hypre and PETSc's FORTRAN Interface (PLEASE IGNORE MY PREVIOUS EMAIL WITH SAME TITLE!)
Mon Aug 27 12:22:32 CDT 2007
  Keita,
    If you know the correct options with --host that are needed you can try
adding them to python/PETSc/packages/hypre.py as additional arguments when
--with-batch is on. We haven't done this ourselves because we are not familar
with this feature of auto-conf. Please send us your results and we'll add them
to petsc-dev.
    Thanks and take care,
     Barry
On Mon, 27 Aug 2007, Keita Teranishi wrote:
> Hi Satish,
> Our environment requires cross compiling, set by --with-batch option for PETSc's configure.  However, it doesn't set the correct cross-compiling option for hypre's configure script (--host).  I am wondering if this happen only for our environment...
> Thanks,
> Keita
> -----Original Message-----
> From: owner-petsc-users at mcs.anl.gov [mailto:owner-petsc-users at mcs.anl.gov] On Behalf Of Satish Balay
> Sent: Monday, August 27, 2007 10:46 PM
> To: petsc-users at mcs.anl.gov
> Subject: RE: hypre and PETSc's FORTRAN Interface (PLEASE IGNORE MY PREVIOUS EMAIL WITH SAME TITLE!)
> If you download hypre tarball [from PETSc website] manually - its
> best to install it with PETSc configure - with the option:
> --download-hypre=/path-to/hypre.tar.gz
> Satish
> > Hi,
> > Please ignore my previous email.  I found the error was related to hypre's configure script (not PETSc). I found PETSc configure script disables Babel for installing hypre.
> > Sorry,
> > Keita
> > ________________________________
> > From: owner-petsc-users at mcs.anl.gov [mailto:owner-petsc-users at mcs.anl.gov] On Behalf Of Keita Teranishi
> > Sent: Monday, August 27, 2007 2:02 PM
> > Subject: hypre and PETSc's FORTRAN Interface
> > Hi,
> > I am trying to build petsc with FORTRAN interface and hypre together, but having a configure error message due to language compatibility between FORTRAN and C++.  More precisely, the configure script complains that PETSc's FORTRAN interface cannot be linked to some C++ objects of hypre.  I thought the latest version of hypre is implemented in C except some optional packages such as Babel.  If this is right, we could use FOTRAN interface to use PETSc and hypre together.
> > I would like to know how PETSc accesses to hypre.
> > Thanks,
> > Keita
