KSP/PC choice
Tim Kröger tim at cevis.uni-bremen.de
Mon Jul 23 09:26:13 CDT 2007
Dear gaatenek
On Mon, 23 Jul 2007, gaatenek at irisa.fr wrote:
> Do you monitoring the convergence? Try it a see if you have stagnation in
> your convergence.
Yes, I monitor it, but that doesn't seem to give me any helpful
information -- except that it stagnates of course.
> However you can  try this setting,
> -ksp_type gmres
> -ksp_gmres_restart 30
> -pc_type asm
> -pc_asm_overlap 2
> -sub_pc_type ilu
> -sub_pc_factor_zeropivot 0
> -sub_pc_ilu_levels 3
Thank you, I tried it, and it worked well for a test case.  However,
for the real application, the PC eats up all my memory (even in cases
where my former setting did work).
Any hints (except buying a larger computer)?
Might some sub_ksp method help?
Best Regards,
Tim
Dr. Tim Kroeger                            Phone +49-421-218-7710
tim at mevis.de, tim at cevis.uni-bremen.de      Fax   +49-421-218-4236
MeVis Research GmbH, Universitaetsallee 29, D-28359 Bremen, Germany
Amtsgericht Bremen HRB 16222
Geschaeftsfuehrer: Prof. Dr. H.-O. Peitgen
