fill for matrix multiplication
Manav Bhatia manav at u.washington.edu
Sun Feb 18 07:08:14 CST 2007
   I am performing a matrix multiplication of two dense matrices with
both MatMatMult and MatMatMultTranspose.
   What do I choose a fill factor as? According to the definition in
the documentation: fiill = expected fill as ratio of nnz(C)/(nnz(A) +
nnz(B)).
  So, If I have two full matrices A and B, I will get a full matrix
as my result. Hence, the fill factor will be 0.5. However, both these
methods give an error with a fill factor less than 1.0. Also, if I
use PETSC_DFAULT as the fill argument, it agains results in an error
since its value is -2.
Kindly help me with your advice here.
Thanks
Manav
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20070218/0e941af4/attachment.htm>
