how to use PetscMap?
Yixun Liu yxliu at fudan.edu.cn
Thu Nov 2 21:12:36 CST 2006
I did as you said,
PetscMap map;
// PetscMapSetBlockSize(&map,n);
 map.bs = 1;
 ierr = PetscMapInitialize(PETSC_COMM_WORLD, &map);
 ierr = PetscMapSetSize (&map, n);
 ierr = PetscMapGetLocalRange(&map,&Istart,&Iend); CHKERRQ(ierr);
The running error is,
[0]PETSC ERROR: ------------------------------------------------------------------------
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[0]PETSC ERROR: or try http://valgrind.org on linux or man libgmalloc on Apple to find memory corruption errors
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR:       INSTEAD the line number of the start of the function
[0]PETSC ERROR:       is given.
[0]PETSC ERROR: [0] PetscMapInitialize line 41 src/vec/vec/impls/mpi/d:\MyVC\PETSC-~1.2-P\src\vec\vec\impls\mpi\pmap.c
[0]PETSC ERROR: --------------------- Error Message ------------------------------------
[0]PETSC ERROR: Signal received!
[0]PETSC ERROR: Petsc Release Version 2.3.2, Patch 3, Fri Sep 29 17:09:34 CDT 2006 HG revision: 9215af156a9cbcdc1ec666e2b5c7934688ddc526
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR: D:\MyVC\PETSCTest\PETSCTemplate\Debug\PETSCTemplate.exe on a cygwin-cx named DMRC-6700512 by DMRC-user Fri Nov 03 11:10:22 2006
[0]PETSC ERROR: Libraries linked from /cygdrive/D/MyVC/petsc-2.3.2-p3/lib/cygwin-cxx-debug
[0]PETSC ERROR: Configure run at Wed Nov  1 10:08:10 2006
[0]PETSC ERROR: Configure options --with-mpi-dir=/cygdrive/d/MPICH2 --with-cc="win32fe cl" --with-fc=0 --with-cxx="win32fe cl" --with-clanguage=cxx --with-blas-lapack-dir=/cygdrive/D/MyVC/petsc-2.3.2-p3/externalpackages/w_mkl_serial_p_8.1.001/mkl_serial_8.1/mkl_8.1_serial/ia32/lib COPTFLAGS="-MD -Z7" CXXOPTFLAGS="-MD -Z7" --useThreads=0 --with-shared=0
[0]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
unable to read the cmd header on the pmi context, Undefined dynamic error code.
job aborted:
rank: node: exit code[: error message]
0: dmrc-6700512: 59: application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
Best,
Yixun
----- Original Message -----
To: <petsc-users at mcs.anl.gov>
Sent: Friday, November 03, 2006 10:51 AM
Subject: Re: how to use PetscMap?
  Sorry about this; you can just use map->bs = 1; before the call to
PetscMapInitialize()
   Barry
On Fri, 3 Nov 2006, Yixun Liu wrote:
> Hi,
> I do not use PetscMapSetBlockSize firstly and it is ok with compiler.
> PetscMap map;
>  CHKERRQ(ierr);
> However,the running error is:
> [0]PETSC ERROR: Object is in wrong state!
> [0]PETSC ERROR: BlockSize not yet set!
> [0]PETSC ERROR: D:\MyVC\PETSCTest\PETSCTemplate\Debug\PETSCTemplate.exe on a cygwin-cx named DMRC-6700512 by DMRC-user Fri Nov 03 10:26:11 2006
> [0]PETSC ERROR: PetscMapInitialize() line 44 in src/vec/vec/impls/mpi/d:\MyVC\PETSC-~1.2-P\src\vec\vec\impls\mpi\pmap.c
> Norm of error 0.00110997 iterations 44
> 0.0702505
> Yixun
> From: "Barry Smith" <bsmith at mcs.anl.gov>
> Sent: Friday, November 03, 2006 10:30 AM
> > Hi,
> > I use PetscMap as below,
> >  PetscMap map;
> >  ierr = PetscMapInitialize(PETSC_COMM_WORLD, &map); CHKERRQ(ierr);
> >  ierr = PetscMapSetBlockSize(&map,n); CHKERRQ(ierr);
>   You do not need to use PetscMapSetBlockSize(), in it extraordinarily unlikely
> you want to set it to n.
> >  ierr = PetscMapSetSize (&map, n); CHKERRQ(ierr);
> > The compiler error is :PetscMapSetBlockSize' : undeclared identifier.  I am sure I include "petscksp.h", so I think 2.3.2 does not support PetscMap.
>    Yes, but the other functions (PetscMapInitialize() etc) are NOT undeclared, so they do exist.
>   Barry
> > BTW,  I am not clear about the block size.
> > Best,
> > Yixun
> > Sent: Friday, November 03, 2006 9:26 AM
> >   Yixun
> >    Please read the manual pages for PetscMapInitialize, PetscMapGetLocalRange,
> > PetscMapGetGlobalRange etc.
> > http://www-unix.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Vec/PetscMapInitialize.html
> > I told you about PetscMapInitialize() over a week ago.
> > You should not need to broadcast these simple tasks to everyone; you should be
> > able to use the manual pages to handle this trivial stuff.
> >    Barry
> > > Hi,
> > > For example, if N is known,  I call PetscSplitOwnership(PETSC_COMM, PETSC_DECIDE ,  &N) . However, how to get the start and end value like PetscMapGetLocalRange?
> > > Best,
> > > Yixun
> > > From: "Matthew Knepley" <knepley at gmail.com>
> > > Sent: Thursday, November 02, 2006 10:27 PM
> > > > http://www-unix.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Sys/PetscSplitOwnership.html
> > > >   Matt
> > > > On 11/2/06, Yixun Liu <yxliu at fudan.edu.cn> wrote:
> > > >> Hi,
> > > >> I want to use PetscMap to gets the range of values owned by this process, e.g.,PetscMapGetLocalRange(map,&Istart,&Iend). Then according to Istart and Iend to determine the parameters used by MatCreateMPIAIJ to create a matrix.
> > > >> Best,
> > > >> Yixun
> > > >> Sent: Thursday, November 02, 2006 9:56 PM
> > > >> > There is no replacement. What are you tring to do here?
> > > >> >   Matt
> > > >> >> Hi,
> > > >> >> I want to change the code, which is based on old version PETSC to version 2.3.2. The old petsc code are,
> > > >> >> PetscMap map;
> > > >> >> ierr = PetscMapCreateMPI(PETSC_COMM_WORLD,PETSC_DECIDE,n,&map);CHKERRQ(ierr);
> > > >> >> ierr = PetscMapGetLocalRange(map,&Istart,&Iend); CHKERRQ(ierr);
> > > >> >> ierr = PetscMapDestroy(map); CHKERRQ(ierr);
> > > >> >> If 2.3.2 does not support PetscMap, which class should I use?
> > > >> >> Best,
> > > >> >> Yixun
> > > >> >> Sent: Thursday, November 02, 2006 9:07 PM
> > > >> >> > No, in 2.3.2 PetscMap no longer exists.
> > > >> >> >   Matt
> > > >> >> >> Hi,
> > > >> >> >> I reveive the error as,
> > > >> >> >> [0]PETSC ERROR:
> > > >> >> >> [0]PETSC ERROR:
> > > >> >> >> [0]PETSC ERROR:
> > > >> >> >> [0]PETSC ERROR: Unknown Name on a cygwin-cx named DMRC-6700512 by DMRC-user
> > > >> >> >> Thu Nov 02 16:22:47 2006
> > > >> >> >> [0]PETSC ERROR:
> > > >> >> >> file
> > > >> >> >> code.
> > > >> >> >> job aborted:
> > > >> >> >> process 0
> > > >> >> >> I think this error maybe caused by these codes,
> > > >> >> >>  PetscMap *map;
> > > >> >> >>  ierr = PetscMapInitialize(PETSC_COMM_WORLD, map);
> > > >> >> >>  CHKERRQ(ierr);
> > > >> >> >>  ierr = PetscMapSetSize (map, n);
> > > >> >> >> CHKERRQ(ierr);
> > > >> >> >> Is it correct to use the PetscMap like this?
> > > >> >> >> Best,
> > > >> >> >> Yixun
> > > >> >> > "Failure has a thousand explanations. Success doesn't need one" -- Sir
> > > >> >> > Alec Guiness
> > > >> > Alec Guiness
> > > > Alec Guiness
