Using Compaq visual fortran w/o intel mkl & visual 6 c++
Tue Nov 28 09:51:57 CST 2006
We haven't tried gcc+compaq fortran. I don't think it will work.
You'll need the C compiler to install PETSc libraries. But once the
libraries are installed - you might be able to copy/use them on a
different machine with only the fortran compiler [provided everything
else PETSc is configured with - i.e blas, mpi - are in the exact same
location on this other machine]
Satish
On Tue, 28 Nov 2006, Ben Tay wrote:
> Hi,
> may I know if it is possible to run my program in compaq visual
> fortran 6.6without installing visual c++6 and intel mkl? in other
> words, use gnu c
> compiler and the downloaded blas/lapack.
> all a system with all these it worked. however, another comp in my sch only
> has vf 6.6.
> thank you very much!
