about option database
Tue Oct 24 21:31:19 CDT 2006
Options can be read from:
  1) The command line
  2) a ~/.petscrc file
  3) the PETSC_OPTIONS environment variable
   Matt
On 10/24/06, Yixun Liu <yxliu at fudan.edu.cn> wrote:
>  Hi,
> I am reading the source code of
> $PETSC_DIR\src\ksp\ksp\examples\tutorials\ex2.c. Some codes are,
>   PetscInitialize(&argc,&args,(char *)0,help);
>   ierr = PetscOptionsGetInt(PETSC_NULL,"-m",&m,PETSC_NULL);CHKERRQ(ierr);
> However, I cannot find the default option database file .petscrc in user
> home directory.
> Regards,
> Yixun
"Failure has a thousand explanations. Success doesn't need one" -- Sir Alec
Guiness
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20061024/ef057cd3/attachment.htm>
