866
4.70866
4.70866
4.70867
4.70869
4.70874
4.70881
4.70894
4.7091
4.70932
4.71017
-18.3603
-20.1926
-21.6917
-22.9222
-23.9389
-24.7847
-25.4929
-26.089
-26.5934
-27.0216
-27.3863
-27.6973
-27.9627
-28.1888
-28.3809
-28.5431
-28.6788
-28.7908
-28.881
-28.9514
-29.0031
-29.037
-29.0539
-31.395
-31.3755
-31.3364
-31.2768
-31.1958
-31.092
-30.9635
-30.808
-30.6226
-30.4036
-30.1466
-29.846
-29.4952
-29.0859
-28.6078
-28.0484
-27.392
-26.619
-25.7051
-24.6197
-23.3244
-21.7718
-19.9021
-17.6341
4.70174
4.702
4.7018
4.70166
4.70161
4.70158
4.70158
4.70159
4.70159
4.70159
4.70158
4.70158
4.70161
4.70166
4.7018
4.702
4.70174
-17.6341
-19.9021
-21.7718
-23.3244
-24.6197
-25.7051
-26.619
-27.392
-28.0484
-28.6078
-29.0859
-29.4952
-29.846
-30.1466
-30.4036
-30.6226
-30.808
-30.9635
-31.092
-31.1958
-31.2768
-31.3364
-31.3755
-31.395
-33.7558
-33.7341
-33.6904
-33.624
-33.5338
-33.4183
-33.2757
-33.1034
-32.8984
-32.657
-32.3746
-32.0457
-31.6635
-31.2199
-30.7048
-30.1063
-29.4095
-28.5965
-27.6455
-26.5302
-25.2186
-23.6729
-21.8483
-19.6931
-17.1542
4.69537
4.69461
4.69443
4.69444
4.69445
4.69448
4.69451
4.69452
4.69451
4.69448
4.69445
4.69444
4.69443
4.69461
4.69537
-17.1542
-19.6931
-21.8483
-23.6729
-25.2186
-26.5302
-27.6455
-28.5965
-29.4095
-30.1063
-30.7048
-31.2199
-31.6635
-32.0457
-32.3746
-32.657
-32.8984
-33.1034
-33.2757
-33.4183
-33.5338
-33.624
-33.6904
-33.7341
-33.7558
-36.1386
-36.115
-36.0675
-35.9953
-35.8974
-35.7723
-35.6179
-35.4319
-35.2112
-34.952
-34.6499
-34.2995
-33.8943
-33.4265
-32.8867
-32.2639
-31.545
-30.7141
-29.7529
-28.64
-27.3506
-25.8572
-24.1304
-22.1416
-19.8695
-17.313
4.68682
4.68701
4.68727
4.68731
4.68739
4.68745
4.68747
4.68745
4.68739
4.68731
4.68727
4.68701
4.68682
-17.313
-19.8695
-22.1416
-24.1304
-25.8572
-27.3506
-28.64
-29.7529
-30.7141
-31.545
-32.2639
-32.8867
-33.4265
-33.8943
-34.2995
-34.6499
-34.952
-35.2112
-35.4319
-35.6179
-35.7723
-35.8974
-35.9953
-36.0675
-36.115
-36.1386
-38.5454
-38.5202
-38.4696
-38.3928
-38.2887
-38.1558
-37.9923
-37.7957
-37.5629
-37.2906
-36.9743
-36.609
-36.1886
-35.706
-35.1529
-34.5193
-33.794
-32.964
-32.0145
-30.9289
-29.6897
-28.2785
-26.6787
-24.8779
-22.8737
-20.6819
-18.346
4.67951
4.68032
4.68013
4.68031
4.68043
4.68047
4.68043
4.68031
4.68013
4.68032
4.67951
-18.346
-20.6819
-22.8737
-24.8779
-26.6787
-28.2785
-29.6897
-30.9289
-32.0145
-32.964
-33.794
-34.5193
-35.1529
-35.706
-36.1886
-36.609
-36.9743
-37.2906
-37.5629
-37.7957
-37.9923
-38.1558
-38.2887
-38.3928
-38.4696
-38.5202
-38.5454
-40.9777
-40.9513
-40.8983
-40.818
-40.7092
-40.5706
-40.4003
-40.196
-39.955
-39.6738
-39.3485
-38.9745
-38.5462
-38.0573
-37.5006
-36.8678
-36.1495
-35.3354
-34.4141
-33.374
-32.2033
-30.8915
-29.4311
-27.8206
-26.0683
-24.1973
-22.2505
-20.2927
-18.4185
4.67255
4.67328
4.67351
4.67355
4.67351
4.67328
4.67255
-18.4185
-20.2927
-22.2505
-24.1973
-26.0683
-27.8206
-29.4311
-30.8915
-32.2033
-33.374
-34.4141
-35.3354
-36.1495
-36.8678
-37.5006
-38.0573
-38.5462
-38.9745
-39.3485
-39.6738
-39.955
-40.196
-40.4003
-40.5706
-40.7092
-40.818
-40.8983
-40.9513
-40.9777
-43.4367
-43.4095
-43.3549
-43.272
-43.16
-43.0175
-42.8428
-42.6338
-42.3878
-42.1018
-41.7723
-41.395
-40.9652
-40.4775
-39.9257
-39.3031
-38.6023
-37.8155
-36.9345
-35.9517
-34.8602
-33.6553
-32.3361
-30.9075
-29.3834
-27.7895
-26.1663
-24.5705
-23.0771
-21.7751
-20.7793
-20.1459
-19.9278
-20.1459
-20.7793
-21.7751
-23.0771
-24.5705
-26.1663
-27.7895
-29.3834
-30.9075
-32.3361
-33.6553
-34.8602
-35.9517
-36.9345
-37.8155
-38.6023
-39.3031
-39.9257
-40.4775
-40.9652
-41.395
-41.7723
-42.1018
-42.3878
-42.6338
-42.8428
-43.0175
-43.16
-43.272
-43.3549
-43.4095
-43.4367
-45.9234
-45.8957
-45.84
-45.7556
-45.6418
-45.4972
-45.3202
-45.109
-44.8612
-44.5741
-44.2445
-43.8689
-43.4431
-42.9627
-42.4227
-41.8179
-41.1425
-40.3911
-39.5584
-38.6398
-37.6322
-36.5352
-35.352
-34.0914
-32.7694
-31.4116
-30.0541
-28.7444
-27.5413
-26.511
-25.7229
-25.2266
-25.0568
-25.2266
-25.7229
-26.511
-27.5413
-28.7444
-30.0541
-31.4116
-32.7694
-34.0914
-35.352
-36.5352
-37.6322
-38.6398
-39.5584
-40.3911
-41.1425
-41.8179
-42.4227
-42.9627
-43.4431
-43.8689
-44.2445
-44.5741
-44.8612
-45.109
-45.3202
-45.4972
-45.6418
-45.7556
-45.84
-45.8957
-45.9234
-48.4382
-48.4103
-48.3541
-48.2692
-48.1548
-48.0097
-47.8324
-47.6214
-47.3745
-47.0894
-46.7635
-46.3936
-45.9765
-45.5084
-44.9856
-44.4041
-43.76
-43.0494
-42.2695
-41.4181
-40.4951
-39.5026
-38.4466
-37.3375
-36.1919
-35.0334
-33.8932
-32.8103
-31.8299
-31.0008
-30.3703
-29.9755
-29.841
-29.9755
-30.3703
-31.0008
-31.8299
-32.8103
-33.8932
-35.0334
-36.1919
-37.3375
-38.4466
-39.5026
-40.4951
-41.4181
-42.2695
-43.0494
-43.76
-44.4041
-44.9856
-45.5084
-45.9765
-46.3936
-46.7635
-47.0894
-47.3745
-47.6214
-47.8324
-48.0097
-48.1548
-48.2692
-48.3541
-48.4103
-48.4382
-50.9814
-50.9535
-50.8975
-50.8129
-50.699
-50.5547
-50.379
-50.1702
-49.9266
-49.6464
-49.3271
-48.9664
-48.5615
-48.1097
-47.6082
-47.0541
-46.4448
-45.7782
-45.0531
-44.2693
-43.4285
-42.5346
-41.595
-40.6207
-39.6275
-38.6366
-37.6742
-36.772
-35.9648
-35.289
-34.7784
-34.4602
-34.3521
-34.4602
-34.7784
-35.289
-35.9648
-36.772
-37.6742
-38.6366
-39.6275
-40.6207
-41.595
-42.5346
-43.4285
-44.2693
-45.0531
-45.7782
-46.4448
-47.0541
-47.6082
-48.1097
-48.5615
-48.9664
-49.3271
-49.6464
-49.9266
-50.1702
-50.379
-50.5547
-50.699
-50.8129
-50.8975
-50.9535
-50.9814
-53.5528
-53.5253
-53.4699
-53.3863
-53.2739
-53.1318
-52.959
-52.7543
-52.5161
-52.2429
-51.9328
-51.5839
-51.1942
-50.7616
-50.2842
-49.76
-49.1877
-48.5665
-47.8963
-47.1784
-46.4157
-45.6132
-44.7787
-43.9231
-43.0609
-42.2106
-41.3943
-40.6371
-39.9664
-39.4094
-38.9911
-38.7315
-38.6434
-38.7315
-38.9911
-39.4094
-39.9664
-40.6371
-41.3943
-42.2106
-43.0609
-43.9231
-44.7787
-45.6132
-46.4157
-47.1784
-47.8963
-48.5665
-49.1877
-49.76
-50.2842
-50.7616
-51.1942
-51.5839
-51.9328
-52.2429
-52.5161
-52.7543
-52.959
-53.1318
-53.2739
-53.3863
-53.4699
-53.5253
-53.5528
-56.1523
-56.1253
-56.0709
-55.989
-55.879
-55.7401
-55.5716
-55.3723
-55.1411
-54.8768
-54.5779
-54.2429
-53.8705
-53.4591
-53.0075
-52.5148
-51.9805
-51.4045
-50.788
-50.133
-49.4432
-48.7242
-47.9838
-47.2321
-46.4823
-45.7502
-45.0541
-44.4144
-43.8524
-43.3889
-43.0427
-42.8285
-42.756
-42.8285
-43.0427
-43.3889
-43.8524
-44.4144
-45.0541
-45.7502
-46.4823
-47.2321
-47.9838
-48.7242
-49.4432
-50.133
-50.788
-51.4045
-51.9805
-52.5148
-53.0075
-53.4591
-53.8705
-54.2429
-54.5779
-54.8768
-55.1411
-55.3723
-55.5716
-55.7401
-55.879
-55.989
-56.0709
-56.1253
-56.1523
-58.7793
-58.7529
-58.7
-58.6203
-58.5133
-58.3786
-58.2153
-58.0227
-57.7999
-57.5458
-57.2596
-56.94
-56.5862
-56.1973
-55.7727
-55.312
-54.8154
-54.2837
-53.7186
-53.1229
-52.5005
-51.8571
-51.2002
-50.5393
-49.8857
-49.2532
-48.6568
-48.1129
-47.6384
-47.2494
-46.9601
-46.7817
-46.7214
-46.7817
-46.9601
-47.2494
-47.6384
-48.1129
-48.6568
-49.2532
-49.8857
-50.5393
-51.2002
-51.8571
-52.5005
-53.1229
-53.7186
-54.2837
-54.8154
-55.312
-55.7727
-56.1973
-56.5862
-56.94
-57.2596
-57.5458
-57.7999
-58.0227
-58.2153
-58.3786
-58.5133
-58.6203
-58.7
-58.7529
-58.7793
-61.4331
-61.4075
-61.3563
-61.2792
-61.1759
-61.046
-60.8888
-60.7038
-60.4903
-60.2476
-59.975
-59.6719
-59.3377
-58.9719
-58.5745
-58.1456
-57.686
-57.1969
-56.6805
-56.1398
-55.579
-55.0037
-54.4208
-53.8389
-53.2679
-52.7194
-52.206
-51.741
-51.3376
-51.0086
-50.7648
-50.6149
-50.5643
-50.6149
-50.7648
-51.0086
-51.3376
-51.741
-52.206
-52.7194
-53.2679
-53.8389
-54.4208
-55.0037
-55.579
-56.1398
-56.6805
-57.1969
-57.686
-58.1456
-58.5745
-58.9719
-59.3377
-59.6719
-59.975
-60.2476
-60.4903
-60.7038
-60.8888
-61.046
-61.1759
-61.2792
-61.3563
-61.4075
-61.4331
-64.1128
-64.0882
-64.0389
-63.9648
-63.8656
-63.741
-63.5905
-63.4138
-63.2104
-62.9797
-62.7215
-62.4354
-62.1211
-61.7786
-61.4082
-61.0104
-60.5864
-60.1378
-59.667
-59.1771
-58.6724
-58.158
-57.6405
-57.1273
-56.6272
-56.15
-55.7061
-55.3063
-54.9614
-54.6811
-54.4742
-54.3473
-54.3045
-54.3473
-54.4742
-54.6811
-54.9614
-55.3063
-55.7061
-56.15
-56.6272
-57.1273
-57.6405
-58.158
-58.6724
-59.1771
-59.667
-60.1378
-60.5864
-61.0104
-61.4082
-61.7786
-62.1211
-62.4354
-62.7215
-62.9797
-63.2104
-63.4138
-63.5905
-63.741
-63.8656
-63.9648
-64.0389
-64.0882
-64.1128
-66.8175
-66.7939
-66.7468
-66.6759
-66.5811
-66.4622
-66.3189
-66.1509
-65.958
-65.7399
-65.4964
-65.2275
-64.9331
-64.6137
-64.2696
-63.9019
-63.5119
-63.1013
-62.6728
-62.2295
-61.7755
-61.3156
-60.8556
-60.4024
-59.9633
-59.5468
-59.1614
-58.8161
-58.5194
-58.2792
-58.1024
-57.9942
-57.9577
-57.9942
-58.1024
-58.2792
-58.5194
-58.8161
-59.1614
-59.5468
-59.9633
-60.4024
-60.8556
-61.3156
-61.7755
-62.2295
-62.6728
-63.1013
-63.5119
-63.9019
-64.2696
-64.6137
-64.9331
-65.2275
-65.4964
-65.7399
-65.958
-66.1509
-66.3189
-66.4622
-66.5811
-66.6759
-66.7468
-66.7939
-66.8175
-69.5461
-69.5236
-69.4787
-69.4113
-69.3211
-69.2082
-69.0724
-68.9134
-68.7313
-68.5258
-68.2972
-68.0454
-67.7707
-67.4737
-67.1551
-66.8161
-66.4581
-66.0831
-65.6937
-65.2929
-64.8845
-64.4732
-64.064
-63.663
-63.2766
-62.9119
-62.5761
-62.2764
-62.0199
-61.813
-61.661
-61.5681
-61.5369
-61.5681
-61.661
-61.813
-62.0199
-62.2764
-62.5761
-62.9119
-63.2766
-63.663
-64.064
-64.4732
-64.8845
-65.2929
-65.6937
-66.0831
-66.4581
-66.8161
-67.1551
-67.4737
-67.7707
-68.0454
-68.2972
-68.5258
-68.7313
-68.9134
-69.0724
-69.2082
-69.3211
-69.4113
-69.4787
-69.5236
-69.5461
-72.2974
-72.2761
-72.2336
-72.1696
-72.0843
-71.9775
-71.8493
-71.6995
-71.5282
-71.3354
-71.1214
-70.8864
-70.631
-70.3556
-70.0614
-69.7496
-69.4216
-69.0796
-68.726
-68.3638
-67.9966
-67.6285
-67.2642
-66.9088
-66.568
-66.2477
-65.954
-65.6929
-65.4702
-65.291
-65.1597
-65.0795
-65.0525
-65.0795
-65.1597
-65.291
-65.4702
-65.6929
-65.954
-66.2477
-66.568
-66.9088
-67.2642
-67.6285
-67.9966
-68.3638
-68.726
-69.0796
-69.4216
-69.7496
-70.0614
-70.3556
-70.631
-70.8864
-71.1214
-71.3354
-71.5282
-71.6995
-71.8493
-71.9775
-72.0843
-72.1696
-72.2336
-72.2761
-72.2974
-75.0704
-75.0503
-75.0101
-74.9497
-74.8693
-74.7687
-74.648
-74.5074
-74.3468
-74.1666
-73.9669
-73.7483
-73.5113
-73.2568
-72.9857
-72.6993
-72.3994
-72.0878
-71.7671
-71.4399
-71.1097
-70.7801
-70.4552
-70.1398
-69.8385
-69.5564
-69.2987
-69.0704
-68.8763
-68.7204
-68.6063
-68.5368
-68.5135
-68.5368
-68.6063
-68.7204
-68.8763
-69.0704
-69.2987
-69.5564
-69.8385
-70.1398
-70.4552
-70.7801
-71.1097
-71.4399
-71.7671
-72.0878
-72.3994
-72.6993
-72.9857
-73.2568
-73.5113
-73.7483
-73.9669
-74.1666
-74.3468
-74.5074
-74.648
-74.7687
-74.8693
-74.9497
-75.0101
-75.0503
-75.0704
-77.8638
-77.8449
-77.807
-77.7503
-77.6746
-77.5802
-77.4671
-77.3355
-77.1855
-77.0174
-76.8317
-76.6289
-76.4096
-76.1747
-75.9254
-75.6629
-75.389
-75.1054
-74.8146
-74.5192
-74.2221
-73.9267
-73.6368
-73.3563
-73.0894
-72.8404
-72.6137
-72.4134
-72.2434
-72.1073
-72.0078
-71.9473
-71.9269
-71.9473
-72.0078
-72.1073
-72.2434
-72.4134
-72.6137
-72.8404
-73.0894
-73.3563
-73.6368
-73.9267
-74.2221
-74.5192
-74.8146
-75.1054
-75.389
-75.6629
-75.9254
-76.1747
-76.4096
-76.6289
-76.8317
-77.0174
-77.1855
-77.3355
-77.4671
-77.5802
-77.6746
-77.7503
-77.807
-77.8449
-77.8638
-80.6764
-80.6587
-80.6232
-80.5699
-80.4991
-80.4108
-80.3051
-80.1822
-80.0424
-79.8862
-79.7139
-79.5261
-79.3236
-79.1074
-78.8785
-78.6382
-78.3882
-78.1304
-77.8669
-77.6001
-77.3327
-77.0679
-76.8088
-76.559
-76.3221
-76.1018
-75.9017
-75.7254
-75.5762
-75.4569
-75.3698
-75.3169
-75.2991
-75.3169
-75.3698
-75.4569
-75.5762
-75.7254
-75.9017
-76.1018
-76.3221
-76.559
-76.8088
-77.0679
-77.3327
-77.6001
-77.8669
-78.1304
-78.3882
-78.6382
-78.8785
-79.1074
-79.3236
-79.5261
-79.7139
-79.8862
-80.0424
-80.1822
-80.3051
-80.4108
-80.4991
-80.5699
-80.6232
-80.6587
-80.6764
-83.5071
-83.4905
-83.4573
-83.4075
-83.3414
-83.2589
-83.1604
-83.0461
-82.9162
-82.7713
-82.6117
-82.4383
-82.2517
-82.0529
-81.843
-81.6234
-81.3955
-81.1612
-80.9224
-80.6815
-80.4408
-80.2032
-79.9715
-79.7487
-79.538
-79.3426
-79.1657
-79.0101
-78.8786
-78.7737
-78.6972
-78.6507
-78.6351
-78.6507
-78.6972
-78.7737
-78.8786
-79.0101
-79.1657
-79.3426
-79.538
-79.7487
-79.9715
-80.2032
-80.4408
-80.6815
-80.9224
-81.1612
-81.3955
-81.6234
-81.843
-82.0529
-82.2517
-82.4383
-82.6117
-82.7713
-82.9162
-83.0461
-83.1604
-83.2589
-83.3414
-83.4075
-83.4573
-83.4905
-83.5071
-86.3546
-86.3391
-86.3082
-86.2618
-86.2002
-86.1235
-86.0319
-85.9257
-85.8053
-85.6711
-85.5237
-85.3638
-85.1921
-85.0097
-84.8175
-84.6169
-84.4093
-84.1965
-83.9802
-83.7626
-83.5459
-83.3325
-83.125
-82.926
-82.7384
-82.5648
-82.4079
-82.2702
-82.1541
-82.0615
-81.9942
-81.9532
-81.9395
-81.9532
-81.9942
-82.0615
-82.1541
-82.2702
-82.4079
-82.5648
-82.7384
-82.926
-83.125
-83.3325
-83.5459
-83.7626
-83.9802
-84.1965
-84.4093
-84.6169
-84.8175
-85.0097
-85.1921
-85.3638
-85.5237
-85.6711
-85.8053
-85.9257
-86.0319
-86.1235
-86.2002
-86.2618
-86.3082
-86.3391
-86.3546
-89.2179
-89.2035
-89.1747
-89.1316
-89.0743
-89.0031
-88.9181
-88.8197
-88.7083
-88.5844
-88.4485
-88.3013
-88.1436
-87.9763
-87.8005
-87.6174
-87.4285
-87.2353
-87.0394
-86.8428
-86.6476
-86.4558
-86.2698
-86.0919
-85.9245
-85.77
-85.6306
-85.5085
-85.4056
-85.3238
-85.2642
-85.2281
-85.216
-85.2281
-85.2642
-85.3238
-85.4056
-85.5085
-85.6306
-85.77
-85.9245
-86.0919
-86.2698
-86.4558
-86.6476
-86.8428
-87.0394
-87.2353
-87.4285
-87.6174
-87.8005
-87.9763
-88.1436
-88.3013
-88.4485
-88.5844
-88.7083
-88.8197
-88.9181
-89.0031
-89.0743
-89.1316
-89.1747
-89.2035
-89.2179
-92.0959
-92.0825
-92.0557
-92.0157
-91.9626
-91.8966
-91.818
-91.727
-91.6241
-91.5099
-91.3847
-91.2494
-91.1047
-90.9515
-90.7909
-90.624
-90.4521
-90.2767
-90.0993
-89.9217
-89.7457
-89.5733
-89.4064
-89.2471
-89.0976
-88.9597
-88.8357
-88.7272
-88.6359
-88.5633
-88.5106
-88.4786
-88.4679
-88.4786
-88.5106
-88.5633
-88.6359
-88.7272
-88.8357
-88.9597
-89.0976
-89.2471
-89.4064
-89.5733
-89.7457
-89.9217
-90.0993
-90.2767
-90.4521
-90.624
-90.7909
-90.9515
-91.1047
-91.2494
-91.3847
-91.5099
-91.6241
-91.727
-91.818
-91.8966
-91.9626
-92.0157
-92.0557
-92.0825
-92.0959
-94.9874
-94.975
-94.9502
-94.9132
-94.864
-94.803
-94.7303
-94.6464
-94.5516
-94.4463
-94.3313
-94.2071
-94.0745
-93.9343
-93.7877
-93.6356
-93.4793
-93.3201
-93.1595
-92.999
-92.8403
-92.6851
-92.5352
-92.3925
-92.2587
-92.1356
-92.025
-91.9283
-91.8472
-91.7827
-91.7359
-91.7075
-91.698
-91.7075
-91.7359
-91.7827
-91.8472
-91.9283
-92.025
-92.1356
-92.2587
-92.3925
-92.5352
-92.6851
-92.8403
-92.999
-93.1595
-93.3201
-93.4793
-93.6356
-93.7877
-93.9343
-94.0745
-94.2071
-94.3313
-94.4463
-94.5516
-94.6464
-94.7303
-94.803
-94.864
-94.9132
-94.9502
-94.975
-94.9874
-97.8915
-97.8801
-97.8572
-97.8229
-97.7775
-97.7212
-97.6542
-97.5768
-97.4895
-97.3928
-97.2871
-97.1732
-97.0519
-96.9238
-96.79
-96.6515
-96.5094
-96.3649
-96.2195
-96.0744
-95.9312
-95.7915
-95.6568
-95.5287
-95.4089
-95.2988
-95.2
-95.1138
-95.0415
-94.9841
-94.9425
-94.9172
-94.9088
-94.9172
-94.9425
-94.9841
-95.0415
-95.1138
-95.2
-95.2988
-95.4089
-95.5287
-95.6568
-95.7915
-95.9312
-96.0744
-96.2195
-96.3649
-96.5094
-96.6515
-96.79
-96.9238
-97.0519
-97.1732
-97.2871
-97.3928
-97.4895
-97.5768
-97.6542
-97.7212
-97.7775
-97.8229
-97.8572
-97.8801
-97.8915
-100.807
-100.797
-100.776
-100.744
-100.702
-100.65
-100.589
-100.517
-100.437
-100.348
-100.251
-100.147
-100.036
-99.9191
-99.7971
-99.671
-99.5418
-99.4108
-99.2791
-99.1479
-99.0187
-98.8928
-98.7717
-98.6566
-98.5492
-98.4506
-98.3623
-98.2853
-98.2207
-98.1695
-98.1324
-98.1099
-98.1024
-98.1099
-98.1324
-98.1695
-98.2207
-98.2853
-98.3623
-98.4506
-98.5492
-98.6566
-98.7717
-98.8928
-99.0187
-99.1479
-99.2791
-99.4108
-99.5418
-99.671
-99.7971
-99.9191
-100.036
-100.147
-100.251
-100.348
-100.437
-100.517
-100.589
-100.65
-100.702
-100.744
-100.776
-100.797
-100.807
-103.734
-103.724
-103.705
-103.676
-103.637
-103.589
-103.532
-103.467
-103.393
-103.312
-103.223
-103.128
-103.026
-102.919
-102.808
-102.694
-102.576
-102.457
-102.338
-102.219
-102.103
-101.989
-101.88
-101.777
-101.68
-101.592
-101.513
-101.444
-101.386
-101.341
-101.308
-101.287
-101.281
-101.287
-101.308
-101.341
-101.386
-101.444
-101.513
-101.592
-101.68
-101.777
-101.88
-101.989
-102.103
-102.219
-102.338
-102.457
-102.576
-102.694
-102.808
-102.919
-103.026
-103.128
-103.223
-103.312
-103.393
-103.467
-103.532
-103.589
-103.637
-103.676
-103.705
-103.724
-103.734
-106.67
-106.661
-106.643
-106.617
-106.581
-106.537
-106.485
-106.425
-106.358
-106.283
-106.202
-106.114
-106.022
-105.924
-105.823
-105.719
-105.612
-105.504
-105.396
-105.289
-105.184
-105.081
-104.983
-104.89
-104.803
-104.724
-104.653
-104.591
-104.54
-104.499
-104.469
-104.451
-104.445
-104.451
-104.469
-104.499
-104.54
-104.591
-104.653
-104.724
-104.803
-104.89
-104.983
-105.081
-105.184
-105.289
-105.396
-105.504
-105.612
-105.719
-105.823
-105.924
-106.022
-106.114
-106.202
-106.283
-106.358
-106.425
-106.485
-106.537
-106.581
-106.617
-106.643
-106.661
-106.67
-109.616
-109.608
-109.591
-109.567
-109.534
-109.494
-109.446
-109.391
-109.329
-109.261
-109.186
-109.107
-109.022
-108.933
-108.841
-108.746
-108.649
-108.552
-108.454
-108.357
-108.262
-108.169
-108.081
-107.997
-107.919
-107.848
-107.784
-107.729
-107.682
-107.646
-107.619
-107.603
-107.598
-107.603
-107.619
-107.646
-107.682
-107.729
-107.784
-107.848
-107.919
-107.997
-108.081
-108.169
-108.262
-108.357
-108.454
-108.552
-108.649
-108.746
-108.841
-108.933
-109.022
-109.107
-109.186
-109.261
-109.329
-109.391
-109.446
-109.494
-109.534
-109.567
-109.591
-109.608
-109.616
-112.57
-112.562
-112.547
-112.525
-112.495
-112.458
-112.414
-112.364
-112.307
-112.244
-112.177
-112.104
-112.027
-111.946
-111.862
-111.776
-111.688
-111.599
-111.51
-111.423
-111.336
-111.253
-111.173
-111.098
-111.028
-110.964
-110.906
-110.857
-110.815
-110.782
-110.759
-110.744
-110.739
-110.744
-110.759
-110.782
-110.815
-110.857
-110.906
-110.964
-111.028
-111.098
-111.173
-111.253
-111.336
-111.423
-111.51
-111.599
-111.688
-111.776
-111.862
-111.946
-112.027
-112.104
-112.177
-112.244
-112.307
-112.364
-112.414
-112.458
-112.495
-112.525
-112.547
-112.562
-112.57
-115.532
-115.525
-115.511
-115.49
-115.463
-115.429
-115.389
-115.343
-115.291
-115.234
-115.172
-115.105
-115.035
-114.961
-114.885
-114.807
-114.727
-114.646
-114.566
-114.487
-114.409
-114.333
-114.261
-114.193
-114.13
-114.073
-114.021
-113.977
-113.939
-113.91
-113.888
-113.875
-113.871
-113.875
-113.888
-113.91
-113.939
-113.977
-114.021
-114.073
-114.13
-114.193
-114.261
-114.333
-114.409
-114.487
-114.566
-114.646
-114.727
-114.807
-114.885
-114.961
-115.035
-115.105
-115.172
-115.234
-115.291
-115.343
-115.389
-115.429
-115.463
-115.49
-115.511
-115.525
-115.532
-118.5
-118.494
-118.481
-118.462
-118.437
-118.406
-118.37
-118.327
-118.28
-118.228
-118.171
-118.111
-118.047
-117.98
-117.91
-117.839
-117.767
-117.694
-117.621
-117.549
-117.479
-117.41
-117.345
-117.284
-117.227
-117.175
-117.129
-117.089
-117.055
-117.029
-117.01
-116.998
-116.994
-116.998
-117.01
-117.029
-117.055
-117.089
-117.129
-117.175
-117.227
-117.284
-117.345
-117.41
-117.479
-117.549
-117.621
-117.694
-117.767
-117.839
-117.91
-117.98
-118.047
-118.111
-118.171
-118.228
-118.28
-118.327
-118.37
-118.406
-118.437
-118.462
-118.481
-118.494
-118.5
-121.476
-121.47
-121.458
-121.441
-121.418
-121.39
-121.356
-121.317
-121.274
-121.227
-121.175
-121.12
-121.061
-121
-120.937
-120.873
-120.807
-120.741
-120.675
-120.61
-120.546
-120.484
-120.426
-120.37
-120.319
-120.272
-120.231
-120.194
-120.164
-120.14
-120.123
-120.113
-120.109
-120.113
-120.123
-120.14
-120.164
-120.194
-120.231
-120.272
-120.319
-120.37
-120.426
-120.484
-120.546
-120.61
-120.675
-120.741
-120.807
-120.873
-120.937
-121
-121.061
-121.12
-121.175
-121.227
-121.274
-121.317
-121.356
-121.39
-121.418
-121.441
-121.458
-121.47
-121.476
-124.457
-124.452
-124.441
-124.425
-124.404
-124.378
-124.347
-124.312
-124.273
-124.229
-124.182
-124.132
-124.079
-124.023
-123.966
-123.907
-123.848
-123.788
-123.728
-123.669
-123.611
-123.556
-123.503
-123.453
-123.406
-123.364
-123.326
-123.294
-123.267
-123.245
-123.23
-123.22
-123.217
-123.22
-123.23
-123.245
-123.267
-123.294
-123.326
-123.364
-123.406
-123.453
-123.503
-123.556
-123.611
-123.669
-123.728
-123.788
-123.848
-123.907
-123.966
-124.023
-124.079
-124.132
-124.182
-124.229
-124.273
-124.312
-124.347
-124.378
-124.404
-124.425
-124.441
-124.452
-124.457
-127.443
-127.439
-127.429
-127.414
-127.395
-127.372
-127.344
-127.311
-127.275
-127.236
-127.193
-127.147
-127.099
-127.048
-126.996
-126.943
-126.889
-126.834
-126.78
-126.727
-126.674
-126.624
-126.576
-126.531
-126.489
-126.451
-126.417
-126.388
-126.363
-126.344
-126.33
-126.322
-126.319
-126.322
-126.33
-126.344
-126.363
-126.388
-126.417
-126.451
-126.489
-126.531
-126.576
-126.624
-126.674
-126.727
-126.78
-126.834
-126.889
-126.943
-126.996
-127.048
-127.099
-127.147
-127.193
-127.236
-127.275
-127.311
-127.344
-127.372
-127.395
-127.414
-127.429
-127.439
-127.443
-130.435
-130.43
-130.422
-130.408
-130.391
-130.369
-130.344
-130.314
-130.282
-130.246
-130.207
-130.165
-130.121
-130.075
-130.028
-129.979
-129.93
-129.88
-129.831
-129.783
-129.736
-129.69
-129.647
-129.606
-129.568
-129.534
-129.504
-129.477
-129.455
-129.438
-129.425
-129.417
-129.415
-129.417
-129.425
-129.438
-129.455
-129.477
-129.504
-129.534
-129.568
-129.606
-129.647
-129.69
-129.736
-129.783
-129.831
-129.88
-129.93
-129.979
-130.028
-130.075
-130.121
-130.165
-130.207
-130.246
-130.282
-130.314
-130.344
-130.369
-130.391
-130.408
-130.422
-130.43
-130.435
-133.431
-133.427
-133.419
-133.407
-133.391
-133.371
-133.348
-133.321
-133.291
-133.258
-133.223
-133.185
-133.145
-133.103
-133.06
-133.016
-132.971
-132.927
-132.882
-132.838
-132.796
-132.754
-132.715
-132.678
-132.644
-132.613
-132.586
-132.562
-132.542
-132.526
-132.515
-132.508
-132.505
-132.508
-132.515
-132.526
-132.542
-132.562
-132.586
-132.613
-132.644
-132.678
-132.715
-132.754
-132.796
-132.838
-132.882
-132.927
-132.971
-133.016
-133.06
-133.103
-133.145
-133.185
-133.223
-133.258
-133.291
-133.321
-133.348
-133.371
-133.391
-133.407
-133.419
-133.427
-133.431
-136.431
-136.427
-136.42
-136.409
-136.395
-136.377
-136.355
-136.331
-136.304
-136.274
-136.241
-136.207
-136.171
-136.133
-136.093
-136.054
-136.013
-135.972
-135.932
-135.892
-135.854
-135.816
-135.781
-135.748
-135.717
-135.689
-135.664
-135.642
-135.624
-135.61
-135.6
-135.594
-135.592
-135.594
-135.6
-135.61
-135.624
-135.642
-135.664
-135.689
-135.717
-135.748
-135.781
-135.816
-135.854
-135.892
-135.932
-135.972
-136.013
-136.054
-136.093
-136.133
-136.171
-136.207
-136.241
-136.274
-136.304
-136.331
-136.355
-136.377
-136.395
-136.409
-136.42
-136.427
-136.431
-139.435
-139.432
-139.425
-139.415
-139.402
-139.385
-139.366
-139.344
-139.319
-139.292
-139.262
-139.231
-139.198
-139.163
-139.128
-139.092
-139.055
-139.018
-138.981
-138.945
-138.91
-138.877
-138.845
-138.814
-138.787
-138.761
-138.739
-138.719
-138.703
-138.69
-138.681
-138.675
-138.673
-138.675
-138.681
-138.69
-138.703
-138.719
-138.739
-138.761
-138.787
-138.814
-138.845
-138.877
-138.91
-138.945
-138.981
-139.018
-139.055
-139.092
-139.128
-139.163
-139.198
-139.231
-139.262
-139.292
-139.319
-139.344
-139.366
-139.385
-139.402
-139.415
-139.425
-139.432
-139.435
-142.443
-142.439
-142.433
-142.424
-142.412
-142.397
-142.38
-142.359
-142.337
-142.312
-142.285
-142.257
-142.227
-142.195
-142.163
-142.13
-142.097
-142.063
-142.03
-141.997
-141.966
-141.935
-141.906
-141.879
-141.854
-141.831
-141.81
-141.793
-141.778
-141.767
-141.758
-141.753
-141.751
-141.753
-141.758
-141.767
-141.778
-141.793
-141.81
-141.831
-141.854
-141.879
-141.906
-141.935
-141.966
-141.997
-142.03
-142.063
-142.097
-142.13
-142.163
-142.195
-142.227
-142.257
-142.285
-142.312
-142.337
-142.359
-142.38
-142.397
-142.412
-142.424
-142.433
-142.439
-142.443
-145.453
-145.45
-145.445
-145.436
-145.425
-145.412
-145.396
-145.377
-145.357
-145.334
-145.31
-145.284
-145.257
-145.228
-145.199
-145.169
-145.139
-145.108
-145.078
-145.049
-145.02
-144.992
-144.966
-144.941
-144.918
-144.898
-144.879
-144.863
-144.85
-144.84
-144.832
-144.828
-144.826
-144.828
-144.832
-144.84
-144.85
-144.863
-144.879
-144.898
-144.918
-144.941
-144.966
-144.992
-145.02
-145.049
-145.078
-145.108
-145.139
-145.169
-145.199
-145.228
-145.257
-145.284
-145.31
-145.334
-145.357
-145.377
-145.396
-145.412
-145.425
-145.436
-145.445
-145.45
-145.453
-148.466
-148.464
-148.459
-148.451
-148.441
-148.429
-148.414
-148.397
-148.379
-148.358
-148.336
-148.313
-148.288
-148.262
-148.235
-148.208
-148.181
-148.153
-148.126
-148.099
-148.073
-148.048
-148.024
-148.002
-147.981
-147.962
-147.946
-147.931
-147.919
-147.91
-147.903
-147.899
-147.898
-147.899
-147.903
-147.91
-147.919
-147.931
-147.946
-147.962
-147.981
-148.002
-148.024
-148.048
-148.073
-148.099
-148.126
-148.153
-148.181
-148.208
-148.235
-148.262
-148.288
-148.313
-148.336
-148.358
-148.379
-148.397
-148.414
-148.429
-148.441
-148.451
-148.459
-148.464
-148.466
-151.482
-151.48
-151.475
-151.469
-151.459
-151.448
-151.435
-151.42
-151.403
-151.384
-151.364
-151.342
-151.32
-151.296
-151.272
-151.248
-151.223
-151.198
-151.173
-151.149
-151.125
-151.102
-151.081
-151.061
-151.042
-151.025
-151.01
-150.997
-150.986
-150.977
-150.971
-150.968
-150.966
-150.968
-150.971
-150.977
-150.986
-150.997
-151.01
-151.025
-151.042
-151.061
-151.081
-151.102
-151.125
-151.149
-151.173
-151.198
-151.223
-151.248
-151.272
-151.296
-151.32
-151.342
-151.364
-151.384
-151.403
-151.42
-151.435
-151.448
-151.459
-151.469
-151.475
-151.48
-151.482
-154.501
-154.499
-154.494
-154.488
-154.48
-154.47
-154.457
-154.444
-154.428
-154.411
-154.393
-154.373
-154.353
-154.332
-154.31
-154.287
-154.265
-154.242
-154.22
-154.198
-154.176
-154.156
-154.136
-154.118
-154.101
-154.086
-154.072
-154.06
-154.05
-154.043
-154.037
-154.034
-154.033
-154.034
-154.037
-154.043
-154.05
-154.06
-154.072
-154.086
-154.101
-154.118
-154.136
-154.156
-154.176
-154.198
-154.22
-154.242
-154.265
-154.287
-154.31
-154.332
-154.353
-154.373
-154.393
-154.411
-154.428
-154.444
-154.457
-154.47
-154.48
-154.488
-154.494
-154.499
-154.501
-157.521
-157.519
-157.515
-157.51
-157.502
-157.493
-157.482
-157.469
-157.455
-157.44
-157.423
-157.405
-157.387
-157.368
-157.348
-157.327
-157.307
-157.286
-157.266
-157.246
-157.227
-157.208
-157.19
-157.174
-157.158
-157.144
-157.132
-157.121
-157.113
-157.106
-157.1
-157.097
-157.096
-157.097
-157.1
-157.106
-157.113
-157.121
-157.132
-157.144
-157.158
-157.174
-157.19
-157.208
-157.227
-157.246
-157.266
-157.286
-157.307
-157.327
-157.348
-157.368
-157.387
-157.405
-157.423
-157.44
-157.455
-157.469
-157.482
-157.493
-157.502
-157.51
-157.515
-157.519
-157.521
-160.544
-160.542
-160.538
-160.533
-160.526
-160.518
-160.508
-160.496
-160.484
-160.47
-160.455
-160.438
-160.422
-160.404
-160.386
-160.367
-160.349
-160.33
-160.312
-160.294
-160.276
-160.259
-160.243
-160.228
-160.214
-160.202
-160.191
-160.181
-160.173
-160.166
-160.162
-160.159
-160.158
-160.159
-160.162
-160.166
-160.173
-160.181
-160.191
-160.202
-160.214
-160.228
-160.243
-160.259
-160.276
-160.294
-160.312
-160.33
-160.349
-160.367
-160.386
-160.404
-160.422
-160.438
-160.455
-160.47
-160.484
-160.496
-160.508
-160.518
-160.526
-160.533
-160.538
-160.542
-160.544
-163.568
-163.566
-163.563
-163.558
-163.552
-163.544
-163.535
-163.525
-163.513
-163.501
-163.487
-163.472
-163.457
-163.441
-163.425
-163.408
-163.391
-163.374
-163.357
-163.341
-163.325
-163.31
-163.295
-163.282
-163.269
-163.258
-163.247
-163.239
-163.231
-163.226
-163.222
-163.219
-163.218
-163.219
-163.222
-163.226
-163.231
-163.239
-163.247
-163.258
-163.269
-163.282
-163.295
-163.31
-163.325
-163.341
-163.357
-163.374
-163.391
-163.408
-163.425
-163.441
-163.457
-163.472
-163.487
-163.501
-163.513
-163.525
-163.535
-163.544
-163.552
-163.558
-163.563
-163.566
-163.568
-166.594
-166.592
-166.589
-166.585
-166.579
-166.572
-166.564
-166.555
-166.544
-166.533
-166.52
-166.507
-166.493
-166.478
-166.463
-166.448
-166.433
-166.418
-166.402
-166.388
-166.373
-166.359
-166.346
-166.334
-166.322
-166.312
-166.303
-166.295
-166.288
-166.283
-166.279
-166.277
-166.276
-166.277
-166.279
-166.283
-166.288
-166.295
-166.303
-166.312
-166.322
-166.334
-166.346
-166.359
-166.373
-166.388
-166.402
-166.418
-166.433
-166.448
-166.463
-166.478
-166.493
-166.507
-166.52
-166.533
-166.544
-166.555
-166.564
-166.572
-166.579
-166.585
-166.589
-166.592
-166.594
-169.621
-169.62
-169.617
-169.613
-169.608
-169.602
-169.594
-169.586
-169.576
-169.565
-169.554
-169.542
-169.529
-169.516
-169.503
-169.489
-169.475
-169.461
-169.447
-169.434
-169.421
-169.408
-169.396
-169.385
-169.375
-169.365
-169.357
-169.35
-169.344
-169.339
-169.336
-169.334
-169.333
-169.334
-169.336
-169.339
-169.344
-169.35
-169.357
-169.365
-169.375
-169.385
-169.396
-169.408
-169.421
-169.434
-169.447
-169.461
-169.475
-169.489
-169.503
-169.516
-169.529
-169.542
-169.554
-169.565
-169.576
-169.586
-169.594
-169.602
-169.608
-169.613
-169.617
-169.62
-169.621
-172.65
-172.648
-172.646
-172.643
-172.638
-172.632
-172.625
-172.617
-172.609
-172.599
-172.589
-172.578
-172.566
-172.555
-172.542
-172.53
-172.517
-172.505
-172.492
-172.48
-172.468
-172.457
-172.446
-172.436
-172.426
-172.418
-172.41
-172.404
-172.398
-172.394
-172.391
-172.389
-172.389
-172.389
-172.391
-172.394
-172.398
-172.404
-172.41
-172.418
-172.426
-172.436
-172.446
-172.457
-172.468
-172.48
-172.492
-172.505
-172.517
-172.53
-172.542
-172.555
-172.566
-172.578
-172.589
-172.599
-172.609
-172.617
-172.625
-172.632
-172.638
-172.643
-172.646
-172.648
-172.65
-175.68
-175.678
-175.676
-175.673
-175.669
-175.664
-175.657
-175.65
-175.642
-175.634
-175.624
-175.614
-175.604
-175.593
-175.582
-175.571
-175.559
-175.548
-175.536
-175.525
-175.515
-175.504
-175.494
-175.485
-175.477
-175.469
-175.462
-175.456
-175.451
-175.448
-175.445
-175.443
-175.443
-175.443
-175.445
-175.448
-175.451
-175.456
-175.462
-175.469
-175.477
-175.485
-175.494
-175.504
-175.515
-175.525
-175.536
-175.548
-175.559
-175.571
-175.582
-175.593
-175.604
-175.614
-175.624
-175.634
-175.642
-175.65
-175.657
-175.664
-175.669
-175.673
-175.676
-175.678
-175.68
-178.71
-178.709
-178.708
-178.705
-178.701
-178.696
-178.69
-178.684
-178.677
-178.669
-178.66
-178.651
-178.642
-178.632
-178.622
-178.612
-178.601
-178.591
-178.581
-178.571
-178.561
-178.551
-178.542
-178.534
-178.526
-178.519
-178.513
-178.508
-178.504
-178.5
-178.498
-178.496
-178.495
-178.496
-178.498
-178.5
-178.504
-178.508
-178.513
-178.519
-178.526
-178.534
-178.542
-178.551
-178.561
-178.571
-178.581
-178.591
-178.601
-178.612
-178.622
-178.632
-178.642
-178.651
-178.66
-178.669
-178.677
-178.684
-178.69
-178.696
-178.701
-178.705
-178.708
-178.709
-178.71
-181.742
-181.742
-181.74
-181.737
-181.734
-181.729
-181.724
-181.718
-181.712
-181.705
-181.697
-181.689
-181.68
-181.671
-181.662
-181.653
-181.643
-181.634
-181.625
-181.615
-181.607
-181.598
-181.59
-181.582
-181.575
-181.569
-181.564
-181.559
-181.555
-181.552
-181.549
-181.548
-181.547
-181.548
-181.549
-181.552
-181.555
-181.559
-181.564
-181.569
-181.575
-181.582
-181.59
-181.598
-181.607
-181.615
-181.625
-181.634
-181.643
-181.653
-181.662
-181.671
-181.68
-181.689
-181.697
-181.705
-181.712
-181.718
-181.724
-181.729
-181.734
-181.737
-181.74
-181.742
-181.742
-184.775
-184.775
-184.773
-184.77
-184.767
-184.763
-184.759
-184.753
-184.747
-184.741
-184.734
-184.727
-184.719
-184.711
-184.702
-184.694
-184.685
-184.677
-184.668
-184.66
-184.652
-184.644
-184.637
-184.63
-184.624
-184.618
-184.613
-184.609
-184.605
-184.602
-184.6
-184.599
-184.598
-184.599
-184.6
-184.602
-184.605
-184.609
-184.613
-184.618
-184.624
-184.63
-184.637
-184.644
-184.652
-184.66
-184.668
-184.677
-184.685
-184.694
-184.702
-184.711
-184.719
-184.727
-184.734
-184.741
-184.747
-184.753
-184.759
-184.763
-184.767
-184.77
-184.773
-184.775
-184.775
-187.809
-187.808
-187.807
-187.805
-187.802
-187.798
-187.794
-187.789
-187.784
-187.778
-187.772
-187.765
-187.758
-187.75
-187.743
-187.735
-187.727
-187.72
-187.712
-187.704
-187.697
-187.69
-187.683
-187.677
-187.672
-187.666
-187.662
-187.658
-187.654
-187.652
-187.65
-187.649
-187.648
-187.649
-187.65
-187.652
-187.654
-187.658
-187.662
-187.666
-187.672
-187.677
-187.683
-187.69
-187.697
-187.704
-187.712
-187.72
-187.727
-187.735
-187.743
-187.75
-187.758
-187.765
-187.772
-187.778
-187.784
-187.789
-187.794
-187.798
-187.802
-187.805
-187.807
-187.808
-187.809
-190.844
-190.843
-190.842
-190.84
-190.837
-190.834
-190.83
-190.825
-190.821
-190.815
-190.809
-190.803
-190.797
-190.79
-190.783
-190.776
-190.769
-190.762
-190.755
-190.748
-190.742
-190.736
-190.73
-190.724
-190.719
-190.714
-190.71
-190.706
-190.703
-190.701
-190.699
-190.698
-190.698
-190.698
-190.699
-190.701
-190.703
-190.706
-190.71
-190.714
-190.719
-190.724
-190.73
-190.736
-190.742
-190.748
-190.755
-190.762
-190.769
-190.776
-190.783
-190.79
-190.797
-190.803
-190.809
-190.815
-190.821
-190.825
-190.83
-190.834
-190.837
-190.84
-190.842
-190.843
-190.844
-193.879
-193.878
-193.877
-193.875
-193.873
-193.87
-193.866
-193.862
-193.858
-193.853
-193.848
-193.842
-193.836
-193.83
-193.824
-193.818
-193.811
-193.805
-193.799
-193.792
-193.786
-193.781
-193.775
-193.77
-193.765
-193.761
-193.757
-193.754
-193.751
-193.749
-193.748
-193.747
-193.746
-193.747
-193.748
-193.749
-193.751
-193.754
-193.757
-193.761
-193.765
-193.77
-193.775
-193.781
-193.786
-193.792
-193.799
-193.805
-193.811
-193.818
-193.824
-193.83
-193.836
-193.842
-193.848
-193.853
-193.858
-193.862
-193.866
-193.87
-193.873
-193.875
-193.877
-193.878
-193.879
-196.914
-196.914
-196.913
-196.911
-196.909
-196.906
-196.903
-196.9
-196.895
-196.891
-196.886
-196.881
-196.876
-196.87
-196.865
-196.859
-196.853
-196.847
-196.842
-196.836
-196.831
-196.825
-196.821
-196.816
-196.812
-196.808
-196.804
-196.801
-196.799
-196.797
-196.796
-196.795
-196.794
-196.795
-196.796
-196.797
-196.799
-196.801
-196.804
-196.808
-196.812
-196.816
-196.821
-196.825
-196.831
-196.836
-196.842
-196.847
-196.853
-196.859
-196.865
-196.87
-196.876
-196.881
-196.886
-196.891
-196.895
-196.9
-196.903
-196.906
-196.909
-196.911
-196.913
-196.914
-196.914
-199.951
-199.95
-199.949
-199.948
-199.946
-199.943
-199.941
-199.937
-199.934
-199.93
-199.925
-199.921
-199.916
-199.911
-199.906
-199.9
-199.895
-199.89
-199.885
-199.88
-199.875
-199.87
-199.866
-199.861
-199.857
-199.854
-199.851
-199.848
-199.846
-199.844
-199.843
-199.842
-199.842
-199.842
-199.843
-199.844
-199.846
-199.848
-199.851
-199.854
-199.857
-199.861
-199.866
-199.87
-199.875
-199.88
-199.885
-199.89
-199.895
-199.9
-199.906
-199.911
-199.916
-199.921
-199.925
-199.93
-199.934
-199.937
-199.941
-199.943
-199.946
-199.948
-199.949
-199.95
-199.951
-202.988
-202.987
-202.986
-202.985
-202.983
-202.981
-202.978
-202.975
-202.972
-202.968
-202.964
-202.96
-202.956
-202.951
-202.947
-202.942
-202.937
-202.932
-202.928
-202.923
-202.919
-202.914
-202.91
-202.906
-202.903
-202.9
-202.897
-202.894
-202.892
-202.891
-202.89
-202.889
-202.889
-202.889
-202.89
-202.891
-202.892
-202.894
-202.897
-202.9
-202.903
-202.906
-202.91
-202.914
-202.919
-202.923
-202.928
-202.932
-202.937
-202.942
-202.947
-202.951
-202.956
-202.96
-202.964
-202.968
-202.972
-202.975
-202.978
-202.981
-202.983
-202.985
-202.986
-202.987
-202.988
-206.025
-206.025
-206.024
-206.022
-206.021
-206.019
-206.016
-206.014
-206.011
-206.007
-206.004
-206
-205.996
-205.992
-205.988
-205.983
-205.979
-205.975
-205.971
-205.966
-205.962
-205.958
-205.955
-205.951
-205.948
-205.945
-205.943
-205.94
-205.939
-205.937
-205.936
-205.935
-205.935
-205.935
-205.936
-205.937
-205.939
-205.94
-205.943
-205.945
-205.948
-205.951
-205.955
-205.958
-205.962
-205.966
-205.971
-205.975
-205.979
-205.983
-205.988
-205.992
-205.996
-206
-206.004
-206.007
-206.011
-206.014
-206.016
-206.019
-206.021
-206.022
-206.024
-206.025
-206.025
-209.063
-209.062
-209.062
-209.06
-209.059
-209.057
-209.055
-209.053
-209.05
-209.047
-209.044
-209.04
-209.037
-209.033
-209.029
-209.025
-209.021
-209.017
-209.013
-209.009
-209.006
-209.002
-208.999
-208.996
-208.993
-208.99
-208.988
-208.986
-208.984
-208.983
-208.982
-208.981
-208.981
-208.981
-208.982
-208.983
-208.984
-208.986
-208.988
-208.99
-208.993
-208.996
-208.999
-209.002
-209.006
-209.009
-209.013
-209.017
-209.021
-209.025
-209.029
-209.033
-209.037
-209.04
-209.044
-209.047
-209.05
-209.053
-209.055
-209.057
-209.059
-209.06
-209.062
-209.062
-209.063
-212.101
-212.1
-212.1
-212.099
-212.097
-212.096
-212.094
-212.092
-212.089
-212.086
-212.083
-212.08
-212.077
-212.074
-212.07
-212.067
-212.063
-212.059
-212.056
-212.052
-212.049
-212.046
-212.043
-212.04
-212.037
-212.035
-212.033
-212.031
-212.03
-212.028
-212.028
-212.027
-212.027
-212.027
-212.028
-212.028
-212.03
-212.031
-212.033
-212.035
-212.037
-212.04
-212.043
-212.046
-212.049
-212.052
-212.056
-212.059
-212.063
-212.067
-212.07
-212.074
-212.077
-212.08
-212.083
-212.086
-212.089
-212.092
-212.094
-212.096
-212.097
-212.099
-212.1
-212.1
-212.101
-215.139
-215.139
-215.138
-215.137
-215.136
-215.135
-215.133
-215.131
-215.129
-215.126
-215.124
-215.121
-215.118
-215.115
-215.111
-215.108
-215.105
-215.102
-215.099
-215.095
-215.092
-215.089
-215.087
-215.084
-215.082
-215.08
-215.078
-215.076
-215.075
-215.074
-215.073
-215.072
-215.072
-215.072
-215.073
-215.074
-215.075
-215.076
-215.078
-215.08
-215.082
-215.084
-215.087
-215.089
-215.092
-215.095
-215.099
-215.102
-215.105
-215.108
-215.111
-215.115
-215.118
-215.121
-215.124
-215.126
-215.129
-215.131
-215.133
-215.135
-215.136
-215.137
-215.138
-215.139
-215.139
-218.178
-218.178
-218.177
-218.176
-218.175
-218.174
-218.172
-218.17
-218.168
-218.166
-218.164
-218.161
-218.158
-218.156
-218.153
-218.15
-218.147
-218.144
-218.141
-218.138
-218.135
-218.133
-218.13
-218.128
-218.126
-218.124
-218.122
-218.121
-218.119
-218.118
-218.118
-218.117
-218.117
-218.117
-218.118
-218.118
-218.119
-218.121
-218.122
-218.124
-218.126
-218.128
-218.13
-218.133
-218.135
-218.138
-218.141
-218.144
-218.147
-218.15
-218.153
-218.156
-218.158
-218.161
-218.164
-218.166
-218.168
-218.17
-218.172
-218.174
-218.175
-218.176
-218.177
-218.178
-218.178
-221.217
-221.217
-221.216
-221.216
-221.215
-221.213
-221.212
-221.21
-221.208
-221.206
-221.204
-221.202
-221.199
-221.197
-221.194
-221.192
-221.189
-221.186
-221.184
-221.181
-221.178
-221.176
-221.174
-221.172
-221.17
-221.168
-221.166
-221.165
-221.164
-221.163
-221.162
-221.162
-221.162
-221.162
-221.162
-221.163
-221.164
-221.165
-221.166
-221.168
-221.17
-221.172
-221.174
-221.176
-221.178
-221.181
-221.184
-221.186
-221.189
-221.192
-221.194
-221.197
-221.199
-221.202
-221.204
-221.206
-221.208
-221.21
-221.212
-221.213
-221.215
-221.216
-221.216
-221.217
-221.217
-224.257
-224.256
-224.256
-224.255
-224.254
-224.253
-224.252
-224.25
-224.249
-224.247
-224.245
-224.243
-224.24
-224.238
-224.236
-224.233
-224.231
-224.228
-224.226
-224.224
-224.221
-224.219
-224.217
-224.215
-224.213
-224.212
-224.21
-224.209
-224.208
-224.207
-224.207
-224.206
-224.206
-224.206
-224.207
-224.207
-224.208
-224.209
-224.21
-224.212
-224.213
-224.215
-224.217
-224.219
-224.221
-224.224
-224.226
-224.228
-224.231
-224.233
-224.236
-224.238
-224.24
-224.243
-224.245
-224.247
-224.249
-224.25
-224.252
-224.253
-224.254
-224.255
-224.256
-224.256
-224.257
-227.296
-227.296
-227.295
-227.295
-227.294
-227.293
-227.292
-227.29
-227.289
-227.287
-227.285
-227.283
-227.281
-227.279
-227.277
-227.275
-227.273
-227.27
-227.268
-227.266
-227.264
-227.262
-227.26
-227.258
-227.257
-227.255
-227.254
-227.253
-227.252
-227.251
-227.251
-227.25
-227.25
-227.25
-227.251
-227.251
-227.252
-227.253
-227.254
-227.255
-227.257
-227.258
-227.26
-227.262
-227.264
-227.266
-227.268
-227.27
-227.273
-227.275
-227.277
-227.279
-227.281
-227.283
-227.285
-227.287
-227.289
-227.29
-227.292
-227.293
-227.294
-227.295
-227.295
-227.296
-227.296
-230.336
-230.336
-230.335
-230.335
-230.334
-230.333
-230.332
-230.331
-230.329
-230.328
-230.326
-230.324
-230.322
-230.321
-230.319
-230.317
-230.315
-230.313
-230.311
-230.309
-230.307
-230.305
-230.303
-230.302
-230.3
-230.299
-230.298
-230.297
-230.296
-230.295
-230.295
-230.294
-230.294
-230.294
-230.295
-230.295
-230.296
-230.297
-230.298
-230.299
-230.3
-230.302
-230.303
-230.305
-230.307
-230.309
-230.311
-230.313
-230.315
-230.317
-230.319
-230.321
-230.322
-230.324
-230.326
-230.328
-230.329
-230.331
-230.332
-230.333
-230.334
-230.335
-230.335
-230.336
-230.336
-233.376
-233.376
-233.375
-233.375
-233.374
-233.373
-233.372
-233.371
-233.37
-233.368
-233.367
-233.365
-233.364
-233.362
-233.36
-233.358
-233.356
-233.355
-233.353
-233.351
-233.349
-233.348
-233.346
-233.345
-233.343
-233.342
-233.341
-233.34
-233.339
-233.339
-233.338
-233.338
-233.338
-233.338
-233.338
-233.339
-233.339
-233.34
-233.341
-233.342
-233.343
-233.345
-233.346
-233.348
-233.349
-233.351
-233.353
-233.355
-233.356
-233.358
-233.36
-233.362
-233.364
-233.365
-233.367
-233.368
-233.37
-233.371
-233.372
-233.373
-233.374
-233.375
-233.375
-233.376
-233.376
-236.416
-236.416
-236.416
-236.415
-236.414
-236.414
-236.413
-236.412
-236.411
-236.409
-236.408
-236.406
-236.405
-236.403
-236.402
-236.4
-236.398
-236.397
-236.395
-236.393
-236.392
-236.39
-236.389
-236.388
-236.386
-236.385
-236.384
-236.383
-236.383
-236.382
-236.382
-236.382
-236.381
-236.382
-236.382
-236.382
-236.383
-236.383
-236.384
-236.385
-236.386
-236.388
-236.389
-236.39
-236.392
-236.393
-236.395
-236.397
-236.398
-236.4
-236.402
-236.403
-236.405
-236.406
-236.408
-236.409
-236.411
-236.412
-236.413
-236.414
-236.414
-236.415
-236.416
-236.416
-236.416
-239.456
-239.456
-239.456
-239.456
-239.455
-239.454
-239.453
-239.452
-239.451
-239.45
-239.449
-239.448
-239.446
-239.445
-239.443
-239.442
-239.44
-239.439
-239.437
-239.436
-239.434
-239.433
-239.432
-239.43
-239.429
-239.428
-239.427
-239.427
-239.426
-239.426
-239.425
-239.425
-239.425
-239.425
-239.425
-239.426
-239.426
-239.427
-239.427
-239.428
-239.429
-239.43
-239.432
-239.433
-239.434
-239.436
-239.437
-239.439
-239.44
-239.442
-239.443
-239.445
-239.446
-239.448
-239.449
-239.45
-239.451
-239.452
-239.453
-239.454
-239.455
-239.456
-239.456
-239.456
-239.456
-242.497
-242.497
-242.496
-242.496
-242.496
-242.495
-242.494
-242.493
-242.492
-242.491
-242.49
-242.489
-242.488
-242.486
-242.485
-242.484
-242.482
-242.481
-242.479
-242.478
-242.477
-242.476
-242.474
-242.473
-242.472
-242.471
-242.47
-242.47
-242.469
-242.469
-242.468
-242.468
-242.468
-242.468
-242.468
-242.469
-242.469
-242.47
-242.47
-242.471
-242.472
-242.473
-242.474
-242.476
-242.477
-242.478
-242.479
-242.481
-242.482
-242.484
-242.485
-242.486
-242.488
-242.489
-242.49
-242.491
-242.492
-242.493
-242.494
-242.495
-242.496
-242.496
-242.496
-242.497
-242.497
-245.537
-245.537
-245.537
-245.537
-245.536
-245.536
-245.535
-245.534
-245.533
-245.532
-245.531
-245.53
-245.529
-245.528
-245.527
-245.525
-245.524
-245.523
-245.522
-245.52
-245.519
-245.518
-245.517
-245.516
-245.515
-245.514
-245.513
-245.513
-245.512
-245.512
-245.511
-245.511
-245.511
-245.511
-245.511
-245.512
-245.512
-245.513
-245.513
-245.514
-245.515
-245.516
-245.517
-245.518
-245.519
-245.52
-245.522
-245.523
-245.524
-245.525
-245.527
-245.528
-245.529
-245.53
-245.531
-245.532
-245.533
-245.534
-245.535
-245.536
-245.536
-245.537
-245.537
-245.537
-245.537
-248.578
-248.578
-248.578
-248.578
-248.577
-248.577
-248.576
-248.575
-248.574
-248.574
-248.573
-248.572
-248.57
-248.569
-248.568
-248.567
-248.566
-248.565
-248.564
-248.563
-248.561
-248.56
-248.559
-248.558
-248.558
-248.557
-248.556
-248.556
-248.555
-248.555
-248.554
-248.554
-248.554
-248.554
-248.554
-248.555
-248.555
-248.556
-248.556
-248.557
-248.558
-248.558
-248.559
-248.56
-248.561
-248.563
-248.564
-248.565
-248.566
-248.567
-248.568
-248.569
-248.57
-248.572
-248.573
-248.574
-248.574
-248.575
-248.576
-248.577
-248.577
-248.578
-248.578
-248.578
-248.578
-251.619
-251.619
-251.619
-251.618
-251.618
-251.618
-251.617
-251.616
-251.616
-251.615
-251.614
-251.613
-251.612
-251.611
-251.61
-251.609
-251.608
-251.607
-251.606
-251.605
-251.604
-251.603
-251.602
-251.601
-251.6
-251.599
-251.599
-251.598
-251.598
-251.598
-251.597
-251.597
-251.597
-251.597
-251.597
-251.598
-251.598
-251.598
-251.599
-251.599
-251.6
-251.601
-251.602
-251.603
-251.604
-251.605
-251.606
-251.607
-251.608
-251.609
-251.61
-251.611
-251.612
-251.613
-251.614
-251.615
-251.616
-251.616
-251.617
-251.618
-251.618
-251.618
-251.619
-251.619
-251.619
-254.66
-254.66
-254.66
-254.659
-254.659
-254.659
-254.658
-254.658
-254.657
-254.656
-254.655
-254.654
-254.654
-254.653
-254.652
-254.651
-254.65
-254.649
-254.648
-254.647
-254.646
-254.645
-254.644
-254.643
-254.643
-254.642
-254.641
-254.641
-254.641
-254.64
-254.64
-254.64
-254.64
-254.64
-254.64
-254.64
-254.641
-254.641
-254.641
-254.642
-254.643
-254.643
-254.644
-254.645
-254.646
-254.647
-254.648
-254.649
-254.65
-254.651
-254.652
-254.653
-254.654
-254.654
-254.655
-254.656
-254.657
-254.658
-254.658
-254.659
-254.659
-254.659
-254.66
-254.66
-254.66
-257.701
-257.701
-257.701
-257.701
-257.7
-257.7
-257.699
-257.699
-257.698
-257.697
-257.697
-257.696
-257.695
-257.694
-257.693
-257.692
-257.692
-257.691
-257.69
-257.689
-257.688
-257.687
-257.687
-257.686
-257.685
-257.685
-257.684
-257.684
-257.683
-257.683
-257.683
-257.683
-257.682
-257.683
-257.683
-257.683
-257.683
-257.684
-257.684
-257.685
-257.685
-257.686
-257.687
-257.687
-257.688
-257.689
-257.69
-257.691
-257.692
-257.692
-257.693
-257.694
-257.695
-257.696
-257.697
-257.697
-257.698
-257.699
-257.699
-257.7
-257.7
-257.701
-257.701
-257.701
-257.701
-260.742
-260.742
-260.742
-260.742
-260.741
-260.741
-260.741
-260.74
-260.74
-260.739
-260.738
-260.737
-260.737
-260.736
-260.735
-260.734
-260.733
-260.733
-260.732
-260.731
-260.73
-260.729
-260.729
-260.728
-260.728
-260.727
-260.726
-260.726
-260.726
-260.725
-260.725
-260.725
-260.725
-260.725
-260.725
-260.725
-260.726
-260.726
-260.726
-260.727
-260.728
-260.728
-260.729
-260.729
-260.73
-260.731
-260.732
-260.733
-260.733
-260.734
-260.735
-260.736
-260.737
-260.737
-260.738
-260.739
-260.74
-260.74
-260.741
-260.741
-260.741
-260.742
-260.742
-260.742
-260.742
-263.783
-263.783
-263.783
-263.783
-263.783
-263.782
-263.782
-263.781
-263.781
-263.78
-263.78
-263.779
-263.778
-263.778
-263.777
-263.776
-263.775
-263.775
-263.774
-263.773
-263.772
-263.772
-263.771
-263.77
-263.77
-263.769
-263.769
-263.768
-263.768
-263.768
-263.768
-263.768
-263.768
-263.768
-263.768
-263.768
-263.768
-263.768
-263.769
-263.769
-263.77
-263.77
-263.771
-263.772
-263.772
-263.773
-263.774
-263.775
-263.775
-263.776
-263.777
-263.778
-263.778
-263.779
-263.78
-263.78
-263.781
-263.781
-263.782
-263.782
-263.783
-263.783
-263.783
-263.783
-263.783
-266.825
-266.825
-266.825
-266.824
-266.824
-266.824
-266.823
-266.823
-266.822
-266.822
-266.821
-266.821
-266.82
-266.819
-266.819
-266.818
-266.817
-266.816
-266.816
-266.815
-266.814
-266.814
-266.813
-266.813
-266.812
-266.812
-266.811
-266.811
-266.811
-266.81
-266.81
-266.81
-266.81
-266.81
-266.81
-266.81
-266.811
-266.811
-266.811
-266.812
-266.812
-266.813
-266.813
-266.814
-266.814
-266.815
-266.816
-266.816
-266.817
-266.818
-266.819
-266.819
-266.82
-266.821
-266.821
-266.822
-266.822
-266.823
-266.823
-266.824
-266.824
-266.824
-266.825
-266.825
-266.825
-269.866
-269.866
-269.866
-269.866
-269.866
-269.865
-269.865
-269.864
-269.864
-269.863
-269.863
-269.862
-269.862
-269.861
-269.86
-269.86
-269.859
-269.858
-269.858
-269.857
-269.856
-269.856
-269.855
-269.855
-269.854
-269.854
-269.853
-269.853
-269.853
-269.853
-269.852
-269.852
-269.852
-269.852
-269.852
-269.853
-269.853
-269.853
-269.853
-269.854
-269.854
-269.855
-269.855
-269.856
-269.856
-269.857
-269.858
-269.858
-269.859
-269.86
-269.86
-269.861
-269.862
-269.862
-269.863
-269.863
-269.864
-269.864
-269.865
-269.865
-269.866
-269.866
-269.866
-269.866
-269.866
-272.908
-272.908
-272.907
-272.907
-272.907
-272.907
-272.906
-272.906
-272.906
-272.905
-272.905
-272.904
-272.903
-272.903
-272.902
-272.902
-272.901
-272.9
-272.9
-272.899
-272.899
-272.898
-272.897
-272.897
-272.896
-272.896
-272.896
-272.895
-272.895
-272.895
-272.895
-272.895
-272.895
-272.895
-272.895
-272.895
-272.895
-272.895
-272.896
-272.896
-272.896
-272.897
-272.897
-272.898
-272.899
-272.899
-272.9
-272.9
-272.901
-272.902
-272.902
-272.903
-272.903
-272.904
-272.905
-272.905
-272.906
-272.906
-272.906
-272.907
-272.907
-272.907
-272.907
-272.908
-272.908
-275.949
-275.949
-275.949
-275.949
-275.949
-275.948
-275.948
-275.948
-275.947
-275.947
-275.946
-275.946
-275.945
-275.945
-275.944
-275.943
-275.943
-275.942
-275.942
-275.941
-275.941
-275.94
-275.939
-275.939
-275.939
-275.938
-275.938
-275.938
-275.937
-275.937
-275.937
-275.937
-275.937
-275.937
-275.937
-275.937
-275.937
-275.938
-275.938
-275.938
-275.939
-275.939
-275.939
-275.94
-275.941
-275.941
-275.942
-275.942
-275.943
-275.943
-275.944
-275.945
-275.945
-275.946
-275.946
-275.947
-275.947
-275.948
-275.948
-275.948
-275.949
-275.949
-275.949
-275.949
-275.949
-278.991
-278.991
-278.99
-278.99
-278.99
-278.99
-278.99
-278.989
-278.989
-278.988
-278.988
-278.987
-278.987
-278.986
-278.986
-278.985
-278.985
-278.984
-278.984
-278.983
-278.983
-278.982
-278.982
-278.981
-278.981
-278.98
-278.98
-278.98
-278.979
-278.979
-278.979
-278.979
-278.979
-278.979
-278.979
-278.979
-278.979
-278.98
-278.98
-278.98
-278.981
-278.981
-278.982
-278.982
-278.983
-278.983
-278.984
-278.984
-278.985
-278.985
-278.986
-278.986
-278.987
-278.987
-278.988
-278.988
-278.989
-278.989
-278.99
-278.99
-278.99
-278.99
-278.99
-278.991
-278.991
-282.032
-282.032
-282.032
-282.032
-282.032
-282.031
-282.031
-282.031
-282.03
-282.03
-282.03
-282.029
-282.029
-282.028
-282.028
-282.027
-282.027
-282.026
-282.025
-282.025
-282.024
-282.024
-282.024
-282.023
-282.023
-282.022
-282.022
-282.022
-282.022
-282.021
-282.021
-282.021
-282.021
-282.021
-282.021
-282.021
-282.022
-282.022
-282.022
-282.022
-282.023
-282.023
-282.024
-282.024
-282.024
-282.025
-282.025
-282.026
-282.027
-282.027
-282.028
-282.028
-282.029
-282.029
-282.03
-282.03
-282.03
-282.031
-282.031
-282.031
-282.032
-282.032
-282.032
-282.032
-282.032
-285.074
-285.074
-285.074
-285.074
-285.073
-285.073
-285.073
-285.073
-285.072
-285.072
-285.071
-285.071
-285.07
-285.07
-285.069
-285.069
-285.068
-285.068
-285.067
-285.067
-285.066
-285.066
-285.065
-285.065
-285.065
-285.064
-285.064
-285.064
-285.064
-285.063
-285.063
-285.063
-285.063
-285.063
-285.063
-285.063
-285.064
-285.064
-285.064
-285.064
-285.065
-285.065
-285.065
-285.066
-285.066
-285.067
-285.067
-285.068
-285.068
-285.069
-285.069
-285.07
-285.07
-285.071
-285.071
-285.072
-285.072
-285.073
-285.073
-285.073
-285.073
-285.074
-285.074
-285.074
-285.074
-288.116
-288.116
-288.115
-288.115
-288.115
-288.115
-288.115
-288.114
-288.114
-288.114
-288.113
-288.113
-288.112
-288.112
-288.111
-288.111
-288.11
-288.11
-288.109
-288.109
-288.108
-288.108
-288.107
-288.107
-288.107
-288.106
-288.106
-288.106
-288.106
-288.105
-288.105
-288.105
-288.105
-288.105
-288.105
-288.105
-288.106
-288.106
-288.106
-288.106
-288.107
-288.107
-288.107
-288.108
-288.108
-288.109
-288.109
-288.11
-288.11
-288.111
-288.111
-288.112
-288.112
-288.113
-288.113
-288.114
-288.114
-288.114
-288.115
-288.115
-288.115
-288.115
-288.115
-288.116
-288.116
-291.157
-291.157
-291.157
-291.157
-291.157
-291.157
-291.156
-291.156
-291.156
-291.155
-291.155
-291.155
-291.154
-291.154
-291.153
-291.153
-291.152
-291.152
-291.151
-291.151
-291.15
-291.15
-291.149
-291.149
-291.149
-291.148
-291.148
-291.148
-291.148
-291.147
-291.147
-291.147
-291.147
-291.147
-291.147
-291.147
-291.148
-291.148
-291.148
-291.148
-291.149
-291.149
-291.149
-291.15
-291.15
-291.151
-291.151
-291.152
-291.152
-291.153
-291.153
-291.154
-291.154
-291.155
-291.155
-291.155
-291.156
-291.156
-291.156
-291.157
-291.157
-291.157
-291.157
-291.157
-291.157
-294.199
-294.199
-294.199
-294.199
-294.199
-294.199
-294.198
-294.198
-294.198
-294.197
-294.197
-294.196
-294.196
-294.195
-294.195
-294.194
-294.194
-294.194
-294.193
-294.193
-294.192
-294.192
-294.191
-294.191
-294.19
-294.19
-294.19
-294.19
-294.189
-294.189
-294.189
-294.189
-294.189
-294.189
-294.189
-294.189
-294.189
-294.19
-294.19
-294.19
-294.19
-294.191
-294.191
-294.192
-294.192
-294.193
-294.193
-294.194
-294.194
-294.194
-294.195
-294.195
-294.196
-294.196
-294.197
-294.197
-294.198
-294.198
-294.198
-294.199
-294.199
-294.199
-294.199
-294.199
-294.199
  0 KSP preconditioned resid norm 3.005729294791e+04 true resid norm 3.005729294791e+04 ||Ae||/||Ax|| 9.486627323288e-05
  1 KSP preconditioned resid norm 5.352387062140e-07 true resid norm 8.438016085313e-07 ||Ae||/||Ax|| 2.663191062748e-15
Linear solve converged due to CONVERGED_RTOL
Process [0]
71.0932
71.0721
71.0298
70.9666
70.8829
70.779
70.6555
70.5131
70.3525
70.1748
69.9809
69.7722
69.5501
69.3161
69.072
68.8197
68.5614
68.2993
68.0357
67.7734
67.515
67.2632
67.0208
66.7908
66.5759
66.3787
66.202
66.048
65.919
65.8166
65.7424
65.6974
65.6823
65.6974
65.7424
65.8166
65.919
66.048
66.202
66.3787
66.5759
66.7908
67.0208
67.2632
67.515
67.7734
68.0357
68.2993
68.5614
68.8197
69.072
69.3161
69.5501
69.7722
69.9809
70.1748
70.3525
70.5131
70.6555
70.779
70.8829
70.9666
71.0298
71.0721
71.0932
68.0729
68.0516
68.0091
67.9456
67.8615
67.757
67.6328
67.4896
67.3281
67.1492
66.9541
66.744
66.5203
66.2845
66.0384
65.784
65.5234
65.2588
64.9927
64.7276
64.4664
64.2117
63.9665
63.7336
63.5159
63.3162
63.1371
62.981
62.85
62.7462
62.6709
62.6252
62.6099
62.6252
62.6709
62.7462
62.85
62.981
63.1371
63.3162
63.5159
63.7336
63.9665
64.2117
64.4664
64.7276
64.9927
65.2588
65.5234
65.784
66.0384
66.2845
66.5203
66.744
66.9541
67.1492
67.3281
67.4896
67.6328
67.757
67.8615
67.9456
68.0091
68.0516
68.0729
65.0742
65.0527
65.0098
64.9457
64.8606
64.7551
64.6295
64.4847
64.3213
64.1402
63.9426
63.7296
63.5026
63.2633
63.0133
62.7547
62.4894
62.2199
61.9485
61.678
61.4111
61.1506
60.8996
60.661
60.4378
60.2328
60.0488
59.8883
59.7536
59.6467
59.5692
59.5222
59.5065
59.5222
59.5692
59.6467
59.7536
59.8883
60.0488
60.2328
60.4378
60.661
60.8996
61.1506
61.4111
61.678
61.9485
62.2199
62.4894
62.7547
63.0133
63.2633
63.5026
63.7296
63.9426
64.1402
64.3213
64.4847
64.6295
64.7551
64.8606
64.9457
65.0098
65.0527
65.0742
62.0973
62.0755
62.032
61.9669
61.8806
61.7734
61.6459
61.4986
61.3323
61.148
60.9466
60.7293
60.4976
60.2529
59.9971
59.732
59.4598
59.1828
58.9035
58.6247
58.3492
58.08
57.8202
57.5728
57.3411
57.128
56.9366
56.7694
56.629
56.5175
56.4366
56.3875
56.3711
56.3875
56.4366
56.5175
56.629
56.7694
56.9366
57.128
57.3411
57.5728
57.8202
58.08
58.3492
58.6247
58.9035
59.1828
59.4598
59.732
59.9971
60.2529
60.4976
60.7293
60.9466
61.148
61.3323
61.4986
61.6459
61.7734
61.8806
61.9669
62.032
62.0755
62.0973
59.1426
59.1204
59.0761
59.0098
58.9218
58.8124
58.6822
58.5318
58.3618
58.1731
57.9667
57.7438
57.5057
57.2539
56.9902
56.7165
56.435
56.148
55.8581
55.5681
55.2809
54.9998
54.728
54.4687
54.2254
54.0013
53.7997
53.6233
53.4751
53.3572
53.2716
53.2196
53.2022
53.2196
53.2716
53.3572
53.4751
53.6233
53.7997
54.0013
54.2254
54.4687
54.728
54.9998
55.2809
55.5681
55.8581
56.148
56.435
56.7165
56.9902
57.2539
57.5057
57.7438
57.9667
58.1731
58.3618
58.5318
58.6822
58.8124
58.9218
59.0098
59.0761
59.1204
59.1426
56.2105
56.1878
56.1425
56.0746
55.9846
55.8726
55.7392
55.5849
55.4103
55.2162
55.0036
54.7737
54.5277
54.267
53.9935
53.709
53.4157
53.1161
52.8127
52.5085
52.2066
51.9103
51.6231
51.3485
51.0903
50.8519
50.637
50.4488
50.2903
50.1641
50.0724
50.0167
49.998
50.0167
50.0724
50.1641
50.2903
50.4488
50.637
50.8519
51.0903
51.3485
51.6231
51.9103
52.2066
52.5085
52.8127
53.1161
53.4157
53.709
53.9935
54.267
54.5277
54.7737
55.0036
55.2162
55.4103
55.5849
55.7392
55.8726
55.9846
56.0746
56.1425
56.1878
56.2105
53.3014
53.2782
53.2317
53.1621
53.0696
52.9546
52.8174
52.6585
52.4785
52.2781
52.0582
51.8199
51.5645
51.2932
51.0079
50.7105
50.403
50.088
49.7682
49.4466
49.1265
48.8115
48.5052
48.2117
47.9349
47.6787
47.4472
47.2441
47.0727
46.936
46.8366
46.7762
46.7559
46.7762
46.8366
46.936
47.0727
47.2441
47.4472
47.6787
47.9349
48.2117
48.5052
48.8115
49.1265
49.4466
49.7682
50.088
50.403
50.7105
51.0079
51.2932
51.5645
51.8199
52.0582
52.2781
52.4785
52.6585
52.8174
52.9546
53.0696
53.1621
53.2317
53.2782
53.3014
50.416
50.3921
50.3444
50.2728
50.1776
50.0591
49.9176
49.7535
49.5673
49.3597
49.1315
48.8836
48.6173
48.3337
48.0347
47.722
47.3979
47.0648
46.7255
46.3832
46.0413
45.7038
45.3745
45.0579
44.7584
44.4805
44.2286
44.0071
43.8198
43.6702
43.5612
43.4949
43.4726
43.4949
43.5612
43.6702
43.8198
44.0071
44.2286
44.4805
44.7584
45.0579
45.3745
45.7038
46.0413
46.3832
46.7255
47.0648
47.3979
47.722
48.0347
48.3337
48.6173
48.8836
49.1315
49.3597
49.5673
49.7535
49.9176
50.0591
50.1776
50.2728
50.3444
50.3921
50.416
47.555
47.5304
47.4812
47.4075
47.3094
47.1871
47.0408
46.871
46.678
46.4623
46.2248
45.9661
45.6874
45.39
45.0753
44.7453
44.4019
44.0478
43.6858
43.3193
42.9518
42.5876
42.231
41.8868
41.5601
41.2558
40.9793
40.7353
40.5286
40.3631
40.2424
40.1688
40.1442
40.1688
40.2424
40.3631
40.5286
40.7353
40.9793
41.2558
41.5601
41.8868
42.231
42.5876
42.9518
43.3193
43.6858
44.0478
44.4019
44.7453
45.0753
45.39
45.6874
45.9661
46.2248
46.4623
46.678
46.871
47.0408
47.1871
47.3094
47.4075
47.4812
47.5304
47.555
44.7189
44.6936
44.6429
44.5669
44.4656
44.3393
44.188
44.012
43.8116
43.5872
43.3394
43.069
42.7767
42.4638
42.1316
41.782
41.4169
41.0389
40.6509
40.2563
39.8591
39.4636
39.0748
38.698
38.3388
38.0031
37.6968
37.4258
37.1954
37.0107
36.8756
36.7932
36.7656
36.7932
36.8756
37.0107
37.1954
37.4258
37.6968
38.0031
38.3388
38.698
39.0748
39.4636
39.8591
40.2563
40.6509
41.0389
41.4169
41.782
42.1316
42.4638
42.7767
43.069
43.3394
43.5872
43.8116
44.012
44.188
44.3393
44.4656
44.5669
44.6429
44.6936
44.7189
41.9087
41.8826
41.8303
41.7519
41.6474
41.5168
41.3602
41.1777
40.9695
40.7359
40.4771
40.1939
39.8869
39.5571
39.2057
38.8343
38.4449
38.04
37.6225
37.196
36.7645
36.3329
35.9065
35.4913
35.0937
34.7204
34.3785
34.0749
33.816
33.6078
33.4552
33.3621
33.3308
33.3621
33.4552
33.6078
33.816
34.0749
34.3785
34.7204
35.0937
35.4913
35.9065
36.3329
36.7645
37.196
37.6225
38.04
38.4449
38.8343
39.2057
39.5571
39.8869
40.1939
40.4771
40.7359
40.9695
41.1777
41.3602
41.5168
41.6474
41.7519
41.8303
41.8826
41.9087
39.125
39.0981
39.0443
38.9635
38.8557
38.7208
38.5588
38.3696
38.1533
37.9099
37.6398
37.343
37.0203
36.6723
36.3
35.9049
35.4888
35.054
34.6034
34.1407
33.6702
33.1969
32.7269
32.2667
31.8238
31.406
31.0214
30.6785
30.385
30.1483
29.9745
29.8682
29.8324
29.8682
29.9745
30.1483
30.385
30.6785
31.0214
31.406
31.8238
32.2667
32.7269
33.1969
33.6702
34.1407
34.6034
35.054
35.4888
35.9049
36.3
36.6723
37.0203
37.343
37.6398
37.9099
38.1533
38.3696
38.5588
38.7208
38.8557
38.9635
39.0443
39.0981
39.125
36.3686
36.341
36.2857
36.2025
36.0915
35.9523
35.7849
35.589
35.3645
35.1113
34.8293
34.5186
34.1794
33.8121
33.4176
32.9969
32.5516
32.0839
31.5966
31.0933
30.5785
30.0577
29.5372
29.0246
28.5284
28.0576
27.6222
27.2319
26.8965
26.625
26.4251
26.3027
26.2614
26.3027
26.4251
26.625
26.8965
27.2319
27.6222
28.0576
28.5284
29.0246
29.5372
30.0577
30.5785
31.0933
31.5966
32.0839
32.5516
32.9969
33.4176
33.8121
34.1794
34.5186
34.8293
35.1113
35.3645
35.589
35.7849
35.9523
36.0915
36.2025
36.2857
36.341
36.3686
33.6403
33.612
33.5553
33.4699
33.3558
33.2125
33.0399
32.8375
32.6049
32.3419
32.048
31.723
31.3669
30.9797
30.5617
30.1138
29.6372
29.1338
28.6061
28.0576
27.493
26.918
26.3395
25.766
25.2071
24.6735
24.1769
23.7295
23.3431
23.0291
22.7971
22.6547
22.6067
22.6547
22.7971
23.0291
23.3431
23.7295
24.1769
24.6735
25.2071
25.766
26.3395
26.918
27.493
28.0576
28.6061
29.1338
29.6372
30.1138
30.5617
30.9797
31.3669
31.723
32.048
32.3419
32.6049
32.8375
33.0399
33.2125
33.3558
33.4699
33.5553
33.612
33.6403
30.9409
30.9119
30.8539
30.7666
30.6496
30.5026
30.3251
30.1166
29.8764
29.6038
29.2983
28.9592
28.586
28.1784
27.7363
27.2599
26.7501
26.2083
25.6366
25.0384
24.4181
23.7818
23.1368
22.4926
21.86
21.2518
20.6819
20.165
19.7163
19.3498
19.078
18.9108
18.8544
18.9108
19.078
19.3498
19.7163
20.165
20.6819
21.2518
21.86
22.4926
23.1368
23.7818
24.4181
25.0384
25.6366
26.2083
26.7501
27.2599
27.7363
28.1784
28.586
28.9592
29.2983
29.6038
29.8764
30.1166
30.3251
30.5026
30.6496
30.7666
30.8539
30.9119
30.9409
28.2709
28.2414
28.1823
28.0933
27.9739
27.8237
27.6419
27.4278
27.1806
26.8992
26.5826
26.2299
25.84
25.4122
24.9456
24.44
23.8956
23.313
22.6941
22.0415
21.3596
20.6543
19.9334
19.2072
18.4882
17.7912
17.1329
16.5315
16.0059
15.5743
15.2529
15.0545
14.9874
15.0545
15.2529
15.5743
16.0059
16.5315
17.1329
17.7912
18.4882
19.2072
19.9334
20.6543
21.3596
22.0415
22.6941
23.313
23.8956
24.44
24.9456
25.4122
25.84
26.2299
26.5826
26.8992
27.1806
27.4278
27.6419
27.8237
27.9739
28.0933
28.1823
28.2414
28.2709
25.6308
25.601
25.5411
25.4508
25.3296
25.1768
24.9915
24.7728
24.5195
24.2303
23.9037
23.5384
23.1327
22.6852
22.1945
21.6596
21.0797
20.4548
19.7857
19.0745
18.3249
17.5425
16.7354
15.9147
15.0942
14.2912
13.526
12.821
12.2001
11.6868
11.3027
11.0648
10.9842
11.0648
11.3027
11.6868
12.2001
12.821
13.526
14.2912
15.0942
15.9147
16.7354
17.5425
18.3249
19.0745
19.7857
20.4548
21.0797
21.6596
22.1945
22.6852
23.1327
23.5384
23.9037
24.2303
24.5195
24.7728
24.9915
25.1768
25.3296
25.4508
25.5411
25.601
25.6308
23.0212
22.9911
22.9308
22.8397
22.7173
22.5628
22.3751
22.1529
21.8949
21.5993
21.2642
20.8878
20.4678
20.0021
19.4885
18.9248
18.3095
17.6413
16.92
16.1465
15.3234
14.4557
13.5514
12.6217
11.6823
10.753
9.85794
9.0251
8.28488
7.66833
7.20406
6.9153
6.81728
6.9153
7.20406
7.66833
8.28488
9.0251
9.85794
10.753
11.6823
12.6217
13.5514
14.4557
15.3234
16.1465
16.92
17.6413
18.3095
18.9248
19.4885
20.0021
20.4678
20.8878
21.2642
21.5993
21.8949
22.1529
22.3751
22.5628
22.7173
22.8397
22.9308
22.9911
23.0212
20.442
20.412
20.3516
20.2605
20.1378
19.9826
19.7936
19.5695
19.3084
19.0082
18.6668
18.2815
17.8494
17.3677
16.8331
16.2425
15.593
14.8819
14.1074
13.2688
12.3672
11.4063
10.393
9.33877
8.26019
7.17991
6.12672
5.13513
4.2441
3.49514
2.92715
2.57212
2.45128
2.57212
2.92715
3.49514
4.2441
5.13513
6.12672
7.17991
8.26019
9.33877
10.393
11.4063
12.3672
13.2688
14.1074
14.8819
15.593
16.2425
16.8331
17.3677
17.8494
18.2815
18.6668
19.0082
19.3084
19.5695
19.7936
19.9826
20.1378
20.2605
20.3516
20.412
20.442
17.8935
17.8637
17.8038
17.7132
17.5912
17.4366
17.2479
17.0236
16.7615
16.4592
16.1139
15.7226
15.2815
14.7869
14.2346
13.6202
12.939
12.1869
11.3598
10.4551
9.47129
8.40996
7.27624
6.0805
4.83981
3.57931
2.33294
1.14303
0.0590359
-0.86183
-1.56602
-2.00892
-2.16018
-2.00892
-1.56602
-0.86183
0.0590359
1.14303
2.33294
3.57931
4.83981
6.0805
7.27624
8.40996
9.47129
10.4551
11.3598
12.1869
12.939
13.6202
14.2346
14.7869
15.2815
15.7226
16.1139
16.4592
16.7615
17.0236
17.2479
17.4366
17.5912
17.7132
17.8038
17.8637
17.8935
15.3753
15.346
15.2871
15.1979
15.0777
14.9251
14.7385
14.5161
14.2554
13.9538
13.6079
13.2141
12.768
12.2648
11.6993
11.0655
10.3572
9.56789
8.69127
7.72151
6.65415
5.48717
4.22247
2.86788
1.43954
-0.0356466
-1.5182
-2.95663
-4.29171
-5.43886
-6.32455
-6.88616
-7.07886
-6.88616
-6.32455
-5.43886
-4.29171
-2.95663
-1.5182
-0.0356466
1.43954
2.86788
4.22247
5.48717
6.65415
7.72151
8.69127
9.56789
10.3572
11.0655
11.6993
12.2648
12.768
13.2141
13.6079
13.9538
14.2554
14.5161
14.7385
14.9251
15.0777
15.1979
15.2871
15.346
15.3753
12.8868
12.8583
12.801
12.7143
12.597
12.448
12.2655
12.0474
11.791
11.4933
11.1506
10.7586
10.3123
9.80605
9.2332
8.58642
7.85752
7.03761
6.11729
5.08709
3.93819
2.6636
1.25997
-0.269846
-1.91317
-3.64313
-5.41414
-7.16128
-8.83331
-10.2814
-11.4123
-12.1382
9.37384
-12.1382
-11.4123
-10.2814
-8.83331
-7.16128
-5.41414
-3.64313
-1.91317
-0.269846
1.25997
2.6636
3.93819
5.08709
6.11729
7.03761
7.85752
8.58642
9.2332
9.80605
10.3123
10.7586
11.1506
11.4933
11.791
12.0474
12.2655
12.448
12.597
12.7143
12.801
12.8583
12.8868
10.4273
10.4
10.345
10.2615
10.1487
10.005
9.82873
9.61751
9.36857
9.07854
8.74338
8.35831
7.91768
7.41489
6.84222
6.19077
5.45032
4.60931
3.6549
2.5732
1.34986
-0.0289113
-1.57439
-3.2923
-5.17791
-7.20892
-9.33435
-11.4427
9.36703
9.3665
9.3665
9.36662
9.36669
9.36662
9.3665
9.3665
9.36703
-11.4427
-9.33435
-7.20892
-5.17791
-3.2923
-1.57439
-0.0289113
1.34986
2.5732
3.6549
4.60931
5.45032
6.19077
6.84222
7.41489
7.91768
8.35831
8.74338
9.07854
9.36857
9.61751
9.82873
10.005
10.1487
10.2615
10.345
10.4
10.4273
7.99565
7.9698
7.91769
7.83865
7.73163
7.59517
7.4274
7.22593
6.98785
6.70959
6.38683
6.01442
5.58615
5.09468
4.53125
3.8855
3.14524
2.29617
1.32177
0.203169
-1.08064
-2.55212
-4.23365
-6.14444
-8.29502
-10.6788
9.36027
9.35958
9.35974
9.35964
9.35962
9.35965
9.35967
9.35965
9.35962
9.35964
9.35974
9.35958
9.36027
-10.6788
-8.29502
-6.14444
-4.23365
-2.55212
-1.08064
0.203169
1.32177
2.29617
3.14524
3.8855
4.53125
5.09468
5.58615
6.01442
6.38683
6.70959
6.98785
7.22593
7.4274
7.59517
7.73163
7.83865
7.91769
7.9698
7.99565
5.59029
5.56625
5.51777
5.4442
5.34446
5.21712
5.06028
4.87155
4.64794
4.38582
4.08072
3.72723
3.31882
2.84756
2.30388
1.67623
0.950643
0.11032
-0.864911
-1.99909
-3.32055
-4.86202
-6.66009
-8.75307
-11.1753
9.35305
9.35297
9.35277
9.35274
9.3527
9.35268
9.35268
9.35269
9.35268
9.35268
9.3527
9.35274
9.35277
9.35297
9.35305
-11.1753
-8.75307
-6.66009
-4.86202
-3.32055
-1.99909
-0.864911
0.11032
0.950643
1.67623
2.30388
2.84756
3.31882
3.72723
4.08072
4.38582
4.64794
4.87155
5.06028
5.21712
5.34446
5.4442
5.51777
5.56625
5.59029
3.20939
3.1875
3.14336
3.0763
2.98533
2.86902
2.72555
2.55257
2.34716
2.1057
1.82374
1.49584
1.11531
0.673977
0.161794
-0.433595
-1.12743
-1.93853
-2.89018
-4.01117
-5.33702
-6.91132
-8.78705
-11.0274
9.34533
9.34572
9.34581
9.34578
9.34576
9.34574
9.34572
9.34572
9.34572
9.34572
9.34572
9.34574
9.34576
9.34578
9.34581
9.34572
9.34533
-11.0274
-8.78705
-6.91132
-5.33702
-4.01117
-2.89018
-1.93853
-1.12743
-0.433595
0.161794
0.673977
1.11531
1.49584
1.82374
2.1057
2.34716
2.55257
2.72555
2.86902
2.98533
3.0763
3.14336
3.1875
3.20939
0.850766
0.83136
0.792211
0.732709
0.651912
0.548511
0.420785
0.266531
0.082984
-0.133297
-0.386575
-0.682119
-1.02645
-1.42765
-1.89579
-2.44344
-3.08641
-3.84464
-4.74346
-5.8152
-7.10119
-8.65453
-10.5437
9.33799
9.33846
9.33868
9.33877
9.33878
9.33877
9.33876
9.33875
9.33875
9.33875
9.33875
9.33875
9.33876
9.33877
9.33878
9.33877
9.33868
9.33846
9.33799
-10.5437
-8.65453
-7.10119
-5.8152
-4.74346
-3.84464
-3.08641
-2.44344
-1.89579
-1.42765
-1.02645
-0.682119
-0.386575
-0.133297
0.082984
0.266531
0.420785
0.548511
0.651912
0.732709
0.792211
0.83136
0.850766
-1.48811
-1.50473
-1.53827
-1.58926
-1.65855
-1.74729
-1.85704
-1.98976
-2.14795
-2.33472
-2.55397
-2.81053
-3.11045
-3.46131
-3.87263
-4.3565
-4.92833
-5.60797
-6.42116
-7.40163
-8.59387
-10.0566
-11.8665
9.33233
9.33183
9.33178
9.33179
9.3318
9.3318
9.33179
9.33178
9.33177
9.33177
9.33177
9.33178
9.33179
9.3318
9.3318
9.33179
9.33178
9.33183
9.33233
-11.8665
-10.0566
-8.59387
-7.40163
-6.42116
-5.60797
-4.92833
-4.3565
-3.87263
-3.46131
-3.11045
-2.81053
-2.55397
-2.33472
-2.14795
-1.98976
-1.85704
-1.74729
-1.65855
-1.58926
-1.53827
-1.50473
-1.48811
-3.81009
-3.82365
-3.85102
-3.89265
-3.94924
-4.02177
-4.11153
-4.22019
-4.34985
-4.50317
-4.68346
-4.89491
-5.14273
-5.43356
-5.77579
-6.18022
-6.66077
-7.23567
-7.92898
-8.77302
-9.81183
-11.107
9.32283
9.32445
9.32475
9.32481
9.32483
9.32483
9.32482
9.32481
9.3248
9.3248
9.32479
9.3248
9.3248
9.32481
9.32482
9.32483
9.32483
9.32481
9.32475
9.32445
9.32283
-11.107
-9.81183
-8.77302
-7.92898
-7.23567
-6.66077
-6.18022
-5.77579
-5.43356
-5.14273
-4.89491
-4.68346
-4.50317
-4.34985
-4.22019
-4.11153
-4.02177
-3.94924
-3.89265
-3.85102
-3.82365
-3.81009
-6.11826
-6.12854
-6.14929
-6.18084
-6.22375
-6.27875
-6.34683
-6.42928
-6.52772
-6.64421
-6.78133
-6.94233
-7.13134
-7.3536
-7.6158
-7.92663
-8.29741
-8.7431
-9.28374
-9.94661
-10.7695
-11.8055
9.318
9.31789
9.3179
9.3179
9.31788
9.31787
9.31785
9.31784
9.31782
9.31782
9.31781
9.31782
9.31782
9.31784
9.31785
9.31787
9.31788
9.3179
9.3179
9.31789
9.318
-11.8055
-10.7695
-9.94661
-9.28374
-8.7431
-8.29741
-7.92663
-7.6158
-7.3536
-7.13134
-6.94233
-6.78133
-6.64421
-6.52772
-6.42928
-6.34683
-6.27875
-6.22375
-6.18084
-6.14929
-6.12854
-6.11826
-8.41597
-8.4228
-8.43657
-8.45752
-8.48598
-8.52244
-8.56755
-8.62214
-8.68728
-8.76431
-8.85493
-8.96132
-9.08619
-9.23306
-9.40643
-9.61217
-9.85798
-10.1541
-10.5144
-10.9577
-11.5106
-12.2104
9.31163
9.31122
9.31106
9.31099
9.31094
9.31091
9.31088
9.31086
9.31084
9.31083
9.31083
9.31083
9.31084
9.31086
9.31088
9.31091
9.31094
9.31099
9.31106
9.31122
9.31163
-12.2104
-11.5106
-10.9577
-10.5144
-10.1541
-9.85798
-9.61217
-9.40643
-9.23306
-9.08619
-8.96132
-8.85493
-8.76431
-8.68728
-8.62214
-8.56755
-8.52244
-8.48598
-8.45752
-8.43657
-8.4228
-8.41597
-10.7067
-10.71
-10.7166
-10.7266
-10.7401
-10.7573
-10.7786
-10.8043
-10.8347
-10.8706
-10.9125
-10.9615
-11.0187
-11.0856
-11.1642
-11.257
-11.3674
-11.5
-11.6606
-11.8577
-12.1026
-12.4118
9.30454
9.30429
9.30414
9.30405
9.30399
9.30394
9.3039
9.30387
9.30385
9.30384
9.30383
9.30384
9.30385
9.30387
9.3039
9.30394
9.30399
9.30405
9.30414
9.30429
9.30454
-12.4118
-12.1026
-11.8577
-11.6606
-11.5
-11.3674
-11.257
-11.1642
-11.0856
-11.0187
-10.9615
-10.9125
-10.8706
-10.8347
-10.8043
-10.7786
-10.7573
-10.7401
-10.7266
-10.7166
-10.71
-10.7067
-12.9942
-12.9938
-12.9931
-12.992
-12.9904
-12.9882
-12.9853
-12.9815
-12.9768
-12.9707
-12.963
-12.9534
-12.9413
-12.9263
-12.9075
-12.884
-12.8545
-12.8172
-12.77
-12.7092
-12.6295
-12.5215
9.29723
9.29724
9.29717
9.29709
9.29702
9.29696
9.29691
9.29687
9.29685
9.29684
9.29683
9.29684
9.29685
9.29687
9.29691
9.29696
9.29702
9.29709
9.29717
9.29724
9.29723
-12.5215
-12.6295
-12.7092
-12.77
-12.8172
-12.8545
-12.884
-12.9075
-12.9263
-12.9413
-12.9534
-12.963
-12.9707
-12.9768
-12.9815
-12.9853
-12.9882
-12.9904
-12.992
-12.9931
-12.9938
-12.9942
-15.282
-15.2781
-15.2701
-15.2579
-15.2413
-15.2197
-15.1928
-15.1599
-15.1201
-15.0724
-15.0155
-14.9477
-14.867
-14.7708
-14.6556
-14.517
-14.3493
-14.1448
-13.893
-13.5798
-13.185
-12.6784
9.29009
9.29026
9.29022
9.29012
9.29004
9.28996
9.28991
9.28987
9.28984
9.28983
9.28982
9.28983
9.28984
9.28987
9.28991
9.28996
9.29004
9.29012
9.29022
9.29026
9.29009
-12.6784
-13.185
-13.5798
-13.893
-14.1448
-14.3493
-14.517
-14.6556
-14.7708
-14.867
-14.9477
-15.0155
-15.0724
-15.1201
-15.1599
-15.1928
-15.2197
-15.2413
-15.2579
-15.2701
-15.2781
-15.282
-17.5738
-17.5664
-17.5513
-17.5284
-17.4971
-17.4567
-17.4065
-17.3452
-17.2714
-17.1834
-17.0789
-16.9552
-16.8086
-16.6346
-16.4274
-16.1797
-15.8816
-15.5202
-15.0785
-14.5333
-13.8537
-13
9.28363
9.28351
9.28331
9.28315
9.28304
9.28295
9.28289
9.28285
9.28282
9.28281
9.2828
9.28281
9.28282
9.28285
9.28289
9.28295
9.28304
9.28315
9.28331
9.28351
9.28363
-13
-13.8537
-14.5333
-15.0785
-15.5202
-15.8816
-16.1797
-16.4274
-16.6346
-16.8086
-16.9552
-17.0789
-17.1834
-17.2714
-17.3452
-17.4065
-17.4567
-17.4971
-17.5284
-17.5513
-17.5664
-17.5738
-19.8732
-19.8624
-19.8406
-19.8074
-19.7621
-19.7038
-19.6313
-19.5431
-19.4372
-19.3112
-19.162
-18.9859
-18.7779
-18.532
-18.2405
-17.8935
-17.478
-16.9773
-16.3691
-15.6232
-14.699
-13.5396
9.27862
9.27684
9.27635
9.27614
9.27601
9.27592
9.27585
9.27581
9.27579
9.27577
9.27577
9.27577
9.27579
9.27581
9.27585
9.27592
9.27601
9.27614
9.27635
9.27684
9.27862
-13.5396
-14.699
-15.6232
-16.3691
-16.9773
-17.478
-17.8935
-18.2405
-18.532
-18.7779
-18.9859
-19.162
-19.3112
-19.4372
-19.5431
-19.6313
-19.7038
-19.7621
-19.8074
-19.8406
-19.8624
-19.8732
-22.1835
-22.1696
-22.1415
-22.0987
-22.0403
-21.9653
-21.8721
-21.759
-21.6234
-21.4625
-21.2725
-21.0488
-20.7857
-20.4758
-20.11
-19.6767
-19.1611
-18.5437
-17.7993
-16.8944
-15.7829
-14.3994
-12.6413
9.26888
9.26911
9.26904
9.26894
9.26885
9.2688
9.26876
9.26874
9.26873
9.26873
9.26873
9.26874
9.26876
9.2688
9.26885
9.26894
9.26904
9.26911
9.26888
-12.6413
-14.3994
-15.7829
-16.8944
-17.7993
-18.5437
-19.1611
-19.6767
-20.11
-20.4758
-20.7857
-21.0488
-21.2725
-21.4625
-21.6234
-21.759
-21.8721
-21.9653
-22.0403
-22.0987
-22.1415
-22.1696
-22.1835
-24.5081
-24.4913
-24.4573
-24.4057
-24.3354
-24.2451
-24.1332
-23.9976
-23.8354
-23.6434
-23.4173
-23.1519
-22.8409
-22.4763
-22.048
-21.5437
-20.9474
-20.239
-19.3927
-18.3752
-17.1431
-15.6413
-13.806
9.26295
9.26218
9.26198
9.26184
9.26176
9.26172
9.2617
9.26169
9.26169
9.26169
9.26169
9.26169
9.2617
9.26172
9.26176
9.26184
9.26198
9.26218
9.26295
-13.806
-15.6413
-17.1431
-18.3752
-19.3927
-20.239
-20.9474
-21.5437
-22.048
-22.4763
-22.8409
-23.1519
-23.4173
-23.6434
-23.8354
-23.9976
-24.1332
-24.2451
-24.3354
-24.4057
-24.4573
-24.4913
-24.5081
-26.8497
-26.8303
-26.7912
-26.7317
-26.6507
-26.547
-26.4185
-26.2631
-26.0777
-25.8588
-25.6018
-25.3013
-24.9506
-24.5413
-24.0633
-23.504
-22.8475
-22.0744
-21.1601
-20.0739
-18.7773
-17.222
-15.3475
-13.0688
9.25465
9.25487
9.25469
9.25462
9.25462
9.25462
9.25463
9.25464
9.25464
9.25464
9.25463
9.25462
9.25462
9.25462
9.25469
9.25487
9.25465
-13.0688
-15.3475
-17.222
-18.7773
-20.0739
-21.1601
-22.0744
-22.8475
-23.504
-24.0633
-24.5413
-24.9506
-25.3013
-25.6018
-25.8588
-26.0777
-26.2631
-26.4185
-26.547
-26.6507
-26.7317
-26.7912
-26.8303
-26.8497
-29.211
-29.1894
-29.1457
-29.0794
-28.9892
-28.8738
-28.7313
-28.5591
-28.3542
-28.1129
-27.8306
-27.5018
-27.1198
-26.6762
-26.1613
-25.5629
-24.8661
-24.0532
-23.1021
-21.9864
-20.674
-19.127
-17.3001
-15.1415
-12.6017
9.24816
9.24742
9.24742
9.2475
9.24754
9.24757
9.24759
9.2476
9.24759
9.24757
9.24754
9.2475
9.24742
9.24742
9.24816
-12.6017
-15.1415
-17.3001
-19.127
-20.674
-21.9864
-23.1021
-24.0532
-24.8661
-25.5629
-26.1613
-26.6762
-27.1198
-27.5018
-27.8306
-28.1129
-28.3542
-28.5591
-28.7313
-28.8738
-28.9892
-29.0794
-29.1457
-29.1894
-29.211
-31.5944
-31.5708
-31.5234
-31.4513
-31.3534
-31.2283
-31.0741
-30.8882
-30.6676
-30.4085
-30.1066
-29.7564
-29.3513
-28.8837
-28.3441
-27.7216
-27.0028
-26.1722
-25.2112
-24.0984
-22.8092
-21.3161
-19.5898
-17.6018
-15.3302
-12.7637
9.23938
9.24013
9.24045
9.24046
9.24051
9.24056
9.24058
9.24056
9.24051
9.24046
9.24045
9.24013
9.23938
-12.7637
-15.3302
-17.6018
-19.5898
-21.3161
-22.8092
-24.0984
-25.2112
-26.1722
-27.0028
-27.7216
-28.3441
-28.8837
-29.3513
-29.7564
-30.1066
-30.4085
-30.6676
-30.8882
-31.0741
-31.2283
-31.3534
-31.4513
-31.5234
-31.5708
-31.5944
-34.0016
-33.9766
-33.926
-33.8493
-33.7452
-33.6125
-33.4491
-33.2525
-33.02
-32.7478
-32.4317
-32.0666
-31.6465
-31.1641
-30.6112
-29.978
-29.2531
-28.4236
-27.4746
-26.3897
-25.1515
-23.742
-22.1451
-20.35
-18.3585
-16.2
-13.9758
9.23329
9.2337
9.23333
9.23346
9.23356
9.23361
9.23356
9.23346
9.23333
9.2337
9.23329
-13.9758
-16.2
-18.3585
-20.35
-22.1451
-23.742
-25.1515
-26.3897
-27.4746
-28.4236
-29.2531
-29.978
-30.6112
-31.1641
-31.6465
-32.0666
-32.4317
-32.7478
-33.02
-33.2525
-33.4491
-33.6125
-33.7452
-33.8493
-33.926
-33.9766
-34.0016
-36.4344
-36.4082
-36.3552
-36.275
-36.1663
-36.0278
-35.8576
-35.6535
-35.4126
-35.1316
-34.8066
-34.4328
-34.0047
-33.5162
-32.9599
-32.3275
-31.6097
-30.7963
-29.8758
-28.8368
-27.6677
-26.3583
-24.9018
-23.2977
-21.5562
-19.7029
-17.7754
-15.7649
-13.8678
9.2257
9.22641
9.22663
9.22673
9.22663
9.22641
9.2257
-13.8678
-15.7649
-17.7754
-19.7029
-21.5562
-23.2977
-24.9018
-26.3583
-27.6677
-28.8368
-29.8758
-30.7963
-31.6097
-32.3275
-32.9599
-33.5162
-34.0047
-34.4328
-34.8066
-35.1316
-35.4126
-35.6535
-35.8576
-36.0278
-36.1663
-36.275
-36.3552
-36.4082
-36.4344
-38.894
-38.8669
-38.8122
-38.7295
-38.6176
-38.4752
-38.3007
-38.0918
-37.846
-37.5602
-37.2309
-36.854
-36.4245
-35.9371
-35.3858
-34.7637
-34.0636
-33.2775
-32.3976
-31.4161
-30.3263
-29.124
-27.8084
-26.3849
-24.8677
-23.2811
-21.66
-20.0468
-18.5407
-17.2346
-16.2389
-15.6153
-15.4425
-15.6153
-16.2389
-17.2346
-18.5407
-20.0468
-21.66
-23.2811
-24.8677
-26.3849
-27.8084
-29.124
-30.3263
-31.4161
-32.3976
-33.2775
-34.0636
-34.7637
-35.3858
-35.9371
-36.4245
-36.854
-37.2309
-37.5602
-37.846
-38.0918
-38.3007
-38.4752
-38.6176
-38.7295
-38.8122
-38.8669
-38.894
-41.3811
-41.3535
-41.2978
-41.2136
-41.0999
-40.9554
-40.7786
-40.5676
-40.32
-40.0331
-39.7038
-39.3284
-38.903
-38.4231
-37.8836
-37.2793
-36.6047
-35.8541
-35.0225
-34.1052
-33.0994
-32.0047
-30.8244
-29.5674
-28.2494
-26.8946
-25.5365
-24.2201
-23.0106
-21.9775
-21.1905
-20.7002
-20.5412
-20.7002
-21.1905
-21.9775
-23.0106
-24.2201
-25.5365
-26.8946
-28.2494
-29.5674
-30.8244
-32.0047
-33.0994
-34.1052
-35.0225
-35.8541
-36.6047
-37.2793
-37.8836
-38.4231
-38.903
-39.3284
-39.7038
-40.0331
-40.32
-40.5676
-40.7786
-40.9554
-41.0999
-41.2136
-41.2978
-41.3535
-41.3811
-43.8964
-43.8685
-43.8125
-43.7277
-43.6133
-43.4684
-43.2913
-43.0805
-42.8338
-42.549
-42.2233
-41.8538
-41.437
-40.9694
-40.4471
-39.8663
-39.2228
-38.5132
-37.7343
-36.8842
-35.9628
-34.9722
-33.9185
-32.8118
-31.6685
-30.5114
-29.3706
-28.2847
-27.3013
-26.4707
-25.8408
-25.4486
-25.3169
-25.4486
-25.8408
-26.4707
-27.3013
-28.2847
-29.3706
-30.5114
-31.6685
-32.8118
-33.9185
-34.9722
-35.9628
-36.8842
-37.7343
-38.5132
-39.2228
-39.8663
-40.4471
-40.9694
-41.437
-41.8538
-42.2233
-42.549
-42.8338
-43.0805
-43.2913
-43.4684
-43.6133
-43.7277
-43.8125
-43.8685
-43.8964
-46.44
-46.4122
-46.3563
-46.2718
-46.158
-46.0139
-45.8383
-45.6297
-45.3864
-45.1064
-44.7874
-44.427
-44.0226
-43.5713
-43.0703
-42.5168
-41.9082
-41.2425
-40.5184
-39.7357
-38.8963
-38.004
-37.0661
-36.0935
-35.1018
-34.1116
-33.1489
-32.2453
-31.4367
-30.7601
-30.2497
-29.9325
-29.8252
-29.9325
-30.2497
-30.7601
-31.4367
-32.2453
-33.1489
-34.1116
-35.1018
-36.0935
-37.0661
-38.004
-38.8963
-39.7357
-40.5184
-41.2425
-41.9082
-42.5168
-43.0703
-43.5713
-44.0226
-44.427
-44.7874
-45.1064
-45.3864
-45.6297
-45.8383
-46.0139
-46.158
-46.2718
-46.3563
-46.4122
-46.44
-49.0119
-48.9844
-48.9291
-48.8456
-48.7334
-48.5914
-48.4188
-48.2142
-47.9763
-47.7033
-47.3936
-47.0451
-46.6558
-46.2236
-45.7467
-45.2232
-44.6516
-44.0311
-43.3619
-42.645
-41.8834
-41.0822
-40.249
-39.3947
-38.5335
-37.6837
-36.8673
-36.1096
-35.4382
-34.8808
-34.4625
-34.2032
-34.1154
-34.2032
-34.4625
-34.8808
-35.4382
-36.1096
-36.8673
-37.6837
-38.5335
-39.3947
-40.249
-41.0822
-41.8834
-42.645
-43.3619
-44.0311
-44.6516
-45.2232
-45.7467
-46.2236
-46.6558
-47.0451
-47.3936
-47.7033
-47.9763
-48.2142
-48.4188
-48.5914
-48.7334
-48.8456
-48.9291
-48.9844
-49.0119
-51.6118
-51.5848
-51.5306
-51.4488
-51.3388
-51.2001
-51.0317
-50.8327
-50.6018
-50.3377
-50.0391
-49.7045
-49.3324
-48.9215
-48.4705
-47.9784
-47.4446
-46.8694
-46.2537
-45.5996
-44.9109
-44.1929
-43.4535
-42.7027
-41.9537
-41.222
-40.526
-39.8861
-39.3238
-38.8601
-38.5138
-38.2998
-38.2274
-38.2998
-38.5138
-38.8601
-39.3238
-39.8861
-40.526
-41.222
-41.9537
-42.7027
-43.4535
-44.1929
-44.9109
-45.5996
-46.2537
-46.8694
-47.4446
-47.9784
-48.4705
-48.9215
-49.3324
-49.7045
-50.0391
-50.3377
-50.6018
-50.8327
-51.0317
-51.2001
-51.3388
-51.4488
-51.5306
-51.5848
-51.6118
-54.2392
-54.2128
-54.16
-54.0804
-53.9736
-53.839
-53.6759
-53.4835
-53.2609
-53.0071
-52.7212
-52.402
-52.0486
-51.6601
-51.2359
-50.7758
-50.2798
-49.7488
-49.1845
-48.5895
-47.9679
-47.3254
-46.6693
-46.0091
-45.3562
-44.724
-44.1277
-43.5839
-43.1093
-42.7202
-42.4308
-42.2525
-42.1922
-42.2525
-42.4308
-42.7202
-43.1093
-43.5839
-44.1277
-44.724
-45.3562
-46.0091
-46.6693
-47.3254
-47.9679
-48.5895
-49.1845
-49.7488
-50.2798
-50.7758
-51.2359
-51.6601
-52.0486
-52.402
-52.7212
-53.0071
-53.2609
-53.4835
-53.6759
-53.839
-53.9736
-54.0804
-54.16
-54.2128
-54.2392
-56.8933
-56.8678
-56.8167
-56.7397
-56.6365
-56.5067
-56.3497
-56.1649
-55.9517
-55.7092
-55.437
-55.1342
-54.8003
-54.435
-54.038
-53.6096
-53.1506
-52.6621
-52.1463
-51.6063
-51.0463
-50.4717
-49.8894
-49.3081
-48.7376
-48.1895
-47.6763
-47.2113
-46.808
-46.4789
-46.2352
-46.0853
-46.0347
-46.0853
-46.2352
-46.4789
-46.808
-47.2113
-47.6763
-48.1895
-48.7376
-49.3081
-49.8894
-50.4717
-51.0463
-51.6063
-52.1463
-52.6621
-53.1506
-53.6096
-54.038
-54.435
-54.8003
-55.1342
-55.437
-55.7092
-55.9517
-56.1649
-56.3497
-56.5067
-56.6365
-56.7397
-56.8167
-56.8678
-56.8933
-59.5733
-59.5488
-59.4997
-59.4257
-59.3266
-59.2021
-59.0518
-58.8753
-58.6721
-58.4417
-58.1838
-57.898
-57.584
-57.2419
-56.8719
-56.4746
-56.0511
-55.6031
-55.1328
-54.6436
-54.1394
-53.6257
-53.1087
-52.596
-52.0963
-51.6195
-51.1758
-50.7761
-50.4312
-50.1511
-49.9442
-49.8172
-49.7744
-49.8172
-49.9442
-50.1511
-50.4312
-50.7761
-51.1758
-51.6195
-52.0963
-52.596
-53.1087
-53.6257
-54.1394
-54.6436
-55.1328
-55.6031
-56.0511
-56.4746
-56.8719
-57.2419
-57.584
-57.898
-58.1838
-58.4417
-58.6721
-58.8753
-59.0518
-59.2021
-59.3266
-59.4257
-59.4997
-59.5488
-59.5733
-62.2784
-62.2549
-62.2078
-62.137
-62.0424
-61.9236
-61.7805
-61.6127
-61.42
-61.2022
-60.9589
-60.6903
-60.3963
-60.0772
-59.7336
-59.3663
-58.9767
-58.5666
-58.1386
-57.6959
-57.2423
-56.7829
-56.3235
-55.8707
-55.432
-55.0157
-54.6306
-54.2854
-53.9888
-53.7487
-53.572
-53.4637
-53.4273
-53.4637
-53.572
-53.7487
-53.9888
-54.2854
-54.6306
-55.0157
-55.432
-55.8707
-56.3235
-56.7829
-57.2423
-57.6959
-58.1386
-58.5666
-58.9767
-59.3663
-59.7336
-60.0772
-60.3963
-60.6903
-60.9589
-61.2022
-61.42
-61.6127
-61.7805
-61.9236
-62.0424
-62.137
-62.2078
-62.2549
-62.2784
-65.0072
-64.9849
-64.9401
-64.8727
-64.7827
-64.6699
-64.5342
-64.3755
-64.1935
-63.9883
-63.7599
-63.5084
-63.2341
-62.9374
-62.6192
-62.2806
-61.923
-61.5484
-61.1594
-60.7591
-60.3512
-59.9403
-59.5316
-59.1309
-58.7449
-58.3804
-58.0448
-57.7453
-57.489
-57.2821
-57.1302
-57.0373
-57.0061
-57.0373
-57.1302
-57.2821
-57.489
-57.7453
-58.0448
-58.3804
-58.7449
-59.1309
-59.5316
-59.9403
-60.3512
-60.7591
-61.1594
-61.5484
-61.923
-62.2806
-62.6192
-62.9374
-63.2341
-63.5084
-63.7599
-63.9883
-64.1935
-64.3755
-64.5342
-64.6699
-64.7827
-64.8727
-64.9401
-64.9849
-65.0072
-67.7589
-67.7377
-67.6952
-67.6313
-67.5461
-67.4395
-67.3114
-67.1618
-66.9907
-66.7981
-66.5844
-66.3497
-66.0945
-65.8195
-65.5256
-65.2141
-64.8865
-64.5449
-64.1917
-63.83
-63.4632
-63.0954
-62.7315
-62.3764
-62.0359
-61.7158
-61.4223
-61.1614
-60.9388
-60.7597
-60.6285
-60.5483
-60.5214
-60.5483
-60.6285
-60.7597
-60.9388
-61.1614
-61.4223
-61.7158
-62.0359
-62.3764
-62.7315
-63.0954
-63.4632
-63.83
-64.1917
-64.5449
-64.8865
-65.2141
-65.5256
-65.8195
-66.0945
-66.3497
-66.5844
-66.7981
-66.9907
-67.1618
-67.3114
-67.4395
-67.5461
-67.6313
-67.6952
-67.7377
-67.7589
-70.5322
-70.5121
-70.472
-70.4117
-70.3314
-70.2309
-70.1104
-69.9699
-69.8095
-69.6295
-69.4301
-69.2117
-68.975
-68.7208
-68.45
-68.164
-67.8644
-67.5532
-67.2327
-66.906
-66.5761
-66.2468
-65.9223
-65.6071
-65.3061
-65.0242
-64.7668
-64.5386
-64.3445
-64.1888
-64.0748
-64.0053
-63.982
-64.0053
-64.0748
-64.1888
-64.3445
-64.5386
-64.7668
-65.0242
-65.3061
-65.6071
-65.9223
-66.2468
-66.5761
-66.906
-67.2327
-67.5532
-67.8644
-68.164
-68.45
-68.7208
-68.975
-69.2117
-69.4301
-69.6295
-69.8095
-69.9699
-70.1104
-70.2309
-70.3314
-70.4117
-70.472
-70.5121
-70.5322
-73.3258
-73.3069
-73.2691
-73.2125
-73.137
-73.0427
-72.9297
-72.7982
-72.6484
-72.4805
-72.295
-72.0924
-71.8734
-71.6388
-71.3898
-71.1276
-70.8539
-70.5707
-70.2802
-69.9851
-69.6883
-69.3933
-69.1037
-68.8234
-68.5567
-68.308
-68.0814
-67.8812
-67.7114
-67.5753
-67.476
-67.4154
-67.3951
-67.4154
-67.476
-67.5753
-67.7114
-67.8812
-68.0814
-68.308
-68.5567
-68.8234
-69.1037
-69.3933
-69.6883
-69.9851
-70.2802
-70.5707
-70.8539
-71.1276
-71.3898
-71.6388
-71.8734
-72.0924
-72.295
-72.4805
-72.6484
-72.7982
-72.9297
-73.0427
-73.137
-73.2125
-73.2691
-73.3069
-73.3258
-76.1387
-76.1209
-76.0855
-76.0324
-75.9617
-75.8734
-75.7679
-75.6451
-75.5056
-75.3495
-75.1774
-74.9898
-74.7876
-74.5716
-74.3429
-74.1029
-73.8532
-73.5957
-73.3324
-73.0659
-72.7989
-72.5343
-72.2755
-72.0259
-71.7892
-71.5691
-71.3692
-71.193
-71.0439
-70.9246
-70.8377
-70.7847
-70.767
-70.7847
-70.8377
-70.9246
-71.0439
-71.193
-71.3692
-71.5691
-71.7892
-72.0259
-72.2755
-72.5343
-72.7989
-73.0659
-73.3324
-73.5957
-73.8532
-74.1029
-74.3429
-74.5716
-74.7876
-74.9898
-75.1774
-75.3495
-75.5056
-75.6451
-75.7679
-75.8734
-75.9617
-76.0324
-76.0855
-76.1209
-76.1387
-78.9695
-78.953
-78.9198
-78.8702
-78.8041
-78.7218
-78.6234
-78.5092
-78.3795
-78.2347
-78.0754
-77.9021
-77.7157
-77.5172
-77.3075
-77.0881
-76.8605
-76.6265
-76.388
-76.1473
-75.9069
-75.6695
-75.438
-75.2154
-75.0049
-74.8097
-74.6329
-74.4774
-74.346
-74.2412
-74.1648
-74.1183
-74.1028
-74.1183
-74.1648
-74.2412
-74.346
-74.4774
-74.6329
-74.8097
-75.0049
-75.2154
-75.438
-75.6695
-75.9069
-76.1473
-76.388
-76.6265
-76.8605
-77.0881
-77.3075
-77.5172
-77.7157
-77.9021
-78.0754
-78.2347
-78.3795
-78.5092
-78.6234
-78.7218
-78.8041
-78.8702
-78.9198
-78.953
-78.9695
-81.8173
-81.8018
-81.7709
-81.7246
-81.6631
-81.5865
-81.495
-81.389
-81.2687
-81.1347
-80.9875
-80.8277
-80.6563
-80.474
-80.282
-80.0817
-79.8743
-79.6617
-79.4457
-79.2283
-79.0118
-78.7986
-78.5913
-78.3926
-78.2051
-78.0316
-77.8749
-77.7373
-77.6213
-77.5288
-77.4615
-77.4206
-77.4069
-77.4206
-77.4615
-77.5288
-77.6213
-77.7373
-77.8749
-78.0316
-78.2051
-78.3926
-78.5913
-78.7986
-79.0118
-79.2283
-79.4457
-79.6617
-79.8743
-80.0817
-80.282
-80.474
-80.6563
-80.8277
-80.9875
-81.1347
-81.2687
-81.389
-81.495
-81.5865
-81.6631
-81.7246
-81.7709
-81.8018
-81.8173
-84.6808
-84.6664
-84.6376
-84.5946
-84.5374
-84.4662
-84.3814
-84.2831
-84.1719
-84.0481
-83.9123
-83.7653
-83.6078
-83.4407
-83.2651
-83.0822
-82.8935
-82.7005
-82.5048
-82.3085
-82.1134
-81.9218
-81.736
-81.5583
-81.391
-81.2366
-81.0974
-80.9754
-80.8726
-80.7908
-80.7314
-80.6953
-80.6832
-80.6953
-80.7314
-80.7908
-80.8726
-80.9754
-81.0974
-81.2366
-81.391
-81.5583
-81.736
-81.9218
-82.1134
-82.3085
-82.5048
-82.7005
-82.8935
-83.0822
-83.2651
-83.4407
-83.6078
-83.7653
-83.9123
-84.0481
-84.1719
-84.2831
-84.3814
-84.4662
-84.5374
-84.5946
-84.6376
-84.6664
-84.6808
-87.5589
-87.5455
-87.5188
-87.4789
-87.4259
-87.3599
-87.2814
-87.1906
-87.0878
-86.9737
-86.8487
-86.7135
-86.569
-86.416
-86.2555
-86.0888
-85.9171
-85.7419
-85.5647
-85.3873
-85.2115
-85.0392
-84.8725
-84.7134
-84.5639
-84.4263
-84.3023
-84.1939
-84.1027
-84.0302
-83.9775
-83.9456
-83.9348
-83.9456
-83.9775
-84.0302
-84.1027
-84.1939
-84.3023
-84.4263
-84.5639
-84.7134
-84.8725
-85.0392
-85.2115
-85.3873
-85.5647
-85.7419
-85.9171
-86.0888
-86.2555
-86.416
-86.569
-86.7135
-86.8487
-86.9737
-87.0878
-87.1906
-87.2814
-87.3599
-87.4259
-87.4789
-87.5188
-87.5455
-87.5589
-90.4506
-90.4382
-90.4135
-90.3765
-90.3274
-90.2665
-90.1939
-90.1101
-90.0153
-89.9102
-89.7953
-89.6713
-89.5388
-89.3988
-89.2523
-89.1004
-88.9443
-88.7852
-88.6248
-88.4645
-88.3059
-88.1509
-88.0012
-87.8586
-87.7249
-87.602
-87.4914
-87.3949
-87.3138
-87.2494
-87.2026
-87.1743
-87.1648
-87.1743
-87.2026
-87.2494
-87.3138
-87.3949
-87.4914
-87.602
-87.7249
-87.8586
-88.0012
-88.1509
-88.3059
-88.4645
-88.6248
-88.7852
-88.9443
-89.1004
-89.2523
-89.3988
-89.5388
-89.6713
-89.7953
-89.9102
-90.0153
-90.1101
-90.1939
-90.2665
-90.3274
-90.3765
-90.4135
-90.4382
-90.4506
-93.3549
-93.3434
-93.3205
-93.2864
-93.2411
-93.1848
-93.1179
-93.0406
-92.9534
-92.8568
-92.7513
-92.6375
-92.5162
-92.3883
-92.2547
-92.1163
-91.9744
-91.8301
-91.6848
-91.5399
-91.3968
-91.2573
-91.1227
-90.9947
-90.875
-90.7651
-90.6664
-90.5803
-90.508
-90.4506
-90.409
-90.3838
-90.3754
-90.3838
-90.409
-90.4506
-90.508
-90.5803
-90.6664
-90.7651
-90.875
-90.9947
-91.1227
-91.2573
-91.3968
-91.5399
-91.6848
-91.8301
-91.9744
-92.1163
-92.2547
-92.3883
-92.5162
-92.6375
-92.7513
-92.8568
-92.9534
-93.0406
-93.1179
-93.1848
-93.2411
-93.2864
-93.3205
-93.3434
-93.3549
-96.2708
-96.2602
-96.2391
-96.2076
-96.1658
-96.1139
-96.0523
-95.9812
-95.9011
-95.8123
-95.7156
-95.6114
-95.5005
-95.3836
-95.2618
-95.1358
-95.0068
-94.8759
-94.7443
-94.6133
-94.4843
-94.3585
-94.2375
-94.1226
-94.0152
-93.9167
-93.8285
-93.7515
-93.6871
-93.6359
-93.5988
-93.5764
-93.5688
-93.5764
-93.5988
-93.6359
-93.6871
-93.7515
-93.8285
-93.9167
-94.0152
-94.1226
-94.2375
-94.3585
-94.4843
-94.6133
-94.7443
-94.8759
-95.0068
-95.1358
-95.2618
-95.3836
-95.5005
-95.6114
-95.7156
-95.8123
-95.9011
-95.9812
-96.0523
-96.1139
-96.1658
-96.2076
-96.2391
-96.2602
-96.2708
-99.1975
-99.1877
-99.1683
-99.1392
-99.1008
-99.053
-98.9963
-98.931
-98.8574
-98.776
-98.6874
-98.5921
-98.4907
-98.3841
-98.273
-98.1584
-98.0412
-97.9225
-97.8033
-97.6848
-97.5683
-97.4549
-97.346
-97.2427
-97.1463
-97.0581
-96.979
-96.9102
-96.8526
-96.8069
-96.7738
-96.7537
-96.747
-96.7537
-96.7738
-96.8069
-96.8526
-96.9102
-96.979
-97.0581
-97.1463
-97.2427
-97.346
-97.4549
-97.5683
-97.6848
-97.8033
-97.9225
-98.0412
-98.1584
-98.273
-98.3841
-98.4907
-98.5921
-98.6874
-98.776
-98.8574
-98.931
-98.9963
-99.053
-99.1008
-99.1392
-99.1683
-99.1877
-99.1975
-102.134
-102.125
-102.107
-102.08
-102.045
-102.001
-101.949
-101.889
-101.822
-101.747
-101.666
-101.579
-101.486
-101.389
-101.288
-101.184
-101.077
-100.969
-100.862
-100.754
-100.649
-100.547
-100.449
-100.356
-100.269
-100.19
-100.119
-100.058
-100.006
-99.9651
-99.9355
-99.9176
-99.9116
-99.9176
-99.9355
-99.9651
-100.006
-100.058
-100.119
-100.19
-100.269
-100.356
-100.449
-100.547
-100.649
-100.754
-100.862
-100.969
-101.077
-101.184
-101.288
-101.389
-101.486
-101.579
-101.666
-101.747
-101.822
-101.889
-101.949
-102.001
-102.045
-102.08
-102.107
-102.125
-102.134
-105.08
-105.072
-105.055
-105.031
-104.998
-104.958
-104.91
-104.855
-104.793
-104.725
-104.651
-104.571
-104.487
-104.398
-104.306
-104.211
-104.114
-104.017
-103.919
-103.822
-103.727
-103.635
-103.546
-103.463
-103.385
-103.314
-103.25
-103.195
-103.148
-103.112
-103.085
-103.069
-103.064
-103.069
-103.085
-103.112
-103.148
-103.195
-103.25
-103.314
-103.385
-103.463
-103.546
-103.635
-103.727
-103.822
-103.919
-104.017
-104.114
-104.211
-104.306
-104.398
-104.487
-104.571
-104.651
-104.725
-104.793
-104.855
-104.91
-104.958
-104.998
-105.031
-105.055
-105.072
-105.08
-108.034
-108.026
-108.011
-107.989
-107.959
-107.922
-107.878
-107.828
-107.771
-107.709
-107.641
-107.568
-107.491
-107.41
-107.327
-107.24
-107.153
-107.064
-106.975
-106.888
-106.802
-106.719
-106.639
-106.563
-106.493
-106.429
-106.372
-106.323
-106.281
-106.248
-106.225
-106.21
-106.205
-106.21
-106.225
-106.248
-106.281
-106.323
-106.372
-106.429
-106.493
-106.563
-106.639
-106.719
-106.802
-106.888
-106.975
-107.064
-107.153
-107.24
-107.327
-107.41
-107.491
-107.568
-107.641
-107.709
-107.771
-107.828
-107.878
-107.922
-107.959
-107.989
-108.011
-108.026
-108.034
-110.996
-110.989
-110.975
-110.954
-110.927
-110.893
-110.853
-110.807
-110.755
-110.698
-110.636
-110.57
-110.5
-110.426
-110.35
-110.271
-110.192
-110.111
-110.031
-109.952
-109.874
-109.799
-109.727
-109.659
-109.596
-109.538
-109.487
-109.442
-109.405
-109.376
-109.354
-109.341
-109.337
-109.341
-109.354
-109.376
-109.405
-109.442
-109.487
-109.538
-109.596
-109.659
-109.727
-109.799
-109.874
-109.952
-110.031
-110.111
-110.192
-110.271
-110.35
-110.426
-110.5
-110.57
-110.636
-110.698
-110.755
-110.807
-110.853
-110.893
-110.927
-110.954
-110.975
-110.989
-110.996
-113.964
-113.958
-113.945
-113.927
-113.902
-113.871
-113.834
-113.792
-113.744
-113.692
-113.636
-113.575
-113.511
-113.444
-113.375
-113.304
-113.232
-113.159
-113.086
-113.014
-112.944
-112.876
-112.811
-112.75
-112.693
-112.641
-112.595
-112.554
-112.521
-112.495
-112.475
-112.464
-112.46
-112.464
-112.475
-112.495
-112.521
-112.554
-112.595
-112.641
-112.693
-112.75
-112.811
-112.876
-112.944
-113.014
-113.086
-113.159
-113.232
-113.304
-113.375
-113.444
-113.511
-113.575
-113.636
-113.692
-113.744
-113.792
-113.834
-113.871
-113.902
-113.927
-113.945
-113.958
-113.964
-116.94
-116.934
-116.922
-116.905
-116.882
-116.854
-116.82
-116.782
-116.739
-116.691
-116.64
-116.584
-116.526
-116.465
-116.402
-116.337
-116.272
-116.206
-116.14
-116.075
-116.011
-115.95
-115.891
-115.836
-115.785
-115.738
-115.696
-115.66
-115.63
-115.606
-115.589
-115.578
-115.575
-115.578
-115.589
-115.606
-115.63
-115.66
-115.696
-115.738
-115.785
-115.836
-115.891
-115.95
-116.011
-116.075
-116.14
-116.206
-116.272
-116.337
-116.402
-116.465
-116.526
-116.584
-116.64
-116.691
-116.739
-116.782
-116.82
-116.854
-116.882
-116.905
-116.922
-116.934
-116.94
-119.921
-119.916
-119.905
-119.889
-119.868
-119.842
-119.812
-119.777
-119.737
-119.694
-119.647
-119.597
-119.544
-119.488
-119.431
-119.372
-119.312
-119.253
-119.193
-119.134
-119.076
-119.021
-118.968
-118.918
-118.872
-118.83
-118.792
-118.759
-118.732
-118.711
-118.695
-118.686
-118.683
-118.686
-118.695
-118.711
-118.732
-118.759
-118.792
-118.83
-118.872
-118.918
-118.968
-119.021
-119.076
-119.134
-119.193
-119.253
-119.312
-119.372
-119.431
-119.488
-119.544
-119.597
-119.647
-119.694
-119.737
-119.777
-119.812
-119.842
-119.868
-119.889
-119.905
-119.916
-119.921
-122.908
-122.903
-122.893
-122.879
-122.86
-122.836
-122.808
-122.776
-122.74
-122.7
-122.658
-122.612
-122.563
-122.513
-122.461
-122.408
-122.353
-122.299
-122.245
-122.192
-122.14
-122.089
-122.041
-121.996
-121.955
-121.917
-121.883
-121.853
-121.829
-121.81
-121.796
-121.787
-121.784
-121.787
-121.796
-121.81
-121.829
-121.853
-121.883
-121.917
-121.955
-121.996
-122.041
-122.089
-122.14
-122.192
-122.245
-122.299
-122.353
-122.408
-122.461
-122.513
-122.563
-122.612
-122.658
-122.7
-122.74
-122.776
-122.808
-122.836
-122.86
-122.879
-122.893
-122.903
-122.908
-125.899
-125.895
-125.886
-125.873
-125.855
-125.834
-125.808
-125.779
-125.746
-125.71
-125.671
-125.629
-125.586
-125.54
-125.492
-125.444
-125.395
-125.345
-125.296
-125.248
-125.201
-125.156
-125.112
-125.072
-125.034
-124.999
-124.969
-124.942
-124.92
-124.903
-124.89
-124.883
-124.88
-124.883
-124.89
-124.903
-124.92
-124.942
-124.969
-124.999
-125.034
-125.072
-125.112
-125.156
-125.201
-125.248
-125.296
-125.345
-125.395
-125.444
-125.492
-125.54
-125.586
-125.629
-125.671
-125.71
-125.746
-125.779
-125.808
-125.834
-125.855
-125.873
-125.886
-125.895
-125.899
-128.895
-128.891
-128.883
-128.871
-128.855
-128.836
-128.812
-128.786
-128.756
-128.723
-128.687
-128.65
-128.61
-128.568
-128.525
-128.481
-128.436
-128.392
-128.347
-128.303
-128.261
-128.22
-128.18
-128.144
-128.109
-128.078
-128.051
-128.027
-128.007
-127.991
-127.98
-127.973
-127.971
-127.973
-127.98
-127.991
-128.007
-128.027
-128.051
-128.078
-128.109
-128.144
-128.18
-128.22
-128.261
-128.303
-128.347
-128.392
-128.436
-128.481
-128.525
-128.568
-128.61
-128.65
-128.687
-128.723
-128.756
-128.786
-128.812
-128.836
-128.855
-128.871
-128.883
-128.891
-128.895
-131.896
-131.892
-131.885
-131.874
-131.859
-131.841
-131.82
-131.796
-131.768
-131.738
-131.706
-131.672
-131.635
-131.597
-131.558
-131.518
-131.478
-131.437
-131.397
-131.357
-131.319
-131.282
-131.246
-131.213
-131.182
-131.154
-131.129
-131.108
-131.09
-131.075
-131.065
-131.059
-131.057
-131.059
-131.065
-131.075
-131.09
-131.108
-131.129
-131.154
-131.182
-131.213
-131.246
-131.282
-131.319
-131.357
-131.397
-131.437
-131.478
-131.518
-131.558
-131.597
-131.635
-131.672
-131.706
-131.738
-131.768
-131.796
-131.82
-131.841
-131.859
-131.874
-131.885
-131.892
-131.896
-134.9
-134.896
-134.889
-134.879
-134.866
-134.85
-134.831
-134.808
-134.784
-134.756
-134.727
-134.696
-134.663
-134.628
-134.593
-134.556
-134.52
-134.483
-134.446
-134.41
-134.375
-134.342
-134.31
-134.28
-134.252
-134.226
-134.204
-134.184
-134.168
-134.155
-134.146
-134.141
-134.139
-134.141
-134.146
-134.155
-134.168
-134.184
-134.204
-134.226
-134.252
-134.28
-134.31
-134.342
-134.375
-134.41
-134.446
-134.483
-134.52
-134.556
-134.593
-134.628
-134.663
-134.696
-134.727
-134.756
-134.784
-134.808
-134.831
-134.85
-134.866
-134.879
-134.889
-134.896
-134.9
-137.907
-137.904
-137.898
-137.889
-137.877
-137.862
-137.844
-137.824
-137.801
-137.777
-137.75
-137.721
-137.691
-137.66
-137.628
-137.595
-137.562
-137.528
-137.495
-137.463
-137.431
-137.4
-137.371
-137.344
-137.319
-137.296
-137.276
-137.258
-137.243
-137.232
-137.223
-137.218
-137.217
-137.218
-137.223
-137.232
-137.243
-137.258
-137.276
-137.296
-137.319
-137.344
-137.371
-137.4
-137.431
-137.463
-137.495
-137.528
-137.562
-137.595
-137.628
-137.66
-137.691
-137.721
-137.75
-137.777
-137.801
-137.824
-137.844
-137.862
-137.877
-137.889
-137.898
-137.904
-137.907
-140.918
-140.915
-140.909
-140.901
-140.89
-140.876
-140.86
-140.842
-140.821
-140.799
-140.775
-140.749
-140.721
-140.693
-140.664
-140.634
-140.604
-140.573
-140.543
-140.514
-140.485
-140.457
-140.431
-140.406
-140.384
-140.363
-140.345
-140.329
-140.315
-140.305
-140.297
-140.293
-140.291
-140.293
-140.297
-140.305
-140.315
-140.329
-140.345
-140.363
-140.384
-140.406
-140.431
-140.457
-140.485
-140.514
-140.543
-140.573
-140.604
-140.634
-140.664
-140.693
-140.721
-140.749
-140.775
-140.799
-140.821
-140.842
-140.86
-140.876
-140.89
-140.901
-140.909
-140.915
-140.918
-143.931
-143.928
-143.923
-143.916
-143.906
-143.893
-143.879
-143.862
-143.843
-143.823
-143.801
-143.777
-143.752
-143.727
-143.7
-143.673
-143.646
-143.618
-143.591
-143.564
-143.538
-143.513
-143.489
-143.467
-143.446
-143.428
-143.411
-143.397
-143.385
-143.375
-143.368
-143.364
-143.363
-143.364
-143.368
-143.375
-143.385
-143.397
-143.411
-143.428
-143.446
-143.467
-143.489
-143.513
-143.538
-143.564
-143.591
-143.618
-143.646
-143.673
-143.7
-143.727
-143.752
-143.777
-143.801
-143.823
-143.843
-143.862
-143.879
-143.893
-143.906
-143.916
-143.923
-143.928
-143.931
-146.947
-146.945
-146.94
-146.933
-146.924
-146.913
-146.9
-146.884
-146.867
-146.849
-146.829
-146.807
-146.785
-146.761
-146.737
-146.712
-146.688
-146.663
-146.638
-146.614
-146.59
-146.567
-146.546
-146.526
-146.507
-146.49
-146.475
-146.462
-146.451
-146.443
-146.436
-146.433
-146.432
-146.433
-146.436
-146.443
-146.451
-146.462
-146.475
-146.49
-146.507
-146.526
-146.546
-146.567
-146.59
-146.614
-146.638
-146.663
-146.688
-146.712
-146.737
-146.761
-146.785
-146.807
-146.829
-146.849
-146.867
-146.884
-146.9
-146.913
-146.924
-146.933
-146.94
-146.945
-146.947
-149.965
-149.963
-149.959
-149.953
-149.944
-149.934
-149.922
-149.908
-149.893
-149.876
-149.858
-149.838
-149.818
-149.796
-149.775
-149.752
-149.73
-149.707
-149.685
-149.663
-149.641
-149.621
-149.601
-149.583
-149.566
-149.551
-149.537
-149.525
-149.515
-149.508
-149.502
-149.499
-149.498
-149.499
-149.502
-149.508
-149.515
-149.525
-149.537
-149.551
-149.566
-149.583
-149.601
-149.621
-149.641
-149.663
-149.685
-149.707
-149.73
-149.752
-149.775
-149.796
-149.818
-149.838
-149.858
-149.876
-149.893
-149.908
-149.922
-149.934
-149.944
-149.953
-149.959
-149.963
-149.965
-152.986
-152.984
-152.98
-152.974
-152.967
-152.958
-152.947
-152.934
-152.92
-152.905
-152.888
-152.87
-152.852
-152.832
-152.812
-152.792
-152.772
-152.751
-152.731
-152.711
-152.692
-152.673
-152.655
-152.639
-152.623
-152.61
-152.597
-152.587
-152.578
-152.571
-152.566
-152.563
-152.562
-152.563
-152.566
-152.571
-152.578
-152.587
-152.597
-152.61
-152.623
-152.639
-152.655
-152.673
-152.692
-152.711
-152.731
-152.751
-152.772
-152.792
-152.812
-152.832
-152.852
-152.87
-152.888
-152.905
-152.92
-152.934
-152.947
-152.958
-152.967
-152.974
-152.98
-152.984
-152.986
-156.008
-156.007
-156.003
-155.998
-155.991
-155.983
-155.973
-155.961
-155.948
-155.934
-155.919
-155.903
-155.886
-155.869
-155.851
-155.832
-155.814
-155.795
-155.777
-155.759
-155.741
-155.724
-155.708
-155.693
-155.679
-155.667
-155.656
-155.646
-155.638
-155.632
-155.627
-155.624
-155.623
-155.624
-155.627
-155.632
-155.638
-155.646
-155.656
-155.667
-155.679
-155.693
-155.708
-155.724
-155.741
-155.759
-155.777
-155.795
-155.814
-155.832
-155.851
-155.869
-155.886
-155.903
-155.919
-155.934
-155.948
-155.961
-155.973
-155.983
-155.991
-155.998
-156.003
-156.007
-156.008
-159.033
-159.031
-159.028
-159.023
-159.017
-159.009
-159
-158.99
-158.978
-158.965
-158.952
-158.937
-158.922
-158.906
-158.889
-158.873
-158.856
-158.839
-158.822
-158.806
-158.79
-158.775
-158.76
-158.747
-158.734
-158.723
-158.712
-158.704
-158.696
-158.691
-158.687
-158.684
-158.683
-158.684
-158.687
-158.691
-158.696
-158.704
-158.712
-158.723
-158.734
-158.747
-158.76
-158.775
-158.79
-158.806
-158.822
-158.839
-158.856
-158.873
-158.889
-158.906
-158.922
-158.937
-158.952
-158.965
-158.978
-158.99
-159
-159.009
-159.017
-159.023
-159.028
-159.031
-159.033
-162.058
-162.057
-162.054
-162.05
-162.044
-162.037
-162.029
-162.019
-162.009
-161.997
-161.985
-161.972
-161.958
-161.943
-161.928
-161.913
-161.898
-161.883
-161.867
-161.853
-161.838
-161.824
-161.811
-161.799
-161.787
-161.777
-161.768
-161.76
-161.753
-161.748
-161.745
-161.742
-161.742
-161.742
-161.745
-161.748
-161.753
-161.76
-161.768
-161.777
-161.787
-161.799
-161.811
-161.824
-161.838
-161.853
-161.867
-161.883
-161.898
-161.913
-161.928
-161.943
-161.958
-161.972
-161.985
-161.997
-162.009
-162.019
-162.029
-162.037
-162.044
-162.05
-162.054
-162.057
-162.058
-165.086
-165.084
-165.082
-165.078
-165.073
-165.066
-165.059
-165.05
-165.041
-165.03
-165.019
-165.007
-164.994
-164.981
-164.968
-164.954
-164.94
-164.926
-164.912
-164.899
-164.886
-164.873
-164.861
-164.85
-164.84
-164.83
-164.822
-164.815
-164.809
-164.804
-164.801
-164.799
-164.798
-164.799
-164.801
-164.804
-164.809
-164.815
-164.822
-164.83
-164.84
-164.85
-164.861
-164.873
-164.886
-164.899
-164.912
-164.926
-164.94
-164.954
-164.968
-164.981
-164.994
-165.007
-165.019
-165.03
-165.041
-165.05
-165.059
-165.066
-165.073
-165.078
-165.082
-165.084
-165.086
-168.114
-168.113
-168.111
-168.107
-168.103
-168.097
-168.09
-168.082
-168.074
-168.064
-168.054
-168.043
-168.031
-168.019
-168.007
-167.995
-167.982
-167.969
-167.957
-167.945
-167.933
-167.921
-167.911
-167.901
-167.891
-167.883
-167.875
-167.869
-167.863
-167.859
-167.856
-167.854
-167.854
-167.854
-167.856
-167.859
-167.863
-167.869
-167.875
-167.883
-167.891
-167.901
-167.911
-167.921
-167.933
-167.945
-167.957
-167.969
-167.982
-167.995
-168.007
-168.019
-168.031
-168.043
-168.054
-168.064
-168.074
-168.082
-168.09
-168.097
-168.103
-168.107
-168.111
-168.113
-168.114
-171.144
-171.143
-171.141
-171.138
-171.134
-171.128
-171.122
-171.115
-171.107
-171.098
-171.089
-171.079
-171.069
-171.058
-171.047
-171.035
-171.024
-171.013
-171.001
-170.99
-170.98
-170.969
-170.959
-170.95
-170.942
-170.934
-170.927
-170.921
-170.916
-170.913
-170.91
-170.908
-170.908
-170.908
-170.91
-170.913
-170.916
-170.921
-170.927
-170.934
-170.942
-170.95
-170.959
-170.969
-170.98
-170.99
-171.001
-171.013
-171.024
-171.035
-171.047
-171.058
-171.069
-171.079
-171.089
-171.098
-171.107
-171.115
-171.122
-171.128
-171.134
-171.138
-171.141
-171.143
-171.144
-174.175
-174.174
-174.172
-174.169
-174.165
-174.161
-174.155
-174.149
-174.142
-174.134
-174.125
-174.116
-174.107
-174.097
-174.087
-174.076
-174.066
-174.056
-174.045
-174.035
-174.026
-174.016
-174.007
-173.999
-173.991
-173.984
-173.978
-173.973
-173.969
-173.965
-173.963
-173.961
-173.961
-173.961
-173.963
-173.965
-173.969
-173.973
-173.978
-173.984
-173.991
-173.999
-174.007
-174.016
-174.026
-174.035
-174.045
-174.056
-174.066
-174.076
-174.087
-174.097
-174.107
-174.116
-174.125
-174.134
-174.142
-174.149
-174.155
-174.161
-174.165
-174.169
-174.172
-174.174
-174.175
-177.207
-177.206
-177.205
-177.202
-177.198
-177.194
-177.189
-177.183
-177.177
-177.169
-177.162
-177.154
-177.145
-177.136
-177.127
-177.118
-177.108
-177.099
-177.089
-177.08
-177.071
-177.063
-177.055
-177.047
-177.04
-177.034
-177.029
-177.024
-177.02
-177.017
-177.014
-177.013
-177.012
-177.013
-177.014
-177.017
-177.02
-177.024
-177.029
-177.034
-177.04
-177.047
-177.055
-177.063
-177.071
-177.08
-177.089
-177.099
-177.108
-177.118
-177.127
-177.136
-177.145
-177.154
-177.162
-177.169
-177.177
-177.183
-177.189
-177.194
-177.198
-177.202
-177.205
-177.206
-177.207
-180.24
-180.239
-180.238
-180.235
-180.232
-180.228
-180.224
-180.218
-180.212
-180.206
-180.199
-180.191
-180.184
-180.176
-180.167
-180.159
-180.15
-180.142
-180.133
-180.125
-180.117
-180.109
-180.102
-180.095
-180.089
-180.083
-180.078
-180.074
-180.07
-180.067
-180.065
-180.064
-180.063
-180.064
-180.065
-180.067
-180.07
-180.074
-180.078
-180.083
-180.089
-180.095
-180.102
-180.109
-180.117
-180.125
-180.133
-180.142
-180.15
-180.159
-180.167
-180.176
-180.184
-180.191
-180.199
-180.206
-180.212
-180.218
-180.224
-180.228
-180.232
-180.235
-180.238
-180.239
-180.24
-183.274
-183.273
-183.272
-183.269
-183.267
-183.263
-183.259
-183.254
-183.249
-183.243
-183.236
-183.23
-183.223
-183.215
-183.208
-183.2
-183.192
-183.184
-183.177
-183.169
-183.162
-183.155
-183.148
-183.142
-183.136
-183.131
-183.127
-183.123
-183.119
-183.117
-183.115
-183.114
-183.113
-183.114
-183.115
-183.117
-183.119
-183.123
-183.127
-183.131
-183.136
-183.142
-183.148
-183.155
-183.162
-183.169
-183.177
-183.184
-183.192
-183.2
-183.208
-183.215
-183.223
-183.23
-183.236
-183.243
-183.249
-183.254
-183.259
-183.263
-183.267
-183.269
-183.272
-183.273
-183.274
-186.308
-186.308
-186.306
-186.304
-186.302
-186.298
-186.295
-186.29
-186.285
-186.28
-186.274
-186.268
-186.262
-186.255
-186.248
-186.241
-186.234
-186.227
-186.22
-186.213
-186.207
-186.2
-186.194
-186.189
-186.184
-186.179
-186.175
-186.171
-186.168
-186.166
-186.164
-186.163
-186.163
-186.163
-186.164
-186.166
-186.168
-186.171
-186.175
-186.179
-186.184
-186.189
-186.194
-186.2
-186.207
-186.213
-186.22
-186.227
-186.234
-186.241
-186.248
-186.255
-186.262
-186.268
-186.274
-186.28
-186.285
-186.29
-186.295
-186.298
-186.302
-186.304
-186.306
-186.308
-186.308
-189.343
-189.343
-189.342
-189.34
-189.337
-189.335
-189.331
-189.327
-189.323
-189.318
-189.313
-189.307
-189.301
-189.295
-189.289
-189.283
-189.276
-189.27
-189.263
-189.257
-189.251
-189.246
-189.24
-189.235
-189.23
-189.226
-189.222
-189.219
-189.216
-189.214
-189.213
-189.212
-189.211
-189.212
-189.213
-189.214
-189.216
-189.219
-189.222
-189.226
-189.23
-189.235
-189.24
-189.246
-189.251
-189.257
-189.263
-189.27
-189.276
-189.283
-189.289
-189.295
-189.301
-189.307
-189.313
-189.318
-189.323
-189.327
-189.331
-189.335
-189.337
-189.34
-189.342
-189.343
-189.343
-192.379
-192.379
-192.378
-192.376
-192.374
-192.371
-192.368
-192.364
-192.36
-192.356
-192.351
-192.346
-192.341
-192.335
-192.33
-192.324
-192.318
-192.312
-192.307
-192.301
-192.296
-192.29
-192.285
-192.281
-192.277
-192.273
-192.269
-192.266
-192.264
-192.262
-192.261
-192.26
-192.259
-192.26
-192.261
-192.262
-192.264
-192.266
-192.269
-192.273
-192.277
-192.281
-192.285
-192.29
-192.296
-192.301
-192.307
-192.312
-192.318
-192.324
-192.33
-192.335
-192.341
-192.346
-192.351
-192.356
-192.36
-192.364
-192.368
-192.371
-192.374
-192.376
-192.378
-192.379
-192.379
-195.416
-195.415
-195.414
-195.413
-195.411
-195.408
-195.405
-195.402
-195.398
-195.394
-195.39
-195.386
-195.381
-195.376
-195.371
-195.365
-195.36
-195.355
-195.35
-195.345
-195.34
-195.335
-195.33
-195.326
-195.322
-195.319
-195.316
-195.313
-195.311
-195.309
-195.308
-195.307
-195.307
-195.307
-195.308
-195.309
-195.311
-195.313
-195.316
-195.319
-195.322
-195.326
-195.33
-195.335
-195.34
-195.345
-195.35
-195.355
-195.36
-195.365
-195.371
-195.376
-195.381
-195.386
-195.39
-195.394
-195.398
-195.402
-195.405
-195.408
-195.411
-195.413
-195.414
-195.415
-195.416
-198.452
-198.452
-198.451
-198.45
-198.448
-198.446
-198.443
-198.44
-198.437
-198.433
-198.429
-198.425
-198.421
-198.416
-198.412
-198.407
-198.402
-198.397
-198.393
-198.388
-198.384
-198.379
-198.375
-198.371
-198.368
-198.365
-198.362
-198.359
-198.357
-198.356
-198.355
-198.354
-198.354
-198.354
-198.355
-198.356
-198.357
-198.359
-198.362
-198.365
-198.368
-198.371
-198.375
-198.379
-198.384
-198.388
-198.393
-198.397
-198.402
-198.407
-198.412
-198.416
-198.421
-198.425
-198.429
-198.433
-198.437
-198.44
-198.443
-198.446
-198.448
-198.45
-198.451
-198.452
-198.452
-201.49
-201.489
-201.489
-201.487
-201.486
-201.484
-201.481
-201.479
-201.476
-201.472
-201.469
-201.465
-201.461
-201.457
-201.453
-201.448
-201.444
-201.44
-201.435
-201.431
-201.427
-201.423
-201.42
-201.416
-201.413
-201.41
-201.408
-201.405
-201.403
-201.402
-201.401
-201.4
-201.4
-201.4
-201.401
-201.402
-201.403
-201.405
-201.408
-201.41
-201.413
-201.416
-201.42
-201.423
-201.427
-201.431
-201.435
-201.44
-201.444
-201.448
-201.453
-201.457
-201.461
-201.465
-201.469
-201.472
-201.476
-201.479
-201.481
-201.484
-201.486
-201.487
-201.489
-201.489
-201.49
-204.528
-204.527
-204.526
-204.525
-204.524
-204.522
-204.52
-204.517
-204.515
-204.512
-204.508
-204.505
-204.501
-204.498
-204.494
-204.49
-204.486
-204.482
-204.478
-204.474
-204.471
-204.467
-204.464
-204.461
-204.458
-204.455
-204.453
-204.451
-204.449
-204.448
-204.447
-204.446
-204.446
-204.446
-204.447
-204.448
-204.449
-204.451
-204.453
-204.455
-204.458
-204.461
-204.464
-204.467
-204.471
-204.474
-204.478
-204.482
-204.486
-204.49
-204.494
-204.498
-204.501
-204.505
-204.508
-204.512
-204.515
-204.517
-204.52
-204.522
-204.524
-204.525
-204.526
-204.527
-204.528
-207.566
-207.565
-207.565
-207.564
-207.562
-207.561
-207.559
-207.556
-207.554
-207.551
-207.548
-207.545
-207.542
-207.539
-207.535
-207.532
-207.528
-207.524
-207.521
-207.517
-207.514
-207.511
-207.508
-207.505
-207.502
-207.5
-207.498
-207.496
-207.495
-207.493
-207.492
-207.492
-207.492
-207.492
-207.492
-207.493
-207.495
-207.496
-207.498
-207.5
-207.502
-207.505
-207.508
-207.511
-207.514
-207.517
-207.521
-207.524
-207.528
-207.532
-207.535
-207.539
-207.542
-207.545
-207.548
-207.551
-207.554
-207.556
-207.559
-207.561
-207.562
-207.564
-207.565
-207.565
-207.566
-210.604
-210.604
-210.603
-210.602
-210.601
-210.6
-210.598
-210.596
-210.594
-210.591
-210.588
-210.586
-210.583
-210.579
-210.576
-210.573
-210.57
-210.567
-210.563
-210.56
-210.557
-210.554
-210.552
-210.549
-210.547
-210.544
-210.543
-210.541
-210.54
-210.538
-210.538
-210.537
-210.537
-210.537
-210.538
-210.538
-210.54
-210.541
-210.543
-210.544
-210.547
-210.549
-210.552
-210.554
-210.557
-210.56
-210.563
-210.567
-210.57
-210.573
-210.576
-210.579
-210.583
-210.586
-210.588
-210.591
-210.594
-210.596
-210.598
-210.6
-210.601
-210.602
-210.603
-210.604
-210.604
-213.643
-213.643
-213.642
-213.641
-213.64
-213.639
-213.637
-213.635
-213.633
-213.631
-213.629
-213.626
-213.623
-213.621
-213.618
-213.615
-213.612
-213.609
-213.606
-213.603
-213.6
-213.598
-213.595
-213.593
-213.591
-213.589
-213.587
-213.585
-213.584
-213.583
-213.583
-213.582
-213.582
-213.582
-213.583
-213.583
-213.584
-213.585
-213.587
-213.589
-213.591
-213.593
-213.595
-213.598
-213.6
-213.603
-213.606
-213.609
-213.612
-213.615
-213.618
-213.621
-213.623
-213.626
-213.629
-213.631
-213.633
-213.635
-213.637
-213.639
-213.64
-213.641
-213.642
-213.643
-213.643
-216.682
-216.682
-216.681
-216.68
-216.679
-216.678
-216.677
-216.675
-216.673
-216.671
-216.669
-216.667
-216.664
-216.662
-216.659
-216.656
-216.654
-216.651
-216.648
-216.646
-216.643
-216.641
-216.639
-216.637
-216.635
-216.633
-216.631
-216.63
-216.629
-216.628
-216.627
-216.627
-216.627
-216.627
-216.627
-216.628
-216.629
-216.63
-216.631
-216.633
-216.635
-216.637
-216.639
-216.641
-216.643
-216.646
-216.648
-216.651
-216.654
-216.656
-216.659
-216.662
-216.664
-216.667
-216.669
-216.671
-216.673
-216.675
-216.677
-216.678
-216.679
-216.68
-216.681
-216.682
-216.682
-219.721
-219.721
-219.721
-219.72
-219.719
-219.718
-219.717
-219.715
-219.713
-219.712
-219.71
-219.707
-219.705
-219.703
-219.7
-219.698
-219.696
-219.693
-219.691
-219.688
-219.686
-219.684
-219.682
-219.68
-219.678
-219.677
-219.675
-219.674
-219.673
-219.672
-219.671
-219.671
-219.671
-219.671
-219.671
-219.672
-219.673
-219.674
-219.675
-219.677
-219.678
-219.68
-219.682
-219.684
-219.686
-219.688
-219.691
-219.693
-219.696
-219.698
-219.7
-219.703
-219.705
-219.707
-219.71
-219.712
-219.713
-219.715
-219.717
-219.718
-219.719
-219.72
-219.721
-219.721
-219.721
-222.761
-222.761
-222.76
-222.76
-222.759
-222.758
-222.757
-222.755
-222.754
-222.752
-222.75
-222.748
-222.746
-222.744
-222.742
-222.74
-222.738
-222.735
-222.733
-222.731
-222.729
-222.727
-222.725
-222.723
-222.722
-222.72
-222.719
-222.718
-222.717
-222.716
-222.716
-222.715
-222.715
-222.715
-222.716
-222.716
-222.717
-222.718
-222.719
-222.72
-222.722
-222.723
-222.725
-222.727
-222.729
-222.731
-222.733
-222.735
-222.738
-222.74
-222.742
-222.744
-222.746
-222.748
-222.75
-222.752
-222.754
-222.755
-222.757
-222.758
-222.759
-222.76
-222.76
-222.761
-222.761
-225.801
-225.801
-225.8
-225.8
-225.799
-225.798
-225.797
-225.796
-225.794
-225.793
-225.791
-225.789
-225.787
-225.785
-225.783
-225.781
-225.779
-225.777
-225.775
-225.774
-225.772
-225.77
-225.768
-225.767
-225.765
-225.764
-225.763
-225.761
-225.761
-225.76
-225.759
-225.759
-225.759
-225.759
-225.759
-225.76
-225.761
-225.761
-225.763
-225.764
-225.765
-225.767
-225.768
-225.77
-225.772
-225.774
-225.775
-225.777
-225.779
-225.781
-225.783
-225.785
-225.787
-225.789
-225.791
-225.793
-225.794
-225.796
-225.797
-225.798
-225.799
-225.8
-225.8
-225.801
-225.801
-228.841
-228.841
-228.84
-228.84
-228.839
-228.838
-228.837
-228.836
-228.835
-228.833
-228.832
-228.83
-228.829
-228.827
-228.825
-228.823
-228.821
-228.82
-228.818
-228.816
-228.814
-228.813
-228.811
-228.81
-228.808
-228.807
-228.806
-228.805
-228.804
-228.804
-228.803
-228.803
-228.803
-228.803
-228.803
-228.804
-228.804
-228.805
-228.806
-228.807
-228.808
-228.81
-228.811
-228.813
-228.814
-228.816
-228.818
-228.82
-228.821
-228.823
-228.825
-228.827
-228.829
-228.83
-228.832
-228.833
-228.835
-228.836
-228.837
-228.838
-228.839
-228.84
-228.84
-228.841
-228.841
-231.881
-231.881
-231.88
-231.88
-231.879
-231.879
-231.878
-231.877
-231.875
-231.874
-231.873
-231.871
-231.87
-231.868
-231.867
-231.865
-231.863
-231.862
-231.86
-231.858
-231.857
-231.855
-231.854
-231.853
-231.851
-231.85
-231.849
-231.848
-231.848
-231.847
-231.847
-231.846
-231.846
-231.846
-231.847
-231.847
-231.848
-231.848
-231.849
-231.85
-231.851
-231.853
-231.854
-231.855
-231.857
-231.858
-231.86
-231.862
-231.863
-231.865
-231.867
-231.868
-231.87
-231.871
-231.873
-231.874
-231.875
-231.877
-231.878
-231.879
-231.879
-231.88
-231.88
-231.881
-231.881
-234.921
-234.921
-234.921
-234.92
-234.92
-234.919
-234.918
-234.917
-234.916
-234.915
-234.914
-234.913
-234.911
-234.91
-234.908
-234.907
-234.905
-234.904
-234.902
-234.901
-234.899
-234.898
-234.897
-234.895
-234.894
-234.893
-234.892
-234.892
-234.891
-234.89
-234.89
-234.89
-234.89
-234.89
-234.89
-234.89
-234.891
-234.892
-234.892
-234.893
-234.894
-234.895
-234.897
-234.898
-234.899
-234.901
-234.902
-234.904
-234.905
-234.907
-234.908
-234.91
-234.911
-234.913
-234.914
-234.915
-234.916
-234.917
-234.918
-234.919
-234.92
-234.92
-234.921
-234.921
-234.921
-237.962
-237.962
-237.961
-237.961
-237.96
-237.96
-237.959
-237.958
-237.957
-237.956
-237.955
-237.954
-237.952
-237.951
-237.95
-237.948
-237.947
-237.946
-237.944
-237.943
-237.942
-237.94
-237.939
-237.938
-237.937
-237.936
-237.935
-237.935
-237.934
-237.934
-237.933
-237.933
-237.933
-237.933
-237.933
-237.934
-237.934
-237.935
-237.935
-237.936
-237.937
-237.938
-237.939
-237.94
-237.942
-237.943
-237.944
-237.946
-237.947
-237.948
-237.95
-237.951
-237.952
-237.954
-237.955
-237.956
-237.957
-237.958
-237.959
-237.96
-237.96
-237.961
-237.961
-237.962
-237.962
-241.002
-241.002
-241.002
-241.002
-241.001
-241.001
-241
-240.999
-240.998
-240.997
-240.996
-240.995
-240.994
-240.993
-240.991
-240.99
-240.989
-240.988
-240.986
-240.985
-240.984
-240.983
-240.982
-240.981
-240.98
-240.979
-240.978
-240.978
-240.977
-240.977
-240.976
-240.976
-240.976
-240.976
-240.976
-240.977
-240.977
-240.978
-240.978
-240.979
-240.98
-240.981
-240.982
-240.983
-240.984
-240.985
-240.986
-240.988
-240.989
-240.99
-240.991
-240.993
-240.994
-240.995
-240.996
-240.997
-240.998
-240.999
-241
-241.001
-241.001
-241.002
-241.002
-241.002
-241.002
-244.043
-244.043
-244.043
-244.042
-244.042
-244.041
-244.041
-244.04
-244.039
-244.038
-244.037
-244.036
-244.035
-244.034
-244.033
-244.032
-244.031
-244.03
-244.029
-244.027
-244.026
-244.025
-244.024
-244.023
-244.023
-244.022
-244.021
-244.02
-244.02
-244.02
-244.019
-244.019
-244.019
-244.019
-244.019
-244.02
-244.02
-244.02
-244.021
-244.022
-244.023
-244.023
-244.024
-244.025
-244.026
-244.027
-244.029
-244.03
-244.031
-244.032
-244.033
-244.034
-244.035
-244.036
-244.037
-244.038
-244.039
-244.04
-244.041
-244.041
-244.042
-244.042
-244.043
-244.043
-244.043
-247.084
-247.084
-247.084
-247.083
-247.083
-247.082
-247.082
-247.081
-247.08
-247.08
-247.079
-247.078
-247.077
-247.076
-247.075
-247.074
-247.073
-247.072
-247.071
-247.07
-247.069
-247.068
-247.067
-247.066
-247.065
-247.064
-247.064
-247.063
-247.063
-247.062
-247.062
-247.062
-247.062
-247.062
-247.062
-247.062
-247.063
-247.063
-247.064
-247.064
-247.065
-247.066
-247.067
-247.068
-247.069
-247.07
-247.071
-247.072
-247.073
-247.074
-247.075
-247.076
-247.077
-247.078
-247.079
-247.08
-247.08
-247.081
-247.082
-247.082
-247.083
-247.083
-247.084
-247.084
-247.084
-250.125
-250.125
-250.125
-250.124
-250.124
-250.124
-250.123
-250.122
-250.122
-250.121
-250.12
-250.119
-250.118
-250.117
-250.117
-250.116
-250.115
-250.114
-250.113
-250.112
-250.111
-250.11
-250.109
-250.108
-250.108
-250.107
-250.106
-250.106
-250.105
-250.105
-250.105
-250.105
-250.105
-250.105
-250.105
-250.105
-250.105
-250.106
-250.106
-250.107
-250.108
-250.108
-250.109
-250.11
-250.111
-250.112
-250.113
-250.114
-250.115
-250.116
-250.117
-250.117
-250.118
-250.119
-250.12
-250.121
-250.122
-250.122
-250.123
-250.124
-250.124
-250.124
-250.125
-250.125
-250.125
-253.166
-253.166
-253.166
-253.165
-253.165
-253.165
-253.164
-253.164
-253.163
-253.162
-253.162
-253.161
-253.16
-253.159
-253.158
-253.157
-253.156
-253.156
-253.155
-253.154
-253.153
-253.152
-253.151
-253.151
-253.15
-253.149
-253.149
-253.148
-253.148
-253.148
-253.148
-253.147
-253.147
-253.147
-253.148
-253.148
-253.148
-253.148
-253.149
-253.149
-253.15
-253.151
-253.151
-253.152
-253.153
-253.154
-253.155
-253.156
-253.156
-253.157
-253.158
-253.159
-253.16
-253.161
-253.162
-253.162
-253.163
-253.164
-253.164
-253.165
-253.165
-253.165
-253.166
-253.166
-253.166
-256.207
-256.207
-256.207
-256.207
-256.206
-256.206
-256.205
-256.205
-256.204
-256.204
-256.203
-256.202
-256.202
-256.201
-256.2
-256.199
-256.198
-256.198
-256.197
-256.196
-256.195
-256.194
-256.194
-256.193
-256.192
-256.192
-256.191
-256.191
-256.191
-256.19
-256.19
-256.19
-256.19
-256.19
-256.19
-256.19
-256.191
-256.191
-256.191
-256.192
-256.192
-256.193
-256.194
-256.194
-256.195
-256.196
-256.197
-256.198
-256.198
-256.199
-256.2
-256.201
-256.202
-256.202
-256.203
-256.204
-256.204
-256.205
-256.205
-256.206
-256.206
-256.207
-256.207
-256.207
-256.207
-259.248
-259.248
-259.248
-259.248
-259.248
-259.247
-259.247
-259.246
-259.246
-259.245
-259.245
-259.244
-259.243
-259.242
-259.242
-259.241
-259.24
-259.239
-259.239
-259.238
-259.237
-259.237
-259.236
-259.235
-259.235
-259.234
-259.234
-259.233
-259.233
-259.233
-259.233
-259.233
-259.232
-259.233
-259.233
-259.233
-259.233
-259.233
-259.234
-259.234
-259.235
-259.235
-259.236
-259.237
-259.237
-259.238
-259.239
-259.239
-259.24
-259.241
-259.242
-259.242
-259.243
-259.244
-259.245
-259.245
-259.246
-259.246
-259.247
-259.247
-259.248
-259.248
-259.248
-259.248
-259.248
-262.29
-262.29
-262.289
-262.289
-262.289
-262.289
-262.288
-262.288
-262.287
-262.287
-262.286
-262.286
-262.285
-262.284
-262.284
-262.283
-262.282
-262.281
-262.281
-262.28
-262.279
-262.279
-262.278
-262.278
-262.277
-262.277
-262.276
-262.276
-262.275
-262.275
-262.275
-262.275
-262.275
-262.275
-262.275
-262.275
-262.275
-262.276
-262.276
-262.277
-262.277
-262.278
-262.278
-262.279
-262.279
-262.28
-262.281
-262.281
-262.282
-262.283
-262.284
-262.284
-262.285
-262.286
-262.286
-262.287
-262.287
-262.288
-262.288
-262.289
-262.289
-262.289
-262.289
-262.29
-262.29
-265.331
-265.331
-265.331
-265.331
-265.33
-265.33
-265.33
-265.329
-265.329
-265.328
-265.328
-265.327
-265.327
-265.326
-265.325
-265.325
-265.324
-265.323
-265.323
-265.322
-265.321
-265.321
-265.32
-265.32
-265.319
-265.319
-265.318
-265.318
-265.318
-265.318
-265.317
-265.317
-265.317
-265.317
-265.317
-265.318
-265.318
-265.318
-265.318
-265.319
-265.319
-265.32
-265.32
-265.321
-265.321
-265.322
-265.323
-265.323
-265.324
-265.325
-265.325
-265.326
-265.327
-265.327
-265.328
-265.328
-265.329
-265.329
-265.33
-265.33
-265.33
-265.331
-265.331
-265.331
-265.331
-268.372
-268.372
-268.372
-268.372
-268.372
-268.372
-268.371
-268.371
-268.37
-268.37
-268.369
-268.369
-268.368
-268.368
-268.367
-268.366
-268.366
-268.365
-268.365
-268.364
-268.363
-268.363
-268.362
-268.362
-268.361
-268.361
-268.361
-268.36
-268.36
-268.36
-268.36
-268.36
-268.36
-268.36
-268.36
-268.36
-268.36
-268.36
-268.361
-268.361
-268.361
-268.362
-268.362
-268.363
-268.363
-268.364
-268.365
-268.365
-268.366
-268.366
-268.367
-268.368
-268.368
-268.369
-268.369
-268.37
-268.37
-268.371
-268.371
-268.372
-268.372
-268.372
-268.372
-268.372
-268.372
-271.414
-271.414
-271.414
-271.414
-271.413
-271.413
-271.413
-271.412
-271.412
-271.412
-271.411
-271.411
-271.41
-271.409
-271.409
-271.408
-271.408
-271.407
-271.407
-271.406
-271.405
-271.405
-271.404
-271.404
-271.403
-271.403
-271.403
-271.402
-271.402
-271.402
-271.402
-271.402
-271.402
-271.402
-271.402
-271.402
-271.402
-271.402
-271.403
-271.403
-271.403
-271.404
-271.404
-271.405
-271.405
-271.406
-271.407
-271.407
-271.408
-271.408
-271.409
-271.409
-271.41
-271.411
-271.411
-271.412
-271.412
-271.412
-271.413
-271.413
-271.413
-271.414
-271.414
-271.414
-271.414
-274.456
-274.455
-274.455
-274.455
-274.455
-274.455
-274.454
-274.454
-274.454
-274.453
-274.453
-274.452
-274.452
-274.451
-274.451
-274.45
-274.45
-274.449
-274.448
-274.448
-274.447
-274.447
-274.446
-274.446
-274.446
-274.445
-274.445
-274.445
-274.444
-274.444
-274.444
-274.444
-274.444
-274.444
-274.444
-274.444
-274.444
-274.445
-274.445
-274.445
-274.446
-274.446
-274.446
-274.447
-274.447
-274.448
-274.448
-274.449
-274.45
-274.45
-274.451
-274.451
-274.452
-274.452
-274.453
-274.453
-274.454
-274.454
-274.454
-274.455
-274.455
-274.455
-274.455
-274.455
-274.456
-277.497
-277.497
-277.497
-277.497
-277.497
-277.496
-277.496
-277.496
-277.495
-277.495
-277.495
-277.494
-277.494
-277.493
-277.493
-277.492
-277.491
-277.491
-277.49
-277.49
-277.489
-277.489
-277.488
-277.488
-277.488
-277.487
-277.487
-277.487
-277.486
-277.486
-277.486
-277.486
-277.486
-277.486
-277.486
-277.486
-277.486
-277.487
-277.487
-277.487
-277.488
-277.488
-277.488
-277.489
-277.489
-277.49
-277.49
-277.491
-277.491
-277.492
-277.493
-277.493
-277.494
-277.494
-277.495
-277.495
-277.495
-277.496
-277.496
-277.496
-277.497
-277.497
-277.497
-277.497
-277.497
-280.539
-280.539
-280.539
-280.538
-280.538
-280.538
-280.538
-280.537
-280.537
-280.537
-280.536
-280.536
-280.535
-280.535
-280.534
-280.534
-280.533
-280.533
-280.532
-280.532
-280.531
-280.531
-280.53
-280.53
-280.53
-280.529
-280.529
-280.529
-280.528
-280.528
-280.528
-280.528
-280.528
-280.528
-280.528
-280.528
-280.528
-280.529
-280.529
-280.529
-280.53
-280.53
-280.53
-280.531
-280.531
-280.532
-280.532
-280.533
-280.533
-280.534
-280.534
-280.535
-280.535
-280.536
-280.536
-280.537
-280.537
-280.537
-280.538
-280.538
-280.538
-280.538
-280.539
-280.539
-280.539
-283.58
-283.58
-283.58
-283.58
-283.58
-283.58
-283.58
-283.579
-283.579
-283.578
-283.578
-283.578
-283.577
-283.577
-283.576
-283.576
-283.575
-283.575
-283.574
-283.574
-283.573
-283.573
-283.572
-283.572
-283.572
-283.571
-283.571
-283.571
-283.57
-283.57
-283.57
-283.57
-283.57
-283.57
-283.57
-283.57
-283.57
-283.571
-283.571
-283.571
-283.572
-283.572
-283.572
-283.573
-283.573
-283.574
-283.574
-283.575
-283.575
-283.576
-283.576
-283.577
-283.577
-283.578
-283.578
-283.578
-283.579
-283.579
-283.58
-283.58
-283.58
-283.58
-283.58
-283.58
-283.58
-286.622
-286.622
-286.622
-286.622
-286.622
-286.622
-286.621
-286.621
-286.621
-286.62
-286.62
-286.619
-286.619
-286.618
-286.618
-286.618
-286.617
-286.617
-286.616
-286.616
-286.615
-286.615
-286.614
-286.614
-286.613
-286.613
-286.613
-286.613
-286.612
-286.612
-286.612
-286.612
-286.612
-286.612
-286.612
-286.612
-286.612
-286.613
-286.613
-286.613
-286.613
-286.614
-286.614
-286.615
-286.615
-286.616
-286.616
-286.617
-286.617
-286.618
-286.618
-286.618
-286.619
-286.619
-286.62
-286.62
-286.621
-286.621
-286.621
-286.622
-286.622
-286.622
-286.622
-286.622
-286.622
-289.664
-289.664
-289.664
-289.664
-289.664
-289.663
-289.663
-289.663
-289.662
-289.662
-289.662
-289.661
-289.661
-289.66
-289.66
-289.659
-289.659
-289.658
-289.658
-289.657
-289.657
-289.657
-289.656
-289.656
-289.655
-289.655
-289.655
-289.655
-289.654
-289.654
-289.654
-289.654
-289.654
-289.654
-289.654
-289.654
-289.654
-289.655
-289.655
-289.655
-289.655
-289.656
-289.656
-289.657
-289.657
-289.657
-289.658
-289.658
-289.659
-289.659
-289.66
-289.66
-289.661
-289.661
-289.662
-289.662
-289.662
-289.663
-289.663
-289.663
-289.664
-289.664
-289.664
-289.664
-289.664
  0 KSP preconditioned resid norm 2.323895570103e+08 true resid norm 2.323895570103e+08 ||Ae||/||Ax|| 5.690336650352e-01
  1 KSP preconditioned resid norm 3.346785854152e+06 true resid norm 3.346785854152e+06 ||Ae||/||Ax|| 8.195006028572e-03
  2 KSP preconditioned resid norm 4.820123849610e+03 true resid norm 4.820123849597e+03 ||Ae||/||Ax|| 1.180265058097e-05
  3 KSP preconditioned resid norm 1.466152207985e+01 true resid norm 1.466152208369e+01 ||Ae||/||Ax|| 3.590049292063e-08
  4 KSP preconditioned resid norm 1.116987751777e-01 true resid norm 1.116987932656e-01 ||Ae||/||Ax|| 2.735078741473e-10
  5 KSP preconditioned resid norm 8.016466601186e-05 true resid norm 8.013227122691e-05 ||Ae||/||Ax|| 1.962134640234e-13
Linear solve converged due to CONVERGED_RTOL
Process [0]
70.9845
70.9636
70.9217
70.859
70.776
70.673
70.5505
70.4092
70.25
70.0738
69.8816
69.6747
69.4545
69.2226
68.9807
68.7307
68.4748
68.2151
67.9542
67.6945
67.4387
67.1895
66.9498
66.7223
66.5098
66.3149
66.1403
65.9881
65.8606
65.7595
65.6862
65.6418
65.6269
65.6418
65.6862
65.7595
65.8606
65.9881
66.1403
66.3149
66.5098
66.7223
66.9498
67.1895
67.4387
67.6945
67.9542
68.2151
68.4748
68.7307
68.9807
69.2226
69.4545
69.6747
69.8816
70.0738
70.25
70.4092
70.5505
70.673
70.776
70.859
70.9217
70.9636
70.9845
67.9639
67.9429
67.9008
67.8378
67.7543
67.6508
67.5276
67.3856
67.2254
67.048
66.8546
66.6463
66.4245
66.1908
65.9469
65.6949
65.4367
65.1746
64.9111
64.6487
64.3901
64.1381
63.8956
63.6653
63.45
63.2526
63.0756
62.9214
62.7921
62.6895
62.6151
62.5701
62.555
62.5701
62.6151
62.6895
62.7921
62.9214
63.0756
63.2526
63.45
63.6653
63.8956
64.1381
64.3901
64.6487
64.9111
65.1746
65.4367
65.6949
65.9469
66.1908
66.4245
66.6463
66.8546
67.048
67.2254
67.3856
67.5276
67.6508
67.7543
67.8378
67.9008
67.9429
67.9639
64.9648
64.9436
64.901
64.8375
64.7531
64.6485
64.524
64.3803
64.2182
64.0387
63.8427
63.6315
63.4066
63.1693
62.9216
62.6653
62.4025
62.1355
61.8668
61.599
61.3348
61.0772
60.8289
60.5929
60.3722
60.1696
59.9878
59.8293
59.6963
59.5908
59.5143
59.4679
59.4524
59.4679
59.5143
59.5908
59.6963
59.8293
59.9878
60.1696
60.3722
60.5929
60.8289
61.0772
61.3348
61.599
61.8668
62.1355
62.4025
62.6653
62.9216
63.1693
63.4066
63.6315
63.8427
64.0387
64.2182
64.3803
64.524
64.6485
64.7531
64.8375
64.901
64.9436
64.9648
61.9874
61.9659
61.9227
61.8582
61.7726
61.6663
61.5398
61.3937
61.2288
61.046
60.8462
60.6308
60.4011
60.1585
59.905
59.6423
59.3726
59.0982
58.8217
58.5457
58.273
58.0066
57.7496
57.5051
57.276
57.0655
56.8764
56.7113
56.5727
56.4627
56.3828
56.3344
56.3182
56.3344
56.3828
56.4627
56.5727
56.7113
56.8764
57.0655
57.276
57.5051
57.7496
58.0066
58.273
58.5457
58.8217
59.0982
59.3726
59.6423
59.905
60.1585
60.4011
60.6308
60.8462
61.046
61.2288
61.3937
61.5398
61.6663
61.7726
61.8582
61.9227
61.9659
61.9874
59.032
59.01
58.9661
58.9003
58.813
58.7046
58.5754
58.4262
58.2576
58.0704
57.8657
57.6447
57.4086
57.159
56.8976
56.6263
56.3474
56.0631
55.776
55.4889
55.2047
54.9266
54.6578
54.4015
54.161
53.9396
53.7405
53.5665
53.4201
53.3039
53.2194
53.1682
53.151
53.1682
53.2194
53.3039
53.4201
53.5665
53.7405
53.9396
54.161
54.4015
54.6578
54.9266
55.2047
55.4889
55.776
56.0631
56.3474
56.6263
56.8976
57.159
57.4086
57.6447
57.8657
58.0704
58.2576
58.4262
58.5754
58.7046
58.813
58.9003
58.9661
59.01
59.032
56.099
56.0765
56.0316
55.9643
55.875
55.7639
55.6315
55.4784
55.3052
55.1127
54.9018
54.6738
54.4298
54.1714
53.9002
53.6183
53.3276
53.0308
52.7303
52.4291
52.1303
51.8372
51.5532
51.2818
51.0266
50.7912
50.5791
50.3934
50.2371
50.1127
50.0223
49.9674
49.949
49.9674
50.0223
50.1127
50.2371
50.3934
50.5791
50.7912
51.0266
51.2818
51.5532
51.8372
52.1303
52.4291
52.7303
53.0308
53.3276
53.6183
53.9002
54.1714
54.4298
54.6738
54.9018
55.1127
55.3052
55.4784
55.6315
55.7639
55.875
55.9643
56.0316
56.0765
56.099
53.1889
53.1659
53.1198
53.0507
52.959
52.8449
52.7087
52.551
52.3724
52.1736
51.9555
51.7191
51.4657
51.1967
50.9138
50.619
50.3142
50.0021
49.6854
49.367
49.0502
48.7385
48.4357
48.1456
47.8721
47.6193
47.3908
47.1905
47.0216
46.887
46.7891
46.7296
46.7097
46.7296
46.7891
46.887
47.0216
47.1905
47.3908
47.6193
47.8721
48.1456
48.4357
48.7385
49.0502
49.367
49.6854
50.0021
50.3142
50.619
50.9138
51.1967
51.4657
51.7191
51.9555
52.1736
52.3724
52.551
52.7087
52.8449
52.959
53.0507
53.1198
53.1659
53.1889
50.3023
50.2786
50.2312
50.1602
50.0658
49.9482
49.8077
49.6448
49.4601
49.2541
49.0276
48.7817
48.5174
48.2362
47.9396
47.6296
47.3083
46.9782
46.6421
46.3032
45.9648
45.6309
45.3053
44.9925
44.6967
44.4224
44.1741
43.9557
43.7713
43.6241
43.5169
43.4517
43.4298
43.4517
43.5169
43.6241
43.7713
43.9557
44.1741
44.4224
44.6967
44.9925
45.3053
45.6309
45.9648
46.3032
46.6421
46.9782
47.3083
47.6296
47.9396
48.2362
48.5174
48.7817
49.0276
49.2541
49.4601
49.6448
49.8077
49.9482
50.0658
50.1602
50.2312
50.2786
50.3023
47.4398
47.4155
47.3666
47.2935
47.1961
47.0747
46.9295
46.7609
46.5693
46.3553
46.1195
45.8628
45.5863
45.2912
44.9791
44.6518
44.3114
43.9604
43.6018
43.2388
42.875
42.5147
42.1621
41.822
41.4994
41.1993
40.9268
40.6865
40.4832
40.3205
40.2019
40.1297
40.1055
40.1297
40.2019
40.3205
40.4832
40.6865
40.9268
41.1993
41.4994
41.822
42.1621
42.5147
42.875
43.2388
43.6018
43.9604
44.3114
44.6518
44.9791
45.2912
45.5863
45.8628
46.1195
46.3553
46.5693
46.7609
46.9295
47.0747
47.1961
47.2935
47.3666
47.4155
47.4398
44.6022
44.5771
44.5268
44.4513
44.3508
44.2254
44.0751
43.9004
43.7014
43.4786
43.2327
42.9642
42.6741
42.3636
42.034
41.6872
41.3251
40.9504
40.5659
40.1751
39.7818
39.3905
39.0061
38.6339
38.2793
37.9483
37.6466
37.38
37.1536
36.9723
36.8398
36.7591
36.732
36.7591
36.8398
36.9723
37.1536
37.38
37.6466
37.9483
38.2793
38.6339
39.0061
39.3905
39.7818
40.1751
40.5659
40.9504
41.3251
41.6872
42.034
42.3636
42.6741
42.9642
43.2327
43.4786
43.7014
43.9004
44.0751
44.2254
44.3508
44.4513
44.5268
44.5771
44.6022
41.7902
41.7644
41.7125
41.6346
41.5309
41.4012
41.2456
41.0644
40.8576
40.6256
40.3687
40.0875
39.7827
39.4553
39.1065
38.738
38.3518
37.9503
37.5364
37.1138
36.6866
36.2595
35.8379
35.4277
35.0353
34.6674
34.3309
34.0324
33.7784
33.5744
33.4251
33.3341
33.3035
33.3341
33.4251
33.5744
33.7784
34.0324
34.3309
34.6674
35.0353
35.4277
35.8379
36.2595
36.6866
37.1138
37.5364
37.9503
38.3518
38.738
39.1065
39.4553
39.7827
40.0875
40.3687
40.6256
40.8576
41.0644
41.2456
41.4012
41.5309
41.6346
41.7125
41.7644
41.7902
39.0046
38.978
38.9245
38.8443
38.7372
38.6032
38.4423
38.2543
38.0395
37.7977
37.5294
37.2347
36.9142
36.5686
36.199
35.8069
35.394
34.9626
34.5159
34.0573
33.5912
33.1228
32.658
32.2034
31.7664
31.3547
30.9765
30.6398
30.3523
30.1209
29.9512
29.8476
29.8128
29.8476
29.9512
30.1209
30.3523
30.6398
30.9765
31.3547
31.7664
32.2034
32.658
33.1228
33.5912
34.0573
34.5159
34.9626
35.394
35.8069
36.199
36.5686
36.9142
37.2347
37.5294
37.7977
38.0395
38.2543
38.4423
38.6032
38.7372
38.8443
38.9245
38.978
39.0046
36.2462
36.2188
36.1638
36.0813
35.9709
35.8326
35.6663
35.4716
35.2486
34.997
34.7168
34.4081
34.0711
33.7063
33.3145
32.8968
32.4548
31.9907
31.5073
31.0083
30.4982
29.9825
29.4677
28.9613
28.4717
28.008
27.58
27.1973
26.8693
26.6046
26.4102
26.2914
26.2514
26.2914
26.4102
26.6046
26.8693
27.1973
27.58
28.008
28.4717
28.9613
29.4677
29.9825
30.4982
31.0083
31.5073
31.9907
32.4548
32.8968
33.3145
33.7063
34.0711
34.4081
34.7168
34.997
35.2486
35.4716
35.6663
35.8326
35.9709
36.0813
36.1638
36.2188
36.2462
33.5157
33.4876
33.4312
33.3464
33.2329
33.0906
32.919
32.7178
32.4867
32.2252
31.9332
31.6102
31.2563
30.8715
30.4563
30.0114
29.5381
29.0383
28.5146
27.9706
27.4109
26.8413
26.2689
25.7021
25.1506
24.6252
24.1374
23.6992
23.3221
23.0169
22.7924
22.6551
22.6089
22.6551
22.7924
23.0169
23.3221
23.6992
24.1374
24.6252
25.1506
25.7021
26.2689
26.8413
27.4109
27.9706
28.5146
29.0383
29.5381
30.0114
30.4563
30.8715
31.2563
31.6102
31.9332
32.2252
32.4867
32.7178
32.919
33.0906
33.2329
33.3464
33.4312
33.4876
33.5157
30.8138
30.7851
30.7274
30.6406
30.5243
30.3782
30.2018
29.9944
29.7556
29.4846
29.1809
28.8438
28.4728
28.0677
27.6283
27.1549
26.6484
26.1102
25.5426
24.9489
24.3337
23.703
23.0644
22.4274
21.803
21.2041
20.6444
20.1389
19.702
19.3473
19.086
18.9262
18.8725
18.9262
19.086
19.3473
19.702
20.1389
20.6444
21.2041
21.803
22.4274
23.0644
23.703
24.3337
24.9489
25.5426
26.1102
26.6484
27.1549
27.6283
28.0677
28.4728
28.8438
29.1809
29.4846
29.7556
29.9944
30.2018
30.3782
30.5243
30.6406
30.7274
30.7851
30.8138
28.1412
28.112
28.0532
27.9647
27.8461
27.6967
27.5159
27.303
27.0571
26.7773
26.4625
26.1117
25.724
25.2986
24.8347
24.332
23.7908
23.2119
22.597
21.949
21.2722
20.5726
19.8584
19.1399
18.4297
17.743
17.0966
16.5089
15.9985
15.5828
15.2765
15.0896
15.0269
15.0896
15.2765
15.5828
15.9985
16.5089
17.0966
17.743
18.4297
19.1399
19.8584
20.5726
21.2722
21.949
22.597
23.2119
23.7908
24.332
24.8347
25.2986
25.724
26.1117
26.4625
26.7773
27.0571
27.303
27.5159
27.6967
27.8461
27.9647
28.0532
28.112
28.1412
25.4985
25.4688
25.4093
25.3195
25.1989
25.047
24.8627
24.6451
24.3932
24.1055
23.7806
23.4172
23.0136
22.5685
22.0804
21.5483
20.9716
20.3502
19.6851
18.9783
18.2337
17.4571
16.6567
15.8438
15.0326
14.2409
13.4891
12.8003
12.1986
11.7073
11.3458
11.1267
11.0542
11.1267
11.3458
11.7073
12.1986
12.8003
13.4891
14.2409
15.0326
15.8438
16.6567
17.4571
18.2337
18.9783
19.6851
20.3502
20.9716
21.5483
22.0804
22.5685
23.0136
23.4172
23.7806
24.1055
24.3932
24.6451
24.8627
25.047
25.1989
25.3195
25.4093
25.4688
25.4985
22.8859
22.8561
22.7961
22.7055
22.5838
22.43
22.2433
22.0222
21.7655
21.4713
21.138
20.7634
20.3454
19.882
19.3708
18.81
18.1977
17.5329
16.8154
16.0461
15.2278
14.3657
13.4678
12.5459
11.6159
10.6981
9.81763
9.00329
8.28675
7.69997
7.27047
7.0151
6.93398
7.0151
7.27047
7.69997
8.28675
9.00329
9.81763
10.6981
11.6159
12.5459
13.4678
14.3657
15.2278
16.0461
16.8154
17.5329
18.1977
18.81
19.3708
19.882
20.3454
20.7634
21.138
21.4713
21.7655
22.0222
22.2433
22.43
22.5838
22.7055
22.7961
22.8561
22.8859
20.3037
20.2739
20.2139
20.1232
20.0011
19.8467
19.6587
19.4356
19.1757
18.877
18.5371
18.1536
17.7235
17.2439
16.7117
16.1238
15.4771
14.7692
13.9982
13.1636
12.2664
11.3106
10.3033
9.25631
8.18661
7.11755
6.07896
5.10694
4.24307
3.53285
3.01827
2.72646
2.649
2.72646
3.01827
3.53285
4.24307
5.10694
6.07896
7.11755
8.18661
9.25631
10.3033
11.3106
12.2664
13.1636
13.9982
14.7692
15.4771
16.1238
16.7117
17.2439
17.7235
18.1536
18.5371
18.877
19.1757
19.4356
19.6587
19.8467
20.0011
20.1232
20.2139
20.2739
20.3037
17.752
17.7224
17.6628
17.5727
17.4513
17.2974
17.1096
16.8863
16.6254
16.3245
15.9807
15.591
15.1518
14.6593
14.1093
13.4972
12.8188
12.0696
11.2457
10.3445
9.36464
8.30777
7.17924
5.9897
4.75669
3.50602
2.27267
1.10073
0.0433147
-0.832977
-1.46019
-1.7799
-1.79334
-1.7799
-1.46019
-0.832977
0.0433147
1.10073
2.27267
3.50602
4.75669
5.9897
7.17924
8.30777
9.36464
10.3445
11.2457
12.0696
12.8188
13.4972
14.1093
14.6593
15.1518
15.591
15.9807
16.3245
16.6254
16.8863
17.1096
17.2974
17.4513
17.5727
17.6628
17.7224
17.752
15.2305
15.2014
15.1428
15.0541
14.9344
14.7825
14.5968
14.3753
14.1158
13.8154
13.471
13.0787
12.6344
12.1331
11.5697
10.9382
10.2323
9.44568
8.57189
7.60516
6.54109
5.3777
4.11707
2.76723
1.34468
-0.123125
-1.596
-3.02181
-4.34042
-5.4518
-6.25099
-6.59732
-6.26304
-6.59732
-6.25099
-5.4518
-4.34042
-3.02181
-1.596
-0.123125
1.34468
2.76723
4.11707
5.3777
6.54109
7.60516
8.57189
9.44568
10.2323
10.9382
11.5697
12.1331
12.6344
13.0787
13.471
13.8154
14.1158
14.3753
14.5968
14.7825
14.9344
15.0541
15.1428
15.2014
15.2305
12.7386
12.7103
12.6533
12.5669
12.4502
12.3019
12.1202
11.9029
11.6476
11.3511
11.0098
10.6193
10.1746
9.67016
9.09925
8.45456
7.72789
6.91031
5.99242
4.96471
3.81837
2.54639
1.14547
-0.381429
-2.02139
-3.74715
-5.51252
-7.25327
-8.93467
-10.3877
-11.502
-12.1064
-10.0542
-12.1064
-11.502
-10.3877
-8.93467
-7.25327
-5.51252
-3.74715
-2.02139
-0.381429
1.14547
2.54639
3.81837
4.96471
5.99242
6.91031
7.72789
8.45456
9.09925
9.67016
10.1746
10.6193
11.0098
11.3511
11.6476
11.9029
12.1202
12.3019
12.4502
12.5669
12.6533
12.7103
12.7386
10.2756
10.2484
10.1936
10.1106
9.99822
9.85517
9.6796
9.46924
9.22129
8.93238
8.59849
8.21482
7.77573
7.27461
6.70375
6.05421
5.31577
4.47681
3.52446
2.44474
1.22323
-0.153971
-1.69823
-3.41528
-5.30038
-7.33099
-9.45411
-11.546
9.20731
9.20688
9.20689
9.20688
9.20413
9.20688
9.20689
9.20688
9.20731
-11.546
-9.45411
-7.33099
-5.30038
-3.41528
-1.69823
-0.153971
1.22323
2.44474
3.52446
4.47681
5.31577
6.05421
6.70375
7.27461
7.77573
8.21482
8.59849
8.93238
9.22129
9.46924
9.6796
9.85517
9.99822
10.1106
10.1936
10.2484
10.2756
7.84022
7.8145
7.76265
7.68396
7.57738
7.44149
7.27439
7.07372
6.83655
6.55933
6.23775
5.86663
5.43981
4.9499
4.38814
3.74416
3.00571
2.15847
1.18582
0.0687764
-1.21383
-2.6847
-4.36646
-6.27853
-8.43163
-10.821
9.20085
9.20015
9.20013
9.19996
9.19983
9.19959
9.19897
9.19959
9.19983
9.19996
9.20013
9.20015
9.20085
-10.821
-8.43163
-6.27853
-4.36646
-2.6847
-1.21383
0.0687764
1.18582
2.15847
3.00571
3.74416
4.38814
4.9499
5.43981
5.86663
6.23775
6.55933
6.83655
7.07372
7.27439
7.44149
7.57738
7.68396
7.76265
7.8145
7.84022
5.43109
5.40718
5.35893
5.28566
5.18633
5.0595
4.90327
4.71526
4.49249
4.23132
3.9273
3.57503
3.16795
2.69814
2.15603
1.53003
0.80614
-0.0325068
-1.00618
-2.13907
-3.45973
-5.00128
-6.80084
-8.89704
-11.3231
9.19357
9.19348
9.19324
9.19312
9.19299
9.19286
9.19271
9.19254
9.19271
9.19286
9.19299
9.19312
9.19324
9.19348
9.19357
-11.3231
-8.89704
-6.80084
-5.00128
-3.45973
-2.13907
-1.00618
-0.0325068
0.80614
1.53003
2.15603
2.69814
3.16795
3.57503
3.9273
4.23132
4.49249
4.71526
4.90327
5.0595
5.18633
5.28566
5.35893
5.40718
5.43109
3.04634
3.02456
2.98062
2.91384
2.82322
2.70736
2.56443
2.3921
2.18744
1.94684
1.66587
1.33907
0.959784
0.519817
0.00911677
-0.584696
-1.2769
-2.08637
-3.0365
-4.15623
-5.48132
-7.05587
-8.93402
-11.1807
9.18583
9.1862
9.18627
9.1862
9.18611
9.18601
9.18592
9.18583
9.18577
9.18583
9.18592
9.18601
9.18611
9.1862
9.18627
9.1862
9.18583
-11.1807
-8.93402
-7.05587
-5.48132
-4.15623
-3.0365
-2.08637
-1.2769
-0.584696
0.00911677
0.519817
0.959784
1.33907
1.66587
1.94684
2.18744
2.3921
2.56443
2.70736
2.82322
2.91384
2.98062
3.02456
3.04634
0.683779
0.664473
0.62549
0.566222
0.485732
0.382715
0.255456
0.10176
-0.0811293
-0.296645
-0.549038
-0.843572
-1.18676
-1.58668
-2.0534
-2.59951
-3.24084
-3.9974
-4.8946
-5.96486
-7.24962
-8.80217
-10.693
9.17848
9.17895
9.17915
9.1792
9.17917
9.17911
9.17904
9.17897
9.17892
9.17889
9.17892
9.17897
9.17904
9.17911
9.17917
9.1792
9.17915
9.17895
9.17848
-10.693
-8.80217
-7.24962
-5.96486
-4.8946
-3.9974
-3.24084
-2.59951
-2.0534
-1.58668
-1.18676
-0.843572
-0.549038
-0.296645
-0.0811293
0.10176
0.255456
0.382715
0.485732
0.566222
0.62549
0.664473
0.683779
-1.6591
-1.67564
-1.70904
-1.75984
-1.82888
-1.91731
-2.02667
-2.15893
-2.31656
-2.50268
-2.72115
-2.97681
-3.27568
-3.62534
-4.03529
-4.51762
-5.08777
-5.76561
-6.57698
-7.55566
-8.74601
-10.205
-11.9982
9.17281
9.17231
9.17224
9.17222
9.17218
9.17213
9.17207
9.17201
9.17197
9.17196
9.17197
9.17201
9.17207
9.17213
9.17218
9.17222
9.17224
9.17231
9.17281
-11.9982
-10.205
-8.74601
-7.55566
-6.57698
-5.76561
-5.08777
-4.51762
-4.03529
-3.62534
-3.27568
-2.97681
-2.72115
-2.50268
-2.31656
-2.15893
-2.02667
-1.91731
-1.82888
-1.75984
-1.70904
-1.67564
-1.6591
-3.98512
-3.99862
-4.02589
-4.06738
-4.12379
-4.19609
-4.28555
-4.39385
-4.52307
-4.67585
-4.8555
-5.06616
-5.31305
-5.60276
-5.94368
-6.34656
-6.82534
-7.39824
-8.08944
-8.93154
-9.96966
-11.2697
9.16342
9.16499
9.16525
9.16528
9.16526
9.16521
9.16515
9.16509
9.16504
9.16501
9.16499
9.16501
9.16504
9.16509
9.16515
9.16521
9.16526
9.16528
9.16525
9.16499
9.16342
-11.2697
-9.96966
-8.93154
-8.08944
-7.39824
-6.82534
-6.34656
-5.94368
-5.60276
-5.31305
-5.06616
-4.8555
-4.67585
-4.52307
-4.39385
-4.28555
-4.19609
-4.12379
-4.06738
-4.02589
-3.99862
-3.98512
-6.29738
-6.30762
-6.3283
-6.35978
-6.40257
-6.45742
-6.52531
-6.60752
-6.70565
-6.82173
-6.95835
-7.11872
-7.30693
-7.52818
-7.78914
-8.09843
-8.46733
-8.91075
-9.44869
-10.1084
-10.9274
-11.9578
9.15858
9.15845
9.15843
9.15838
9.15832
9.15824
9.15817
9.1581
9.15805
9.15802
9.158
9.15802
9.15805
9.1581
9.15817
9.15824
9.15832
9.15838
9.15843
9.15845
9.15858
-11.9578
-10.9274
-10.1084
-9.44869
-8.91075
-8.46733
-8.09843
-7.78914
-7.52818
-7.30693
-7.11872
-6.95835
-6.82173
-6.70565
-6.60752
-6.52531
-6.45742
-6.40257
-6.35978
-6.3283
-6.30762
-6.29738
-8.5992
-8.60601
-8.61976
-8.64068
-8.6691
-8.70551
-8.75054
-8.80502
-8.86999
-8.94678
-9.03708
-9.143
-9.26725
-9.41328
-9.58553
-9.78978
-10.0337
-10.3273
-10.6843
-11.1235
-11.6705
-12.3618
9.15223
9.15181
9.15162
9.1515
9.15139
9.15128
9.15119
9.1511
9.15104
9.151
9.15099
9.151
9.15104
9.1511
9.15119
9.15128
9.15139
9.1515
9.15162
9.15181
9.15223
-12.3618
-11.6705
-11.1235
-10.6843
-10.3273
-10.0337
-9.78978
-9.58553
-9.41328
-9.26725
-9.143
-9.03708
-8.94678
-8.86999
-8.80502
-8.75054
-8.70551
-8.6691
-8.64068
-8.61976
-8.60601
-8.5992
-10.8941
-10.8973
-10.9039
-10.914
-10.9275
-10.9448
-10.9662
-10.9919
-11.0223
-11.0581
-11.0999
-11.1487
-11.2055
-11.2718
-11.3494
-11.4409
-11.5495
-11.6794
-11.8366
-12.029
-12.2678
-12.5697
9.14521
9.14494
9.14475
9.1446
9.14445
9.14431
9.14418
9.14408
9.14401
9.14396
9.14395
9.14396
9.14401
9.14408
9.14418
9.14431
9.14445
9.1446
9.14475
9.14494
9.14521
-12.5697
-12.2678
-12.029
-11.8366
-11.6794
-11.5495
-11.4409
-11.3494
-11.2718
-11.2055
-11.1487
-11.0999
-11.0581
-11.0223
-10.9919
-10.9662
-10.9448
-10.9275
-10.914
-10.9039
-10.8973
-10.8941
-13.1856
-13.1853
-13.1847
-13.1836
-13.1821
-13.1801
-13.1774
-13.1738
-13.1692
-13.1633
-13.1558
-13.1462
-13.134
-13.1187
-13.0993
-13.0747
-13.0435
-13.0039
-12.9531
-12.8875
-12.8013
-12.6847
9.13797
9.13797
9.13786
9.13769
9.1375
9.13732
9.13716
9.13704
9.13695
9.13689
9.13688
9.13689
9.13695
9.13704
9.13716
9.13732
9.1375
9.13769
9.13786
9.13797
9.13797
-12.6847
-12.8013
-12.8875
-12.9531
-13.0039
-13.0435
-13.0747
-13.0993
-13.1187
-13.134
-13.1462
-13.1558
-13.1633
-13.1692
-13.1738
-13.1774
-13.1801
-13.1821
-13.1836
-13.1847
-13.1853
-13.1856
-15.4775
-15.4736
-15.4658
-15.4537
-15.4373
-15.4161
-15.3895
-15.3569
-15.3175
-15.2702
-15.2137
-15.1463
-15.0659
-14.9697
-14.8543
-14.7152
-14.5463
-14.3397
-14.0847
-13.7668
-13.3657
-12.8502
9.13094
9.13112
9.13102
9.1308
9.13055
9.1303
9.1301
9.12995
9.12985
9.12979
9.12977
9.12979
9.12985
9.12995
9.1301
9.1303
9.13055
9.1308
9.13102
9.13112
9.13094
-12.8502
-13.3657
-13.7668
-14.0847
-14.3397
-14.5463
-14.7152
-14.8543
-14.9697
-15.0659
-15.1463
-15.2137
-15.2702
-15.3175
-15.3569
-15.3895
-15.4161
-15.4373
-15.4537
-15.4658
-15.4736
-15.4775
-17.7733
-17.7659
-17.7511
-17.7284
-17.6974
-17.6574
-17.6076
-17.5469
-17.4737
-17.3864
-17.2827
-17.1596
-17.0137
-16.8403
-16.6336
-16.3859
-16.0873
-15.7247
-15.2803
-14.7308
-14.0457
-13.189
9.1246
9.12456
9.12431
9.12395
9.12357
9.12325
9.123
9.12282
9.12271
9.12264
9.12262
9.12264
9.12271
9.12282
9.123
9.12325
9.12357
9.12395
9.12431
9.12456
9.1246
-13.189
-14.0457
-14.7308
-15.2803
-15.7247
-16.0873
-16.3859
-16.6336
-16.8403
-17.0137
-17.1596
-17.2827
-17.3864
-17.4737
-17.5469
-17.6076
-17.6574
-17.6974
-17.7284
-17.7511
-17.7659
-17.7733
-20.0766
-20.0659
-20.0443
-20.0114
-19.9665
-19.9088
-19.8369
-19.7494
-19.6444
-19.5193
-19.3712
-19.1962
-18.9894
-18.7447
-18.4544
-18.1083
-17.6935
-17.1926
-16.5827
-15.8326
-14.8992
-13.7189
9.11963
9.11821
9.1177
9.11711
9.11655
9.11612
9.11582
9.11563
9.11551
9.11545
9.11543
9.11545
9.11551
9.11563
9.11582
9.11612
9.11655
9.11711
9.1177
9.11821
9.11963
-13.7189
-14.8992
-15.8326
-16.5827
-17.1926
-17.6935
-18.1083
-18.4544
-18.7447
-18.9894
-19.1962
-19.3712
-19.5193
-19.6444
-19.7494
-19.8369
-19.9088
-19.9665
-20.0114
-20.0443
-20.0659
-20.0766
-22.3908
-22.377
-22.3491
-22.3067
-22.2488
-22.1744
-22.0821
-21.9698
-21.8354
-21.6757
-21.4871
-21.265
-21.0036
-20.6956
-20.3318
-19.9007
-19.387
-18.7712
-18.0274
-17.1208
-16.0034
-14.607
-12.8342
9.11095
9.11117
9.11025
9.1094
9.10885
9.10853
9.10836
9.10826
9.10822
9.1082
9.10822
9.10826
9.10836
9.10853
9.10885
9.1094
9.11025
9.11117
9.11095
-12.8342
-14.607
-16.0034
-17.1208
-18.0274
-18.7712
-19.387
-19.9007
-20.3318
-20.6956
-21.0036
-21.265
-21.4871
-21.6757
-21.8354
-21.9698
-22.0821
-22.1744
-22.2488
-22.3067
-22.3491
-22.377
-22.3908
-24.719
-24.7024
-24.6687
-24.6175
-24.5478
-24.4583
-24.3474
-24.2128
-24.052
-23.8614
-23.6371
-23.3737
-23.065
-22.703
-22.2778
-21.7768
-21.1842
-20.4798
-19.6374
-18.623
-17.391
-15.8808
-14.0134
9.10551
9.10579
9.10333
9.10195
9.10135
9.1011
9.101
9.10096
9.10095
9.10095
9.10095
9.10096
9.101
9.1011
9.10135
9.10195
9.10333
9.10579
9.10551
-14.0134
-15.8808
-17.391
-18.623
-19.6374
-20.4798
-21.1842
-21.7768
-22.2778
-22.703
-23.065
-23.3737
-23.6371
-23.8614
-24.052
-24.2128
-24.3474
-24.4583
-24.5478
-24.6175
-24.6687
-24.7024
-24.719
-27.0642
-27.045
-27.0062
-26.9472
-26.8669
-26.764
-26.6367
-26.4825
-26.2987
-26.0815
-25.8266
-25.5286
-25.1807
-24.7747
-24.3006
-23.7459
-23.095
-22.3285
-21.4223
-20.3461
-19.0611
-17.5174
-15.6417
-13.2882
9.1032
9.09531
9.09371
9.09348
9.09352
9.09358
9.09364
9.09367
9.09368
9.09367
9.09364
9.09358
9.09352
9.09348
9.09371
9.09531
9.1032
-13.2882
-15.6417
-17.5174
-19.0611
-20.3461
-21.4223
-22.3285
-23.095
-23.7459
-24.3006
-24.7747
-25.1807
-25.5286
-25.8266
-26.0815
-26.2987
-26.4825
-26.6367
-26.764
-26.8669
-26.9472
-27.0062
-27.045
-27.0642
-29.4289
-29.4075
-29.3642
-29.2984
-29.209
-29.0946
-28.9532
-28.7824
-28.5792
-28.3399
-28.06
-27.734
-27.3552
-26.9156
-26.4054
-25.8127
-25.1231
-24.3191
-23.38
-22.2811
-20.9942
-19.4911
-17.7568
-15.8471
-14.1552
9.08089
9.08408
9.08533
9.08591
9.08618
9.08633
9.08642
9.08644
9.08642
9.08633
9.08618
9.08591
9.08533
9.08408
9.08089
-14.1552
-15.8471
-17.7568
-19.4911
-20.9942
-22.2811
-23.38
-24.3191
-25.1231
-25.8127
-26.4054
-26.9156
-27.3552
-27.734
-28.06
-28.3399
-28.5792
-28.7824
-28.9532
-29.0946
-29.209
-29.2984
-29.3642
-29.4075
-29.4289
-31.8155
-31.7922
-31.7451
-31.6736
-31.5766
-31.4525
-31.2996
-31.1152
-30.8964
-30.6396
-30.3402
-29.993
-29.5916
-29.1283
-28.594
-27.9779
-27.2672
-26.4471
-25.5001
-24.4069
-23.1468
-21.6997
-20.0499
-18.1856
-16.0398
-13.017
9.07643
9.07787
9.07861
9.07889
9.07909
9.07922
9.07926
9.07922
9.07909
9.07889
9.07861
9.07787
9.07643
-13.017
-16.0398
-18.1856
-20.0499
-21.6997
-23.1468
-24.4069
-25.5001
-26.4471
-27.2672
-27.9779
-28.594
-29.1283
-29.5916
-29.993
-30.3402
-30.6396
-30.8964
-31.1152
-31.2996
-31.4525
-31.5766
-31.6736
-31.7451
-31.7922
-31.8155
-34.2258
-34.201
-34.1508
-34.0747
-33.9716
-33.8399
-33.6778
-33.4829
-33.2523
-32.9824
-32.669
-32.3071
-31.8908
-31.413
-30.8656
-30.2391
-29.5227
-28.7038
-27.7687
-26.7024
-25.4893
-24.1141
-22.5612
-20.8098
-18.8153
-16.4971
-14.1591
9.07112
9.07179
9.07167
9.07193
9.07211
9.07217
9.07211
9.07193
9.07167
9.07179
9.07112
-14.1591
-16.4971
-18.8153
-20.8098
-22.5612
-24.1141
-25.4893
-26.7024
-27.7687
-28.7038
-29.5227
-30.2391
-30.8656
-31.413
-31.8908
-32.3071
-32.669
-32.9824
-33.2523
-33.4829
-33.6778
-33.8399
-33.9716
-34.0747
-34.1508
-34.201
-34.2258
-36.6615
-36.6354
-36.5829
-36.5033
-36.3955
-36.2581
-36.0894
-35.8869
-35.648
-35.3693
-35.047
-34.6765
-34.2523
-33.7684
-33.2176
-32.5918
-31.8821
-31.0785
-30.1705
-29.1468
-27.9965
-26.709
-25.274
-23.6811
-21.9197
-19.9965
-18.0053
-15.9616
-14.0432
9.06406
9.06484
9.06511
9.06521
9.06511
9.06484
9.06406
-14.0432
-15.9616
-18.0053
-19.9965
-21.9197
-23.6811
-25.274
-26.709
-27.9965
-29.1468
-30.1705
-31.0785
-31.8821
-32.5918
-33.2176
-33.7684
-34.2523
-34.6765
-35.047
-35.3693
-35.648
-35.8869
-36.0894
-36.2581
-36.3955
-36.5033
-36.5829
-36.6354
-36.6615
-39.1236
-39.0968
-39.0426
-38.9605
-38.8495
-38.7083
-38.5351
-38.3279
-38.0841
-37.8007
-37.4741
-37.1003
-36.6746
-36.1917
-35.6456
-35.0297
-34.3369
-33.5595
-32.6897
-31.72
-30.6432
-29.4535
-28.1472
-26.7235
-25.1886
-23.5651
-21.9057
-20.2648
-18.74
-17.4241
-16.4171
-15.7885
-15.6054
-15.7885
-16.4171
-17.4241
-18.74
-20.2648
-21.9057
-23.5651
-25.1886
-26.7235
-28.1472
-29.4535
-30.6432
-31.72
-32.6897
-33.5595
-34.3369
-35.0297
-35.6456
-36.1917
-36.6746
-37.1003
-37.4741
-37.8007
-38.0841
-38.3279
-38.5351
-38.7083
-38.8495
-38.9605
-39.0426
-39.0968
-39.1236
-41.6132
-41.5858
-41.5306
-41.4471
-41.3342
-41.1909
-41.0154
-40.806
-40.5604
-40.2758
-39.9491
-39.5769
-39.1551
-38.6792
-38.1445
-37.5458
-36.8775
-36.1342
-35.3105
-34.4018
-33.4044
-32.3167
-31.1396
-29.8789
-28.5474
-27.1701
-25.7874
-24.4502
-23.2248
-22.1808
-21.385
-20.8892
-20.7267
-20.8892
-21.385
-22.1808
-23.2248
-24.4502
-25.7874
-27.1701
-28.5474
-29.8789
-31.1396
-32.3167
-33.4044
-34.4018
-35.3105
-36.1342
-36.8775
-37.5458
-38.1445
-38.6792
-39.1551
-39.5769
-39.9491
-40.2758
-40.5604
-40.806
-41.0154
-41.1909
-41.3342
-41.4471
-41.5306
-41.5858
-41.6132
-44.1307
-44.1031
-44.0475
-43.9634
-43.8499
-43.706
-43.5303
-43.321
-43.0762
-42.7936
-42.4705
-42.1038
-41.6903
-41.2265
-40.7085
-40.1324
-39.4943
-38.7904
-38.0176
-37.1736
-36.2575
-35.2705
-34.2171
-33.1061
-31.9527
-30.7806
-29.6231
-28.5219
-27.5257
-26.6854
-26.0482
-25.6515
-25.5179
-25.6515
-26.0482
-26.6854
-27.5257
-28.5219
-29.6231
-30.7806
-31.9527
-33.1061
-34.2171
-35.2705
-36.2575
-37.1736
-38.0176
-38.7904
-39.4943
-40.1324
-40.7085
-41.2265
-41.6903
-42.1038
-42.4705
-42.7936
-43.0762
-43.321
-43.5303
-43.706
-43.8499
-43.9634
-44.0475
-44.1031
-44.1307
-46.6764
-46.6488
-46.5933
-46.5095
-46.3965
-46.2535
-46.0792
-45.8721
-45.6306
-45.3526
-45.036
-44.6782
-44.2768
-43.8288
-43.3315
-42.7821
-42.1779
-41.5167
-40.7972
-40.0187
-39.1825
-38.2919
-37.3531
-36.3763
-35.3769
-34.3762
-33.4018
-32.4868
-31.6683
-30.9837
-30.4674
-30.1465
-30.0379
-30.1465
-30.4674
-30.9837
-31.6683
-32.4868
-33.4018
-34.3762
-35.3769
-36.3763
-37.3531
-38.2919
-39.1825
-40.0187
-40.7972
-41.5167
-42.1779
-42.7821
-43.3315
-43.8288
-44.2768
-44.6782
-45.036
-45.3526
-45.6306
-45.8721
-46.0792
-46.2535
-46.3965
-46.5095
-46.5933
-46.6488
-46.6764
-49.2501
-49.2229
-49.168
-49.0851
-48.9737
-48.8327
-48.6613
-48.4582
-48.2219
-47.9508
-47.6432
-47.2971
-46.9105
-46.4813
-46.0075
-45.4874
-44.9193
-44.3024
-43.6364
-42.9224
-42.1628
-41.3621
-40.5276
-39.6696
-38.8026
-37.9451
-37.1201
-36.3539
-35.6749
-35.1112
-34.6882
-34.426
-34.3372
-34.426
-34.6882
-35.1112
-35.6749
-36.3539
-37.1201
-37.9451
-38.8026
-39.6696
-40.5276
-41.3621
-42.1628
-42.9224
-43.6364
-44.3024
-44.9193
-45.4874
-46.0075
-46.4813
-46.9105
-47.2971
-47.6432
-47.9508
-48.2219
-48.4582
-48.6613
-48.8327
-48.9737
-49.0851
-49.168
-49.2229
-49.2501
-51.8517
-51.8249
-51.7711
-51.6899
-51.5807
-51.4429
-51.2757
-51.0779
-50.8485
-50.5862
-50.2895
-49.9571
-49.5873
-49.179
-48.7306
-48.2413
-47.7104
-47.1379
-46.5246
-45.8724
-45.1847
-44.4668
-43.7259
-42.9721
-42.2185
-41.4811
-40.7788
-40.1325
-39.5643
-39.0957
-38.7457
-38.5294
-38.4562
-38.5294
-38.7457
-39.0957
-39.5643
-40.1325
-40.7788
-41.4811
-42.2185
-42.9721
-43.7259
-44.4668
-45.1847
-45.8724
-46.5246
-47.1379
-47.7104
-48.2413
-48.7306
-49.179
-49.5873
-49.9571
-50.2895
-50.5862
-50.8485
-51.0779
-51.2757
-51.4429
-51.5807
-51.6899
-51.7711
-51.8249
-51.8517
-54.4806
-54.4545
-54.402
-54.3229
-54.2168
-54.0831
-53.921
-53.7298
-53.5086
-53.2564
-52.9722
-52.6549
-52.3035
-51.9172
-51.4953
-51.0375
-50.5437
-50.0148
-49.4522
-48.8585
-48.2375
-47.5947
-46.9372
-46.2745
-45.618
-44.9815
-44.3804
-43.8318
-43.3527
-42.9598
-42.6676
-42.4874
-42.4265
-42.4874
-42.6676
-42.9598
-43.3527
-43.8318
-44.3804
-44.9815
-45.618
-46.2745
-46.9372
-47.5947
-48.2375
-48.8585
-49.4522
-50.0148
-50.5437
-51.0375
-51.4953
-51.9172
-52.3035
-52.6549
-52.9722
-53.2564
-53.5086
-53.7298
-53.921
-54.0831
-54.2168
-54.3229
-54.402
-54.4545
-54.4806
-57.136
-57.1108
-57.06
-56.9835
-56.881
-56.7519
-56.5959
-56.4122
-56.2002
-55.9592
-55.6884
-55.3873
-55.0552
-54.6916
-54.2966
-53.8701
-53.4128
-52.9259
-52.4114
-51.8722
-51.3124
-50.7374
-50.1539
-49.5705
-48.9973
-48.4458
-47.929
-47.4603
-47.0536
-46.7216
-46.4756
-46.3243
-46.2733
-46.3243
-46.4756
-46.7216
-47.0536
-47.4603
-47.929
-48.4458
-48.9973
-49.5705
-50.1539
-50.7374
-51.3124
-51.8722
-52.4114
-52.9259
-53.4128
-53.8701
-54.2966
-54.6916
-55.0552
-55.3873
-55.6884
-55.9592
-56.2002
-56.4122
-56.5959
-56.7519
-56.881
-56.9835
-57.06
-57.1108
-57.136
-59.8173
-59.7929
-59.7441
-59.6705
-59.572
-59.4483
-59.2988
-59.1233
-58.9212
-58.6921
-58.4355
-58.1511
-57.8387
-57.4981
-57.1297
-56.7339
-56.3119
-55.865
-55.3957
-54.9069
-54.4029
-53.8887
-53.3706
-52.8563
-52.3545
-51.875
-51.4285
-51.026
-50.6785
-50.3961
-50.1874
-50.0594
-50.0163
-50.0594
-50.1874
-50.3961
-50.6785
-51.026
-51.4285
-51.875
-52.3545
-52.8563
-53.3706
-53.8887
-54.4029
-54.9069
-55.3957
-55.865
-56.3119
-56.7339
-57.1297
-57.4981
-57.8387
-58.1511
-58.4355
-58.6921
-58.9212
-59.1233
-59.2988
-59.4483
-59.572
-59.6705
-59.7441
-59.7929
-59.8173
-62.5233
-62.5
-62.4533
-62.3829
-62.2888
-62.1707
-62.0283
-61.8614
-61.6697
-61.4529
-61.2109
-60.9435
-60.6508
-60.333
-59.9906
-59.6246
-59.2361
-58.827
-58.3996
-57.9572
-57.5037
-57.0439
-56.5835
-56.1293
-55.6889
-55.2707
-54.8833
-54.536
-54.2374
-53.9955
-53.8175
-53.7084
-53.6716
-53.7084
-53.8175
-53.9955
-54.2374
-54.536
-54.8833
-55.2707
-55.6889
-56.1293
-56.5835
-57.0439
-57.5037
-57.9572
-58.3996
-58.827
-59.2361
-59.6246
-59.9906
-60.333
-60.6508
-60.9435
-61.2109
-61.4529
-61.6697
-61.8614
-62.0283
-62.1707
-62.2888
-62.3829
-62.4533
-62.5
-62.5233
-65.2532
-65.2309
-65.1864
-65.1194
-65.0299
-64.9177
-64.7827
-64.6247
-64.4436
-64.2394
-64.012
-63.7615
-63.4883
-63.1927
-62.8756
-62.538
-62.1813
-61.8074
-61.4189
-61.0188
-60.6109
-60.1996
-59.7901
-59.3884
-59.0009
-58.6349
-58.2976
-57.9964
-57.7385
-57.5303
-57.3774
-57.2838
-57.2524
-57.2838
-57.3774
-57.5303
-57.7385
-57.9964
-58.2976
-58.6349
-59.0009
-59.3884
-59.7901
-60.1996
-60.6109
-61.0188
-61.4189
-61.8074
-62.1813
-62.538
-62.8756
-63.1927
-63.4883
-63.7615
-64.012
-64.2394
-64.4436
-64.6247
-64.7827
-64.9177
-65.0299
-65.1194
-65.1864
-65.2309
-65.2532
-68.0056
-67.9845
-67.9423
-67.8788
-67.794
-67.6879
-67.5604
-67.4115
-67.2411
-67.0494
-66.8365
-66.6027
-66.3485
-66.0744
-65.7814
-65.4707
-65.1439
-64.8028
-64.45
-64.0884
-63.7215
-63.3534
-62.9888
-62.6329
-62.2913
-61.97
-61.6752
-61.413
-61.1892
-61.009
-60.8769
-60.7963
-60.7692
-60.7963
-60.8769
-61.009
-61.1892
-61.413
-61.6752
-61.97
-62.2913
-62.6329
-62.9888
-63.3534
-63.7215
-64.0884
-64.45
-64.8028
-65.1439
-65.4707
-65.7814
-66.0744
-66.3485
-66.6027
-66.8365
-67.0494
-67.2411
-67.4115
-67.5604
-67.6879
-67.794
-67.8788
-67.9423
-67.9845
-68.0056
-70.7796
-70.7596
-70.7197
-70.6598
-70.5798
-70.4798
-70.3599
-70.22
-70.0603
-69.8809
-69.6823
-69.4647
-69.2288
-68.9753
-68.7052
-68.4199
-68.1209
-67.8101
-67.49
-67.1633
-66.8333
-66.5037
-66.1787
-65.8628
-65.5609
-65.2781
-65.0196
-64.7905
-64.5955
-64.4389
-64.3243
-64.2544
-64.2309
-64.2544
-64.3243
-64.4389
-64.5955
-64.7905
-65.0196
-65.2781
-65.5609
-65.8628
-66.1787
-66.5037
-66.8333
-67.1633
-67.49
-67.8101
-68.1209
-68.4199
-68.7052
-68.9753
-69.2288
-69.4647
-69.6823
-69.8809
-70.0603
-70.22
-70.3599
-70.4798
-70.5798
-70.6598
-70.7197
-70.7596
-70.7796
-73.5738
-73.5551
-73.5175
-73.4611
-73.3859
-73.292
-73.1796
-73.0486
-72.8993
-72.7321
-72.5473
-72.3453
-72.127
-71.893
-71.6446
-71.383
-71.1098
-70.8269
-70.5366
-70.2416
-69.9447
-69.6494
-69.3594
-69.0786
-68.8112
-68.5617
-68.3343
-68.1333
-67.9628
-67.8261
-67.7262
-67.6654
-67.645
-67.6654
-67.7262
-67.8261
-67.9628
-68.1333
-68.3343
-68.5617
-68.8112
-69.0786
-69.3594
-69.6494
-69.9447
-70.2416
-70.5366
-70.8269
-71.1098
-71.383
-71.6446
-71.893
-72.127
-72.3453
-72.5473
-72.7321
-72.8993
-73.0486
-73.1796
-73.292
-73.3859
-73.4611
-73.5175
-73.5551
-73.5738
-76.3872
-76.3696
-76.3344
-76.2815
-76.211
-76.1232
-76.018
-75.8958
-75.7567
-75.6011
-75.4296
-75.2426
-75.0409
-74.8255
-74.5973
-74.3578
-74.1085
-73.8512
-73.5881
-73.3217
-73.0545
-72.7898
-72.5306
-72.2806
-72.0434
-71.8227
-71.6221
-71.4453
-71.2956
-71.1759
-71.0885
-71.0354
-71.0175
-71.0354
-71.0885
-71.1759
-71.2956
-71.4453
-71.6221
-71.8227
-72.0434
-72.2806
-72.5306
-72.7898
-73.0545
-73.3217
-73.5881
-73.8512
-74.1085
-74.3578
-74.5973
-74.8255
-75.0409
-75.2426
-75.4296
-75.6011
-75.7567
-75.8958
-76.018
-76.1232
-76.211
-76.2815
-76.3344
-76.3696
-76.3872
-79.2186
-79.2021
-79.1691
-79.1197
-79.0539
-78.9719
-78.8738
-78.76
-78.6308
-78.4864
-78.3276
-78.1548
-77.9689
-77.7708
-77.5616
-77.3426
-77.1153
-76.8814
-76.6431
-76.4024
-76.162
-75.9244
-75.6926
-75.4697
-75.2588
-75.0631
-74.8858
-74.7299
-74.5981
-74.4928
-74.4161
-74.3695
-74.3539
-74.3695
-74.4161
-74.4928
-74.5981
-74.7299
-74.8858
-75.0631
-75.2588
-75.4697
-75.6926
-75.9244
-76.162
-76.4024
-76.6431
-76.8814
-77.1153
-77.3426
-77.5616
-77.7708
-77.9689
-78.1548
-78.3276
-78.4864
-78.6308
-78.76
-78.8738
-78.9719
-79.0539
-79.1197
-79.1691
-79.2021
-79.2186
-82.0667
-82.0514
-82.0206
-81.9745
-81.9132
-81.8368
-81.7457
-81.64
-81.5201
-81.3865
-81.2397
-81.0804
-80.9093
-80.7274
-80.5358
-80.3358
-80.1287
-79.9163
-79.7004
-79.483
-79.2665
-79.0531
-78.8456
-78.6466
-78.4588
-78.285
-78.1278
-77.9899
-77.8735
-77.7807
-77.7132
-77.6722
-77.6584
-77.6722
-77.7132
-77.7807
-77.8735
-77.9899
-78.1278
-78.285
-78.4588
-78.6466
-78.8456
-79.0531
-79.2665
-79.483
-79.7004
-79.9163
-80.1287
-80.3358
-80.5358
-80.7274
-80.9093
-81.0804
-81.2397
-81.3865
-81.5201
-81.64
-81.7457
-81.8368
-81.9132
-81.9745
-82.0206
-82.0514
-82.0667
-84.9306
-84.9163
-84.8876
-84.8447
-84.7878
-84.7169
-84.6323
-84.5343
-84.4234
-84.3
-84.1646
-84.0179
-83.8607
-83.6939
-83.5186
-83.3361
-83.1475
-82.9547
-82.7591
-82.5628
-82.3677
-82.176
-81.99
-81.8121
-81.6446
-81.4899
-81.3503
-81.228
-81.125
-81.043
-80.9833
-80.9471
-80.935
-80.9471
-80.9833
-81.043
-81.125
-81.228
-81.3503
-81.4899
-81.6446
-81.8121
-81.99
-82.176
-82.3677
-82.5628
-82.7591
-82.9547
-83.1475
-83.3361
-83.5186
-83.6939
-83.8607
-84.0179
-84.1646
-84.3
-84.4234
-84.5343
-84.6323
-84.7169
-84.7878
-84.8447
-84.8876
-84.9163
-84.9306
-87.809
-87.7957
-87.7691
-87.7293
-87.6765
-87.6108
-87.5325
-87.4419
-87.3394
-87.2256
-87.1009
-86.966
-86.8218
-86.6691
-86.5089
-86.3424
-86.1708
-85.9957
-85.8187
-85.6413
-85.4654
-85.2931
-85.1262
-84.9669
-84.8173
-84.6794
-84.5552
-84.4466
-84.3552
-84.2825
-84.2297
-84.1976
-84.1869
-84.1976
-84.2297
-84.2825
-84.3552
-84.4466
-84.5552
-84.6794
-84.8173
-84.9669
-85.1262
-85.2931
-85.4654
-85.6413
-85.8187
-85.9957
-86.1708
-86.3424
-86.5089
-86.6691
-86.8218
-86.966
-87.1009
-87.2256
-87.3394
-87.4419
-87.5325
-87.6108
-87.6765
-87.7293
-87.7691
-87.7957
-87.809
-90.701
-90.6886
-90.664
-90.6272
-90.5782
-90.5175
-90.4451
-90.3615
-90.267
-90.1622
-90.0475
-89.9237
-89.7915
-89.6518
-89.5055
-89.3538
-89.1978
-89.0389
-88.8785
-88.7182
-88.5597
-88.4046
-88.2547
-88.112
-87.9782
-87.8551
-87.7443
-87.6476
-87.5664
-87.5018
-87.4549
-87.4265
-87.417
-87.4265
-87.4549
-87.5018
-87.5664
-87.6476
-87.7443
-87.8551
-87.9782
-88.112
-88.2547
-88.4046
-88.5597
-88.7182
-88.8785
-89.0389
-89.1978
-89.3538
-89.5055
-89.6518
-89.7915
-89.9237
-90.0475
-90.1622
-90.267
-90.3615
-90.4451
-90.5175
-90.5782
-90.6272
-90.664
-90.6886
-90.701
-93.6055
-93.5941
-93.5713
-93.5372
-93.4921
-93.436
-93.3692
-93.2921
-93.2052
-93.1087
-93.0034
-92.8899
-92.7689
-92.6412
-92.5077
-92.3695
-92.2277
-92.0835
-91.9382
-91.7934
-91.6503
-91.5107
-91.3761
-91.248
-91.1282
-91.0181
-90.9192
-90.833
-90.7606
-90.7032
-90.6615
-90.6362
-90.6277
-90.6362
-90.6615
-90.7032
-90.7606
-90.833
-90.9192
-91.0181
-91.1282
-91.248
-91.3761
-91.5107
-91.6503
-91.7934
-91.9382
-92.0835
-92.2277
-92.3695
-92.5077
-92.6412
-92.7689
-92.8899
-93.0034
-93.1087
-93.2052
-93.2921
-93.3692
-93.436
-93.4921
-93.5372
-93.5713
-93.5941
-93.6055
-96.5216
-96.5111
-96.4901
-96.4586
-96.417
-96.3652
-96.3038
-96.2328
-96.1529
-96.0643
-95.9677
-95.8638
-95.753
-95.6364
-95.5147
-95.3889
-95.26
-95.1292
-94.9976
-94.8667
-94.7376
-94.6118
-94.4907
-94.3757
-94.2683
-94.1697
-94.0813
-94.0043
-93.9397
-93.8885
-93.8513
-93.8288
-93.8213
-93.8288
-93.8513
-93.8885
-93.9397
-94.0043
-94.0813
-94.1697
-94.2683
-94.3757
-94.4907
-94.6118
-94.7376
-94.8667
-94.9976
-95.1292
-95.26
-95.3889
-95.5147
-95.6364
-95.753
-95.8638
-95.9677
-96.0643
-96.1529
-96.2328
-96.3038
-96.3652
-96.417
-96.4586
-96.4901
-96.5111
-96.5216
-99.4485
-99.4388
-99.4194
-99.3904
-99.3521
-99.3045
-99.2479
-99.1827
-99.1093
-99.0281
-98.9396
-98.8444
-98.7432
-98.6368
-98.5258
-98.4113
-98.2942
-98.1756
-98.0564
-97.938
-97.8215
-97.7081
-97.5991
-97.4958
-97.3993
-97.311
-97.2319
-97.163
-97.1052
-97.0595
-97.0263
-97.0063
-96.9995
-97.0063
-97.0263
-97.0595
-97.1052
-97.163
-97.2319
-97.311
-97.3993
-97.4958
-97.5991
-97.7081
-97.8215
-97.938
-98.0564
-98.1756
-98.2942
-98.4113
-98.5258
-98.6368
-98.7432
-98.8444
-98.9396
-99.0281
-99.1093
-99.1827
-99.2479
-99.3045
-99.3521
-99.3904
-99.4194
-99.4388
-99.4485
-102.385
-102.376
-102.358
-102.332
-102.297
-102.253
-102.201
-102.141
-102.074
-101.999
-101.918
-101.831
-101.739
-101.642
-101.541
-101.436
-101.33
-101.222
-101.115
-101.007
-100.902
-100.8
-100.702
-100.609
-100.522
-100.443
-100.372
-100.31
-100.259
-100.218
-100.188
-100.17
-100.164
-100.17
-100.188
-100.218
-100.259
-100.31
-100.372
-100.443
-100.522
-100.609
-100.702
-100.8
-100.902
-101.007
-101.115
-101.222
-101.33
-101.436
-101.541
-101.642
-101.739
-101.831
-101.918
-101.999
-102.074
-102.141
-102.201
-102.253
-102.297
-102.332
-102.358
-102.376
-102.385
-105.331
-105.323
-105.306
-105.282
-105.25
-105.209
-105.162
-105.107
-105.045
-104.977
-104.903
-104.823
-104.739
-104.651
-104.559
-104.464
-104.367
-104.27
-104.172
-104.075
-103.98
-103.888
-103.799
-103.715
-103.638
-103.566
-103.503
-103.447
-103.401
-103.364
-103.338
-103.322
-103.317
-103.322
-103.338
-103.364
-103.401
-103.447
-103.503
-103.566
-103.638
-103.715
-103.799
-103.888
-103.98
-104.075
-104.172
-104.27
-104.367
-104.464
-104.559
-104.651
-104.739
-104.823
-104.903
-104.977
-105.045
-105.107
-105.162
-105.209
-105.25
-105.282
-105.306
-105.323
-105.331
-108.285
-108.278
-108.263
-108.24
-108.21
-108.174
-108.13
-108.08
-108.023
-107.961
-107.893
-107.821
-107.744
-107.663
-107.579
-107.493
-107.405
-107.317
-107.228
-107.141
-107.055
-106.971
-106.892
-106.816
-106.746
-106.682
-106.625
-106.575
-106.534
-106.501
-106.477
-106.463
-106.458
-106.463
-106.477
-106.501
-106.534
-106.575
-106.625
-106.682
-106.746
-106.816
-106.892
-106.971
-107.055
-107.141
-107.228
-107.317
-107.405
-107.493
-107.579
-107.663
-107.744
-107.821
-107.893
-107.961
-108.023
-108.08
-108.13
-108.174
-108.21
-108.24
-108.263
-108.278
-108.285
-111.247
-111.24
-111.226
-111.206
-111.179
-111.145
-111.105
-111.059
-111.007
-110.95
-110.888
-110.822
-110.752
-110.679
-110.602
-110.524
-110.444
-110.364
-110.284
-110.205
-110.127
-110.052
-109.98
-109.912
-109.849
-109.791
-109.74
-109.695
-109.658
-109.628
-109.607
-109.594
-109.59
-109.594
-109.607
-109.628
-109.658
-109.695
-109.74
-109.791
-109.849
-109.912
-109.98
-110.052
-110.127
-110.205
-110.284
-110.364
-110.444
-110.524
-110.602
-110.679
-110.752
-110.822
-110.888
-110.95
-111.007
-111.059
-111.105
-111.145
-111.179
-111.206
-111.226
-111.24
-111.247
-114.216
-114.21
-114.197
-114.178
-114.153
-114.122
-114.086
-114.044
-113.996
-113.944
-113.888
-113.828
-113.764
-113.697
-113.628
-113.556
-113.484
-113.411
-113.339
-113.267
-113.197
-113.129
-113.064
-113.002
-112.945
-112.894
-112.847
-112.807
-112.774
-112.747
-112.728
-112.716
-112.713
-112.716
-112.728
-112.747
-112.774
-112.807
-112.847
-112.894
-112.945
-113.002
-113.064
-113.129
-113.197
-113.267
-113.339
-113.411
-113.484
-113.556
-113.628
-113.697
-113.764
-113.828
-113.888
-113.944
-113.996
-114.044
-114.086
-114.122
-114.153
-114.178
-114.197
-114.21
-114.216
-117.191
-117.186
-117.174
-117.157
-117.134
-117.106
-117.072
-117.034
-116.991
-116.943
-116.892
-116.837
-116.778
-116.718
-116.655
-116.59
-116.524
-116.458
-116.392
-116.327
-116.264
-116.202
-116.144
-116.089
-116.037
-115.99
-115.949
-115.913
-115.883
-115.859
-115.841
-115.831
-115.828
-115.831
-115.841
-115.859
-115.883
-115.913
-115.949
-115.99
-116.037
-116.089
-116.144
-116.202
-116.264
-116.327
-116.392
-116.458
-116.524
-116.59
-116.655
-116.718
-116.778
-116.837
-116.892
-116.943
-116.991
-117.034
-117.072
-117.106
-117.134
-117.157
-117.174
-117.186
-117.191
-120.173
-120.167
-120.157
-120.141
-120.12
-120.094
-120.064
-120.029
-119.989
-119.946
-119.899
-119.849
-119.796
-119.741
-119.683
-119.625
-119.565
-119.505
-119.445
-119.387
-119.329
-119.274
-119.221
-119.171
-119.124
-119.082
-119.045
-119.012
-118.985
-118.963
-118.948
-118.939
-118.935
-118.939
-118.948
-118.963
-118.985
-119.012
-119.045
-119.082
-119.124
-119.171
-119.221
-119.274
-119.329
-119.387
-119.445
-119.505
-119.565
-119.625
-119.683
-119.741
-119.796
-119.849
-119.899
-119.946
-119.989
-120.029
-120.064
-120.094
-120.12
-120.141
-120.157
-120.167
-120.173
-123.159
-123.155
-123.145
-123.131
-123.111
-123.088
-123.06
-123.028
-122.992
-122.952
-122.91
-122.864
-122.816
-122.765
-122.713
-122.66
-122.606
-122.552
-122.498
-122.444
-122.392
-122.342
-122.294
-122.249
-122.207
-122.169
-122.135
-122.106
-122.082
-122.062
-122.048
-122.04
-122.037
-122.04
-122.048
-122.062
-122.082
-122.106
-122.135
-122.169
-122.207
-122.249
-122.294
-122.342
-122.392
-122.444
-122.498
-122.552
-122.606
-122.66
-122.713
-122.765
-122.816
-122.864
-122.91
-122.952
-122.992
-123.028
-123.06
-123.088
-123.111
-123.131
-123.145
-123.155
-123.159
-126.151
-126.147
-126.138
-126.125
-126.107
-126.086
-126.06
-126.031
-125.998
-125.962
-125.923
-125.882
-125.838
-125.792
-125.745
-125.696
-125.647
-125.598
-125.549
-125.501
-125.454
-125.408
-125.365
-125.324
-125.286
-125.252
-125.222
-125.195
-125.173
-125.156
-125.143
-125.135
-125.133
-125.135
-125.143
-125.156
-125.173
-125.195
-125.222
-125.252
-125.286
-125.324
-125.365
-125.408
-125.454
-125.501
-125.549
-125.598
-125.647
-125.696
-125.745
-125.792
-125.838
-125.882
-125.923
-125.962
-125.998
-126.031
-126.06
-126.086
-126.107
-126.125
-126.138
-126.147
-126.151
-129.147
-129.143
-129.135
-129.123
-129.107
-129.088
-129.064
-129.038
-129.008
-128.975
-128.94
-128.902
-128.862
-128.82
-128.777
-128.733
-128.689
-128.644
-128.6
-128.556
-128.513
-128.472
-128.433
-128.396
-128.362
-128.331
-128.303
-128.28
-128.26
-128.244
-128.233
-128.226
-128.224
-128.226
-128.233
-128.244
-128.26
-128.28
-128.303
-128.331
-128.362
-128.396
-128.433
-128.472
-128.513
-128.556
-128.6
-128.644
-128.689
-128.733
-128.777
-128.82
-128.862
-128.902
-128.94
-128.975
-129.008
-129.038
-129.064
-129.088
-129.107
-129.123
-129.135
-129.143
-129.147
-132.148
-132.144
-132.137
-132.126
-132.111
-132.093
-132.072
-132.048
-132.02
-131.991
-131.958
-131.924
-131.888
-131.85
-131.811
-131.771
-131.73
-131.69
-131.65
-131.61
-131.571
-131.534
-131.499
-131.465
-131.435
-131.407
-131.382
-131.36
-131.342
-131.328
-131.318
-131.312
-131.31
-131.312
-131.318
-131.328
-131.342
-131.36
-131.382
-131.407
-131.435
-131.465
-131.499
-131.534
-131.571
-131.61
-131.65
-131.69
-131.73
-131.771
-131.811
-131.85
-131.888
-131.924
-131.958
-131.991
-132.02
-132.048
-132.072
-132.093
-132.111
-132.126
-132.137
-132.144
-132.148
-135.152
-135.148
-135.142
-135.132
-135.118
-135.102
-135.083
-135.061
-135.036
-135.009
-134.979
-134.948
-134.915
-134.881
-134.845
-134.809
-134.772
-134.735
-134.699
-134.663
-134.628
-134.594
-134.562
-134.532
-134.504
-134.479
-134.456
-134.437
-134.421
-134.408
-134.399
-134.393
-134.391
-134.393
-134.399
-134.408
-134.421
-134.437
-134.456
-134.479
-134.504
-134.532
-134.562
-134.594
-134.628
-134.663
-134.699
-134.735
-134.772
-134.809
-134.845
-134.881
-134.915
-134.948
-134.979
-135.009
-135.036
-135.061
-135.083
-135.102
-135.118
-135.132
-135.142
-135.148
-135.152
-138.159
-138.156
-138.15
-138.141
-138.129
-138.114
-138.096
-138.076
-138.054
-138.029
-138.002
-137.974
-137.944
-137.912
-137.88
-137.847
-137.814
-137.781
-137.748
-137.715
-137.683
-137.653
-137.624
-137.597
-137.571
-137.549
-137.528
-137.511
-137.496
-137.484
-137.476
-137.471
-137.469
-137.471
-137.476
-137.484
-137.496
-137.511
-137.528
-137.549
-137.571
-137.597
-137.624
-137.653
-137.683
-137.715
-137.748
-137.781
-137.814
-137.847
-137.88
-137.912
-137.944
-137.974
-138.002
-138.029
-138.054
-138.076
-138.096
-138.114
-138.129
-138.141
-138.15
-138.156
-138.159
-141.17
-141.167
-141.161
-141.153
-141.142
-141.128
-141.112
-141.094
-141.074
-141.051
-141.027
-141.001
-140.974
-140.945
-140.916
-140.886
-140.856
-140.826
-140.796
-140.766
-140.737
-140.71
-140.684
-140.659
-140.636
-140.615
-140.597
-140.581
-140.568
-140.557
-140.55
-140.545
-140.544
-140.545
-140.55
-140.557
-140.568
-140.581
-140.597
-140.615
-140.636
-140.659
-140.684
-140.71
-140.737
-140.766
-140.796
-140.826
-140.856
-140.886
-140.916
-140.945
-140.974
-141.001
-141.027
-141.051
-141.074
-141.094
-141.112
-141.128
-141.142
-141.153
-141.161
-141.167
-141.17
-144.183
-144.181
-144.175
-144.168
-144.158
-144.146
-144.131
-144.114
-144.096
-144.075
-144.053
-144.03
-144.005
-143.979
-143.952
-143.925
-143.898
-143.87
-143.843
-143.817
-143.791
-143.766
-143.742
-143.719
-143.699
-143.68
-143.663
-143.649
-143.637
-143.628
-143.621
-143.617
-143.615
-143.617
-143.621
-143.628
-143.637
-143.649
-143.663
-143.68
-143.699
-143.719
-143.742
-143.766
-143.791
-143.817
-143.843
-143.87
-143.898
-143.925
-143.952
-143.979
-144.005
-144.03
-144.053
-144.075
-144.096
-144.114
-144.131
-144.146
-144.158
-144.168
-144.175
-144.181
-144.183
-147.199
-147.197
-147.192
-147.185
-147.176
-147.165
-147.152
-147.137
-147.12
-147.101
-147.081
-147.059
-147.037
-147.014
-146.989
-146.965
-146.94
-146.915
-146.89
-146.866
-146.843
-146.82
-146.798
-146.778
-146.76
-146.743
-146.728
-146.715
-146.704
-146.695
-146.689
-146.685
-146.684
-146.685
-146.689
-146.695
-146.704
-146.715
-146.728
-146.743
-146.76
-146.778
-146.798
-146.82
-146.843
-146.866
-146.89
-146.915
-146.94
-146.965
-146.989
-147.014
-147.037
-147.059
-147.081
-147.101
-147.12
-147.137
-147.152
-147.165
-147.176
-147.185
-147.192
-147.197
-147.199
-150.217
-150.215
-150.211
-150.205
-150.197
-150.186
-150.174
-150.161
-150.145
-150.128
-150.11
-150.09
-150.07
-150.049
-150.027
-150.005
-149.982
-149.959
-149.937
-149.915
-149.894
-149.873
-149.854
-149.835
-149.818
-149.803
-149.79
-149.778
-149.768
-149.76
-149.755
-149.751
-149.75
-149.751
-149.755
-149.76
-149.768
-149.778
-149.79
-149.803
-149.818
-149.835
-149.854
-149.873
-149.894
-149.915
-149.937
-149.959
-149.982
-150.005
-150.027
-150.049
-150.07
-150.09
-150.11
-150.128
-150.145
-150.161
-150.174
-150.186
-150.197
-150.205
-150.211
-150.215
-150.217
-153.238
-153.236
-153.232
-153.227
-153.219
-153.21
-153.199
-153.186
-153.172
-153.157
-153.14
-153.123
-153.104
-153.085
-153.065
-153.045
-153.024
-153.004
-152.983
-152.963
-152.944
-152.925
-152.908
-152.891
-152.876
-152.862
-152.85
-152.839
-152.83
-152.823
-152.818
-152.815
-152.814
-152.815
-152.818
-152.823
-152.83
-152.839
-152.85
-152.862
-152.876
-152.891
-152.908
-152.925
-152.944
-152.963
-152.983
-153.004
-153.024
-153.045
-153.065
-153.085
-153.104
-153.123
-153.14
-153.157
-153.172
-153.186
-153.199
-153.21
-153.219
-153.227
-153.232
-153.236
-153.238
-156.26
-156.259
-156.255
-156.25
-156.243
-156.235
-156.225
-156.213
-156.201
-156.187
-156.172
-156.156
-156.139
-156.121
-156.103
-156.085
-156.066
-156.048
-156.029
-156.011
-155.994
-155.977
-155.961
-155.946
-155.932
-155.919
-155.908
-155.898
-155.89
-155.884
-155.88
-155.877
-155.876
-155.877
-155.88
-155.884
-155.89
-155.898
-155.908
-155.919
-155.932
-155.946
-155.961
-155.977
-155.994
-156.011
-156.029
-156.048
-156.066
-156.085
-156.103
-156.121
-156.139
-156.156
-156.172
-156.187
-156.201
-156.213
-156.225
-156.235
-156.243
-156.25
-156.255
-156.259
-156.26
-159.285
-159.283
-159.28
-159.275
-159.269
-159.261
-159.252
-159.242
-159.23
-159.218
-159.204
-159.189
-159.174
-159.158
-159.142
-159.125
-159.108
-159.091
-159.075
-159.058
-159.042
-159.027
-159.013
-158.999
-158.986
-158.975
-158.965
-158.956
-158.949
-158.943
-158.939
-158.937
-158.936
-158.937
-158.939
-158.943
-158.949
-158.956
-158.965
-158.975
-158.986
-158.999
-159.013
-159.027
-159.042
-159.058
-159.075
-159.091
-159.108
-159.125
-159.142
-159.158
-159.174
-159.189
-159.204
-159.218
-159.23
-159.242
-159.252
-159.261
-159.269
-159.275
-159.28
-159.283
-159.285
-162.311
-162.309
-162.306
-162.302
-162.296
-162.289
-162.281
-162.272
-162.261
-162.25
-162.237
-162.224
-162.21
-162.196
-162.181
-162.166
-162.15
-162.135
-162.12
-162.105
-162.091
-162.077
-162.064
-162.051
-162.04
-162.03
-162.02
-162.012
-162.006
-162.001
-161.997
-161.995
-161.994
-161.995
-161.997
-162.001
-162.006
-162.012
-162.02
-162.03
-162.04
-162.051
-162.064
-162.077
-162.091
-162.105
-162.12
-162.135
-162.15
-162.166
-162.181
-162.196
-162.21
-162.224
-162.237
-162.25
-162.261
-162.272
-162.281
-162.289
-162.296
-162.302
-162.306
-162.309
-162.311
-165.338
-165.337
-165.334
-165.33
-165.325
-165.319
-165.311
-165.303
-165.293
-165.283
-165.271
-165.259
-165.247
-165.233
-165.22
-165.206
-165.192
-165.178
-165.165
-165.151
-165.138
-165.126
-165.114
-165.103
-165.092
-165.083
-165.075
-165.067
-165.061
-165.057
-165.053
-165.051
-165.051
-165.051
-165.053
-165.057
-165.061
-165.067
-165.075
-165.083
-165.092
-165.103
-165.114
-165.126
-165.138
-165.151
-165.165
-165.178
-165.192
-165.206
-165.22
-165.233
-165.247
-165.259
-165.271
-165.283
-165.293
-165.303
-165.311
-165.319
-165.325
-165.33
-165.334
-165.337
-165.338
-168.367
-168.365
-168.363
-168.359
-168.355
-168.349
-168.342
-168.334
-168.326
-168.316
-168.306
-168.295
-168.284
-168.272
-168.259
-168.247
-168.234
-168.222
-168.209
-168.197
-168.185
-168.174
-168.163
-168.153
-168.144
-168.135
-168.128
-168.121
-168.116
-168.112
-168.108
-168.107
-168.106
-168.107
-168.108
-168.112
-168.116
-168.121
-168.128
-168.135
-168.144
-168.153
-168.163
-168.174
-168.185
-168.197
-168.209
-168.222
-168.234
-168.247
-168.259
-168.272
-168.284
-168.295
-168.306
-168.316
-168.326
-168.334
-168.342
-168.349
-168.355
-168.359
-168.363
-168.365
-168.367
-171.396
-171.395
-171.393
-171.39
-171.386
-171.381
-171.374
-171.367
-171.359
-171.351
-171.341
-171.332
-171.321
-171.31
-171.299
-171.288
-171.276
-171.265
-171.254
-171.243
-171.232
-171.222
-171.212
-171.203
-171.194
-171.186
-171.18
-171.174
-171.169
-171.165
-171.162
-171.161
-171.16
-171.161
-171.162
-171.165
-171.169
-171.174
-171.18
-171.186
-171.194
-171.203
-171.212
-171.222
-171.232
-171.243
-171.254
-171.265
-171.276
-171.288
-171.299
-171.31
-171.321
-171.332
-171.341
-171.351
-171.359
-171.367
-171.374
-171.381
-171.386
-171.39
-171.393
-171.395
-171.396
-174.427
-174.426
-174.425
-174.422
-174.418
-174.413
-174.407
-174.401
-174.394
-174.386
-174.377
-174.368
-174.359
-174.349
-174.339
-174.329
-174.318
-174.308
-174.298
-174.288
-174.278
-174.269
-174.26
-174.252
-174.244
-174.237
-174.231
-174.225
-174.221
-174.217
-174.215
-174.213
-174.213
-174.213
-174.215
-174.217
-174.221
-174.225
-174.231
-174.237
-174.244
-174.252
-174.26
-174.269
-174.278
-174.288
-174.298
-174.308
-174.318
-174.329
-174.339
-174.349
-174.359
-174.368
-174.377
-174.386
-174.394
-174.401
-174.407
-174.413
-174.418
-174.422
-174.425
-174.426
-174.427
-177.459
-177.459
-177.457
-177.454
-177.451
-177.446
-177.441
-177.435
-177.429
-177.422
-177.414
-177.406
-177.397
-177.388
-177.379
-177.37
-177.36
-177.351
-177.342
-177.333
-177.324
-177.315
-177.307
-177.3
-177.293
-177.287
-177.281
-177.276
-177.272
-177.269
-177.267
-177.265
-177.265
-177.265
-177.267
-177.269
-177.272
-177.276
-177.281
-177.287
-177.293
-177.3
-177.307
-177.315
-177.324
-177.333
-177.342
-177.351
-177.36
-177.37
-177.379
-177.388
-177.397
-177.406
-177.414
-177.422
-177.429
-177.435
-177.441
-177.446
-177.451
-177.454
-177.457
-177.459
-177.459
-180.492
-180.492
-180.49
-180.488
-180.484
-180.48
-180.476
-180.47
-180.465
-180.458
-180.451
-180.444
-180.436
-180.428
-180.42
-180.411
-180.403
-180.394
-180.386
-180.377
-180.369
-180.362
-180.354
-180.347
-180.341
-180.335
-180.33
-180.326
-180.322
-180.319
-180.317
-180.316
-180.316
-180.316
-180.317
-180.319
-180.322
-180.326
-180.33
-180.335
-180.341
-180.347
-180.354
-180.362
-180.369
-180.377
-180.386
-180.394
-180.403
-180.411
-180.42
-180.428
-180.436
-180.444
-180.451
-180.458
-180.465
-180.47
-180.476
-180.48
-180.484
-180.488
-180.49
-180.492
-180.492
-183.526
-183.525
-183.524
-183.522
-183.519
-183.515
-183.511
-183.506
-183.501
-183.495
-183.489
-183.482
-183.475
-183.467
-183.46
-183.452
-183.445
-183.437
-183.429
-183.422
-183.414
-183.407
-183.401
-183.395
-183.389
-183.384
-183.379
-183.375
-183.372
-183.369
-183.367
-183.366
-183.366
-183.366
-183.367
-183.369
-183.372
-183.375
-183.379
-183.384
-183.389
-183.395
-183.401
-183.407
-183.414
-183.422
-183.429
-183.437
-183.445
-183.452
-183.46
-183.467
-183.475
-183.482
-183.489
-183.495
-183.501
-183.506
-183.511
-183.515
-183.519
-183.522
-183.524
-183.525
-183.526
-186.561
-186.56
-186.559
-186.557
-186.554
-186.551
-186.547
-186.543
-186.538
-186.532
-186.527
-186.52
-186.514
-186.507
-186.501
-186.494
-186.487
-186.479
-186.473
-186.466
-186.459
-186.453
-186.447
-186.441
-186.436
-186.431
-186.427
-186.424
-186.421
-186.418
-186.417
-186.415
-186.415
-186.415
-186.417
-186.418
-186.421
-186.424
-186.427
-186.431
-186.436
-186.441
-186.447
-186.453
-186.459
-186.466
-186.473
-186.479
-186.487
-186.494
-186.501
-186.507
-186.514
-186.52
-186.527
-186.532
-186.538
-186.543
-186.547
-186.551
-186.554
-186.557
-186.559
-186.56
-186.561
-189.596
-189.595
-189.594
-189.592
-189.59
-189.587
-189.583
-189.579
-189.575
-189.57
-189.565
-189.559
-189.553
-189.547
-189.541
-189.535
-189.529
-189.522
-189.516
-189.51
-189.504
-189.498
-189.492
-189.487
-189.483
-189.478
-189.475
-189.471
-189.469
-189.467
-189.465
-189.464
-189.464
-189.464
-189.465
-189.467
-189.469
-189.471
-189.475
-189.478
-189.483
-189.487
-189.492
-189.498
-189.504
-189.51
-189.516
-189.522
-189.529
-189.535
-189.541
-189.547
-189.553
-189.559
-189.565
-189.57
-189.575
-189.579
-189.583
-189.587
-189.59
-189.592
-189.594
-189.595
-189.596
-192.632
-192.631
-192.63
-192.628
-192.626
-192.623
-192.62
-192.617
-192.613
-192.608
-192.603
-192.598
-192.593
-192.588
-192.582
-192.576
-192.57
-192.565
-192.559
-192.553
-192.548
-192.543
-192.538
-192.533
-192.529
-192.525
-192.522
-192.519
-192.516
-192.514
-192.513
-192.512
-192.512
-192.512
-192.513
-192.514
-192.516
-192.519
-192.522
-192.525
-192.529
-192.533
-192.538
-192.543
-192.548
-192.553
-192.559
-192.565
-192.57
-192.576
-192.582
-192.588
-192.593
-192.598
-192.603
-192.608
-192.613
-192.617
-192.62
-192.623
-192.626
-192.628
-192.63
-192.631
-192.632
-195.668
-195.667
-195.666
-195.665
-195.663
-195.661
-195.658
-195.654
-195.651
-195.647
-195.642
-195.638
-195.633
-195.628
-195.623
-195.618
-195.612
-195.607
-195.602
-195.597
-195.592
-195.587
-195.583
-195.579
-195.575
-195.571
-195.568
-195.565
-195.563
-195.561
-195.56
-195.559
-195.559
-195.559
-195.56
-195.561
-195.563
-195.565
-195.568
-195.571
-195.575
-195.579
-195.583
-195.587
-195.592
-195.597
-195.602
-195.607
-195.612
-195.618
-195.623
-195.628
-195.633
-195.638
-195.642
-195.647
-195.651
-195.654
-195.658
-195.661
-195.663
-195.665
-195.666
-195.667
-195.668
-198.705
-198.704
-198.703
-198.702
-198.7
-198.698
-198.695
-198.692
-198.689
-198.686
-198.682
-198.677
-198.673
-198.669
-198.664
-198.659
-198.654
-198.65
-198.645
-198.64
-198.636
-198.632
-198.628
-198.624
-198.62
-198.617
-198.614
-198.612
-198.61
-198.608
-198.607
-198.606
-198.606
-198.606
-198.607
-198.608
-198.61
-198.612
-198.614
-198.617
-198.62
-198.624
-198.628
-198.632
-198.636
-198.64
-198.645
-198.65
-198.654
-198.659
-198.664
-198.669
-198.673
-198.677
-198.682
-198.686
-198.689
-198.692
-198.695
-198.698
-198.7
-198.702
-198.703
-198.704
-198.705
-201.742
-201.742
-201.741
-201.74
-201.738
-201.736
-201.734
-201.731
-201.728
-201.725
-201.721
-201.717
-201.713
-201.709
-201.705
-201.701
-201.696
-201.692
-201.688
-201.684
-201.68
-201.676
-201.672
-201.669
-201.665
-201.662
-201.66
-201.658
-201.656
-201.654
-201.653
-201.653
-201.653
-201.653
-201.653
-201.654
-201.656
-201.658
-201.66
-201.662
-201.665
-201.669
-201.672
-201.676
-201.68
-201.684
-201.688
-201.692
-201.696
-201.701
-201.705
-201.709
-201.713
-201.717
-201.721
-201.725
-201.728
-201.731
-201.734
-201.736
-201.738
-201.74
-201.741
-201.742
-201.742
-204.78
-204.779
-204.779
-204.778
-204.776
-204.774
-204.772
-204.77
-204.767
-204.764
-204.761
-204.757
-204.754
-204.75
-204.746
-204.742
-204.738
-204.734
-204.731
-204.727
-204.723
-204.72
-204.716
-204.713
-204.71
-204.708
-204.705
-204.703
-204.702
-204.7
-204.699
-204.699
-204.699
-204.699
-204.699
-204.7
-204.702
-204.703
-204.705
-204.708
-204.71
-204.713
-204.716
-204.72
-204.723
-204.727
-204.731
-204.734
-204.738
-204.742
-204.746
-204.75
-204.754
-204.757
-204.761
-204.764
-204.767
-204.77
-204.772
-204.774
-204.776
-204.778
-204.779
-204.779
-204.78
-207.818
-207.818
-207.817
-207.816
-207.815
-207.813
-207.811
-207.809
-207.806
-207.804
-207.801
-207.798
-207.794
-207.791
-207.787
-207.784
-207.78
-207.777
-207.773
-207.77
-207.766
-207.763
-207.76
-207.757
-207.755
-207.752
-207.75
-207.748
-207.747
-207.746
-207.745
-207.744
-207.744
-207.744
-207.745
-207.746
-207.747
-207.748
-207.75
-207.752
-207.755
-207.757
-207.76
-207.763
-207.766
-207.77
-207.773
-207.777
-207.78
-207.784
-207.787
-207.791
-207.794
-207.798
-207.801
-207.804
-207.806
-207.809
-207.811
-207.813
-207.815
-207.816
-207.817
-207.818
-207.818
-210.856
-210.856
-210.856
-210.855
-210.853
-210.852
-210.85
-210.848
-210.846
-210.843
-210.841
-210.838
-210.835
-210.832
-210.829
-210.825
-210.822
-210.819
-210.816
-210.813
-210.81
-210.807
-210.804
-210.801
-210.799
-210.797
-210.795
-210.793
-210.792
-210.791
-210.79
-210.79
-210.789
-210.79
-210.79
-210.791
-210.792
-210.793
-210.795
-210.797
-210.799
-210.801
-210.804
-210.807
-210.81
-210.813
-210.816
-210.819
-210.822
-210.825
-210.829
-210.832
-210.835
-210.838
-210.841
-210.843
-210.846
-210.848
-210.85
-210.852
-210.853
-210.855
-210.856
-210.856
-210.856
-213.895
-213.895
-213.894
-213.894
-213.892
-213.891
-213.889
-213.888
-213.886
-213.883
-213.881
-213.878
-213.876
-213.873
-213.87
-213.867
-213.864
-213.861
-213.858
-213.855
-213.853
-213.85
-213.848
-213.845
-213.843
-213.841
-213.839
-213.838
-213.837
-213.836
-213.835
-213.834
-213.834
-213.834
-213.835
-213.836
-213.837
-213.838
-213.839
-213.841
-213.843
-213.845
-213.848
-213.85
-213.853
-213.855
-213.858
-213.861
-213.864
-213.867
-213.87
-213.873
-213.876
-213.878
-213.881
-213.883
-213.886
-213.888
-213.889
-213.891
-213.892
-213.894
-213.894
-213.895
-213.895
-216.934
-216.934
-216.934
-216.933
-216.932
-216.931
-216.929
-216.927
-216.926
-216.924
-216.921
-216.919
-216.917
-216.914
-216.911
-216.909
-216.906
-216.903
-216.901
-216.898
-216.896
-216.893
-216.891
-216.889
-216.887
-216.885
-216.884
-216.882
-216.881
-216.88
-216.879
-216.879
-216.879
-216.879
-216.879
-216.88
-216.881
-216.882
-216.884
-216.885
-216.887
-216.889
-216.891
-216.893
-216.896
-216.898
-216.901
-216.903
-216.906
-216.909
-216.911
-216.914
-216.917
-216.919
-216.921
-216.924
-216.926
-216.927
-216.929
-216.931
-216.932
-216.933
-216.934
-216.934
-216.934
-219.974
-219.973
-219.973
-219.972
-219.971
-219.97
-219.969
-219.967
-219.966
-219.964
-219.962
-219.96
-219.957
-219.955
-219.953
-219.95
-219.948
-219.946
-219.943
-219.941
-219.939
-219.936
-219.934
-219.932
-219.931
-219.929
-219.927
-219.926
-219.925
-219.924
-219.924
-219.923
-219.923
-219.923
-219.924
-219.924
-219.925
-219.926
-219.927
-219.929
-219.931
-219.932
-219.934
-219.936
-219.939
-219.941
-219.943
-219.946
-219.948
-219.95
-219.953
-219.955
-219.957
-219.96
-219.962
-219.964
-219.966
-219.967
-219.969
-219.97
-219.971
-219.972
-219.973
-219.973
-219.974
-223.013
-223.013
-223.013
-223.012
-223.011
-223.01
-223.009
-223.008
-223.006
-223.004
-223.002
-223.001
-222.999
-222.996
-222.994
-222.992
-222.99
-222.988
-222.985
-222.983
-222.981
-222.979
-222.977
-222.976
-222.974
-222.973
-222.971
-222.97
-222.969
-222.968
-222.968
-222.968
-222.968
-222.968
-222.968
-222.968
-222.969
-222.97
-222.971
-222.973
-222.974
-222.976
-222.977
-222.979
-222.981
-222.983
-222.985
-222.988
-222.99
-222.992
-222.994
-222.996
-222.999
-223.001
-223.002
-223.004
-223.006
-223.008
-223.009
-223.01
-223.011
-223.012
-223.013
-223.013
-223.013
-226.053
-226.053
-226.052
-226.052
-226.051
-226.05
-226.049
-226.048
-226.046
-226.045
-226.043
-226.042
-226.04
-226.038
-226.036
-226.034
-226.032
-226.03
-226.028
-226.026
-226.024
-226.022
-226.02
-226.019
-226.017
-226.016
-226.015
-226.014
-226.013
-226.012
-226.012
-226.012
-226.011
-226.012
-226.012
-226.012
-226.013
-226.014
-226.015
-226.016
-226.017
-226.019
-226.02
-226.022
-226.024
-226.026
-226.028
-226.03
-226.032
-226.034
-226.036
-226.038
-226.04
-226.042
-226.043
-226.045
-226.046
-226.048
-226.049
-226.05
-226.051
-226.052
-226.052
-226.053
-226.053
-229.093
-229.093
-229.093
-229.092
-229.091
-229.09
-229.089
-229.088
-229.087
-229.086
-229.084
-229.083
-229.081
-229.079
-229.077
-229.076
-229.074
-229.072
-229.07
-229.068
-229.067
-229.065
-229.063
-229.062
-229.061
-229.059
-229.058
-229.057
-229.057
-229.056
-229.056
-229.055
-229.055
-229.055
-229.056
-229.056
-229.057
-229.057
-229.058
-229.059
-229.061
-229.062
-229.063
-229.065
-229.067
-229.068
-229.07
-229.072
-229.074
-229.076
-229.077
-229.079
-229.081
-229.083
-229.084
-229.086
-229.087
-229.088
-229.089
-229.09
-229.091
-229.092
-229.093
-229.093
-229.093
-232.133
-232.133
-232.133
-232.132
-232.132
-232.131
-232.13
-232.129
-232.128
-232.126
-232.125
-232.124
-232.122
-232.121
-232.119
-232.117
-232.116
-232.114
-232.112
-232.111
-232.109
-232.108
-232.106
-232.105
-232.104
-232.103
-232.102
-232.101
-232.1
-232.099
-232.099
-232.099
-232.099
-232.099
-232.099
-232.099
-232.1
-232.101
-232.102
-232.103
-232.104
-232.105
-232.106
-232.108
-232.109
-232.111
-232.112
-232.114
-232.116
-232.117
-232.119
-232.121
-232.122
-232.124
-232.125
-232.126
-232.128
-232.129
-232.13
-232.131
-232.132
-232.132
-232.133
-232.133
-232.133
-235.174
-235.173
-235.173
-235.173
-235.172
-235.171
-235.171
-235.17
-235.169
-235.167
-235.166
-235.165
-235.163
-235.162
-235.161
-235.159
-235.157
-235.156
-235.154
-235.153
-235.152
-235.15
-235.149
-235.148
-235.147
-235.146
-235.145
-235.144
-235.143
-235.143
-235.142
-235.142
-235.142
-235.142
-235.142
-235.143
-235.143
-235.144
-235.145
-235.146
-235.147
-235.148
-235.149
-235.15
-235.152
-235.153
-235.154
-235.156
-235.157
-235.159
-235.161
-235.162
-235.163
-235.165
-235.166
-235.167
-235.169
-235.17
-235.171
-235.171
-235.172
-235.173
-235.173
-235.173
-235.174
-238.214
-238.214
-238.214
-238.213
-238.213
-238.212
-238.211
-238.21
-238.209
-238.208
-238.207
-238.206
-238.205
-238.203
-238.202
-238.201
-238.199
-238.198
-238.197
-238.195
-238.194
-238.193
-238.192
-238.19
-238.189
-238.189
-238.188
-238.187
-238.186
-238.186
-238.186
-238.185
-238.185
-238.185
-238.186
-238.186
-238.186
-238.187
-238.188
-238.189
-238.189
-238.19
-238.192
-238.193
-238.194
-238.195
-238.197
-238.198
-238.199
-238.201
-238.202
-238.203
-238.205
-238.206
-238.207
-238.208
-238.209
-238.21
-238.211
-238.212
-238.213
-238.213
-238.214
-238.214
-238.214
-241.255
-241.255
-241.254
-241.254
-241.253
-241.253
-241.252
-241.251
-241.251
-241.25
-241.248
-241.247
-241.246
-241.245
-241.244
-241.243
-241.241
-241.24
-241.239
-241.238
-241.236
-241.235
-241.234
-241.233
-241.232
-241.231
-241.231
-241.23
-241.229
-241.229
-241.229
-241.229
-241.228
-241.229
-241.229
-241.229
-241.229
-241.23
-241.231
-241.231
-241.232
-241.233
-241.234
-241.235
-241.236
-241.238
-241.239
-241.24
-241.241
-241.243
-241.244
-241.245
-241.246
-241.247
-241.248
-241.25
-241.251
-241.251
-241.252
-241.253
-241.253
-241.254
-241.254
-241.255
-241.255
-244.295
-244.295
-244.295
-244.295
-244.294
-244.294
-244.293
-244.292
-244.292
-244.291
-244.29
-244.289
-244.288
-244.287
-244.285
-244.284
-244.283
-244.282
-244.281
-244.28
-244.279
-244.278
-244.277
-244.276
-244.275
-244.274
-244.273
-244.273
-244.272
-244.272
-244.272
-244.271
-244.271
-244.271
-244.272
-244.272
-244.272
-244.273
-244.273
-244.274
-244.275
-244.276
-244.277
-244.278
-244.279
-244.28
-244.281
-244.282
-244.283
-244.284
-244.285
-244.287
-244.288
-244.289
-244.29
-244.291
-244.292
-244.292
-244.293
-244.294
-244.294
-244.295
-244.295
-244.295
-244.295
-247.336
-247.336
-247.336
-247.336
-247.335
-247.335
-247.334
-247.334
-247.333
-247.332
-247.331
-247.33
-247.329
-247.328
-247.327
-247.326
-247.325
-247.324
-247.323
-247.322
-247.321
-247.32
-247.319
-247.318
-247.317
-247.317
-247.316
-247.316
-247.315
-247.315
-247.315
-247.314
-247.314
-247.314
-247.315
-247.315
-247.315
-247.316
-247.316
-247.317
-247.317
-247.318
-247.319
-247.32
-247.321
-247.322
-247.323
-247.324
-247.325
-247.326
-247.327
-247.328
-247.329
-247.33
-247.331
-247.332
-247.333
-247.334
-247.334
-247.335
-247.335
-247.336
-247.336
-247.336
-247.336
-250.377
-250.377
-250.377
-250.377
-250.376
-250.376
-250.375
-250.375
-250.374
-250.373
-250.372
-250.372
-250.371
-250.37
-250.369
-250.368
-250.367
-250.366
-250.365
-250.364
-250.363
-250.362
-250.361
-250.361
-250.36
-250.359
-250.359
-250.358
-250.358
-250.357
-250.357
-250.357
-250.357
-250.357
-250.357
-250.357
-250.358
-250.358
-250.359
-250.359
-250.36
-250.361
-250.361
-250.362
-250.363
-250.364
-250.365
-250.366
-250.367
-250.368
-250.369
-250.37
-250.371
-250.372
-250.372
-250.373
-250.374
-250.375
-250.375
-250.376
-250.376
-250.377
-250.377
-250.377
-250.377
-253.418
-253.418
-253.418
-253.418
-253.417
-253.417
-253.417
-253.416
-253.415
-253.415
-253.414
-253.413
-253.412
-253.411
-253.411
-253.41
-253.409
-253.408
-253.407
-253.406
-253.405
-253.405
-253.404
-253.403
-253.402
-253.402
-253.401
-253.401
-253.4
-253.4
-253.4
-253.4
-253.4
-253.4
-253.4
-253.4
-253.4
-253.401
-253.401
-253.402
-253.402
-253.403
-253.404
-253.405
-253.405
-253.406
-253.407
-253.408
-253.409
-253.41
-253.411
-253.411
-253.412
-253.413
-253.414
-253.415
-253.415
-253.416
-253.417
-253.417
-253.417
-253.418
-253.418
-253.418
-253.418
-256.459
-256.459
-256.459
-256.459
-256.459
-256.458
-256.458
-256.457
-256.457
-256.456
-256.455
-256.455
-256.454
-256.453
-256.452
-256.452
-256.451
-256.45
-256.449
-256.448
-256.447
-256.447
-256.446
-256.445
-256.445
-256.444
-256.444
-256.443
-256.443
-256.443
-256.442
-256.442
-256.442
-256.442
-256.442
-256.443
-256.443
-256.443
-256.444
-256.444
-256.445
-256.445
-256.446
-256.447
-256.447
-256.448
-256.449
-256.45
-256.451
-256.452
-256.452
-256.453
-256.454
-256.455
-256.455
-256.456
-256.457
-256.457
-256.458
-256.458
-256.459
-256.459
-256.459
-256.459
-256.459
-259.501
-259.501
-259.5
-259.5
-259.5
-259.5
-259.499
-259.499
-259.498
-259.498
-259.497
-259.496
-259.496
-259.495
-259.494
-259.493
-259.493
-259.492
-259.491
-259.49
-259.49
-259.489
-259.488
-259.488
-259.487
-259.487
-259.486
-259.486
-259.485
-259.485
-259.485
-259.485
-259.485
-259.485
-259.485
-259.485
-259.485
-259.486
-259.486
-259.487
-259.487
-259.488
-259.488
-259.489
-259.49
-259.49
-259.491
-259.492
-259.493
-259.493
-259.494
-259.495
-259.496
-259.496
-259.497
-259.498
-259.498
-259.499
-259.499
-259.5
-259.5
-259.5
-259.5
-259.501
-259.501
-262.542
-262.542
-262.542
-262.542
-262.541
-262.541
-262.541
-262.54
-262.54
-262.539
-262.538
-262.538
-262.537
-262.537
-262.536
-262.535
-262.534
-262.534
-262.533
-262.532
-262.532
-262.531
-262.53
-262.53
-262.529
-262.529
-262.528
-262.528
-262.528
-262.528
-262.527
-262.527
-262.527
-262.527
-262.527
-262.528
-262.528
-262.528
-262.528
-262.529
-262.529
-262.53
-262.53
-262.531
-262.532
-262.532
-262.533
-262.534
-262.534
-262.535
-262.536
-262.537
-262.537
-262.538
-262.538
-262.539
-262.54
-262.54
-262.541
-262.541
-262.541
-262.542
-262.542
-262.542
-262.542
-265.583
-265.583
-265.583
-265.583
-265.583
-265.582
-265.582
-265.582
-265.581
-265.581
-265.58
-265.58
-265.579
-265.578
-265.578
-265.577
-265.576
-265.576
-265.575
-265.574
-265.574
-265.573
-265.573
-265.572
-265.572
-265.571
-265.571
-265.57
-265.57
-265.57
-265.57
-265.57
-265.57
-265.57
-265.57
-265.57
-265.57
-265.57
-265.571
-265.571
-265.572
-265.572
-265.573
-265.573
-265.574
-265.574
-265.575
-265.576
-265.576
-265.577
-265.578
-265.578
-265.579
-265.58
-265.58
-265.581
-265.581
-265.582
-265.582
-265.582
-265.583
-265.583
-265.583
-265.583
-265.583
-268.625
-268.625
-268.625
-268.624
-268.624
-268.624
-268.624
-268.623
-268.623
-268.622
-268.622
-268.621
-268.621
-268.62
-268.619
-268.619
-268.618
-268.618
-268.617
-268.616
-268.616
-268.615
-268.615
-268.614
-268.614
-268.613
-268.613
-268.613
-268.612
-268.612
-268.612
-268.612
-268.612
-268.612
-268.612
-268.612
-268.612
-268.613
-268.613
-268.613
-268.614
-268.614
-268.615
-268.615
-268.616
-268.616
-268.617
-268.618
-268.618
-268.619
-268.619
-268.62
-268.621
-268.621
-268.622
-268.622
-268.623
-268.623
-268.624
-268.624
-268.624
-268.624
-268.625
-268.625
-268.625
-271.666
-271.666
-271.666
-271.666
-271.666
-271.665
-271.665
-271.665
-271.664
-271.664
-271.663
-271.663
-271.662
-271.662
-271.661
-271.661
-271.66
-271.659
-271.659
-271.658
-271.658
-271.657
-271.657
-271.656
-271.656
-271.655
-271.655
-271.655
-271.655
-271.654
-271.654
-271.654
-271.654
-271.654
-271.654
-271.654
-271.655
-271.655
-271.655
-271.655
-271.656
-271.656
-271.657
-271.657
-271.658
-271.658
-271.659
-271.659
-271.66
-271.661
-271.661
-271.662
-271.662
-271.663
-271.663
-271.664
-271.664
-271.665
-271.665
-271.665
-271.666
-271.666
-271.666
-271.666
-271.666
-274.708
-274.708
-274.708
-274.708
-274.707
-274.707
-274.707
-274.706
-274.706
-274.706
-274.705
-274.705
-274.704
-274.704
-274.703
-274.702
-274.702
-274.701
-274.701
-274.7
-274.7
-274.699
-274.699
-274.698
-274.698
-274.698
-274.697
-274.697
-274.697
-274.696
-274.696
-274.696
-274.696
-274.696
-274.696
-274.696
-274.697
-274.697
-274.697
-274.698
-274.698
-274.698
-274.699
-274.699
-274.7
-274.7
-274.701
-274.701
-274.702
-274.702
-274.703
-274.704
-274.704
-274.705
-274.705
-274.706
-274.706
-274.706
-274.707
-274.707
-274.707
-274.708
-274.708
-274.708
-274.708
-277.749
-277.749
-277.749
-277.749
-277.749
-277.749
-277.748
-277.748
-277.748
-277.747
-277.747
-277.746
-277.746
-277.745
-277.745
-277.744
-277.744
-277.743
-277.743
-277.742
-277.742
-277.741
-277.741
-277.74
-277.74
-277.74
-277.739
-277.739
-277.739
-277.739
-277.738
-277.738
-277.738
-277.738
-277.738
-277.739
-277.739
-277.739
-277.739
-277.74
-277.74
-277.74
-277.741
-277.741
-277.742
-277.742
-277.743
-277.743
-277.744
-277.744
-277.745
-277.745
-277.746
-277.746
-277.747
-277.747
-277.748
-277.748
-277.748
-277.749
-277.749
-277.749
-277.749
-277.749
-277.749
-280.791
-280.791
-280.791
-280.791
-280.791
-280.79
-280.79
-280.79
-280.789
-280.789
-280.789
-280.788
-280.788
-280.787
-280.787
-280.786
-280.786
-280.785
-280.785
-280.784
-280.784
-280.783
-280.783
-280.782
-280.782
-280.782
-280.781
-280.781
-280.781
-280.781
-280.781
-280.78
-280.78
-280.78
-280.781
-280.781
-280.781
-280.781
-280.781
-280.782
-280.782
-280.782
-280.783
-280.783
-280.784
-280.784
-280.785
-280.785
-280.786
-280.786
-280.787
-280.787
-280.788
-280.788
-280.789
-280.789
-280.789
-280.79
-280.79
-280.79
-280.791
-280.791
-280.791
-280.791
-280.791
-283.833
-283.833
-283.833
-283.833
-283.832
-283.832
-283.832
-283.832
-283.831
-283.831
-283.83
-283.83
-283.829
-283.829
-283.828
-283.828
-283.827
-283.827
-283.826
-283.826
-283.826
-283.825
-283.825
-283.824
-283.824
-283.824
-283.823
-283.823
-283.823
-283.823
-283.823
-283.822
-283.822
-283.822
-283.823
-283.823
-283.823
-283.823
-283.823
-283.824
-283.824
-283.824
-283.825
-283.825
-283.826
-283.826
-283.826
-283.827
-283.827
-283.828
-283.828
-283.829
-283.829
-283.83
-283.83
-283.831
-283.831
-283.832
-283.832
-283.832
-283.832
-283.833
-283.833
-283.833
-283.833
-286.875
-286.875
-286.874
-286.874
-286.874
-286.874
-286.874
-286.873
-286.873
-286.873
-286.872
-286.872
-286.871
-286.871
-286.87
-286.87
-286.869
-286.869
-286.868
-286.868
-286.867
-286.867
-286.867
-286.866
-286.866
-286.865
-286.865
-286.865
-286.865
-286.865
-286.864
-286.864
-286.864
-286.864
-286.864
-286.865
-286.865
-286.865
-286.865
-286.865
-286.866
-286.866
-286.867
-286.867
-286.867
-286.868
-286.868
-286.869
-286.869
-286.87
-286.87
-286.871
-286.871
-286.872
-286.872
-286.873
-286.873
-286.873
-286.874
-286.874
-286.874
-286.874
-286.874
-286.875
-286.875
-289.916
-289.916
-289.916
-289.916
-289.916
-289.916
-289.915
-289.915
-289.915
-289.914
-289.914
-289.914
-289.913
-289.913
-289.912
-289.912
-289.911
-289.911
-289.91
-289.91
-289.909
-289.909
-289.908
-289.908
-289.908
-289.907
-289.907
-289.907
-289.907
-289.906
-289.906
-289.906
-289.906
-289.906
-289.906
-289.906
-289.907
-289.907
-289.907
-289.907
-289.908
-289.908
-289.908
-289.909
-289.909
-289.91
-289.91
-289.911
-289.911
-289.912
-289.912
-289.913
-289.913
-289.914
-289.914
-289.914
-289.915
-289.915
-289.915
-289.916
-289.916
-289.916
-289.916
-289.916
-289.916
  0 KSP preconditioned resid norm 1.399306616230e+07 true resid norm 1.399306616230e+07 ||Ae||/||Ax|| 3.441528283198e-02
  1 KSP preconditioned resid norm 9.516387654208e+05 true resid norm 9.516387654208e+05 ||Ae||/||Ax|| 2.340510427520e-03
  2 KSP preconditioned resid norm 1.672012246723e+03 true resid norm 1.672012246751e+03 ||Ae||/||Ax|| 4.112234852823e-06
  3 KSP preconditioned resid norm 9.105905260285e+00 true resid norm 9.105905236027e+00 ||Ae||/||Ax|| 2.239554222815e-08
  4 KSP preconditioned resid norm 3.863456505538e-02 true resid norm 3.863455920924e-02 ||Ae||/||Ax|| 9.501986675783e-11
  5 KSP preconditioned resid norm 3.774649063131e-05 true resid norm 3.774854002114e-05 ||Ae||/||Ax|| 9.284074456977e-14
Linear solve converged due to CONVERGED_RTOL
Process [0]
72.7687
72.7477
72.7058
72.6432
72.5602
72.4572
72.3348
72.1937
72.0346
71.8585
71.6664
71.4597
71.2397
71.008
70.7663
70.5166
70.261
70.0017
69.741
69.4816
69.2261
68.9773
68.7379
68.5107
68.2985
68.104
67.9296
67.7777
67.6504
67.5495
67.4763
67.432
67.4171
67.432
67.4763
67.5495
67.6504
67.7777
67.9296
68.104
68.2985
68.5107
68.7379
68.9773
69.2261
69.4816
69.741
70.0017
70.261
70.5166
70.7663
71.008
71.2397
71.4597
71.6664
71.8585
72.0346
72.1937
72.3348
72.4572
72.5602
72.6432
72.7058
72.7477
72.7687
69.7481
69.7271
69.6849
69.622
69.5386
69.435
69.312
69.17
69.01
68.8327
68.6394
68.4313
68.2097
67.9762
67.7326
67.4808
67.2229
66.9611
66.6979
66.4358
66.1776
65.9259
65.6836
65.4537
65.2388
65.0417
64.8649
64.7109
64.5818
64.4794
64.4052
64.3602
64.3452
64.3602
64.4052
64.4794
64.5818
64.7109
64.8649
65.0417
65.2388
65.4537
65.6836
65.9259
66.1776
66.4358
66.6979
66.9611
67.2229
67.4808
67.7326
67.9762
68.2097
68.4313
68.6394
68.8327
69.01
69.17
69.312
69.435
69.5386
69.622
69.6849
69.7271
69.7481
66.749
66.7277
66.6852
66.6217
66.5374
66.4327
66.3083
66.1647
66.0028
65.8234
65.6275
65.4166
65.1918
64.9548
64.7073
64.4512
64.1887
63.922
63.6536
63.3861
63.1223
62.8649
62.6169
62.3813
62.161
61.9587
61.7772
61.6189
61.4861
61.3808
61.3044
61.2581
61.2426
61.2581
61.3044
61.3808
61.4861
61.6189
61.7772
61.9587
62.161
62.3813
62.6169
62.8649
63.1223
63.3861
63.6536
63.922
64.1887
64.4512
64.7073
64.9548
65.1918
65.4166
65.6275
65.8234
66.0028
66.1647
66.3083
66.4327
66.5374
66.6217
66.6852
66.7277
66.749
63.7716
63.75
63.7069
63.6423
63.5568
63.4505
63.3241
63.1781
63.0133
62.8306
62.6311
62.4158
62.1863
61.9439
61.6906
61.4281
61.1587
60.8846
60.6084
60.3327
60.0604
59.7944
59.5377
59.2935
59.0648
58.8546
58.6658
58.501
58.3626
58.2528
58.173
58.1247
58.1085
58.1247
58.173
58.2528
58.3626
58.501
58.6658
58.8546
59.0648
59.2935
59.5377
59.7944
60.0604
60.3327
60.6084
60.8846
61.1587
61.4281
61.6906
61.9439
62.1863
62.4158
62.6311
62.8306
63.0133
63.1781
63.3241
63.4505
63.5568
63.6423
63.7069
63.75
63.7716
60.8162
60.7942
60.7502
60.6844
60.5972
60.4888
60.3597
60.2106
60.0421
59.855
59.6505
59.4296
59.1937
58.9443
58.6832
58.4122
58.1335
57.8495
57.5627
57.2759
56.9921
56.7143
56.4458
56.1899
55.9498
55.7288
55.5299
55.3562
55.2102
55.0941
55.0098
54.9587
54.9416
54.9587
55.0098
55.0941
55.2102
55.3562
55.5299
55.7288
55.9498
56.1899
56.4458
56.7143
56.9921
57.2759
57.5627
57.8495
58.1335
58.4122
58.6832
58.9443
59.1937
59.4296
59.6505
59.855
60.0421
60.2106
60.3597
60.4888
60.5972
60.6844
60.7502
60.7942
60.8162
57.8831
57.8606
57.8156
57.7484
57.6591
57.548
57.4157
57.2627
57.0896
56.8972
56.6865
56.4586
56.2149
55.9566
55.6857
55.404
55.1137
54.8171
54.5169
54.2161
53.9176
53.6249
53.3412
53.0702
52.8154
52.5804
52.3686
52.1833
52.0273
51.9031
51.8129
51.7582
51.7398
51.7582
51.8129
51.9031
52.0273
52.1833
52.3686
52.5804
52.8154
53.0702
53.3412
53.6249
53.9176
54.2161
54.5169
54.8171
55.1137
55.404
55.6857
55.9566
56.2149
56.4586
56.6865
56.8972
57.0896
57.2627
57.4157
57.548
57.6591
57.7484
57.8156
57.8606
57.8831
54.9729
54.9499
54.9037
54.8347
54.743
54.6289
54.4928
54.3352
54.1567
53.958
53.74
53.5038
53.2506
52.9819
52.6992
52.4046
52.1001
51.7883
51.4719
51.1539
50.8374
50.5261
50.2237
49.934
49.661
49.4085
49.1805
48.9806
48.812
48.6777
48.58
48.5207
48.5008
48.5207
48.58
48.6777
48.812
48.9806
49.1805
49.4085
49.661
49.934
50.2237
50.5261
50.8374
51.1539
51.4719
51.7883
52.1001
52.4046
52.6992
52.9819
53.2506
53.5038
53.74
53.958
54.1567
54.3352
54.4928
54.6289
54.743
54.8347
54.9037
54.9499
54.9729
52.0862
52.0625
52.0151
51.9441
51.8497
51.7321
51.5918
51.429
51.2443
51.0384
50.8121
50.5663
50.3022
50.0212
49.7249
49.4151
49.0941
48.7643
48.4285
48.0899
47.752
47.4184
47.0933
46.7809
46.4856
46.2118
45.9639
45.746
45.562
45.4151
45.3081
45.2431
45.2213
45.2431
45.3081
45.4151
45.562
45.746
45.9639
46.2118
46.4856
46.7809
47.0933
47.4184
47.752
48.0899
48.4285
48.7643
49.0941
49.4151
49.7249
50.0212
50.3022
50.5663
50.8121
51.0384
51.2443
51.429
51.5918
51.7321
51.8497
51.9441
52.0151
52.0625
52.0862
49.2237
49.1992
49.1504
49.0773
48.9799
48.8585
48.7134
48.5449
48.3534
48.1395
47.9039
47.6473
47.371
47.0761
46.7642
46.4371
46.097
45.7464
45.3881
45.0254
44.6621
44.3021
43.95
43.6105
43.2884
42.9888
42.7168
42.4771
42.2742
42.1119
41.9937
41.9217
41.8975
41.9217
41.9937
42.1119
42.2742
42.4771
42.7168
42.9888
43.2884
43.6105
43.95
44.3021
44.6621
45.0254
45.3881
45.7464
46.097
46.4371
46.7642
47.0761
47.371
47.6473
47.9039
48.1395
48.3534
48.5449
48.7134
48.8585
48.9799
49.0773
49.1504
49.1992
49.2237
46.3859
46.3608
46.3104
46.235
46.1345
46.0091
45.8589
45.6842
45.4853
45.2627
45.0169
44.7485
44.4586
44.1483
43.819
43.4724
43.1106
42.7361
42.352
41.9615
41.5687
41.1779
40.794
40.4222
40.0683
39.7379
39.4368
39.1708
38.945
38.7642
38.6321
38.5517
38.5247
38.5517
38.6321
38.7642
38.945
39.1708
39.4368
39.7379
40.0683
40.4222
40.794
41.1779
41.5687
41.9615
42.352
42.7361
43.1106
43.4724
43.819
44.1483
44.4586
44.7485
45.0169
45.2627
45.4853
45.6842
45.8589
46.0091
46.1345
46.235
46.3104
46.3608
46.3859
43.5738
43.5479
43.496
43.4181
43.3144
43.1847
43.0292
42.8481
42.6414
42.4094
42.1527
41.8716
41.567
41.2398
40.8912
40.523
40.137
39.7358
39.3223
38.9001
38.4733
38.0466
37.6256
37.216
36.8242
36.4571
36.1213
35.8236
35.5703
35.3669
35.2182
35.1275
35.097
35.1275
35.2182
35.3669
35.5703
35.8236
36.1213
36.4571
36.8242
37.216
37.6256
38.0466
38.4733
38.9001
39.3223
39.7358
40.137
40.523
40.8912
41.2398
41.567
41.8716
42.1527
42.4094
42.6414
42.8481
43.0292
43.1847
43.3144
43.4181
43.496
43.5479
43.5738
40.788
40.7613
40.7079
40.6276
40.5206
40.3866
40.2257
40.0378
39.823
39.5814
39.3132
39.0186
38.6983
38.3529
37.9836
37.5916
37.179
36.7479
36.3015
35.8433
35.3777
34.9098
34.4455
33.9916
33.5553
33.1444
32.7671
32.4314
32.1448
31.9142
31.7452
31.6421
31.6075
31.6421
31.7452
31.9142
32.1448
32.4314
32.7671
33.1444
33.5553
33.9916
34.4455
34.9098
35.3777
35.8433
36.3015
36.7479
37.179
37.5916
37.9836
38.3529
38.6983
39.0186
39.3132
39.5814
39.823
40.0378
40.2257
40.3866
40.5206
40.6276
40.7079
40.7613
40.788
38.0294
38.002
37.947
37.8644
37.7541
37.6158
37.4495
37.2549
37.032
36.7805
36.5004
36.1918
35.855
35.4904
35.0988
34.6813
34.2396
33.7757
33.2927
32.794
32.2844
31.7692
31.255
30.7492
30.2604
29.7977
29.3707
28.9892
28.6624
28.3988
28.2054
28.0872
28.0475
28.0872
28.2054
28.3988
28.6624
28.9892
29.3707
29.7977
30.2604
30.7492
31.255
31.7692
32.2844
32.794
33.2927
33.7757
34.2396
34.6813
35.0988
35.4904
35.855
36.1918
36.5004
36.7805
37.032
37.2549
37.4495
37.6158
37.7541
37.8644
37.947
38.002
38.0294
35.2987
35.2705
35.2141
35.1293
35.0159
34.8736
34.702
34.5009
34.2699
34.0085
33.7165
33.3937
33.0399
32.6553
32.2403
31.7956
31.3226
30.823
30.2996
29.756
29.1967
28.6276
28.0558
27.4897
26.9391
26.4147
25.9282
25.4914
25.1159
24.8122
24.5891
24.4527
24.4069
24.4527
24.5891
24.8122
25.1159
25.4914
25.9282
26.4147
26.9391
27.4897
28.0558
28.6276
29.1967
29.756
30.2996
30.823
31.3226
31.7956
32.2403
32.6553
33.0399
33.3937
33.7165
34.0085
34.2699
34.5009
34.702
34.8736
35.0159
35.1293
35.2141
35.2705
35.2987
32.5966
32.5678
32.5102
32.4233
32.3071
32.161
31.9846
31.7773
31.5385
31.2676
30.964
30.627
30.2562
29.8512
29.4119
28.9388
28.4325
27.8945
27.3272
26.7338
26.119
25.4888
24.8508
24.2145
23.5911
22.9933
22.4351
21.9313
21.4965
21.1439
20.8846
20.7263
20.6731
20.7263
20.8846
21.1439
21.4965
21.9313
22.4351
22.9933
23.5911
24.2145
24.8508
25.4888
26.119
26.7338
27.3272
27.8945
28.4325
28.9388
29.4119
29.8512
30.2562
30.627
30.964
31.2676
31.5385
31.7773
31.9846
32.161
32.3071
32.4233
32.5102
32.5678
32.5966
29.9238
29.8945
29.8357
29.7472
29.6286
29.4792
29.2985
29.0856
28.8398
28.56
28.2453
27.8947
27.5071
27.0818
26.618
26.1156
25.5745
24.9958
24.3812
23.7334
23.057
22.3578
21.6441
20.9263
20.2171
19.5316
18.8868
18.3012
17.7935
17.3808
17.0775
16.893
16.8314
16.893
17.0775
17.3808
17.7935
18.3012
18.8868
19.5316
20.2171
20.9263
21.6441
22.3578
23.057
23.7334
24.3812
24.9958
25.5745
26.1156
26.618
27.0818
27.5071
27.8947
28.2453
28.56
28.8398
29.0856
29.2985
29.4792
29.6286
29.7472
29.8357
29.8945
29.9238
27.2808
27.2511
27.1916
27.1018
26.9812
26.8292
26.645
26.4275
26.1756
25.8879
25.5632
25.1998
24.7964
24.3514
23.8634
23.3315
22.7549
22.1337
21.4688
20.7622
20.0179
19.2416
18.4417
17.6293
16.819
16.0284
15.2784
14.5922
13.9939
13.5067
13.1498
12.935
12.8645
12.935
13.1498
13.5067
13.9939
14.5922
15.2784
16.0284
16.819
17.6293
18.4417
19.2416
20.0179
20.7622
21.4688
22.1337
22.7549
23.3315
23.8634
24.3514
24.7964
25.1998
25.5632
25.8879
26.1756
26.4275
26.645
26.8292
26.9812
27.1018
27.1916
27.2511
27.2808
24.668
24.6381
24.5781
24.4875
24.3658
24.212
24.0253
23.8043
23.5476
23.2535
22.9202
22.5457
22.1279
21.6645
21.1535
20.5927
19.9806
19.316
18.5986
17.8294
17.0113
16.1494
15.2518
14.3303
13.4008
12.4841
11.6053
10.7938
10.0814
9.50029
9.07794
8.83038
8.7543
8.83038
9.07794
9.50029
10.0814
10.7938
11.6053
12.4841
13.4008
14.3303
15.2518
16.1494
17.0113
17.8294
18.5986
19.316
19.9806
20.5927
21.1535
21.6645
22.1279
22.5457
22.9202
23.2535
23.5476
23.8043
24.0253
24.212
24.3658
24.4875
24.5781
24.6381
24.668
22.0856
22.0557
21.9956
21.9049
21.7828
21.6284
21.4404
21.2174
20.9576
20.6589
20.3191
19.9356
19.5056
19.0261
18.494
17.9062
17.2596
16.5518
15.7809
14.9463
14.0493
13.0935
12.0863
11.0393
9.96976
8.90121
7.86389
6.8946
6.03562
5.33262
4.8285
4.55164
4.48957
4.55164
4.8285
5.33262
6.03562
6.8946
7.86389
8.90121
9.96976
11.0393
12.0863
13.0935
14.0493
14.9463
15.7809
16.5518
17.2596
17.9062
18.494
19.0261
19.5056
19.9356
20.3191
20.6589
20.9576
21.2174
21.4404
21.6284
21.7828
21.9049
21.9956
22.0557
22.0856
19.5335
19.5039
19.4443
19.3542
19.2327
19.0788
18.8911
18.6678
18.407
18.1061
17.7624
17.3727
16.9336
16.4412
15.8912
15.2793
14.6009
13.8517
13.0279
12.1267
11.1468
10.0898
8.96107
7.77118
6.5377
5.28659
4.05339
2.88343
1.83144
0.962959
0.348276
0.0547373
0.0987876
0.0547373
0.348276
0.962959
1.83144
2.88343
4.05339
5.28659
6.5377
7.77118
8.96107
10.0898
11.1468
12.1267
13.0279
13.8517
14.6009
15.2793
15.8912
16.4412
16.9336
17.3727
17.7624
18.1061
18.407
18.6678
18.8911
19.0788
19.2327
19.3542
19.4443
19.5039
19.5335
17.0117
16.9826
16.9239
16.8352
16.7155
16.5636
16.3779
16.1565
15.897
15.5967
15.2523
14.8601
14.4158
13.9147
13.3513
12.7198
12.014
11.2274
10.3536
9.38683
8.32264
7.15903
5.89796
4.54735
3.12352
1.65379
0.178676
-1.24758
-2.55912
-3.66446
-4.45811
-4.78502
-4.20253
-4.78502
-4.45811
-3.66446
-2.55912
-1.24758
0.178676
1.65379
3.12352
4.54735
5.89796
7.15903
8.32264
9.38683
10.3536
11.2274
12.014
12.7198
13.3513
13.9147
14.4158
14.8601
15.2523
15.5967
15.897
16.1565
16.3779
16.5636
16.7155
16.8352
16.9239
16.9826
17.0117
14.5195
14.4912
14.4341
14.3477
14.231
14.0827
13.901
13.6838
13.4285
13.1321
12.7908
12.4003
11.9558
11.4513
10.8805
10.2358
9.5092
8.69163
7.77371
6.74594
5.59945
4.32721
2.92577
1.39788
-0.244044
-1.97356
-3.74567
-5.4951
-7.15909
-8.60843
-9.73865
-10.549
-7.23537
-10.549
-9.73865
-8.60843
-7.15909
-5.4951
-3.74567
-1.97356
-0.244044
1.39788
2.92577
4.32721
5.59945
6.74594
7.77371
8.69163
9.5092
10.2358
10.8805
11.4513
11.9558
12.4003
12.7908
13.1321
13.4285
13.6838
13.901
14.0827
14.231
14.3477
14.4341
14.4912
14.5195
12.0561
12.0289
11.9741
11.8911
11.7787
11.6357
11.4601
11.2498
11.0019
10.713
10.3792
9.99556
9.55653
9.05547
8.48465
7.83516
7.09673
6.25777
5.30538
4.2256
3.00397
1.6266
0.0820078
-1.63579
-3.52266
-5.55765
-7.69308
-9.82985
10.9923
10.9916
10.9914
10.9908
10.9844
10.9908
10.9914
10.9916
10.9923
-9.82985
-7.69308
-5.55765
-3.52266
-1.63579
0.0820078
1.6266
3.00397
4.2256
5.30538
6.25777
7.09673
7.83516
8.48465
9.05547
9.55653
9.99556
10.3792
10.713
11.0019
11.2498
11.4601
11.6357
11.7787
11.8911
11.9741
12.0289
12.0561
9.62046
9.59471
9.54282
9.46412
9.35755
9.22167
9.05459
8.85394
8.61681
8.33964
8.01811
7.64705
7.22028
6.73043
6.16872
5.52478
4.78635
3.93911
2.96642
1.84932
0.566661
-0.9042
-2.58586
-4.49777
-6.65087
-9.03976
10.9854
10.9847
10.9849
10.9847
10.9846
10.9845
10.985
10.9845
10.9846
10.9847
10.9849
10.9847
10.9854
-9.03976
-6.65087
-4.49777
-2.58586
-0.9042
0.566661
1.84932
2.96642
3.93911
4.78635
5.52478
6.16872
6.73043
7.22028
7.64705
8.01811
8.33964
8.61681
8.85394
9.05459
9.22167
9.35755
9.46412
9.54282
9.59471
9.62046
7.21098
7.18703
7.13876
7.06548
6.96616
6.83933
6.68313
6.49514
6.27242
6.0113
5.70733
5.35512
4.9481
4.47836
3.93631
3.31035
2.58649
1.74783
0.774118
-0.358831
-1.67952
-3.22093
-5.0199
-7.11483
-9.53964
10.9783
10.9781
10.9779
10.9779
10.9778
10.9777
10.9777
10.9778
10.9777
10.9777
10.9778
10.9779
10.9779
10.9781
10.9783
-9.53964
-7.11483
-5.0199
-3.22093
-1.67952
-0.358831
0.774118
1.74783
2.58649
3.31035
3.93631
4.47836
4.9481
5.35512
5.70733
6.0113
6.27242
6.49514
6.68313
6.83933
6.96616
7.06548
7.13876
7.18703
7.21098
4.82586
4.80406
4.76009
4.6933
4.60269
4.48684
4.34393
4.17163
3.96701
3.72647
3.44556
3.11883
2.73962
2.29973
1.78911
1.19535
0.503192
-0.306284
-1.25647
-2.37632
-3.70157
-5.27609
-7.15337
-9.39691
10.9706
10.9709
10.971
10.9709
10.9709
10.9709
10.9708
10.9708
10.9708
10.9708
10.9708
10.9709
10.9709
10.9709
10.971
10.9709
10.9706
-9.39691
-7.15337
-5.27609
-3.70157
-2.37632
-1.25647
-0.306284
0.503192
1.19535
1.78911
2.29973
2.73962
3.11883
3.44556
3.72647
3.96701
4.17163
4.34393
4.48684
4.60269
4.6933
4.76009
4.80406
4.82586
2.46293
2.44359
2.4046
2.34532
2.26483
2.16183
2.0346
1.88094
1.69809
1.48264
1.23031
0.935858
0.592763
0.192941
-0.27368
-0.8197
-1.46096
-2.2175
-3.11476
-4.18523
-5.47046
-7.02381
-8.91488
10.9633
10.9637
10.9639
10.964
10.964
10.9639
10.9639
10.9639
10.9638
10.9638
10.9638
10.9639
10.9639
10.9639
10.964
10.964
10.9639
10.9637
10.9633
-8.91488
-7.02381
-5.47046
-4.18523
-3.11476
-2.2175
-1.46096
-0.8197
-0.27368
0.192941
0.592763
0.935858
1.23031
1.48264
1.69809
1.88094
2.0346
2.16183
2.26483
2.34532
2.4046
2.44359
2.46293
0.119664
0.103104
0.0696906
0.0188837
-0.0501494
-0.138568
-0.247905
-0.380123
-0.537706
-0.723758
-0.942153
-1.19772
-1.49649
-1.84601
-2.25583
-2.73803
-3.30805
-3.98581
-4.79716
-5.77602
-6.96707
-8.42857
-10.2313
10.9576
10.9571
10.9571
10.957
10.957
10.957
10.9569
10.9569
10.9569
10.9569
10.9569
10.9569
10.9569
10.957
10.957
10.957
10.9571
10.9571
10.9576
-10.2313
-8.42857
-6.96707
-5.77602
-4.79716
-3.98581
-3.30805
-2.73803
-2.25583
-1.84601
-1.49649
-1.19772
-0.942153
-0.723758
-0.537706
-0.380123
-0.247905
-0.138568
-0.0501494
0.0188837
0.0696906
0.103104
0.119664
-2.20675
-2.22027
-2.24755
-2.28904
-2.34545
-2.41773
-2.50717
-2.61542
-2.74459
-2.89731
-3.07687
-3.28742
-3.53418
-3.82374
-4.16448
-4.56717
-5.04574
-5.61843
-6.30944
-7.15134
-8.18904
-9.48741
10.9483
10.9498
10.9501
10.9501
10.9501
10.9501
10.95
10.95
10.9499
10.9499
10.9499
10.9499
10.9499
10.95
10.95
10.9501
10.9501
10.9501
10.9501
10.9498
10.9483
-9.48741
-8.18904
-7.15134
-6.30944
-5.61843
-5.04574
-4.56717
-4.16448
-3.82374
-3.53418
-3.28742
-3.07687
-2.89731
-2.74459
-2.61542
-2.50717
-2.41773
-2.34545
-2.28904
-2.24755
-2.22027
-2.20675
-4.51941
-4.52967
-4.55036
-4.58183
-4.62462
-4.67945
-4.74732
-4.82949
-4.92757
-5.04359
-5.18011
-5.34036
-5.52842
-5.74949
-6.01023
-6.31925
-6.68784
-7.13091
-7.66849
-8.32781
-9.1463
-10.1754
10.9434
10.9433
10.9433
10.9432
10.9432
10.9431
10.943
10.943
10.9429
10.9429
10.9429
10.9429
10.9429
10.943
10.943
10.9431
10.9432
10.9432
10.9433
10.9433
10.9434
-10.1754
-9.1463
-8.32781
-7.66849
-7.13091
-6.68784
-6.31925
-6.01023
-5.74949
-5.52842
-5.34036
-5.18011
-5.04359
-4.92757
-4.82949
-4.74732
-4.67945
-4.62462
-4.58183
-4.55036
-4.52967
-4.51941
-6.82164
-6.82846
-6.84222
-6.86313
-6.89155
-6.92795
-6.97295
-7.0274
-7.09232
-7.16905
-7.25925
-7.36505
-7.48914
-7.63495
-7.80693
-8.01084
-8.25429
-8.54742
-8.90393
-9.34263
-9.88968
-10.5824
10.9371
10.9367
10.9365
10.9364
10.9363
10.9362
10.9361
10.936
10.9359
10.9359
10.9359
10.9359
10.9359
10.936
10.9361
10.9362
10.9363
10.9364
10.9365
10.9367
10.9371
-10.5824
-9.88968
-9.34263
-8.90393
-8.54742
-8.25429
-8.01084
-7.80693
-7.63495
-7.48914
-7.36505
-7.25925
-7.16905
-7.09232
-7.0274
-6.97295
-6.92795
-6.89155
-6.86313
-6.84222
-6.82846
-6.82164
-9.11693
-9.12021
-9.1268
-9.13682
-9.15038
-9.16769
-9.18901
-9.21466
-9.24508
-9.28082
-9.32255
-9.37117
-9.42779
-9.49385
-9.5712
-9.66228
-9.77029
-9.89955
-10.0559
-10.2474
-10.4854
-10.7866
10.9301
10.9298
10.9296
10.9295
10.9293
10.9292
10.9291
10.929
10.9289
10.9289
10.9288
10.9289
10.9289
10.929
10.9291
10.9292
10.9293
10.9295
10.9296
10.9298
10.9301
-10.7866
-10.4854
-10.2474
-10.0559
-9.89955
-9.77029
-9.66228
-9.5712
-9.49385
-9.42779
-9.37117
-9.32255
-9.28082
-9.24508
-9.21466
-9.18901
-9.16769
-9.15038
-9.13682
-9.1268
-9.12021
-9.11693
-11.4089
-11.4086
-11.4079
-11.4069
-11.4054
-11.4034
-11.4007
-11.3971
-11.3924
-11.3865
-11.3789
-11.3692
-11.3569
-11.3413
-11.3215
-11.2965
-11.2647
-11.2242
-11.1722
-11.105
-11.0171
-10.8989
10.9229
10.9229
10.9227
10.9226
10.9224
10.9222
10.9221
10.9219
10.9218
10.9218
10.9218
10.9218
10.9218
10.9219
10.9221
10.9222
10.9224
10.9226
10.9227
10.9229
10.9229
-10.8989
-11.0171
-11.105
-11.1722
-11.2242
-11.2647
-11.2965
-11.3215
-11.3413
-11.3569
-11.3692
-11.3789
-11.3865
-11.3924
-11.3971
-11.4007
-11.4034
-11.4054
-11.4069
-11.4079
-11.4086
-11.4089
-13.7012
-13.6973
-13.6894
-13.6774
-13.661
-13.6397
-13.6132
-13.5806
-13.5412
-13.4938
-13.4373
-13.3698
-13.2893
-13.1929
-13.0772
-12.9376
-12.768
-12.5604
-12.3039
-11.9838
-11.5793
-11.0603
10.9158
10.916
10.9159
10.9157
10.9155
10.9152
10.915
10.9149
10.9147
10.9147
10.9147
10.9147
10.9147
10.9149
10.915
10.9152
10.9155
10.9157
10.9159
10.916
10.9158
-11.0603
-11.5793
-11.9838
-12.3039
-12.5604
-12.768
-12.9376
-13.0772
-13.1929
-13.2893
-13.3698
-13.4373
-13.4938
-13.5412
-13.5806
-13.6132
-13.6397
-13.661
-13.6774
-13.6894
-13.6973
-13.7012
-15.9974
-15.99
-15.9752
-15.9525
-15.9215
-15.8815
-15.8318
-15.771
-15.6979
-15.6106
-15.5068
-15.3837
-15.2377
-15.0642
-14.8572
-14.6092
-14.31
-13.9463
-13.5003
-12.9481
-12.2577
-11.3892
10.9095
10.9094
10.9092
10.9089
10.9085
10.9082
10.9079
10.9077
10.9076
10.9075
10.9075
10.9075
10.9076
10.9077
10.9079
10.9082
10.9085
10.9089
10.9092
10.9094
10.9095
-11.3892
-12.2577
-12.9481
-13.5003
-13.9463
-14.31
-14.6092
-14.8572
-15.0642
-15.2377
-15.3837
-15.5068
-15.6106
-15.6979
-15.771
-15.8318
-15.8815
-15.9215
-15.9525
-15.9752
-15.99
-15.9974
-18.3011
-18.2904
-18.2688
-18.2359
-18.1911
-18.1333
-18.0615
-17.9741
-17.8691
-17.744
-17.596
-17.4209
-17.2141
-16.9694
-16.679
-16.3327
-15.9174
-15.4158
-14.8047
-14.0528
-13.1166
-11.9336
10.9046
10.903
10.9026
10.9021
10.9015
10.9011
10.9008
10.9005
10.9004
10.9003
10.9003
10.9003
10.9004
10.9005
10.9008
10.9011
10.9015
10.9021
10.9026
10.903
10.9046
-11.9336
-13.1166
-14.0528
-14.8047
-15.4158
-15.9174
-16.3327
-16.679
-16.9694
-17.2141
-17.4209
-17.596
-17.744
-17.8691
-17.9741
-18.0615
-18.1333
-18.1911
-18.2359
-18.2688
-18.2904
-18.3011
-20.6157
-20.6019
-20.574
-20.5316
-20.4737
-20.3994
-20.3071
-20.1949
-20.0605
-19.9009
-19.7124
-19.4904
-19.2291
-18.9211
-18.5575
-18.1263
-17.6125
-16.9964
-16.2521
-15.3446
-14.2261
-12.829
-11.0564
10.8955
10.8961
10.8953
10.8944
10.8938
10.8935
10.8933
10.8932
10.8931
10.8931
10.8931
10.8932
10.8933
10.8935
10.8938
10.8944
10.8953
10.8961
10.8955
-11.0564
-12.829
-14.2261
-15.3446
-16.2521
-16.9964
-17.6125
-18.1263
-18.5575
-18.9211
-19.2291
-19.4904
-19.7124
-19.9009
-20.0605
-20.1949
-20.3071
-20.3994
-20.4737
-20.5316
-20.574
-20.6019
-20.6157
-22.9443
-22.9276
-22.894
-22.8428
-22.7731
-22.6837
-22.5728
-22.4383
-22.2776
-22.0872
-21.863
-21.5998
-21.2913
-20.9295
-20.5045
-20.0037
-19.4114
-18.7073
-17.8651
-16.8507
-15.6185
-14.1074
-12.2386
10.8896
10.891
10.8886
10.8871
10.8864
10.886
10.8859
10.8858
10.8858
10.8858
10.8858
10.8858
10.8859
10.886
10.8864
10.8871
10.8886
10.891
10.8896
-12.2386
-14.1074
-15.6185
-16.8507
-17.8651
-18.7073
-19.4114
-20.0037
-20.5045
-20.9295
-21.2913
-21.5998
-21.863
-22.0872
-22.2776
-22.4383
-22.5728
-22.6837
-22.7731
-22.8428
-22.894
-22.9276
-22.9443
-25.2898
-25.2706
-25.2318
-25.1728
-25.0926
-24.9898
-24.8625
-24.7085
-24.5248
-24.3078
-24.0531
-23.7553
-23.4076
-23.0021
-22.5284
-21.9742
-21.3239
-20.5583
-19.6532
-18.5781
-17.2942
-15.7492
-13.8605
-11.4599
10.8925
10.8809
10.8789
10.8785
10.8784
10.8784
10.8785
10.8785
10.8785
10.8785
10.8785
10.8784
10.8784
10.8785
10.8789
10.8809
10.8925
-11.4599
-13.8605
-15.7492
-17.2942
-18.5781
-19.6532
-20.5583
-21.3239
-21.9742
-22.5284
-23.0021
-23.4076
-23.7553
-24.0531
-24.3078
-24.5248
-24.7085
-24.8625
-24.9898
-25.0926
-25.1728
-25.2318
-25.2706
-25.2898
-27.6549
-27.6334
-27.5902
-27.5244
-27.4351
-27.3207
-27.1794
-27.0087
-26.8057
-26.5666
-26.287
-25.9613
-25.5829
-25.1438
-24.6341
-24.0422
-23.3535
-22.551
-21.6138
-20.5176
-19.2351
-17.74
-16.0248
-14.1777
-12.7916
10.8692
10.8692
10.8702
10.8707
10.871
10.8711
10.8712
10.8712
10.8712
10.8711
10.871
10.8707
10.8702
10.8692
10.8692
-12.7916
-14.1777
-16.0248
-17.74
-19.2351
-20.5176
-21.6138
-22.551
-23.3535
-24.0422
-24.6341
-25.1438
-25.5829
-25.9613
-26.287
-26.5666
-26.8057
-27.0087
-27.1794
-27.3207
-27.4351
-27.5244
-27.5902
-27.6334
-27.6549
-30.0418
-30.0184
-29.9714
-29.8999
-29.803
-29.679
-29.5261
-29.3419
-29.1233
-28.8667
-28.5676
-28.2208
-27.8198
-27.357
-26.8235
-26.2083
-25.4989
-24.6804
-23.7358
-22.6462
-21.3918
-19.9545
-18.3232
-16.4932
-14.3942
-11.271
10.8614
10.8626
10.8633
10.8636
10.8639
10.864
10.864
10.864
10.8639
10.8636
10.8633
10.8626
10.8614
-11.271
-14.3942
-16.4932
-18.3232
-19.9545
-21.3918
-22.6462
-23.7358
-24.6804
-25.4989
-26.2083
-26.8235
-27.357
-27.8198
-28.2208
-28.5676
-28.8667
-29.1233
-29.3419
-29.5261
-29.679
-29.803
-29.8999
-29.9714
-30.0184
-30.0418
-32.4524
-32.4275
-32.3774
-32.3013
-32.1982
-32.0666
-31.9047
-31.7099
-31.4795
-31.2099
-30.8968
-30.5353
-30.1194
-29.6423
-29.0957
-28.4702
-27.755
-26.9379
-26.0052
-24.9423
-23.7342
-22.3662
-20.8232
-19.0821
-17.0842
-14.7051
-12.2743
10.8553
10.8563
10.8563
10.8567
10.8569
10.8569
10.8569
10.8567
10.8563
10.8563
10.8553
-12.2743
-14.7051
-17.0842
-19.0821
-20.8232
-22.3662
-23.7342
-24.9423
-26.0052
-26.9379
-27.755
-28.4702
-29.0957
-29.6423
-30.1194
-30.5353
-30.8968
-31.2099
-31.4795
-31.7099
-31.9047
-32.0666
-32.1982
-32.3013
-32.3774
-32.4275
-32.4524
-34.8883
-34.8623
-34.8098
-34.7302
-34.6225
-34.4852
-34.3165
-34.1142
-33.8755
-33.5971
-33.2752
-32.905
-32.4814
-31.998
-31.448
-30.8232
-30.1147
-29.3128
-28.4068
-27.3859
-26.239
-24.9555
-23.5243
-21.932
-20.1611
-18.2102
-16.1917
-14.1688
-12.2613
10.8488
10.8496
10.8499
10.8499
10.8499
10.8496
10.8488
-12.2613
-14.1688
-16.1917
-18.2102
-20.1611
-21.932
-23.5243
-24.9555
-26.239
-27.3859
-28.4068
-29.3128
-30.1147
-30.8232
-31.448
-31.998
-32.4814
-32.905
-33.2752
-33.5971
-33.8755
-34.1142
-34.3165
-34.4852
-34.6225
-34.7302
-34.8098
-34.8623
-34.8883
-37.3507
-37.3238
-37.2697
-37.1876
-37.0767
-36.9355
-36.7625
-36.5554
-36.3118
-36.0287
-35.7025
-35.3291
-34.9039
-34.4215
-33.8761
-33.2611
-32.5694
-31.7933
-30.9251
-29.9573
-28.8826
-27.6948
-26.3891
-24.9632
-23.4208
-21.7841
-20.114
-18.476
-16.9543
-15.6374
-14.6289
-13.995
-13.7887
-13.995
-14.6289
-15.6374
-16.9543
-18.476
-20.114
-21.7841
-23.4208
-24.9632
-26.3891
-27.6948
-28.8826
-29.9573
-30.9251
-31.7933
-32.5694
-33.2611
-33.8761
-34.4215
-34.9039
-35.3291
-35.7025
-36.0287
-36.3118
-36.5554
-36.7625
-36.9355
-37.0767
-37.1876
-37.2697
-37.3238
-37.3507
-39.8405
-39.8131
-39.7579
-39.6744
-39.5616
-39.4183
-39.243
-39.0338
-38.7883
-38.504
-38.1776
-37.8058
-37.3844
-36.9091
-36.375
-35.777
-35.1096
-34.3673
-33.5448
-32.6372
-31.6409
-30.5537
-29.3761
-28.1128
-26.7762
-25.3918
-24.0035
-22.6651
-21.4396
-20.3944
-19.5966
-19.097
-18.9288
-19.097
-19.5966
-20.3944
-21.4396
-22.6651
-24.0035
-25.3918
-26.7762
-28.1128
-29.3761
-30.5537
-31.6409
-32.6372
-33.5448
-34.3673
-35.1096
-35.777
-36.375
-36.9091
-37.3844
-37.8058
-38.1776
-38.504
-38.7883
-39.0338
-39.243
-39.4183
-39.5616
-39.6744
-39.7579
-39.8131
-39.8405
-42.3582
-42.3306
-42.275
-42.1909
-42.0775
-41.9336
-41.758
-41.5489
-41.3043
-41.0219
-40.6991
-40.3327
-39.9197
-39.4563
-38.9389
-38.3634
-37.7259
-37.0228
-36.2507
-35.4074
-34.4916
-33.5045
-32.4501
-31.3369
-30.18
-29.0036
-27.8426
-26.7393
-25.7419
-24.9003
-24.2615
-23.8626
-23.7274
-23.8626
-24.2615
-24.9003
-25.7419
-26.7393
-27.8426
-29.0036
-30.18
-31.3369
-32.4501
-33.5045
-34.4916
-35.4074
-36.2507
-37.0228
-37.7259
-38.3634
-38.9389
-39.4563
-39.9197
-40.3327
-40.6991
-41.0219
-41.3043
-41.5489
-41.758
-41.9336
-42.0775
-42.1909
-42.275
-42.3306
-42.3582
-44.904
-44.8764
-44.8209
-44.7371
-44.6242
-44.4812
-44.307
-44.1001
-43.8587
-43.581
-43.2646
-42.9072
-42.5061
-42.0585
-41.5616
-41.0127
-40.4089
-39.7483
-39.0291
-38.251
-37.4148
-36.5237
-35.5839
-34.6054
-33.6035
-32.5999
-31.6229
-30.7061
-29.8861
-29.2002
-28.6826
-28.3605
-28.2512
-28.3605
-28.6826
-29.2002
-29.8861
-30.7061
-31.6229
-32.5999
-33.6035
-34.6054
-35.5839
-36.5237
-37.4148
-38.251
-39.0291
-39.7483
-40.4089
-41.0127
-41.5616
-42.0585
-42.5061
-42.9072
-43.2646
-43.581
-43.8587
-44.1001
-44.307
-44.4812
-44.6242
-44.7371
-44.8209
-44.8764
-44.904
-47.4779
-47.4506
-47.3957
-47.3129
-47.2014
-47.0606
-46.8893
-46.6862
-46.4501
-46.1792
-45.8718
-45.5259
-45.1396
-44.7107
-44.2373
-43.7175
-43.1498
-42.5332
-41.8674
-41.1535
-40.3936
-39.5925
-38.757
-37.8976
-37.0287
-36.1692
-35.3423
-34.5744
-33.894
-33.3292
-32.9052
-32.6422
-32.5531
-32.6422
-32.9052
-33.3292
-33.894
-34.5744
-35.3423
-36.1692
-37.0287
-37.8976
-38.757
-39.5925
-40.3936
-41.1535
-41.8674
-42.5332
-43.1498
-43.7175
-44.2373
-44.7107
-45.1396
-45.5259
-45.8718
-46.1792
-46.4501
-46.6862
-46.8893
-47.0606
-47.2014
-47.3129
-47.3957
-47.4506
-47.4779
-50.0796
-50.0528
-49.9989
-49.9177
-49.8086
-49.6709
-49.5037
-49.306
-49.0768
-48.8146
-48.5181
-48.1858
-47.8164
-47.4082
-46.9601
-46.471
-45.9403
-45.368
-44.7548
-44.1025
-43.4146
-42.696
-41.9543
-41.1994
-40.4444
-39.7054
-39.0016
-38.354
-37.7846
-37.3151
-36.9643
-36.7474
-36.674
-36.7474
-36.9643
-37.3151
-37.7846
-38.354
-39.0016
-39.7054
-40.4444
-41.1994
-41.9543
-42.696
-43.4146
-44.1025
-44.7548
-45.368
-45.9403
-46.471
-46.9601
-47.4082
-47.8164
-48.1858
-48.5181
-48.8146
-49.0768
-49.306
-49.5037
-49.6709
-49.8086
-49.9177
-49.9989
-50.0528
-50.0796
-52.7085
-52.6824
-52.6299
-52.5508
-52.4447
-52.311
-52.149
-51.9579
-51.7369
-51.4848
-51.2007
-50.8836
-50.5324
-50.1463
-49.7245
-49.2668
-48.7732
-48.2443
-47.6817
-47.0878
-46.4665
-45.8232
-45.165
-44.5013
-43.8437
-43.206
-42.6038
-42.054
-41.574
-41.1803
-40.8874
-40.7069
-40.6459
-40.7069
-40.8874
-41.1803
-41.574
-42.054
-42.6038
-43.206
-43.8437
-44.5013
-45.165
-45.8232
-46.4665
-47.0878
-47.6817
-48.2443
-48.7732
-49.2668
-49.7245
-50.1463
-50.5324
-50.8836
-51.2007
-51.4848
-51.7369
-51.9579
-52.149
-52.311
-52.4447
-52.5508
-52.6299
-52.6824
-52.7085
-55.364
-55.3387
-55.2879
-55.2115
-55.1089
-54.98
-54.8239
-54.6403
-54.4284
-54.1875
-53.9169
-53.6158
-53.2838
-52.9205
-52.5255
-52.0991
-51.6418
-51.1549
-50.6404
-50.101
-49.5409
-48.9653
-48.3812
-47.7971
-47.2229
-46.6705
-46.1527
-45.6832
-45.2757
-44.943
-44.6965
-44.545
-44.4938
-44.545
-44.6965
-44.943
-45.2757
-45.6832
-46.1527
-46.6705
-47.2229
-47.7971
-48.3812
-48.9653
-49.5409
-50.101
-50.6404
-51.1549
-51.6418
-52.0991
-52.5255
-52.9205
-53.2838
-53.6158
-53.9169
-54.1875
-54.4284
-54.6403
-54.8239
-54.98
-55.1089
-55.2115
-55.2879
-55.3387
-55.364
-58.0453
-58.0209
-57.9721
-57.8985
-57.8
-57.6763
-57.5269
-57.3514
-57.1494
-56.9204
-56.6639
-56.3796
-56.0672
-55.7268
-55.3584
-54.9627
-54.5406
-54.0937
-53.6242
-53.1353
-52.6309
-52.1162
-51.5976
-51.0826
-50.5801
-50.0999
-49.6526
-49.2494
-48.9013
-48.6183
-48.4093
-48.281
-48.2378
-48.281
-48.4093
-48.6183
-48.9013
-49.2494
-49.6526
-50.0999
-50.5801
-51.0826
-51.5976
-52.1162
-52.6309
-53.1353
-53.6242
-54.0937
-54.5406
-54.9627
-55.3584
-55.7268
-56.0672
-56.3796
-56.6639
-56.9204
-57.1494
-57.3514
-57.5269
-57.6763
-57.8
-57.8985
-57.9721
-58.0209
-58.0453
-60.7514
-60.728
-60.6813
-60.6109
-60.5168
-60.3987
-60.2564
-60.0895
-59.8978
-59.6811
-59.4391
-59.1718
-58.8791
-58.5614
-58.2191
-57.853
-57.4645
-57.0553
-56.6278
-56.1852
-55.7313
-55.2711
-54.8103
-54.3556
-53.9146
-53.4957
-53.1078
-52.7598
-52.4607
-52.2185
-52.0401
-51.9308
-51.894
-51.9308
-52.0401
-52.2185
-52.4607
-52.7598
-53.1078
-53.4957
-53.9146
-54.3556
-54.8103
-55.2711
-55.7313
-56.1852
-56.6278
-57.0553
-57.4645
-57.853
-58.2191
-58.5614
-58.8791
-59.1718
-59.4391
-59.6811
-59.8978
-60.0895
-60.2564
-60.3987
-60.5168
-60.6109
-60.6813
-60.728
-60.7514
-63.4812
-63.459
-63.4144
-63.3474
-63.2579
-63.1457
-63.0107
-62.8528
-62.6717
-62.4675
-62.2402
-61.9897
-61.7165
-61.421
-61.1039
-60.7662
-60.4094
-60.0355
-59.6468
-59.2465
-58.8383
-58.4266
-58.0167
-57.6146
-57.2267
-56.8601
-56.5223
-56.2207
-55.9623
-55.7538
-55.6006
-55.5069
-55.4754
-55.5069
-55.6006
-55.7538
-55.9623
-56.2207
-56.5223
-56.8601
-57.2267
-57.6146
-58.0167
-58.4266
-58.8383
-59.2465
-59.6468
-60.0355
-60.4094
-60.7662
-61.1039
-61.421
-61.7165
-61.9897
-62.2402
-62.4675
-62.6717
-62.8528
-63.0107
-63.1457
-63.2579
-63.3474
-63.4144
-63.459
-63.4812
-66.2337
-66.2126
-66.1703
-66.1068
-66.022
-65.9159
-65.7884
-65.6395
-65.4691
-65.2775
-65.0646
-64.8308
-64.5766
-64.3025
-64.0095
-63.6987
-63.3718
-63.0306
-62.6777
-62.3158
-61.9487
-61.5803
-61.2154
-60.859
-60.517
-60.1953
-59.9001
-59.6375
-59.4134
-59.233
-59.1007
-59.0199
-58.9928
-59.0199
-59.1007
-59.233
-59.4134
-59.6375
-59.9001
-60.1953
-60.517
-60.859
-61.2154
-61.5803
-61.9487
-62.3158
-62.6777
-63.0306
-63.3718
-63.6987
-64.0095
-64.3025
-64.5766
-64.8308
-65.0646
-65.2775
-65.4691
-65.6395
-65.7884
-65.9159
-66.022
-66.1068
-66.1703
-66.2126
-66.2337
-69.0076
-68.9877
-68.9477
-68.8877
-68.8078
-68.7078
-68.5878
-68.4479
-68.2882
-68.1089
-67.9103
-67.6927
-67.4568
-67.2033
-66.9332
-66.6478
-66.3486
-66.0377
-65.7175
-65.3906
-65.0604
-64.7305
-64.4052
-64.089
-63.7868
-63.5037
-63.2448
-63.0153
-62.8201
-62.6632
-62.5485
-62.4785
-62.455
-62.4785
-62.5485
-62.6632
-62.8201
-63.0153
-63.2448
-63.5037
-63.7868
-64.089
-64.4052
-64.7305
-65.0604
-65.3906
-65.7175
-66.0377
-66.3486
-66.6478
-66.9332
-67.2033
-67.4568
-67.6927
-67.9103
-68.1089
-68.2882
-68.4479
-68.5878
-68.7078
-68.8078
-68.8877
-68.9477
-68.9877
-69.0076
-71.8019
-71.7831
-71.7455
-71.689
-71.6139
-71.52
-71.4075
-71.2765
-71.1273
-70.96
-70.7752
-70.5732
-70.3548
-70.1209
-69.8724
-69.6107
-69.3374
-69.0544
-68.764
-68.4688
-68.1717
-67.8762
-67.5859
-67.3048
-67.0371
-66.7873
-66.5597
-66.3584
-66.1876
-66.0508
-65.9508
-65.8899
-65.8694
-65.8899
-65.9508
-66.0508
-66.1876
-66.3584
-66.5597
-66.7873
-67.0371
-67.3048
-67.5859
-67.8762
-68.1717
-68.4688
-68.764
-69.0544
-69.3374
-69.6107
-69.8724
-70.1209
-70.3548
-70.5732
-70.7752
-70.96
-71.1273
-71.2765
-71.4075
-71.52
-71.6139
-71.689
-71.7455
-71.7831
-71.8019
-74.6152
-74.5976
-74.5623
-74.5094
-74.439
-74.3511
-74.2459
-74.1236
-73.9845
-73.829
-73.6574
-73.4704
-73.2687
-73.0532
-72.825
-72.5854
-72.336
-72.0786
-71.8154
-71.5488
-71.2815
-71.0165
-70.7571
-70.5069
-70.2694
-70.0484
-69.8477
-69.6707
-69.5208
-69.4009
-69.3134
-69.2602
-69.2423
-69.2602
-69.3134
-69.4009
-69.5208
-69.6707
-69.8477
-70.0484
-70.2694
-70.5069
-70.7571
-71.0165
-71.2815
-71.5488
-71.8154
-72.0786
-72.336
-72.5854
-72.825
-73.0532
-73.2687
-73.4704
-73.6574
-73.829
-73.9845
-74.1236
-74.2459
-74.3511
-74.439
-74.5094
-74.5623
-74.5976
-74.6152
-77.4466
-77.4301
-77.397
-77.3476
-77.2818
-77.1997
-77.1017
-76.9879
-76.8586
-76.7142
-76.5554
-76.3826
-76.1966
-75.9985
-75.7892
-75.5701
-75.3427
-75.1088
-74.8703
-74.6295
-74.3888
-74.1511
-73.9191
-73.696
-73.4849
-73.289
-73.1115
-72.9554
-72.8234
-72.718
-72.6413
-72.5946
-72.5789
-72.5946
-72.6413
-72.718
-72.8234
-72.9554
-73.1115
-73.289
-73.4849
-73.696
-73.9191
-74.1511
-74.3888
-74.6295
-74.8703
-75.1088
-75.3427
-75.5701
-75.7892
-75.9985
-76.1966
-76.3826
-76.5554
-76.7142
-76.8586
-76.9879
-77.1017
-77.1997
-77.2818
-77.3476
-77.397
-77.4301
-77.4466
-80.2947
-80.2793
-80.2485
-80.2023
-80.141
-80.0647
-79.9735
-79.8678
-79.7479
-79.6142
-79.4674
-79.3081
-79.1369
-78.955
-78.7633
-78.5632
-78.356
-78.1435
-77.9275
-77.71
-77.4933
-77.2798
-77.0721
-76.8729
-76.685
-76.511
-76.3536
-76.2156
-76.0991
-76.0062
-75.9385
-75.8975
-75.8837
-75.8975
-75.9385
-76.0062
-76.0991
-76.2156
-76.3536
-76.511
-76.685
-76.8729
-77.0721
-77.2798
-77.4933
-77.71
-77.9275
-78.1435
-78.356
-78.5632
-78.7633
-78.955
-79.1369
-79.3081
-79.4674
-79.6142
-79.7479
-79.8678
-79.9735
-80.0647
-80.141
-80.2023
-80.2485
-80.2793
-80.2947
-83.1585
-83.1441
-83.1155
-83.0726
-83.0156
-82.9446
-82.86
-82.7621
-82.6511
-82.5276
-82.3922
-82.2455
-82.0882
-81.9214
-81.7461
-81.5634
-81.3748
-81.1819
-80.9862
-80.7897
-80.5945
-80.4027
-80.2166
-80.0385
-79.8708
-79.716
-79.5763
-79.4538
-79.3507
-79.2686
-79.2089
-79.1726
-79.1605
-79.1726
-79.2089
-79.2686
-79.3507
-79.4538
-79.5763
-79.716
-79.8708
-80.0385
-80.2166
-80.4027
-80.5945
-80.7897
-80.9862
-81.1819
-81.3748
-81.5634
-81.7461
-81.9214
-82.0882
-82.2455
-82.3922
-82.5276
-82.6511
-82.7621
-82.86
-82.9446
-83.0156
-83.0726
-83.1155
-83.1441
-83.1585
-86.0368
-86.0235
-85.9969
-85.9571
-85.9042
-85.8385
-85.7602
-85.6696
-85.5671
-85.4532
-85.3285
-85.1936
-85.0493
-84.8965
-84.7363
-84.5697
-84.3981
-84.2229
-84.0457
-83.8682
-83.6923
-83.5198
-83.3528
-83.1934
-83.0436
-82.9056
-82.7813
-82.6725
-82.581
-82.5083
-82.4554
-82.4233
-82.4126
-82.4233
-82.4554
-82.5083
-82.581
-82.6725
-82.7813
-82.9056
-83.0436
-83.1934
-83.3528
-83.5198
-83.6923
-83.8682
-84.0457
-84.2229
-84.3981
-84.5697
-84.7363
-84.8965
-85.0493
-85.1936
-85.3285
-85.4532
-85.5671
-85.6696
-85.7602
-85.8385
-85.9042
-85.9571
-85.9969
-86.0235
-86.0368
-88.9288
-88.9164
-88.8918
-88.8549
-88.806
-88.7452
-88.6728
-88.5891
-88.4946
-88.3898
-88.2751
-88.1512
-88.019
-87.8792
-87.7328
-87.581
-87.425
-87.266
-87.1055
-86.9451
-86.7865
-86.6313
-86.4813
-86.3385
-86.2046
-86.0813
-85.9705
-85.8737
-85.7924
-85.7277
-85.6808
-85.6524
-85.6428
-85.6524
-85.6808
-85.7277
-85.7924
-85.8737
-85.9705
-86.0813
-86.2046
-86.3385
-86.4813
-86.6313
-86.7865
-86.9451
-87.1055
-87.266
-87.425
-87.581
-87.7328
-87.8792
-88.019
-88.1512
-88.2751
-88.3898
-88.4946
-88.5891
-88.6728
-88.7452
-88.806
-88.8549
-88.8918
-88.9164
-88.9288
-91.8333
-91.8218
-91.799
-91.765
-91.7197
-91.6636
-91.5968
-91.5197
-91.4327
-91.3363
-91.2309
-91.1174
-90.9963
-90.8685
-90.735
-90.5967
-90.4548
-90.3106
-90.1653
-90.0203
-89.8772
-89.7374
-89.6027
-89.4746
-89.3546
-89.2444
-89.1455
-89.0592
-88.9867
-88.9292
-88.8875
-88.8622
-88.8537
-88.8622
-88.8875
-88.9292
-88.9867
-89.0592
-89.1455
-89.2444
-89.3546
-89.4746
-89.6027
-89.7374
-89.8772
-90.0203
-90.1653
-90.3106
-90.4548
-90.5967
-90.735
-90.8685
-90.9963
-91.1174
-91.2309
-91.3363
-91.4327
-91.5197
-91.5968
-91.6636
-91.7197
-91.765
-91.799
-91.8218
-91.8333
-94.7493
-94.7388
-94.7178
-94.6863
-94.6446
-94.5929
-94.5313
-94.4604
-94.3804
-94.2918
-94.1952
-94.0912
-93.9804
-93.8637
-93.7419
-93.6161
-93.4871
-93.3562
-93.2246
-93.0936
-92.9644
-92.8385
-92.7174
-92.6023
-92.4948
-92.3961
-92.3077
-92.2306
-92.1659
-92.1146
-92.0775
-92.0549
-92.0474
-92.0549
-92.0775
-92.1146
-92.1659
-92.2306
-92.3077
-92.3961
-92.4948
-92.6023
-92.7174
-92.8385
-92.9644
-93.0936
-93.2246
-93.3562
-93.4871
-93.6161
-93.7419
-93.8637
-93.9804
-94.0912
-94.1952
-94.2918
-94.3804
-94.4604
-94.5313
-94.5929
-94.6446
-94.6863
-94.7178
-94.7388
-94.7493
-97.6762
-97.6665
-97.6471
-97.6181
-97.5797
-97.532
-97.4755
-97.4102
-97.3368
-97.2555
-97.167
-97.0718
-96.9706
-96.8641
-96.7531
-96.6385
-96.5214
-96.4026
-96.2834
-96.1649
-96.0483
-95.9349
-95.8258
-95.7224
-95.6259
-95.5375
-95.4583
-95.3893
-95.3315
-95.2857
-95.2526
-95.2325
-95.2257
-95.2325
-95.2526
-95.2857
-95.3315
-95.3893
-95.4583
-95.5375
-95.6259
-95.7224
-95.8258
-95.9349
-96.0483
-96.1649
-96.2834
-96.4026
-96.5214
-96.6385
-96.7531
-96.8641
-96.9706
-97.0718
-97.167
-97.2555
-97.3368
-97.4102
-97.4755
-97.532
-97.5797
-97.6181
-97.6471
-97.6665
-97.6762
-100.613
-100.604
-100.586
-100.559
-100.524
-100.48
-100.428
-100.368
-100.301
-100.227
-100.146
-100.059
-99.9661
-99.8689
-99.7678
-99.6636
-99.5572
-99.4495
-99.3415
-99.2344
-99.1291
-99.0267
-98.9285
-98.8355
-98.7488
-98.6694
-98.5984
-98.5367
-98.485
-98.444
-98.4144
-98.3964
-98.3904
-98.3964
-98.4144
-98.444
-98.485
-98.5367
-98.5984
-98.6694
-98.7488
-98.8355
-98.9285
-99.0267
-99.1291
-99.2344
-99.3415
-99.4495
-99.5572
-99.6636
-99.7678
-99.8689
-99.9661
-100.059
-100.146
-100.227
-100.301
-100.368
-100.428
-100.48
-100.524
-100.559
-100.586
-100.604
-100.613
-103.559
-103.55
-103.534
-103.51
-103.477
-103.437
-103.389
-103.334
-103.273
-103.204
-103.13
-103.051
-102.966
-102.878
-102.786
-102.691
-102.594
-102.497
-102.399
-102.302
-102.207
-102.114
-102.026
-101.942
-101.864
-101.793
-101.729
-101.674
-101.628
-101.591
-101.564
-101.548
-101.543
-101.548
-101.564
-101.591
-101.628
-101.674
-101.729
-101.793
-101.864
-101.942
-102.026
-102.114
-102.207
-102.302
-102.399
-102.497
-102.594
-102.691
-102.786
-102.878
-102.966
-103.051
-103.13
-103.204
-103.273
-103.334
-103.389
-103.437
-103.477
-103.51
-103.534
-103.55
-103.559
-106.513
-106.505
-106.49
-106.468
-106.438
-106.401
-106.357
-106.307
-106.251
-106.188
-106.12
-106.048
-105.971
-105.89
-105.806
-105.72
-105.633
-105.544
-105.455
-105.368
-105.282
-105.198
-105.118
-105.043
-104.973
-104.909
-104.852
-104.802
-104.76
-104.727
-104.704
-104.689
-104.684
-104.689
-104.704
-104.727
-104.76
-104.802
-104.852
-104.909
-104.973
-105.043
-105.118
-105.198
-105.282
-105.368
-105.455
-105.544
-105.633
-105.72
-105.806
-105.89
-105.971
-106.048
-106.12
-106.188
-106.251
-106.307
-106.357
-106.401
-106.438
-106.468
-106.49
-106.505
-106.513
-109.475
-109.468
-109.454
-109.433
-109.406
-109.372
-109.332
-109.286
-109.235
-109.178
-109.116
-109.049
-108.979
-108.906
-108.83
-108.751
-108.672
-108.591
-108.511
-108.432
-108.354
-108.279
-108.206
-108.139
-108.075
-108.018
-107.966
-107.922
-107.884
-107.855
-107.833
-107.82
-107.816
-107.82
-107.833
-107.855
-107.884
-107.922
-107.966
-108.018
-108.075
-108.139
-108.206
-108.279
-108.354
-108.432
-108.511
-108.591
-108.672
-108.751
-108.83
-108.906
-108.979
-109.049
-109.116
-109.178
-109.235
-109.286
-109.332
-109.372
-109.406
-109.433
-109.454
-109.468
-109.475
-112.444
-112.437
-112.425
-112.406
-112.381
-112.35
-112.313
-112.271
-112.224
-112.172
-112.115
-112.055
-111.991
-111.924
-111.855
-111.784
-111.711
-111.638
-111.566
-111.494
-111.423
-111.355
-111.29
-111.229
-111.172
-111.12
-111.074
-111.034
-111
-110.974
-110.955
-110.943
-110.939
-110.943
-110.955
-110.974
-111
-111.034
-111.074
-111.12
-111.172
-111.229
-111.29
-111.355
-111.423
-111.494
-111.566
-111.638
-111.711
-111.784
-111.855
-111.924
-111.991
-112.055
-112.115
-112.172
-112.224
-112.271
-112.313
-112.35
-112.381
-112.406
-112.425
-112.437
-112.444
-115.419
-115.413
-115.402
-115.384
-115.361
-115.333
-115.3
-115.261
-115.218
-115.171
-115.119
-115.064
-115.006
-114.945
-114.882
-114.817
-114.751
-114.685
-114.619
-114.554
-114.491
-114.429
-114.371
-114.315
-114.264
-114.217
-114.175
-114.139
-114.109
-114.085
-114.068
-114.058
-114.054
-114.058
-114.068
-114.085
-114.109
-114.139
-114.175
-114.217
-114.264
-114.315
-114.371
-114.429
-114.491
-114.554
-114.619
-114.685
-114.751
-114.817
-114.882
-114.945
-115.006
-115.064
-115.119
-115.171
-115.218
-115.261
-115.3
-115.333
-115.361
-115.384
-115.402
-115.413
-115.419
-118.4
-118.395
-118.384
-118.369
-118.348
-118.322
-118.291
-118.256
-118.217
-118.173
-118.126
-118.076
-118.023
-117.968
-117.91
-117.852
-117.792
-117.732
-117.672
-117.614
-117.556
-117.5
-117.447
-117.397
-117.351
-117.309
-117.271
-117.239
-117.212
-117.19
-117.175
-117.165
-117.162
-117.165
-117.175
-117.19
-117.212
-117.239
-117.271
-117.309
-117.351
-117.397
-117.447
-117.5
-117.556
-117.614
-117.672
-117.732
-117.792
-117.852
-117.91
-117.968
-118.023
-118.076
-118.126
-118.173
-118.217
-118.256
-118.291
-118.322
-118.348
-118.369
-118.384
-118.395
-118.4
-121.387
-121.382
-121.372
-121.358
-121.339
-121.315
-121.287
-121.255
-121.219
-121.18
-121.137
-121.091
-121.043
-120.993
-120.941
-120.887
-120.833
-120.779
-120.725
-120.671
-120.619
-120.569
-120.521
-120.476
-120.434
-120.396
-120.362
-120.333
-120.308
-120.289
-120.275
-120.267
-120.264
-120.267
-120.275
-120.289
-120.308
-120.333
-120.362
-120.396
-120.434
-120.476
-120.521
-120.569
-120.619
-120.671
-120.725
-120.779
-120.833
-120.887
-120.941
-120.993
-121.043
-121.091
-121.137
-121.18
-121.219
-121.255
-121.287
-121.315
-121.339
-121.358
-121.372
-121.382
-121.387
-124.379
-124.374
-124.365
-124.352
-124.335
-124.313
-124.288
-124.258
-124.226
-124.19
-124.151
-124.109
-124.065
-124.019
-123.972
-123.923
-123.874
-123.825
-123.776
-123.728
-123.681
-123.635
-123.592
-123.551
-123.513
-123.479
-123.448
-123.422
-123.4
-123.382
-123.37
-123.362
-123.36
-123.362
-123.37
-123.382
-123.4
-123.422
-123.448
-123.479
-123.513
-123.551
-123.592
-123.635
-123.681
-123.728
-123.776
-123.825
-123.874
-123.923
-123.972
-124.019
-124.065
-124.109
-124.151
-124.19
-124.226
-124.258
-124.288
-124.313
-124.335
-124.352
-124.365
-124.374
-124.379
-127.375
-127.371
-127.363
-127.35
-127.335
-127.315
-127.292
-127.265
-127.235
-127.202
-127.167
-127.129
-127.089
-127.047
-127.004
-126.96
-126.916
-126.871
-126.827
-126.783
-126.74
-126.699
-126.66
-126.623
-126.589
-126.558
-126.53
-126.506
-126.487
-126.471
-126.459
-126.453
-126.45
-126.453
-126.459
-126.471
-126.487
-126.506
-126.53
-126.558
-126.589
-126.623
-126.66
-126.699
-126.74
-126.783
-126.827
-126.871
-126.916
-126.96
-127.004
-127.047
-127.089
-127.129
-127.167
-127.202
-127.235
-127.265
-127.292
-127.315
-127.335
-127.35
-127.363
-127.371
-127.375
-130.375
-130.371
-130.364
-130.353
-130.338
-130.32
-130.299
-130.275
-130.248
-130.218
-130.186
-130.151
-130.115
-130.077
-130.038
-129.998
-129.957
-129.917
-129.877
-129.837
-129.798
-129.761
-129.726
-129.692
-129.661
-129.633
-129.609
-129.587
-129.569
-129.555
-129.545
-129.538
-129.536
-129.538
-129.545
-129.555
-129.569
-129.587
-129.609
-129.633
-129.661
-129.692
-129.726
-129.761
-129.798
-129.837
-129.877
-129.917
-129.957
-129.998
-130.038
-130.077
-130.115
-130.151
-130.186
-130.218
-130.248
-130.275
-130.299
-130.32
-130.338
-130.353
-130.364
-130.371
-130.375
-133.379
-133.376
-133.369
-133.359
-133.346
-133.329
-133.31
-133.288
-133.263
-133.236
-133.206
-133.175
-133.142
-133.108
-133.072
-133.036
-132.999
-132.962
-132.926
-132.89
-132.855
-132.821
-132.789
-132.759
-132.731
-132.706
-132.683
-132.664
-132.648
-132.635
-132.626
-132.62
-132.618
-132.62
-132.626
-132.635
-132.648
-132.664
-132.683
-132.706
-132.731
-132.759
-132.789
-132.821
-132.855
-132.89
-132.926
-132.962
-132.999
-133.036
-133.072
-133.108
-133.142
-133.175
-133.206
-133.236
-133.263
-133.288
-133.31
-133.329
-133.346
-133.359
-133.369
-133.376
-133.379
-136.386
-136.383
-136.377
-136.368
-136.356
-136.341
-136.324
-136.303
-136.281
-136.256
-136.229
-136.201
-136.171
-136.14
-136.107
-136.074
-136.041
-136.008
-135.975
-135.942
-135.91
-135.88
-135.851
-135.824
-135.798
-135.775
-135.755
-135.737
-135.723
-135.711
-135.703
-135.698
-135.696
-135.698
-135.703
-135.711
-135.723
-135.737
-135.755
-135.775
-135.798
-135.824
-135.851
-135.88
-135.91
-135.942
-135.975
-136.008
-136.041
-136.074
-136.107
-136.14
-136.171
-136.201
-136.229
-136.256
-136.281
-136.303
-136.324
-136.341
-136.356
-136.368
-136.377
-136.383
-136.386
-139.397
-139.394
-139.389
-139.38
-139.369
-139.356
-139.34
-139.321
-139.301
-139.278
-139.254
-139.228
-139.201
-139.172
-139.143
-139.113
-139.083
-139.053
-139.023
-138.993
-138.964
-138.937
-138.911
-138.886
-138.863
-138.842
-138.824
-138.808
-138.795
-138.784
-138.777
-138.772
-138.771
-138.772
-138.777
-138.784
-138.795
-138.808
-138.824
-138.842
-138.863
-138.886
-138.911
-138.937
-138.964
-138.993
-139.023
-139.053
-139.083
-139.113
-139.143
-139.172
-139.201
-139.228
-139.254
-139.278
-139.301
-139.321
-139.34
-139.356
-139.369
-139.38
-139.389
-139.394
-139.397
-142.41
-142.408
-142.403
-142.395
-142.385
-142.373
-142.358
-142.342
-142.323
-142.302
-142.28
-142.257
-142.232
-142.206
-142.18
-142.152
-142.125
-142.098
-142.07
-142.044
-142.018
-141.993
-141.969
-141.946
-141.926
-141.907
-141.89
-141.876
-141.864
-141.855
-141.848
-141.844
-141.842
-141.844
-141.848
-141.855
-141.864
-141.876
-141.89
-141.907
-141.926
-141.946
-141.969
-141.993
-142.018
-142.044
-142.07
-142.098
-142.125
-142.152
-142.18
-142.206
-142.232
-142.257
-142.28
-142.302
-142.323
-142.342
-142.358
-142.373
-142.385
-142.395
-142.403
-142.408
-142.41
-145.426
-145.424
-145.419
-145.413
-145.403
-145.392
-145.379
-145.364
-145.347
-145.328
-145.308
-145.287
-145.264
-145.241
-145.217
-145.192
-145.167
-145.142
-145.117
-145.093
-145.07
-145.047
-145.025
-145.005
-144.986
-144.97
-144.954
-144.941
-144.931
-144.922
-144.916
-144.912
-144.911
-144.912
-144.916
-144.922
-144.931
-144.941
-144.954
-144.97
-144.986
-145.005
-145.025
-145.047
-145.07
-145.093
-145.117
-145.142
-145.167
-145.192
-145.217
-145.241
-145.264
-145.287
-145.308
-145.328
-145.347
-145.364
-145.379
-145.392
-145.403
-145.413
-145.419
-145.424
-145.426
-148.445
-148.443
-148.438
-148.432
-148.424
-148.414
-148.402
-148.388
-148.372
-148.355
-148.337
-148.318
-148.297
-148.276
-148.254
-148.232
-148.209
-148.186
-148.164
-148.142
-148.121
-148.1
-148.081
-148.062
-148.045
-148.03
-148.016
-148.005
-147.995
-147.987
-147.982
-147.978
-147.977
-147.978
-147.982
-147.987
-147.995
-148.005
-148.016
-148.03
-148.045
-148.062
-148.081
-148.1
-148.121
-148.142
-148.164
-148.186
-148.209
-148.232
-148.254
-148.276
-148.297
-148.318
-148.337
-148.355
-148.372
-148.388
-148.402
-148.414
-148.424
-148.432
-148.438
-148.443
-148.445
-151.465
-151.463
-151.459
-151.454
-151.446
-151.437
-151.426
-151.413
-151.399
-151.384
-151.367
-151.35
-151.331
-151.312
-151.292
-151.272
-151.251
-151.231
-151.21
-151.19
-151.171
-151.152
-151.135
-151.118
-151.103
-151.089
-151.077
-151.066
-151.057
-151.05
-151.045
-151.042
-151.041
-151.042
-151.045
-151.05
-151.057
-151.066
-151.077
-151.089
-151.103
-151.118
-151.135
-151.152
-151.171
-151.19
-151.21
-151.231
-151.251
-151.272
-151.292
-151.312
-151.331
-151.35
-151.367
-151.384
-151.399
-151.413
-151.426
-151.437
-151.446
-151.454
-151.459
-151.463
-151.465
-154.488
-154.486
-154.482
-154.477
-154.47
-154.462
-154.452
-154.441
-154.428
-154.414
-154.399
-154.383
-154.366
-154.348
-154.33
-154.312
-154.293
-154.275
-154.256
-154.238
-154.221
-154.204
-154.188
-154.173
-154.159
-154.146
-154.135
-154.125
-154.117
-154.111
-154.106
-154.104
-154.103
-154.104
-154.106
-154.111
-154.117
-154.125
-154.135
-154.146
-154.159
-154.173
-154.188
-154.204
-154.221
-154.238
-154.256
-154.275
-154.293
-154.312
-154.33
-154.348
-154.366
-154.383
-154.399
-154.414
-154.428
-154.441
-154.452
-154.462
-154.47
-154.477
-154.482
-154.486
-154.488
-157.512
-157.51
-157.507
-157.502
-157.496
-157.489
-157.479
-157.469
-157.457
-157.445
-157.431
-157.416
-157.401
-157.385
-157.369
-157.352
-157.335
-157.318
-157.302
-157.285
-157.269
-157.254
-157.24
-157.226
-157.213
-157.202
-157.192
-157.183
-157.176
-157.17
-157.166
-157.164
-157.163
-157.164
-157.166
-157.17
-157.176
-157.183
-157.192
-157.202
-157.213
-157.226
-157.24
-157.254
-157.269
-157.285
-157.302
-157.318
-157.335
-157.352
-157.369
-157.385
-157.401
-157.416
-157.431
-157.445
-157.457
-157.469
-157.479
-157.489
-157.496
-157.502
-157.507
-157.51
-157.512
-160.538
-160.536
-160.533
-160.529
-160.524
-160.517
-160.508
-160.499
-160.488
-160.477
-160.464
-160.451
-160.437
-160.423
-160.408
-160.393
-160.377
-160.362
-160.347
-160.332
-160.318
-160.304
-160.291
-160.278
-160.267
-160.257
-160.247
-160.239
-160.233
-160.228
-160.224
-160.222
-160.221
-160.222
-160.224
-160.228
-160.233
-160.239
-160.247
-160.257
-160.267
-160.278
-160.291
-160.304
-160.318
-160.332
-160.347
-160.362
-160.377
-160.393
-160.408
-160.423
-160.437
-160.451
-160.464
-160.477
-160.488
-160.499
-160.508
-160.517
-160.524
-160.529
-160.533
-160.536
-160.538
-163.565
-163.564
-163.561
-163.557
-163.552
-163.546
-163.538
-163.53
-163.52
-163.51
-163.498
-163.486
-163.474
-163.461
-163.447
-163.433
-163.419
-163.406
-163.392
-163.378
-163.365
-163.353
-163.341
-163.33
-163.319
-163.31
-163.302
-163.294
-163.288
-163.284
-163.28
-163.278
-163.278
-163.278
-163.28
-163.284
-163.288
-163.294
-163.302
-163.31
-163.319
-163.33
-163.341
-163.353
-163.365
-163.378
-163.392
-163.406
-163.419
-163.433
-163.447
-163.461
-163.474
-163.486
-163.498
-163.51
-163.52
-163.53
-163.538
-163.546
-163.552
-163.557
-163.561
-163.564
-163.565
-166.594
-166.593
-166.59
-166.587
-166.582
-166.576
-166.569
-166.562
-166.553
-166.543
-166.533
-166.522
-166.511
-166.499
-166.487
-166.474
-166.461
-166.449
-166.436
-166.424
-166.412
-166.401
-166.39
-166.38
-166.371
-166.362
-166.355
-166.348
-166.343
-166.339
-166.335
-166.334
-166.333
-166.334
-166.335
-166.339
-166.343
-166.348
-166.355
-166.362
-166.371
-166.38
-166.39
-166.401
-166.412
-166.424
-166.436
-166.449
-166.461
-166.474
-166.487
-166.499
-166.511
-166.522
-166.533
-166.543
-166.553
-166.562
-166.569
-166.576
-166.582
-166.587
-166.59
-166.593
-166.594
-169.624
-169.623
-169.62
-169.617
-169.613
-169.608
-169.602
-169.594
-169.587
-169.578
-169.569
-169.559
-169.548
-169.537
-169.526
-169.515
-169.504
-169.492
-169.481
-169.47
-169.459
-169.449
-169.439
-169.43
-169.421
-169.413
-169.407
-169.401
-169.396
-169.392
-169.389
-169.388
-169.387
-169.388
-169.389
-169.392
-169.396
-169.401
-169.407
-169.413
-169.421
-169.43
-169.439
-169.449
-169.459
-169.47
-169.481
-169.492
-169.504
-169.515
-169.526
-169.537
-169.548
-169.559
-169.569
-169.578
-169.587
-169.594
-169.602
-169.608
-169.613
-169.617
-169.62
-169.623
-169.624
-172.655
-172.654
-172.652
-172.649
-172.645
-172.64
-172.635
-172.628
-172.621
-172.613
-172.605
-172.596
-172.586
-172.576
-172.566
-172.556
-172.546
-172.535
-172.525
-172.515
-172.505
-172.496
-172.487
-172.479
-172.471
-172.464
-172.458
-172.452
-172.448
-172.444
-172.442
-172.44
-172.44
-172.44
-172.442
-172.444
-172.448
-172.452
-172.458
-172.464
-172.471
-172.479
-172.487
-172.496
-172.505
-172.515
-172.525
-172.535
-172.546
-172.556
-172.566
-172.576
-172.586
-172.596
-172.605
-172.613
-172.621
-172.628
-172.635
-172.64
-172.645
-172.649
-172.652
-172.654
-172.655
-175.687
-175.686
-175.684
-175.681
-175.678
-175.673
-175.668
-175.663
-175.656
-175.649
-175.641
-175.633
-175.624
-175.615
-175.606
-175.597
-175.588
-175.578
-175.569
-175.56
-175.551
-175.542
-175.534
-175.527
-175.52
-175.514
-175.508
-175.503
-175.499
-175.496
-175.494
-175.492
-175.492
-175.492
-175.494
-175.496
-175.499
-175.503
-175.508
-175.514
-175.52
-175.527
-175.534
-175.542
-175.551
-175.56
-175.569
-175.578
-175.588
-175.597
-175.606
-175.615
-175.624
-175.633
-175.641
-175.649
-175.656
-175.663
-175.668
-175.673
-175.678
-175.681
-175.684
-175.686
-175.687
-178.72
-178.719
-178.717
-178.715
-178.712
-178.708
-178.703
-178.698
-178.692
-178.685
-178.678
-178.671
-178.663
-178.655
-178.647
-178.638
-178.63
-178.621
-178.613
-178.604
-178.596
-178.589
-178.581
-178.574
-178.568
-178.562
-178.557
-178.553
-178.549
-178.547
-178.544
-178.543
-178.543
-178.543
-178.544
-178.547
-178.549
-178.553
-178.557
-178.562
-178.568
-178.574
-178.581
-178.589
-178.596
-178.604
-178.613
-178.621
-178.63
-178.638
-178.647
-178.655
-178.663
-178.671
-178.678
-178.685
-178.692
-178.698
-178.703
-178.708
-178.712
-178.715
-178.717
-178.719
-178.72
-181.753
-181.753
-181.751
-181.749
-181.746
-181.742
-181.738
-181.733
-181.728
-181.722
-181.716
-181.709
-181.702
-181.695
-181.687
-181.679
-181.672
-181.664
-181.656
-181.649
-181.641
-181.634
-181.628
-181.622
-181.616
-181.611
-181.606
-181.602
-181.599
-181.596
-181.594
-181.593
-181.593
-181.593
-181.594
-181.596
-181.599
-181.602
-181.606
-181.611
-181.616
-181.622
-181.628
-181.634
-181.641
-181.649
-181.656
-181.664
-181.672
-181.679
-181.687
-181.695
-181.702
-181.709
-181.716
-181.722
-181.728
-181.733
-181.738
-181.742
-181.746
-181.749
-181.751
-181.753
-181.753
-184.788
-184.787
-184.786
-184.784
-184.781
-184.778
-184.774
-184.77
-184.765
-184.759
-184.754
-184.748
-184.741
-184.734
-184.728
-184.721
-184.714
-184.707
-184.7
-184.693
-184.686
-184.68
-184.674
-184.668
-184.663
-184.658
-184.654
-184.651
-184.648
-184.645
-184.644
-184.643
-184.642
-184.643
-184.644
-184.645
-184.648
-184.651
-184.654
-184.658
-184.663
-184.668
-184.674
-184.68
-184.686
-184.693
-184.7
-184.707
-184.714
-184.721
-184.728
-184.734
-184.741
-184.748
-184.754
-184.759
-184.765
-184.77
-184.774
-184.778
-184.781
-184.784
-184.786
-184.787
-184.788
-187.823
-187.822
-187.821
-187.819
-187.817
-187.814
-187.81
-187.806
-187.802
-187.797
-187.792
-187.786
-187.781
-187.775
-187.768
-187.762
-187.756
-187.749
-187.743
-187.737
-187.731
-187.725
-187.72
-187.714
-187.71
-187.705
-187.702
-187.698
-187.696
-187.694
-187.692
-187.691
-187.691
-187.691
-187.692
-187.694
-187.696
-187.698
-187.702
-187.705
-187.71
-187.714
-187.72
-187.725
-187.731
-187.737
-187.743
-187.749
-187.756
-187.762
-187.768
-187.775
-187.781
-187.786
-187.792
-187.797
-187.802
-187.806
-187.81
-187.814
-187.817
-187.819
-187.821
-187.822
-187.823
-190.859
-190.858
-190.857
-190.855
-190.853
-190.851
-190.847
-190.844
-190.84
-190.835
-190.831
-190.826
-190.82
-190.815
-190.809
-190.803
-190.798
-190.792
-190.786
-190.78
-190.775
-190.77
-190.765
-190.76
-190.756
-190.752
-190.749
-190.746
-190.743
-190.741
-190.74
-190.739
-190.739
-190.739
-190.74
-190.741
-190.743
-190.746
-190.749
-190.752
-190.756
-190.76
-190.765
-190.77
-190.775
-190.78
-190.786
-190.792
-190.798
-190.803
-190.809
-190.815
-190.82
-190.826
-190.831
-190.835
-190.84
-190.844
-190.847
-190.851
-190.853
-190.855
-190.857
-190.858
-190.859
-193.895
-193.895
-193.894
-193.892
-193.89
-193.888
-193.885
-193.882
-193.878
-193.874
-193.87
-193.865
-193.86
-193.855
-193.85
-193.845
-193.84
-193.834
-193.829
-193.824
-193.819
-193.814
-193.81
-193.806
-193.802
-193.798
-193.795
-193.793
-193.79
-193.789
-193.787
-193.787
-193.786
-193.787
-193.787
-193.789
-193.79
-193.793
-193.795
-193.798
-193.802
-193.806
-193.81
-193.814
-193.819
-193.824
-193.829
-193.834
-193.84
-193.845
-193.85
-193.855
-193.86
-193.865
-193.87
-193.874
-193.878
-193.882
-193.885
-193.888
-193.89
-193.892
-193.894
-193.895
-193.895
-196.932
-196.931
-196.931
-196.929
-196.927
-196.925
-196.923
-196.92
-196.916
-196.913
-196.909
-196.905
-196.9
-196.896
-196.891
-196.886
-196.882
-196.877
-196.872
-196.867
-196.863
-196.859
-196.855
-196.851
-196.847
-196.844
-196.841
-196.839
-196.837
-196.835
-196.834
-196.833
-196.833
-196.833
-196.834
-196.835
-196.837
-196.839
-196.841
-196.844
-196.847
-196.851
-196.855
-196.859
-196.863
-196.867
-196.872
-196.877
-196.882
-196.886
-196.891
-196.896
-196.9
-196.905
-196.909
-196.913
-196.916
-196.92
-196.923
-196.925
-196.927
-196.929
-196.931
-196.931
-196.932
-199.969
-199.969
-199.968
-199.967
-199.965
-199.963
-199.961
-199.958
-199.955
-199.952
-199.948
-199.944
-199.94
-199.936
-199.932
-199.928
-199.923
-199.919
-199.915
-199.911
-199.907
-199.903
-199.899
-199.896
-199.892
-199.89
-199.887
-199.885
-199.883
-199.881
-199.88
-199.88
-199.88
-199.88
-199.88
-199.881
-199.883
-199.885
-199.887
-199.89
-199.892
-199.896
-199.899
-199.903
-199.907
-199.911
-199.915
-199.919
-199.923
-199.928
-199.932
-199.936
-199.94
-199.944
-199.948
-199.952
-199.955
-199.958
-199.961
-199.963
-199.965
-199.967
-199.968
-199.969
-199.969
-203.007
-203.007
-203.006
-203.005
-203.003
-203.001
-202.999
-202.997
-202.994
-202.991
-202.988
-202.984
-202.981
-202.977
-202.973
-202.969
-202.965
-202.962
-202.958
-202.954
-202.95
-202.947
-202.943
-202.94
-202.937
-202.935
-202.932
-202.93
-202.929
-202.927
-202.926
-202.926
-202.926
-202.926
-202.926
-202.927
-202.929
-202.93
-202.932
-202.935
-202.937
-202.94
-202.943
-202.947
-202.95
-202.954
-202.958
-202.962
-202.965
-202.969
-202.973
-202.977
-202.981
-202.984
-202.988
-202.991
-202.994
-202.997
-202.999
-203.001
-203.003
-203.005
-203.006
-203.007
-203.007
-206.045
-206.045
-206.044
-206.043
-206.042
-206.04
-206.038
-206.036
-206.033
-206.031
-206.028
-206.025
-206.021
-206.018
-206.014
-206.011
-206.007
-206.004
-206
-205.997
-205.993
-205.99
-205.987
-205.984
-205.982
-205.979
-205.977
-205.975
-205.974
-205.973
-205.972
-205.971
-205.971
-205.971
-205.972
-205.973
-205.974
-205.975
-205.977
-205.979
-205.982
-205.984
-205.987
-205.99
-205.993
-205.997
-206
-206.004
-206.007
-206.011
-206.014
-206.018
-206.021
-206.025
-206.028
-206.031
-206.033
-206.036
-206.038
-206.04
-206.042
-206.043
-206.044
-206.045
-206.045
-209.084
-209.083
-209.083
-209.082
-209.08
-209.079
-209.077
-209.075
-209.073
-209.07
-209.068
-209.065
-209.062
-209.059
-209.056
-209.053
-209.049
-209.046
-209.043
-209.04
-209.037
-209.034
-209.031
-209.028
-209.026
-209.024
-209.022
-209.02
-209.019
-209.018
-209.017
-209.017
-209.016
-209.017
-209.017
-209.018
-209.019
-209.02
-209.022
-209.024
-209.026
-209.028
-209.031
-209.034
-209.037
-209.04
-209.043
-209.046
-209.049
-209.053
-209.056
-209.059
-209.062
-209.065
-209.068
-209.07
-209.073
-209.075
-209.077
-209.079
-209.08
-209.082
-209.083
-209.083
-209.084
-212.122
-212.122
-212.122
-212.121
-212.12
-212.118
-212.117
-212.115
-212.113
-212.11
-212.108
-212.105
-212.103
-212.1
-212.097
-212.094
-212.091
-212.088
-212.085
-212.083
-212.08
-212.077
-212.075
-212.072
-212.07
-212.068
-212.066
-212.065
-212.064
-212.063
-212.062
-212.062
-212.061
-212.062
-212.062
-212.063
-212.064
-212.065
-212.066
-212.068
-212.07
-212.072
-212.075
-212.077
-212.08
-212.083
-212.085
-212.088
-212.091
-212.094
-212.097
-212.1
-212.103
-212.105
-212.108
-212.11
-212.113
-212.115
-212.117
-212.118
-212.12
-212.121
-212.122
-212.122
-212.122
-215.161
-215.161
-215.161
-215.16
-215.159
-215.158
-215.156
-215.155
-215.153
-215.151
-215.148
-215.146
-215.144
-215.141
-215.138
-215.136
-215.133
-215.13
-215.128
-215.125
-215.123
-215.12
-215.118
-215.116
-215.114
-215.112
-215.111
-215.109
-215.108
-215.107
-215.107
-215.106
-215.106
-215.106
-215.107
-215.107
-215.108
-215.109
-215.111
-215.112
-215.114
-215.116
-215.118
-215.12
-215.123
-215.125
-215.128
-215.13
-215.133
-215.136
-215.138
-215.141
-215.144
-215.146
-215.148
-215.151
-215.153
-215.155
-215.156
-215.158
-215.159
-215.16
-215.161
-215.161
-215.161
-218.201
-218.201
-218.2
-218.199
-218.198
-218.197
-218.196
-218.195
-218.193
-218.191
-218.189
-218.187
-218.185
-218.182
-218.18
-218.178
-218.175
-218.173
-218.17
-218.168
-218.166
-218.163
-218.161
-218.159
-218.158
-218.156
-218.155
-218.153
-218.152
-218.152
-218.151
-218.151
-218.15
-218.151
-218.151
-218.152
-218.152
-218.153
-218.155
-218.156
-218.158
-218.159
-218.161
-218.163
-218.166
-218.168
-218.17
-218.173
-218.175
-218.178
-218.18
-218.182
-218.185
-218.187
-218.189
-218.191
-218.193
-218.195
-218.196
-218.197
-218.198
-218.199
-218.2
-218.201
-218.201
-221.24
-221.24
-221.24
-221.239
-221.238
-221.237
-221.236
-221.235
-221.233
-221.231
-221.23
-221.228
-221.226
-221.224
-221.221
-221.219
-221.217
-221.215
-221.213
-221.21
-221.208
-221.206
-221.205
-221.203
-221.201
-221.2
-221.198
-221.197
-221.196
-221.196
-221.195
-221.195
-221.195
-221.195
-221.195
-221.196
-221.196
-221.197
-221.198
-221.2
-221.201
-221.203
-221.205
-221.206
-221.208
-221.21
-221.213
-221.215
-221.217
-221.219
-221.221
-221.224
-221.226
-221.228
-221.23
-221.231
-221.233
-221.235
-221.236
-221.237
-221.238
-221.239
-221.24
-221.24
-221.24
-224.28
-224.28
-224.28
-224.279
-224.278
-224.277
-224.276
-224.275
-224.274
-224.272
-224.27
-224.269
-224.267
-224.265
-224.263
-224.261
-224.259
-224.257
-224.255
-224.253
-224.251
-224.249
-224.248
-224.246
-224.244
-224.243
-224.242
-224.241
-224.24
-224.239
-224.239
-224.239
-224.239
-224.239
-224.239
-224.239
-224.24
-224.241
-224.242
-224.243
-224.244
-224.246
-224.248
-224.249
-224.251
-224.253
-224.255
-224.257
-224.259
-224.261
-224.263
-224.265
-224.267
-224.269
-224.27
-224.272
-224.274
-224.275
-224.276
-224.277
-224.278
-224.279
-224.28
-224.28
-224.28
-227.32
-227.32
-227.32
-227.319
-227.318
-227.318
-227.317
-227.315
-227.314
-227.313
-227.311
-227.31
-227.308
-227.306
-227.304
-227.303
-227.301
-227.299
-227.297
-227.295
-227.294
-227.292
-227.29
-227.289
-227.288
-227.286
-227.285
-227.284
-227.284
-227.283
-227.283
-227.282
-227.282
-227.282
-227.283
-227.283
-227.284
-227.284
-227.285
-227.286
-227.288
-227.289
-227.29
-227.292
-227.294
-227.295
-227.297
-227.299
-227.301
-227.303
-227.304
-227.306
-227.308
-227.31
-227.311
-227.313
-227.314
-227.315
-227.317
-227.318
-227.318
-227.319
-227.32
-227.32
-227.32
-230.36
-230.36
-230.36
-230.359
-230.359
-230.358
-230.357
-230.356
-230.355
-230.354
-230.352
-230.351
-230.349
-230.348
-230.346
-230.344
-230.343
-230.341
-230.339
-230.338
-230.336
-230.335
-230.333
-230.332
-230.331
-230.33
-230.329
-230.328
-230.327
-230.327
-230.326
-230.326
-230.326
-230.326
-230.326
-230.327
-230.327
-230.328
-230.329
-230.33
-230.331
-230.332
-230.333
-230.335
-230.336
-230.338
-230.339
-230.341
-230.343
-230.344
-230.346
-230.348
-230.349
-230.351
-230.352
-230.354
-230.355
-230.356
-230.357
-230.358
-230.359
-230.359
-230.36
-230.36
-230.36
-233.401
-233.401
-233.4
-233.4
-233.399
-233.399
-233.398
-233.397
-233.396
-233.395
-233.393
-233.392
-233.391
-233.389
-233.388
-233.386
-233.385
-233.383
-233.382
-233.38
-233.379
-233.377
-233.376
-233.375
-233.374
-233.373
-233.372
-233.371
-233.37
-233.37
-233.37
-233.369
-233.369
-233.369
-233.37
-233.37
-233.37
-233.371
-233.372
-233.373
-233.374
-233.375
-233.376
-233.377
-233.379
-233.38
-233.382
-233.383
-233.385
-233.386
-233.388
-233.389
-233.391
-233.392
-233.393
-233.395
-233.396
-233.397
-233.398
-233.399
-233.399
-233.4
-233.4
-233.401
-233.401
-236.441
-236.441
-236.441
-236.44
-236.44
-236.439
-236.438
-236.438
-236.437
-236.436
-236.434
-236.433
-236.432
-236.431
-236.429
-236.428
-236.426
-236.425
-236.424
-236.422
-236.421
-236.42
-236.419
-236.418
-236.417
-236.416
-236.415
-236.414
-236.414
-236.413
-236.413
-236.413
-236.412
-236.413
-236.413
-236.413
-236.414
-236.414
-236.415
-236.416
-236.417
-236.418
-236.419
-236.42
-236.421
-236.422
-236.424
-236.425
-236.426
-236.428
-236.429
-236.431
-236.432
-236.433
-236.434
-236.436
-236.437
-236.438
-236.438
-236.439
-236.44
-236.44
-236.441
-236.441
-236.441
-239.482
-239.482
-239.481
-239.481
-239.481
-239.48
-239.479
-239.478
-239.478
-239.477
-239.476
-239.474
-239.473
-239.472
-239.471
-239.47
-239.468
-239.467
-239.466
-239.465
-239.463
-239.462
-239.461
-239.46
-239.459
-239.458
-239.458
-239.457
-239.457
-239.456
-239.456
-239.456
-239.456
-239.456
-239.456
-239.456
-239.457
-239.457
-239.458
-239.458
-239.459
-239.46
-239.461
-239.462
-239.463
-239.465
-239.466
-239.467
-239.468
-239.47
-239.471
-239.472
-239.473
-239.474
-239.476
-239.477
-239.478
-239.478
-239.479
-239.48
-239.481
-239.481
-239.481
-239.482
-239.482
-242.523
-242.522
-242.522
-242.522
-242.521
-242.521
-242.52
-242.52
-242.519
-242.518
-242.517
-242.516
-242.515
-242.514
-242.513
-242.511
-242.51
-242.509
-242.508
-242.507
-242.506
-242.505
-242.504
-242.503
-242.502
-242.501
-242.5
-242.5
-242.499
-242.499
-242.499
-242.499
-242.499
-242.499
-242.499
-242.499
-242.499
-242.5
-242.5
-242.501
-242.502
-242.503
-242.504
-242.505
-242.506
-242.507
-242.508
-242.509
-242.51
-242.511
-242.513
-242.514
-242.515
-242.516
-242.517
-242.518
-242.519
-242.52
-242.52
-242.521
-242.521
-242.522
-242.522
-242.522
-242.523
-245.563
-245.563
-245.563
-245.563
-245.562
-245.562
-245.561
-245.561
-245.56
-245.559
-245.558
-245.557
-245.556
-245.555
-245.554
-245.553
-245.552
-245.551
-245.55
-245.549
-245.548
-245.547
-245.546
-245.545
-245.545
-245.544
-245.543
-245.543
-245.542
-245.542
-245.542
-245.541
-245.541
-245.541
-245.542
-245.542
-245.542
-245.543
-245.543
-245.544
-245.545
-245.545
-245.546
-245.547
-245.548
-245.549
-245.55
-245.551
-245.552
-245.553
-245.554
-245.555
-245.556
-245.557
-245.558
-245.559
-245.56
-245.561
-245.561
-245.562
-245.562
-245.563
-245.563
-245.563
-245.563
-248.604
-248.604
-248.604
-248.604
-248.603
-248.603
-248.602
-248.602
-248.601
-248.6
-248.6
-248.599
-248.598
-248.597
-248.596
-248.595
-248.594
-248.593
-248.592
-248.591
-248.59
-248.589
-248.589
-248.588
-248.587
-248.586
-248.586
-248.585
-248.585
-248.585
-248.584
-248.584
-248.584
-248.584
-248.584
-248.585
-248.585
-248.585
-248.586
-248.586
-248.587
-248.588
-248.589
-248.589
-248.59
-248.591
-248.592
-248.593
-248.594
-248.595
-248.596
-248.597
-248.598
-248.599
-248.6
-248.6
-248.601
-248.602
-248.602
-248.603
-248.603
-248.604
-248.604
-248.604
-248.604
-251.645
-251.645
-251.645
-251.645
-251.645
-251.644
-251.644
-251.643
-251.642
-251.642
-251.641
-251.64
-251.639
-251.639
-251.638
-251.637
-251.636
-251.635
-251.634
-251.633
-251.632
-251.632
-251.631
-251.63
-251.629
-251.629
-251.628
-251.628
-251.628
-251.627
-251.627
-251.627
-251.627
-251.627
-251.627
-251.627
-251.628
-251.628
-251.628
-251.629
-251.629
-251.63
-251.631
-251.632
-251.632
-251.633
-251.634
-251.635
-251.636
-251.637
-251.638
-251.639
-251.639
-251.64
-251.641
-251.642
-251.642
-251.643
-251.644
-251.644
-251.645
-251.645
-251.645
-251.645
-251.645
-254.687
-254.686
-254.686
-254.686
-254.686
-254.685
-254.685
-254.684
-254.684
-254.683
-254.683
-254.682
-254.681
-254.68
-254.679
-254.679
-254.678
-254.677
-254.676
-254.675
-254.675
-254.674
-254.673
-254.672
-254.672
-254.671
-254.671
-254.67
-254.67
-254.67
-254.67
-254.669
-254.669
-254.669
-254.67
-254.67
-254.67
-254.67
-254.671
-254.671
-254.672
-254.672
-254.673
-254.674
-254.675
-254.675
-254.676
-254.677
-254.678
-254.679
-254.679
-254.68
-254.681
-254.682
-254.683
-254.683
-254.684
-254.684
-254.685
-254.685
-254.686
-254.686
-254.686
-254.686
-254.687
-257.728
-257.728
-257.728
-257.727
-257.727
-257.727
-257.726
-257.726
-257.725
-257.725
-257.724
-257.723
-257.723
-257.722
-257.721
-257.72
-257.72
-257.719
-257.718
-257.717
-257.717
-257.716
-257.715
-257.715
-257.714
-257.714
-257.713
-257.713
-257.712
-257.712
-257.712
-257.712
-257.712
-257.712
-257.712
-257.712
-257.712
-257.713
-257.713
-257.714
-257.714
-257.715
-257.715
-257.716
-257.717
-257.717
-257.718
-257.719
-257.72
-257.72
-257.721
-257.722
-257.723
-257.723
-257.724
-257.725
-257.725
-257.726
-257.726
-257.727
-257.727
-257.727
-257.728
-257.728
-257.728
-260.769
-260.769
-260.769
-260.769
-260.768
-260.768
-260.768
-260.767
-260.767
-260.766
-260.766
-260.765
-260.764
-260.764
-260.763
-260.762
-260.762
-260.761
-260.76
-260.759
-260.759
-260.758
-260.758
-260.757
-260.756
-260.756
-260.756
-260.755
-260.755
-260.755
-260.754
-260.754
-260.754
-260.754
-260.754
-260.755
-260.755
-260.755
-260.756
-260.756
-260.756
-260.757
-260.758
-260.758
-260.759
-260.759
-260.76
-260.761
-260.762
-260.762
-260.763
-260.764
-260.764
-260.765
-260.766
-260.766
-260.767
-260.767
-260.768
-260.768
-260.768
-260.769
-260.769
-260.769
-260.769
-263.81
-263.81
-263.81
-263.81
-263.81
-263.81
-263.809
-263.809
-263.808
-263.808
-263.807
-263.807
-263.806
-263.805
-263.805
-263.804
-263.803
-263.803
-263.802
-263.801
-263.801
-263.8
-263.8
-263.799
-263.799
-263.798
-263.798
-263.797
-263.797
-263.797
-263.797
-263.797
-263.797
-263.797
-263.797
-263.797
-263.797
-263.797
-263.798
-263.798
-263.799
-263.799
-263.8
-263.8
-263.801
-263.801
-263.802
-263.803
-263.803
-263.804
-263.805
-263.805
-263.806
-263.807
-263.807
-263.808
-263.808
-263.809
-263.809
-263.81
-263.81
-263.81
-263.81
-263.81
-263.81
-266.852
-266.852
-266.852
-266.852
-266.851
-266.851
-266.851
-266.85
-266.85
-266.849
-266.849
-266.848
-266.848
-266.847
-266.847
-266.846
-266.845
-266.845
-266.844
-266.843
-266.843
-266.842
-266.842
-266.841
-266.841
-266.84
-266.84
-266.84
-266.839
-266.839
-266.839
-266.839
-266.839
-266.839
-266.839
-266.839
-266.839
-266.84
-266.84
-266.84
-266.841
-266.841
-266.842
-266.842
-266.843
-266.843
-266.844
-266.845
-266.845
-266.846
-266.847
-266.847
-266.848
-266.848
-266.849
-266.849
-266.85
-266.85
-266.851
-266.851
-266.851
-266.852
-266.852
-266.852
-266.852
-269.893
-269.893
-269.893
-269.893
-269.893
-269.893
-269.892
-269.892
-269.891
-269.891
-269.891
-269.89
-269.889
-269.889
-269.888
-269.888
-269.887
-269.887
-269.886
-269.885
-269.885
-269.884
-269.884
-269.883
-269.883
-269.883
-269.882
-269.882
-269.882
-269.881
-269.881
-269.881
-269.881
-269.881
-269.881
-269.881
-269.882
-269.882
-269.882
-269.883
-269.883
-269.883
-269.884
-269.884
-269.885
-269.885
-269.886
-269.887
-269.887
-269.888
-269.888
-269.889
-269.889
-269.89
-269.891
-269.891
-269.891
-269.892
-269.892
-269.893
-269.893
-269.893
-269.893
-269.893
-269.893
-272.935
-272.935
-272.935
-272.935
-272.934
-272.934
-272.934
-272.933
-272.933
-272.933
-272.932
-272.932
-272.931
-272.931
-272.93
-272.93
-272.929
-272.928
-272.928
-272.927
-272.927
-272.926
-272.926
-272.925
-272.925
-272.925
-272.924
-272.924
-272.924
-272.924
-272.923
-272.923
-272.923
-272.923
-272.923
-272.924
-272.924
-272.924
-272.924
-272.925
-272.925
-272.925
-272.926
-272.926
-272.927
-272.927
-272.928
-272.928
-272.929
-272.93
-272.93
-272.931
-272.931
-272.932
-272.932
-272.933
-272.933
-272.933
-272.934
-272.934
-272.934
-272.935
-272.935
-272.935
-272.935
-275.977
-275.976
-275.976
-275.976
-275.976
-275.976
-275.975
-275.975
-275.975
-275.974
-275.974
-275.973
-275.973
-275.972
-275.972
-275.971
-275.971
-275.97
-275.97
-275.969
-275.969
-275.968
-275.968
-275.967
-275.967
-275.967
-275.966
-275.966
-275.966
-275.966
-275.966
-275.965
-275.965
-275.965
-275.966
-275.966
-275.966
-275.966
-275.966
-275.967
-275.967
-275.967
-275.968
-275.968
-275.969
-275.969
-275.97
-275.97
-275.971
-275.971
-275.972
-275.972
-275.973
-275.973
-275.974
-275.974
-275.975
-275.975
-275.975
-275.976
-275.976
-275.976
-275.976
-275.976
-275.977
-279.018
-279.018
-279.018
-279.018
-279.018
-279.017
-279.017
-279.017
-279.017
-279.016
-279.016
-279.015
-279.015
-279.014
-279.014
-279.013
-279.013
-279.012
-279.012
-279.011
-279.011
-279.01
-279.01
-279.009
-279.009
-279.009
-279.008
-279.008
-279.008
-279.008
-279.008
-279.008
-279.008
-279.008
-279.008
-279.008
-279.008
-279.008
-279.008
-279.009
-279.009
-279.009
-279.01
-279.01
-279.011
-279.011
-279.012
-279.012
-279.013
-279.013
-279.014
-279.014
-279.015
-279.015
-279.016
-279.016
-279.017
-279.017
-279.017
-279.017
-279.018
-279.018
-279.018
-279.018
-279.018
-282.06
-282.06
-282.06
-282.06
-282.059
-282.059
-282.059
-282.059
-282.058
-282.058
-282.057
-282.057
-282.057
-282.056
-282.056
-282.055
-282.055
-282.054
-282.054
-282.053
-282.053
-282.052
-282.052
-282.051
-282.051
-282.051
-282.05
-282.05
-282.05
-282.05
-282.05
-282.05
-282.05
-282.05
-282.05
-282.05
-282.05
-282.05
-282.05
-282.051
-282.051
-282.051
-282.052
-282.052
-282.053
-282.053
-282.054
-282.054
-282.055
-282.055
-282.056
-282.056
-282.057
-282.057
-282.057
-282.058
-282.058
-282.059
-282.059
-282.059
-282.059
-282.06
-282.06
-282.06
-282.06
-285.102
-285.102
-285.102
-285.101
-285.101
-285.101
-285.101
-285.1
-285.1
-285.1
-285.099
-285.099
-285.098
-285.098
-285.097
-285.097
-285.096
-285.096
-285.095
-285.095
-285.095
-285.094
-285.094
-285.093
-285.093
-285.093
-285.092
-285.092
-285.092
-285.092
-285.092
-285.091
-285.091
-285.091
-285.092
-285.092
-285.092
-285.092
-285.092
-285.093
-285.093
-285.093
-285.094
-285.094
-285.095
-285.095
-285.095
-285.096
-285.096
-285.097
-285.097
-285.098
-285.098
-285.099
-285.099
-285.1
-285.1
-285.1
-285.101
-285.101
-285.101
-285.101
-285.102
-285.102
-285.102
-288.144
-288.143
-288.143
-288.143
-288.143
-288.143
-288.143
-288.142
-288.142
-288.142
-288.141
-288.141
-288.14
-288.14
-288.139
-288.139
-288.138
-288.138
-288.137
-288.137
-288.136
-288.136
-288.136
-288.135
-288.135
-288.134
-288.134
-288.134
-288.134
-288.134
-288.133
-288.133
-288.133
-288.133
-288.133
-288.134
-288.134
-288.134
-288.134
-288.134
-288.135
-288.135
-288.136
-288.136
-288.136
-288.137
-288.137
-288.138
-288.138
-288.139
-288.139
-288.14
-288.14
-288.141
-288.141
-288.142
-288.142
-288.142
-288.143
-288.143
-288.143
-288.143
-288.143
-288.143
-288.144
 Time step         1  t=1.56074E-04  dt=1.561E-04  cfl=3.00E-01 cfl_v=9.48E-02
 c_conv= 2.54E+03 c_visc= 6.07E+02 c_grav= 1.78E+02 c_st= 5.03E+02
