Problem with using ADD_VALUES
Mon Aug 6 06:26:15 CDT 2007
1) You could use MatZeroEntries() to zero out the matrix
2) You could call MatAssembly*(m, MAT_ASSEMBLY_FLUSH) in
    between INSERT and ADD.
  MAtt
On 8/6/07, Ben Tay <zonexo at gmail.com> wrote:
> Hi,
> I am trying to insert values into a matrix. I used to use INSERT_VALUES
> with MatSetValues or MatSetValue. However, since I need to add values to
> the same II,JJ location more than 1 time, I have to use ADD_VALUES with
> MatSetValues.
> However I got this error message:
> Object is in wrong state!
> Cannot mix add values and insert values!
> My code is something like this:
> call MatSetValues(A_mat,1,II,1,JJ,0.,INSERT_VALUES,ierr)         ->
>    to reset values at II,JJ to zero 1st
> do JJ=1,5
>     call
> MatSetValues(A_mat,1,II,1,int_A(m,JJ)-1,big_A(m,JJ),ADD_VALUES,ierr)
>          ->         to put values into the matrix, with the possibility
> of adding values to the same II,JJ locations more than once.
> end do
> How can I solve this problem?
> Thanks.
experiments is infinitely more interesting than any results to which
their experiments lead.
-- Norbert Wiener
