about Unstructured Meshes
Fri Feb 23 09:53:07 CST 2007
On 2/23/07, Niriedith Karina <niriedith at gmail.com> wrote:
> oka oka...
> thaks
> but... i don't understand very well....
> what can i do with petsc and the unstructured mesh support? because you say
> that petsc does not make meshes so what it's new about the meshes in petsc ?
> i'm sorry but i'm very new in this area...
Then I think you should not try out the PETSc stuff yet. I would just get the
appropriate mesh generator and go from there. The extra support is for
construction of functions and operators over a mesh, but you can do that
yourself after generating them.
   Matt
> thaks again...
> On 2/23/07, Matthew Knepley <knepley at gmail.com > wrote:
> > On 2/23/07, Niriedith Karina < niriedith at gmail.com> wrote:
> > > Hi !!
> > > I'm new here...and i'm new a petsc user.. :P
> > > I want to know if petsc has support for meshes...
> > > I was reading about that and i need create a mesh but all the software
> that
> > > i see are comercial ...so I use petsc for linear solver and matrices so
> if
> > > petsc create meshes it would be but easy for me  .. so..
> > > help me ! :D
> > 1) PETSc does not make meshes, but there are good free meshing packages,
> >     Triangle in 2D and TetGen in 3D.
> > 2) The unstructured mesh support in PETSc is very new, and at this point
> is
> >     probably only usable by expert programmers. If you feel up to it,
> > take a look
> >     at the examples in src/dm/mesh/examples/tutorials. Otherwise, you can
> use
> >     the packages above and manage the construction of Mats and Vecs
> yourself.
> >   Thanks,
> >     Matt
> > > Thanks anyway...
One trouble is that despite this system, anyone who reads journals widely
and critically is forced to realize that there are scarcely any bars to eventual
publication. There seems to be no study too fragmented, no hypothesis too
trivial, no literature citation too biased or too egotistical, no design too
warped, no methodology too bungled, no presentation of results too
inaccurate, too obscure, and too contradictory, no analysis too self-serving,
no argument too circular, no conclusions too trifling or too unjustified, and
no grammar and syntax too offensive for a paper to end up in print. --
Drummond Rennie
