Error with using downloaded mpich and lammpi shared
Ben Tay zonexo at gmail.com
Sun Apr 8 22:29:21 CDT 2007
when trying to configure usign download-mpich=1, I got this error:
Running configure on MPICH; this may take several
minutes
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
details):
Error running configure on MPICH: Could not execute 'cd
/lsftmp/g0306332/petsc-
2.3.2-p8-new/externalpackages/mpich2-1.0.4p1;./configure
--prefix=/lsftmp/g0306332/petsc-2.3.2-p8-new/externalpackages/mpich2-1.0.4p1/ia64
CC="/scratch1/g0306332/intel/cc/bin/icc  -fPIC -O " CXX="g++  -Wall
-Wwrite-strings -O   -fPIC " F90="/scratch1/g0306332/intel/fc/bin/ifort
-fPIC -O  " F77="/scratch1/g0306332/intel/fc/bin/ifort  -fPIC -O  "
--enable-sharedlibs=gcc --without-mpe --with-pm=gforker':
Configuring MPICH2 version 1.0.4p1 with '--prefix=/lsftmp/g0306332/petsc-
2.3.2-p8-new/externalpackages/mpich2-1.0.4p1/ia64'
'CC=/scratch1/g0306332/intel/cc/bin/icc  -fPIC -O ' 'CXX=g++  -Wall
-Wwrite-strings -O   -fPIC ' 'F90=/scratch1/g0306332/intel/fc/bin/ifort
-fPIC -O  ' 'F77=/scratch1/g0306332/intel/fc/bin/ifort  -fPIC -O  '
'--enable-sharedlibs=gcc' '--without-mpe' '--with-pm=gforker' 'CFLAGS=-mp
-DANSI -I/app1/ia64/imsl/imsl/cnl600/itanium/include' 'F90FLAGS=-w -nologo
-fpp -I/app1/ia64/imsl/CTT6.0/include/linx64_i9 -I/usr/local/mpich-
1.2.7p1/include'
'FFLAGS=-w -nologo -fpp -I/app1/ia64/imsl/CTT6.0/include/linx64_i9
-I/usr/local/mpich-1.2.7p1/include'
Executing mpich2prereq in
1.0.4p1/src/mpid/ch3 with
Executing mpich2prereq in /lsftmp/g0306332/petsc-2.3.2-p8-new
/externalpackages/mpich2-1.0.4p1/src/mpid/ch3/channels/sock
sourcing /lsftmp/g0306332/petsc-2.3.2-p8-new/externalpackages/mpich2-
1.0.4p1/src/pm/gforker/mpich2prereq
checking for gcc... /scratch1/g0306332/intel/cc/bin/icc  -fPIC -O
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether /scratch1/g0306332/intel/cc/bin/icc  -fPIC -O  accepts
-g... yes
checking for /scratch1/g0306332/intel/cc/bin/icc  -fPIC -O  option to accept
ANSI C... none needed
checking for type of weak symbol support... pragma weak
checking whether __attribute__ ((weak)) allowed... yes
checking for multiple weak symbol support... yes
configure: error: The values of the environment variables F77
(=/scratch1/g0306332/intel/fc/bin/ifort  -fPIC -O  ) and FC (=ifort) are not
the same.  Unset one or both and rerun configure
 it seems that the F77 and FC environment variables are different. I want to
use (=/scratch1/g0306332/intel/fc/bin/ifort). How can I configure them?
 If I use the lammpi which the sch provide, I got this error msg:
./config/configure.py --with-cc=icc --with-fc=ifort
--download-f-blas-lapack=1 --download-hypre=1 --with-debugging=0
--with-mpi-include=/app1/ia64/lammpi/include/
--with-mpi-lib=/app1/ia64/lammpi/lib/libmpi.la
--with-mpirun=/app1/ia64/lammpi/bin/mpirun --with-x=0 --with-shared
I also replace libmpi.la with libmpi.a but both cannot work.
Shared libraries cannot be built using MPI provided.
Either rebuild with --with-shared=0 or rebuild MPI with shared library
support
What's the extension for shared libraries for ia64 platform? Is it *.so?
thanks alot
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20070409/015f7aba/attachment.htm>
