KSP/PC choice
Mon Jul 23 10:01:11 CDT 2007
1) Until you run out of memory, I would use sparse direct like MUMPS
2) After that, as long as you have the memory I would increase the
GMRES vectors, say to 50 or 100.
3) After that I would try LGMRES which generally converges better on these
    problems.
   Matt
On 7/23/07, Tim Kröger <tim at cevis.uni-bremen.de> wrote:
> Dear Lissandro,
> >> the more KSP and PC methods are available, the more difficult it is to
> >> choose a suitable one.
> >> I want to compute Navier-Stokes (using Finite Elements) for
> >> medium-sized Reynolds numbers (still laminar, though).  I am currently
> >> using
> > Are you solving incompresible flow?
> Yes.
> > Tansient or steady state?
> Transient.
> > Are you using a monolithic formulation; or a fractional-step like
> > formulation?
> Monolithic.  (I am not quite sure about this word but I assume it
> means that I don't try to decouple the two equations.)
> > What kind of stabilization for advection and pressure are you using?
> Streamline diffusion (for advection).  I am not aware of the
> requirement to stabilize the pressure as well.
> > I ask this because in my experience incompressible flows with
> > monolithic formulations are usually hard to solve, and a good choice
> > of stabilization method not only leads to better final solution, but
> > also lead to linear systems with better conditioning.
> Would you recommend to use a fractional step method?  Would you
> recommend a different stabilization method?  If you have any
> suggestion, please let me know.
> Best Regards,
> Tim
> Dr. Tim Kroeger                            Phone +49-421-218-7710
> tim at mevis.de, tim at cevis.uni-bremen.de      Fax   +49-421-218-4236
> MeVis Research GmbH, Universitaetsallee 29, D-28359 Bremen, Germany
> Amtsgericht Bremen HRB 16222
> Geschaeftsfuehrer: Prof. Dr. H.-O. Peitgen
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
