about PETSC run time lib
Yixun Liu yxliu at fudan.edu.cn
Sat Nov 4 00:15:42 CST 2006
I config PETSC with,
$ ./config/configure.py --with-mpi-dir=/cygdrive/d/MPICH2 --with-cc='win32fe cl' --with-fc=0 --with-cxx='win32fe cl' --with-clanguage=cxx --with-blas-lapack-dir=$PETSC_DIR/externalpackages/w_mkl_serial_p_8.1.001/mkl_serial_8.1/mkl_8.1_serial/ia32/lib COPTFLAGS='-MD -Z7' CXXOPTFLAGS='-MD -Z7'
In my applicaton I use another lib, which use Debug multithread DLL run time lib. When I use this two libs together I alwayse receive the warning :
"LINK : warning LNK4098: defaultlib "MSVCRTD" conflicts with use of other libs; use /NODEFAULTLIB:library".
 I think this is because PETSC use MSVCRT run time lib and the other lib use MSVCRTD run time lib. If I ignore this warning the application will run into exception. So I need to config the PETSC to let it use the same run time lib. Should I use COPTFLAGS='-MDd -Z7' CXXOPTFLAGS='-MDd -Z7'?
Best,
Yixun
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20061104/1c5703f1/attachment.htm>
