how to clear number of iterations
Randall Mackie randy at geosystem.us
Tue Apr 10 15:05:05 CDT 2007
I have a situation where I am calling a KSP to solve various systems
of equations (same matrix, different right hand sides).
Once in a while, one of the solutions does not require any iterations, ie,
it's starting solution that I set is correct.
The problem is that when I call KSPGetIterationNumber, it has retained the
number of iterations from the previous solve.
Is there some call I can make that would clear this or set it to zero
in between KSP calls? That way, I can print out the true number of
iterations for each solve.
Thanks, Randy
Randall Mackie
GSY-USA, Inc.
PMB# 643
2261 Market St.,
San Francisco, CA 94114-1600
Tel (415) 469-8649
Fax (415) 469-5044
California Registered Geophysicist
License No. GP 1034
