Problems with -eps_monitor_draw and mpiexec
Thu Jun 14 07:32:12 CDT 2007
The X server does not like your hostname (localhost.localdomain). You can
set your DISPLAY env variable, or just give the display argument -display :0.0
  Matt
On 6/14/07, Tim Stitt <timothy.stitt at ichec.ie> wrote:
> Hi all,
> I've finally got my parallel solver working in SLEPc. I want to monitor the
> eigenvalues and error tolerances graphically using -eps_monitor_draw. This
> works perfectly fine for the serial version of the code but when I test the
> parallel version I get the following errors from all nodes:
> [1]PETSC ERROR: --------------------- Error
> Message ------------------------------------
> [1]PETSC ERROR: Error in external library!
> [1]PETSC ERROR: Unable to open display on localhost.localdomain:0.0
> .  Make sure your COMPUTE NODES are authorized to connect
>     to this X server and either your DISPLAY variable
>     is set or you use the -display name option
> FYI: I am testing these codes on a multi-core laptop so I am running mpiexec
> directly from the command-line. Without -eps_monitor_draw the code runs as
> aspected.
> Just wondering if someone can hint at a fix so that I can get the graphical
> monitoring working in parallel.
> Regards,
> Tim.
> Dr. Timothy Stitt <timothy_dot_stitt_at_ichec.ie>
> HPC Application Consultant - ICHEC (www.ichec.ie)
> Dublin Institute for Advanced Studies
> 5 Merrion Square - Dublin 2 - Ireland
> +353-1-6621333 (tel) / +353-1-6621477 (fax) / +353-874195427 (mobile)
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
