about PETSC installation
Sat Oct 21 22:46:36 CDT 2006
On 10/21/06, Yixun Liu <yxliu at fudan.edu.cn> wrote:
> Hi,
> I try it, the error is "Error downloading f2cblaslapack.tar.gz requested
> with -with-c-blas-lapack option". So I install  fortran. I think fortran
> provide blas and lapack. If this what command should I use?
 Please refer installation questions to petsc-maint at mcs.anl.gov. Fortran
does not provide those
libraries. You would need something like --download-f-blas-lapack. However,
it would likely for
for the same reason as the last option. Every time your installation fails,
you should send the
configure.log to petsc-maint, as it advises you to do in the error messge.
  Matt
Best,
> Yixun
"Failure has a thousand explanations. Success doesn't need one" -- Sir Alec
Guiness
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20061021/c96c107e/attachment.htm>
