Running 'make' command in verbose mode
Sumit Vaidya sumit_vaidya at persistent.co.in
Thu Aug 2 00:26:04 CDT 2007
My interest is to use PETSc by building the libraries.
I got the answer. Thank you for the information. Yes, the build procedure is
equivalent to autoconf model.
Sumit
-----Original Message-----
From: owner-petsc-users at mcs.anl.gov [mailto:owner-petsc-users at mcs.anl.gov]
On Behalf Of Satish Balay
Sent: Wednesday, August 01, 2007 8:25 PM
To: petsc-users at mcs.anl.gov
Subject: RE: Running 'make' command in verbose mode
Is your interest either of:
 - use PETSc [by building PETSc libraries] -
 - investigate the build infrastructure in PETSc?
If its the second one - could I enquire for what purpose would such
investigation be useful?
On Wed, 1 Aug 2007, Sumit Vaidya wrote:
> I found your build procedure something different than the other
> applications. So I was eager to know about it.
> Other applications produce makefiles through configure script and use it
for
> actual building. But here I found makefiles are already present along with
> the package and configure script is mainly doing some testing and
producing
> architecture configuration files.
This is inference is incorrect. [there is not much difference in the 2
methods you mention - except for a different organization of the
makefiles]
Our model is equivalent to autoconf model [you refer to]. With
autoconf, [from what I understand] Makefile.in has the pre-written
make targets [by the package developer], and then there are some
variables [like CC etc] that configure detects and substitutes - and
creates Makefile.
We also have pre-written targets, and variables that configure detects
and substitutes. The difference is - in case of autoconf, the
generated makefile has both targets & variables. We chose to split up
generated variables into different makefiles in bmake/$PETSC_ARCH, and
the pre-written targets into bmake/common/* files. [And then the
toplevel makefile that included the relavent generated/precoded
targets]
So, in both cases, the 'makefiles' are useable by the user only after
configure is run.
Hope this helps,
Satish
DISCLAIMER
This e-mail may contain privileged and confidential information which is the property of Persistent Systems Pvt. Ltd. It is intended only for the use of the individual or entity to which it is addressed. If you are not the intended recipient, you are not authorized to read, retain, copy, print, distribute or use this message. If you have received this communication in error, please notify the sender and delete all copies of this message. Persistent Systems Pvt. Ltd. does not accept any liability for virus infected mails.
