A simple question.
Hong Zhang hzhang at mcs.anl.gov
Mon Apr 2 20:48:41 CDT 2007
The problem is at VecSetValues().
>     Vec x;
>     PetscInt n =10;
>     PetscErrorCode ierr;
>     PetscMPIInt size;
>     PetscScalar one=1.0;
>     double vd[3]={2.,2.,2.};
>     int indices[3]={0,5,7};
>     PetscScalar* v=&vd[0];
>     ierr = PetscInitialize(&argc,&args,(char *)0,help);  CHKERRQ(ierr);
>     ierr = MPI_Comm_size(PETSC_COMM_WORLD,&size);        CHKERRQ(ierr);
>     printf("Number of processors : %d\n",size);
>     ierr = VecCreate(PETSC_COMM_WORLD,&x);               CHKERRQ(ierr);
>     ierr = VecSetSizes(x,PETSC_DECIDE,n);                CHKERRQ(ierr);
>     ierr = VecSetType(x,"mpi");                          CHKERRQ(ierr);
>     ierr = VecSetFromOptions(x);                         CHKERRQ(ierr);
>     ierr = VecSet(x,one);                                CHKERRQ(ierr);
>     VecSetValues(x,3,indices,v,ADD_VALUES);
Here, when np = 2, both processors add v=2.0 into the vector at 0,5
7th component, resulting different output than np=1.
You should call VecGetOwnershipRange(Vec x,PetscInt *low,PetscInt *high),
then have each processor set values into its own part.
Hong
>     VecAssemblyBegin(x);
>     VecAssemblyEnd(x);
>     ierr = VecView(x,PETSC_VIEWER_STDOUT_WORLD);         CHKERRQ(ierr);
>     VecDestroy(x);                                       CHKERRQ(ierr);
>     ierr = PetscFinalize();                              CHKERRQ(ierr);
>     return 0;
> 3. And now I'm running it on a dual core processor for -n 1 & 2. These are
> the results.
> Number of processors : 1
> Process [0]
> 3
> 1
> 1
> 1
> 1
> 3
> 1
> 3
> 1
> 1
> Number of processors : 2
> Process [0]
> 5
> 1
> 1
> 1
> 1
> Process [1]
> 5
> 1
> 5
> 1
> 1
> This is not I was really looking for. I intended to have the same output
> (concerning the vector entries) and no double-printings (like "Number of
> processors : 2").
> Do you think this is an MPI setup problem, or have I not really understood
> what the above code does?
> Kind regards,
> Fotios Karaoulanis._
> ps. Congratulations on your excellent work!
> Fotios E. Karaoulanis
> Dipl. Civil Engineer, MSc TUM
> tel     +30 2310 458913
> fax     +30 2310 458913
> mob     +30 6948 179452
> e-mail  fkar at nemesis-project.org
> Consider visiting www.nemesis-project.org.
> Home of an experimental finite element code.
