General matrix interative solver
Julian julvar at tamu.edu
Thu Oct 12 14:31:09 CDT 2006
I think I got the preallocation right.. But it still gets stuck at pretty
much the same spot.
When it slowed to almost pretty much a full stop, I did a break all in debug
mode and it looks like its stuck in a memset function which according to the
call stack is called down the line from the following petsc function:
PetscErrorCode PETSC_DLLEXPORT PetscMallocAlign(size_t mem,int line,const
char func[],const char file[],const char dir[],void** result)
I am using the symmetric matrix (MATSBAIJ) ..and I'm not sure how I should
specify the nnz when I create the matrix
Is it the number of non-zeroes in each row in the upper triangle (cos that
is all I'm storing, right?) or is it the non zeroes in each row for the
whole matrix?
Julian.
> -----Original Message-----
> From: owner-petsc-users at mcs.anl.gov
> [mailto:owner-petsc-users at mcs.anl.gov] On Behalf Of Julian
> Sent: Thursday, October 12, 2006 1:47 PM
> To: petsc-users at mcs.anl.gov
> Subject: RE: General matrix interative solver
> Thanks, I got it working after I switched to icc
> All this time I was running test cases where I just read in
> an already assembled global stiffness matrix and load vector
> and solved the problem using petsc.
> After I got that working, I tried to fully  integrate the
> solver with the FEA program.
> One problem I had was with populating the matrix. The
> interfaces to the other existing solvers in our code were
> written so that we can assign a value directly to a memory
> space assigned for an element in the matrix.
> Something like mat(I,J)=value; Where mat(I,J) gives the
> reference to the location. But petsc does not work that way
> (I had already asked this on the mailing list a couple of
> months back) and I understand maybe its wise to do that,
> considering it handles parallel implementation as well. So, I
> changed our code to work with petsc.
> Now, when assembling the global matrix, sometimes I need to
> use ADD_VALUES and other times INSERT_VALUES (depending on
> constraints)
> At first, I used 	MatAssemblyBegin(*(Mat*)mat,
> MAT_FINAL_ASSEMBLY);
> MatAssemblyEnd(*(Mat*)mat, MAT_FINAL_ASSEMBLY); But then it
> took too long and I  realized I should be using
> MAT_FLUSH_ASSEMBLY. But even then it takes considerably more
> time in assembling than my other solvers. So, I used a flag
> to call the assembly only when I am switching between
> ADD_VALUES and INSERT_VALUES. That reduced the calls to
> MAT_FLUSH_ASSEMBLY but it still was a slower than the other
> solvers.. And this was for a small problem (1317 unknowns) I
> tried it out with a larger problem ~15000 unknowns and the
> program just got stuck during the assembly process ! It
> wouldn't crash but looks like its doing something inside of
> petsc... probably memory allocations. So, I think I need to
> start preallocating memory. I'm working on that now... So
> hopefully, after that the assembly process won't slow down
> bcause of memory allocation. But my question for now... is
> using the flag method to call assembly only when needed the
> most efficient way to do this? Or do you have any better
> ideas? One other possiblity is to have an array of flags, so
> as to avoid the call to INSERT_VALUES altogether... And
> thereby eliminating the need to call MAT_FLUSH_ASSEMBLY.
> I'll get back to you after I get the preallocation right.
> Maybe that will fix everything.
> Thanks,
> Julian.
> > [mailto:owner-petsc-users at mcs.anl.gov] On Behalf Of Barry Smith
> > Sent: Wednesday, October 11, 2006 2:58 PM
> >   ILU is for general matrices; for symmetric you need to use
> > PCSetType(pc,PCICC); or -pc_type icc
> >    Barry
> > On Wed, 11 Oct 2006, Julian wrote:
> > > Hong,
> > > I made the following change to specify it to be in sbaij
> > format... And
> > > then proceeded to store only the upper triangle.
> > > 	Assert( mat = (double*)malloc(sizeof(Mat)) );
> > > 	MatCreateSeqAIJ(PETSC_COMM_SELF, L, L, PETSC_DEFAULT,
> > PETSC_NULL,
> > > (Mat*)mat);
> > > 	MatSetType(*(Mat*)mat,MATSBAIJ);
> > > But I get the following error when I try to solve:
> > > -- Petsc Release Version 2.3.1, Patch 16, Fri Jul 21
> > 15:09:15 CDT 2006
> > > HG
> > > revision:
> > >  5bc424fae3770001f0d316695a9956fde3bc58b0
> > > See docs/changes/index.html for recent updates.
> > > See docs/faq.html for hints about trouble shooting.
> > > See docs/index.html for manual pages.
> > > -- Unknown Name on a cygwin-cx named ALPHA2 by j0v1008 Wed Oct 11
> > > 14:51:00 2006 Libraries linked from
> > > /cygdrive/e/cygwin/home/petsc-2.3.1-p16/lib/cygwin-cxx-rea
> > > l-debug
> > > Configure run at Mon Aug 14 15:35:57 2006 Configure options
> > > --with-cc="win32fe cl --nodetect" --with-cxx="win32fe cl
> > --nod etect"
> > > --COPTFLAGS="-MDd -Z7" --with-fc=0 --with-clanguage=cxx
> > > --download-c-blas
> > > -lapack=1 --with-mpi=0 --useThreads=0 --with-shared=0
> > > -- [0]PETSC ERROR: MatILUFactorSymbolic() line 4573 in
> > > src/mat/interface/e:\cygwin\
> > > home\PETSC-~1.1-P\src\mat\INTERF~1\matrix.c
> > > [0]PETSC ERROR: No support for this operation for this
> object type!
> > > [0]PETSC ERROR: Matrix type sbaij  symbolic ILU!
> > > [0]PETSC ERROR: PCSetUp_ILU() line 532 in
> > > src/ksp/pc/impls/factor/ilu/e:\cygwin\
> > > home\PETSC-~1.1-P\src\ksp\pc\impls\factor\ilu\ilu.c
> > > [0]PETSC ERROR: PCSetUp() line 798 in
> > > src/ksp/pc/interface/e:\cygwin\home\PETSC-
> > > ~1.1-P\src\ksp\pc\INTERF~1\precon.c
> > > [0]PETSC ERROR: KSPSetUp() line 234 in
> > > src/ksp/ksp/interface/e:\cygwin\home\PETS
> > > C-~1.1-P\src\ksp\ksp\INTERF~1\itfunc.c
> > > [0]PETSC ERROR: KSPSolve() line 334 in
> > > > [mailto:owner-petsc-users at mcs.anl.gov] On Behalf Of Hong Zhang
> > > > Sent: Wednesday, October 11, 2006 2:14 PM
> > > > Julian,
> > > > If you do not perform matrix reordering, you can use
> petsc sbaij
> > > > format, which only stores the upper triangular entries.
> > > > aij format has more algorithmic options and is more
> efficient and
> > > > supports matrix reordering.
> > > > Hong
> > > > > I'm using '-ksp_type cg' now to solve the symmetric
> > > > matric...But then
> > > > > do I need to store all the non-zero elements of a symmetric
> > > > matrix ?
> > > > > i.e. A[i,j] as well as A[j,i] ?
> > > > > Shouldn't I be able to store just the upper or lower
> > > > triangle or the
> > > > > matrix ? Is that possible with petsc ?
> > > > > Julian.
> > > > > > Sent: Wednesday, October 11, 2006 12:37 PM
> > > > > > Barry,
> > > > > > I tried sending the commands from a file for now... And
> > > > once I used
> > > > > > '-ksp_type cg', I got pretty much the same
> > performance as that
> > > > > > of the inhouse code !
> > > > > > Now, I'll try the performance with larger cases...
> > > > > > Thanks for your help!
> > > > > > Julian.
> > > > > > > Smith
> > > > > > > Sent: Wednesday, October 11, 2006 11:25 AM
> > > > > > >   PetscOptionsSetValue() but recommend putting them on
> > > > the command
> > > > > > > line or in a file (pass the name of the file into
> > > > > > PetscInitialize()).
> > > > > > > Having to recompile for every option is too painful.
> > > > > > >    Barry
> > > > > > > > Hong,
> > > > > > > > The times are for the solution process alone and the
> > > > > > > initial guess is
> > > > > > > > the same, i.e. zero.
> > > > > > > > As for the algorithm, they are probably different.
> > > > > > > > Can you tell me how to pass 'runtime options' like -help
> > > > > > > and -ksp_view
> > > > > > > > from within the code... I mean, at compile time.
> > > > > > > > thanks
> > > > > > > > > Julian,
> > > > > > > > > When comparing the inhouse solver and petsc
> solver, you
> > > > > > need make
> > > > > > > > > sure
> > > > > > > > > 1. Timings are collected for solution process.
> > The matrix
> > > > > > > and vector
> > > > > > > > >    assembly should be excluded.
> > > > > > > > > 2. They should use same iterative algorithm.
> By default,
> > > > > > > petsc uses
> > > > > > > > >    gmres with restart=30 and ilu(0) preconditioner.
> > > > > > Petsc supports
> > > > > > > > >    symmetric matrices, e.g., runtime option
> > '-ksp_type cg
> > > > > > > -pc_type
> > > > > > > > > icc'
> > > > > > > > >    might give better performance 3. They should
> > start from
> > > > > > > > > same intial guess. By default, petsc
> > > > > > > > >    initial guess is zero.
> > > > > > > > > You can use '-ksp_view' to see what algorithm
> > and options
> > > > > > > are used
> > > > > > > > > in petsc.
> > > > > > > > > Hong
> > > > > > > > > > Hello,
> > > > > > > > > > I implemented the iterative sparse matrix solver in
> > > > > > > > > > PetSc
> > > > > > > > > into my FEM
> > > > > > > > > > code recently. I compared the results from a problem
> > > > > > with 1317
> > > > > > > > > > unknowns. I used a direct solver to obtain
> > the reference
> > > > > > > > > solution. I
> > > > > > > > > > have another in-house sparse iterative
> solver that I
> > > > > > > > > > have
> > > > > > > > > been using
> > > > > > > > > > so far. It was written by someone else but I have
> > > > access to
> > > > > > > > > the source for that solver.
> > > > > > > > > > I find the 'error norm' in the solution by
> taking the
> > > > > > > > > square root of
> > > > > > > > > > the sum of the squares of the absolute differences
> > > > > > between the
> > > > > > > > > > solution from the direct solver and the iterative
> > > > > > solver. I am
> > > > > > > > > > ignoring the numerical zeros in the solutions
> > > > when doing this.
> > > > > > > > > > I find that in order to get same order of the error
> > > > > > > norm (1e-13)
> > > > > > > > > > as the in-house iterative solver, the petsc solver
> > > > > > takes a much
> > > > > > > > > > longer time and larger number of iterations. While
> > > > > > the inhouse
> > > > > > > > > > solver took less than one second, the petsc
> > > > solver took 13
> > > > > > > > > > seconds. The inhouse solver took 476
> > iterations whereas
> > > > > > > the petsc
> > > > > > > > > > solver took
> > > > > > > > > 4738 iterations.
> > > > > > > > > > I'm guessing this has to do with different
> setting of
> > > > > > > the solver
> > > > > > > > > > in petsc such as the preconditioner etc.
> > > > > > > > > > Can you tell me what the different settings are?
> > > > And how to
> > > > > > > > > tweak them
> > > > > > > > > > so that I can atleast get as good as a
> performance as
> > > > > > > > > > the
> > > > > > > > > inhouse code ?
> > > > > > > > > > Given below is how I have implemented the
> > petsc solver:
> > > > > > > > > > /////initialization
> > > > > > > > > >     PetscInitializeNoArguments();
> > > > > > > > > >         Assert( mat =
> > > > > > > > > >       PETSC_DEFAULT, PETSC_NULL, (Mat*)mat);
> > > > > > > > > > ////// this is the function I use to populate
> > the matrix
> > > > > > > > > > MatSetValue(*(Mat*)mat, ii, jj, value, ADD_VALUES);
> > > > > > > > > > ////// this is how I actaully solve the matrix
> > > > > > > > > >   MatAssemblyBegin(*(Mat*)mat, MAT_FINAL_ASSEMBLY);
> > > > > > > > > >   double iter_error = 1e-10;
> > > > > > > > > >   int max_iter_num = 10000;
> > > > > > > > > >   int num_of_iter;
> > > > > > > > > >         Vec rhs, x;
> > > > > > > > > >     VecCreateSeqWithArray(PETSC_COMM_SELF, L,
> > b, &rhs);
> > > > > > > > > >     VecDuplicate(rhs, &x);
> > > > > > > > > >     KSP ksp;
> > > > > > > > > >     KSPCreate(PETSC_COMM_SELF, &ksp);
> > > > > > > > > >     KSPSetTolerances(ksp, iter_error, PETSC_DEFAULT,
> > > > > > > > > >       PETSC_DEFAULT, max_iter_num);
> > > > > > > > > >     KSPSetFromOptions(ksp);
> > > > > > > > > >     KSPSetOperators(ksp, *(Mat*)mat, *(Mat*)mat,
> > > > > > > > > >       SAME_PRECONDITIONER);
> > > > > > > > > >     KSPSolve(ksp,rhs,x);
> > > > > > > > > >     PetscReal r_norm;
> > > > > > > > > >     KSPGetResidualNorm(ksp, &r_norm);
> > > > > > > > > >     KSPGetIterationNumber(ksp, &num_of_iter);
> > > > > > > > > >         cout << "max_iter_num\t" <<
> > max_iter_num << endl;
> > > > > > > > > >         cout << "iter_error\t" <<
> iter_error << endl;
> > > > > > > > > >         cout << "Matrix solver step " <<
> > num_of_iter <<
> > > > > > > > > residual "
> > > > > > > > > > << r_norm << ".\n";
> > > > > > > > > >         PetscScalar *p;
> > > > > > > > > >     VecGetArray(x, &p);
> > > > > > > > > >     for(int i=0; i<L; i++) {
> > > > > > > > > >         b[i] = p[i];
> > > > > > > > > >     VecRestoreArray(x, &p);
> > > > > > > > > >     KSPDestroy(ksp);
> > > > > > > > > >     VecDestroy(rhs);
> > > > > > > > > >     VecDestroy(x);
> > > > > > > > > > cout <<"Iterations for convergence="<<
> > num_of_iter << "
> > > > > > > > > Residual Norm = "
> > > > > > > > > > << r_norm << endl;
> > > > > > > > > > If this is not the typical method to be
> used to solve
> > > > > > > this kind of
> > > > > > > > > > problem, please let me know what functions I
> > should use.
> > > > > > > > > > I should mention that the inhouse code is for
> > symmetric
> > > > > > > > > matrices and
> > > > > > > > > > from what I understand, the petsc solver works for
> > > > > > > > > > general
> > > > > > > > > unsymmetric matrices.
> > > > > > > > > > But I think for iterative solvers, it should
> > still give
> > > > > > > around the
> > > > > > > > > > same performance.
> > > > > > > > > > I tested the solvers against some other problems as
> > > > > > well, and I
> > > > > > > > > > got the same performance.. In some cases, no
> > > > matter how many
> > > > > > > > > iterations it
> > > > > > > > > > goes through, the petsc solver would not go below
> > > > a certain
> > > > > > > > > error norm
> > > > > > > > > > whereas the inhouse solver would get almost
> > exactly the
> > > > > > > > > same answer as
> > > > > > > > > > the direct solver solution. I'm thinking the petsc
> > > > > > > solver should
> > > > > > > > > > be able to solve this problem just as easily.
> > It would
> > > > > > > > > > be
> > > > > > > > > great if anyone
> > > > > > > > > > could help me figure out the appropriate settings I
> > > > > > > > > > should
> > > > > > > > > use in the petsc solver.
> > > > > > > > > > Thanks,
> > > > > > > > > > Julian.
