KSP/PC choice
    Tim Kröger
    tim at cevis.uni-bremen.de
    Tue Jul 24 02:37:41 CDT 2007
Dear Lisandro,
On Mon, 23 Jul 2007, Lisandro Dalcin wrote:
> On 7/23/07, Tim Kröger <tim at cevis.uni-bremen.de> wrote:
>> > What kind of stabilization for advection and pressure are you using?
>> Streamline diffusion (for advection).  I am not aware of the
>> requirement to stabilize the pressure as well.
> Well, you need to stabilize pressure if you have a non div-stable
> finite element space (this happens when using linear, equal-order FE
> for both velocity and pressure). Surely you are using a stable FE.
I'm using Taylor-Hood tetrahedron elements.
> I'm not exactly sure what do you understand for 'streamline difussion'
> (is rathre general). But we normally use non div-stable FE pairs,
> formulated with SUPG/PSPG (the first for advection, the second for
> pressure) stabilization, as proposed by Tezduyar in many publications.
I think it's the same that I am using, but I am not sure.  Can you
give me a helpful reference?
> If you are interested in trying the my solution, I can help you. But I
> cannot assert you will have good performance, specially in big 3D
> problems. Anyway, we are currently using it to simulate the flow
> around a racing car (Re=16e6) with about 600K nodes in 30 processors.
I'm currently trying Matt's suggestion (to use MUMPS).  (It seems not
to easy to install MUMPS.)  Anyway, I would like to try your solution
as well.  What would I have to do?
Best Regards,
Tim
Dr. Tim Kroeger                            Phone +49-421-218-7710
tim at mevis.de, tim at cevis.uni-bremen.de      Fax   +49-421-218-4236
MeVis Research GmbH, Universitaetsallee 29, D-28359 Bremen, Germany
Amtsgericht Bremen HRB 16222
Geschaeftsfuehrer: Prof. Dr. H.-O. Peitgen
