PetscPrintf/ifort 9.1
Sanjay Govindjee sanjay at ce.berkeley.edu
Wed Aug 29 04:39:14 CDT 2007
As a side note to this discussion, on some machines, a call to flush
will "interleave" the
output from write(*,*) with the PETSc output instead of buffering it
until the end.
-sanjay
> P.S. The reason why I care is because on any compiler I've used (other
> than Intel), write(*,*) prints out at different times and not in
> sequence with PETSc so all my output comes out after PETSc is done
> outputting. Using PetscPrintf, I can have everything print out in order.
