Modifying the MSDdev *.dsw *.dsp files to run without mpi
Fri Nov 24 20:11:55 CST 2006
You'll have to follow instructions in the 'Project Files' section at
http://www-unix.mcs.anl.gov/petsc/petsc-as/documentation/installation.html
[specifically - perhaps that MPI include/library paths in the project
files were not updated to point to mpiuni stuff [as would be visible
when a PETSc example is compiled from cygwin bash using make.]
Satish
On Fri, 24 Nov 2006, Matthew Knepley wrote:
> We are not able to generate MSDev files, so you will have to alter them
> yourself. You need to take out the references to MPI.
>   Matt
> On 11/24/06, Ben Tay <zonexo at gmail.com> wrote:
> > Hi,
> > yes I did that. There is no problem if I run the example in cygwin. However,
> > if I use the project files for MSDev given in the petsc package, it gives me
> > errors during linking. Compiling works though.
> > I tried to recompile the whole Petsc with mpich1 and there is no such
> > errors.
> > Thank you.
> > On 11/25/06, Matthew Knepley <knepley at gmail.com> wrote:
> > > You need to configure using --wih-mpi=0.
> > > Matt
> > > On 11/24/06, Ben Tay < zonexo at gmail.com> wrote:
> > > > Hi,
> > > > I've managed to compile and run the examples in MSDev when i use MPICH.
> > > > However, if I compile without MPI, I 'll get errors during linking. How
> > > > should I modify my configuration file in MSDev so that I can run without
> > > > mpi?
> > > > Thank you very much!
> > > "Failure has a thousand explanations. Success doesn't need one" -- Sir
> > > Alec Guiness
