External software help
Ben Tay zonexo at gmail.com
Mon Feb 12 10:03:19 CST 2007
Btw, how is Trilinos/ML <http://software.sandia.gov/trilinos/> used and
installed? Is the command to download also
--download*-*Trilinos/ML<http://software.sandia.gov/trilinos/> ?
waht about the command to use it?
Thank you.
On 2/12/07, Ben Tay <zonexo at gmail.com> wrote:
> Hi Satish,
> I've installed superlu. I issued the command ./a.out  -mat_type
> superlu -ksp_type preonly -pc_type lu and it just hanged there. Is it
> because I had install it with mpich? I also wanted to try umfpack and
> plapack. Is it similar?
> Btw, plapack 's option isn't in pg 82 of the manual.
> Thank you.
>  On 2/12/07, Satish Balay <balay at mcs.anl.gov> wrote:
> > On Mon, 12 Feb 2007, Ben Tay wrote:
> > > Hi,
> > > I'm trying to experiment with using external solvers. I have some
> > questions:
> > > 1. Is there any difference in speed with calling the external software
> > from
> > > PETSc or directly using them?
> > There is minor conversion overhead when you use them from PETSc.
> > > 2. I tried to install MUMPS using  --download-mumps. I was prompted to
> > > include --with-scalapack. After changing, I was again prompted to
> > include
> > > --with-blacs. I changed and again I was told the need for
> > > --with-blacs-dir=<directory>. I thought I'm supposed to specify where
> > to
> > > install blacs and entered a directory. But it seems that I need to
> > specify
> > > the location of where blacs is. But I do not have it. So how do I
> > solve
> > > that?
> > Mumps requires blacs & scalapack. So use:
> > --download-blacs=1 --download-scalapack=1 --download-mumps=1
> > > 3. I installed some other external packages. I wanted to test their
> > speed at
> > > solving equations. In the manual, I was told to use the runtime option
> > > -mat_type <mattype> -ksp_type preonly -pc_type <pctype> and also -help
> > to
> > > get help msg. However when I tried to issue ./a.out -mat_type superlu
> > > -ksp_type preonly -pc_type lu, nothing happened. How should the
> > command be
> > > issued? I tried to get help by running ./a.out -h what appears isn't
> > what I
> > > want.
> > Did you install PETSc with superlu_dist? If so use '-mat_type
> > superlu_dist'
> > [Note: superlu & superlu_dist are different packages - the first one
> > is sequential - the second one is parallel]
> > Satish
> > > Thank you very much. Regards.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20070213/6ff8fb8f/attachment.htm>
