Question regarding PCMG
TsuyoshiKoyama(berkeley) tkoyama at berkeley.edu
Tue Aug 14 10:59:30 CDT 2007
With regards to the first problem I had, I was misinterpreting how
the function PCApply should work. I had assumed that you could pass
in an initial vector x_init to the PCApply by calling PCApply(x, x_init) and
have x_init
rewritten by the result. Unfortunately this is not the correct way to do
things
in PETSc and I have figured out a way to use the KSPRichardson context
for the stationary solver I have coded as my own PC object.
For the second problem, the fix for the first problem will avoid it since I
will no longer be trying to use the KSPPreonly but the KSPRichardson.
Thank you very much for your help, Mr. Knepley!
Sincerely,
-Tsuyoshi Koyama
----- Original Message -----
To: <petsc-users at mcs.anl.gov>
Sent: Tuesday, August 14, 2007 3:02 PM
Subject: Re: Question regarding PCMG
> On 8/13/07, TsuyoshiKoyama(berkeley) <tkoyama at berkeley.edu> wrote:
>> As for the second case, the reason I might not select a coarse solver is
>> since I
>> am trying to solve a Helmholtz equation and the coarse grid solve might
>> not
>> be
>> correct enough to apply. Thus, you may just point out that the coarse
>> grid
>> should
>> be large enough to resolve the so called low frequency error and that if
>> you
>> do so
>> you should still be able to solve direct, but I was curious on testing
>> different types
>> of operations at the coarsest level.
> The coarse solver can be set to anything you choose. You just extract the
> coarse KSP and set the type.
>  Thanks,
>    Matt
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
