PETSC's hypre version
Matt Funk mafunk at nmsu.edu
Fri Nov 3 11:40:18 CST 2006
mat
On Friday 03 November 2006 10:34, Satish Balay wrote:
> On Fri, 3 Nov 2006, Matt Funk wrote:
> > Hi,
> > i downloaded hypre through PETSc (i.e. download-hypre=1). The hypre
> > package it downloaded is: hypre-1.9.0b-mod
> > I assume the 'mod' stands for modified. So i was wondering if there have
> > been major changes to it or in what way it has been modified? The reason
> > i am wondering is because i am thinking of trying to use hypre standalone
> > and am wondering whether i can use these modified libraries?
> The modifications are for the following reasons:
> - cleanly build hypre with PETSc
> - avoid duplication of superlu/blas stuff.
> etc..
> The user interface is untouched - so you should be able to use the
> libraries built by PETSc. However there are newer version of hypre -
> which you might want to explore [curently petsc uses hypre-1.11b, and
> the latest hypre version is hypre-1.13]
> Satish
