Setting tolerances for multigrid
Fri Jun 15 14:30:34 CDT 2007
  What happens if you run the two level with -ksp_rtol 1.e-12
  BTW: when you just change -dmmg_nlevels from 1 to 2 you are now
solving a NEW problem that has twice as many points in each direction,
this can also effect the time-stepping. You can use -dmmg_nlevels 2
-pc_type lu to compare with the -dmmg_nlevels 2
  Always verify things with a direct solver before using multigrid
or any other iterative linear solver. Multigrid is ONLY an optimization
(faster, less memory), debug BEFORE turning on the optimizations.
   Barry
On Fri, 15 Jun 2007, Knut Erik Teigen wrote:
> When running with those options I get this after the first timestep for
> both one and two levels:
> 159 KSP preconditioned resid norm 1.397494864058e-07 true resid norm
> 4.996893774970e-02 ||Ae||/||Ax|| 1.577132216812e-10
> Linear solve converged due to CONVERGED_RTOL
> However, after the second timestep they start to get different.
> With two levels the norm is actually lower, but still, the computation
> diverges after about 6 time steps. With one level the computation runs
> smoothly. Here are the numbers:
> -dmmg_nlevels 1
>   0 KSP preconditioned resid norm 1.674785901465e+02
> true resid norm 4.083933362528e+08 ||Ae||/||Ax|| 1.000000000000e+00
>   1 KSP preconditioned resid norm 6.256839347623e+01
> true resid norm 4.220478752135e+07 ||Ae||/||Ax|| 1.033434774147e-01
> 159 KSP preconditioned resid norm 1.318896741223e-07
> true resid norm 5.104451971417e-02 ||Ae||/||Ax|| 1.249886204866e-10
> -dmmg_nlevels 2
>   1 KSP preconditioned resid norm 6.252455641723e+01
> true resid norm 5.561545924132e+07 ||Ae||/||Ax|| 1.361811134129e-01
> 159 KSP preconditioned resid norm 1.305901659826e-07
> true resid norm 4.297164043386e-02 ||Ae||/||Ax|| 1.052212086224e-10
> -Knut Erik-
> On Fri, 2007-06-15 at 10:10 -0500, Barry Smith wrote:
> >   You need to make sure the linear solvers are converging properly
> > before even worrying about time-stepping. Run with -ksp_monitor_true_residual
> > (-ksp_truemonitor on older versions of PETSc) and -ksp_converged_reason
> >    Barry
> > > The computation runs just fine with -dmmg_nlevels 1.
> > > I use a grid of 65x129, with three levels, so that the coarsest grid is
> > > 17x33.
> > > I've diffed the solutions, and they are equal for the first two time
> > > steps, but then they start to differ somewhat. Here is an excerpt:
> > > -dmmg_nlevels 1:
> > > 65.0427492820557        65.0216231814457      64.9793945321386
> > > -dmmg_nlevels 3:
> > > 65.0920864319067        65.0711253401585      65.0292265582817
> > > Using 2 or 4 levels produce the same result as 3 levels.
> > > -Knut Erik-
> > > On Fri, 2007-06-15 at 10:21 +0200, Matthew Knepley wrote:
> > > > This does not sound right to me. I think something must be
> > > > configured incorrectly. All MG does is accelerate the solution
> > > > of the fine grid problem. I think something must be wrong with
> > > > the specification here. It is easy to check. Run with -dmmg_nlevels 1
> > > > which just solves on the fine grid.
> > > >   Matt
> > > > On 6/15/07, Knut Erik Teigen <knutert at stud.ntnu.no> wrote:
> > > > > Thanks, Matthew. It seems like the tolerances weren't my problem,
> > > > > though. Even with a tolerance of 1e-10, the computation diverges after
> > > > > only a few time steps when using multigrid. With ordinary linear
> > > > > solvers, I can use a tolerance of 1e-4 and still get a satisfactory
> > > > > solution.
> > > > > Could it be that the Galerkin approximation for the coarser levels is
> > > > > too inaccurate for my problem?
> > > > > -Knut Erik-
> > > > > On Thu, 2007-06-14 at 11:32 -0500, Matthew Knepley wrote:
> > > > > > On 6/14/07, Knut Erik Teigen <knutert at stud.ntnu.no> wrote:
> > > > > > > Hello,
> > > > > > > How do I set the tolerances for the KSP solvers when using the
> > > > > > > DMMG routines without using command line arguments? It seems that
> > > > > > > I can use the argument -ksp_rtol on the command line, but in the code I
> > > > > > > can't use KSPSetTolerances since I don't have access to the KSP solver
> > > > > > > context?
> > > > > > You can use DMMGGetKSP() for the finest level, and dmmg[level]->ksp for
> > > > > > any others.
> > > > > > > Also, I see there is a reference to the function DMMGSetUseGalerkin
> > > > > > > in the source code, but I can't find the documentation for it.
> > > > > > > Does this function not exist yet? Again I would like to use
> > > > > > > -dmmg_galerkin, but setting it in the code instead of on the command
> > > > > > > line.
> > > > > > I think you want this:
> > > > > > http://www-unix.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/DA/DMMGSetUseGalerkinCoarse.html
> > > > > >   Matt
> > > > > > > Regards,
> > > > > > > Knut Erik Teigen
