how to use PetscMap?
Yixun Liu yxliu at fudan.edu.cn
Thu Nov 2 02:27:11 CST 2006
I reveive the error as,
[0]PETSC ERROR: ------------------------------------------------------------------------
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[0]PETSC ERROR: or try http://valgrind.org on linux or man libgmalloc on Apple to find memory corruption errors
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR:       INSTEAD the line number of the start of the function
[0]PETSC ERROR:       is given.
[0]PETSC ERROR: [0] PetscMapInitialize line 41 src/vec/vec/impls/mpi/d:\MyVC\PETSC-~1.2-P\src\vec\vec\impls\mpi\pmap.c
[0]PETSC ERROR: --------------------- Error Message ------------------------------------
[0]PETSC ERROR: Signal received!
[0]PETSC ERROR: Petsc Release Version 2.3.2, Patch 3, Fri Sep 29 17:09:34 CDT 2006 HG revision: 9215af156a9cbcdc1ec666e2b5c7934688ddc526
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR: Unknown Name on a cygwin-cx named DMRC-6700512 by DMRC-user Thu Nov 02 16:22:47 2006
[0]PETSC ERROR: Libraries linked from /cygdrive/D/MyVC/petsc-2.3.2-p3/lib/cygwin-cxx-debug
[0]PETSC ERROR: Configure run at Wed Nov  1 10:08:10 2006
[0]PETSC ERROR: Configure options --with-mpi-dir=/cygdrive/d/MPICH2 --with-cc="win32fe cl" --with-fc=0 --with-cxx="win32fe cl" --with-clanguage=cxx --with-blas-lapack-dir=/cygdrive/D/MyVC/petsc-2.3.2-p3/externalpackages/w_mkl_serial_p_8.1.001/mkl_serial_8.1/mkl_8.1_serial/ia32/lib COPTFLAGS="-MD -Z7" CXXOPTFLAGS="-MD -Z7" --useThreads=0 --with-shared=0
[0]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
unable to read the cmd header on the pmi context, Undefined dynamic error code.
job aborted:
rank: node: exit code[: error message]
0: dmrc-6700512: 59: application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
I think this error maybe caused by these codes,
 PetscMap *map;
 ierr = PetscMapInitialize(PETSC_COMM_WORLD, map);
 CHKERRQ(ierr);
 ierr = PetscMapSetSize (map, n);
 ierr = PetscMapGetLocalRange(map,&Istart,&Iend); CHKERRQ(ierr);
Is it correct to use the PetscMap like this?
Best,
Yixun
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20061102/d5699587/attachment.htm>
