about parallel execution
Tue Oct 17 09:09:32 CDT 2006
Note: PETSc uses MPI - and it follws the SPMD [Single Program Multiple
Data] model. You might want to check the replies to the same question
posted earlier at:
http://www-unix.mcs.anl.gov/web-mail-archive/lists/petsc-users/2006/10/msg00052.html
Satish
On Tue, 17 Oct 2006, Hong Zhang wrote:
> Yixun,
> Chapter 1 of the
> Petsc users manual gives detailed instruction
> on
> 1. set petsc environment
> 2. write petsc program
> 3. compile and run program
> You may start running petsc examples as described
> in the manual.
> Hong
> On Tue, 17 Oct 2006, Yixun Liu wrote:
> > Hi,
> > I am a new user of PETSC. I want to know how to execute of the PETSC application.
> > For example, my code are like below,
> > PETSCInitialize();
> > code1;
> > code2;
> > PETSCFinalize();
> > Does PETSC copy the above codes, assuming there n processors, to each processor? Will code1 be execute on each processor?
> > Best regards,
> > Yixun
