Undefined symbol in executing time
Tue Oct 24 14:17:04 CDT 2006
To look for build errors, consult the file $PETSC_DIR/make_log_*, or
send it to us.
   Matt
On 10/24/06, Isabel Gil <misabel at litec.csic.es> wrote:
> Hello PETSc's users!
> I am trying to use PETSc for the first time along with another library.
> I compile my program without any problem but when I try to execute it,
> in a parallel way, I obtain the following error:
> "symbol lookup error:
> /path_where_PETSc_is_installed/petsc-2.2.1
> /lib/libg_c++/linux-gnu/libpetscmat.so:
> undefined symbol: PETSC_COMM_SELF"
> I have used the command "nm" and ,effectively, this symbol is undefined.
> I don't really know where the problem is. I am using version 2.2.1
> Any help and advice will be welcome
> Thanks in advance
> Isa
"Failure has a thousand explanations. Success doesn't need one" -- Sir Alec
Guiness
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20061024/df0819e8/attachment.htm>
