Question about memory used by PetsC Objects
Fri Apr 13 09:34:22 CDT 2007
There is a way to get exactly what you want which is not really very hard.
Petsc allows you to easily override PetscMalloc() and PetscFree() which
we use for everything. You could just keep a running static tally of the sizes
and then call the regular version. This would only take a few lines of code.
Take a look at
http://www-unix.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Sys/PetscSetMalloc.html
   Matt
On 4/13/07, Laurent Nguyen <laurent.nguyen at idris.fr> wrote:
> Yes, I've tested the argument -memory_info. I've seen the memory given
> to me is the same memory given by a PetscMemoryGetCurrentUsage() before
> PetscFinalize(). I didn't know it was the same ^^.
> It is not the memory I need. I would like to have the real memory used
> by my program (It is a little difficult to explain clearly): for
> example, if I create 2 vectors of size 100, the program is consuming
> 2*8*100 bytes. But later, when I destroy only 1 vector, the programs is
> consuming 1*8*100 bytes. This is this kind of information that I need
> (more precisely, the max). I tell you that because, in my context of
> computation, I've only 1.5Go of memory per processors. And the memory
> given by the argument -memory_info was 2.4Go. So I was perplex about
> that. But now I understand how your function is running.
> But thanks to yours functions, I can now better manage the memory of my
> objects!
> Regards,
> NGUYEN Anh-Khai Laurent
> Equipe Support Utilisateur
> Email    :    laurent.nguyen at idris.fr
> Tél      :    01.69.35.85.66
> Adresse  :    IDRIS - Institut du Développement et des Ressources en
>                Informatique Scientifique
>                CNRS
>                Batiment 506
>                BP 167
>                F - 91403 ORSAY Cedex
> Site Web :    http://www.idris.fr
> >> Barry,
> >> I thank you for your help. So I tried to apply the functions. It seems
> >> that PetscMemoryGetCurrentUsage() gives the total amount of memory
> >> allocated at the point of the program where it is placed. But, if a
> >> object is deallocated, PetscMemoryGetCurrentUsage() doesn't take it.
> >> I would like to try PetscMemoryGetMaximumUsage() at the end of the
> >> program hoping it gives me the maximum memory used by my program but
> >> there are problems. When I put PetscMemoryGetMaximumUsage(), I've this
> >> error at the execution:
> >> [0]PETSC ERROR: --------------------- Error Message
> >> [0]PETSC ERROR: Object is in wrong state!
> >> [0]PETSC ERROR: To use this function you must first call
> >> PetscMemorySetGetMaximumUsage()!
> >> So I put PetscMemorySetGetMaximumUsage() before, but at linking, it
> >> didn't find PetscMemorySetGetMaximumUsage in the petsc libraries. I
> >> thought I made a bad install but when I tried on another machine, I've
> >> the same problem.
> > The function is definitely there (check src/sys/memory/mem.c). You can try
> > a short test:
> >  cd src/ksp/ksp/examples/tutorials
> >  make ex2
> >  ./ex2 -memory_info
> >  ./ex2 -malloc_log
> > Also, I have fixed the specific logging errors you pointed out in the dev
> > copy, but we are doing a code review to make sure no other omissions
> > are lurking.
> >  Matt
> >> Best regards,
> >>                CNRS
> >>                Batiment 506
> >>                BP 167
> >> Barry Smith a écrit :
> >> >   Laurent,
> >> >    The memory usage printed with -log_summary is not correct.
> >> > Much of the memory used is not printed out.
> >> >    You can use PetscMemoryGetCurrentUsage() and
> >> > in your code before and after creating a filling in PETSc objects
> >> > to see how much memory they are used. You can also use
> >> PetscMallocDump()
> >> > at any point to see exactly where in PETSc and how much all of PETSc's
> >> > memory was allocated.
> >> >    Barry
> >> > On Thu, 12 Apr 2007, Laurent Nguyen wrote:
> >> >> Hi,
> >> >> I'm a Petsc user, but I'm beginning to use petsc in a supercomputation
> >> >> context. So, I'm trying parallel versions of my old mono-processed
> >> programs.
> >> >> But I've some difficulties to determine how much memory my program
> >> use. (I
> >> >> give a little example). In this example on one processor (with
> >> these command
> >> >> line arguments: -mat_type mpiaij -pc_type none -log_summary), I
> >> created one
> >> >> mpiaij matrix (size = 500*500) and two vectors (size = 500). I've this
> >> >> information from output:
> >> >>   Matrix Object:
> >> >>     type=mpiaij, rows=250000, cols=250000
> >> >>     total: nonzeros=749996, allocated nonzeros=1750000
> >> >> To me, there is an array of 1750000 double precision number of 8
> >> bytes =
> >> >> 14000000 bytes (14Mo).
> >> >> Same for vectors: 2*8*250000 = 4 Mo
> >> >> But in the log summary, I've:
> >> >> Memory usage is given in bytes:
> >> >> Object Type          Creations   Destructions   Memory
> >> Descendants' Mem.
> >> >> --- Event Stage 0: Main Stage
> >> >>               Viewer     1              1          0     0
> >> >>            Index Set     2              2        672     0
> >> >>                  Map    16             16       4992     0
> >> >>                  Vec    10             10    2006576     0
> >> >>          Vec Scatter     1              1          0     0
> >> >>               Matrix     3              3       1068     0
> >> >>        Krylov Solver     1              1      17208     0
> >> >>       Preconditioner     1              1          0     0
> >> >> I don't understand this output...If you have some documentation
> >> about how
> >> >> Petsc deals with memory or if you can explain, I would be very
> >> interested.
> >> >> This is a problem because I'm working on IBM SP4, and I've
> >> limitations of
> >> >> memory (700mb for data and 700mb for stack). I think the objects
> >> created by
> >> >> Petsc is created in the stack memory, but as I cannot determine
> >> exactly the
> >> >> memory usage, I cannot verify.
> >> >> Thank you for your advices,
> >> >> Best regards
The government saving money is like me spilling beer. It happens, but
never on purpose.
