Memory allocated by PETSC?
Wed Feb 28 17:23:51 CST 2007
On Wed, 28 Feb 2007, Satish Balay wrote:
> > Maximum memory PetscMalloc()ed 29246912 maximum size of entire process 0
> The choice of wording here is a bit misleading. PETSc is using
> getrusage(ru_maxrss) - which is resident set size. [so top should show
> similar numbers got RSS]
Ops - my comments are wrong here.. RSS here is printed as '0' - so
there is a problem with PETSc code somewhere..
Satish
