General matrix interative solver
Wed Oct 11 11:25:00 CDT 2006
  PetscOptionsSetValue() but recommend putting
them on the command line or in a file (pass the name
of the file into PetscInitialize()). Having to recompile
for every option is too painful.
   Barry
On Wed, 11 Oct 2006, Julian wrote:
> Hong,
> The times are for the solution process alone and the initial guess is the
> same, i.e. zero.
> As for the algorithm, they are probably different.
> Can you tell me how to pass 'runtime options' like -help and -ksp_view from
> within the code... I mean, at compile time.
> thanks
> > Julian,
> > When comparing the inhouse solver and petsc solver, you need make sure
> > 1. Timings are collected for solution process. The matrix and vector
> >    assembly should be excluded.
> > 2. They should use same iterative algorithm. By default, petsc uses
> >    gmres with restart=30 and ilu(0) preconditioner. Petsc supports
> >    symmetric matrices, e.g., runtime option '-ksp_type cg
> > -pc_type icc'
> >    might give better performance
> > 3. They should start from same intial guess. By default, petsc
> >    initial guess is zero.
> > You can use '-ksp_view' to see what algorithm and options are
> > used in petsc.
> > Hong
> > > Hello,
> > > I implemented the iterative sparse matrix solver in PetSc
> > into my FEM
> > > code recently. I compared the results from a problem with 1317
> > > unknowns. I used a direct solver to obtain the reference
> > solution. I
> > > have another in-house sparse iterative solver that I have
> > been using
> > > so far. It was written by someone else but I have access to
> > the source for that solver.
> > > I find the 'error norm' in the solution by taking the
> > square root of
> > > the sum of the squares of the absolute differences between the
> > > solution from the direct solver and the iterative solver. I am
> > > ignoring the numerical zeros in the solutions when doing this.
> > > I find that in order to get same order of the error norm (1e-13) as
> > > the in-house iterative solver, the petsc solver takes a much longer
> > > time and larger number of iterations. While the inhouse solver took
> > > less than one second, the petsc solver took 13 seconds. The inhouse
> > > solver took 476 iterations whereas the petsc solver took
> > 4738 iterations.
> > > I'm guessing this has to do with different setting of the solver in
> > > petsc such as the preconditioner etc.
> > > Can you tell me what the different settings are? And how to
> > tweak them
> > > so that I can atleast get as good as a performance as the
> > inhouse code ?
> > > Given below is how I have implemented the petsc solver:
> > > /////initialization
> > >     PetscInitializeNoArguments();
> > >         Assert( mat = (double*)malloc(sizeof(Mat)) );
> > >     MatCreateSeqAIJ(PETSC_COMM_SELF, L, L,
> > >       PETSC_DEFAULT, PETSC_NULL, (Mat*)mat);
> > > ////// this is the function I use to populate the matrix
> > > MatSetValue(*(Mat*)mat, ii, jj, value, ADD_VALUES);
> > > ////// this is how I actaully solve the matrix
> > >   MatAssemblyBegin(*(Mat*)mat, MAT_FINAL_ASSEMBLY);
> > >   MatAssemblyEnd(*(Mat*)mat, MAT_FINAL_ASSEMBLY);
> > >   double iter_error = 1e-10;
> > >   int max_iter_num = 10000;
> > >   int num_of_iter;
> > >         Vec rhs, x;
> > >     VecCreateSeqWithArray(PETSC_COMM_SELF, L, b, &rhs);
> > >     VecDuplicate(rhs, &x);
> > >     KSP ksp;
> > >     KSPCreate(PETSC_COMM_SELF, &ksp);
> > >     KSPSetTolerances(ksp, iter_error, PETSC_DEFAULT,
> > >       PETSC_DEFAULT, max_iter_num);
> > >     KSPSetFromOptions(ksp);
> > >     KSPSetOperators(ksp, *(Mat*)mat, *(Mat*)mat,
> > >       SAME_PRECONDITIONER);
> > >     KSPSolve(ksp,rhs,x);
> > >     PetscReal r_norm;
> > >     KSPGetResidualNorm(ksp, &r_norm);
> > >     KSPGetIterationNumber(ksp, &num_of_iter);
> > >         cout << "max_iter_num\t" << max_iter_num << endl;
> > >         cout << "iter_error\t" << iter_error << endl;
> > >         cout << "Matrix solver step " << num_of_iter << ",
> > residual "
> > > << r_norm << ".\n";
> > >         PetscScalar *p;
> > >     VecGetArray(x, &p);
> > >     for(int i=0; i<L; i++) {
> > >         b[i] = p[i];
> > >     VecRestoreArray(x, &p);
> > >     KSPDestroy(ksp);
> > >     VecDestroy(rhs);
> > >     VecDestroy(x);
> > > cout <<"Iterations for convergence="<< num_of_iter << " -
> > Residual Norm = "
> > > << r_norm << endl;
> > > If this is not the typical method to be used to solve this kind of
> > > problem, please let me know what functions I should use.
> > > I should mention that the inhouse code is for symmetric
> > matrices and
> > > from what I understand, the petsc solver works for general
> > unsymmetric matrices.
> > > But I think for iterative solvers, it should still give around the
> > > same performance.
> > > I tested the solvers against some other problems as well, and I got
> > > the same performance.. In some cases, no matter how many
> > iterations it
> > > goes through, the petsc solver would not go below a certain
> > error norm
> > > whereas the inhouse solver would get almost exactly the
> > same answer as
> > > the direct solver solution. I'm thinking the petsc solver should be
> > > able to solve this problem just as easily. It would be
> > great if anyone
> > > could help me figure out the appropriate settings I should
> > use in the petsc solver.
> > > Thanks,
> > > Julian.
