A 3D example of KSPSolve?
Fri Feb 9 23:09:50 CST 2007
On Fri, 9 Feb 2007, Shi Jin wrote:
> MatGetRow are used to build the right hand side
> vector.
  Huh?
> We use it in order to get the number of nonzero cols,
> global col indices and values in a row.
  Huh? What do you do with all this information? Maybe
we can do what you do with this information much more efficiently?
Without all the calls to MatGetRow().
   Barry
> The reason it is time consuming is that it is called
> for each row of the matrix. I am not sure how I can
> get  away without it.
> Thanks.
> Shi
> --- Barry Smith <bsmith at mcs.anl.gov> wrote:
> >   What are all the calls for MatGetRow() for? They
> > are consuming a
> > great deal of time. Is there anyway to get rid of
> > them?
> >    Barry
> > > Sorry that is not informative.
> > > So I decide to attach the 5 files for
> > NP=1,2,4,8,16
> > > for
> > > the 400,000 finite element case.
> > > Please note that the simulation runs over 100
> > steps.
> > > The 1st step is first order update, named as stage
> > 1.
> > > The rest 99 steps are second order updates. Within
> > > that, stage 2-9 are created for the 8 stages of a
> > > second order update. We should concentrate on the
> > > second order updates. So four calls to KSPSolve in
> > the
> > > log file are important, in stage 4,5,6,and 8
> > > separately.
> > > Pleaes let me know if you need any other
> > information
> > > or explanation.
> > > Thank you very much.
> > > Shi
> > > --- Matthew Knepley <knepley at gmail.com> wrote:
> > > > You really have to give us the log summary
> > output.
> > > > None of the relevant
> > > > numbers are in your summary.
> > > >  Thanks,
> > > >    Matt
> > > > On 2/9/07, Shi Jin <jinzishuai at yahoo.com> wrote:
> > > > > Dear Barry,
> > > > > Thank you.
> > > > > I actually have done the staging already.
> > > > > I summarized the timing of the runs in google
> > > > online
> > > > > spreadsheets. I have two runs.
> > > > > 1. with 400,000 finite elements:
> http://spreadsheets.google.com/pub?key=pZHoqlL60quZeDZlucTjEIA
> > > > > 2. with 1,600,000 finite elements:
> http://spreadsheets.google.com/pub?key=pZHoqlL60quZcCVLAqmzqQQ
> > > > > If you can take a look at them and give me
> > some
> > > > > advice, I will be deeply grateful.
> > > > > Shi
> > > > > >   NO, NO, don't spend time stripping your
> > code!
> > > > > > Unproductive
> > > > > >   See the manul pages for
> > > > PetscLogStageRegister(),
> > > > > > PetscLogStagePush() and
> > > > > > PetscLogStagePop(). All you need to do is
> > > > maintain a
> > > > > > seperate stage for each
> > > > > > of your KSPSolves; in your case you'll
> > create 3
> > > > > > stages.
> > > > > >    Barry
> > > > > > > Thank you.
> > > > > > > But my code has 10 calls to KSPSolve of
> > three
> > > > > > > different linear systems at each time
> > update.
> > > > > > Should I
> > > > > > > strip it down to a single KSPSolve so that
> > it
> > > > is
> > > > > > > easier to analysis? I might have the code
> > dump
> > > > the
> > > > > > > Matrix and vector and write another code
> > to
> > > > read
> > > > > > them
> > > > > > > into and call KSPSolve. I don't know
> > whether
> > > > this
> > > > > > is
> > > > > > > worth doing  or should I just send in the
> > > > messy
> > > > > > log
> > > > > > > file of the whole run.
> > > > > > > Thanks for any advice.
> > > > > > > Shi
> > wrote:
> > > > > > > >   Shi,
> > > > > > > >    There is never a better test problem
> > then
> > > > > > your
> > > > > > > > actual problem.
> > > > > > > > Send the results from running on 1, 4,
> > and 8
> > > > > > > > processes with the options
> > > > > > > > -log_summary -ksp_view (use the
> > optimized
> > > > > > version of
> > > > > > > > PETSc (running
> > > > > > > > config/configure.py --with-debugging=0))
> > > > > > > >   Barry
> > > > > > > > > Hi there,
> > > > > > > > > I am tuning our 3D FEM CFD code
> > written
> > > > with
> > > > > > > > PETSc.
> > > > > > > > > The code doesn't scale very well. For
> > > > example,
> > > > > > > > with 8
> > > > > > > > > processes on a linux cluster, the
> > speedup
> > > > we
> > > > > > > > achieve
> > > > > > > > > with a fairly large problem
> > size(million
> > > > of
> > > > > > > > elements)
> > > > > > > > > is only 3 to 4 using the Congugate
> > > > gradient
> > > > > > > > solver. We
> > > > > > > > > can achieve a speed up of a 6.5 using
> > a
> > > > GMRes
> > > > > > > > solver
> > > > > > > > > but the wall clock time of a GMRes is
> > > > longer
> > > > > > than
> > > > > > > > a CG
> > > > > > > > > solver which indicates that CG is the
> > > > faster
> > > > > > > > solver
> > > > > > > > > and it scales not as good as GMRes. Is
> > > > this
> > > > > > > > generally
> > > > > > > > > true?
> > > > > > > > > I then went to the examples and find a
> > 2D
> > > > > > example
> > > > > > > > of
> > > > > > > > > KSPSolve (ex2.c). I let the code ran
> > with
> > > > a
> > > > > > > > 1000x1000
> > > > > > > > > mesh and get a linear scaling of the
> > CG
> > > > solver
> > > > > > and
> > > > > > > > a
> > > > > > > > > super linear scaling of the GMRes.
> > These
> > > > are
> > > > > > both
> > > > > > > > much
> > > > > > > > > better than our code. However, I think
> > the
> > > > 2D
> > > > > > > > nature
> === message truncated ===
> ____________________________________________________________________________________
> Cheap talk?
> Check out Yahoo! Messenger's low PC-to-Phone call rates.
> http://voice.yahoo.com
