Running 'make' command in verbose mode
Sumit Vaidya sumit_vaidya at persistent.co.in
Wed Aug 1 09:22:30 CDT 2007
I found your build procedure something different than the other
applications. So I was eager to know about it.
Other applications produce makefiles through configure script and use it for
actual building. But here I found makefiles are already present along with
the package and configure script is mainly doing some testing and producing
architecture configuration files.
Sumit
-----Original Message-----
From: owner-petsc-users at mcs.anl.gov [mailto:owner-petsc-users at mcs.anl.gov]
On Behalf Of Satish Balay
Sent: Wednesday, August 01, 2007 7:17 PM
To: petsc-users at mcs.anl.gov
Subject: Re: Running 'make' command in verbose mode
Could you tell us what exactly are you trying to acomplish?
you can try:
make ACTION=lib tree
Satish
On Wed, 1 Aug 2007, Sumit Vaidya wrote:
> Hi,
> I want to run the 'make' command in verbose mode.
> I want to know which files(.c/.f) the compiler(gcc/g77) takes as an input
> and which are the libraries that are created as an output.
> How to achieve this?
> Regards,
> Sumit
> DISCLAIMER
> This e-mail may contain privileged and confidential information which is
the property of Persistent Systems Pvt. Ltd. It is intended only for the use
of the individual or entity to which it is addressed. If you are not the
intended recipient, you are not authorized to read, retain, copy, print,
distribute or use this message. If you have received this communication in
error, please notify the sender and delete all copies of this message.
Persistent Systems Pvt. Ltd. does not accept any liability for virus
infected mails.
DISCLAIMER
This e-mail may contain privileged and confidential information which is the property of Persistent Systems Pvt. Ltd. It is intended only for the use of the individual or entity to which it is addressed. If you are not the intended recipient, you are not authorized to read, retain, copy, print, distribute or use this message. If you have received this communication in error, please notify the sender and delete all copies of this message. Persistent Systems Pvt. Ltd. does not accept any liability for virus infected mails.
