Routine to convert matrix to CSR format
Hong Zhang hzhang at mcs.anl.gov
Sat Aug 25 16:36:08 CDT 2007
You can use
MatGetRowIJ()
(http://www-unix.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Mat/MatGetRowIJ.html)
and
MatGetArray()
(http://www-unix.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Mat/MatGetArray.html#MatGetArray)
Hong
On Sat, 25 Aug 2007, Ben Tay wrote:
> Hi,
> May I know if there's a routine which can convert a matrix initially
> created using MatCreateSeqAIJ to compressed row format (CSR) ? Then I
> would like to view it in my visual fortran debugger. In other words, the
> matrix is in standard array format, not Mat.
> Thanks
