about MPI_Comm_size(PETSC_COMM_WORLD,&size)
Thu Oct 26 01:19:37 CDT 2006
As long as you plan to run multiple MPI procs on the same machine,
'localonly' option is appropriate and should be fine.
If you wish to avoid using this option - then you probably need to run
the mpd configuration tool and set things up correctly [don't know
exactly what that would be]. Its certainly not something which
requires a reinstall of mpich.
Satish
On Thu, 26 Oct 2006, Yixun Liu wrote:
> Hi,
> I tried what you said and mpiexec - n 2 localonly is ok. Do I need to reinstall the MPICH2?
> Best,
> Yixun
> From: "Satish Balay" <balay at mcs.anl.gov>
> To: <petsc-users at mcs.anl.gov>
> Sent: Thursday, October 26, 2006 1:21 PM
> Subject: Re: about MPI_Comm_size(PETSC_COMM_WORLD,&size)
> >> Hi,
> >> Can I compiler and link it in VC enviroment and then copy the .exe to a directory.
> > you can just go to the dir which has the executable. [copy is not necessary]
> >> Then, at command line run mpiexec -n 2 xxx.exe?
> > yes
> >> I try it, but the error is "Credentials for yxliu rejected
> >> connecting to dmrc-6700512 Aborting: Unable to connect to
> >> dmrc-6700512". I have used wmpiregister to register the accout
> >> correctly.
> > Sounds like your mpi install is not setup properly. I'm guessing
> > you are using mpich2. I don't know enough about this version.
> > Can you check if any of the following work?
> > executable
> > mpiexec -n 1 executable
> > mpiexec -n 2 executable
> > mpiexec -n 2 -localonly executable
> > Satish
