Using valgrind on petsc projects
Berend van Wachem berend at chalmers.se
Sun May 28 15:03:09 CDT 2006
I am using Petsc with Open-Mpi and have started to use valgrind to find
a bug. One of the things that I see is that there is memory lost in
PetscInitialize by calling MPI_Init and in DACreate (which I do quite
often in my project). The amounts of memory lost aren't huge; should I
be alarmed?
To give an example, I have attached the output of valgrind on
$PETSC_DIR/src/snes/examples/tutorials
Berend.
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20060528/7cd3e5b6/attachment.diff>
