CSR Sparse Matrix Query
Sat Apr 21 10:56:34 CDT 2007
  You can also use MatCreateSeqAIJWithArrays() and in parallel
MatCreateMPIAIJWithArrays(). These are intended for those who already
form the matrix in CSR format.
   Barry
On Sat, 21 Apr 2007, Randall Mackie wrote:
> Hi Tim,
> There's no need to generate a dense matrix if you're dealing with sparse
> matrices. There are many approaches, but if you just want to get your
> existing matrix into PETSc, you can use something like the following (written
> in Fortran, but almost the same in C):
> Assume the global vector length is np:
>       call VecCreateMPI(PETSC_COMM_WORLD,PETSC_DECIDE,np,b,ierr)
>       call VecDuplicate(b,xsol,ierr)
>       call VecGetLocalSize(b,mloc,ierr)
>       call VecGetOwnershipRange(b,Istart,Iend,ierr)
>       do i=Istart+1,Iend
>         loc(i)=i-1
>       end do
>       ALLOCATE (d_nnz(mloc), o_nnz(mloc), STAT=istat)
> Note: the d_nnz and o_nnz are used to determine the pre-allocation of the
> global matrix
> according to the PETSc manual (basically just looping through and figuring out
> which
> elements are in d_nnz and which are in o_nnz).
> Then you can create the matrix:
>       call MatCreateMPIAIJ(PETSC_COMM_WORLD,mloc,mloc,np,np,
>      .     PETSC_NULL_INTEGER, d_nnz, PETSC_NULL_INTEGER,
>      .     o_nnz,P,ierr)
> And then I had a subroutine to fill it like this (the critical part is the
> check
> whether that part of the matrix is owned by the current processor):
>       jj=0
>       do i=1,l
>         do k=2,n
>           do j=2,m
>             jj=jj+1
>             row = jj-1
>             IF (jj >= Istart+1 .and. jj <= Iend) THEN
>               if(k.ne.2) then
>                 fact=-rijcy*dx*dy/z(k-1)       ! Hxijc
>                 ic=ic+1
>                 v(ic)=fact
>                 col(ic)=ijkhx(i,j,k-1)-1
>               end if
> [snip code]
>               call MatSetValues(A,i1,row,ic,col,v,INSERT_VALUES,
>      .             ierr)
> [and finally at the end you assemble the matrix]
>       call MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY,ierr)
>       call MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY,ierr)
> Since these early days, I've switched over to using Distributed Arrays,
> which in my opinion are much better and much easier to use.
> Hope this helps,
> Randy
> Dr. Timothy Stitt wrote:
> > Hi all,
> > I have just begun to use PETSc and I have already ran into a problem.
> > Apologies if this has been dealt with before.
> > My code currently generates its own non-distributed Hamiltonian sparse
> > matrix in CSR format (due to the large size of the dense representation). I
> > want to exploit PETSc's (actually SLEPc's) eigensolver routines and hence I
> > need to convert my CSR representation into PETSc CSR representation for use
> > by the eigensolver.
> >  From reading the documentation I am under the impression that you initially
> > supply the dense matrix to the PETSc matrix routines for conversion to PETSc
> > CSR representation. In my case I do not generate the dense matrix. I would
> > be grateful if someone could guide me on to how to create a PETSC sparse
> > matrix from my own in-code generated sparse matrix.
> > Thanks in advance for any assistance that can be provided.
> > Regards,
> > Tim.
