Using Compaq visual fortran with PETSc and not installing Intel MKL/MPICH
Thu Feb 22 09:15:57 CST 2007
On Thu, 22 Feb 2007, Ben Tay wrote:
> Hi,
> I have been using PETSc with visual fortran/intel mkl/mpich installed. This
> has the same configuration as the configuration file .dsw supplied by PETSc.
> However, now using another of my school's computer, MKL and MPICH are not
> installed.
> Is there anyway I can still use compaq visual fortran with PETSc? By using
> --download-f-blas-lapack=1, how can I make them work?
For blas/lapack the above should work, but for MPI - you'll have to
either install mpich or use --with-mpi=0.
Satish
