CSR Sparse Matrix Query
Dr. Timothy Stitt timothy.stitt at ichec.ie
Sat Apr 21 06:50:21 CDT 2007
Hi all,
I have just begun to use PETSc and I have already ran into a problem.
Apologies if this has been dealt with before.
My code currently generates its own non-distributed Hamiltonian sparse
matrix in CSR format (due to the large size of the dense
representation). I want to exploit PETSc's (actually SLEPc's)
eigensolver routines and hence I need to convert my CSR representation
into PETSc CSR representation for use by the eigensolver.
 From reading the documentation I am under the impression that you
initially supply the dense matrix to the PETSc matrix routines for
conversion to PETSc CSR representation. In my case I do not generate the
dense matrix. I would be grateful if someone could guide me on to how to
create a PETSC sparse matrix from my own in-code generated sparse matrix.
Thanks in advance for any assistance that can be provided.
Tim.
Dr. Timothy Stitt <timothy_dot_stitt_at_ichec.ie>
HPC Application Consultant - ICHEC (www.ichec.ie)
Dublin Institute for Advanced Studies
5 Merrion Square - Dublin 2 - Ireland
+353-1-6621333 (tel) / +353-1-6621477 (fax) / +353-874195427 (mobile)
