about AMG
Lisandro Dalcin dalcinl at gmail.com
Tue Feb 27 13:35:41 CST 2007
In case this helps you, here goes what I usually do for installing
petsc in our cluster, in a central location. Make sure 'mpicc' is in
your $PATH, the first line is to be sure about this.
$ which mpicc
/usr/local/mpich2/1.0.5/bin/mpicc
$ tar -zxf petsc-2.3.2-p8.tar.gz
$ cd petsc-2.3.2-p8
$ export PETSC_DIR=`pwd`
$ export PETSC_ARCH=linux-gnu
$ touch ~/.hypre_license
$ python config/configure.py --prefix=/usr/local/petsc/2.3.2
--with-shared=1 --with-hypre=1 --download-hypre=ifneeded
$ make
$ su -c 'make install'
$ export PETSC_DIR=/usr/local/petsc/2.3.2
$ make test
On 2/27/07, Niriedith Karina <niriedith at gmail.com> wrote:
>  i did that...and the configuration was successful
> ./configure
> and then
> make install
> but it doesn't work :(
> I think that may be the dir where i did it is the problem...
> petsc in /opt/petsc/
> hypre in /opt/hypre/
> (sorry also i'm new in  english and  linux :P )
> Help me....
Lisandro Dalcín
Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
PTLC - Güemes 3450, (3000) Santa Fe, Argentina
Tel/Fax: +54-(0)342-451.1594
