Windows version of PETSc
Mon Jul 16 10:29:59 CDT 2007
- could you avoid cross posting to multiple lists? [this issue is more
relavent to petsc-users list]
Our current testbox is: sparc SunOS 5.9. However it should work on any
solaris versions. If you encounter problems, let us know at
petsc-maint at mcs.anl.gov
Satish
On Mon, 16 Jul 2007, Trivedi, Jagruti CIV 470000D, 474300D wrote:
> Hi,
> Is PetSc supported for Solaris 10 for X86? The following link describe
> only Solaris 5.7
> Or Sparcstation is supported.
> Response is appreciated.
> ...Jagruti
> -----Original Message-----
> From: owner-petsc-users at mcs.anl.gov
> [mailto:owner-petsc-users at mcs.anl.gov] On Behalf Of Sumit Vaidya
> Sent: Wednesday, June 13, 2007 5:22
> To: petsc-dev at mcs.anl.gov; petsc-users at mcs.anl.gov
> Cc: 'Sumit Vaidya'
> Subject: Windows version of PETSc
> Hi,
> These are the machines supported by PETSc.
> http://www.caspur.it/risorse/softappl/doc/petsc_docs/machines.html
> From this, I came to know that PETSc is already available for Windows
> with 32-bit processor.
> Where can I get this software version of PETSc for windows?
> Waiting for your reply,
> Sumit
> DISCLAIMER ========== This e-mail may contain privileged and
> confidential information which is the property of Persistent Systems
> Pvt. Ltd. It is intended only for the use of the individual or entity to
> which it is addressed. If you are not the intended recipient, you are
> not authorized to read, retain, copy, print, distribute or use this
> message. If you have received this communication in error, please notify
> the sender and delete all copies of this message. Persistent Systems
> Pvt. Ltd. does not accept any liability for virus infected mails.
