Preallocation for external direct solvers
Sat Apr 14 16:14:03 CDT 2007
   Paul,
    This is a bug in how MatSetFromOptions() changes the type. You can
use instead
   MatConvert(J,MATAIJMUMPS,MAT_REUSE_MATRIX,J,ierr)
for now and I will investigate how the bug can be fixed.
  Another, maybe better alternative is to use
  MatCreate(comm,J,ierr)
  MatSetSizes(J,....)
  MatSetFromOptions(J,ierr)
  MatSeqAIJSetPreallocation(....)
  MatMPIAIJSetPreallocation(...)
  Sorry and thanks for reporting the problem,
   Barry
  The bug is that MatSetType() does not know that AIJMUMPS is inherited from
AIJ and hence destroys the AIJ data structure (including the preallocation
information) before creating a whole new AIJMUMPS matrix.
On Sat, 14 Apr 2007, Paul T. Bauman wrote:
> Hello,
> I'm developing some code and am using direct solvers (for the moment), in
> particular MUMPS and SuperLU. I noticed that PETSc is not preallocating the
> memory for it even though I specify maximum number of entries per row.
>       call MatCreateSeqAIJ(PETSC_COMM_WORLD,total_num_dofs,total_num_dofs, &
>            max_number_nonzeros_row,PETSC_NULL_INTEGER, J ,ierr)
>       call MatSetFromOptions(J,ierr)
>       call SNESSetJacobian(snes,J,J,FormJacobian,PETSC_NULL_OBJECT,ierr)
> When I print -info:
> [0] User provided function(): (Fortran):PETSc successfully started: procs 1
> [0] User provided function(): Running on machine: dhcp-67-30.ices.utexas.edu
> [0] PetscCommDuplicate(): Duplicating a communicator 1140850688 -2080374784
> max tags = 2147483647
> [0] PetscCommDuplicate(): Using internal PETSc communicator 1140850688
> -2080374784
> -2080374784
> -2080374784
> -2080374784
> [0] MatConvert_AIJ_AIJMUMPS(): Using MUMPS for LU factorization and solves.
> -2080374784
>  0 SNES Function norm 8.500000000000e-01
> [0] MatSetUpPreallocation(): Warning not preallocating matrix storage
> So, of course, this really slows down the code for even small problems (20000
> dof).  Same story for SuperLU. Should I use a different call to do the
> preallocation?
> Thanks for any suggestions.
> Best,
> Paul
