Do not ignore errors in Makefile
Shi Jin jinzishuai at yahoo.com
Sun Jun 10 22:47:28 CDT 2007
Hi Barry,
The make PETSC_MAKE_STOP_ON_ERROR="" method works
perfectly.
However, when putting this line inside the Makefile
after all the include statements, it showslots of
script code and there is not detailed compiler errors.
I changed it to PETSC_MAKE_STOP_ON_ERROR=, without the
"" in the end and it works just like the command line
case.
Anyway, this is a very good feature and I can't wait
for it to show up in the release.
Thank you very much.
Shi
--- Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Shi,
>    I have come up with a scheme that helps with this
> implemented
> in petsc-dev. The default behavior is the same, for
> example,
> [anlext2wls147:snes/examples/tutorials] bsmith% make
> ex37f90
> gfortran -c
> -I/Users/bsmith/Src/petsc-dev/include/finclude -fPIC
> -Wall -Wno-unused-variable -g
> -I/Users/bsmith/Src/petsc-dev/c-gfortran/include
> -I/usr/X11R6/include
>    -o mex37f90.o mex37f90.F90
> mex37f90.F90:4:
> ffv
> 1
> Error: Unclassifiable statement at (1)
> mex37f90.F90:77.22:
>           use mex37f90
>                      1
> Fatal Error: Can't open module file 'mex37f90.mod'
> for reading at (1): No such file or directory
> make: [mex37f90.o] Error 1 (ignored)
> gfortran -c
>    -o ex37f90.o ex37f90.F90
> ex37f90.F90:14.18:
>       use mex37f90
>                  1
> make: [ex37f90.o] Error 1 (ignored)
> /Users/bsmith/Src/petsc-dev/c-gfortran/bin/mpif90
> -fPIC -Wall -Wno-unused-variable -g   -o ex37f90
> ex37f90.o
> -L/Users/bsmith/Src/petsc-dev/c-gfortran/lib
> -lpetscsnes -lpetscksp -lpetscdm -lpetscmat
> -lpetscvec -lpetsc   -L/usr/X11R6/lib -lX11
> -llapack -lblas
> -L/usr/lib/gcc/i686-apple-darwin8/4.0.1
> -L/usr/lib/gcc/i686-apple-darwin8/4.0.1/../../..
> -ldl -lSystem -lgfortranbegin -lgfortran
-L/usr/local/gfortran/lib/gcc/i386-apple-darwin8.8.1/4.3.0
-L/usr/local/gfortran/lib/gcc/i386-apple-darwin8.8.1/4.3.0/../../..
> -lgcc_s.10.4  -ldl
> -ldl -lSystem -ldl
> gfortran: ex37f90.o: No such file or directory
> make: [ex37f90] Error 1 (ignored)
> /bin/rm -f ex37f90.o mex37f90.mod mex37f90.o
> mex37finterfaces.mod
> But
> ex37f90 PETSC_MAKE_STOP_ON_ERROR=""
> gfortran -c
> mex37f90.F90:4:
> ffv
> 1
> mex37f90.F90:77.22:
>           use mex37f90
>                      1
> make: *** [mex37f90.o] Error 1
> Causes it to stop immediately. You can also put
> PETSC_MAKE_STOP_ON_ERROR = ""
> in the makefile UNDER all the includes in the
> makefile
>   Hope this helps,
>    Barry
> On Fri, 8 Jun 2007, Shi Jin wrote:
> > Hi,there,
> > I found that the default behavior of compiling a
> PETSc
> > program composed of many source files is that
> errors
> > are ignored and compilations continue to the next
> > source file when an error is encountered during
> > "make".
> > I think it is caused by the "-" sign in the
> Makefile.
> > There may be a good reason to have this feature
> but
> > for my code, I really don't want it. I want to he
> > process to stop so that I can immediately deal
> with
> > the error. Is there a way to accomplish this
> feature?
> > I guess something must be changed inside
> > ${PETSC_DIR}/bmake/common/base etc but it seems
> quite
> > complicated to figure it out. Could you please
> help me
> > here? Thank you very much.
> > Shi
____________________________________________________________________________________
> > Food fight? Enjoy some healthy debate
> > in the Yahoo! Answers Food & Drink Q&A.
http://answers.yahoo.com/dir/?link=list&sid=396545367
Don't get soaked.  Take a quick peak at the forecast
with the Yahoo! Search weather shortcut.
http://tools.search.yahoo.com/shortcuts/#loc_weather
