understanding the output from -info
Ben Tay zonexo at gmail.com
Tue Feb 13 00:28:41 CST 2007
Ya thanks for the suggestion. strangely it worked. However, if I had not
included hypre, the original command also worked.
Tks anyway.
On 2/12/07, Satish Balay <balay at mcs.anl.gov> wrote:
> - If you have build isses [involing sending configure.log] please use
> petsc-maint at mcs.anl.gov address [not the mailing list]
> - Looks like you were using the following configure options:
> --with-cc=/scratch/g0306332/intel/cc/bin/icc
> --with-fc=/lsftmp/g0306332/inter/fc/bin/ifort
> --with-blas-lapack-dir=/lsftmp/g0306332/inter/mkl/lib/32
> --with-mpi=0 --with-x=0 --with-shared
> But now - you are not specifing the compilers. The default compiler in
> your path must be Intel compilers version 7. Configure breaks with it.
> So sugest using the compilers that worked for you before. i.e
> If you still have problem with hypre - remove
> externalpackages/hypre-1.11.1b and retry.
> Satish
> On Mon, 12 Feb 2007, Ben Tay wrote:
> > Hi,
> > I tried to compile PETSc again and using --download-hypre=1. My command
> > given is
> > ./config/configure.py --with-vendor-compilers=intel
> > --with-blas-lapack-dir=/lsftmp/g0306332/inter/mkl/ --wit
> > h-x=0 --with-shared --with-mpi-dir=/opt/mpich/myrinet/intel/
> > --with-debugging=0 --download-hypre=1
> > I tried twice and the same error msg appears:
> > Downloaded hypre could not be used. Please check install in
> > /nas/lsftmp/g0306332/petsc-2.3.2-p8/externalpackages/hypre-1.11.1b
> /linux-hypre.
> > I've attached the configure.log for your reference.
> > Thank you.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20070213/9fe36306/attachment.htm>
