understanding the output from -info
Ben Tay zonexo at gmail.com
Fri Feb 9 06:34:34 CST 2007
I've tried to use log_summary but nothing came out? Did I miss out
something? It worked when I used -info...
On 2/9/07, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> On 2/8/07, Ben Tay <zonexo at gmail.com> wrote:
> > i'm trying to solve my cfd code using PETSc in parallel. Besides the
> linear
> > eqns for PETSc, other parts of the code has also been parallelized using
> > MPI.
> Finite elements or finite differences, or what?
> > however i find that the parallel version of the code running on 4
> processors
> > is even slower than the sequential version.
> Can you monitor the convergence and iteration count of momentum and
> poisson steps?
> > in order to find out why, i've used the -info option to print out the
> > details. there are 2 linear equations being solved - momentum and
> poisson.
> > the momentum one is twice the size of the poisson. it is shown below:
> Can you use -log_summary command line option and send the output attached?
> > i saw some statements stating "seq". am i running in sequential or
> parallel
> > mode? have i preallocated too much space?
> It seems you are running in parallel. The "Seq" are related to local,
> internal objects. In PETSc, parallel matrices have inner sequential
> matrices.
> > lastly, if Ax=b, A_sta and A_end from  MatGetOwnershipRange and b_sta
> and
> > b_end from VecGetOwnershipRange should always be the same value, right?
> I should. If not, you are likely going to get an runtime error.
> Regards,
> Lisandro Dalcín
> Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
> Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
> PTLC - Güemes 3450, (3000) Santa Fe, Argentina
> Tel/Fax: +54-(0)342-451.1594
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20070209/77850adc/attachment.htm>
