MPI Initialisation Problem
Tim Stitt timothy.stitt at ichec.ie
Sat Jun 16 12:32:40 CDT 2007
Hi all,
I am having some difficulty getting my parallel eigensolver to run over
multiple processes.
When I execute my parallel code on my distributed-memory machine ( with > 1
processes) I keep getting the following runtime message:
mpiexec: Warning: task 0 exited before completing MPI startup.
mpiexec: Warning: task 1 exited oddly---report bug: status 0 done 0.
MPI_Comm_Size returns 1 for #processes even though I mpiexec -n 2 or higher.
The code still runs to completion but serially.......
I have taken the same code and ran it on my shared-memory machine with no
problems and all processes getting picked up so I know it is not a coding
problem.....the sample ksp test codes that come with my petsc (2.3.3)
distribution also exhibit this problem.
So there seems to be a problem with the PETScInitialize routine with this
particular architecture. I have tried both pathscale and pgi compilers with
the same result. As far as I can see there are no noticeable warnings
generated during the config and make phases. Others use MPI regularly on our
cluster so I don't see how it could be a MPI library issue.
Any thoughts on what could be happening gratefully received.
Tim.
Dr. Timothy Stitt <timothy_dot_stitt_at_ichec.ie>
HPC Application Consultant - ICHEC (www.ichec.ie)
Dublin Institute for Advanced Studies
5 Merrion Square - Dublin 2 - Ireland
+353-1-6621333 (tel) / +353-1-6621477 (fax) / +353-874195427 (mobile)
