CSR Sparse Matrix Query
Dr. Timothy Stitt timothy.stitt at ichec.ie
Mon Apr 23 06:33:20 CDT 2007
Sorry just a couple more questions.
I am using Fortran. Do I have to perform some operation to switch from
column-major to row-major representation before calling the
MatCreateSeqAIJWithArrays routine? Also does this routine replace the
call to the MatCreate() routine? I am assuming I still need to do the
assembling of the matrix afterwards?
Tim.
Mads Fredrik Skoge Hoel wrote:
> I was just dealing with this a few moments ago. Remember to make sure the
> row and col array start at 0 (and stop at nnz and n-1 respectively). I
> just did that mistake.
> Regards,
> Mads
>>   You can also use MatCreateSeqAIJWithArrays() and in parallel
>> MatCreateMPIAIJWithArrays(). These are intended for those who already
>> form the matrix in CSR format.
>>    Barry
>> On Sat, 21 Apr 2007, Randall Mackie wrote:
>>> Hi Tim,
>>> There's no need to generate a dense matrix if you're dealing with sparse
>>> matrices. There are many approaches, but if you just want to get your
>>> existing matrix into PETSc, you can use something like the following
>>> (written
>>> in Fortran, but almost the same in C):
>>> Assume the global vector length is np:
>>>       call VecCreateMPI(PETSC_COMM_WORLD,PETSC_DECIDE,np,b,ierr)
>>>       call VecDuplicate(b,xsol,ierr)
>>>       call VecGetLocalSize(b,mloc,ierr)
>>>       call VecGetOwnershipRange(b,Istart,Iend,ierr)
>>>       do i=Istart+1,Iend
>>>         loc(i)=i-1
>>>       end do
>>>       ALLOCATE (d_nnz(mloc), o_nnz(mloc), STAT=istat)
>>> Note: the d_nnz and o_nnz are used to determine the pre-allocation of
>>> the
>>> global matrix
>>> according to the PETSc manual (basically just looping through and
>>> figuring out
>>> which
>>> elements are in d_nnz and which are in o_nnz).
>>> Then you can create the matrix:
>>>       call MatCreateMPIAIJ(PETSC_COMM_WORLD,mloc,mloc,np,np,
>>>      .     PETSC_NULL_INTEGER, d_nnz, PETSC_NULL_INTEGER,
>>>      .     o_nnz,P,ierr)
>>> And then I had a subroutine to fill it like this (the critical part is
>>> the
>>> check
>>> whether that part of the matrix is owned by the current processor):
>>>       jj=0
>>>       do i=1,l
>>>         do k=2,n
>>>           do j=2,m
>>>             jj=jj+1
>>>             row = jj-1
>>>             IF (jj >= Istart+1 .and. jj <= Iend) THEN
>>>               if(k.ne.2) then
>>>                 fact=-rijcy*dx*dy/z(k-1)       ! Hxijc
>>>                 ic=ic+1
>>>                 v(ic)=fact
>>>                 col(ic)=ijkhx(i,j,k-1)-1
>>>               end if
>>> [snip code]
>>>               call MatSetValues(A,i1,row,ic,col,v,INSERT_VALUES,
>>>      .             ierr)
>>> [and finally at the end you assemble the matrix]
>>>       call MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY,ierr)
>>>       call MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY,ierr)
>>> Since these early days, I've switched over to using Distributed Arrays,
>>> which in my opinion are much better and much easier to use.
>>> Hope this helps,
>>> Randy
>>> Dr. Timothy Stitt wrote:
>>>> Hi all,
>>>> I have just begun to use PETSc and I have already ran into a problem.
>>>> Apologies if this has been dealt with before.
>>>> My code currently generates its own non-distributed Hamiltonian sparse
>>>> matrix in CSR format (due to the large size of the dense
>>> representation). I
>>>> want to exploit PETSc's (actually SLEPc's) eigensolver routines and
>>> hence I
>>>> need to convert my CSR representation into PETSc CSR representation
>>> for use
>>>> by the eigensolver.
>>>>  From reading the documentation I am under the impression that you
>>> initially
>>>> supply the dense matrix to the PETSc matrix routines for conversion to
>>> PETSc
>>>> CSR representation. In my case I do not generate the dense matrix. I
>>> would
>>>> be grateful if someone could guide me on to how to create a PETSC
>>> sparse
>>>> matrix from my own in-code generated sparse matrix.
>>>> Thanks in advance for any assistance that can be provided.
>>>> Regards,
>>>> Tim.
Dr. Timothy Stitt <timothy_dot_stitt_at_ichec.ie>
HPC Application Consultant - ICHEC (www.ichec.ie)
Dublin Institute for Advanced Studies
5 Merrion Square - Dublin 2 - Ireland
+353-1-6621333 (tel) / +353-1-6621477 (fax) / +353-874195427 (mobile)
