algebraic multigrid preconditioner
Lisandro Dalcin dalcinl at gmail.com
Tue Feb 27 17:41:11 CST 2007
Well, in our cluster, the debug version need
[dalcinl at aquiles ~]$ du -sh /usr/local/petsc/dev/lib/linux-gnu
163M    /usr/local/petsc/dev/lib/linux-gnu
but the optimized version only need
[dalcinl at aquiles ~]$ du -sh /usr/local/petsc/dev/lib/linux-gnu-O
18M     /usr/local/petsc/dev/lib/linux-gnu-O
Can you afford to have 20M in your cluster account? Of course, you
will need many more space for building PETSc, but perhaps you can do
that on /tmp or some public scratch space.
Or even better, ask your cluster sys admin to build PETSc with your
specific configure options (in your case, with hypre), usig an
appropriate name for PETSC_ARCH, for example
PETSC_ARCH=linux-gnu-O-hypre.
On 2/27/07, Niriedith Karina <niriedith at gmail.com> wrote:
> Finally I understood =D ...but...i have a problem...my account in the
> cluster is limited...i use petsc but it's installed previously in the
> university i have a month using petsc...so...my question is it's the only
> way to do that right,( reinstall petsc)?
> Thanks!
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
