PETSc and gfortran
Paul T. Bauman pbauman at ices.utexas.edu
Wed Jan 10 17:24:28 CST 2007
Hello,
Has anyone had any experience using PETSc and gfortran together?  My
code compiles, but when I run it, it crashes with the following error
(mac Tiger 10.4.8, power pc, latest build of gfortran, MPICH2, petsc 2.3.2):
[0]PETSC ERROR:
[0]PETSC ERROR: Caught signal number 10 BUS: Bus Error, possibly illegal
memory access
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[0]PETSC
ERROR: or try http://valgrind.org on linux or man libgmalloc on Apple to
find memory corruption errors
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: ---------------------  Stack Frames
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR:       INSTEAD the line number of the start of the function
[0]PETSC ERROR:       is given.
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Signal received!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Release Version 2.3.2, Patch 8, Tue Jan  2
14:33:59 PST 2007 HG revision: ebeddcedcc065e32fc252af32cf1d01ed4fc7a80
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: EXEC/shrink_tao on a Apple_Pow named
dhcp-67-30.ices.utexas.edu by pbauman Wed Jan 10 17:20:03 2007
[0]PETSC ERROR: Libraries linked from
/Users/pbauman/LIBRARIES/PETSC/petsc-2.3.2-p8/lib/Apple_PowerPC_Tiger_Debug
[0]PETSC ERROR: Configure run at Tue Jan  9 15:42:42 2007
[0]PETSC ERROR: Configure options --with-shared=0 --with-clanguage=C++
--with-mpi-dir=/Users/pbauman/LIBRARIES/MPICH/mpich2-1.0.5_Apple_PowerPC_Tiger_gcc_gfortran
--with-blas-lapack-dir=/Users/pbauman/LIBRARIES/PETSC/petsc-2.3.2-p8/externalpackages/fblaslapack/Apple_PowerPC_Tiger_Debug/
[0]PETSC ERROR:
[0]PETSC ERROR: User provided function() line 0 in unknown directory
unknown file
[cli_0]: aborting job:
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
rank 0 in job 2  dhcp-67-30.ices.utexas.edu_50482   caused collective
abort of all ranks
  exit status of rank 0: return code 59
make: *** [run_shrink_tao_tr] Error 59
This happens at the very beginning of the code (I put a write statement
in at the first line of the program and nothing came out).  This code
runs successfully on linux with intel compilers. I'm sure the problem is
somehow with gfortran/my build, I'm just not sure where to begin with
this kind of problem, so I thought I'd see if anyone had a similar
experience.
Paul
