MPI question
Sun Oct 15 21:35:08 CDT 2006
On 10/15/06, Julian <julvar at tamu.edu> wrote:
> I am using petsc in my fem program on the supercomputer we have here at
> texas a&m univ. I configured petsc to build the libraries with mpi.
> So, I ran  'mpirun -np 2 /home/j0v1008/bin/alphampi a.alpha' in order to
> use
> 2 processors.
> Till the point where petsc is initialized, everything looks normal. From
> the
> point petsc in initialized, I get duplicates of everything that is written
> to cout (at the very least, maybe it's doing duplicates of other things as
> well).
> I understand that all the petsc functions might be called twice or so
> depending on how it parallelizes, but I don't understand why it executes
> lines that are outside of the petsc world, that have nothing to do with
> mpi.
> Maybe this would clear things up:
> void main()
> Cout << "line1"
> //insert code to initialize mpi
> Cout << "line2"
> MyfunctionusingMPI()
> Cout << "line3"
> //insert code to finalizeMPI
> Say I run this program with 2 processors, will "line2" be printed twice ?
> If
> yes, can you explain why it does that when I didn't ask for that line to
> be
> parallelized?
Yes. MPI is an SPMD model. There are multiple running copies of the same
program. I suggest "Using MPI" by Gropp, et. al. for a better understading
of parallel code.
   Matt
If no, then why is my fea program behaving so?
> Thanks,
> Julian.
"Failure has a thousand explanations. Success doesn't need one" -- Sir Alec
Guiness
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20061015/19bef6b3/attachment.htm>
